2009 Golf ABS fault code 01130
Justin0
Wales, UK
C?ID=538994
Hi all, thank you for adding me to your forum.
I would like to ask for a bit of help with my 2009 MK6 Golf. I'm having some issues with the ABS system and getting flashing ABS, Handbrake and TC lights flashing. I'm getting 01130 Implausible signal. Are there any common issues with these? I'm thinking it's the ABS module at fault. I've spoken to VW and they did a recall in 2017 and updated the software.
Any advice welcomed.
[/Monday,12,August,2019,18:21:59:11626
VCDS Version: 19.6.1.0
VIN: WVWZZZ1KZ9P456476   License Plate: CA09FKU
Mileage: 154770km-96169mi   Repair Order:
Chassis Type: 1K-VW36 (1K0)
VIN: WVWZZZ1KZ9P456476   Mileage: 154770km-96169miles
Address 01: Engine (BSE)       Labels: 06A-906-033-BGU.lbl
   Part No SW: 06A 906 033 JF    HW: 06A 906 033 JF
   Component:  BSE S71 1.6 2V     3840
   Revision: --H01---    Serial number:
   Coding: 0064071
   Shop #: WSC 00028 028 00001
   VCID: 6CD000FF4FA69D2F55-8038
Readiness: 0010 1001
   Part No SW: 1K0 907 379 CD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0120
   Revision: 00H35001
   Coding: 133B200D09270000C80F04EB901F00803000
   Shop #: WSC 60792 001 1048576
   VCID: 76E42297C1EA57FFB3-8022
01130 - ABS Operation
                    Reset counter: 139
                    Mileage: 154775 km
                    Date: 2014.01.02
                    Time: 17:55:45
                    Count: 4608
                    Count: 120
                    Count: 48655
                    Count: 62701
   Part No SW: 3C8 907 336     HW: 3C8 907 336
   Component: Climatic      120 0102
   Revision: 00004001
   Coding: 0000000000
   ASAM Dataset: EV_Climatic A01001
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 6ADC06E78D52831F27-803E
   Part No SW: 1K0 937 084     HW: 1K0 937 084
   Component: BCM PQ35  B   020 0358
   Revision: 00020000
   Coding: 40180A3A9025180044000080100000E441010088524D8960648000000000
   VCID: 6BD203E38AA89A175C-803E
   Component: Wischer 13010  21  0501
   Coding: 009795
                    Fault Status: 00101110
                    Reset counter: 178
                    Mileage: 154769 km
                    Date: 2013.12.31
                    Time: 20:55:23
                    Voltage: 13.80 V
                        Term 50 Off
   Part No SW: 5K0 959 655     HW: 5K0 959 655
   Component: AirbagVW10    033 0604
   Serial number: 003C2D08SFRM
   Coding: 00003136
   Shop #: WSC 00028 028 00307
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 77FA2F93CEE02EF7A8-8022
   Component: S.Sens.Fahr.V  U01 ----
   Serial number: 49634144ZZZZZZZZZZZZ
   Component: S.Sens.Beif.V  U01 ----
   Serial number: 7C675444ZZZZZZZZZZZZ
   Serial number: 0042187AZZZZZZZZZZZZ
   Serial number: 1E4B204BZZZZZZZZZZZZ
   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
   Component: J0527           853 0111
   Coding: 0000004
   VCID: 03024B434238725784-8056
   Part No SW: 5K0 920 960 F    HW: 5K0 920 960 F
   Component: KOMBI         H21 0029
   Coding: 470B00
   Shop #: WSC 00028 028 00024
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
   VCID: 3068D48F6B0E39CF29-8064
   Revision:   H07 01    Serial number: 180109F2000077
   Coding: E9801F06000202000001
   VCID: 377AEF934660EEF768-8062
Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
   Component: IMMO          H21 0029
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
   Part No SW: 1K0 959 701 AF    HW: 1K0 959 701 AF
   Component: Tuer-SG         008 2044
   Coding: 0000564
   VCID: 72EC1E876D824BDF9F-8026
   Part No: 1K0 909 144 E
   Component: EPS_ZFLS Kl. 67     2501
   Revision: 00H15000
   VCID: 2C50C0FF8F265D2F15-8078
   Part No SW: 1K0 959 702 AF    HW: 1K0 959 702 AF
   Coding: 0000564
   VCID: 73E21B83129842D794-8026
   Part No SW: 1K0 035 156 A    HW: 1K0 035 156 A
   Component: Radio         018 0041
   Revision: R0018000    Serial number: VWZAZ1I7095732
   Coding: 0000020002
   VCID: 214E21CB38E48047B6-8074
End-------------------------(Elapsed Time: 02:14)--------------------------
Address 09,1K0 937 084 ,recoded (Long Coding),from,40180A3A9025180044000080100000E441010088524D8960648000000000,to,46180A3A9025180044000080100000E441010088524D8960648000000000,(00028/028/00001),
Justin0
Wales, UK
C?ID=538994
Hi, yeah I found that earlier. It's looking more likely that the module is toast. Cheers..
