The other day I was driving on the way to get gas and my "Check gas cap" light came on, I thought weird but okay. I filled up and put a few extra clicks on the gas cap and then when I started the car it was fairly hard to start. Shortly there after the MIL P0455 came one, as well as a couple other seemingly related vaults during a VCDS scan. As it were, I just swung by the dealership and bought a new gas cap as the rubber ring on mine was looking cracked and the tether to it has broken some time last year and that had been an annoyance that I know had more reason to take care of. I have since fueled up once more and once again the car was hard to start after the fill up. This all makes me think it's the evap/purge valve, N80. It's never been replaced before, and still has those annoying crimp bands on it. I just want to run it by everyone and see if anyone has other ideas before I just start tossing money at the problem, especially since the usually code for a broken N80 is P0441.
Auto-Scan results:
Auto-Scan results:
Wednesday,14,August,2019,21:12:32:26167
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: 3VWKJ71K66M6xxxx License Plate:
Mileage: 342700km-212943mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 52 56 62 72
VIN: 3VWKJ71K66M6xxxx Mileage: 342700km-212943miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 B HW: 1K0 907 115 B
Component: 2.0l R4/4V TFSI 0040
Revision: --H10--- Serial number: VWZ7Z0E2568520
Coding: 0403010A18070160
Shop #: WSC 66565 257 00032
VCID: 2517F1E459E7655F99F-8070
012555 - Low Pressure Fuel regulation
P310B - 004 - Fuel Pressure Outside Specification
Fault Frequency: 39
Mileage: 341260 km
Time: 23:06:47
RPM: 814 /min
Load: 29.4 %
Speed: 13.0 km/h
Temperature: 94.0°C
Temperature: 51.0°C
Absolute Pres.: 980.0 mbar
Voltage: 13.462 V
P310B - 008 - Fuel Pressure Outside Specification - Intermittent
Mileage: 341760 km
Time: 17:10:45
RPM: 877 /min
Load: 16.9 %
Temperature: 101.0°C
Temperature: 56.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.716 V
001109 - EVAP System
P0455 - 001 - Large Leak Detected - MIL ON
Fault Status: 11100001
Mileage: 341870 km
Time: 07:37:58
RPM: 2001 /min
Load: 21.2 %
Speed: 82.0 km/h
Temperature: 81.0°C
Temperature: 23.0°C
Voltage: 13.843 V
004243 - Bank 1; Fuel Measuring System 2
P1093 - 008 - Malfunction - Intermittent
Mileage: 342400 km
Time: 21:56:35
RPM: 1740 /min
Load: 11.4 %
Speed: 35.0 km/h
Temperature: 95.0°C
Temperature: 39.0°C
Voltage: 13.589 V
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Coding: 0021122
Shop #: WSC 00066 000 00000
VCID: 40D94070A685A0778A9-8014
Part No: 1K0 907 044 BA
Component: ClimatronicPQ35 066 0606
VCID: 678BBBECE36BB74F6B3-8032
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000121550
Coding: 05058E234004180000140000001400000028770B5C
Shop #: WSC 09449 444 52571
VCID: 2B0307DC3F03532F4FB-807E
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0402
Coding: 00065493
Shop #: WSC 09449
01505 - Bulb for Blinkers; Rear Right (M8)
Fault Status: 00101100
Reset counter: 199
Mileage: 341669 km
Voltage: 12.30 V
Fault Status: 01101100
Reset counter: 169
Mileage: 341218 km
Voltage: 13.65 V
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No SW: 8E0 035 593 E HW: 8E0 035 593 E
Component: SDAR XM H03 0080
Revision: 00000000 Serial number: AUZ4Z7E3031320
00003 - Control Module
014 - Defective
Fault Status: 01101110
Reset counter: 166
Mileage: 28901 km
Time: 00:08:59
02788 - Internal Communications Error
Fault Frequency: 147
Reset counter: 209
Mileage: 341218 km
Time: 17:28:49
Bin. Bits: 00000010
Bin. Bits: 00000000
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 1S AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD038G8Z
Coding: 0012627
VCID: 2E050EC80C112607685-807A
Subsystem 1 - Part No: 1K0 959 339 B
Component: BF-Gewichtsens. 006 0003
Subsystem 2 - Serial number: 6332MSME0A4A4F29P
Subsystem 3 - Serial number: 6342MSME0A3F3811D
Subsystem 4 - Serial number: 6351HSME075E432BD
Subsystem 5 - Serial number: 6361HSME0759656EK
Subsystem 6 - Serial number: 63727SME0A174021S
Subsystem 7 - Serial number: 63827SME072B1A383
01587 - Igniter 2 for Airbag; Drivers Side (N250)
Part No SW: 1K0 953 549 AJ HW: 1K0 953 549 AJ
Component: J0527 034 0070
Coding: 0002021
VCID: 7AADF29880D93AA784D-802E
Component: E0221 007 0050
01426 - Controls in Steering Wheel (E221)
Part No: 1K0 920 972 C
Component: KOMBIINSTRUMENT 3HL 1212
Coding: 0023203
VCID: 2C0104C03A0D5417461-8078
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001056168AD9
Coding: 3D7F03600F1002
VCID: 2A0D02D830F94A27B4D-807E
Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
Component: Kompass 005 0003
Revision: 00005000 Serial number: 1293324T05CJ01
Coding: 0000003
VCID: 392F2D94C55FF1BFCD7-806C
Component: IMMO 3HL 1212
Shop #: WSC 09215 444 101392
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 B HW: 3C0 959 760 B
Component: Sitzverstellung 0701
Revision: 00003000 Serial number: 00000000000000
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2377
Coding: 0001269
VCID: 363526A8F4411EC7205-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 323D1AB8182902E70CD-8066
Part No SW: 1K0 959 433 AT HW: 1K0 959 433 AT
Component: 01 KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 13900E880106083F2D04050FB0080F0480A540
VCID: 025D8A78E8097267DCD-8056
003 - Mechanical Failure
Fault Status: 01100011
Reset counter: 142
Mileage: 341564 km
Time: 16:30:20
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001269
VCID: 372B2BACF34BE7CF3B3-8062
Part No SW: 1K0 035 180 C HW: 1K0 035 180 C
Component: Radio DE2 011 0014
Revision: 00011000 Serial number: VWZ4Z7E2036415
Coding: 0040400
VCID: 2019E0F046C58077EA9-8074
00877 - Treble Speaker Rear Right (R16)
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2434
Coding: 0000144
VCID: 313F15B41D2F39FF757-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
End----------(Elapsed Time: 01:10, VBatt start/end: 12.2V/12.2V)-----------
