Results 1 to 10 of 13
Thread: ABS Hydraulic Unit Replacement - Original Code not working
    Aug 2019
    My apologies for posting this twice but it seemed like this was the better place to post this. I can't see how to move the original thread or remove it.
    My ABS Module was acting up so I took in to the dealership because my VIN fell under the recall. Unfortunately VW refused to replace the module because they were unable to do their software update. They wanted to charge me $2600 to replace the module and do the work.
    So I bought a replacement module from a junkyard based off the revised part number VW quoted me.
    Before installing the junkyard module I pulled the code off my original module which was: 113B400D492300FF880F02E5921E00413000
    After I installed the junkyard module I input this code but it was rejected in VCDS. I'm hoping someone out there can help me with coding this module. It's worth mentioning that the original part# was 1K0 907 379 AD but the new part number is 1K0 907 379 AN. According to VW this is the correct revised part number as the AD was phased out.
    Thanks in advance to anyone who is able to help.
    Here is my Auto-Scan prior to repair:
     Saturday,17,August,2019,14:31:05:54182
    VIN: 3VWHM71K49M015415   License Plate:
    Mileage: 270160km-167869mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
    VIN: 3VWHM71K49M015415   Mileage: 270160km-167869miles
    Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
       Part No SW: 07K 906 055 Q    HW: 07K 906 055 M
       Component: 2,5l R5/4V      G   9970
       Revision: G6H01---    Serial number: VWX7Z0H624C13L
       Coding: 0000071
       Shop #: WSC 43600 000 1048576
       VCID: 3C2134666A669D87D61-8068
    049441 - No Communication with ABS Brake Control Module
                   U0121 - 000 -  - Intermittent
                        Fault Frequency: 69
                        Mileage: 269670 km
                        Time: 03:40:32
                        RPM: 708 /min
                        Load: 26.3 %
                        Temperature: 84.0C
                        Temperature: 45.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 13.970 V
    053271 - Please Check Fault Codes in Control Module for ABS Brakes
                   U1017 - 000 -
                        Fault Frequency: 36
                        Mileage: 269496 km
                        Time: 03:45:25
                        RPM: 3168 /min
                        Load: 43.5 %
                        Speed: 16.0 km/h
                        Temperature: 63.0C
                        Temperature: 41.0C
                        Voltage: 13.970 V
    050197 - Implausible Data Received from ABS Control Module
                   U0415 - 000 -  - Intermittent - MIL ON
                        Fault Status: 10100000
                        Fault Frequency: 135
                        Mileage: 269581 km
                        Time: 18:55:09
                        RPM: 2643 /min
                        Load: 67.4 %
                        Speed: 255.0 km/h
                        Temperature: 90.0C
                        Temperature: 65.0C
                        Voltage: 13.970 V
    001287 - Idle Control System RPM
                   P0507 - 000 - Higher than Expected. - Intermittent
                        Mileage: 269681 km
                        Time: 03:57:41
                        RPM: 1443 /min
                        Load: 12.9 %
                        Temperature: 86.0C
                        Temperature: 60.0C
                        Voltage: 13.843 V
    001281 - Vehicle Speed Sensor
                   P0501 - 000 - Implausible Signal - Intermittent
                        Fault Frequency: 6
                        Mileage: 270116 km
                        Time: 18:44:29
                        RPM: 2901 /min
                        Load: 52.1 %
                        Temperature: 80.0C
                        Temperature: 31.0C
                        Voltage: 14.097 V
                   U1017 - 000 -  - Intermittent
                        Mileage: 269992 km
                        Time: 06:02:56
                        RPM: 2772 /min
                        Load: 18.0 %
                        Speed: 107.0 km/h
                        Temperature: 86.0C
                        Temperature: 60.0C
                        Voltage: 13.970 V
       Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
       Component: ESP MK60EC1   H35 0104
       Revision: 00H35001
       Coding: 113B400D492300FF880F02E5921E00413000
       Shop #: WSC 00066 000 00000
       VCID: 74B1DC460EB615C7DE1-8020
    10 Faults Found:
    01130 - ABS Operation
                        Fault Frequency: 35
                        Reset counter: 216
                        Mileage: 269495 km
                        Count: 7
                        Count: 1
                        Count: 12800
                        Count: 125
                        Count: 19
                        Count: 3072
                        Count: 63232
