I get random (only) #1 cylinder misfire codes, always 2 of them. Engine starts and runs great, reading on fuel injected ridiculous and never changing for #1 injector. I have cleaned connections at injector before and ordered new harness this time. Is CPU failing? Mostly just irritating having to clear codes... Thanks. Sorry if I didn't get the scan inside code thingy properly.
Monday,12,August,2019,13:38:51:07126
VCDS Version: 19.6.0.2 HEX-V2 CB: 0.4505.4
VIN: 3VWRR69M74M078653 License Plate: LEM 8-12-19
Mileage: 401100km-249231mi Repair Order:
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
75 76
VIN: 3VWRR69M74M078653 Mileage: 401100km-249231miles
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 038 906 016 H HW: 028 101 114 6
Component: R4 1.9L EDC G000AG 5375
Revision: 12345678 Serial number: VWZ7Z0C8501312
Coding: 0150034
VCID: 196FCEEF45880FAF2DF-5184
16685 - Cylinder 1
P0301 - 000 - Misfire Detected
RPM: 903 /min
Torque: 64.0 Nm
Voltage: 13.98 V
Bin. Bits: 00001111
Temperature: 64.8°C
(no units): 44.0
Readiness: 1 1 1 1 0
Address 02: Auto Trans Labels: 09A-927-750.lbl
Part No: 09A 927 750 AM
Component: AG5 Getriebe 09A 0242
VCID: 76B5E55391D680D7E0D-508A
01045 - Tiptronic Switch (F189)
27-00 - Implausible Signal
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019458
VCID: 34311F5BC22AD2C71E9-5184
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 04 AIRBAG VW61 0202 0003
Coding: 12340
Shop #: WSC 00066
VCID: 270BF81706FCA95FABB-513C
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J5 920 906 R
Component: KOMBI+WEGFAHRSP VDO V54
Coding: 15234
VCID: 3C21377BEF7A1A87D69-513C
3VWRR69M74M078653 VWZ7Z0C8501312
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00066
VCID: 70B9D34BF3B2AEE73A1-513C
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 1H Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 00066
VCID: 372B2857D65C39DF3BB-4B1E
Component: 1H Tõrsteuer.FS KLO 0202
Component: 1H Tõrsteuer.BF KLO 0202
Component: 1H Tõrsteuer.HL KLO 0202
Component: 1H Tõrsteuer.HR KLO 0202
00912 - Window Regulator Switch; Front Left (E40)
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180 F
Component: Radio ZSW 0016
Coding: 00401
Shop #: WSC 00066
VCID: 2313EC0772C4457FF73-513C
End----------(Elapsed Time: 05:13, VBatt start/end: 12.2V/12.2V)-----------
Address 01: Engine (038 906 016 H)
13:41:22 Group 001: Injection Quantity
924 /min Engine Speed (G28)
5.2 mg/str Injection Quantity
7.7°KW Injection Duration (specified)
74.7°C Coolant Temperature (G62)
13:41:22 Group 004: Pump-Jet Valves
4.0 °BTDC Injection Start (specified)
7.1°KW Injection Duration (specified)
-1.7°KW Torsion Value
13:41:22 Group 011: Charge Pressure Control
1040.4 mbar Boost Pressure (specified)
979.2 mbar Boost Pressure (actual)
81.3 % Charge Pressure Control Duty Cycle
13:43:18
882 /min Engine Speed (G28)
6.0 mg/str Injection Quantity
6.6°KW Injection Duration (specified)
2.99 mg/str Injection Quantity Deviation Cyl. 1
-1.84 mg/str Injection Quantity Deviation Cyl. 2
-0.80 mg/str Injection Quantity Deviation Cyl. 3
-0.61 mg/str Injection Quantity Deviation Cyl. 4
0.0 Injector Status Cylinder 1
0.0 Injector Status Cylinder 2
0.0 Injector Status Cylinder 3
0.0 Injector Status Cylinder 4
13:43:34
2016 /min Engine Speed (G28)
5.1°KW Injection Duration (specified)
-1.67 mg/str Injection Quantity Deviation Cyl. 2
-1.18 mg/str Injection Quantity Deviation Cyl. 3
-0.24 mg/str Injection Quantity Deviation Cyl. 4
13:43:45
2961 /min Engine Speed (G28)
6.9 mg/str Injection Quantity
2.0°KW Injection Duration (specified)
4.0 Injector Status Cylinder 1
4.0 Injector Status Cylinder 2
4.0 Injector Status Cylinder 3
4.0 Injector Status Cylinder 4
13:44:06
3654 /min Engine Speed (G28)
6.6 mg/str Injection Quantity
0.5°KW Injection Duration (specified)
Address 01: DTCs cleared
13:46:25
2814 /min Engine Speed (G28)
6.3 mg/str Injection Quantity
2.6°KW Injection Duration (specified)
-1.65 mg/str Injection Quantity Deviation Cyl. 2
-1.01 mg/str Injection Quantity Deviation Cyl. 3
-0.38 mg/str Injection Quantity Deviation Cyl. 4
36.0 Nm Torque Request (Driver)
0 /min Cylinder 1
