Results 1 to 10 of 16
Thread: LED Headlight Issues
    Verified VCDS User bip78's Avatar
    Aug 2018
    This morning I installed a new/replacement OEM Audi LED full headlight for my C7 RS6.
    From what I can see, everything works fine, all the light functions are active as they need to be - HOWEVER I am getting error message come up on my display. I have used VCDS to clear the DTCs and they pop up again afterwards.
    Would anyone be able to advise on these errors and if VCDS can rectify?
    393989 - Headlight
    Reset counter: 66
    Mileage: 94447 km
    Date: 2019.08.17
    Time: 17:38:58
    Aug 2018
    The fan error is resolved, so no need to worry about that. The previous is the only error.
    Saturday,17,August,2019,17:47:57:06608
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 20 22 28 30 34 36 3B 42 44
              46 47 52 53 55 56 5F 62 65 69 6D 72 BA
    VIN: X   Mileage: 94447km-58686miles
    BA-Motor Mounts -- Status: OK 0000
    Address 01: Engine (------CRDB)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 4G0 906 560     HW: 4H0 906 014
       Component: 4.0l V8TFSI / H62 0012
       Revision: NCH62---
       Coding: 122A00326536030A0800
       Shop #: WSC 33788 001 1048576
       ASAM Dataset: EV_ECM40TFS0114G0906560 001013
       ROD: EV_ECM40TFS0114G0906560.rod
       VCID: 6597B0E185E05B2F59F-8030
    Readiness: 1110 1101
       Part No SW: 4G0 927 158 BD    HW: 0BK 927 156 AM
       Component: 0BK 40TFSIRdW H16 1006
       Revision: --H16---
       Coding: 000001
       VCID: 71BFD4B14128878F357-8024
       Part No SW: 4G0 907 379 P    HW: 4G0 907 379 P
       Component: ESP PREMIUM   H09 0100
       Coding: 62B7DB0146EDDB80EB00
       ASAM Dataset: EV_ESPPremiAU57X 004036
       VCID: 3E253F8D40F628F7F85-806A
       Part No SW: 4H0 907 064 EN    HW: 4H0 907 064 EN
       Component: BCM2 2.0      H36 0521
       Coding: 01B93046000000000000
       VCID: 79AFEC9119D8CFCF8D7-802C
       Serial number: 0214000018443002
       Part No SW: 4G0 820 043 AM    HW: 4G0 820 043 AM
       Component: KLIMA 4 ZONEN H14 0093
       Serial number: 03031400040247
       Coding: 682200B809
       ASAM Dataset: EV_AirCondiComfoUDS 004003
       ROD: EV_AirCondiComfoUDS_004.rod
       VCID: 6A8DC3DD6CFE745774D-803E
       Revision: 11012002    Serial number: 00000001524549
       Coding: 090F2011097C9FE02F8100C7A0001800CF9DE70A2F080201800108546F00
       VCID: 6FBBD2C9579C917F233-803A
       Component: WWS57X 140214  H37 0080
       Serial number:         140222014234
       Coding: 0045F7
       Serial number: 22323029
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 S    HW: 4G0 941 531 S
       Component: E1 - LDS  H07 0044
       Serial number: 20 02 2014  00001245
       Subsystem 4 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
       Serial number: 00000025021400010395
       Coding: 110000
       Serial number: 00000017021400010091
       Coding: 110000
       Subsystem 6 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA107528000006093776
       Coding: 020300
       Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: D6688617000000000001
    03528 - Fan for Left Headlight
                        Reset counter: 66
                        Mileage: 94447 km
                        Date: 2019.08.17
                        Time: 17:42:00
       Part No SW: 4H0 919 475 AC    HW: 4H0 919 475 AG
       Component: PARKHILFE ACC H01 0091
       Revision: 11001001    Serial number: 61031405300682
       Coding: 89C30F
       VCID: 73B3DEB93B34B59FC7B-8026
       Revision: --------    Serial number: 003JG00H1L1Z
       Coding: 3032343631334E303537554A305234473053
       VCID: 363527AD68C6E0B7205-8062
       Serial number: 3575HRB404V2DE2S4PNA
       Serial number: 3585HRB405L2DJEQ88H+
       Serial number: 3515JRB400I50TIS79DU
       Serial number: 3525JRB400G50U80NP2D
