Results 1 to 10 of 14
Thread: 2015 Jetta GLI ABS Lost Coding/has no coding
    Aug 2019
    First time posting. Blough Automotive is a VW specifice used car dealership and repair facility. We buy auction cars and rebuild them for re sale along with general service of VW jettas, tiguans, ect. Below is an auto scan of a repairable vehicle that has lost its abs coding. Please ignore other codes as the vehicle is in the middle of rebuild. We would like to solve the coding issue with the abs module prior to investing in further repair. Any help would be greatly appreciated. I have seen on other threads where people have been able to come up with long coding numbers to try. If possible I would like to know where and how they are able to come up with the code so I may write my own in the future.
    Tuesday,13,August,2019,08:56:37:20258
    VCDS Version: 19.6.1.0
    VIN: 3VW4T7AJ6GM246967   License Plate:
    Mileage: 23300km-14477mi   Repair Order: 318
    Chassis Type: AJ-VW36 (7N0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 25 2B 3C 42 44 46 47 4F 52
              55 5F 62 72 75
    VIN: 3VW4T7AJ6GM246967   Mileage: 23300km-14477miles
    Address 01: Engine (J623-CPPA)       Labels:. 06K-907-425-V2.clb
       Part No SW: 06K 906 071 AT    HW: 06K 907 425 C
       Component: R4 2.0l TFS   H13 2346
       Revision: --H13---
       Coding: 001D0012242400171000
       Shop #: WSC 00066 000 00018
       ASAM Dataset: EV_ECM20TFS02006K906071AT 001003
       ROD: EV_ECM20TFS02006K906071AT.rod
       VCID: 7DFA0D63ECBE4CA7F2-8028
    6 Faults Found:
    16837 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
              P2185 00 [175] - Signal too High
                        Mileage: 23303 km
                        Date: 2019.07.18
                        Time: 02:35:00
                        Coolant temperature: 46 C
                        Intake air temperature: 22 C
                        Voltage terminal 30: 11.738 V
                        Engine: operating status: ES
                        STATE_LS_SAE[1]: INI
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 97 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                        FAC_TPS_1_SAE: 17.968750 %
                        FUP_H_SAE: 15390.0 kPa
    17791 - Coolant Pump Control Circuit
              P2600 00 [047] - Open
                        Mileage: 23303 km
                        Date: 2019.07.18
                        Time: 02:35:02
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 97 kPa
                        FUP_H_SAE: 15400.0 kPa
    15252 - Relay for Secondary Air Injection Pump (J299)
              P0418 00 [237] - Malfunction
                        Mileage: 23303 km
                        Date: 2019.07.18
                        Time: 00:34:16
                        Engine speed: 1725.50 /min
                        Normed load value: 14.5 %
                        Coolant temperature: 16 C
                        Intake air temperature: 18 C
                        Voltage terminal 30: 11.406 V
                        Engine: operating status: IS
                        STATE_LS_SAE[1]: OL_CDN
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 39 kPa
                        FAC_TPS_1_SAE: 14.843750 %
                        FUP_H_SAE: 7820.0 kPa
    18876 - Cruise Control Switch (E45)
              P0568 00 [047] - Implausible Signal
                        Fault Frequency: 25
                        Mileage: 23303 km
                        Date: 2019.07.18
                        Time: 02:35:00
                        ACC variants (coding): CCS
                        CCS Switch: CCS operating unit
                        Cruise control switch actuation-Main switch hardware: not activated
                        Cruise control switch actuation-Main switch CAN: not activated
                        Cruise control switch actuation-Control component verified: No
                        ACC variants: ACC
    26384 - Databus
              U1123 00 [109] - Received Error Message
                        Mileage: 23303 km
                        Date: 2019.07.18
                        Time: 01:40:36
                        Engine speed: 1147.75 /min
                        Normed load value: 25.9 %
                        Vehicle speed: 15 km/h
                        Coolant temperature: 76 C
                        Voltage terminal 30: 13.691 V
                        Engine: operating status: PL
                        STATE_LS_SAE[1]: CL
                        T_AST_SAE: 4001 s
                        MAP_MES_SAE: 60 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.904 V
                        FAC_TPS_1_SAE: 14.062500 %
                        FUP_H_SAE: 17020.0 kPa
    19854 - Steering Column Control Module
              U0212 00 [047] - No Communications
                        Mileage: 23303 km
                        Date: 2019.07.18
                        Time: 02:35:00
                        ECU_STATE: ENG_STOP
                        Engine oil temperature: 28.0 C
                        Time since engine start: 0.0 s
                        T_ES: 17 min
                        STATE_ERR_ABC_PRED: 5
    Readiness: 1010 0101
       Part No SW: 02E 300 063 P    HW: 02E 927 770 AL
       Component: GSG DSG AG6     531 4907
       Revision: 06253104    Serial number: 00001507051438
       VCID: 234E1B1BE29ADA57A4-8076
    18275 - Powertrain Data Bus
