#1 cylinder misfire detected
john van
C?ID=346762
I get random (only) #1 cylinder misfire codes, always 2 of them. Engine starts and runs great, reading on fuel injected ridiculous and never changing for #1 injector. I have cleaned connections at injector before and ordered new harness this time. Is CPU failing? Mostly just irritating having to clear codes... Thanks. Sorry if I didn't get the scan inside code thingy properly.
Monday,12,August,2019,13:38:51:07126
VCDS Version: 19.6.0.2  HEX-V2 CB: 0.4505.4
VIN: 3VWRR69M74M078653   License Plate: LEM 8-12-19
Mileage: 401100km-249231mi   Repair Order:
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
          75 76
VIN: 3VWRR69M74M078653   Mileage: 401100km-249231miles
Address 01: Engine        Labels: 038-906-016-BEW.lbl
   Part No SW: 038 906 016 H    HW: 028 101 114 6
   Component: R4 1.9L EDC G000AG  5375
   Revision: 12345678    Serial number: VWZ7Z0C8501312
   Coding: 0150034
   VCID: 196FCEEF45880FAF2DF-5184
16685 - Cylinder 1
            P0301 - 000 - Misfire Detected
                    RPM: 903 /min
                    Torque: 64.0 Nm
                    Voltage: 13.98 V
                    Bin. Bits: 00001111
                    Temperature: 64.8°C
                    (no units): 44.0
Readiness: 1 1 1 1 0
Address 02: Auto Trans        Labels: 09A-927-750.lbl
   Part No: 09A 927 750 AM
   Component: AG5 Getriebe 09A   0242
   VCID: 76B5E55391D680D7E0D-508A
01045 - Tiptronic Switch (F189)
            27-00 - Implausible Signal
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 M
   Coding: 0019458
   VCID: 34311F5BC22AD2C71E9-5184
   Part No: 1C0 909 605 F
   Component: 04 AIRBAG VW61 0202 0003
   Coding: 12340
   Shop #: WSC 00066
   VCID: 270BF81706FCA95FABB-513C
   Part No: 1J5 920 906 R
   Component: KOMBI+WEGFAHRSP VDO V54
   Coding: 15234
   VCID: 3C21377BEF7A1A87D69-513C
   3VWRR69M74M078653     VWZ7Z0C8501312
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70B9D34BF3B2AEE73A1-513C
   Part No: 1C0 959 799 C
   Component: 1H Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 00066
   VCID: 372B2857D65C39DF3BB-4B1E
   Component: 1H Tõrsteuer.FS KLO 0202
   Component: 1H Tõrsteuer.BF KLO 0202
   Component: 1H Tõrsteuer.HL KLO 0202
   Component: 1H Tõrsteuer.HR KLO 0202
00912 - Window Regulator Switch; Front Left (E40)
Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
   Part No: 3B7 035 180 F
   Component:    Radio ZSW        0016
   Coding: 00401
   Shop #: WSC 00066
   VCID: 2313EC0772C4457FF73-513C
End----------(Elapsed Time: 05:13, VBatt start/end: 12.2V/12.2V)-----------
                Address 01: Engine  (038 906 016 H)
13:41:22 Group 001: Injection Quantity
  924 /min  Engine Speed (G28)
  5.2 mg/str  Injection Quantity
  7.7°KW  Injection Duration (specified)
  74.7°C  Coolant Temperature (G62)
13:41:22 Group 004: Pump-Jet Valves
  4.0 °BTDC  Injection Start (specified)
  7.1°KW  Injection Duration (specified)
  -1.7°KW  Torsion Value
13:41:22 Group 011: Charge Pressure Control
  1040.4 mbar  Boost Pressure (specified)
  979.2 mbar  Boost Pressure (actual)
  81.3 %  Charge Pressure Control Duty Cycle
13:43:18
  882 /min   Engine Speed (G28)
  6.0 mg/str   Injection Quantity
  6.6°KW   Injection Duration (specified)
  2.99 mg/str   Injection Quantity Deviation Cyl. 1
  -1.84 mg/str   Injection Quantity Deviation Cyl. 2
  -0.80 mg/str   Injection Quantity Deviation Cyl. 3
  -0.61 mg/str   Injection Quantity Deviation Cyl. 4
  0.0   Injector Status Cylinder 1
  0.0   Injector Status Cylinder 2
  0.0   Injector Status Cylinder 3
  0.0   Injector Status Cylinder 4
13:43:34
  2016 /min   Engine Speed (G28)
