Results 1 to 4 of 4
Thread: Steering column lock
    Oct 2017
    The car is a 2017 RS3 with keyless ignition. I've experienced an issue several times where the car will not start due the the steering column being locked. I've tried to turn the steering wheel while the wheels on the ground with no luck. Oddly, if I lift the front end off the ground and remove pressure off the steering system the car will start. Here is the full autoscan, as you can see lots of messages, the TPMS messages are due to putting on a set of wheels that did not have sensors in them for a few days.
    Sunday,18,August,2019,12:04:42:24295
    VIN: WUABWGFF9H1900173   License Plate:
    Mileage: 43596km-27089mi   Repair Order:
    Chassis Type: FF-AU37 (3Q0)
    Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 29 2B 39 3C 42 44 47
              52 55 5F 65 6C BB BC CF D6 D7
    VIN: WUABWGFF9H1900173   Mileage: 43596km-27089miles
    29-Left Light -- Status: Malfunction 0010
    39-Right Light -- Status: Malfunction 0010
    6C-Back-up Cam. -- Status: Cannot be reached 0100
    Address 01: Engine (------DAZA)       Labels:. 07K-907-309-V1.clb
       Part No SW: 8V0 907 404 G    HW: 07K 907 309 E
       Component: R5 2.5l TFSI  X21 0004
       Revision: 53X21000
       Coding: 0A250032242600053620
       ASAM Dataset: EV_ECM25TFS0118V0907404G 001004
       ROD: EV_ECM25TFS0118V0907404G.rod
       VCID: 3D27C5225DF4409FE1F-8068
    10064 - Fuel Pump
              P308D 00 [096] - RPM too Low
                        Mileage: 43320 km
                        Date: 2019.08.15
                        Time: 08:41:58
                        Engine speed: 7098.50 /min
                        Normed load value: 65.9 %
                        Vehicle speed: 200 km/h
                        Coolant temperature: 93 °C
                        Intake air temperature: 52 °C
                        Voltage terminal 30: 12.540 V
                        Fuel pump: specified value: 77.423 %
                        Low fuel pressure: specified value: 500.0 kPa
                        Fuel temperature: 39.8 °C
                        Adaptation of Fuel Pump (FP): -83.4 kPa
                        High fuel pressure: specified value: 24.0000 MPa
    10203 - Random/Multiple Cylinder Misfire Detected
              P0300 00 [100] - -
                        Mileage: 43436 km
                        Date: 2019.08.15
                        Time: 14:34:26
                        Engine speed: 6029.00 /min
                        Normed load value: 71.0 %
                        Vehicle speed: 124 km/h
                        Coolant temperature: 98 °C
                        Intake air temperature: 56 °C
                        Voltage terminal 30: 13.000 V
                        Unlearning counter according OBD: 68
                        Engine status: COENG_RUNNING
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
    10594 - Cylinder 4
              P0304 00 [100] - Misfire Detected
                        Mileage: 43436 km
                        Date: 2019.08.15
                        Time: 14:34:26
    10595 - Cylinder 5
              P0305 00 [100] - Misfire Detected
                        Mileage: 43436 km
                        Date: 2019.08.15
                        Time: 14:34:26
    Readiness: 0010 0001
       Part No SW: 0DL 300 012 H    HW: 0GC 927 711 G
       Component: GSG DQ500     H06 2112
       Revision: 00H06V07
       VCID: 2E05F26E8092AB07685-807A
       Part No SW: 8V0 614 517 C    HW: 8V0 614 517 C
       Component: ESC           H25 0621
       Revision: 00000000    Serial number: 60457000000243
       Coding: 2EAA6B7DD4990BA989920B6B81946974D62BD091D081963602415084028812
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
       VCID: 392FD13249DC7CBFCD7-806C
    9 Faults Found:
    8246 - Databus
              [FCAN: Motor_Code_01 message is not received]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:58
    8250 - Databus
              [FCAN: Motor_07 message is not received]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:58
    8252 - Databus
              [FCAN: Motor_11 message is not received]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:53
    8254 - Databus
              [FCAN: Motor_12 message is not received]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:53
    8256 - Databus
              [FCAN: Motor_14 message is not received]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:54
    8258 - Databus
              [FCAN: Motor_20 message is not received]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:53
    8264 - Databus
              [FCAN: Tsk_06 message is not received]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:53
    8351 - Databus
              [FCAN: Motor_17_alt veraltet bit is set]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:55
    8400 - Databus
              [FCAN: AB_Gurt_FA signal is invalid]
                        Reset counter: 168
                        Mileage: 43295 km
                        Date: 2019.08.15