                        Fault Frequency: 30
                        Reset counter: 176
                        Mileage: 270108 km
                        Count: 7
                        Count: 1
                        Count: 4608
                        Count: 89
                        Count: 116
                        Count: 63232
    00285 - ABS Wheel Speed Sensor; Front Right (G45)
                        Fault Frequency: 155
                        Reset counter: 176
                        Date: 2044.00.00
                        Time: 16:01:40
                        Count: 256
                        Count: 32944
                        Count: 51968
                        Count: 57
                        Count: 128
                        Count: 256
                        Count: 20912
                        Count: 7680
    00283 - ABS Wheel Speed Sensor; Front Left  (G47)
                        Fault Frequency: 86
                        Reset counter: 176
                        Mileage: 269796 km
                        Count: 7
                        Count: 1
                        Count: 4608
                        Count: 41
                        Count: 63232
                        Fault Status: 00101100
                        Reset counter: 176
                        Mileage: 270162 km
                        Count: 16391
                        Count: 512
                        Count: 56
                        Count: 63232
                        Reset counter: 176
                        Mileage: 270162 km
                        Count: 16391
                        Count: 512
                        Count: 88
                        Count: 63232
                        Reset counter: 176
                        Mileage: 656901 km
                        Date: 2000.08.00
                        Time: 16:16:17
                        Count: 1795
                        Count: 22
                        Count: 45056
                        Count: 72
                        Count: 61184
                        Count: 59649
                        Count: 80
                        Count: 45058
                        Reset counter: 176
                        Mileage: 270162 km
                        Count: 16391
                        Count: 512
                        Count: 40
                        Count: 63232
                        Fault Frequency: 203
                        Reset counter: 176
                        Mileage: 269796 km
                        Count: 7
                        Count: 1
                        Count: 4608
                        Count: 128
                        Count: 63232
    16352 - Control Module - Electrical Error
                014 - Defective
                        Fault Status: 01101110
                        Fault Frequency: 239
                        Reset counter: 176
                        Mileage: 270116 km
                        Count: 7
                        Count: 1
                        Count: 4608
                        Count: 233
                        Count: 60928
                        Count: 63232
       Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
       Component: Climatic PQ35   142 1111
       Revision: 00142031    Serial number: 00000000000000
       VCID: 7CA1F4662AE65D87961-8028
    01296 - Sensor for Vent Temperature; Center (G191)
                010 - Open or Short to Plus
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-M.lbl
       Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
       Revision: 00H54000    Serial number: 00000001005320
       Coding: 14058E234004100007140000001400000008730B5C000120000000000000
       Shop #: WSC 33311 002 1048576
       VCID: 6FBBD32A6B90361F233-803A
       Component: Wischer 150708 021  0501
       Coding: 00038805
       Shop #: WSC 33311
                        Reset counter: 205
                        Mileage: 269495 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.35 V
    00927 - Terminal 30 (Right)
                        Fault Status: 00101011
                        Reset counter: 181
                        Mileage: 269495 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.50 V
       Component: 6A AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6M0609BP
       Coding: 0013889
       VCID: 6C81C4265A86CD07061-8038
       Subsystem 1 - Part No: 1K0 959 339 H
       Component: BF-Gewichtsens. 007 0006
       Subsystem 2 - Serial number: 6332MSME29416E6FS
       Subsystem 3 - Serial number: 6342MSME3903684FK
       Subsystem 4 - Serial number: 6351HSME163F46136
       Subsystem 5 - Serial number: 6361HSME16631F29B
       Subsystem 6 - Serial number: 63727SME15693564%
       Subsystem 7 - Serial number: 63827SME160E5C212
    01316 - ABS Control Module
       Part No SW: 1K0 953 549 BR    HW: 1K0 953 549 BR
       Component: J0527           051 0101
       Coding: 0000021
       VCID: 03538F9A5718227FD7B-8056
       Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
