Results 1 to 2 of 2
Thread: Trouble with steering rack communication on VW
    Feb 2019
    I have a 2016 VW Jetta S 1.4l that I am having trouble with.
    I have the red steering wheel light on as well as a flashing ABS light.
    I have no communication with the steering control module (J500) or the steering angle sensor (G85). I have checked the wiring to the rack and showed 12v at the connection at the rack from the fuse box. I made the assumption that the rack was bad because it was getting power, but not communicating. I replaced the rack with a used rack (40k mi) from a salvage car and cleared all the DTC codes. I was planning on doing the basic setting, but there is still no communication with either the rack or the steering angle sensor.
    Any help is greatly appreciated.
    Tuesday,13,August,2019,18:05:07:28248
    VIN: 3VW267AJ0GM362664   License Plate:
    Mileage: 121410km-75440mi   Repair Order:
    Chassis Type: AJ-VW36 (7E0)
    Scan: 01 02 03 04 08 09 15 17 19 25 44 5F
    VIN: 3VW267AJ0GM362664   Mileage: 121410km-75440miles
    04-Steering Angle -- Status: Cannot be reached 1100
    44-Steering Assist -- Status: Cannot be reached 1100
    Address 01: Engine (J623-CZTA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 023 AQ    HW: 04E 907 309 AP
       Component: R4 1.4l TFS   H22 2954
       Revision: X5H22---
       Coding: 011A0012232400000000
       Shop #: WSC 00066 790 00014
       ASAM Dataset: EV_ECM14TFS01104E906023AQ 003003
       ROD: EV_ECM14TFS01104E906023AQ.rod
       VCID: 6FBBD1E9571BE9FF233-803A
       CAN Converter 01:
    7249 - No Communications with Steering Angle Sender (G85)
              U0126 00 [039] - -
                        Mileage: 121415 km
                        Date: 2019.08.13
                        Time: 00:45:09
                        Coolant temperature: 21 °C
                        Intake air temperature: 23 °C
                        Ambient air pressure: 810 mbar
                        Voltage terminal 30: 12.062 V
    Readiness: 1110 0101
       Part No SW: 09G 927 749 AA    HW: 09G 927 749 AA
       Component: AISIN AG6 G3  129 2944
       Coding: 010200000C000000000000000000000000000000
       ASAM Dataset: EV_TCMAQ250031 002009
       ROD: EV_TCMAQ250031_002_VW26.rod
       VCID: 78A9EAB52255AE47F29-802C
    Address 03: ABS Brakes        Labels:
       VCID: 55F78301DD07B32FC9F-8000
                        Reset counter: 233
                        Mileage: 121415 km
                        Date: 2019.08.13
                        Time: 00:45:05
                        Count: 2
                        Count: 12
                        Count: 28672
                        Count: 166
                        Count: 43008
                        Count: 254
                        Reset counter: 233
                        Mileage: 121415 km
                        Date: 2019.08.13
                        Time: 00:45:05
                        Reset counter: 233
                        Mileage: 121415 km
                        Date: 2019.08.13
                        Time: 00:45:05
                        Reset counter: 233
                        Mileage: 121415 km
                        Date: 2019.08.13
                        Time: 00:45:05
       Part No SW: 5C0 820 047 CR    HW: 5C0 820 047 CR
       Component: J301  Klimaanlage   0211
       Revision: 2001401S    Serial number: 00000003182394
       VCID: 72BDD89D48A9C417CCD-8026
    Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
       Part No SW: 7E0 937 189     HW: 7E0 937 189
       Component: BCM PQ25 MMI3 H80 0736
       Revision: BA080001    Serial number: 18007084160051
       Coding: 7B994B1808AB0B0000392080240884D50FC6702E60004070B00010032844
       Shop #: WSC 00066 123 12345
       VCID: 71BFD79141AFFF0F357-8024
       Subsystem 1 - Part No SW: 6R0 959 801 DF    HW: 6R0 959 801 DF  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  022 1467
       Serial number: 14102743160308133235
       Coding: 820000
       Subsystem 2 - Part No SW: 6R0 959 802 DJ    HW: 6R0 959 802 DJ  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  022 1467
       Serial number: 14202742160301130939
       Coding: 820000
