Results 1 to 8 of 8
Thread: Cannot code RNS-E - Error 31: Request out of range
    New User
    Nov 2015
    Norway
    Hi
    I have an A6 C5 2004 with a RNS-E unit that I'm unable to code. Whatever I put in I always get the same message "Error 31: Request out of range"
    Everything works as it should which is a bit surprising as the current softcoding is now 0020000. I think the correct coding should be 0512118.
    It's also impossible to code the TV-Tuner.
    I'm looking into this because I wanted to add AUX, and I also like to have no fault codes.
    Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
    Part No SW: 4B0 035 192 P HW: 4B0 035 192 P
    Component: RNS-E HIGH EU H58 0660
    Revision: 11S Serial number: AUZBZ7F0589823
    Coding: 0020000
    VCID: 2A5175C18692061FE7-5178
    02024 - Perform Adaptation
    Reset counter: 162
    Date: 2019.07.19
    Time: 18:38:07
    Reset counter: 162
    Date: 2019.07.19
    Time: 18:38:07
    Address 56: Radio Labels: 8E0-035-192-RNSE.clb
    Coding: 0020000
    Reset counter: 162
    Date: 2019.07.19
    Time: 18:38:44
    Reset counter: 162
    Date: 2019.07.19
    Time: 18:38:44
    Address 57: TV Tuner Labels: 4D0-919-146.clb
    Part No SW: 4D0 919 146 D HW: 4D0 919 146 D
    Component: TV Tuner H04 0580
    Revision: 01H04001 Serial number: 00000000014036
    Coding: 0000010
    VCID: 2A5175C18692061FE7-513C
    00861 - Connection to Navigation Computer
    Jun 2014
    Post complete autoscan so we can see what is in the car...
    Golf VII, 1.6TDI BM Ed. 40 - 110 PK
    New User
    Nov 2015
    Norway
              75 76 77
    VIN: WAUZZZ4B84N076861   Mileage: 263640km-163818miles
    Address 01: Engine        Labels: 06B-906-018-AWT.lbl
       Part No: 4B0 906 018 DC
       Component: 1.8L R4/5VT     G   0001
       Coding: 11702
       Shop #: WSC 88641
       VCID: 65CBC6FDFF0CE9624E-513C
       WAUZZZ4B84N076861     AUZ7Z0C2526832
    Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
       Part No: 4B0 614 517 H
       Component: ABS/ESP allrad      3428
       Coding: 06275
       Shop #: WSC 02334
       VCID: 264981F1C28A227A87-513C
    Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
       Part No: 4B0 820 043 AR
       Component: A6-Klimavollautomat 0208
       Coding: 00000
       VCID: 6AD1B5C11612C61A63-2580
    Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
       Part No: 4B0 959 655 AA
       Component: Airbag 8.4EP        1002
       Coding: 0000706
       Shop #: WSC 02334 785 00200
       VCID: 6FE7A4D57DF0233234-513C
    Address 16: Steering wheel        Labels: 4B0-907-487.lbl
       Part No: 4B0 907 487 F
       Component: Lenkradelektronik   D01
       Coding: 01002
       Shop #: WSC 02335
       VCID: 2F6764D5ED70633274-513C
    Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
       Part No: 4B0 920 933 N
       Component: KOMBI+WEGFAHRS. VDO D15
       Coding: 00144
       Shop #: WSC 00006
       VCID: 2E5979D1EA7A6A3A7F-513C
    Address 35: Centr. Locks        Labels:. 4B0-962-258.lbl
       Part No: 4B0 962 258 L
       Component: Zentralverriegelung D38
       Coding: 21543
       Shop #: WSC 26100
       VCID: 32616DA1FE424EDA1B-4ECA
    01366 - Opened Due to Crash Signal
                35-00 -  -
    00957 - Key 3
                09-00 - Adaptation Limit Surpassed
       Component: RNS-E HIGH EU   H58 0650
       Coding: 0020000
       VCID: 2A5175C18692061AA3-515A
                        Reset counter: 177
                        Date: 2016.04.12
                        Time: 08:48:52
                        Reset counter: 177
                        Date: 2016.04.12
                        Time: 08:48:52
       Part No: 4Z7 907 357
       Coding: 00050
       Shop #: WSC 02335
       VCID: 040DFB791476306AF9-4B32
       Coding: 0020000
       VCID: 2A5175C18692061AA3-5178
                        Reset counter: 177
                        Date: 2016.04.12
                        Time: 08:48:52
                        Reset counter: 177
                        Date: 2016.04.12
                        Time: 08:48:52
       Coding: 0000010
       VCID: 2A5175C18692061AA3-513C
    Address 76: Park Assist        Labels: 8Z0-919-283.lbl
       Part No: 8Z0 919 283
       Component: Parkingsyst. A6 RDW D08
       Coding: 00116
       Shop #: WSC 02335
       VCID: 0201FD610E623E5ACB-513C
    End-------------------------(Elapsed Time: 05:02)--------------------------
    Quote Originally Posted by Jone View Post
    Check the Ross-Tech Wiki for RNS-E coding, that value doesn't look right to me
    http://wiki.ross-tech.com/wiki/index...(RNS-E)#Coding
    New User
    Nov 2015
    Norway
    0: First digit is always 0
    5: Audi A6
    1: " Front Treble Speaker Diagnosis inactive" should it not be? And the car has no "Optical Parking Aid" only acoustic
    2: Sound Characteristic Audi A6
    1: Telephone Preparation NOT installed
    1: None of the options under Equipment I is installed
    8: All of the options under Equipment II is installed
    0512118 as the car is now and 0512157 if I unplug the TV tuner and plug in an AUX adapter?
    Since the questions involve VCDS, this doesn't belong in General VW/Audi Repair. Moving to New User section.
    PS: Have you tried non-zero values for WSC, Importer, and Equipment number?
  7. #7
    5: Audi A6
    I would suggest going for a very basic coding first off to see if the RNS-E will accept A6 coding (not all hardware/firmware combinations will), so try 0505111 and see if that is accepted.
    If not then the problem is that the hardware/firmware combination you have MAY be one of those that won't accept A6 coding.
  8. Likes Uwe liked this post
  9. #8
    New User
    Nov 2015
    Norway
    Well what do you know! The car accepted both the codes I mentioned. I must have tried some other codes earlier on based on the VCDS help blob. I probably tried 052xxxx.
    I can't delete the "Perform Adaption" error code though. There was 0 at Channel 1 so I added the tire circumference. Channel 18 is 1 (S3 start screen) it is however impossible to set it to 0. Many other channels cannot be set like speech recognition language but I suppose it can be because the unit has no speech recognition and probably does not support different startup screens.
