Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: 2015 Jetta GLI ABS Lost Coding/has no coding
    Aug 2019
    The coding was accepted but as you said it did not remain due to the other fault codes. I will be working on the car again soon and will put the updated results and DTCs taking care of.
  2. #12
    Aug 2019
    ABS Long Coding
    Car accepted coding but has come back with wheel speed sensor codes. I was able to get the coding to stay in the module. Here is the updated auto scan. Other codes are in the process of being fixed as car is being assembled and some parts are being ordered. As always I greatly appreciate the support!
    Monday,11,November,2019,16:52:43:59206
    VIN: 3VW4T7AJ6GM246967   License Plate:
    Chassis Type: AJ-VW36 (7N0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 25 2B 3C 42 44 46 47 4F 52
              55 5F 62 72 75
    VIN: 3VW4T7AJ6GM246967   Mileage: 23330km-14496miles
    Address 01: Engine (J623-CPPA)       Labels:. 06K-907-425-V2.clb
       Part No SW: 06K 906 071 AT    HW: 06K 907 425 C
       Component: R4 2.0l TFS   H13 2346
       Revision: --H13---
       Coding: 001D0012242400171000
       Shop #: WSC 00066 000 00018
       ASAM Dataset: EV_ECM20TFS02006K906071AT 001003
       ROD: EV_ECM20TFS02006K906071AT.rod
       VCID: 7DB2E27FEC1628A7CC-8028
    16837 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
              P2185 00 [039] - Signal too High
                        Mileage: 23332 km
                        Time: 00:00:00
                        Coolant temperature: 17 C
                        Intake air temperature: 1 C
                        Voltage terminal 30: 11.601 V
                        Engine: operating status: ES
                        STATE_LS_SAE[1]: INI
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 98 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                        FAC_TPS_1_SAE: 17.968750 %
                        FUP_H_SAE: 12530.0 kPa
    17791 - Coolant Pump Control Circuit
              P2600 00 [039] - Open
                        Mileage: 23332 km
                        Time: 00:00:00
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 98 kPa
    15252 - Relay for Secondary Air Injection Pump (J299)
              P0418 00 [101] - Malfunction
                        Mileage: 23332 km
                        Time: 00:00:00
                        Engine speed: 1610.50 /min
                        Normed load value: 20.8 %
                        Intake air temperature: 3 C
                        Voltage terminal 30: 11.289 V
                        Engine: operating status: IS
                        STATE_LS_SAE[1]: OL_CDN
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 43 kPa
                        FAC_TPS_1_SAE: 13.671875 %
                        FUP_H_SAE: 10530.0 kPa
    18876 - Cruise Control Switch (E45)
              P0568 00 [039] - Implausible Signal
                        Fault Frequency: 7
                        Mileage: 23332 km
                        Time: 00:00:00
                        ACC variants (coding): CCS
                        CCS Switch: CCS operating unit
                        Cruise control switch actuation-Main switch hardware: not activated
                        Cruise control switch actuation-Main switch CAN: not activated
                        Cruise control switch actuation-Control component verified: No
                        ACC variants: ACC
    19854 - Steering Column Control Module
              U0212 00 [039] - No Communications
                        Mileage: 23332 km
                        Time: 00:00:00
                        ECU_STATE: ENG_STOP
                        Engine oil temperature: 1.0 C
                        Time since engine start: 0.0 s
                        T_ES: 11 min
                        STATE_ERR_ABC_PRED: 5
    Readiness: 1110 1101
       Part No SW: 02E 300 063 P    HW: 02E 927 770 AL
       Component: GSG DSG AG6     531 4907
       Revision: 06253104    Serial number: 00001507051438
       VCID: 2306F407E232BE579A-8076
    18275 - Powertrain Data Bus
                P1867 - 000 - Missing Message from Steering Wheel (J527)
                        Fault Frequency: 7
                        Reset counter: 40
                        Mileage: 23332 km
                        Date: 2019.11.11
