Having trouble with code to activate regen also security access for reset dpf and pressure sensor any help appreciated
Thursday,15,August,2019,16:03:00:60065
VCDS Version: 19.6.1.0 (x64)
VIN: WV1ZZZ2EZB6006168 License Plate: AK60KAX
Chassis Type: 2E (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
B0 B1 B2 B3 B4 B5 B6 C1
Address 01: Engine (CEB) Labels: Redir Fail!
Part No SW: 076 906 022 N HW: 076 906 022 G
Component: R5 2,5L EDC A020SG 9021
Revision: 24H34--- Serial number: VWXDZ0J1018036
Coding: 0003032
Shop #: WSC 00001 067 57207
VCID: 1E325EA0CA5D74BF8B-5104
009315 - Diesel Particle Filter
P2463 - 000 - Excessive Soot Accumulation
RPM: 777 /min
Pressure: 21 mbar
Hex Value: 0xFF00
Temperature: 96.0°C
(no units): 51.0
Mileage: 510 km
Readiness: 0 1 0 0 1
Address 91: LT3 Engine Labels: Redir Fail!
Coding: 0003032
VCID: 1E325EA0C95D74BF8B-804A
RPM: 777 /min
Pressure: 21 mbar
Hex Value: 0xFF00
Temperature: 96.0°C
(no units): 51.0
Mileage: 510 km
Address 93: LT3 Immo Labels: 2E0-905-865-93.clb
Part No SW: 2E0 905 865 AD HW: 906 545 580 8
Component: IMMO 0805 0815
Revision: 00805000 Serial number: VWXDZ0J1018036
VCID: 6DD0496C747B5F2742-8038
Address 94: LT3 Airbag
Part No HW: 9064461442
Shop #: WSC 00117 555 00000
ASAM Dataset: 3 3332
ROD: CRFT_AB_3_3331.rod (*)
VCID: 55A0018C34EBF7E79A-8000
9003 - Supply voltage: Lower limit not reached
Test Complete - Stored
Address 95: LT3 ESP
Part No SW: 9069022800 HW: 0004460153
ASAM Dataset: 3 4101
ROD: CRFT_ESP_3_36946.rod (*)
VCID: 04060CC88FF1BE6FBD-8050
Address 96: LT3 Instruments
Part No SW: 9069026400 HW: 9069012000
ASAM Dataset: 32 787
ROD: CRFT_KOMBI_32_787.rod
Address 99: LT3 Ign. Switch
Part No HW: 9065455808
ASAM Dataset: 67 257
ROD: CRFT_EZS_67_257.rod (*)
Address 9A: LT3 Central Locks Labels: 2E0-905-865-9A.clb
Component: HF-FFB 0805 0815
Revision: 00805000 Serial number: 12345678901234
00172 - Key 2 not learned
002 - Lower Limit Exceeded
Address 9B: LT3 Driver Door
Part No HW: 9068204126
ASAM Dataset: 33 773
ROD: CRFT_FTUHR_33_773.rod (*)
Address B0: LT3 Roof Display
Part No SW: 9069021000 HW: 9069010900
ASAM Dataset: 21 3
ROD: CRFT_DBE_21_3.rod (*)
VCID: 7BF47734F20FC197CC-802E
909B - Alarm Horn (H12): No communication
9001 - Terminal 30: Lower limit not reached
9020 - Interior light: Short circuit
Test Complete - Active/Stored
Address B1: LT3 Upper Console
Part No HW: 9065454107
ASAM Dataset: 67 3
ROD: CRFT1_OBF_67_3.rod (*)
Address B4: LT3 Central Elec.
Part No SW: 9064420700 HW: 9065453801
ASAM Dataset: 33 772
ROD: CRFT_EZE_33_772.rod (*)
909F - Brake Pad Wear Sensor (G34): Open circuit
Address B6: LT3 Steering Wheel
Part No SW: 9065402345 HW: 9065402345
ASAM Dataset: 72 257
ROD: CRFT_SML_72_257.rod (*)
VCID: 060216C0B9CD8C7FA3-8052
End-------------------------(Elapsed Time: 03:15)--------------------------