                P1867 - 000 - Missing Message from Steering Wheel (J527)
                        Fault Frequency: 10
                        Reset counter: 40
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:05:24
    28907 - No Communications with Cruise Control (Front) Distance Sensor
                U0235 - 000 -  - Intermittent
                        Reset counter: 40
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 05:50:14
       Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
       Component: ESP MK60EC1   H46 0175
       Revision: 00H46001
       Coding: 0000000000000000000000000000000000000000
       VCID: 75EA1543DC8E14E7BA-8020
    10 Faults Found:
    03842 - RPM Sensor Rear Right: Incorrect Signal
                        Reset counter: 7
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:06:32
                        Count: 7
                        Count: 12
                        Count: 20480
                        Count: 87
                        Count: 42752
                        Count: 256
    03841 - RPM Sensor Rear Left: Incorrect Signal
                        Reset counter: 7
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:06:32
                        Count: 7
                        Count: 12
                        Count: 20480
                        Count: 71
                        Count: 42752
                        Count: 256
    00283 - ABS Wheel Speed Sensor; Front Left  (G47)
                        Reset counter: 222
                        Mileage: 917761 km
                        Date: 2055.08.00
                        Time: 16:05:15
                        Count: 256
                        Count: 54494
                        Count: 256
                        Count: 38
                        Count: 212
                        Count: 256
                        Count: 12766
                        Count: 256
                        Reset counter: 222
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 02:15:33
                        Count: 16386
                        Count: 12800
                        Count: 54
                        Count: 49926
                        Count: 59904
                        Count: 768
                        Count: 3072
                        Reset counter: 222
                        Mileage: 526602 km
                        Date: 2001.00.00
                        Time: 16:08:13
                        Count: 1283
                        Count: 307
                        Count: 56832
                        Count: 128
                        Count: 257
                        Count: 9985
                        Count: 270
                        Count: 56833
                        Fault Status: 01100101
                        Reset counter: 222
                        Count: 16386
                        Count: 12
                        Count: 212
                        Count: 45056
                        Count: 256
                        Reset counter: 222
                        Count: 16386
                        Count: 12
                        Count: 279
                        Count: 45056
                        Count: 256
                        Reset counter: 222
                        Count: 16386
                        Count: 12
                        Count: 295
                        Count: 45056
                        Count: 256
                        Reset counter: 222
                        Count: 16386
                        Count: 12
                        Count: 270
                        Count: 45056
                        Count: 256
                        Reset counter: 222
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:06:21
                        Count: 2
                        Count: 12
                        Count: 20480
                        Count: 297
                        Count: 44032
                        Count: 256
       Revision: 00092000    Serial number: 0374283187
       Coding: 030C0C
       Shop #: WSC 00066 000 00295
       VCID: 3776DF4B8E02A6F768-8062
    65813 - Supply voltage
                        Reset counter: 7
                        Time: 00:00:00
       Part No SW: 1K8 907 044 AR    HW: 1K8 907 044 AR
       Component: Climatronic   H05 0304
       Revision: 00001K02
       Coding: 0050019002
       Shop #: WSC 00066 000 00319
       VCID: 7F06F76BE6B25EB7E0-802A
              B10AB F0 [009] - Too Low
                        Reset counter: 221
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:03:35
       Part No SW: 5K0 937 087 AJ    HW: 5K0 937 087 AJ
       Component: BCM PQ35 H+   122 0183
       Revision: BL122001
       Coding: EF200A1A902F06D40188008124000D4C0174000845A08DB2E4842000A040
       VCID: 7DFA0D63E4BE4CA7F2-8028
       Component: RLS 250615 05  54  0403
       Coding: 02300A
    7 Faults Found:
                        Reset counter: 7
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:07:01
                        Voltage: 11.45 V
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 222
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:00:01
                        Voltage: 11.95 V
                        Reset counter: 222
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:00:01
                        Voltage: 11.95 V
                        Reset counter: 222
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:00:01
                        Voltage: 11.95 V
                        Reset counter: 222