Justin0
Wales, UK
C?ID=538994
Would I be able to use a different part number and put in my coding or do I have to use exact number match?
In many case, the original part number has been superseded by newer one(s). You should refer to a proper parts catalog, because your chances with any old random MK60EC1 module are not good.
Justin0
Wales, UK
C?ID=538994
Where could I find the information, VW gave the same part number but ending in BJ but no numbers in between. It would be interesting to know what the common failure is and whether it's repairable. I just assumed the units could be recorded?
A proper parts catalog is something that's officially only available via subscription. Of course the dealer has access.
Justin0
Wales, UK
C?ID=538994
Thank you Uwe, would a 2010 Tsi 1.4 unit work? It's 1k0614157CP, could that be used?
Thanks in advance
Justin
Dana
Western PA, USA
Hi Justin,
Your original module SW # was 1K0 907 379 AD. VW's re-flash changed that to 1K0 907 379 CD:
Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD​
Installing another used module with the early/failure prone AD or CD part number is risky as Uwe mentioned. You don't want to find yourself replacing the replacement shortly after installation due to the labor involved swapping parts. The same applies to a used unit from a newer vehicle because it isn't very likely one from a 2010 MY will be correct.
The direct replacement repair kit (module only) for 1K0 907 379 AD is 1K0 907 375 AN. Repair kits are the most cost effective route when using new replacement parts:
https://photos.app.goo.gl/g3KryhxXQVxSjHR26
The entire (pump and module) new assy is: 1K0 614 517 BJ BEF but those are significantly more cost wise:
https://photos.app.goo.gl/xzRREwsu4tVwEt4f8
Justin0
Wales, UK
C?ID=538994
Thank you Dana, I'll look at this option tomorrow. I didn't realise I could just change the module. I've done it the other way round for brake pressure issues on mk5's but when I asked VW for a repair kit they told me it wasn't available. So with that in mind, could I get that module part number on a different unit and just fit that to my pump? I'm looking for the most cost effective route and ideally source a used part as labour isn't important as I'll fit it myself. The car is just our run around until we find our replacement vehicle.
Thank you for your help, it's very much appreciated.
Kind regards
Justin
Dana
Western PA, USA
Justin0
Wales, UK
C?ID=538994
So, I could fit a 1K0907379AN to my pump and recode?
Justin0
Wales, UK
C?ID=538994
Hi, just wondering if 1K0907379AS would fit my car? Any ideas? I'm struggling to find exact number matches.
Thanks in advance
Justin
Justin0
Wales, UK
C?ID=538994
Well after much searching and the uncertainty of what abs module will fit and operate, I've finally sorted the car out. I managed to get a used module with a 1K061451AS part number, install it and re code with my old details abs voila it works! Thanks all for your help to date. The module options on the VAG range would appear to be a black art! Who'd have thought there would be so many variants.
avmc
New Member
Bulgaria
Hi to all i have a fault 01130 on my 1K0 907 379 AE module what module nomber to look to replace my ? Thanks :)
avmc
New Member
Bulgaria
Hi i find a solution i raplace my with 1KO 907 379 BE and its fit perfect just coding and you are done :)
