Results 1 to 10 of 10
Thread: Steering angle, abs, traction fault.
    Aug 2019
    I have a problem with getting my test drive after wheel bearing and wss replacement. Did 2 at the rear of the car.
    I've done a short video and this is what my wheel speed sensors showing at 40kmh. Don't know what exactly the should be like.
    Thank you
    Welcome to the VCDS forum OP
    This is not an auto-scan and please post one & tell us what specific make and part numbers you used during your repair process?
    JPPSG
    Actual logged data so people can tell exactly what they're looking at would be preferred to a wobbly video.
  4. Likes Jack@European_Parts liked this post
    Aug 2019
    as i said before this is the problem
    Wednesday,21,August,2019,20:52:38:12161
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
    Mileage: 115480km-71755miles
    Address 01: Engine        Labels: 03C-906-056-BAG.lbl
       Part No SW: 03C 997 056 M    HW: Hardware No
       Component: MED9.5.10       G00 9265
       Revision: 00000000    Serial number: VWZ7Z0C8817741
       Coding: 0000072
       Shop #: WSC 01287 785 00200
       VCID: 372B2B8CD34F7CAF3B3-8062
    Readiness: 1110 0001
       Part No: 1K0 907 379 K
       Component: ESP FRONT MK60      0103
       Coding: 0019073
       VCID: 3A2D32B8E05D61C7C4D-806E
       Part No: 1K0 820 047 CC
       Component: Climatic PQ35   080 0201
       VCID: 678BBBCCC36F2C2F6B3-8032
       Part No SW: 1K0 937 049 L    HW: 1K0 937 049 L*
       Component: Bordnetz-SG 1.0 H30 0701
       Revision: 00030000    Serial number: 00000000493804
       Coding: E58F8F0600041800001400001400000000
       VCID: 382928B0DE5173D7329-806C
       Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  012  0401
       Coding: 00065493
       Subsystem 2 - Part No: 1K0 955 559 K  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 002  0505
       Coding: 00217125
       Part No SW: 1K0 909 605 A    HW: 1K0 909 605 A
       Component: 0M AIRBAG VW8   022 0500
       Revision: 04022000    Serial number: 0033FD08EPD8
       Coding: 0012365
       Shop #: WSC 01268 785 00200
       VCID: 2A0D02F810FDD147B4D-807E
       Subsystem 1 - Serial number: 6332MSME69132602
       Subsystem 2 - Serial number: 6342MSME46307001
       Subsystem 3 - Serial number: 6351HSME04106201
       Subsystem 4 - Serial number: 6361HSME60145B01
       Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
       Component: Lenksäulenmodul 034 0070
       Coding: 0000042
       Shop #: WSC 00046 412 688128
       VCID: 76B5E68894C5C5A7E05-8022
    00888 - Wiper Switch for Intermittent Operation (E22)
                014 - Defective
       Part No: 1K0 920 950 K
       Component: KOMBIINSTRUMENT VDD 3550
       Coding: 0005401
       Shop #: WSC 33120 003 1048576
       VCID: 303910903621AB977A9-8064
       Part No SW: 1K0 907 530 C    HW: 1K0 907 951
       Component: Gateway         H08 0080
       Revision: 08          Serial number: 21001042020135
       Coding: 3D0F0340070003
       VCID: 270BFBCC03EFEC2FAB3-8072
       Component: IMMO                3550
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
       Part No: 1K0 959 701 E
       Component: Tuersteuergeraet 09 0116
       Coding: 0000052
    Address 44: Steering Assist        Labels: 1Kx-909-144-G2V1.clb
       Part No: 1K2 909 144 E
       Component: EPS_ZFLS Kl.1       1302
       VCID: 2E050EE82C15BD67685-807A
    02546 - Steering Limit Stop
                        Mileage: 5480 km
                        Temperature: 32.0°C
                        Voltage: 13.50 V
                        Voltage: 13.40 V
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 T
       Component: 0W KSG              0560
       Coding: 99E802087F2D8505485BC61000
       Shop #: WSC 00581 210 06001
       VCID: 41DF45548D8B321F857-8014
       Subsystem 1 - Part No: 1K0 951 605 A
       Component: LIN BACKUP HORN H01 1201
       Subsystem 2 - Part No: 1K0 907 719
       Component: Neigungssensor  003 0003
       Subsystem 3 - Part No: 1K0 951 177
       Component: Innenraumueberw.004 0101
    01134 - Alarm Horn (H12)
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
       Part No: 1K0 959 702 E
       Coding: 0000052
       VCID: 313F15943D2BA29F757-8064
       Part No: 1K0 035 186 J
       Component: Radio BNO           0016
       Coding: 0040400
       VCID: 2D0709E42113C67F51F-8078
    End----------(Elapsed Time: 00:57, VBatt start/end: 13.6V/13.6V)-----------
    Do the adaption ........
    http://wiki.ross-tech.com/wiki/index...#Basic_Setting
    Always log all four speed sensors at a time and in raw numbers is preferred to line up a suspect deviation.
    So far I see no faults for a deviation!
    Aug 2019
    I've tried that but mine always says "not possible"
    What test is failing or is a login error because the test is activated?
    You need to drive it or maybe lift and set back down to re relax the suspension maybe and drive it?
  9. #8
    Aug 2019
    It's a possibility, but this is the reason why I posted this here, I've tried to do all the tests in all orders, I can't log in as it's refusing the key, and as far as I tracked down the problem, the test can not be successful due the wheel speed sensor are not reading correctly, as you can see on the graph the speed is actually 20km/h and front right wheel showing around 30km and one at the rear wheels showing around 10km/h.
  10. #9
    You would never enter the calibration test mode if that was the case to commence adaption.
    Retrace each work step during calibration to complete the adaptation until completed.
  11. #10
    Aug 2019
    I've done the test drive as it's described, my only problem now is the security access, it wont allow me to accept the 40168. The ecu has been disconnected before and batter has been removed, I've change the all sensors and cleaned all the abs rings on wheel bearings, I don't have a problem with readings anymore, I've solved that problem. My only concern if I need to do some sort of calibration on the abs pump, is there anything you be able to recomend me? Thank you.