  5.1°KW   Injection Duration (specified)
  -1.67 mg/str   Injection Quantity Deviation Cyl. 2
  -1.18 mg/str   Injection Quantity Deviation Cyl. 3
  -0.24 mg/str   Injection Quantity Deviation Cyl. 4
13:43:45
  2961 /min   Engine Speed (G28)
  6.9 mg/str   Injection Quantity
  2.0°KW   Injection Duration (specified)
  4.0   Injector Status Cylinder 1
  4.0   Injector Status Cylinder 2
  4.0   Injector Status Cylinder 3
  4.0   Injector Status Cylinder 4
13:44:06
  3654 /min   Engine Speed (G28)
  6.6 mg/str   Injection Quantity
  0.5°KW   Injection Duration (specified)
Address 01: DTCs cleared
13:46:25
  2814 /min   Engine Speed (G28)
  6.3 mg/str   Injection Quantity
  2.6°KW   Injection Duration (specified)
  -1.65 mg/str   Injection Quantity Deviation Cyl. 2
  -1.01 mg/str   Injection Quantity Deviation Cyl. 3
  -0.38 mg/str   Injection Quantity Deviation Cyl. 4
  36.0 Nm   Torque Request (Driver)
  0 /min   Cylinder 1
Did you check lifters & set lash of injector to cam clearance?
john van
C?ID=346762
Yes I have checked cam and lifters and they appear fine. The lash is set at app. 210-220 degrees back from bottom. The compression was 410, 412, 405, and 408 1-4 respectively. Leak down on #1 good. I had misfire codes a few years ago which started ye olde can of worms until I realized it was all due to crappy wires/connectors. Same with glow plugs. Hoping a new harness will correct misfire misfires... I am curious about injection quantity Deviation stuck at 2.99 mg/str ??????? It didn't used to say that, say last year when I did some scans. Thanks for assistance.
WTF! OMG lash is not a degree setting........better RTFB!
HOLY FOD!
john van
C?ID=346762
The Bentley book gives a complicated and problematic method for setting the PD injector clearances. The method is to use a dial indicator mounted onto the rocker, then rotate the engine until the full depth of the stroke is reached. Screw in the adjustor screw until it bottoms out. Then back it out 180 degrees. Tighten the ball screw lock nut to 24 ft lbs. VW did standardize the setting for all PD motors for a 180 degree setting.
Others have indicated that slightly over the 180 degree setting was fine and even suggested by VW. Just prevents bottoming out injector...
Well you have a mechanical which is off, your harness is damaged or maybe check your cam belt and mechanical cam timing and see if you have a broken key-way or virtual key-way by press fit........
john van
C?ID=346762
As I mentioned I am hoping it is just the wiring harness. That should arrive in a few days from IDParts. Hard to believe it's something mechanical since it runs well... Thank you for your time and help though. Much appreciated. Belt and water pump replaced soon after I bought car in 2014 or 15 as it had 225k miles and last replaced about 100k according to maintenance records. It gets 43 mpg on highway.
Yeah well I had a bunch of guys in the past that swore off the mechanical's and low and behold each time it was indeed the issue..........
john van
C?ID=346762
Thanks Jef. Do you see all replies? I wasn't sure if you are included in my replies to Jack. As far as cam belt timing, I thought I read 0 degrees in "Torsion Value" was "best". Mine is -1.7? Seems to run fine but always room for improvement... Also, I am guessing that the misfire code is actuated by an electrical signal so a mechanical should not cause? Hence my efforts to replace wiring harness. Not certain how the magic black box is getting it's information. ;) Thanks.
I am not included in such emails and I dont want to be.....
Fix the inaccurate cam timing already...........
