Results 1 to 10 of 18
Thread: VW Scricco ABS Pump Code lost (MK60EC1)
    Jun 2019
    My nephew has recently purchased a 2009 VW Scricco from an auction site, the car runs and drives however it had the ABS, Tracation control and brake light displayed and beeping along with other items. We wanted to resolve the ABS pump issue first for obvious reasons and then work through the other items.
    I did some online research and it seems the ABS pumps on these vehicles are prone to fail, we sent the unit off to be repaired however it turns out it that it's beyond repair so we purchased a second hand unit with the same part numbers.
    The mechanic said that the original ABS pump does not have a code and therefore he cannot code the second hand unit. I've got the following scan from the car when the original ABS pump was connected and it does show the code to be missing. The car is currently with the mechanic.
    Is there anyway of getting the ABS pump coding given where we are with it? let me know if you any other information is required and I'll try to provide that.
    thanks in advance!
    Friday,10,May,2019,18:32:18:25558
    VCDS Version: 18.9.1.0 (x64)
    VIN: WVWZZZ13Z9V015910   License Plate:
    Mileage: 157570km-97909mi   Repair Order: VW scirroco
    Chassis Type: 13 (1K0)
    Scan: 01 03 08 09 10 14 15 16 17 19 25 2E 42 44 46 52 56
    VIN: WVWZZZ13Z9V015910   Mileage: 157570km-97909miles
    Address 01: Engine (CBD)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 022 KD    HW: 03L 906 022 G
       Component: R4 2.0l TDI 0000SG  9979
       Revision: 13H01---    Serial number: VWX7Z0H93NM1BO
       Coding: 0001072
       Shop #: WSC 55776 001 1048576
       VCID: 71EF931B68CACCC222-8024
    008598 - Oxygen (Lambda) Sensor B1 S1
                   P2196 - 000 - Signal too High (Rich) - MIL ON
                        Fault Status: 11100000
                        Mileage: 154672 km
                        Time: 17:24:23
                        RPM: 2185 /min
                        Speed: 129.0 km/h
                        Lambda: 51.3 %
                        Mass Air / Rev.: 580.0 mg/str
                        Voltage: 0.375 V
                        (no units): 16.0
                        Voltage: 0.975 V
    Readiness: 1 1 0 0 0
       Part No SW: 1K0 907 379 CD    HW: 1K0 907 379 AD
       Component: ESP MK60EC1   H35 0120
       Revision: 00H35001
       VCID: 76E5A007C1A4EBFAF7-8022
                000 -  -
                        Reset counter: 130
                        Count: 4608
                        Count: 195
                        Count: 43008
       Part No SW: 1K0 820 047 JD    HW: 1K0 820 047 JD
       Component: Climatic PQ35   143 1313
       Revision: 00143033    Serial number: 00000000000000
       VCID: 6FEB95637EFEDA3234-803A
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-M.lbl
       Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
       Revision: 00H54000    Serial number: 00000008403739
       Coding: EC880F0300041A0067960E001900000000087B075C400124000000000000
       Shop #: WSC 00020 790 00000
       VCID: 326D5C17AD4CB7DA1B-8066
       Subsystem 1 - Part No: 1K8 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer 180808 022  0602
       Coding: 00038805
       Shop #: WSC 00020
       Component: RLS     291008 054  0402
       Coding: 00209133
       Shop #: WSC 00020
    Address 10: Park/Steer Assist (J446)       Labels:. 1K0-919-475.clb
       Part No SW: 1K0 919 475 F    HW: 1K0 919 475 F
       Component: PARKHILFE     005 1506
       Revision: 00005000    Serial number: 0 263 004 300
       Coding: 100001
       VCID: 3567670B9C22A0E23E-8060
    Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
       Part No SW: 3C0 907 376     HW: 3C0 907 376
       Component: DAEMPFUNGS-SG H07 0069
       Revision: 00000000    Serial number: 16100802910001
       Coding: 000180
       VCID: 66C5F04791041B7A47-8032
    01316 - ABS Control Module
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 130
                        Mileage: 157571 km
                        Time: 18:34:25
                        Bin. Bits: 00000000 00001000
       Part No SW: 1K0 909 605 AE    HW: 1K0 909 605 AE
       Component: 0H AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 003D1D00EWZP
       Coding: 0012360