                        Time: 08:27:44
       Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
       Revision: 00021000    Serial number: 0434002464
       Coding: 030C0C
       VCID: 3B23CB3A43E04EAFDFB-806E
    12716804 - Databus
              [Ausfall Motor_14 - Botschaft -  kein Signal/Kommunikation]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:54
       Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
       Component: AC Automat    H03 0130
       Revision: 20002000    Serial number: 00000001172916
       Coding: 03000015010000000000000000001400
       ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
       VCID: 40D9BCD62A062D778A9-8014
       Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Serial number: EF08869800PAG0MUFU03
    459023 - Databus
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:53
       Part No SW: 5Q0 937 085 BF    HW: 5Q0 937 085 BF
       Component: BCM MQBAB MNA H34 0236
       Serial number: 02001705300865
       ROD: EV_BCMBOSCH_017.rod
       VCID: 7EA5022E10729B87B85-802A
       Component: WWS371 170117  043 0585
       Serial number:         170201053603
       Coding: 0A47F7
       Serial number: 62658002
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
       Component: E1 - LDS MQB  H06 0032
       Serial number: 22 12 2016  00001718
       Serial number: 00000000000068746455
       Sun Roof:
       Component: J245 PS73.404  H03 0004
       Serial number: 0000FST001GD2NJ00000
       Coding: 101F00
    6 Faults Found:
    204290 - Remote key 1
              B1479 18 [009] - Current Too Low
                        Reset counter: 108
                        Mileage: 41721 km
                        Date: 2019.08.02
                        Time: 15:14:32
    541973 - Databus
              [Motor_04 Datenbus fehlende Botschaft]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:53
    542229 - Databus
              [Motor_14 Datenbus fehlende Botschaft]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:53
    542485 - Databus
              [Motor_18 Datenbus fehlende Botschaft]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:54
    555541 - Databus
              [Motor_12_alt aktiv]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:53
    559125 - Databus
              [Motor_07 Datenbus fehlende Botschaft]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:54
       Part No SW: 5QA 919 294 A    HW: 5QA 919 294
       Component: PDC 8 KanalH07 0038
       Serial number: 000308418617056
       Coding: 0470155011
       ASAM Dataset: EV_EPHVA18AU3700000 009031
       VCID: 4ACD9EFE1C3AE72754D-801E
    12648465 - Databus
              [Motorsteuergerät - Motor_12 - kein Signal/keine Kommunikation]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:54
    13637426 - Databus
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:54
    12648468 - Databus
              [Motorsteuergerät - Motor_20 - kein Signal/keine Kommunikation]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:53
       Part No SW: 8V0 907 376 G    HW: 8V0 907 376 F
       Component: DAEMPFUNGS-SG H11 0082
       Serial number:       090117040
       ASAM Dataset: EV_AudiMagneRide 002008
       ROD: EV_AudiMagneRide.rod
       VCID: 45D7ADC23524085FB9F-8010
    6 Faults Found:
    10506241 - Databus
              [Motor_07_Timeout]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:58
                        COM: 0A DF 0A EF 00 01 03 DD 00 00
                        Voltage terminal 30: 12.0 V
                        Terminal 15 status via CAN: Terminal 15 on
                        Engine run: Not available
                        Engine torque: Not available
                        AMR state: 6
                        Damping adjustment indicator lamp: OFF
                        ESP automatic engagement: not activated
                        Fall-back level: 01 B0 20 00
    10510337 - Databus
              [Motor_11_Timeout]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:54
                        COM: 0A EF 0A EF 00 00 F3 BA 00 00
                        Voltage terminal 30: 12.1 V
                        Engine run: 0
                        Engine torque: -4 Nm
                        AMR state: 0
                        Fall-back level: 00 00 00 00
    10510339 - Databus
              [init value Moment Ist Sum]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:28:32
                        COM: 0A DF 0A FE 00 01 89 74 00 00
                        Engine run: 0
                        AMR state: 6
                        Fall-back level: 01 B8 20 00
    10510343 - Databus
              [init value Raw Soll Moment]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:28:32
                        Engine run: 0
                        AMR state: 6
    10514433 - Databus
              [Motor_14_TimeOut]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:54
                        COM: 0A DF 0A FE 00 00 F5 72 00 00
                        AMR state: 6
                        Fall-back level: 01 30 20 00
    10518529 - Databus
