Results 1 to 2 of 2
Thread: RS4 B7 Intermittent starter fault
    Oct 2014
    Kenya
    Hey guys,
    I have a 2007 B7 RS4 that has a random starter failure (start button doesn't do anything) So far is has a new starter, new starter relays, new (aftermarket) clutch switch and new starter inhibitor relays
    I haven't had much time to look at this vehicle so can't give much diagnostic information,
    was just doing some homework before i get into it and hoped if anyone had come across this particular fault before?
     Thursday,15,August,2019,12:23:54:54859VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
    VCDS Version: 19.6.1.0  HEX-V2 CB: 0.4508.4
    Dealer/Shop Name: Euro Tecnik Ltd
    VIN: WUAZZZ8E27N904644   License Plate: KBY 011J
    Mileage: 244200km-151738mi   Repair Order: Mohammed RS4
              67 69 75 76 77
    VIN: WUAZZZ8E27N904644   Mileage: 244200km-151738miles
    Address 01: Engine        Labels:. 079-910-560-BNS1.lbl
       Part No SW: 8E1 910 560     HW: 8E1 907 560
       Component: 4.2L V8/4V FSI     ª0080
       Revision: --H13---    Serial number: XXXXXXXXXXXXXX
       Coding: 010C0003180F0160
       Shop #: WSC 01286 386 08256
       VCID: 639259B89758DCAFB7B-8036
    005924 - Starter Interlock Signal
                   P1724 - 001 - Short to Ground
                        Fault Status: 01100001
                        Mileage: 244208 km
                        RPM: 775 /min
                        Load: 20.0 %
                        Temperature: 85.0°C
                        Temperature: 37.0°C
                        Absolute Pres.: 830.0 mbar
                        Voltage: 13.589 V
    Readiness: 0110 1101
       Part No SW: 8E0 910 517 G    HW: 8E0 614 517 BD
       Component: ESP8 quattro    H06 0150
       Coding: 0004533
       Shop #: WSC 06335 000 00000
       VCID: 2B02F198BF0854EF4FB-807E
       Part No: 8E0 820 043 BM
       Component:   A4 Klimaautomat   2833
       Coding: 00000
       VCID: 6D863F80448C9ADF11F-50F4
       Part No: 8E0 907 279 N
       Component: int. Lastmodul  ECE 0907
       Coding: 11021
       Shop #: WSC 00672
       VCID: 3D26CFC0546CCA5FE1F-4AA4
    01794 - Control Module - Incorrect Chassis (VIN) Number
                35-00 - -
    Address 11: Engine II        Labels:. 079-910-560-BNS2.lbl
       Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
       Component:    Airbag 9.41  H12 3730
       Revision: 91H12373    Serial number: 0036M0G4HY5L
       Coding: 0431612
       VCID: 3B22C1D84F68C46FDFB-806E
       Subsystem 1 - Serial number: 6332DRB404334992H
       Subsystem 2 - Serial number: 6342DRB40425D417K
       Subsystem 3 - Serial number: 6352ARB401D23355E
       Subsystem 4 - Serial number: 6362ARB401D24C43M
       Subsystem 5 - Serial number: 63729RB401D504FDY
       Subsystem 6 - Serial number: 63829RB401D504A7O
    Address 16: Steering wheel        Labels: 8E0-953-549-T.lbl
       Part No: 8E0 953 549 T
       Component: Lenksáulenmodul     0301
       Coding: 04442
       Shop #: WSC 06335
       VCID: 44D0BA243786BB97AE1-4AA4
    01304 - Radio
       Part No SW: 8E0 920 983 C    HW: 8E0 920 983 C
       Component: KOMBI+WFS 4     H14 0100
       Revision: 0100        Serial number: 00000000000000
       Coding: 0023418
       Shop #: WSC 00999 444 64523
       VCID: 2F3AE5888B0028CF633-5118
    01316 - ABS Control Module
       Coding: 0023418
       Part No: 8E0 951 177
       Component: Innenraumueberw.   0804
       Coding: 00001
       VCID: 6B8231987A9894EF0FB-50AE
       Part No: 8E0 959 433 CH
       Component: Komfortgerát T3B    4135
       Coding: 07151
       Shop #: WSC 06335
       VCID: 79AE1BD000C4367F8D7-4AA4
       Subsystem 1 - Part No: 8E2959802F
       Component: Tõrsteuer.FS BRM 0606
       Subsystem 2 - Part No: 8E2959801F
       Component: Tõrsteuer.BF BRM 0606
    01370 - Alarm triggered by Interior Monitoring
                35-00 - -
    00962 - Alarm via. Tilt Sensor
                35-00 - -
       Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
       Coding: 0000019
       VCID: 290E0B90B5F446FFBD7-807C
       Component: AFS-Modul links H03 0020
       Component: AFS-Modul rechtsH03 0020
    Address 65: Tire Pressure        Labels: 8E0-907-273.lbl
       Part No SW: 8E0 907 273 A    HW: 8E0 907 273 A
       Component: Reifendruck 3   H04 0130
       Coding: 0022523
       Shop #: WSC 79667 074 574529
       VCID: 2A0CF49CB0D24DE7B4D-5160
                        Fault Status: 11100100
                        Reset counter: 40
                        (no units): 0.0
                        Voltage: 12.30 V
                        (no units): 61.0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                        Raw, Index/Key Err.: 205 000 000
    01833 - Antenna for Tire Pressure Monitoring; Rear (R96)
                        Reset counter: 40
                        (no units): 0.0
                        Voltage: 12.30 V
                        (no units): 130.0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                        Error Code: 0
    Address 76: Park Assist        Labels: 8E0-919-283-8EC.lbl
       Part No SW: 8E0 919 283 E    HW: 8E0 919 283 E
       Component: Parkhilfe 8-Kan H06 0010
       Revision: 00H06000    Serial number: 00067802130629
       Coding: 0000114
       VCID: 323CECFC980205270CD-5184
    01629 - Sensor for Parking-Aid; Front Left (G255)
                        Reset counter: 67
       Part No SW: 8P0 862 335 H    HW: 8P0 862 335 H
       Component: FSE_255x BT     H26 0290
       Revision: 00000000    Serial number: 00000005044252
       Coding: 0011822
       VCID: 3B22C1D84F78C46FDFB-50D0
    End----(Elapsed Time: 04:50, VBatt start/end: 13.8V/13.8V. VIgn 0.0V)------
    Clearly FOD that is for sure.........
    Did you load test all wires to relay from ECU?
