About 6 months ago my radio gradually stopped working.
I eventually found out that the washer fluid hose between trunk and roof liner had broken and washer fluid had poured down the trunk inside and on the right hand side of the car.
With time the fluid has caused the connector(s) to the BOSE amplifier in the back to corrode, short and break. I replaced the BOSE amp with an identical unit and the stereo now worked again.
Around the same time I also became aware my parking aid no longer worked: when engaging the reverse a sound/tone would go off from the front of the car (front buzzer) but then no further tones were given when parking between cars (so no front or rear audible signals).
I first attributed this to a clutch/flywheel install around the same time thinking they had forgotten to connect the reverse switch. However reverse lights work and I do get that one tone when engaging the reverse gear.
So I now think it's to do with that washer fluid leakage.
Here's what I have done to troubleshoot:
Is there anything I can do using VCDS to find the error? Otherwise I think I will have to remove the rear bumper and inspect...
Thanks for looking!
I would be surprised if it was the buzzer (01543) since its on the left hand side in the trunk and was not affected by washer fluid leaking.
Autoscan (does not show 01543):
- I've put my head against all front sensors (sound of them being active)
- I've put my head against all rear sensors (again, sound of them being active)
- I've scanned the car getting (once) a 01543 code, but I've not reproduced it on repeat scans.
Thanks for looking!
Tuesday,13,August,2019,10:53:36:15041
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WUAZZZ8E47A801426 License Plate:
67 69 75 76 77
VIN: WUAZZZ8E47A801426 Mileage: 123190km-76546miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 8E0 910 115 N HW: 8E0 907 115 D
Component: 2.0l R4/4V TFSI 0070
Revision: 5EH13--- Serial number:
Coding: 010C0003180F0120
Shop #: WSC 40970 222 87061
VCID: 2C0104EECA089B77461-8078
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 J HW: 8E0 614 517 BH
Component: ESP8 quattro H06 0140
Coding: 0004526
Shop #: WSC 06335 000 00000
VCID: 2E050EE6FC14E967685-807A
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 11141
Shop #: WSC 65536
VCID: 3D2739AA246202FFE1F-4AA4
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H12 3730
Revision: 91H12373 Serial number: 0036M0G2T14/
Coding: 0031612
VCID: 3B2337B23F660CCFDFB-806E
Subsystem 1 - Serial number: 6332DRB403ABC8AF9
Subsystem 2 - Serial number: 6342DRB40392CC24S
Subsystem 3 - Serial number: 6352ARB401773B15H
Subsystem 4 - Serial number: 6362ARB40179CF55.
Subsystem 5 - Serial number: 63729RB4017DDE12Y
Subsystem 6 - Serial number: 63829RB4017DDE6B6
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0701
Coding: 04042
VCID: 41DF455A589A661F857-4AA4
01304 - Radio
49-00 - No Communications
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 901 J HW: 8E0 920 901 J
Component: KOMBI+WFS 4 H14 0200
Revision: 0200 Serial number: 00000000000000
Coding: 0007111
Shop #: WSC 80093 222 69422
VCID: 2C0104EECA189B77461-50F4
01304 - Radio
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0007111
01304 - Radio
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
Shop #: WSC 40970
VCID: 6B83C7F20A965C4F0FB-508A
Address 46: Central Conv. Labels:. 8E0-959-433-MIN.clb
Part No: 8E0 959 433 CJ
Component: Komfortgerát TBF 4035
Coding: 07018
Shop #: WSC 06335
VCID: 7BA3F7B27AF6CCCF9FB-4AA4
Subsystem 1 - Part No: 8E1959801H
Component: Tõrsteuer.FS BRM 0606
Subsystem 2 - Part No: 8E1959802H
Component: Tõrsteuer.BF BRM 0606
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Coding: 0000005
VCID: 3D2739AA217202FFE1F-8068
Part No SW: 8P0 862 335 H HW: 8P0 862 335 H
Component: FSE_255x BT H25 0290
Revision: 00000000 Serial number: 00000005007651
Coding: 0001692
VCID: 3B2337B23F760CCFDFB-50D0
01304 - Radio
Reset counter: 176
Time Indication: 15
End----------(Elapsed Time: 05:09, VBatt start/end: 12.0V/12.1V)-----------