              [Motor_Code_01_Timeout]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:58
                        COM: 0A D0 0A EF 00 01 03 8C 00 00
                        AMR state: 6
       Serial number: 003GCR07ENV4
       Coding: 9DCCFCC0008000005000001AC24800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 47CBA7CA0F281A4F4B3-8012
       Belt Pretensioner left:
       Component: BeltPretRevFL  H37 0350
       Serial number: 34230167A28021750057
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H37 0350
       Serial number: 34230168A01031740816
       Coding: 333135
       Occupant Detection:
       Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
       Serial number: 694000000000001KJ98X
       Coding: 303337
       Subsystem 4 - Part No SW: -----------    HW: 480 002 602 17
       Serial number: 3570000000040B44E12C
       Subsystem 5 - Part No SW: -----------    HW: 480 002 602 17
       Serial number: 358000000009FA44E12W
       Subsystem 6 - Part No SW: -----------    HW: 480 401 502 17
       Serial number: 351000199247F13265F2
       Subsystem 7 - Part No SW: -----------    HW: 480 401 502 17
       Serial number: 352000199247F136536
       Subsystem 8 - Part No SW: -----------    HW: 480 401 601 17
       Serial number: 3550002C523C4E32E2EG
       Front Sensor Passenger:
       Subsystem 9 - Part No SW: -----------    HW: 480 401 601 17
       Serial number: 3560002C323C4E35B245
    1053952 - Databus
              [NWD: 0x121 Motor_20 Timeout]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:54
       Part No SW: 8V0 953 521 KK    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 02031704401807
       Coding: A018
       VCID: 0D4755E22DD4B01FB1F-8058
    Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
       Part No SW: 8V0 920 890     HW: 8V0 920 890
       Component: FBenUSA       H14 0046
       Coding: 086D18D33A88CF050204EE041800001000000000
       ASAM Dataset: EV_DashBoardFPKAU37X 001023
       ROD: EV_DashBoardFPKAU37X.rod
       VCID: 7AAD0E3E0C5AB7A784D-802E
    16776971 - Databus
              [Motor_04 communication error can_error_timeout]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:54
       Component: GW MQB High   515 5286
       Serial number: 28021710522664
       Coding: 03010004340860005B00822CB80B00000001010000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 2F3BEF6A8798A20F633-807A
       Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
       Component: J453 MFL  H04 0002
       Serial number: 20170210175324 22168
       Subsystem 3 - Part No SW: 8S0 915 181 C    HW: 8S0 915 181 C
       Serial number: 1384521504
    131689 - Rear View Camera System Control Module
              U104C 00 [009] - No communication
              [Timeout Knoten 0x69 / 6C - Steuergerät für Rückfahrkamerasystem]
                        Reset counter: 133
                        Mileage: 41260 km
                        Date: 2019.07.06
                        Time: 12:38:32
                        Terminal 15: On
    131702 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [008] - -
              [Timeout Knoten 0x76 / 01 - Motorsteuergerät]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:56
                        Terminal 15: On
       Part No SW: 0CQ 907 554 K    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7762
       Serial number: HA1-00001.09.16
       Coding: 0601
       VCID: 4DC795E2ED54F01F71F-8018
    6 Faults Found:
    17506 - Databus
              [Motorsteuergerät - TO -- Mot_07]
                        Fault Priority: 8
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:57
    17473 - Databus
              [Motorsteuergerät - TO -- Mot_11]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:53
    16657 - Databus
              [Motorsteuergerät - TO -- Mot_12]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:53
    17474 - Databus
              [Motorsteuergerät - TO -- Mot_14]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:53
    16727 - Databus
              [Motorsteuergerät - TO -- Mot_20]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:53
    17475 - Databus
              [Motorsteuergerät - TO -- Mot_Code]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:57
    Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
       Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
       Component: LCM_MQB       H06 0017
       ASAM Dataset: EV_LCMLeftCONTIAU426 001009
       ROD: EV_LCMLeftCONTIAU426_VW41.rod
       VCID: 42DDB6DE240A3F679CD-8016
    0279 - Databus
              [databus - message missing]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:54
       Revision: 00000000    Serial number: 17000608488008
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3431E0066EBE81D71E1-8060
    12666369 - Databus
              [Timeout Message Motor_14]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:53
                        ELV State: 04
                        Information Clamps: 77 60
                        CoCo State: A0 01