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:00:01
                        Voltage: 11.95 V
    02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                        Reset counter: 221
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:03:39
                        Voltage: 11.85 V
    02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                        Reset counter: 221
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:03:39
                        Voltage: 11.85 V
       Part No SW: 1K8 919 472 B    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0479
       Revision: --------    Serial number: 39311520205556
       Coding: 0071155011
       ASAM Dataset: EV_EPHVA18VW364GP00 001006
       VCID: 3668D24F89085FFF73-8062
    1113107 - Front Parking Aid Sensor(s)
              B10FC 13 [008] - Open Circuit
                        Reset counter: 222
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:16:48
              U1400 00 [008] - -
                        Reset counter: 7
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:27:33
    Address 15: Airbags (J234)       Labels:* 561-959-655.clb
       Part No SW: 561 959 655     HW: 561 959 655
       Component: AirbagVW11    001 0207
       Serial number: 003RXM00YFRW
       Coding: 8CCCF000000000005000001AC20800000065
       Shop #: WSC 00066 790 00012
       ASAM Dataset: EV_AirbaVW11SMEVW411 001002
       ROD: EV_AirbaVW11SMEVW411_VW32.rod
       VCID: 63CE5B1B6A1A9A57E4-8036
       Component: BF-Gewichtss.  H11 0021
       Serial number: IBH000000000003DDMDO
       Coding: 30314C
       Subsystem 2 - Part No SW: -----------    HW: 480 001 806 15
       Serial number: 35700000000D1145F41G
       Subsystem 3 - Part No SW: -----------    HW: 480 001 806 15
       Serial number: 3580000000022145F417
       Subsystem 4 - Part No SW: -----------    HW: 480 022 107 15
       Component: SideSensor_Dr  000 0148
       Serial number: 3510001C31B2C526751Y
       Subsystem 5 - Part No SW: -----------    HW: 480 022 107 15
       Component: SideSensor_Pr  000 0148
       Serial number: 3520001C31B2C52103FZ
       Subsystem 6 - Part No SW: -----------    HW: -----------
       Component: FrontSensor_D  --- ----
       Serial number: -------------------$
       Subsystem 7 - Part No SW: -----------    HW: -----------
       Component: FrontSensor_P  --- ----
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:03:38
    9443861 - Driver's Front Airbag Crash Sensor
              B101A 15 [137] - Open or Short to Plus
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:03:40
    9444117 - Front Passenger's Front Airbag Crash Sensor
              B101B 15 [137] - Open or Short to Plus
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:03:40
    9483264 - Seat Occupied Recognition
              B10B4 00 [008] - Function Restriction due to Undervoltage
                        Reset counter: 7
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:28:14
       Part No SW: 1K5 953 521 CR    HW: 5K0 953 569 BF
       Component: LENKS.MODUL   018 0230
       Revision: FF010042    Serial number: 20150720200140
       Coding: 0012440008
       ROD: EV_SMLSNGVOLWSR8C.rod
    114178 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Reset counter: 7
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:27:33
    365080 - Controls in Steering Wheel
                        Reset counter: 222
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:06:13
       Part No SW: 5C6 920 985 C    HW: 5C6 920 985 C
       Component: KOMBI         H04 1009
       Coding: 271E010000
       VCID: 3260EE5F656043DF5F-8066
       Part No SW: 7N0 907 530 BC    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1663
       Revision:   H56       Serial number: 28071503000548
       Coding: 351032
       VCID: 72E02E5FADE003DF9F-8026
       Component: IMMO          H04 1009
       Coding: 000007
       VCID: 6AD0363F8D30CB1F27-803E
       Revision: 00000000    Serial number: 15000175260005
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 3064E4576B6C71CF29-8064
              U1400 00 [008] - -
                        Reset counter: 7
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:27:37
                        ELV State: 0C
                        Information Clamps: 77 60
                        CoCo State: B0 01
                        WFS State: 67 1A
                        Vehicle speed: 0.00 km/h
                        Voltage: 4A
    1049345 - Comfort System CAN Bus (SAE Medium Speed Bus)
              U0011 00 [008] - Performance
                        Reset counter: 7
                        Time: 00:00:00
                        ELV State: 0A
                        Information Clamps: 00 00
                        CoCo State: F0 01
                        WFS State: 00 1A
                        Vehicle speed: 655.35 km/h
                        Voltage: 2F
       Component: HRE_Master    H11 0071
       Serial number: 0372940763
       Coding: 02011102
       Shop #: WSC 00066 790 00295
       ROD: EV_HREntryHella_VW32.rod
       VCID: 3C7CC067B72485AF85-8068
       Lane Change Assistant 2:
       Component: HRE_Slave  H11 0071
       Serial number: 0373662439
       Coding: 020111
              U1400 00 [008] - -
                        Reset counter: 6
       Revision: 13110009    Serial number: 0009945611
       Coding: 0404BD
       Shop #: WSC 00066 790 00192
       VCID: 5BBE63FB526AA297AC-800E