                        Time: 08:46:41
       Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
       Component: ESP MK60EC1   H46 0175
       Revision: 00H46001
       Coding: A14B600C49260000851406EA922000412118F02A
       Shop #: WSC 00066 123 12345
       VCID: 75A2FA5FDC2670E784-8020
    03842 - RPM Sensor Rear Right: Incorrect Signal
                        Reset counter: 224
                        Mileage: 23332 km
                        Count: 3
                        Count: 12
                        Count: 20480
                        Count: 87
                        Count: 41984
                        Count: 512
    03841 - RPM Sensor Rear Left: Incorrect Signal
                        Reset counter: 224
                        Mileage: 23332 km
                        Count: 3
                        Count: 12
                        Count: 20480
                        Count: 71
                        Count: 41984
                        Count: 512
                003 - Mechanical Failure
                        Fault Status: 01100011
                        Reset counter: 224
                        Mileage: 23332 km
                        Count: 3
                        Count: 12
                        Count: 20480
                        Count: 288
                        Count: 41984
                        Count: 512
       Revision: 00092000    Serial number: 0374283187
       Coding: 030C0C
       Shop #: WSC 00066 000 00295
       VCID: 373E30578EAAC2F756-8062
       Part No SW: 1K8 907 044 AR    HW: 1K8 907 044 AR
       Component: Climatronic   H05 0304
       Revision: 00001K02
       Coding: 0050019002
       Shop #: WSC 00066 000 00319
       VCID: 7F4E1877E61A3AB7DE-802A
              B10AB F0 [009] - Too Low
                        Reset counter: 222
                        Mileage: 23303 km
                        Date: 2019.08.14
                        Time: 05:28:26
       Part No SW: 5K0 937 087 AJ    HW: 5K0 937 087 AJ
       Component: BCM PQ35 H+   122 0183
       Revision: BL122001
       Coding: EF200A1A902F06D40188008124000D4C0174000845A08DB2E4842000A040
       VCID: 7DB2E27FE41628A7CC-8028
       Component: RLS 250615 05  54  0403
       Coding: 02300A
    7 Faults Found:
                        Reset counter: 224
                        Mileage: 23332 km
                        Date: 2019.11.11
                        Time: 09:08:57
                        Voltage: 11.60 V
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 224
                        Mileage: 23332 km
                        Date: 2019.11.11
                        Time: 08:48:56
                        Voltage: 11.40 V
                        Reset counter: 224
                        Mileage: 23332 km
                        Date: 2019.11.11
                        Time: 08:48:56
                        Voltage: 11.40 V
                        Reset counter: 224
                        Mileage: 23332 km
                        Date: 2019.11.11
                        Time: 08:48:56
                        Voltage: 11.40 V
                        Reset counter: 224
                        Mileage: 23332 km
                        Date: 2019.11.11
                        Time: 08:48:56
                        Voltage: 11.40 V
    02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                        Reset counter: 224
                        Mileage: 23332 km
                        Date: 2019.11.11
                        Time: 08:47:49
                        Voltage: 11.55 V
    02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                        Reset counter: 224
                        Mileage: 23332 km
                        Date: 2019.11.11
                        Time: 08:47:49
                        Voltage: 11.55 V
       Part No SW: 1K8 919 472 B    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0479
       Revision: --------    Serial number: 39311520205556
       Coding: 0071155011
       ASAM Dataset: EV_EPHVA18VW364GP00 001006
       VCID: 36203D5389A03BFF4D-8062
    1113107 - Front Parking Aid Sensor(s)
              B10FC 13 [008] - Open Circuit
                        Reset counter: 222
                        Mileage: 23303 km
                        Date: 2019.08.14
                        Time: 05:30:26