       Component: KOMBIINSTRUMENT 3HL 1222
       Revision: V0003000    Serial number: VWX7Z0H624C13L
       Coding: 0023203
       Shop #: WSC 05226 444 57447
                        Fault Frequency: 68
                        Reset counter: 216
                        Mileage: 269495 km
                        Time: 06:07:31
       Component: J533  Gateway   H07 0062
       Revision:   H07 01    Serial number: 270508F1001414
       Coding: E9807F070002021002
       VCID: 35372142494C4CCF29F-8060
                        Fault Status: 00110100
                        Fault Frequency: 70
                        Reset counter: 216
                        Mileage: 269495 km
                        Time: 06:07:32
       Component: IMMO            3HL 1222
       Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
       Component: J386  TUER-SG FT    1519
       Revision: 72009005    Serial number: 00000605388703
       Coding: 0001205
                        Fault Frequency: 29
                        Reset counter: 216
                        Mileage: 269618 km
                        Fault Frequency: 172
                        Reset counter: 216
                        Mileage: 269495 km
    01030 - Central Locking Key Switch; Driver Side; Lock
                        Reset counter: 214
                        Mileage: 270060 km
       Part No: 1K0 909 144 C
       Component: EPS_ZFLS Kl. 69     2301
       Revision: 00H15000
       VCID: 2A0D023E90F21337B4D-807E
                        Fault Frequency: 62
                        Reset counter: 226
                        Mileage: 270153 km
                        Time: 05:23:24
                        Voltage: 14.00 V
                            DU
                        Temperature: 53.0C
                        RPM: 1946 /min
                        Speed: 28.0 km/h
                        Speed: 28.0 km/h
                        Fault Status: 00101101
                        Fault Frequency: 197
                        Reset counter: 226
                        Mileage: 270162 km
                        Time: 02:26:17
                        Voltage: 12.50 V
                            DD
                        Temperature: 28.0C
                        Fault Frequency: 128
                        Reset counter: 226
                        Mileage: 270161 km
                        Time: 06:37:22
                        Voltage: 14.00 V
                            DU
                        Temperature: 49.0C
                        RPM: 2138 /min
                        Speed: 63.0 km/h
                        Speed: 63.0 km/h
       Component:    KSG PQ35 RDK 052 0221
       Coding: 13900F880186281B0904058FB0880F0488DCA0
       VCID: 04518C8652162547EE1-8050
                        Reset counter: 216
                        Mileage: 270153 km
                        Time: 05:24:43
       Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
       Component: J387  TUER-SG BT    1519
       Revision: 72009005    Serial number: 00000075288702
       Coding: 0001204
       VCID: 70B9D05676AE29E73A9-8024
    01553 - Motor for Central Locking; Passenger Door (V57); Lock
                        Reset counter: 216
                        Mileage: 263190 km
                        Fault Status: 00111000
                        Fault Frequency: 201
                        Reset counter: 216
                        Mileage: 263190 km
    Address 56: Radio        Labels: 1K0-035-161.lbl
       Part No SW: 1K0 035 161 D    HW: 1K0 035 161 D
       Component: Radio DE2       017 0021
       Revision: 00017000    Serial number: VWZ4Z7H6359866
       Coding: 0040402
       VCID: 2019E016E6CED967EA9-8074
       Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
       Component: J388   TUER-SG HL   1401
       Revision: 12006001    Serial number: 00000003284488
       Coding: 0001168
       VCID: 76B5E64E14CA07D7E05-8022
                        Reset counter: 216
                        Mileage: 241449 km
       Component:    RDK              0450
       Coding: 0100101
    00625 - Vehicle Speed Signal
                        Fault Frequency: 169
                        Reset counter: 216
                        Mileage: 270161 km
                        Time: 06:37:23
       Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
       Component: J389   TUER-SG HR   1401
       Revision: 12006001    Serial number: 00000003277375
       Coding: 0001168
       VCID: 77ABEB4A13C07EDFFB3-8022
    End----------(Elapsed Time: 01:26, VBatt start/end: 12.4V/12.4V)-----------
    Address 08: DTCs cleared
    Address 01: DTCs cleared
    Address 09: DTCs cleared
    Address 46: DTCs cleared
    Address 65: DTCs cleared
    Aug 2019
    Here is an Auto-Scan post repair:
    Saturday,17,August,2019,22:50:48:54182
    Mileage: 270180km-167882mi   Repair Order:
    VIN: 3VWHM71K49M015415   Mileage: 270180km-167882miles
       Coding: 0000071
                        Fault Frequency: 7
                        Mileage: 270173 km
                        Time: 04:24:20