       Slave Driver:
       Subsystem 1 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
       Serial number: 14102587150806035755
       Coding: 800000
              B11EC 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 222
    131584 - Motor for Rear Window Regulator
              B11EE 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 222
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 306    3501
       Revision: 00H22000
       VCID: 3972D9737016B0879E-806C
                        Fault Status: 00101101
                        Reset counter: 3
                        Mileage: 23303 km
                        Date: 2019.07.18
                        Time: 02:37:16
                        Voltage: 11.75 V
                            DD
                        Temperature: 18.0C
                000 - - - MIL ON
                        Fault Status: 11100000
                        Battery Volts: 12.3 V
                            PD
                        Temperature: 20.0C
                        Count: 2
                        Steering Angle: 0.00
                            SteerAng n.Init
       Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
       Component: KonzernAmp10K H08 6831
       Revision: --------    Serial number: EAA098C0065849
       VCID: 28540C3753BC390FF1-807C
    9462035 - Front Left Treble Speaker
              B1061 13 [008] - Open Circuit
                        Reset counter: 5
                        Mileage: 23303 km
                        Date: 2019.07.18
                        Time: 00:02:56
    9462803 - Front Right Treble Speaker
              B1064 13 [008] - Open Circuit
                        Reset counter: 5
                        Mileage: 23303 km
                        Date: 2019.07.18
                        Time: 00:02:56
              U1400 00 [008] - -
                        Reset counter: 4
                        Mileage: 23302 km
                        Date: 2019.07.18
                        Time: 09:13:56
       Component: EZE_2         H56 1663
       Coding: 01030100
       VCID: 6FE6272BBED22E3770-803A
       Subsystem 1 - Part No SW: 5K0 959 591 A    HW: 6R0 959 591 D
       Component: J245 PS41.402  H03 0004
       Serial number: 0000FST000CGRYH00000
       Coding: 180000
       Revision: 15110009    Serial number: 0009931221
       Coding: 0404BC
       VCID: 5CBC60E75764A5AFA5-8008
       Slave Passenger:
       Subsystem 1 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
       Serial number: 14202586150821045214
       Coding: 800000
                        Reset counter: 222
                        Reset counter: 222
       Component: AFS-ECU       H05 0111
       Coding: 081200010B000200
       Shop #: WSC 01383 790 50316
       ROD: EV_HeadlRegulVWAFSPt_VW32.rod
    13679104 - Local Data Bus
              U10BA 00 [137] - No Communication
                        Reset counter: 222
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:03:36
       Part No SW: 5C0 035 684     HW: 5C0 035 684
       Component: MU-S-NS-US    H21 0241
       Serial number: VWZAZ2R0356515
       Coding: 02630102AA00000051220003001808001F0100D400200105C6
       ROD: EV_MUStd4CTSAT_VW36.rod
       VCID: 62C05E1F7500935FEF-8036
       Subsystem 1 - Part No SW: 3G0 919 866 B    HW: -----------
       Component: NAR 2015/16  --- 0220
    1539 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Reset counter: 7
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:27:43
                        Voltage terminal 30: 8.3 V
              U11B8 00 [009] - No Communications
                        Reset counter: 221
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:03:36
                        Voltage terminal 30: 11.9 V
                        Interface for external media: status-Status: Open circuit
       Part No SW: 561 035 285 A    HW: 561 035 285 A
       Component: OCULowUSA     020 0156
       Serial number: 000003554140541
       Coding: 02630102C24232107F1606000000
       ASAM Dataset: EV_OCULow 002009
       ROD: EV_OCULow_002.rod
       VCID: 142C48C7FF34ADEF2D-8040
              U1400 00 [008] - -
                        Reset counter: 7
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:27:15
    End-------------------------(Elapsed Time: 04:28)--------------------------
    SVM at the dealer............
    Appears to be the correct part number no?
    Looks like you have faults to address no?
    Aug 2019
    The car has had a dead battery and is in the middle of rebuild. The issue I need assistance with is the long coding in the abs module. In the auto scan you can see there is only zeros in the long coding of the abs module. I am not concerned with the other fault codes currently but would like to address the code.
    Coding attempts shouldn't or can't commence until fault codes are corrected & as per SVM and RTFB, what you want and what you get are two very different things.
    You should never dismiss fault codes!
    I am not a player for this type of work, however, anyone else please have at it........
    Aug 2019
    I understand where you are coming from. I will address the codes and put an updated auto scan.
    I'm sure the dealer can help you with an SVM session & after the faults are corrected, no?
    Isn't this car to be checked for campaign recalls & you could also ask them to do it free under useful life standards?
    JPPSG
  7. #7
    Aug 2019
    Here is the updated auto scan.