    Address 15: Airbags (J234)       Labels:* 561-959-655.clb
       Part No SW: 561 959 655     HW: 561 959 655
       Component: AirbagVW11    001 0207
       Serial number: 003RXM00YFRW
       Coding: 8CCCF000000000005000001AC20800000065
       Shop #: WSC 00066 790 00012
       ASAM Dataset: EV_AirbaVW11SMEVW411 001002
       ROD: EV_AirbaVW11SMEVW411_VW32.rod
       VCID: 6386B4076AB2FE57DA-8036
       Component: BF-Gewichtss.  H11 0021
       Serial number: IBH000000000003DDMDO
       Coding: 30314C
       Subsystem 2 - Part No SW: -----------    HW: 480 001 806 15
       Serial number: 35700000000D1145F41G
       Subsystem 3 - Part No SW: -----------    HW: 480 001 806 15
       Serial number: 3580000000022145F417
       Subsystem 4 - Part No SW: -----------    HW: 480 022 107 15
       Component: SideSensor_Dr  000 0148
       Serial number: 3510001C31B2C526751Y
       Subsystem 5 - Part No SW: -----------    HW: 480 022 107 15
       Component: SideSensor_Pr  000 0148
       Serial number: 3520001C31B2C52103FZ
       Subsystem 6 - Part No SW: -----------    HW: -----------
       Component: FrontSensor_D  --- ----
       Serial number: -------------------$
       Subsystem 7 - Part No SW: -----------    HW: -----------
       Component: FrontSensor_P  --- ----
                        Mileage: 23303 km
                        Date: 2019.08.14
                        Time: 05:28:28
    9443861 - Driver's Front Airbag Crash Sensor
              B101A 15 [137] - Open or Short to Plus
                        Mileage: 23303 km
                        Date: 2019.08.14
                        Time: 05:28:30
    9444117 - Front Passenger's Front Airbag Crash Sensor
              B101B 15 [137] - Open or Short to Plus
                        Mileage: 23303 km
                        Date: 2019.08.14
                        Time: 05:28:30
       Part No SW: 1K5 953 521 CR    HW: 5K0 953 569 BF
       Component: LENKS.MODUL   018 0230
       Revision: FF010042    Serial number: 20150720200140
       Coding: 0012440008
       ROD: EV_SMLSNGVOLWSR8C.rod
    365080 - Controls in Steering Wheel
                        Reset counter: 224
                        Mileage: 23332 km
                        Date: 2019.11.11
                        Time: 09:08:28
       Part No SW: 5C6 920 985 C    HW: 5C6 920 985 C
       Component: KOMBI         H04 1009
       Coding: 271E010000
       VCID: 3228014365C827DF61-8066
       Part No SW: 7N0 907 530 BC    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1663
       Revision:   H56       Serial number: 28071503000548
       Coding: 351032
       VCID: 72A8C143AD4867DFA1-8026
       Component: IMMO          H04 1009
       Coding: 000007
       VCID: 6A98D9238D98AF1F19-803E
       Revision: 00000000    Serial number: 15000175260005
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 302C0B4B6BC415CF17-8064
       Component: HRE_Master    H11 0071
       Serial number: 0372940763
       Coding: 02011102
       Shop #: WSC 00066 790 00295
       ROD: EV_HREntryHella_VW32.rod
       VCID: 3C342F7BB78CE1AFBB-8068
       Lane Change Assistant 2:
       Component: HRE_Slave  H11 0071
       Serial number: 0373662439
       Coding: 020111
       Revision: 13110009    Serial number: 0009945611
       Coding: 0404BD
       Shop #: WSC 00066 790 00192
       VCID: 5BF68CE752C2C69792-800E
       Slave Driver:
       Subsystem 1 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
       Serial number: 14102587150806035755
       Coding: 800000
              B11EC 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 7
                        Mileage: 23303 km
                        Date: 2019.08.14
                        Time: 05:28:26
    131584 - Motor for Rear Window Regulator
              B11EE 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 8
                        Mileage: 23303 km
                        Date: 2019.08.14
                        Time: 05:28:26
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 306    3501
       Revision: 00H22000
       VCID: 393A366F70BED487A0-806C
                        Fault Status: 00101101
                        Reset counter: 9
                        Mileage: 23332 km
                        Date: 2019.11.11
                        Time: 08:48:05
                        Voltage: 11.63 V
                            DD
