Results 1 to 5 of 5
Thread: ABS pump Jetta 5 2.0t
    New User
    Aug 2019
    South Africa
    Hi I need long coding for a 2008 Jetta 2.0tfsi abs pump vin nr AAVZZZ1KZ9U016794 pump 1KO907379AD RHD vehicle thanks
    We'll need you to pst a full unedited VCDS Auto-Scan to be able to suggest ABS coding for your Jetta.
  3. Likes Uwe, Jack@European_Parts liked this post
    New User
    Aug 2019
    South Africa
    Hi I put a second hand abs pump as the original has lost communication I could not retrieve the code from the older pump, the newer one in responds but needs the long code for the dash lights to go off..
    Cool story, but we still need to see an Auto-Scan to have any chance at all of making you a coding that will work.
    Vehicle Identification No. AAVZZZ1KZ9U016794
    Model Jetta 2,0
    JE
    Date of production 23.10.2008
    Model year 2009
    Sales type 1K22V2
    Engine Code BWA
    Transmission Code KNU
    It looks like it is the right module, now if you just get kindly registered & post an auto-scan as aforementioned, maybe we can commence..........huh?