              55 5F 62 72 75
       Revision: --H13---
    6 Faults Found:
                        Mileage: 23303 km
                        Date: 2019.07.18
                        Time: 02:35:00
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 97 kPa
                        Mileage: 23303 km
                        Date: 2019.07.18
                        Time: 02:35:02
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 97 kPa
                        Mileage: 23303 km
                        Date: 2019.07.18
                        Time: 00:34:16
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 39 kPa
                        Fault Frequency: 25
                        Mileage: 23303 km
                        Date: 2019.07.18
                        Time: 02:35:00
                        ACC variants: ACC
    26384 - Databus
                        Mileage: 23303 km
                        Date: 2019.07.18
                        Time: 01:40:36
                        STATE_LS_SAE[1]: CL
                        T_AST_SAE: 4001 s
                        MAP_MES_SAE: 60 kPa
                        Mileage: 23303 km
                        Date: 2019.07.18
                        Time: 02:35:00
                        ECU_STATE: ENG_STOP
                        T_ES: 17 min
                        Fault Frequency: 10
                        Reset counter: 40
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:05:24
                        Reset counter: 40
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 05:50:14
       Revision: 00H46001
    10 Faults Found:
                        Reset counter: 7
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:06:32
                        Count: 7
                        Count: 12
                        Count: 20480
                        Count: 87
                        Count: 42752
                        Count: 256
                        Reset counter: 7
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:06:32
                        Count: 7
                        Count: 12
                        Count: 20480
                        Count: 71
                        Count: 42752
                        Count: 256
                        Reset counter: 222
                        Mileage: 917761 km
                        Date: 2055.08.00
                        Time: 16:05:15
                        Count: 256
                        Count: 54494
                        Count: 256
                        Count: 38
                        Count: 212
                        Count: 256
                        Count: 12766
                        Count: 256
                        Reset counter: 222
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 02:15:33
                        Count: 16386
                        Count: 12800
                        Count: 54
                        Count: 49926
                        Count: 59904
                        Count: 768
                        Count: 3072
                        Reset counter: 222
                        Mileage: 526602 km
                        Date: 2001.00.00
                        Time: 16:08:13
                        Count: 1283
                        Count: 307
                        Count: 56832
                        Count: 128
                        Count: 257
                        Count: 9985
                        Count: 270
                        Count: 56833
                        Reset counter: 222
                        Count: 16386
                        Count: 12
                        Count: 212
                        Count: 45056
                        Count: 256
                        Reset counter: 222
                        Count: 16386
                        Count: 12
                        Count: 279
                        Count: 45056
                        Count: 256
                        Reset counter: 222
                        Count: 16386
                        Count: 12
                        Count: 295
                        Count: 45056
                        Count: 256
                        Reset counter: 222
                        Count: 16386
                        Count: 12
                        Count: 270
                        Count: 45056
                        Count: 256
                        Reset counter: 222
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:06:21
                        Count: 2
                        Count: 12
                        Count: 20480
                        Count: 297
                        Count: 44032
                        Count: 256
       Coding: 030C0C
                        Reset counter: 7
                        Time: 00:00:00
       Revision: 00001K02
       Coding: 0050019002
                        Reset counter: 221
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:03:35
       Revision: BL122001
       Coding: 02300A
    7 Faults Found:
                        Reset counter: 7
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:07:01
                        Voltage: 11.45 V
                        Reset counter: 222
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:00:01
                        Voltage: 11.95 V
                        Reset counter: 222
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:00:01
                        Voltage: 11.95 V
                        Reset counter: 222
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:00:01
                        Voltage: 11.95 V
                        Reset counter: 222
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:00:01
                        Voltage: 11.95 V
                        Reset counter: 221
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:03:39
                        Voltage: 11.85 V
                        Reset counter: 221
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:03:39
                        Voltage: 11.85 V
       Coding: 0071155011
                        Reset counter: 222
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:16:48
              U1400 00 [008] - -
                        Reset counter: 7
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:27:33
       Coding: 30314C
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:03:38
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:03:40
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:03:40
                        Reset counter: 7
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:28:14
       Coding: 0012440008
              U1400 00 [008] - -
                        Reset counter: 7
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:27:33
                        Reset counter: 222
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:06:13
       Coding: 271E010000
       Coding: 351032
       Coding: 000007
              U1400 00 [008] - -
                        Reset counter: 7
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:27:37
                        ELV State: 0C
                        CoCo State: B0 01
                        WFS State: 67 1A
                        Voltage: 4A
                        Reset counter: 7
                        Time: 00:00:00
                        ELV State: 0A
                        CoCo State: F0 01
                        WFS State: 00 1A
                        Voltage: 2F
       Coding: 02011102
       Coding: 020111
              U1400 00 [008] - -
                        Reset counter: 6
       Coding: 0404BD
       Slave Driver:
       Coding: 800000
                        Reset counter: 222
                        Reset counter: 222
       Revision: 00H22000
                        Reset counter: 3
                        Mileage: 23303 km
                        Date: 2019.07.18
                        Time: 02:37:16
                        Voltage: 11.75 V
                            DD
                        Temperature: 18.0C
                000 - - - MIL ON
                            PD
                        Temperature: 20.0C
                        Count: 2
                            SteerAng n.Init
                        Reset counter: 5
                        Mileage: 23303 km
                        Date: 2019.07.18
                        Time: 00:02:56
                        Reset counter: 5
                        Mileage: 23303 km
                        Date: 2019.07.18
                        Time: 00:02:56
              U1400 00 [008] - -
                        Reset counter: 4
                        Mileage: 23302 km
                        Date: 2019.07.18
                        Time: 09:13:56
       Coding: 01030100
       Coding: 180000
       Coding: 0404BC
       Slave Passenger:
       Coding: 800000
                        Reset counter: 222
                        Reset counter: 222
                        Reset counter: 222
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:03:36
              U1400 00 [008] - -
                        Reset counter: 7
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:27:43
                        Reset counter: 221
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:03:36
              U1400 00 [008] - -
                        Reset counter: 7
                        Mileage: 23303 km
                        Date: 2019.08.13
                        Time: 00:27:15
  8. #8
    Aug 2019
    Did you receive my private message Jack?
