Results 1 to 10 of 11
Thread: B7 S4 Automatic transmission won't reset learned values + ESP G419 Issue
    Aug 2019
    Los Angeles, USA
    Hello All!
    New to Ross-Tech, VCDS, and the forum - looks like a cool place!
    So, I've just spent the last two years rebuilding a B7 S4, I rebuilt the engine, and the mechatronics unit with new solenoids, separator plate, stem seals, etc. Before installing the engine, I also replaced brittle connectors on just about every plug in the engine bay with new ones.
    I've started the car and driven around the neighborhood - the engine runs great but it shocks into gear on every shift (even 6th!). I expected like this if it had learned poorly flowing old solenoids during it's past life, but my problem is I cannot get the transmission to reset learned values. The Basic Settings button under automatic transmission is grayed out on VCDS and I cannot select it. I tried Adaptives Reset with moving forward and backward 20meters, but that doesn't seem to have helped at all. If someone could help guide me on how to activate the transmission learned values reset, I'd appreciate it.
    Second issue - ESP G419 No Communication. I thought maybe the unit died while the car sat as a shell for a few years, or maybe a voltage spike, etc. etc. I replaced the unit and the ESP light and ABS light are still on. All the fuses on driver side dash are OK, battery voltage is OK, in VCDS I can see plausible wheel speeds from all four corners, steering sensor plausible values too. Not sure where to look next. Some suggestions would be appreciated!
    Sunday,11,August,2019,15:39:27:57034
    VIN: WAUGL68E35A497598   License Plate:
    Mileage: 237320km-147463mi   Repair Order:
              67 69 75 76 77
    VIN: WAUGL68E35A497598   Mileage: 237320km-147463miles
    Address 01: Engine        Labels: 079-910-560-BBK.lbl
       Part No SW: 8E0 910 560 M    HW: 4E0 907 560
       Component: 4.2L V8/5V      G   0010
       Revision: --------    Serial number:
       Coding: 0007771
       Shop #: WSC 06335 000 00000
       VCID: 2F3B138C0B10A0DF633-807A
    18043 - Powertrain Data Bus
                P1635 - 008 - Missing Message from A/C Controller - Intermittent
                P1602 - 002 - Voltage too Low
    Readiness: 0110 1101
       Part No SW: 8E0 910 156 M    HW: 09L 927 156
       Component: AG6 09L  4.2L5V USA 0040
       Revision: --H01---    Serial number:        0087005
       VCID: 303910F0162EBF277A9-8064
       Part No SW: 8E0 910 517 C    HW: 8E0 614 517 BB
       Component: ESP8 quattro    H04 0180
       Coding: 0004902
       VCID: 270BFBAC23E0F89FAB3-8072
                        Fault Frequency: 6
                        Reset counter: 40
                        Hex Value: 0x00C0
                        Hex Value: 0x4302
                        Hex Value: 0x00FF
                        Hex Value: 0xFFA7
                        Hex Value: 0x00FF
                        Fault Frequency: 9
                        Reset counter: 40
                        Hex Value: 0x0000
                        Hex Value: 0x4222
                        Hex Value: 0x00FF
                        Hex Value: 0xFF98
                        Hex Value: 0x00FF
                        Reset counter: 40
                        Hex Value: 0x0000
                        Hex Value: 0x4222
                        Hex Value: 0x00FF
                        Hex Value: 0xFF91
                        Hex Value: 0x00FF
       Part No: 8E0 820 043 AM
       Component:   A4 Klimaautomat   2731
       Coding: 00000
       VCID: 6C81C480FF961BC7061-5160
                27-00 - Implausible Signal
       Part No: 8E0 907 279 J
       Component: int. Lastmodul  USA 0503
       Coding: 01023
       Shop #: WSC 65536
       VCID: 392F2DD4C0447E6FCD7-4B00
    01326 - Control Module for Multi-Function Steering Wheel (J453)
       Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
       Component:    Airbag 9.41  H10 3230
       Revision: 91H10323    Serial number: 0036N0009PM2
       Coding: 0032607
       VCID: 3C2134C0CA664B47D61-8068
       Subsystem 1 - Part No: 8E0 910 339 B
       Component: BF-Gewichtsens. 02  0070
       Serial number: 6332DRB4016E4928R
       Coding: 00032607
       Subsystem 2 - Serial number: 6342DRB4016C92A5T
       Subsystem 3 - Serial number: 6352ARB4004C81D2M
       Subsystem 4 - Serial number: 6362ARB4004D1297J
       Subsystem 5 - Serial number: 63729RB4004C9C51Q
       Subsystem 6 - Serial number: 63829RB400E31923G
       Part No: 8E0 953 549 Q
       Component: Lenksáulenmodul     0601
       Coding: 02141
       Shop #: WSC 06335