                        WFS State: 17 06
                        Vehicle speed: 0.00 km/h
                        Voltage: 68
                        AD-Value H-bridge: 33
                        Clamp15 flip flop: SSTx: button contacts: 06
                        CAN signals: 00
    12666381 - Databus
              [Timeout Message Motor_09]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:54
                        ELV State: 04
                        CoCo State: A0 01
                        WFS State: 17 06
                        Voltage: 68
                        CAN signals: 00
    Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
       ASAM Dataset: EV_LCMRightCONTIAU426 001009
    0279 - Databus
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:55
    Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
       Part No SW: 3Q0 907 566 D    HW: 3Q0 907 566
       Component: MRR1Rear      H16 0410
       Revision: --------
       Coding: 040002
       ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
    1183750 - Databus
              [databus message missing - Motor]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:55
                        Control Module temperature: 38 °C
                        Voltage terminal 30: Measured value not available
                        Terminal 15 status: Measured value not available
                        Voltage terminal 15: 11.70 V
       Serial number: 310117EAV06361
       Coding: 005D1B205C00048000000002
       VCID: 43D3B3DA3B10366F97B-8016
    458803 - Databus
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:54
       Coding: 8106
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 3A2DCE3E4CDA77A7C4D-806E
    6 Faults Found:
    23040 - Databus
              [MOTOR_20 Botschaft - CAN-Timeout]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:53
                        Motor status: 00
                        Supply voltage: 12.00 V
                        Temperature: 36.0 °C
                        KFC: 5A
                        KFA: 00 00
                        Environmental conditions: 20
                        uioUdNotFilt_xdu16: 12.02 V
                        uAdSensI_SwitchedKl30_xdu16: 12.01 V
                        RP_VALCNTSAV: not activated
                        RP_DIAGJOB: not activated
                        RP_RPS: not activated
                        RP_STARTUP: not activated
                        RP_L2PLAUSI: not activated
                        RP_INDEXPLAUSI: not activated
                        RP_RUKUCNTR: not activated
                        RP_UNDERVOLT: not activated
                        RP_CNTERR: not activated
    22272 - Databus
              [KFC_MOTOR_11 Botschaft - CAN-Timeout]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:54
                        Motor status: 00
                        KFC: 57
                        KFA: 00 00
                        uioUdNotFilt_xdu16: 12.17 V
                        uAdSensI_SwitchedKl30_xdu16: 12.16 V
    22528 - Databus
              [MOTOR_12 Botschaft - CAN-Timeout]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:54
                        Motor status: 00
                        KFC: 58
                        KFA: 00 00
    22784 - Databus
              [MOTOR_14-Botschaft - CAN-Timeout]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:54
                        Motor status: 03
                        System status: Driving mode
                        KFC: 59
                        KFA: 00 00
    19460 - Databus
              [ESP_05 Botschaft - SNA-Check]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:54
                        Motor status: 03
                        KFC: 4C
                        KFA: 00 04
    23296 - Databus
              [MOTOR_CODE_01 Botschaft - CAN-Timeout]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:58
                        Motor status: 03
                        KFC: 5B
                        KFA: 00 00
                        uioUdNotFilt_xdu16: 12.14 V
                        uAdSensI_SwitchedKl30_xdu16: 12.14 V
       Part No SW: 81A 035 466     HW: 81A 035 466
       Component: MIB2_amp_P_A3 H10 0100
       Revision: 00000001    Serial number: AUZ8ZAGHX00H2MK
       Coding: 0173030000AAAA2AAA0000010000
       ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
       ROD: EV_AMPMst16C9Gen2ALPI.rod
       VCID: 629D565E84CA5F67BCD-8036
       Serial number: 030217EB326689
       Coding: 005D13205E00048000000002
    458803 - Databus
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:54
       Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0230
       Coding: 0E62021123200400
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
       VCID: 3E25C22E50F25B87F85-806A
    13705475 - Databus
              [Motor_20 Datenbus fehlende Botschaft]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:54
    Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
       Part No SW: 8V1 035 880 A    HW: 8V1 035 880
       Component: MU-P-LNS-US   053 0906