  9. #9
    As of the latest scan posted, this car is still chock-full of other, active fault codes.
  10. Likes Jack@European_Parts, PetrolDave, Dana liked this post
  11. #10
    United States
    Resolving the cause of those electrical DTCs would be best so you don't end up with lost 03-ABS coding again.
    I believe this GLI was born with 1K0 907 379 CB which supers to 1K0 907 375 CC. The installed ABS module should be correct.
    I had a hard time locating a 02E DSG (Auto) configuration with CPPA engine, because most are manual transmissions, but this should be the correct 03-ABS coding for 3VW4T7AJ6GM246967:
    A14B600C49260000851406EA922000412118F02A
    There are a few types of rear wheel speed sensors and some discrepancies related to TPMS in the coding based on my experience. Providing that coding is accepted you want to run the first 4 Basic Setting operations on this page before exiting the module:
    http://wiki.ross-tech.com/wiki/index..._%28MK60EC1%29
    At that point:
    • Verify Basic Settings 042 is available which will confirm indirect TPMS is active.
    • If there are any rear wheel speed sensor DTCs please post another scan so we can see if my coding needs tweaked.
    Vehicle Identification No. 3VW4T7AJ6GM246967
    Model Jetta 2,0
    JEM
    Date of production 28.09.2015
    Model year 2016
    Sales type 1639N6
    Engine Code CPPA
    Transmission Code QZD
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PF Standard wheel bolts
    Vehicle class differentiation units/platform components 7KK Vehicle class differentiation -160-
    drive-off assistance UG4 Hill hold assist + comfort driving assist
    Emission standard 0GT Emission standard SULEV
    Trailer hitch 1D0 without trailer towing
    airbag 4UM Driver's and front passenger air bag, NAR with front passenger air bag deactivation (2-stage) - SMART airbag with automatic deactivation
    Aktivkohlebehlter / Ottopartikelfilter 1E7 Activated carbon canister (ORVR), for intensified evaporation system, siphoning device for fueling
    Storage compartment 7N2 Sunglass holder
    Aerials 8L6 "diversity" window antenna
    Exterior mirror setting 6XN Exterior mirrors, power-adjustable/ separately heated
    Follow-on warranty EA0 Without subsequent warranty
    Left exterior mirror 5SH Left exterior mirror, flat (US)
    Right exterior mirror 5RR Right exterior mirror, convex (US)
    Alternative drive system 0K0 Without alternative drive system
    Drive type 1X0 Front-wheel drive
    "Multimedia"video/DVD/notebook connection 9WT Mirror Link
    Equipment levels A8H Top sports equipment
    Area monitoring systems 6K0 Without forward collision warning/ autonomous emergency braking
    Brake type in rear 1KW Disc brakes in rear
    batteries J1L Battery 280 A (60 Ah)
    Brake type, front 1LV Silver caliper
    Components with special surface 6FF Exterior mirror housing and various attachments colour coded to vehicle
    Battery/alternator capacity NY0 Standard battery/alternator capacity
    Component part sets with country-specific design requirements B0D Assembly kit, USA corresponding vehicle version (not California), various parts
    trim KN0 Without trim element -- without piping
    floor covering 3MH Dilours floor covering without scuff guard
    vehicle tools and jack 1S1 vehicle tools and jack
    Brake systems 1AT Electronic stability control (ESC)
    Owner's manuals 0VM Information kit in American English
    Operating voltage 9Z0 Operating voltage 12 V
    brake wear indicator 9U0 Without brake pad wear indicator
    Heated washer nozzles 9T1 Heated washer nozzles in front
    CD ROM/DVD/SD card 77E SD card (NAR)
    CD changer/CD player 7A0 Without CD changer/CD player
    Chrome package QJ3 Chrome package (version 2)
    General operating permit, alterations C18 Operating permit, alteration
    Roof insert/convertible top 3FE Tilting and sliding glass sunroof with sunbshade
    Suspension system in rear 1JE Rear sports shock absorption
    Suspension system in front G24 Shock absorption in front
    Insert for the filling up of unleaded fuel/fuel type 2G7 Filler neck module 1 with insert
    Installation differentiation for components 0ES Installation differentiation for transmission DQ250 -- vehicle components --
    Theft protection system 7AZ Preparation for anti-theft alarm system
    Inserts 7TK Decorative inserts
    Scuff plates 7M6 Protective film for scuff plate
    Park distance control 7X2 Park distance control in front and rear
    Electric interface for external use UI4 Electric interface for external use, AUX-IN, USB (iPod-capable)
    Manufacturing sequence differentiation 0FL Mexico manufacturing sequence