       Serial number: 3554VRB400M50T8GM0O1
       Serial number: 3564VRB400M50T8GLOMN
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Revision: --------    Serial number: 90372NBR000AW
       Coding: 000035
       VCID: 372B2AA96F4C19BF3B3-8062
       Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
       Serial number: 06 02 2014  D0399850
       Part No SW: 4G0 920 981 Q    HW: 4G0 920 981 Q
       Component: TBenGb    Nv  H58 0621
       Revision: 29460235    Serial number: 658010314596009
       Coding: 33AF110B9B412600010400
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K_AU57.rod
       VCID: 392F2C9159D80FCFCD7-806C
       Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
       Revision: --------    Serial number: 00000001297166
       Coding: 00ED074800
       VCID: 72BDDBBD442EBC97CCD-8026
       Serial number: 5240922603
       Voltage stabilizer:
       Serial number: 131215000000000000BE
       Revision: AA001002
       Coding: 04028264747464545425363E00
       VCID: 7CA1F58516EAFAE7961-8028
    Address 22: AWD (J492)       Labels: 4H0-907-163.clb
       Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
       Component: 4 Wheel Drive H16 0200
       Serial number: 002102140001899
       ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
       VCID: 2809F9D5B2728647A29-807C
       Part No SW: 4G0 919 158 N    HW: 4G0 919 158 N
       Component: KLIMA FOND    H08 0093
       Serial number: 05031400040322
       Coding: 22
       ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
       VCID: 3A2D339D5CDE04D7C4D-806E
       Part No SW: 4H0 907 440     HW: 4H0 907 440
       Component: STS           H06 0030
       Revision: S0H06000    Serial number: 00000000055306
       Coding: 01010101000000000001000102
       VCID: 6491ADE58E5A22274E1-8030
       Part No SW: 4G0 907 553 F    HW: 4G0 907 553 F
       Component: LUFE-DAEMPFER H18 0782
       Coding: 008001
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2E050FCD9096D877685-807A
       Revision: AA000000    Serial number: 00000092653407
       VCID: 77ABEAA92FCCD9BFFB3-8022
       Component: SARA 6D red   H03 0056
       Revision: --------    Serial number: EJ1BPA7E00WKXE
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 372B2AA96FCC19BF3B3-8062
       Coding: 011F16005E21620002080002
       VCID: 47CB5A691FAC693F4B3-8012
       Component: RCEPS         H40 0010
       Revision: 00001000    Serial number: 0023336351
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 323D1BBD84AEFC970CD-8066
       Revision: 00002001    Serial number: 0329024856
       Coding: 013B0620A0B9389483300984200113470000000000000000000000000000
       Subsystem 3 - Part No SW: 4G9 959 591     HW: 8V3 959 591
       Component: J245 PS20.008  H02 0007
       Serial number:     WOO2696686H
       Coding: 901E00
       Subsystem 4 - Part No SW: 4G0 947 135 K    HW: 4G0 947 135
       Serial number: 0000000AP00006355335
       Subsystem 5 - Part No SW: 4G9 959 591     HW: 8V3 959 591
       Component: J394 PS20.008  H02 0007
       Serial number:     WOO26932589
       Coding: 801E00
       Revision: CJ007001    Serial number: 00000000078625
       Coding: 030000
       VCID: 1D67D801EDB053EFC1F-8048
       VCID: 46D5576D18A67037B05-8012
       Component: EPB-4         H03 0015
       Revision: --------    Serial number: 00000000984999
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2D0708C19D90A36F51F-8078
       Serial number: 140307-0002-120
       Coding: 11226F601000A300
       ROD: EV_HeadlRegulBasic.rod
    393989 - Headlight
                        Reset counter: 66
                        Mileage: 94447 km
                        Date: 2019.08.17
                        Time: 17:42:26
       Part No SW: 4G0 035 061 N    HW: 4G0 035 061
       Component: Radio U DAB   H60 0139
       Revision: AB001007    Serial number: 109BW0E7872402