       Subsystem 3 - Part No SW: 6C0 959 442 G    HW: 6C0 959 442 G
       Serial number: 3521520083901759BE2B
       Coding: 280000
       Subsystem 4 - Part No SW: 6R0 959 811 T    HW: 6R0 959 811 T
       Component: J388__TSG_HL  022 1467
       Serial number: 14102745160308211857
       Subsystem 5 - Part No SW: 6R0 959 812 T    HW: 6R0 959 812 T
       Component: J389__TSG_HR  022 1467
       Serial number: 14102744160302173648
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 233
                        Mileage: 121415 km
                        Date: 2019.08.13
                        Time: 00:45:05
    Address 15: Airbags (J234)       Labels:* 561-959-655.clb
       Part No SW: 561 959 655     HW: 561 959 655
       Component: AirbagVW11    001 0207
       Serial number: 003RXM04L4D+
       Coding: 8CCCF000000000005000001AC20800000065
       ASAM Dataset: EV_AirbaVW11SMEVW411 001002
       ROD: EV_AirbaVW11SMEVW411_VW32.rod
       VCID: 6393ADD98BD35D9FB7B-8036
       Component: BF-Gewichtss.  H12 0021
       Serial number: IBH000000000004Q7EDO
       Coding: 303141
       Subsystem 2 - Part No SW: -----------    HW: 480 000 902 16
       Serial number: 3570000000082C18391G
       Subsystem 3 - Part No SW: -----------    HW: 480 000 902 16
       Serial number: 3580000000092C18391I
       Subsystem 4 - Part No SW: -----------    HW: 480 022 501 16
       Component: SideSensor_Dr  000 0148
       Serial number: 3510001A71EED22380FD
       Subsystem 5 - Part No SW: -----------    HW: 480 022 501 16
       Component: SideSensor_Pr  000 0148
       Serial number: 3520001A71EED222A437
       Subsystem 6 - Part No SW: -----------    HW: 480 021 802 16
       Component: FrontSensor_D  000 0189
       Serial number: 3550001B51E954B5C51B
       Subsystem 7 - Part No SW: -----------    HW: 480 021 802 16
       Component: FrontSensor_P  000 0189
       Serial number: 3560001B51E954B62300
       Part No SW: 5C6 920 955 A    HW: 5C6 920 955 A
       Component: KOMBI         H04 1007
       Coding: 270A010000
       Shop #: WSC 00066 790 00319
       VCID: 2D070BE19D97DBEF51F-8078
    13638912 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Steuergerät für Lenkhilfe: keine Kommunikation]
                        Reset counter: 233
                        Mileage: 121415 km
                        Date: 2019.08.13
                        Time: 00:45:06
    Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
       Part No SW: 7E0 909 901     HW: 7E0 937 189
       Component: GW-K-CAN TP20 H80 0736
       Revision: BA080001
       Coding: 102201
       VCID: 6889BAF572753EC7629-803C
                        Reset counter: 233
                        Mileage: 121415 km
                        Date: 2019.08.13
                        Time: 00:45:06
                        Reset counter: 233
                        Mileage: 121415 km
                        Date: 2019.08.13
                        Time: 00:45:06
       Component: IMMO          H04 1007
       VCID: 6A8DC0FD6CF90CD774D-803E
    Address 44: Steering Assist
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
       Part No SW: 561 035 150     HW: 561 035 150
       Component: MU-E--US      857 6495
       Serial number: 28011600012068
       Coding: 02630100AA00000041220001001000001F0000C40000010000
       ASAM Dataset: EV_MUEnt4CGen2LGE 001025
       ROD: EV_MUEnt4CGen2LGE_VW12.rod
       VCID: 4ACD607D0C39ECD754D-801E
    End----------(Elapsed Time: 01:11, VBatt start/end: 14.2V/14.3V)-----------
    Vehicle Identification No. 3VW267AJ0GM362664
    Model Jetta 1.4
    JEM
    Date of production 08.04.2016
    Model year 2016
    Sales type 163VF6
    Engine Code CZTA
    Transmission Code QCE
    Emission standard 7GB Emission standard ULEV 2
    Did you JPPSG yet?
    When you checked for power explain how you tested for it?
    Also how did you test for ground?
    Did you test the twisted pair for the CAN BUS High/Low?
    https://forums.ross-tech.com/showthr...rstanding-of-!
    If you would be so kind and post the OBD2 data for this car and fault memories I'd really appreciate it OP
    Do you get an MIL check engine light because of this?
    123 load lights?
  3. Likes Uwe liked this post