    window regulator 4R4 Power windows with comfort operation and circuit breaker
    fire extinguisher 6A0 without fire extinguisher
    Pedestrian protection VL0 Standard pedestrian protection measures
    Pedal cluster VF1 pedal cluster
    Headlight activation 8K9 Daytime headlights with automatic headlight control and coming home function
    Fresh air intake for passenger compartment (with particulate filter) 2V6 Fresh air intake with dust filter
    Antifreeze 1C2 Antifreeze up to -35 degree celsius tolerance up to -40 degree C
    Vehicle tracing system 7G0 Without preparation for VTS (Vehicle Tracing System)
    Interior noise suppression measures 3W0 Without additional noise suppression measures for passenger compartment
    Alternators 8GU Alternator 140 A
    Weight category rear axle 0YD Weight range 4 installation control only, no requirement forecast
    Weight category front axle L58 Suspension range 58 installation control only, no requirement forecast
    Base engine TL5 4-cyl. petrol engine 2.0 l assembly 06K.F
    Luggage netting/pocket on backrest(s) 4U7 Luggage pocket on backrest of right seat
    Tie down straps/net/pocket 6M0 Without tie down straps/net/pocket
    cruise control system 8T2 Electronic cruise control system (CCS)
    Garage door opener VC2 Garage door opener
    Luggage compartment trim 5A2 Comfort luggage compartment trim
    Transmission specifications G1A 6-speed automatic transmission
    glove box 4Z3 Lockable glove compartment door, with light
    Brackets 3P0 Without bracket for first aid kit and warning triangle
    handle for hand brake lever 6PC handbrake lever grip (leather)
    Rear spoiler 5J1 Rear spoiler
    Rear axle 0N4 4-link rear suspension
    Rear seats 3KB Unsplit rear seat bench, split folding backrest, with center armrest
    Heating and air-conditioning system 9AK Climatronic with impact pressure control, CFC-free
    Headlamps 8IM Gas discharge headlights with dynamic bending light
    Customized installation FC1 Customized installation
    Instrument clusters U5C Instrument cluster, mph speedometer - USA -
    Instrument panel 4N3 Comfort dashboard
    Breakaway interior rearview mirror 4L6 Breakaway interior rearview mirror, auto-dimming
    Sticker (customized or special edition) 0KA Without decals and emblems
    Body style K8B Notchback
    coolbox 1W2 Glove compartment cooling system
    Climatic zones 0Y2 Tropical zones
    Compass/road sign display QR0 Without compass/road sign display/ dynamic road sign display
    headrest for seat, rear 3Q6 Three rear head restraints
    Head restraints 3J1 Hight-adjustable head restraints for front seats
    Fuel tank treatment 2LF Fuel tank with special material treatment (coextrusion) with changed protective layer
    Fuel quantity for initial filling 1Z0 Initial standard fuel filling
    Tire categorization A60 Category 0
    Fuel systems 1A5 Fuel system for SI engine
    Body measures 5C1 Body measures for increased safety requirements
    Child seat anchors in front 3G0 Without child seat anchora in front (ISOFIX)
    Camera systems/accident sensors KA1 With rear view camera system (type 1)
    Radiator grille 6KD Radiator grille
    License plate lighting KL1 LED license plate lighting
    Rear license plate bracket 6P2 License plate bracket, rear (NAR)
    Front license plate bracket 6W3 License plate bracket front (small, NAR)
    Paint preservative/transit coating 5K7 Transport protection film (minimum protection) with additional transport protection measures
    Light package (lighting) QQ1 With additional lights (interior lighting)
    Steering system arrangement L0L Left-hand drive
    Reading lamp 8S1 Reading light in front
    steering 1N3 Speed-related variable steering assist (Servotronic)
    Light control systems 8G0 Without Light Assist
    Lumbar support 7P5 Manually adjustable lumbar support for left front seat
    steering wheels 2FW Leather-wrapped multi-function sports steering wheel with tiptronic
    Driving on the left/on the right AV2 Driving on the right (NAR)
    Speaker installation 8RU Sound system with subwoofer "branded"
    Headlight range control 8Q5 Dynamic headlight range control, with cornering light (AFS 1)
    Center armrest 6E4 Center armrest in front
    Versions FM3 Variant
    Multi-function display/trip computer 9Q4 Multi-function display/trip computer with check control
    Driver alert system EM0 Without driver alert system
    Engine cooling 8Z6 Hot country
    Engine specifications D2D 4-cylinder SI engine 2.0 l/155 kW 16V turbo FSI, homogeneous; base engine is TM2/TV2/TG6/TJ6/TD6/TP6/TL5/TL6/TI6
