Results 1 to 10 of 15
Thread: 2009 Golf ABS fault code 01130
    New User
    Aug 2019
    Wales, UK
    Hi all, thank you for adding me to your forum.
    I would like to ask for a bit of help with my 2009 MK6 Golf. I'm having some issues with the ABS system and getting flashing ABS, Handbrake and TC lights flashing. I'm getting 01130 Implausible signal. Are there any common issues with these? I'm thinking it's the ABS module at fault. I've spoken to VW and they did a recall in 2017 and updated the software.
    Any advice welcomed.
    [/Monday,12,August,2019,18:21:59:11626
    VCDS Version: 19.6.1.0
    VIN: WVWZZZ1KZ9P456476   License Plate: CA09FKU
    Mileage: 154770km-96169mi   Repair Order:
    Chassis Type: 1K-VW36 (1K0)
    VIN: WVWZZZ1KZ9P456476   Mileage: 154770km-96169miles
    Address 01: Engine (BSE)       Labels: 06A-906-033-BGU.lbl
       Part No SW: 06A 906 033 JF    HW: 06A 906 033 JF
       Component:  BSE S71 1.6 2V     3840
       Revision: --H01---    Serial number:
       Coding: 0064071
       Shop #: WSC 00028 028 00001
       VCID: 6CD000FF4FA69D2F55-8038
    Readiness: 0010 1001
       Part No SW: 1K0 907 379 CD    HW: 1K0 907 379 AD
       Component: ESP MK60EC1   H35 0120
       Revision: 00H35001
       Coding: 133B200D09270000C80F04EB901F00803000
       Shop #: WSC 60792 001 1048576
       VCID: 76E42297C1EA57FFB3-8022
    01130 - ABS Operation
                        Reset counter: 139
                        Mileage: 154775 km
                        Date: 2014.01.02
                        Time: 17:55:45
                        Count: 4608
                        Count: 120
                        Count: 48655
                        Count: 62701
       Part No SW: 3C8 907 336     HW: 3C8 907 336
       Component: Climatic      120 0102
       Revision: 00004001
       Coding: 0000000000
       ASAM Dataset: EV_Climatic A01001
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 6ADC06E78D52831F27-803E
       Part No SW: 1K0 937 084     HW: 1K0 937 084
       Component: BCM PQ35  B   020 0358
       Revision: 00020000
       Coding: 40180A3A9025180044000080100000E441010088524D8960648000000000
       VCID: 6BD203E38AA89A175C-803E
       Component: Wischer 13010  21  0501
       Coding: 009795
                        Fault Status: 00101110
                        Reset counter: 178
                        Mileage: 154769 km
                        Date: 2013.12.31
                        Time: 20:55:23
                        Voltage: 13.80 V
                            Term 50 Off
       Part No SW: 5K0 959 655     HW: 5K0 959 655
       Component: AirbagVW10    033 0604
       Serial number: 003C2D08SFRM
       Coding: 00003136
       Shop #: WSC 00028 028 00307
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 77FA2F93CEE02EF7A8-8022
       Component: S.Sens.Fahr.V  U01 ----
       Serial number: 49634144ZZZZZZZZZZZZ
       Component: S.Sens.Beif.V  U01 ----
       Serial number: 7C675444ZZZZZZZZZZZZ
       Serial number: 0042187AZZZZZZZZZZZZ
       Serial number: 1E4B204BZZZZZZZZZZZZ
       Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
       Component: J0527           853 0111
       Coding: 0000004
       VCID: 03024B434238725784-8056
       Part No SW: 5K0 920 960 F    HW: 5K0 920 960 F
       Component: KOMBI         H21 0029
       Coding: 470B00
       Shop #: WSC 00028 028 00024
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
       VCID: 3068D48F6B0E39CF29-8064
       Revision:   H07 01    Serial number: 180109F2000077
       Coding: E9801F06000202000001
       VCID: 377AEF934660EEF768-8062
    Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
       Component: IMMO          H21 0029
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
