Results 1 to 5 of 5
Thread: Audi A5 2008 B8 Brake switch issues.
    Aug 2019
    Derby UK
    Hi. First post here so hopefully its all done correct!
    New to VAGs and VCDS but bought a 2007 Audi A5 3.0tdi quattro and VCDS. Scanned and have a fault of
    4366 - Brake Switch (F)
    P0703 00 [044] - Electrical Malfunction
    and also
    I have tried to reset these but they constantly return. I then replaced the switch with a aftermarket part. The faults remained after reset. I then replaced the switch with an OE one. Fault still remains (followed Elsawin proceedure eg do not move pedal, click in locating tabs and then rotate purple locking tabs clockwise). I checked the bulbs and all brake lights are working correctly.
    Today I got the ESP light on and the errors appear to have moved into the ABS section. Attached full scan if anyone can assist!
    Thursday,15,August,2019,16:47:27:35605
    VIN: WAUZZZ8T88A005904   License Plate:
    Mileage: 152760km-94920mi   Repair Order: esp fault
    Chassis Type: 8T-AU48 (8T0)
    Scan: 01 03 05 06 07 08 09 0E 0F 10 15 16 17 19 1E 36 37 42 46 47
              52 53 55 56 57 77
    VIN: WAUZZZ8T88A005904   Mileage: 152760km-94920miles
    0F-Digital Radio -- Status: Cannot be reached 1100
    Address 01: Engine (J623-CAPA)       Labels:| 059-907-401-V1.clb
       Part No SW: 8K0 907 401     HW: 8K0 907 401
       Component: 3.0TDI EDC17  H01 0008
       Revision: --H01---
       Coding: 01140023180F0118
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_ECM30LTDIA5 A01009
       ROD: EV_ECM30LTDIA5_A01.rod
       VCID: 6889B88AA2FB6A17629-803C
    4698 - Please Check Fault Codes in Control Module for ABS Brakes
              U1017 00 [036] - -
                        Mileage: 152710 km
                        Date: 2019.08.15
                        Time: 15:36:30
                        Engine speed: 792.50 /min
                        Normed load value: 52.2 %
                        Vehicle speed: 10 km/h
                        Coolant temperature: 54 °C
                        Intake air temperature: 19 °C
                        Voltage terminal 30: 14.040 V
                        Engine speed: 795.5 /min
                        Vehicle speed: 23.69 km/h
                        CCS target speed: 0.00 km/h
                        CCS status-Bits 0-7: 11001101
                        Cr Ctl st Shut Offirev-Bits 0-7: 00000000
                        Cr Ctl st Shut Offrev-Bits 0-7: 00000000
                        Cr Ctl st Shut Offrev-Bits 0-7: 00010000
                        Cr Ctl st Shut Offrev-Bits 0-7: 10000000
                        Cr Ctl st Shut Offrev-Bits 0-7: 00001101
                        Cr C st Key 0-Bits 0-7: 00000000
    4699 - Please Check Fault Codes in Control Module for ABS Brakes
              U1017 00 [036] - -
                        Mileage: 152710 km
                        Date: 2019.08.15
                        Time: 15:36:30
                        Engine speed: 792.00 /min
                        Normed load value: 51.8 %
                        Voltage terminal 30: 13.940 V
                        Engine speed: 793.5 /min
                        Vehicle speed: 23.89 km/h
                        Mileage: 152434 km
                        Date: 2019.08.13
                        Time: 15:19:50
                        Engine speed: 1358.50 /min
                        Normed load value: 85.5 %
                        Vehicle speed: 51 km/h
                        Coolant temperature: 50 °C
                        Intake air temperature: 24 °C
                        Ambient air pressure: 1410 mbar
                        Voltage terminal 30: 13.960 V
                        Engine speed: 1749.5 /min
                        Vehicle speed: 38.31 km/h
                        Vehicle voltage terminal 30: 13680 mV
                        Accelerator position: 0.00 %
                        Limiting torque: 395.2 Nm
                        Co Eng st: COENG_RUNNING
    7900 - Right Engine Mount Solenoid Valve (N145)
              P1577 00 [040] - Open Circuit
                        Fault Frequency: 18
                        Mileage: 152416 km
                        Date: 2019.08.12
                        Time: 17:26:55
                        Engine speed: 679.00 /min
                        Normed load value: 25.9 %
                        Intake air temperature: 23 °C
                        Voltage terminal 30: 14.160 V
                        Engine speed: 679.0 /min
                        Vehicle speed: 0.00 km/h
                        Engine mounting valve: right: activation: 0.00 %
                        Engine mounting valve: left: activation: 0.00 %
                        Gearbox mounting valve 1: activation: 0.00 %
                        Gearbox mounting valve 2: activation: 0.00 %
                        Vehicle voltage terminal 30: 14160 mV