       Subsystem 1 - Serial number: 6332MSME413147584
       Subsystem 2 - Serial number: 6342MSME40304B04+
       Subsystem 3 - Serial number: 6352QSME46104B0EH
       Subsystem 4 - Serial number: 6362QSME46102B3CH
       Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
       Component: J0527           053 0111
       Coding: 0000004
       VCID: 0303C9D34276CE52C0-8056
       Part No SW: 1K8 920 960 E    HW: 1K8 920 960 E
       Component: KOMBIINSTRUMENT VDD 1244
       Revision: V0003000    Serial number: VWX7Z0H93NM1BO
       Coding: 0003403
       VCID: 336359135256BED210-8066
       Part No SW: 1K0 907 530 S    HW: 1K0 907 951
       Component: J533__Gateway   H-- 0210
       Revision:   H--       Serial number: 3400K08A2303B2
       Coding: E9A81F06000212004001
       VCID: 377B6D03462E52F22C-8062
       Component: IMMO            VDD 1244
       Revision: A1001003    Serial number: 7661137131
       Coding: 020000
       Shop #: WSC 00040 040 00001
       VCID: 295FBB7B409AF402AA-807C
                000 -  -
                        Reset counter: 130
                        Mileage: 157571 km
                        Time: 18:37:34
       Part No SW: 1Q0 959 701 F    HW: 1Q0 959 701 F
       Component: Tuer-SG         008 2022
       Coding: 0016949
       Part No: 1K0 909 144 C
       Component: EPS_ZFLS Kl. 175    2301
       Revision: 00H15000
       VCID: 2A5D4477859CFF1AA3-807E
       Component:    KSG PQ35 G2  020 0205
       Coding: 81900A0002830C7F3F04840570085ACE903CA0
       Subsystem 2 - Part No: 1K8 951 171
       Component: DWA-Sensor      001 0104
       Part No SW: 1Q0 959 702 F    HW: 1Q0 959 702 F
       Coding: 0016948
       VCID: 38796E3F4B305D8A25-806C
       Part No SW: 3C8 035 195     HW: 3C8 035 195
       Component: Radio RCD510  036 0130
       Revision: 00000001    Serial number: VWZ1Z3H3374556
       Coding: 0100040004
       VCID: 65C7F74B6C0210624E-8030
    End-------------------------(Elapsed Time: 01:42)--------------------------
    OP is now verified. Moving to Car Repair Support.
    Vehicle Identification No. WVWZZZ13Z9V015910
    Model Scirocco 2.0
    SCI
    Date of production 07.11.2008
    Model year 2009
    Sales type 13726L
    Engine Code CBDB
    Transmission Code KRM
    Part No SW: 03L 906 022 KD HW: 03L 906 022 G <<<<<<<<<<<<<<<<<<<<<<<<<<<< FOD CHECK PASS!
    Coding: 0001072
    Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD <<<<<<<<<<<<<<<<<<<<<<<<< FOD CHECK PASS!
    Revision: 00H35001
    Coding: 763B00F5092300FF6E1400E5901900000000 VIN STRIP RHD
    Coding: 763BC0F5092300FF6E1403E5901900813000 RHD TRY THIS
    Welcome OP please try the green and report back .........
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PE Wheel bolts with anti-theft protection (unlockable)
    Vehicle class differentiation units/platform components 7KB Vehicle class differentiation -130-
    drive-off assistance UG0 Without hill start assist/hill descent control/comfort driving assist
    Emission standard 7MG Emission standard EU5
    Trailer hitch 1D0 without trailer towing
    airbag 4UF Airbag for driver and front passenger with front passenger airbag deactivation
    Aktivkohlebehälter / Ottopartikelfilter 1E0 Without activated charcoal canister
    Aerials 8ZH Antenna for AM/FM reception, "diversity"
    Exterior mirror setting 6XN Exterior mirrors, power-adjustable/ separately heated
    Left exterior mirror 5SJ Left exterior mirror, convex
    Right exterior mirror 5RV Right exterior mirror, aspherical
    Drive type 1X0 Front-wheel drive
    "Multimedia"video/DVD/notebook connection 9WL Jack for external audio source
    Equipment levels A8F Sports equipment
    Brake type in rear 1KD Disc brakes in rear
    batteries J0N Battery 330 A (61 Ah)
    Brake type, front 1ZE Disc brakes in front (Geomet D)
    Battery/alternator capacity NY0 Standard battery/alternator capacity
    Component part sets with country-specific design requirements B0N Component parts set, complying with vehicle type for Great Britain, various parts
    vehicle tools and jack 1S1 vehicle tools and jack
    Brake systems 1AT Electronic stability control (ESC)
    Owner's manuals 0VF Information kit in English
    brake wear indicator 9U1 brake wear indicator
    Heated washer nozzles 9T0 Without heated washer nozzles