       VCID: 41DF4534A89426AF857-4B00
    01304 - Radio
                49-00 - No Communications
       Part No SW: 8E0 920 981 Q    HW: 8E0 920 981 Q
       Component: KOMBI+WFS 4     H12 0040
       Revision: 0040        Serial number: 00000000000000
       Coding: 0023261
       Shop #: WSC 22122 444 92497
       VCID: 3B2337DCCF784C7FDFB-5184
    01304 - Radio
       Coding: 0023261
    01304 - Radio
    Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
       Part No: 8E0 959 760
       Component: Sitzmemory R2 F     0305
       Coding: 00002
       VCID: 71BFD5F4D884F62F357-4B3C
       Part No: 8E0 959 433 BT
       Component: Komfortgerát T7B    3132
       Coding: 11836
       Shop #: WSC 06335
       VCID: 04518C20F706F387EE1-4B00
       Subsystem 1 - Part No: 8E1959801F
       Component: Tőrsteuer.FS BRM 0305
       Subsystem 2 - Part No: 8E1959802E
       Component: Tőrsteuer.BF BRM 0205
       Subsystem 3 - Part No: 8E0959801A
       Component: Tőrsteuer.HL BRM 0205
       Subsystem 4 - Part No: 8E0959802A
       Component: Tőrsteuer.HR BRM 0205
    00962 - Alarm via. Tilt Sensor
                35-00 - -
    00955 - Key 1
                35-10 - - - Intermittent
                80-10 - Single-Wire Operation - Intermittent
       Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
       Coding: 0000019
       VCID: 2615F6A824EAE197905-8072
       Subsystem 1 - Part No: 8E0 941 329
       Component: AFS-Modul links H02 0020
       Subsystem 2 - Part No: 8E0 941 329
       Component: AFS-Modul rechtsH02 0020
    00496 - Sensor for Vehicle Leveling; Front
                        Fault Frequency: 19
                        Reset counter: 35
    End----------(Elapsed Time: 05:02, VBatt start/end: 14.0V/13.9V)-----------
    How many of those fault codes are current? There look to be some that MAY be historical - try clearing all fault codes and see which remain would be my suggestion for the first step.
  3. Likes Uwe, Jack@European_Parts liked this post
    I don't see any explicit "learned values" reset in this TCM.
    Slamming into every gear sounds like a pressure control problem, but I'm by far not an expert on automatic transmissions.
  5. Likes Jack@European_Parts liked this post
    Sounds like a BAD MAF!
    Aug 2019
    Los Angeles, USA
    Thanks for the info guys! Do you think the MAF would cause these hard shifts?
    Does anyone know why my Auto Trans> Basic Settings button has been grayed out and not selectable? Is there any advise on how to enable it?
    Quote Originally Posted by LeeO View Post
    When it is grayed, it means there is no Basic Settings in that Control Module.
    Why do you think there should be Basic Settings to do some reset ?
    There is erase of clutch in Adaptation Channel 01
    Save value: 0
    Translated by Google:
    Clutch Adjustments:
    • Measurement block MWB 004.1 must be above 55.0 ° C
    • Check MWB 002 003 009
    • Choose a suitable flat road with good paving
    • Adaptation Channel 01
    PART 1 Accelerates the car from standstill at very low torque 80-120 Nm (MBW 002.4) in drive D to 4th gear Then let the car roll down at speed to 40 km / h without operating the brake and then braking to a standstill. Wait for 5 sec. and then repeat the process 3 times. See MBW 074.2 and 075.4 and 077.2 must be> 1 PART 2 Drive purposefully 3 ... 4 km with a torque of approx. 60-120 Nm in Tiptronic in 5th gear (Mon.) at 1600 ... 2800 min-1 Then accelerate the car and continue in Tiptronic 6.gear (Mon.) with 1600 ... 2800 min-1 additional 3 ... 4 km When 1600 min-1 is reached, the next adjustment step is automatically continued. See MBW 075.2 and 075.4 must be> 1 PART 3 Drive the Tiptronic car in 5th gear (man) between 1400 ... 2100 min-1 for one minute and then let the rpm drop to 1400 min-1 The process is repeated 3 times. Drive the car up at 1900 min-1 See MBW 073.4 must be> 1 PART 4 Hold for one minute the car in Tiptronic in 3rd gear (man) with 60 Nm torque in the range 1400 ... 2100 min-1 and then slow down to a standstill. The process is repeated 3 times. See MBW 076.2 and 077.2 must be> 1
    Aug 2019
    Los Angeles, USA
    The B7 has the 6hp19 ZF transmission - I was pretty sure people had referenced using basic settings to reset adaptive values, etc. for the automatic transmission. Of course, maybe I had seen incorrectly about that.
  10. #8
    MAF can do this yes........... LOW ATF?
  11. #9
    Aug 2019
    Los Angeles, USA
    I'll look into the MAF, and try doing the relearn with Adaptation channel 01.
    AFT is the right level.
  12. #10
    Are the pressures correct for relief in the ATF regulation?
