Cannot code RNS-E - Error 31: Request out of range
Jone
New Member
Norway
Hi
I have an A6 C5 2004 with a RNS-E unit that I'm unable to code. Whatever I put in I always get the same message "Error 31: Request out of range"
Everything works as it should which is a bit surprising as the current softcoding is now 0020000. I think the correct coding should be 0512118.
It's also impossible to code the TV-Tuner.
I'm looking into this because I wanted to add AUX, and I also like to have no fault codes.
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 4B0 035 192 P HW: 4B0 035 192 P
Component: RNS-E HIGH EU H58 0660
Revision: 11S Serial number: AUZBZ7F0589823
Coding: 0020000
VCID: 2A5175C18692061FE7-5178
02024 - Perform Adaptation
Reset counter: 162
Date: 2019.07.19
Time: 18:38:07
Reset counter: 162
Date: 2019.07.19
Time: 18:38:07
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0020000
Reset counter: 162
Date: 2019.07.19
Time: 18:38:44
Reset counter: 162
Date: 2019.07.19
Time: 18:38:44
Address 57: TV Tuner Labels: 4D0-919-146.clb
Part No SW: 4D0 919 146 D HW: 4D0 919 146 D
Component: TV Tuner H04 0580
Revision: 01H04001 Serial number: 00000000014036
Coding: 0000010
VCID: 2A5175C18692061FE7-513C
00861 - Connection to Navigation Computer
Mari
C?ID=150535
Post complete autoscan so we can see what is in the car...
Jone
New Member
Norway
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
          75 76 77
VIN: WAUZZZ4B84N076861   Mileage: 263640km-163818miles
Address 01: Engine        Labels: 06B-906-018-AWT.lbl
   Part No: 4B0 906 018 DC
   Component: 1.8L R4/5VT     G   0001
   Coding: 11702
   Shop #: WSC 88641
   VCID: 65CBC6FDFF0CE9624E-513C
   WAUZZZ4B84N076861     AUZ7Z0C2526832
   Part No: 4B0 614 517 H
   Component: ABS/ESP allrad      3428
   Coding: 06275
   Shop #: WSC 02334
   VCID: 264981F1C28A227A87-513C
Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
   Part No: 4B0 820 043 AR
   Component: A6-Klimavollautomat 0208
   Coding: 00000
   VCID: 6AD1B5C11612C61A63-2580
Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
   Part No: 4B0 959 655 AA
   Component: Airbag 8.4EP        1002
   Coding: 0000706
   Shop #: WSC 02334 785 00200
   VCID: 6FE7A4D57DF0233234-513C
Address 16: Steering wheel        Labels: 4B0-907-487.lbl
   Part No: 4B0 907 487 F
   Component: Lenkradelektronik   D01
   Coding: 01002
   Shop #: WSC 02335
   VCID: 2F6764D5ED70633274-513C
   Part No: 4B0 920 933 N
   Component: KOMBI+WEGFAHRS. VDO D15
   Coding: 00144
   Shop #: WSC 00006
   VCID: 2E5979D1EA7A6A3A7F-513C
Address 35: Centr. Locks        Labels:. 4B0-962-258.lbl
   Part No: 4B0 962 258 L
   Component: Zentralverriegelung D38
   Coding: 21543
   Shop #: WSC 26100
   VCID: 32616DA1FE424EDA1B-4ECA
01366 - Opened Due to Crash Signal
            35-00 -  -
00957 - Key 3
            09-00 - Adaptation Limit Surpassed
   Component: RNS-E HIGH EU   H58 0650
   Coding: 0020000
   VCID: 2A5175C18692061AA3-515A
            000 -  -
                    Reset counter: 177
                    Date: 2016.04.12
                    Time: 08:48:52
            000 -  -
                    Reset counter: 177
                    Date: 2016.04.12
                    Time: 08:48:52
   Part No: 4Z7 907 357
   Coding: 00050
   Shop #: WSC 02335
   VCID: 040DFB791476306AF9-4B32
   Coding: 0020000
   VCID: 2A5175C18692061AA3-5178
            000 -  -
                    Reset counter: 177
                    Date: 2016.04.12
                    Time: 08:48:52
            000 -  -
                    Reset counter: 177
                    Date: 2016.04.12
                    Time: 08:48:52
   Coding: 0000010
   VCID: 2A5175C18692061AA3-513C
            000 -  -
Address 76: Park Assist        Labels: 8Z0-919-283.lbl
   Part No: 8Z0 919 283
   Component: Parkingsyst. A6 RDW D08
   Coding: 00116
   Shop #: WSC 02335
   VCID: 0201FD610E623E5ACB-513C
End-------------------------(Elapsed Time: 05:02)--------------------------
Jone
New Member
Norway
0: First digit is always 0
5: Audi A6
1: " Front Treble Speaker Diagnosis inactive" should it not be? And the car has no "Optical Parking Aid" only acoustic
2: Sound Characteristic Audi A6
1: Telephone Preparation NOT installed
1: None of the options under Equipment I is installed
8: All of the options under Equipment II is installed
0512118 as the car is now and 0512157 if I unplug the TV tuner and plug in an AUX adapter?
Since the questions involve VCDS, this doesn't belong in General VW/Audi Repair. Moving to New User section.
PS: Have you tried non-zero values for WSC, Importer, and Equipment number?
5: Audi A6
I would suggest going for a very basic coding first off to see if the RNS-E will accept A6 coding (not all hardware/firmware combinations will), so try 0505111 and see if that is accepted.
If not then the problem is that the hardware/firmware combination you have MAY be one of those that won't accept A6 coding.
Jone
New Member
Norway
Well what do you know! The car accepted both the codes I mentioned. I must have tried some other codes earlier on based on the VCDS help blob. I probably tried 052xxxx.
I can't delete the "Perform Adaption" error code though. There was 0 at Channel 1 so I added the tire circumference. Channel 18 is 1 (S3 start screen) it is however impossible to set it to 0. Many other channels cannot be set like speech recognition language but I suppose it can be because the unit has no speech recognition and probably does not support different startup screens.