       Part No SW: 8K0 907 379 J    HW: 8K0 907 379 J
       Component: ESP8 quattro  H03 0190
       Coding: 1B0500
       VCID: 40D9402AEA8B72578A9-8014
                        Reset counter: 134
                        Mileage: 152709 km
                        Date: 2019.08.15
                        Time: 11:15:43
                        Hex Value: 0x15C0
                        Hex Value: 0x4006
                        Hex Value: 0x1F07
                        Hex Value: 0x90B7
                        Hex Value: 0x00FF
       Part No SW: 8K0 907 289 C    HW: 8K0 907 289 C
       Component: BCM2.01       H37 0253
       Coding: 031000
       VCID: 392F2DCE8951239FCD7-806C
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Component: FBSAUDIB8 IDG  H33 0049
       Serial number: 0107000081248001
       Subsystem 2 - Part No SW: 8K0 905 852 A    HW: 8K0 905 852 A
       Component: ELVAUDIB8  H34 0039
       Serial number: 0207000000074012
       Part No SW: 8T0 959 760     HW: 8T0 959 760
       Component: MEM-BFS       H08 0027
       Revision: AA000000    Serial number: 00001001007975
       Coding: 08217025002444441000
       VCID: 55F7817E0509E7FFC9F-8000
    Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
       Part No SW: 8T0 035 730     HW: 4E0 035 729 A
       Component: Interfacebox    H43 5570
       Revision: 00000000    Serial number: 331EG077508140
       Coding: 0025002
       Shop #: WSC 00000 000 08192
       VCID: 6E85CE928C9FB427285-803A
       Subsystem 1 - Part No: 8T0 919 609
       Component: E0380 BedienteilH07 0100
       Subsystem 2 - Serial number: 00000000008170
       Subsystem 3 - Serial number: 0108.06.070000000100010006˙
       Subsystem 4 - Serial number: 010006˙
       Part No SW: 8T2 820 043 H    HW: 8T2 820 043 H
       Component: KLIMA 3 ZONEN H04 0093
       Revision: D1000000    Serial number: 0114.06.070011
       Coding: 36060000
       VCID: 372B2BF6BF4535EF3B3-8062
                        Fault Status: 00101101
                        Fault Frequency: 12
                        Reset counter: 133
                        Mileage: 152416 km
                        Date: 2019.08.12
                        Time: 17:45:38
       Part No SW: 8K0 907 063 D    HW: 8K0 907 279 D
       Component: BCM1 1.0      H19 0253
       Revision: 05019001    Serial number: 00000000024939
       Coding: 260050910014AF211709000300005D5D409D03C800010141000000
       Shop #: WSC 00546 210 91529
       VCID: 303910EA5A2BE2D77A9-8064
       Subsystem 1 - Part No SW: 8T2 955 119 B    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 140607  H11 0040
       Serial number: SWFBIE 0000190
       Coding: 00FD11
       Subsystem 2 - Part No SW: 8T0 955 559     HW: 4E0 955 559 B
       Component: RLS  H12 0001
       Serial number: 10007807
       Coding: 02532C
       Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
       Component: E1 - LDS  H07 0070
       Serial number: 00000000001106070660
                        Fault Status: 00101110
                        Fault Frequency: 12
                        Reset counter: 133
                        Mileage: 152416 km
                        Date: 2019.08.12
                        Time: 17:45:00
    03207 - Charisma Switch Module
                        Reset counter: 86
                        Mileage: 152416 km
                        Date: 2019.08.12
                        Time: 17:26:00
       Part No SW: 8T2 035 110 C    HW: 8T2 035 110 A
       Component: MP3-Changer     H42 0390
       Revision: 00042001    Serial number: AUZ5ZBG4511183
       VCID: 2B0307867F0D810F4FB-807E
    Address 0F: Digital Radio
       Part No SW: 8K0 919 475     HW: 8K0 919 475
       Component: PARKHILFE 4K  H06 0003
       Revision: 11001001    Serial number: 46130716301923
       Coding: 100001
       Shop #: WSC 06325 123 12345
       VCID: 76B5E6F2F8CF8CE7E05-8022
       Part No SW: 8K0 959 655     HW: 8K0 959 655
       Component: AirbagVW-AU10 H21 0334
       Serial number: 0038GD082S80
       Coding: 30323232333030303030554A305238543053
       ASAM Dataset: EV_AirbaECUVWAUDI010 A02001
       VCID: 7AADF2C2CC57E88784D-802E
       Serial number: 6334LSME1A251070+
       Serial number: 6344LSME1A3027321
       Serial number: 6352QSME2F5330117
       Serial number: 6362QSME2F5C3303L
       Serial number: 63734SME2E0C3111Z
       Serial number: 63834SME2C62780FB
       Part No SW: 8K0 953 568 B    HW: 8K0 953 568 B
       Component: Lenks.Modul   H09 0011
       Revision: --------    Serial number: 90304GF70000Z
       Coding: 000016
    Address 17: Instruments (J285)       Labels: None
       Part No SW: 8T0 920 980 M    HW: 8T0 920 980 M
       Component: KOMBIINSTR.   H20 0136
       Revision: 00300000    Serial number: 6C1205M67
       Coding: 2F05010002002600010000
       VCID: 45D7513EF5A9577FB9F-8010
       Part No SW: 8T0 907 468 F    HW: 8T0 907 468 F
