Results 1 to 6 of 6
Thread: AC Woes Please Help
    New User
    Aug 2019
    Trinidad and Tobago
    AC Woes Please Help
    Hello my ac is not working and this code is active in the hvac and central control unit
    013 - Check DTC Memory
    I have searched all over mostly people who get this code will get it with the temp sensor and or the ac pressure switch sensor as stated in the TSB regrading this fault code but I only get this code nothing else.
    I drained the system and changed the control valve solenoid on the compressor inspected the oil in the compressor it was clean vacuumed the system and recharged the system to spec 550g using my scale everything was good until i shut off the vehicle and started back up now the compressor does not turn on.
    vehicle is a 2008 jetta with a 2.0fsi non turbo engine and a denso variable displacement compressor thanks.
    Please post an Auto-Scan for context.
    PS: This does not belong in Forum Support & Feedback. Moving to New User section.
    New User
    Aug 2019
    Trinidad and Tobago
    Was just about to delete and move it how do I send my cable serial number to get verified?
    Please see: How to Get Verified.
  5. Likes Dana liked this post
    New User
    Aug 2019
    Trinidad and Tobago
    It was a dead compressor the code had nothing to do with the activation/deactivation of the compressor also cleared the rest of codes the only code I have now is the brake booster code which is intermittent on a side note the customer said that the last tech added oil on the high side will this cause the compressor to fail as it has to push the oil (pag 46) through the condenser etc? thanks.
    Tuesday,13,August,2019,20:16:24:50820
    VCDS Version: 19.6.1.0 (x64)
    VIN: WVWZZZ1KZ8M154124   License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: WVWZZZ1KZ8M154124   Mileage: 144420km-89738miles
       Part No SW: 06F 906 056 JC    HW: 06F 906 056 FD
       Component: MED9.5.10       G00 0849
       Revision: 6AH03---    Serial number: VWX7Z0H224C0U5
       Coding: 0000075
       Shop #: WSC 00066 000 00000
       VCID: 73EFE4001273ACD794-8026
    005241 - Brake Boost Vacuum System
                   P1479 - 008 - Mechanical Failure
                        Fault Status: 01101000
                        Load: 0.0 %
                        Temperature: 75.0C
    Readiness: 0110 0100
       Part No: 09G 927 750 FB
       Component: AQ 250 6F           0844
       Coding: 0000072
       VCID: 76E9DD140101B9FFB3-8022
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
       Part No: 1K0 907 379 P
       Component: ASR FRONT MK70      0105
       Coding: 0017025
       VCID: 3F8778306EBB38B7A0-806A
       Part No SW: 1K0 820 047 HB    HW: 1K0 820 047 HB
       Component: Climatic PQ35   141 1010
       Revision: 00141028    Serial number: 00000000000000
       VCID: 6BDFFC604A4374175C-803E
       Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
       Revision: 00H54000    Serial number: 00000000901587
       Coding: 01050E2700041500470A00000F00000000085D035C000100000000000000
       VCID: 71E3EE08686F9EC766-8024
       Component: Wischer 070308 021  0501
       Coding: 00038805
       Shop #: WSC 00066
    10 Faults Found:
                        Fault Status: 00101100
                        Fault Frequency: 53
                        Reset counter: 26
                        Mileage: 133757 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 13.35 V
                        Fault Frequency: 11
                        Reset counter: 34
                        Mileage: 144069 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 13.65 V
    00532 - Supply Voltage B+
                        Reset counter: 23
                        Mileage: 144057 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 8.95 V
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 250
                        Mileage: 144067 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.00 V
                        Reset counter: 35
                        Mileage: 144426 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.40 V
                        Fault Frequency: 91
                        Reset counter: 23
                        Mileage: 136975 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 8.65 V
    00154 - Windshield Wiper Motor;  Passenger Side (V217)
                        Fault Frequency: 237
                        Reset counter: 23
                        Mileage: 136975 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 9.90 V
    02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
                        Reset counter: 23
                        Mileage: 136975 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 9.90 V
    00153 - Windshield Wiper Motor;  Driver Side (V216)
                        Reset counter: 23
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 11.80 V
    01598 - Drive Battery Voltage