       Serial number: A702B0HS002089
       Coding: 017361020000000011220002041A00102F0028E5017001047E
       VCID: 3829D43672D665B7329-806C
       Subsystem 1 - Part No SW: V03 959 801 PS    HW: -----------
       Component: NAR 2018  --- 0063
       Component: DU High  H49 0014
       Serial number: AUZ8Z9G1Y00Y85
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
       Component: ControlUnit_H  H85 0855
       Serial number: ALJAL112011700010068
       Component: Gracenote2---  --- 3011
    6 Faults Found:
              B11CF 53 [009] - Deactivated
                        Reset counter: 89
                        Mileage: 41260 km
                        Date: 2019.07.06
                        Time: 12:43:25
                        Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                        Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
    5637 - Control Head for Multimedia System; NAV Button
              B1291 F6 [008] - Unknown Error Elaboration
                        Reset counter: 151
                        Mileage: 41260 km
                        Date: 2019.07.06
                        Time: 12:45:55
    5656 - Control Head for Multimedia System; RADIO Button
              B1291 FC [008] - Unknown Error Elaboration
                        Reset counter: 134
                        Mileage: 41260 km
                        Date: 2019.07.06
                        Time: 12:45:55
    1562 - Microphone 1
              B129B 11 [008] - Short to Ground
                        Reset counter: 168
                        Mileage: 43446 km
                        Date: 2019.08.15
                        Time: 14:38:53
                        Voltage terminal 30: 13.8 V
    6708 - Databus
              [Engine: no communication]
                        Reset counter: 167
                        Mileage: 43169 km
                        Date: 2019.08.14
                        Time: 20:27:58
    7179 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Rear-view camera (0x0B) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 89
                        Mileage: 41260 km
                        Date: 2019.07.06
                        Time: 12:38:36
                        BAP-BAP_Function_ID: 02
    Address 65: Tire Pressure (J502)       Labels: None
       Part No SW: 8S0 907 273     HW: 4M0 907 273 B
       Component: RDKHUFAU736   H04 0002
       Serial number: 40000000004695
       ASAM Dataset: EV_RDKHUFAU736 002007
       ROD: EV_RDKHUFAU736_AU37.rod
       VCID: 77AB170A3F48AACFFB3-8022
    9 Faults Found:
    8397058 - Front Left TPMS Sensor
              C1050 31 [008] - No Signal
                        Reset counter: 159
                        Mileage: 41523 km
                        Date: 2019.07.27
                        Time: 17:09:30
                        Expanded ambient data 6-Vehicle speed: 123.65 km/h
                        Expanded ambient data 6-Outside air temperature: 30.00 °C
                        Left front tire pressure sensor: remaining oper. life: 127 m
                        Left front tire pressure sensor: identification-Manufacturer code: numerical value: no text
                        Left front tire pressure sensor: identification-Sensor identification number (sensor ID): 691391293
    8397314 - Front Right TPMS Sensor
              C1051 31 [008] - No Signal
                        Reset counter: 159
                        Mileage: 41523 km
                        Date: 2019.07.27
                        Time: 17:09:30
                        Right front tire pressure sensor: remaining oper. life: 127 m
                        Right front tire pressure sensor: identification-Manufacturer code: numerical value: no text
                        Right front tire pressure sensor: identification-Sensor identification number (sensor ID): 691389745
    8397570 - Rear Left TPMS Sensor
              C1052 31 [008] - No Signal
                        Reset counter: 159
                        Mileage: 41523 km
                        Date: 2019.07.27
                        Time: 17:09:30
                        Left rear tire pressure sensor: remaining oper. life: 127 m
                        Left rear tire pressure sensor: identification-Manufacturer code: numerical value: no text
                        Left rear tire pressure sensor: identification-Sensor identification number (sensor ID): 692634682
    8397826 - Rear Right TPMS Sensor
              C1053 31 [008] - No Signal
                        Reset counter: 159
                        Mileage: 41523 km
                        Date: 2019.07.27
                        Time: 17:09:30
                        Right rear tire pressure sensor: remaining oper. life: 127 m
                        Right rear tire pressure sensor: identification-Manufacturer code: numerical value: no text
                        Right rear tire pressure sensor: identification-Sensor identification number (sensor ID): 691388705
    8389633 - Adapatation Not Possible
