Results 1 to 3 of 3
Thread: 2008 Passat ABS Coding request
    Oct 2014
    Kenya
    Hey guys,
    I have a 2008 Passat that has the Park brake control Module replaced. the vehicle was brought from another workshop with different park brake modules
    fitted so i couldn't save the original codings for the ABS
    Thank you in advance
    Friday,16,August,2019,17:45:20:54859VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
    VCDS Version: 19.6.1.0  HEX-V2 CB: 0.4508.4
    Dealer/Shop Name: Euro Tecnik Ltd
    VIN: WVWZZZ3CZ8P025965   License Plate: KBB 720G
    Mileage: 48980km-30434mi   Repair Order: SUFYAN SLATCH
    Chassis Type: 3C (3C0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
    VIN: WVWZZZ3CZ8P025965   Mileage: 48980km-30434miles
    03-ABS Brakes -- Status: Not registered 0011
    53-Parking Brake -- Status: Not registered 0011
       Part No SW: 06F 906 056 GL    HW: 06F 906 056 FD
       Component: MED9.5.10       G00 0186
       Revision: 6AH03---    Serial number: VWZCZ000000000
       Coding: 0000075
       Shop #: WSC 65200 002 1048576
       VCID: 79AE1BD005D4367F8D7-802C
    005715 - Please check DTC Memory of ABS Controller
                   P1653 - 001 -  - Intermittent
                        Fault Status: 00100001
                        Mileage: 48989 km
                        Time: 23:41:52
                        Temperature: 48.0°C
    006420 - Pressure Sensor for Brake Boost (G294)
                   P1914 - 008 - Implausible Signal - Intermittent
                        Mileage: 48989 km
                        Time: 23:41:52
                        Temperature: 48.0°C
                   P1653 - 004 -  - Intermittent
                        Mileage: 48989 km
                        Time: 23:41:52
                        Temperature: 48.0°C
    006418 - Pressure Sensor for Brake Boost (G294)
                   P1912 - 001 - Short to Plus
                        Fault Status: 01100001
                        Mileage: 48989 km
                        Time: 23:41:53
                        Temperature: 48.0°C
    005161 - Circuit for Brake Vacuum Pump
                   P1429 - 004 - Open Circuit - Intermittent
                        Mileage: 48989 km
                        Time: 23:43:34
                        RPM: 920 /min
                        Load: 31.8 %
                        Temperature: 48.0°C
    Readiness: 0110 0000
    Address 02: Auto Trans
    Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 D    HW: 3C0 614 109 D
       Component: J104    C4 440 V2   0003
       Revision: --020---    Serial number: 00000775699770
       Coding: 0003384
       Shop #: WSC 65200 002 104856
       VCID: 1F1A1548FBB0B84FD33-804A
                        Reset counter: 220
                        Mileage: 48989 km
                        Time: 23:46:30
                        Hex Value: 0x0000
                        Voltage: 13.50 V
                        Bin. Bits: 00011111
                        Count: 199
                        Reset counter: 221
                        Mileage: 48989 km
                        Time: 04:20:56
                        Hex Value: 0x0000
                        Voltage: 12.25 V
                        Bin. Bits: 00011110
                        Count: 149
                        Reset counter: 221
                        Mileage: 48989 km
                        Time: 04:20:56
    Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
       Part No SW: 3C0 907 044 BT    HW: 3C0 907 044 BT
       Component: ClimatronicPQ46 122 0707
       Revision: 00122021    Serial number: 00000000000000
       VCID: 74B02AE422B64B17DE1-8020
    01273 - Fresh Air Blower (V2)
                        Fault Status: 00111010
                        Reset counter: 2
                        Mileage: 48943 km
                        Time: 16:44:39
       Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
       Revision: 00H54000    Serial number: 01000005019391
       Coding: 00840F0700041A00470A00000F000000000959435C000100000000000000
       Shop #: WSC 00028 028 00001
       VCID: 6FBA25884B9068CF233-803A
       Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer 220607 022  0601
       Coding: 00046997
       Shop #: WSC 00028
    00532 - Supply Voltage B+
                        Reset counter: 4
                        Mileage: 48969 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 7.85 V
                        Reset counter: 4
                        Mileage: 48969 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 7.60 V
       Part No SW: 3C0 909 605 M    HW: 3C0 909 605 M
       Component: 0C AIRBAG VW8   032 2522
       Revision: 12032000    Serial number: 003B1PD7KW9Z
       Coding: 0012355
       VCID: 3038E6F4962E37377A9-8064
       Subsystem 1 - Serial number: 6332MSME17783B6D
       Subsystem 2 - Serial number: 6342MSME19104945
       Subsystem 3 - Serial number: 6351HTS6D3K4A3I6
       Subsystem 4 - Serial number: 6361HTS6D3KGD4B7
       Part No SW: 3C0 953 549 J    HW: 3C0 953 549 J
       Component: Lenksäulenmodul 006 0010
       Revision: 00006000    Serial number: 3C5953507BD
       Coding: 0001011
       VCID: 3332E9F867380C2F07B-8066
       Part No SW: 3C0 920 852 P    HW: 3C0 920 852 P
       Component: KOMBIINSTRUMENT VD1 1216
       Revision: V0002000    Serial number: 00000000000000
       Coding: 0006105
       Shop #: WSC 12345 123 999999
                        Reset counter: 4
                        Mileage: 48951 km
                        Time: 01:05:14
