Results 1 to 3 of 3
Thread: Measuring Blocks at Polo AW 2018 (Brazil)
    Jul 2019
    Brazil
    I have a Polo AW 2018 (Brazil) and I'm entering the Engine part and the Measuring Blocks option is disabled for me.
    What can I do to get inside this session?
    Thank you.
     Sunday,18,August,2019,12:05:35:00092
    VIN: 9BWAL5BZ1JP065524   License Plate:
    Mileage: 13154km-8173mi   Repair Order:
    Chassis Type: BZ-VW27 (2QW)
    Scan: 01 03 08 09 15 17 19 44 5F
    VIN: 9BWAL5BZ1JP065524   Mileage: 13154km-8173miles
    Address 01: Engine (0001-CNXC)       Labels: None
       Part No SW: 04E 906 032 AS    HW: 04E 907 425 F
       Component: R4 1.6l MPIH04 5245
       Revision: --H04---
       Coding: 01110016020400000000
       Shop #: WSC 01530 935 00200
       ASAM Dataset: EV_ECM16MPI02104E906032AS 002002
       ROD: EV_ECM16MPI02104E906032AS_002.rod
       VCID: 71BFD582F1291F4F357-8024
    Readiness: 1110 0001
       Part No SW: 2Q0 614 517 S    HW: 2Q0 614 517 L
       Component: ESC_base      H13 0222
       Serial number: 86400234180113
       Coding: 31044B6717478CB2D201E81814DE126A49444926224A242444542254452848569222926444522424222A442AA22924400494240220
       ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
       ROD: EV_Brake1BOSCHESPMQBA0.rod
       VCID: 3E253EBEF0F7B037F85-806A
       Part No SW: 6EA 820 045     HW: 6EA 820 045
       Component: SG_AC_Manuell H50 0301
       Coding: 012000000800000010000000000000000000000000000000000000000000
       ASAM Dataset: EV_ACManuePrehMQBA0 001011
       ROD: EV_ACManuePrehMQBA0_VW27.rod
       VCID: 6FBBD3FAE71D09BF233-803A
       Part No SW: 2QW 937 089     HW: 2QW 937 089
       Component: BCM A0 Entry  H65 0612
       Serial number: 70117321034801
       ASAM Dataset: EV_BCMA0 104001
       ROD: EV_BCMA0_104.rod
       VCID: 1E65DE3E5037D037D85-804A
       Drivers Door Control Module:
       Subsystem 1 - Part No SW: 2Q1 959 881     HW: 2Q1 959 881
       Component: FHSG_DRV  001 0001
       Serial number: 00000000000018908601
       Coding: 130000
       Subsystem 2 - Part No SW: 2Q1 959 882     HW: 2Q1 959 882
       Component: FHSG_PSG  001 0001
       Serial number: 00000000000019263829
       Coding: 090000
       Serial number: 000000000ZY1733326BA
       Subsystem 4 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
       Component: FOND_FHSG_DRV  006 0007
       Serial number: 00000000000018610958
       Coding: 030000
       Subsystem 5 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
       Component: FOND_FHSG_PSG  006 0007
       Serial number: 00000000000018592473
       Coding: 1B0000
       Part No SW: 2QB 959 655     HW: 2QB 959 655
       Component: VW22Airbag    010 0246
       Revision: --------
       Coding: 88C0C00000000000540000CF000000000065
       ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
       ROD: EV_AirbaVW22BPAVW27X.rod
       VCID: 0C41A476F6CB52A7A61-8058
       Subsystem 1 - Part No SW: -----------    HW: 442 1A1 912 17
       Component: SideSensor_Df  2C4 0148
       Serial number: 349B4D19B28A7CC5A349
       Subsystem 2 - Part No SW: -----------    HW: 442 1A1 912 17
       Component: SideSensor_Pf  2C4 0148
       Serial number: 350B4D1AD28A7CC64192
       Subsystem 3 - Part No SW: -----------    HW: 442 131 708 17
       Component: FrontSensor_D  290 118A
       Serial number: 355AG119926DCC3254C1
    Address 17: Instruments (J285)       Labels:* None-SRI3
       Part No SW: 6EA 920 740 A    HW: 6EA 920 740 A
       Component: KOMBI         309 0460
       Coding: 442D02002000000C020830001000000000000000
       ASAM Dataset: EV_DashBoardVDDMQBA0 001020
       ROD: EV_DashBoardVDDMQBA0_VW27.rod
       VCID: 33331F8ACBB56D5F07B-8066
       Part No SW: 2QW 909 901     HW: 2QW 937 089
       Component: GW MQB A0     H65 0612
       Coding: 0101000020086400F8000008080F00000000000000000000000000000000
       ASAM Dataset: EV_GatewA0 013020
       ROD: EV_GatewA0_VW27.rod
       VCID: 1675C61EB8079877005-8042
       Subsystem 2 - Part No SW: 18D 959 442     HW: 18D 959 442
       Component: E221__MFL-YLG  H01 0120
       Serial number: 000000000A0133111017
       Coding: 200000
    Address 44: Steering Assist (J792)       Labels:* None
       Part No SW: 2Q1 909 144 J    HW: 2Q1 909 144 F
       Component: TRW_G4L_MQBA0 610 6030
       Serial number: 01HBL0F9DC15GR0
       Coding: 00000001000000000101020101000101000001
       ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
       ROD: EV_SteerAssisTRWG4LMQBA0_009.rod
       VCID: 392F2DA2E9D9970FCD7-806C
       Part No SW: 5G0 035 280 C    HW: 5G0 035 280 C
       Component: MU-G--RW      557 5516
       Serial number: VWZ7Z2U3601014
       Coding: 02721000AA00000000220001010000002F0006140000010003
       Shop #: WSC 12345 123 61029
       ASAM Dataset: EV_MUGlb4CGen25TPWR 001001
       ROD: EV_MUGlb4CGen25TPWR_VW27.rod
       VCID: 211FE5C26149EFCFE57-8074
    End----------(Elapsed Time: 00:37, VBatt start/end: 12.5V/12.3V)-----------
    Please see:
    https://forums.ross-tech.com/showthread.php?1905
    Short version: ECU uses UDS protocol, which does not support the old "Measuring Blocks" function. Use Advanced Measuring Values instead.
    This question seems to be asked quite often, would it be possible for VCDS to leave the Measuring Blocks button enabled but if clicked with a UDS controller show a message box telling the user that as it's a UDS controller they need to use Advanced Measuring Values instead?
    That would save having to keep answering the question on the forum