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    CD changer/CD player 7A0 Without CD changer/CD player
    "Charism" 2H1 "drive select"
    General operating permit, alterations C03 Operating permit, alteration
    Roof insert/convertible top 3FA roof without cut out
    Suspension system in rear UB7 Rear shock absorption for sports version
    Suspension system in front G03 Shock absorption in front
    Insert for the filling up of unleaded fuel/fuel type 2G5 Filler neck module 1 without insert
    Installation differentiation for components 0EN Installation differentiation for transmission MQ 350 -- vehicle components --
    Theft protection system 7AL Anti-theft alarm system, interior monitoring, backup horn and towing protection
    Park distance control 7X1 Park distance control
    Electric interface for external use UF6 Electric interface for external use (MEDIA-IN jack)
    Manufacturing sequence differentiation 0FA Standard manufacturing sequence
    window regulator 4R4 Power windows with comfort operation and circuit breaker
    fire extinguisher 6A0 without fire extinguisher
    Pedal cluster VF0 Standard pedal cluster
    Headlight activation 8K3 Daytime headlights with automatic headlight control and coming home function
    Alternators 8GU Alternator 140 A
    Weight category rear axle 0YA Weight range 1 installation control only, no requirement forecast
    Weight category front axle L55 Suspension range 55 installation control only, no requirement forecast
    Base engine TU3 4-cylinder diesel engine 2.0 l unit 03L.H
    Luggage netting/pocket on backrest(s) 4U0 Without luggage nets/pockets on backrests
    Luggage compartment cover 3U1 Folding trunk cover
    cruise control system 8T0 Without cruise control system (CCS)
    Transmission specifications G0K 6-speed manual transmission
    handle for hand brake lever 6PC handbrake lever grip (leather)
    Rear window wiper and washer system 8M1 Rear window wiper washer system with intermittent wipe
    Rear seats 3KC Rear bench seat, not split, split backrest, folding
    Heating and air-conditioning system 9AP Climatic air-conditioning system (semi-automatic)
    Headlamps 8BK Twin headlamps for driving on the left, with integrated high beam
    Customized installation FC0 Without individual installation
    Interior light in footwell 6T1 Interior light in footwell
    Instrument clusters U5B Instrument insert, mph speedometer Great Britain
    Breakaway interior rearview mirror 4L6 Breakaway interior rearview mirror, auto-dimming
    Sticker (customized or special edition) 0KA Without decals and emblems
    Body style K8C Coupe
    coolbox 1W2 Glove compartment cooling system
    Climatic zones 0Y1 Standard climatic zones
    Compass/road sign display QR0 Without compass/road sign display/ dynamic road sign display
    Head restraints 3J1 Hight-adjustable head restraints for front seats
    Fuel quantity for initial filling 1Z2 Increase in initial standard fuel filling
    Fuel systems 0F5 Fuel system for diesel engine
    Body measures 5C0 Without special body measures
    Rear license plate bracket 6P1 Rear license plate carrier (ECE)
    Front license plate bracket 6W1 Front license plate carrier (large)
    Paint preservative/transit coating 5K5 Transport protection film with additional transport protection measures
    Steering system arrangement L0R Right-hand drive
    steering 1N3 Speed-related variable steering assist (Servotronic)
    Backrest release 3H9 Backrest release for front seats with Easy Entry feature
    Lumbar support 7P0 Without lumbar support in seat backrests
    steering wheels 1XU Leather steering wheel with aluminium trim
    Speaker installation 8RM 8 speakers (passive)
    Headlight range control 8Q1 Headlight range control
    Center armrest 6E3 Center armrest in front
    Multi-function display/trip computer 9Q1 Multi-function display/trip computer
    Engine cooling 8Z5 not hot country
    Engine specifications D91 4-cyl. turbo diesel engine 2.0 L/103 KW (4 V) TDI common rail TG3/TJ3/TU3/TL4/TP4/TM3/TW3/TR4/TS1/TN5
    Left vanity mirror 4SD Vanity mirror, left, illuminated
    Right vanity mirror 4TD Vanity mirror, right, illuminated
    Navigation device 7Q0 without navigation system
    rear fog lamp 8TD Rear fog light for driving on the left