    Market-specific vehicle version AW1 Version (high)
    Navigation device 7UQ Navigation system MIB2 Standard PQ (NAR)
    rear fog lamp 8TA witout rear fog lamp
    Front fog lamp/additional headlamp 8WH Front fog lamp and cornering lamp
    Online services EL2 Online service, with OCU, without head unit coding, without engine immobilizer interconnection
    Upgrading measures GP1 Vehicles with special upgrade measures
    Rear of platform module base 4P1 Rear floor panel module, type 2
    Platform group class 7PA Platform group class 1
    Panic switch KP4 With additional switch
    Hubcaps 1NL Trims for alloy wheels
    Wheels C6I Alloy wheels 7.5J x 18
    Radios 8AY Radio navigation system
    Smoker's/non-smoker's package 9JF Non-smoking package (NAR)
    Tire pressure monitoring system 7K6 Tire pressure monitoring system
    tire HX9 All-season tires 225/40 R18 92H xl (NAR)
    Tire suppliers V0A Tires without specification of tire brand
    Spare wheel/breakdown kit 1G6 Space-saving spare wheel
    Restraint systems, front 4QQ 3-point seat belts in front with pretensioner and height adjustment, US label
    PMC California emission
    POJ GLI 3 package USA
    WUE GLI 2 package USA
    Side airbag 4X3 Side airbag in front, with curtain airbag
    Gearshift knob/handle 6Q2 Gearshift knob/handle in leather
    Special labels/plates 0SC Labels in English
    Tail lamp assemblies 8SS LED taillamp assembly (NAR)
    Locking mechanism for boot lid/cover rear 4E2 Tailgate/trunk lid release from inside (electrically)
    Service indicator QI7 Service indicator 10 000 miles or 1 year (fix)
    Front seat, left 3TG Sports comfort seat in front, left
    Front seat, right 3SG Sports comfort seat, front, right
    Nameplates for sales name QD0 Without lettering for sales name
    Seat belt check 9P7 Visual and acoustic seat belt reminder, electric contact in buckle
    Outer rear seat belts 3ZD 3-point seat belts, outer rear with US label
    Center rear seat belts 3C8 3-point seat belt, center rear with US label
    seat covers N2Q Seat trim covers in leatherette
    Seat adjustment 3PZ Power seat on the left, right seat with manual height adjustment with modified manual control
    seat heater 4A3 seat heating for front seats separat controlable
    Side lights 7R7 Side marker lights plus exterior mirror turn signals
    Start-stop system/regenerative braking 7L3 Without start/stop system without regenerative braking
    Horns 8Y1 Two-tone horn
    sun visors 5XX Sun visors with mirror, illuminated (NAR)
    Audio-response system/voice control QH1 voice control
    Lane change assist/lane keeping system 7Y8 Blind spot monitor
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    power outlet 7B5 12-volt outlet(s)
    Bumper 2JG bumper in color of vehicle
    Rear stabilizer 0BH Rear stabilizer
    Front stabilizer bar 0AH Front stabilizer bar
    Drawers under front seats QN0 Without drawers under front seats
    Heavy-duty/sports version 2UC Sports version
    Headlamp washer system 8X0 Without headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N3 intermittent windscreen wiper with rain sensor
    Nameplate set 0NQ Nameplate set "GLI"
    Door storage compartments in front 3YQ Door pockets without insert mats
    Mass damper for steering wheels 1Q1 Mass damper for steering wheel, 26.5Hz
    Door and lid locking system 4F6 Central locking system "Keyless Entry" without deadlock (NAR)
    Type approval countries/countries with special requirements BU2 Legal requirements for USA 2 States with CARB requirement
    Carrier frequency for remote control 5D2 Carrier frequency 315 MHz
    Door and side trim panels 3LJ Door and side trim panel in foam film, insert in leatherette
    doors 0A2 4 doors
    TV reception/digital radio reception QU4 Satellite radio reception NAR integrated in device
    Identification plates 1EB without identification plate
    First aid kit / warning triangle 1T0 Without first-aid material, without warning triangle
    Telephone / telematics 9ZX Telephone preparation for cellphone
    LongLife Service Regime QG1 LongLife Service Regime
    Heat accumulator system/auxiliary heater 7E0 W/o heat accumulator/auxiliary heating
    Windshield Glass 4GQ Windshield in heat-insulating glass
    Washer fluid level indicator 8W1 Washer fluid level indicator
    Additional tires (snow tires) 2WA without spare tyre
    floor mats 0TD Front and rear floor mats
    Decorative trims 4ZG Chrome-plated decorative trims
    Additional child seat anchors 3B7 Child seat anchors as per Canadian requirements a. ISOFIX child seat system
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