       Component: GW-BEM 4CAN-M H07 0084
       Revision: EB002032    Serial number: 3200E076088034
       Coding: 000003
       Shop #: WSC 00762 210 57650
       VCID: 44D14C3AFE936E77AE1-8010
       Subsystem 1 - Part No SW: 8K0 915 181     HW: 8K0 915 181
       Component: J367-BDM  H06 0150
       Serial number: 1700178A100507
    02230 - Digital Radio (DAB) (R147)
                        Reset counter: 86
                        Mileage: 152416 km
                        Date: 2019.08.12
                        Time: 17:27:51
    Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
       Part No SW: 4E0 035 785 F    HW: 4E0 035 785 B
       Component: SG ext.Player H15 0850
       Revision: 00000000
       VCID: 2B030786730D810F4FB-807E
       Component: MEM-FS        H08 0027
       Revision: AA000000    Serial number: 00001001004049
       Coding: 08217125002444441000
       Part No SW: 4E0 910 888 P    HW: 4E0 919 887 M
       Component: MNS ECE         H49 1060
       Revision: 00000000    Serial number: 333FT077511984
       VCID: 3B2337C68F6D118FDFB-806E
       Part No SW: 8K0 959 793 A    HW: 8K0 959 793 A
       Component: TSG FA        H08 0149
       Revision:             Serial number: 0VQP
       Coding: 0110022240012201
       VCID: 3E253ED2907F04A7F85-806A
       Revision: 00002001    Serial number: 0104871599
       Coding: 011B068200390440002000
       Component: DWA-Sensor  H02 0030
    02615 - Fuel Tank Cap; Lock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 86
                        Mileage: 152416 km
                        Date: 2019.08.12
                        Time: 17:30:20
    02616 - Fuel Tank Cap; Unlock
                        Reset counter: 86
                        Mileage: 152416 km
                        Date: 2019.08.12
                        Time: 17:35:32
                        Fault Frequency: 129
                        Reset counter: 134
                        Mileage: 152417 km
                        Date: 2019.08.12
                        Time: 17:46:35
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASM.clb
       Part No SW: 8T0 035 223 P    HW: 8T0 035 223 A
       Component: DSP STD       H07 0250
       Revision: 22S00000
       Coding: 010101
       VCID: 3B2337C6836D118FDFB-806E
       Part No SW: 8K0 959 792 A    HW: 8K0 959 792 A
       Component: TSG BF        H08 0149
       Revision:             Serial number: 0HSP
       Coding: 011002224C012201
       VCID: 3D2739DE9D791FBFE1F-8068
       Part No SW: 8K0 907 801 C    HW: 8K0 907 801 C
       Component: EPB Audi B8   H03 0030
       Revision: 00000003    Serial number: 00000000009369
       VCID: 2F3B13964715FD2F633-807A
       Part No: 8K0 907 357
       VCID: 72BDDAE298A790C7CCD-8026
       Part No SW: 4E0 910 541 T    HW: 4F0 035 541 L
       Revision: 00000000    Serial number: 336FS077510297
       VCID: 313F15EE5D21EBDF757-8064
    Address 57: TV Tuner        Labels: None
       Part No SW: 4E0 910 148 E    HW: 4E0 919 148
       Component: R0078 TVhybridT     0470
       Revision: R0H06000    Serial number: 76300800482201
       Coding: 0000203
       VCID: 2517F1BE19E9B77F99F-8070
    Address 77: Telephone        Labels: 4F1-910-336.lbl
       Part No SW: 4F1 910 336 D    HW: 4F1 862 335
       Component: BTA             H09 1120
       Revision: 00H09000    Serial number: 00000007535628
       Coding: 0010021
    End----------(Elapsed Time: 01:51, VBatt start/end: 14.3V/14.4V)-----------
    Waxing pedantic: This is a 2008 model, not 2007. In fact, I don't think a 2007 model A5 exists. I'll fix the thread title.
    Have you verified all the wiring related to the brake switch?
    Aug 2019
    Derby UK
    Thanks for the reply. Appologies, the date on the v5 is first reg 15/10/17 and its a 57 plate so just assumed it was an 07.
    With regards to diagnosis as far as ive got is to confirm the lights work. I also looked at the control module (engine?) And checked that the ecu signal and switch signal were active on pressing the pedal (they were but iirc the ecu lagged slightly behind the switch?) Could you give a brief indication of what to check across tje 4 pins and ill check and report back.
    Really appreciate the help!
    IIRC the switch has two parts - normally open and normally closed when the pedal isn't pressed. The ECU looks for these two parts to always be "opposites".
    Vehicle Identification No. WAUZZZ8T88A005904
    Model Audi A5 Coupe
    Quattro TDI 3.0
    A5CO
    Date of production 05.07.2007
    Model year 2008
    Sales type 8T30H9
    Engine Code CAPA
    Transmission Code KMU
    Indeed............ https://www.youtube.com/watch?v=OpbdGnJbneE
    OP JPPSG
    RTFB
    Did you verify fuses first & ground points + all connections, then switch tracks from end to end isolated with load light & if good change switch, if fault persists chance modules intercepting signal?