                        RPM: 1254 /min
                        Load: 41.2 %
                        Temperature: 80.0C
                        Temperature: 57.0C
                        Voltage: 13.970 V
                        Mileage: 270173 km
                        Time: 03:28:55
                        RPM: 2870 /min
                        Load: 35.3 %
                        Speed: 44.0 km/h
                        Temperature: 87.0C
                        Temperature: 60.0C
                        Voltage: 13.970 V
                        Mileage: 270173 km
                        Time: 03:29:05
                        RPM: 1375 /min
                        Load: 29.0 %
                        Speed: 255.0 km/h
                        Temperature: 87.0C
                        Temperature: 60.0C
                        Voltage: 13.970 V
    Readiness: 0000 1100
       Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
       Component: ESP MK60EC1   H45 0107
       Revision: 00H45001
       VCID: 7EA5FE6E30FA4F97B85-802A
                        Fault Status: 01100101
                        Reset counter: 177
                        Mileage: 270185 km
                        Count: 16391
                        Count: 8192
                        Count: 279
                        Count: 45312
                        Count: 11520
                        Reset counter: 177
                        Mileage: 270185 km
                        Count: 16391
                        Count: 8192
                        Count: 295
                        Count: 45312
                        Count: 11520
                        Reset counter: 177
                        Mileage: 270185 km
                        Count: 16391
                        Count: 8192
                        Count: 270
                        Count: 45312
                        Count: 11520
                        Reset counter: 177
                        Mileage: 270185 km
                        Count: 16391
                        Count: 8192
                        Count: 195
                        Count: 45312
                        Count: 11520
       Coding: 00038805
       Shop #: WSC 33311
       Coding: 0013889
       Coding: 0000021
       Coding: 0023203
                        Fault Frequency: 80
                        Reset counter: 217
                        Mileage: 269495 km
                        Time: 06:07:31
                        Fault Frequency: 82
                        Reset counter: 217
                        Mileage: 269495 km
                        Time: 06:07:32
       Coding: 0001205
                        Fault Status: 01111000
                        Fault Frequency: 32
                        Reset counter: 177
                        Mileage: 269618 km
                        Fault Status: 01101000
                        Fault Frequency: 184
                        Reset counter: 177
                        Mileage: 269495 km
                        Reset counter: 214
                        Mileage: 270060 km
       Revision: 00H15000
                        Fault Frequency: 72
                        Reset counter: 227
                        Mileage: 270174 km
                        Time: 04:28:10
                        Voltage: 14.00 V
                            DU
                        Temperature: 43.0C
                        RPM: 2214 /min
                        Speed: 69.0 km/h
                        Speed: 69.0 km/h
                        Fault Frequency: 200
                        Reset counter: 227
                        Mileage: 270174 km
                        Time: 04:27:46
                        Voltage: 14.00 V
                            DU
                        Temperature: 43.0C
                        RPM: 2816 /min
                        Speed: 87.0 km/h
                        Speed: 87.0 km/h
                        Fault Frequency: 130
                        Reset counter: 227
                        Mileage: 270174 km
                        Time: 04:27:20
                        Voltage: 14.00 V
                            DU
                        Temperature: 43.0C
                        RPM: 2317 /min
                        Speed: 53.0 km/h
                        Speed: 53.0 km/h
       Coding: 0001204
                        Reset counter: 217
                        Mileage: 263190 km
                        Reset counter: 177
                        Mileage: 263190 km
       Coding: 0040402
       Coding: 0001168
                        Reset counter: 216
                        Mileage: 241449 km
       Component:    RDK              0450
       Coding: 0100101
                        Reset counter: 217
                        Mileage: 270174 km
                        Time: 04:28:11
       Coding: 0001168
    End----------(Elapsed Time: 01:23, VBatt start/end: 12.2V/12.2V)-----------
    Why would they not change this safety item for free under the recall & did you contact NHTSA & VW corporate advocates to complain?
