Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Help please BCM upgrade, indicators and windows not working.
    Oct 2018
    Quote Originally Posted by vastechnics View Post
    Hello Timmy. I see you upgrade to max BCM. You need to run wires to make everything work ok. You need to make new wires for Instrument and also Supply for bcm.
    For instrument to need 2 new canbus wires. If im right from instrument 28 (canhigh) and 29 (canlow) > connector b 54 (canhigh) and 57 (canlow)
    For supply need run 2 wires from a63 and b68 to steady plus. Try do this an report.
    Thanks vastechnics, can you confirm the canbus pinouts as I saw one document reference pins 27 & 28, if I'm adding canbus wires would I need to code anything extra for them? also looking at some other documentation, a63 and b68 are showing as being inputs for the headlights?!?!
  2. #12
    May 2016
    No need coding for canbus wires. Yes I know, but they are needed for proper work, also for interior lights
  3. #13
    Oct 2018
  4. #14
    Oct 2018
    Quote Originally Posted by Timmy View Post
    Ignore that last post, a bit more digging and you are correct with 28 & 29.
    Looking into the a63 and b68 inputs, it looks like I need to replace those supplies with two 30A supplies from fuse box B positions 12 & 14, would that be correct?
  5. #15
    May 2016
    That is correct 1x with both wires together must be ok with 30a
  6. #16
    Oct 2018
    Hello again all, thanks to your input and tips from other posts I've finally managed to get the BCM and all of the wiring in and got the cruise and mfsw installed, however I now have new errors that I'm struggling with related to lighting and door, the lights are all working and I have turned off lamp monitoring but still get these errors in 09 electrics, does anyone have any other ideas as I didn't have these on my old BCM?
    Wednesday,02,October,2019,09:36:40:49885
    VCDS Version: 19.6.1.0  HEX-V2 CB: 0.4508.4
    VIN: WV1ZZZ7HZDH124033   License Plate: T11VMY 021019 0936
    Mileage: 181950km-113058mi   Repair Order:
    Chassis Type: 7H-VN75 (6N0)
    Scan: 01 03 04 08 09 15 17 19 25 56 0B
    VIN: WV1ZZZ7HZDH124033   Mileage: 181950km-113058miles
    56-Radio -- Status: Not registered 0011
    Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
       Part No SW: 03L 906 019 GH    HW: 03L 907 309 M
       Component: R4 2,0L EDC   H45 5576
       Revision: 26H45---    Serial number: 00000000000000
       Coding: 01194012232400080000
       Shop #: WSC 02736 790 50316
       ASAM Dataset: EV_ECM20TDI01103L906019GH 003003
       ROD: EV_ECM20TDI01103L906019FM_003.rod
       VCID: 77ABE8B21F41696FFB3-8022
    Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
       Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
       Component: ESP MK25A XT  H43 0110
       Revision: 00H43001
       Coding: 508724AD89A60A9924A29174A96110
       Shop #: WSC 02736 790 49152
       VCID: 3A2D31866C53B407C4D-806E
       Part No SW: 7E5 907 047 BN    HW: 7E5 907 047 BN
       Component: Climatic-T5   H20 0505
       Revision: 00001010
       Coding: 0000000002
       ROD: EV_ClimaT5Basis.rod
       VCID: 7CA1F79E26674A37961-8028
    Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
       Part No SW: 7H0 937 090 D    HW: 7H0 937 090
       Component: BCM PQ25 Max4 H74 0726
       Revision: B9074001    Serial number: 0661 234140059
       Coding: E0A0393A0A212011002808102C2B8C510090430F60060000320000000000
       Shop #: WSC 05205 002 104857
       VCID: 2F3B10D2A71161AF633-807A
       Subsystem 1 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
       Component: J386__TSG_FT  002 3313
       Subsystem 2 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
       Component: J387__TSG_BT  002 3313
       Subsystem 3 - Part No SW: 5G0 959 442 L    HW: 5G0 959 442 L
       Component: E221__MFL-DC1  H11 0103
       Serial number: 29160001628220016484
       Coding: A5FFFF
    03303 - Response Closing Status of Rear Left Door
                        Reset counter: 43
                        Mileage: 181952 km
                        Date: 2014.02.21
                        Time: 22:14:59
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 3
                        Mileage: 181952 km
                        Date: 2014.02.22
                        Time: 09:20:09
                        Reset counter: 3
                        Mileage: 181952 km
                        Date: 2014.02.22
                        Time: 09:20:09
                        Reset counter: 3
                        Mileage: 181952 km
                        Date: 2014.02.21
                        Time: 22:11:06
       Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
       Component: VW10Airbag009 H07 0013
       Revision: --------    Serial number: 003HL00H9LRT
       Coding: 000000000000000000000000000000003039
       Shop #: WSC 02734 790 50316
       VCID: 353722BA45CD5B7F29F-8060
       Part No SW: 7E0 920 960 G    HW: 7E0 920 960 G
       Component: KOMBI         H06 0605
       Coding: 460201
       VCID: 2D070ADAAD9D13BF51F-8078
       Part No SW: 6N0 909 901     HW: 7H0 937 090
       Component: GW-K-CAN TP20 H74 0726
       Revision: B9074001
       Coding: 742300
       VCID: 70B9D3AE7AAF3E573A9-8024
                        Mileage: 181952 km
                        Date: 2014.02.21
                        Time: 22:11:06
       Component: IMMO          H06 0605
       VCID: 6A8DC1C65CF3C48774D-803E
    Address 56: Radio
    End----------(Elapsed Time: 01:42, VBatt start/end: 14.5V/14.5V)-----------
