Results 1 to 4 of 4
Thread: Hello - VW Fox 2007 Horn Failure - Assistance Needed ...
    Aug 2019
    Hello
    A first post, from Standish near Preston in the UK.
    I am seeking assistance with my 2007 VW Urban Fox - WVWZZZ5ZZ74026661
    The front horn failed some time ago (located behind the front bumper) - the horn itself works OK with a 12v battery.
    I assumed that it was the clock-spring, but replacing the original clock-spring wit a new one has not solved the problem.
    The 2007 Fox does not appear to have a conventional fuse-relay configuration, and I believe that the horn is activated by one of the on-board modules ?
    As a niche model, the Fox does not get as much coverage as it's larger bretheren, so I have been working on the assumption that it's related to a Polo 9Z.
    I'm new to VCDS, and don't have much of a clue where to start diagnosing the fault.
    Any useful assistance would be much appreciated.
    Here is a full scan of the vehicle, produced an hour or so ago - no obvious faults ?
    Saturday,17,August,2019,14:51:05:12784
    VCDS Version: 19.6.1.0  HEX-V2 CB: 0.4508.4
    VIN: WVWZZZ5ZZ74026661   License Plate: MA03 GUY
    Mileage: 77320km-48044mi   Repair Order:
    Chassis Type: 5Z (5Z - VW Fox (2004 >))
    Scan: 01 03 08 09 15 17 19 44 46 56
    VIN: WVWZZZ5ZZ74026661   Mileage: 77320km-48044miles
       Part No: 030 906 034 S
       Component:  MARELLI 4EV  MPSF  1605
       Coding: 00031
       VCID: 1C6021C17FB8D8E7361-4B3C
       WVWZZZ5ZZ74026661     VWZ5Z0F7152332
    Readiness: 0110 0101
    Address 03: ABS Brakes        Labels: 5Z0-907-379-ABS.clb
       Part No SW: 5Z0 907 379 A    HW: 5Z0 907 379 A
       Component: ABS 8.0 front   H01 0004
       Coding: 0000010
       Shop #: WSC 00000 785 00200
       VCID: 43D2BABDA786C71F97B-50F4
    Address 09: Cent. Elect.        Labels:. 6Qx-937-049-C.lbl
       Part No: 6Q1 937 049 D
       Component: 0000 BN-SG.         1S34
       Coding: 24580
       VCID: 3C20C141DF78B8E7D61-50F4
       Part No: 1C0 909 605 K
       Component: 1M AIRBAG VW51      0009
       Coding: 12621
       VCID: 2C00F1012F182867461-50F4
    Address 17: Instruments        Labels: 5Z0-920-xxx-V1.clb
       Part No: 5Z2 920 820 A
       Component: KOMBI+WEGFAHRS. M73 0013
       Coding: 00442
       VCID: 372ADE6DE65E9BBF3B3-50F4
       Part No: 6N0 909 901
       Component: 0000 GATEWAY CAN    1S34
       Coding: 00014
       VCID: 70B82571C3B00C873A9-50F4
       Part No: 6Q0 423 156 AB
       Component: LenkhilfeTRW        V270
       Coding: 10140
       VCID: 6FBA260DDE8E137F233-50F4
    Address 46: Central Conv.        Labels: None
       Part No: 5Z0 959 433 J
       Component: MODULO CONFORTO H07 0009
       Coding: 0014899
       VCID: 4ACC979980AC165754D-4B1E
       Part No SW: 5Z0 035 152     HW: 5Z0 035 152
       Component: Radio BVX       006 0010
       Revision: 00006000    Serial number: VWZ1Z5F4023125
       Coding: 0010200
       VCID: 6FBA260DDB8E137F233-50F4
    End----(Elapsed Time: 01:46, VBatt start/end: 12.1V/14.2V. VIgn 0.0V)------
    Many thanks
    Since the the horn itself works, and the car doesn't know what the problem is (as evidenced by the lack of fault codes), then the next step is to get wiring diagrams and figure out what actually does switch the horn on and off.
    Aug 2019
    I was expecting that I can view the horn press signal at the input to one of the modules, and to attempt to activate the horn via one of the control blocks.
    Can anyone assist with the location of data blocks for the logic flow through the horn push through to the horn output, please.
    Try the CECM at address 09, MVB 004.3