       Part No SW: 1K0 959 701 AF    HW: 1K0 959 701 AF
       Component: Tuer-SG         008 2044
       Coding: 0000564
       VCID: 72EC1E876D824BDF9F-8026
       Part No: 1K0 909 144 E
       Component: EPS_ZFLS Kl. 67     2501
       Revision: 00H15000
       VCID: 2C50C0FF8F265D2F15-8078
       Part No SW: 1K0 959 702 AF    HW: 1K0 959 702 AF
       Coding: 0000564
       VCID: 73E21B83129842D794-8026
       Part No SW: 1K0 035 156 A    HW: 1K0 035 156 A
       Component: Radio         018 0041
       Revision: R0018000    Serial number: VWZAZ1I7095732
       Coding: 0000020002
       VCID: 214E21CB38E48047B6-8074
    End-------------------------(Elapsed Time: 02:14)--------------------------
    Address 09,1K0 937 084 ,recoded (Long Coding),from,40180A3A9025180044000080100000E441010088524D8960648000000000,to,46180A3A9025180044000080100000E441010088524D8960648000000000,(00028/028/00001),
    Last edited by Boki Ar; 08-14-2019 at 01:20 PM. Reason: Only add [/ to close [/CODE] tag
    New User
    Aug 2019
    Wales, UK
    Hi, yeah I found that earlier. It's looking more likely that the module is toast. Cheers..
    New User
    Aug 2019
    Wales, UK
    Would I be able to use a different part number and put in my coding or do I have to use exact number match?
    Quote Originally Posted by Justin0 View Post
    In many case, the original part number has been superseded by newer one(s). You should refer to a proper parts catalog, because your chances with any old random MK60EC1 module are not good.
  6. Likes PetrolDave, Dana liked this post
    New User
    Aug 2019
    Wales, UK
    Where could I find the information, VW gave the same part number but ending in BJ but no numbers in between. It would be interesting to know what the common failure is and whether it's repairable. I just assumed the units could be recorded?
    A proper parts catalog is something that's officially only available via subscription. Of course the dealer has access.
  9. #8
    New User
    Aug 2019
    Wales, UK
    Thank you Uwe, would a 2010 Tsi 1.4 unit work? It's 1k0614157CP, could that be used?
    Thanks in advance
    Justin
  10. #9
    United States
    Hi Justin,
    Your original module SW # was 1K0 907 379 AD. VW's re-flash changed that to 1K0 907 379 CD:
    Installing another used module with the early/failure prone AD or CD part number is risky as Uwe mentioned. You don't want to find yourself replacing the replacement shortly after installation due to the labor involved swapping parts. The same applies to a used unit from a newer vehicle because it isn't very likely one from a 2010 MY will be correct.
    The direct replacement repair kit (module only) for 1K0 907 379 AD is 1K0 907 375 AN. Repair kits are the most cost effective route when using new replacement parts:
    https://photos.app.goo.gl/g3KryhxXQVxSjHR26
    The entire (pump and module) new assy is: 1K0 614 517 BJ BEF but those are significantly more cost wise:
    https://photos.app.goo.gl/xzRREwsu4tVwEt4f8
  11. Likes Uwe, Boki Ar, PetrolDave liked this post
  12. #10
    New User
    Aug 2019
    Wales, UK
    Thank you Dana, I'll look at this option tomorrow. I didn't realise I could just change the module. I've done it the other way round for brake pressure issues on mk5's but when I asked VW for a repair kit they told me it wasn't available. So with that in mind, could I get that module part number on a different unit and just fit that to my pump? I'm looking for the most cost effective route and ideally source a used part as labour isn't important as I'll fit it myself. The car is just our run around until we find our replacement vehicle.
    Thank you for your help, it's very much appreciated.
    Kind regards
    Justin
  13. Likes Dana liked this post