                        Reset counter: 4
                        Mileage: 48951 km
                        Time: 01:06:10
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
       Part No SW: 3C0 907 530 E    HW: 3C0 907 951
       Component: J533__Gateway   H10 0080
       Revision:   H10       Serial number: 1200P0762010E1
       Coding: E5807F060002021003
       VCID: 231219B8D7D89CAFF7B-8076
                        Fault Frequency: 27
                        Reset counter: 221
                        Mileage: 48943 km
                        Time: 16:44:43
       Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
       Component:    IMMO         042 0383
       Revision: 00042000    Serial number: VWZCZ000000000
       VCID: 392EDBD04554F67FCD7-806C
       Component:    ELV          027 0380
       3C0905861G     ELV          027 0380
    02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                        Fault Frequency: 15
                        Reset counter: 4
                        Mileage: 48951 km
                        Time: 01:17:02
       Component: J386  TUER-SG FT    1132
       Revision: 32008001    Serial number: 00000506978705
       Coding: 0000693
       VCID: 3B22C1D84F68C46FDFB-806E
                        Reset counter: 4
                        Mileage: 48969 km
       Part No: 1K2 909 144 M
       Component: EPS_ZFLS Kl.133 H08 1901
       VCID: 3634D0EC744A1907205-8062
                        Mileage: 48940 km
                        Temperature: 24.0°C
                        Voltage: 6.50 V
                        Voltage: 6.30 V
                        Mileage: 48970 km
                        Temperature: 26.0°C
                        Voltage: 12.30 V
                        Voltage: 12.10 V
       Component:    KSG PQ46 ELV 042 0472
       Coding: 19910A0001860E763004941570085FCE1078A0
       Shop #: WSC 00312 312 81305
       Component: LIN BACKUP HORN H07 9001
                        Reset counter: 4
                        Mileage: 48951 km
                        Time: 01:04:42
    01134 - Alarm Horn (H12)
                        Reset counter: 5
       Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
       Component: J387  TUER-SG BT    1132
       Revision: 32008001    Serial number: 00000531878705
       Coding: 0000692
       VCID: 3C20C2C44A66C357D61-8068
                        Reset counter: 4
                        Mileage: 48969 km
                        Fault Status: 00100101
                        Reset counter: 3
                        Mileage: 48943 km
       Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
       Component: J540 EPB4  VW-63206 0012
       Revision:   H19       Serial number: 00000000820046
       Coding: 0021057
       VCID: 3828DED47E5EEF77329-806C
    02432 - Supply Voltage for Left Parking Brake Motor (V282)
                        Reset counter: 221
                        Mileage: 48989 km
                        Voltage: 13.50 V
                        Count: 29
                        Hex Value: 0x12E0
                        Hex Value: 0x0001
                        Hex Value: 0x0101
                        Fault Status: 01110000
                        Reset counter: 221
                        Voltage: 13.90 V
                        Count: 41
                        Hex Value: 0x0140
                        Hex Value: 0x0082
                        Hex Value: 0x4040
    16352 - Control Module - Electrical Error
                        Fault Status: 00101110
                        Reset counter: 5
                        Mileage: 48989 km
                        Voltage: 13.80 V
                        Count: 40
                        Hex Value: 0x1270
                        Hex Value: 0x0001
                        Hex Value: 0x0101
    16353 - Control Module - Internal Malfunction
                        Reset counter: 5
                        Mileage: 48989 km
                        Voltage: 13.60 V
                        Count: 111
                        Hex Value: 0x1270
                        Hex Value: 0x0001
                        Hex Value: 0x0101
    03200 - Switch for Electric Parking Brake (E538)
                        Fault Frequency: 7
                        Reset counter: 221
                        Voltage: 11.90 V
                        Count: 9
                        Hex Value: 0x0150
                        Hex Value: 0x0082
                        Hex Value: 0x0101
       Part No: 1K0 035 186 AD
       Component: Radio GR0       033 0033
       Revision: 0003303S    Serial number: VWZ2Z2G1846096
       Coding: 0040402
       VCID: 68884E946E7EBFF7629-803C
       Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
       Component: J388   TUER-SG HL   1118
       Revision: 11006001    Serial number: 00000002000432
       Coding: 0000144
       VCID: 3D26CFC0517CCA5FE1F-8068
    00934 - Electric Window Motor; Rear Left (V26)
                        Reset counter: 4
       Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
       Component: J389   TUER-SG HR   1118
       Revision: 11006001    Serial number: 00000001992370
       Coding: 0000144
       VCID: 3E24C8CC5C7AD147F85-806A
    00935 - Electric Window Motor; Rear Right (V27)
                        Reset counter: 4
    End----------(Elapsed Time: 01:45, VBatt start/end: 12.3V/12.2V)-----------
    Try: 0005504
  3. Likes Jack@European_Parts, Uwe liked this post
    I'm just curious why you are asking the same thing again a year later & for same car OP?