    Please explain & show us documents showing the flash failure and why they rejected replacement?
    Vehicle Identification No. 3VWHM71K49M015415
    Model Jetta
    JEM
    Date of production 22.07.2008
    Model year 2009
    Sales type 1K2ES1
    Engine Code CBTA
    Transmission Code KPF
    On a 10 year old car with 168,000 miles on it?
    Quote Originally Posted by JeffsJetta View Post
    Please don't start duplicate threads. If you think you posted in the wrong place, ask to have your thread moved.
    I'm not sure why the replacement module isn't taking the original coding. Coding lengths appear to be the same, so I would think it should.
  6. #6
    Aug 2019
    I have not contacted anyone to complain aside from my complaint at the dealership. They stated that the ABS module was not communicating and that they could not update the software and begin the recall until the module was replaced. They also tried to say that the hydraulic pump was bad. I couldn't find any codes for a bad pump personally. I decided to cut my losses and just replace the whole ABS unit, module and pump myself.
    I have no idea why its not accepting the original code. Any thoughts on what I can do from here?
    My apologies again for the duplicate post. I'll do what you've asked next time.
  7. #7
    Aug 2019
    Here's a picture of the printout they gave me at the dealership stating the same: https://ibb.co/4sqxY3L
    Oh, I'm not sure how relevant it may be but when it rejected the code it stated something about how it could not accept a subvalue or something like that.
  8. #8
    Are not NHTSA safety campaigns good forever?
    Is it this one below and does anything specify a mileage range?
    https://www-odi.nhtsa.dot.gov/owners...3P45CS14GQ2DLC
    Report Receipt Date: DEC 20, 2016
    NHTSA Campaign Number: 16V913000
    Component(s): ELECTRONIC STABILITY CONTROL , SERVICE BRAKES, HYDRAULIC
    All Products Associated with this Recall expand
    Details close
    26 Associated Documents expand
    Manufacturer: Volkswagen Group of America, Inc.
    SUMMARY:
    Volkswagen Group of America, Inc. (Volkswagen) is recalling certain model year 2009-2010 Volkswagen Jetta A5 Sedan, 2009 Volkswagen Jetta SportWagen, Eos, GTI, Rabbit and Audi A3 vehicles, and 2010 Volkswagen Golf A6 vehicles. The Antilock Brake System (ABS) control unit may fail during ABS or Electronic Stability Control (ESC) activation, possibly causing a loss of vehicle control.
    CONSEQUENCE:
    A loss of vehicle control can increase the risk of a crash.
    REMEDY:
    Volkswagen will notify owners, and dealers will update the ABS control module software to improve the module's self-testing abilities. Any module that fails the new diagnostic test will be replaced. These repairs will be made free of charge. The recall began February 2017. Owners may contact Volkswagen customer service at 1-800-893-5298.
    NOTES:
    Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov
    The OP's complaint or repair concerns of what has happened or as he allegedly describes certainly doesn't add up with the aforementioned at NHTSA, huh?
    IDK OP don't you think you should ask about this being done free from the OEM?
  9. Likes Uwe liked this post
  10. #9
    Aug 2019
    I'm not sure what the deal is but I went back to see exactly what the error message was when it would kick back the code and now the code is being accepted. I'm going to run the adaptions now.
  11. Likes Jack@European_Parts, Dana, Uwe liked this post
  12. #10
    OP:
    Don't you think you should be completely compensated & based on what you were quoted at dealer in a certified letter to VWGoA along with a complaint form to NHTSA copied on the documents?
    I mean seriously, don't you think you could demand that and that the repair still be done too & to the replaced module, no?
  13. Likes Dana liked this post