              C112C 00 [008] - Tire Pressure Sensor(s) Defective or No Signal
                        Reset counter: 159
                        Mileage: 42296 km
                        Date: 2019.08.05
                        Time: 13:39:58
                        Radio interference levels: 28
    8400898 - Tires 01: Tire  Pressure Warning
              C111B 00 [009] - Pressure too Low
                        Reset counter: 128
                        Mileage: 43295 km
                        Date: 2019.08.15
                        Time: 08:18:43
                        Expanded ambient data 6-Vehicle speed: 19.14 km/h
                        Expanded ambient data 6-Outside air temperature: 14.50 °C
                        Expanded ambient data 2-Left front tire pressure sensor: nominal pressure: 2.70 bar
                        Expanded ambient data 2-Left front tire pressure sensor: actual pressure: 2.18 bar
                        Expanded ambient data 2-Left front tire pressure sensor: temperature: 27 °C
                        Expanded ambient data 2-Left front tire pressure sensor: identification: 691389745
    8400901 - Tires 02: Tire  Pressure Warning
              C111D 00 [009] - Pressure too Low
                        Reset counter: 128
                        Mileage: 43295 km
                        Date: 2019.08.15
                        Time: 08:18:52
                        Expanded ambient data 6-Vehicle speed: 15.75 km/h
                        Expanded ambient data 3-Right front tire pressure sensor: nominal pressure: 2.70 bar
                        Expanded ambient data 3-Right front tire pressure sensor: actual pressure: 2.15 bar
                        Expanded ambient data 3-Right front tire pressure sensor: temperature: 23 °C
                        Expanded ambient data 3-Right front tire pressure sensor: identification: 691391293
    8400904 - Tires 03: Tire  Pressure Warning
              C111F 00 [009] - Pressure too Low
                        Reset counter: 128
                        Mileage: 43295 km
                        Date: 2019.08.15
                        Time: 08:23:12
                        Expanded ambient data 6-Vehicle speed: 16.73 km/h
                        Expanded ambient data 4-Left rear tire pressure sensor: nominal pressure: 2.65 bar
                        Expanded ambient data 4-Left rear tire pressure sensor: actual pressure: 2.18 bar
                        Expanded ambient data 4-Left rear tire pressure sensor: temperature: 25 °C
                        Expanded ambient data 4-Left rear tire pressure sensor: identification: 691388705
    8400907 - Tires 04: Tire  Pressure Warning
              C1121 00 [009] - Pressure too Low
                        Reset counter: 128
                        Mileage: 43302 km
                        Date: 2019.08.15
                        Time: 08:34:13
                        Expanded ambient data 6-Vehicle speed: 167.94 km/h
                        Expanded ambient data 6-Outside air temperature: 19.50 °C
                        Expanded ambient data 5-Right rear tire pressure sensor: no: 2.65 bar
                        Expanded ambient data 5-Right rear tire pressure sensor: actual pressure: 2.30 bar
                        Expanded ambient data 5-Right rear tire pressure sensor: temperature: 29 °C
                        Expanded ambient data 5-Right rear tire pressure sensor: identification: 692634682
    Address 6C: Back-up Cam.
       Serial number: 240117EAN1063C
       Coding: 000C13204000048000000002
       Serial number: 240117EAN10638
    Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
       Part No SW: 3Q0 907 590 D    HW: 3Q0 907 590
       Revision: --------
       Coding: 040002
       ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
       VCID: 3635DA0E78C293C7205-8062
       Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A
       Component: LED1L         H09 0008
       VCID: 176B378A1F084ACF1B3-8042
       Component: LED1R         H09 0008
    End----------(Elapsed Time: 02:09, VBatt start/end: 12.0V/11.9V)-----------
    Wow, lotta fault codes in that car! Clear all fault codes and let's see what comes back.
    Oct 2017
    Unfortunately all those (other than the TPMS) came at once on my last track day. I found the limits of my RS3... I'll clear the codes and see if the steering code comes up again by itself.
    Nov 2017
    Bay Area, CA
    Whole lotta data bus codes.
    Something on the bus crashing communication perhaps? Time to start unplugging modules until the CAN bus is happy again?
    Also, the key code might just be a low battery in the fob. KESSY systems are extra sensitive to battery voltage and effectiveness of the transponder key. I think they say once the battery gets below 3.06V the door touch features stop responding more often than not. Get below 3V and it might not detect the key to allow start authorization (which is funny, because the battery is rated at 3V... but if you measure a new battery, they usually are more like 3.3V, so there's that).