       Coding: 010103010000000001
       VCID: 2809F9D5B2F28647A29-807C
       Part No SW: 4G0 035 666 J    HW: 4G0 035 666 H
       Component: H-BN-EU       H52 0798
       Revision: --------    Serial number: 189C/0E7575230
       Coding: 070101010303F1FD4780AF3E00000003E00001020000000000
       VCID: 2F3B12C9971CD17F633-807A
       Subsystem 1 - Part No: 8R0 060 884 BK
       Component: EUR 2014  1703
       Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
       Component: DU8 C7 SV  H43 0021
       Serial number: AUZ8ZDDD003XRSX
       Subsystem 3 - Part No SW: 4G2 919 612 Q    HW: 4G2 919 612 Q
       Serial number: 90349NC4000E2
       Component: CD-Database  5571
       Coding: 010F14004021620002080002
       VCID: 49CF5C5109B89F4F5D7-801C
    Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
       Part No SW: 4H0 907 273     HW: 4H0 907 273
       Component: RDKBERU25     H09 0700
       Serial number: 10000000007172
       ROD: EV_RDKBERU25_AU57.rod
       VCID: 6889B9D572F24647629-803C
    Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
       Part No SW: 4G8 907 383     HW: 4G8 907 383
       Component: Anhaenger     H11 0100
       Revision: 5G001001    Serial number: 00000328844824
       Coding: 0109080000000000
       VCID: 71BFD4B141A8878F357-8024
       Part No SW: 4G9 959 107 B    HW: 4G9 959 107 A
       Component: HDSG-Modul    H03 0143
       Revision: 14003001    Serial number: 059401173
       Coding: 097205C011
       ROD: EV_HDSGAu571.rod
       VCID: 353720A175C0EBAF29F-8060
    Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
       Part No SW: 4H0 907 145 B    HW: 4H0 907 145
       Component: AEM - LEAR    H07 0008
       Revision: 00001001    Serial number: 97812003331401
       ASAM Dataset: EV_AEMLearAU64X 002016
       ROD: EV_AEMLearAU64X_AU57.rod
    End----(Elapsed Time: 02:35, VBatt start/end: 11.8V/11.8V. VIgn 11.9V)-----
    Curious: Why did you replace the headlights? Is this a repair to factor specs or some kind of retrofit?
    Should be pretty standard using these basic settings:
    IDE03675-ENG103121 -- Basic headlamp setting
    IDE03676-ENG103121 -- Acknowledge basic setting
    Much like this:
    http://wiki.ross-tech.com/wiki/index...#Basic_Setting
  5. Likes DrPeter, Dana, bip78 liked this post
    Aug 2018
    Hi Uwe,
    My front headlight was hit by a big ass stone and cracked the outer lens. With condensation building up I didn’t want that worry, so bought a replacement headlight.
    As these are the high end lights the above mentioned seems to be relevant to halogens/Xenons not the LEDs.
    Quote Originally Posted by bip78 View Post
    OK, since you're Verified now, moving this to Car Repair Support.
    Those LEDs still move up and down, but not side-to-side. So although they were sold as "high end" at the time, from a functional standpoint, they really aren't. Also, I did check the data for your specific headlight range module, EV_HeadlRegulBasic before posting advice.
    Aug 2018
    Ok thanks Uwe. What would you suggest to rectify this problem? Have I missed something ?
  9. #8
    OP
    You could install the correct headlights to comport with a repair as certified, no?
    What's this do?
    1221A6601002A400
    12216F601002A400
  10. #9
    Aug 2018
    OP
    What's this do?
    1221A6601002A400
    12216F601002A400
    Sorry Jack I dont understand. The correct headlights are installed - therefore its a case of updating so the headlight are reading from the same source file. As per previous posts, it would seem the replacement headlight is missing its file(s) and wont read frm the other headlights module to solve the issue.
    I would assume a fresh file is needed for both?
  11. #10
    Did you perform the adaptions that Uwe directed you too?
  12. Likes Uwe, Dana, DrPeter liked this post