                        Temperature: 2.0C
       Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
       Component: KonzernAmp10K H08 6831
       Revision: --------    Serial number: EAA098C0065849
       VCID: 281CE32B53145D0FCF-807C
    9462035 - Front Left Treble Speaker
              B1061 13 [008] - Open Circuit
              [Hochton Lautsprecher vorne links: Unterbrechung]
                        Reset counter: 5
                        Mileage: 23303 km
                        Date: 2019.07.19
                        Time: 00:02:56
    9462803 - Front Right Treble Speaker
              B1064 13 [008] - Open Circuit
              [Hochton Lautsprecher vorne rechts: Unterbrechung]
                        Reset counter: 5
                        Mileage: 23303 km
                        Date: 2019.07.19
                        Time: 00:02:56
              U1400 00 [008] - -
                        Reset counter: 4
                        Mileage: 23302 km
                        Date: 2019.07.19
                        Time: 09:13:56
       Component: EZE_2         H56 1663
       Coding: 01030100
       VCID: 6FAEC837BE7A4A374E-803A
       Subsystem 1 - Part No SW: 5K0 959 591 A    HW: 6R0 959 591 D
       Component: J245 PS41.402  H03 0004
       Serial number: 0000FST000CGRYH00000
       Coding: 180000
       Revision: 15110009    Serial number: 0009931221
       Coding: 0404BC
       VCID: 5CF48FFB57CCC1AF9B-8008
       Slave Passenger:
       Subsystem 1 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
       Serial number: 14202586150821045214
       Coding: 800000
                        Reset counter: 7
                        Mileage: 23303 km
                        Date: 2019.08.14
                        Time: 05:28:26
                        Reset counter: 8
                        Mileage: 23303 km
                        Date: 2019.08.14
                        Time: 05:28:26
       Component: AFS-ECU       H05 0111
       Coding: 081200010B000200
       Shop #: WSC 01383 790 50316
       ROD: EV_HeadlRegulVWAFSPt_VW32.rod
    13679104 - Local Data Bus
              U10BA 00 [137] - No Communication
                        Fault Frequency: 9
                        Reset counter: 224
                        Mileage: 23303 km
                        Date: 2019.08.14
                        Time: 05:28:26
    13705985 - Databus
              [Fehlerwert im Signal BR3_Rad_kmh_HL]
                        Reset counter: 7
                        Mileage: 23303 km
                        Date: 2019.08.26
                        Time: 02:27:03
    13705987 - Databus
              [Fehlerwert im Signal BR3_Rad_kmh_HR]
                        Reset counter: 7
                        Mileage: 23303 km
                        Date: 2019.08.26
                        Time: 02:27:03
       Part No SW: 5C0 035 684     HW: 5C0 035 684
       Component: MU-S-NS-US    H21 0241
       Serial number: VWZAZ2R0356515
       Coding: 02630102AA00000051220003001808001F0100D400200105C6
       ROD: EV_MUStd4CTSAT_VW36.rod
       VCID: 6288B10375A8F75FD1-8036
       Subsystem 1 - Part No SW: 3G0 919 866 B    HW: -----------
       Component: NAR 2015/16  --- 0220
              U11B8 00 [009] - No Communications
              [USB - communication error]
                        Reset counter: 222
                        Mileage: 23303 km
                        Date: 2019.08.14
                        Time: 05:28:26
                        Voltage terminal 30: 12.1 V
                        Interface for external media: status-Status: Open circuit
       Part No SW: 561 035 285 A    HW: 561 035 285 A
       Component: OCULowUSA     020 0156
       Serial number: 000003554140541
       Coding: 02630102C24232107F1606000000
       ASAM Dataset: EV_OCULow 002009
       ROD: EV_OCULow_002.rod
       VCID: 1464A7DBFF9CC9EF13-8040
    End----(Elapsed Time: 01:28, VBatt start/end: 11.6V/11.6V. VIgn 11.7V)-----
  3. #13
    VCDS Distributor AIB Wolfgang's Avatar
    Sep 2014
    Hello
    In addition of Dana's coding suggestion A14B600C49260000851406EA922000412118F02A (thank you Dana)
    I would give A14B600C49260000851406EA922000412118A02A a try . Correction of sensor type rear axle
    -Wolfgang
    Drive more talk less
  4. #14
    Aug 2019
    AIB Wolfgang thank you for the attempt but the coding was rejected.