    Front fog lamp/additional headlamp 8WA Without fog lights
    Rear of platform module base 4P0 Rear floor panel module, type 1
    Platform group class 7PA Platform group class 1
    Hubcaps 1NL Trims for alloy wheels
    Wheels CL9 Alloy wheels 8J x 17
    Radios 8AI Radio "RCD510 MP3"
    Smoker's/non-smoker's package 9JA Non smoker version
    Tire pressure monitoring system 7K0 Without tyre pressure monitor
    tire HK0 Tires 235/45 R17 97W x1
    Spare wheel/breakdown kit 1G6 Space-saving spare wheel
    Restraint systems, front 3QT 3-point seat belts in front, with tensioner and height adjustment
    PDD Adaptive chassis control
    PJ1 "Donington" 4 alloy wheels 8J x 17 tires 235/45 R17
    PJW Space and weight saving spare wheel (16-inch)
    PLA "Lights & Vision" package
    RHC "RCD 510" 4 x 20 W, 8 speakers
    WD2 Anti-theft alarm system "Plus" incl. single door opening
    WDI Multimedia socket MEDIA-IN
    Gearshift knob/handle 6Q2 Gearshift knob/handle in leather
    Special labels/plates 0SS Labels in English and French
    Locking mechanism for boot lid/cover rear 4E2 Tailgate/trunk lid release from inside (electrically)
    Front seat, left 3TG Sports comfort seat in front, left
    Front seat, right 3SG Sports comfort seat, front, right
    Seat belt check 9P3 Seat belt reminder, electric contact in buckle
    Outer rear seat belts 3ZB 3-point seat belts, outer rear with ECE label
    seat covers N3A Seat trim covers in fabric
    Seat adjustment 3L3 Manual height adjustment for front seats
    seat heater 4A0 without seat heater
    Safety head restraint system 3K0 w/o safety head restraint system
    Horns 8Y1 Two-tone horn
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    power outlet 7B2 12 volt socket in luggage compartment
    Bumper 2JC Comfort bumpers
    Rear stabilizer 0BE Rear stabilizer
    Front stabilizer bar 0AD Front stabilizer bar
    Headlamp washer system 8X0 Without headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N3 intermittent windscreen wiper with rain sensor
    Nameplate set 0ND Nameplate set "TDI"
    Mass damper for steering wheels 1Q0 steering wheel without balance weight
    Door and lid locking system 4K3 Central locking w/ radio remote control, interior controls and SAFELOCK
    Type approval countries/countries with special requirements B09 Type approval country GB/Northern Ireland
    Carrier frequency for remote control 5D1 Carrier frequency 433.92 to 434.42 Mhz
    Partition 3CA without partition
    Door and side trim panels 4AF Door and side trim panel in foam film and woven fabric
    doors 0A1 2 doors
    TV reception/digital radio reception QV0 without TV/digital radio reception
    Front underbody guard 1SA Without additional front underbody guard
    Identification plates 1EX Special identification plate for EU
    Delivery equipment 2A0 Without delivery equipment
    First aid kit / warning triangle 1T0 Without first-aid material, without warning triangle
    Telephone / telematics 9W0 Without car phone preparation/ installation
    LongLife Service Regime QG1 LongLife Service Regime
    Heat accumulator system/auxiliary heater 7E6 electric air additional heater
    Windshield Glass 4GF Windshield in heat-insulating glass
    Washer fluid level indicator 8W0 without washer water level indicator
    floor mats 0TA without floor mats
    Additional child seat anchors 3B4 Child seat anchors for child seat system ISOFIX
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
  4. Likes Uwe, Golftwincharged liked this post
    Jun 2019
    Thank you, I have forwarded the code to the mechanic and will report back with his feedback.
    Jun 2019
    Hi Jack, thanks for the code, unfortunately that didn’t work, are there any other that you suggest for me to try?
    Thanks in advance
    Jun 2019
    Can Anyone assist or suggest anything else?
    Find me auto-scans of other sciroccos of this region to observe.
  9. #8
    Jun 2019
    Hi Jack, thanks for replying, I won’t be able to get this unless there is someone else on here with a similar car?
  10. #9
    Try this:
    763B40F5492300FF6E1402E5921900823000
    The information.
  11. Likes Jack@European_Parts, Uwe, Jetta ,97 liked this post
  12. #10
    Jun 2019
    Thank you, I’ve forwarded it to my mechanic, will let you know either way.