                        Reset counter: 34
                        Mileage: 136507 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 13.35 V
       Component: 2M AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD1T4AT-
       Coding: 0012877
       VCID: 3D7B023864B72AA7B2-8068
       Subsystem 1 - Serial number: 6332MSME2D156B05E
       Subsystem 2 - Serial number: 6342MSME38257834C
       Subsystem 3 - Serial number: 6351HSME132816570
       Subsystem 4 - Serial number: 6361HSME132869401
                002 - Lower Limit Exceeded - Intermittent - MIL ON
                010 - Open or Short to Plus - Intermittent - MIL ON
    02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
       Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
       Component: J0527           051 0100
       Coding: 0012021
       VCID: 78F5D32C0B15CF8FA1-802C
    00576 - Terminal 15
    00885 - Ignition Switch (D) Terminal 50
       Part No SW: 1K0 920 964 A    HW: 1K0 920 964 A
       Component: KOMBIINSTRUMENT 3HL 1212
       Revision: V0002000    Serial number: VWX7Z0H224C0U5
       Coding: 0016403
       Shop #: WSC 07737 898 62730
       VCID: 2B5F3C608AC3B4171C-807E
                        Reset counter: 35
                        Mileage: 144426 km
                        Time: 13:42:17
       Part No SW: 1K0 907 530 L    HW: 1K0 907 951
       Component: J533  Gateway   H07 0052
       Revision:   H07 01    Serial number: 290108F2001876
       Coding: ED807F060002021003
       VCID: 30652B0CA3E5D7CF29-8064
                        Fault Status: 00110100
                        Reset counter: 34
                        Mileage: 144426 km
                        Time: 13:46:51
       Component: IMMO            3HL 1212
    01176 - Key
                        Mileage: 140655 km
                        Time: 00:15:31
       Component: J386  TUER-SG FT    1134
       Revision: 32008001    Serial number: 00000025988111
       Coding: 0000692
       VCID: 3B7F0C207AA324978C-806E
    01811 - Supply Voltage for Door Controller; Drivers Side (J386)
                        Reset counter: 23
                        Mileage: 144057 km
                        Fault Status: 00100101
                        Reset counter: 34
    01706 - Switch for Mirror-Adjust (E43)
                        Fault Frequency: 58
                        Reset counter: 30
                        Mileage: 144244 km
                        Reset counter: 35
                        Mileage: 144426 km
       Part No: 1K2 909 144 M
       Component: EPS_ZFLS Kl.069 H08 1901
       VCID: 36691D144181F9FF73-8062
       Coding: 99900A0001060C7F2D04850560085F0380FCA0
       VCID: 030FB4C042D39C5784-8056
                        Fault Status: 01101101
                        Reset counter: 250
                        Mileage: 144426 km
                        Time: 13:53:49
       Component: J387  TUER-SG BT    1134
       Revision: 32008001    Serial number: 00000019488122
       Coding: 0000692
       VCID: 3C7D0F3C7FAD23AF85-8068
    01812 - Supply Voltage for Door Controller; Pass. Side (J387)
                        Reset counter: 23
                        Mileage: 144057 km
                        Fault Frequency: 23
                        Reset counter: 34
                        Mileage: 133757 km
    00097 - Front Passengers Central Locking (Safe) Motor (V162)
                        Reset counter: 30
                        Fault Status: 00111000
                        Reset counter: 35
                        Mileage: 133773 km
                        Reset counter: 35
                        Mileage: 144426 km
       Part No SW: 1K0 035 180 M    HW: 1K0 035 180 M
       Component: Radio ZSW       019 0035
       Revision: 00019000    Serial number: VWZ5Z7H6175703
       Coding: 0040400
       VCID: 2A5139648539AD1FE7-807E
                        Fault Frequency: 181
                        Reset counter: 22
                        Mileage: 136975 km
                        Time: 22:33:01
                        Fault Status: 00111011
                        Reset counter: 24
                        Mileage: 144067 km
                        Time: 00:03:18
       Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
       Component: J388   TUER-SG HL   1120
       Revision: 11006001    Serial number: 00000002853556
       Coding: 0000144
       Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
       Component: J389   TUER-SG HR   1120
       Revision: 11006001    Serial number: 00000002821316
       Coding: 0000144
       VCID: 3E79053469B131BFAB-806A
    00935 - Electric Window Motor; Rear Right (V27)
                        Fault Status: 01100101
                        Reset counter: 250
    End-------------------------(Elapsed Time: 01:53)--------------------------
    New User
    Aug 2019
    Trinidad and Tobago
    Anyone know the dangers of adding oil to the high side on a system that uses a denso 7seu17c compressor?
