Results 1 to 6 of 6
Thread: Transporter T 5.1 BCM swap issues
    Oct 2018
    Hi guys,
    hoping someone can help as I've been searching for hours to see if I could resolve this for myself first, to no avail, I have a 2013 T5 and I'm adding a Golk mk7 MFSW with standard button and cruise on the stalks, however before I sort all of that I'm having issues with the BCM swap, I've bought an 090 version but when it's installed I have no power windows and no indicators, when testing I can get the system to turn on the indicators but not the windows.
    I'm not 100% that the BCM was actually out of a T5 previously but I'm hoping that it isn't goosed
    Any help would be appreciated.
    Thanks, Tim.
    Here is my original 086 BCM Scan
    Chassis Type: 7H-VN75 (6N0)
    Scan: 01 03 04 08 09 15 17 19 25 56 0B
    Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
       Part No SW: 03L 906 019 GH    HW: 03L 907 309 M
       Component: R4 2,0L EDC   H45 5576
       Revision: 26H45---    Serial number: 00000000000000
       Coding: 01194012230400080000
       Shop #: WSC 02736 790 50316
       ASAM Dataset: EV_ECM20TDI01103L906019GH 003003
       ROD: EV_ECM20TDI01103L906019FM_003.rod
       VCID: 77ABE8B21F41696FFB3-8022
    Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
       Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
       Component: ESP MK25A XT  H43 0110
       Revision: 00H43001
       Coding: 508724AD89A60A9924A29174A96110
       Shop #: WSC 02736 790 49152
       VCID: 3A2D31866C53B407C4D-806E
    Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
       Part No SW: 7E5 907 047 BN    HW: 7E5 907 047 BN
       Component: Climatic-T5   H20 0505
       Revision: 00001010
       Coding: 0000000002
       ROD: EV_ClimaT5Basis.rod
       VCID: 7CA1F79E26674A37961-8028
              U1111 00 [008] - -
              [Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
                        Fault Frequency: 12
                        Reset counter: 112
                        Time: 00:00:00
       Part No SW: 7H0 937 086 K    HW: 7H0 937 086
       Component: BCM T5GPM++4  H32 0407
       Revision: BM032001    Serial number: 0532 109130782
       Coding: E0A0393A0A212011002008102C2B8C540010430F60060000320000000000
       Shop #: WSC 02736 790 00000
       VCID: 3B23348263698D0FDFB-806E
       Subsystem 1 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
       Component: J386__TSG_FT  002 3313
       Subsystem 2 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
       Component: J387__TSG_BT  002 3313
       Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
       Component: VW10Airbag009 H07 0013
       Revision: --------    Serial number: 003HL00H9LRT
       Shop #: WSC 02734 790 50316
       VCID: 353722BA45CD5B7F29F-8060
              B1000 1B [136] - Resistance Too High
                        Time: 00:00:00
       Part No SW: 7E0 920 960 G    HW: 7E0 920 960 G
       Component: KOMBI         H06 0605
       Coding: 460201
       VCID: 2D070ADAAD9D13BF51F-8078
    12664832 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät für BCM / Bordnetz / el. ZE: keine Kommunikation]
                        Reset counter: 112
                        Time: 00:00:00
       Part No SW: 6N0 909 901     HW: 7H0 937 086
       Component: GW-K-CAN TP20 H32 0407
       Revision: BM032001
       Coding: 042300
       VCID: 70B9D3AE7AAF3E573A9-8024
       Component: IMMO          H06 0605
       VCID: 6A8DC1C65CF3C48774D-803E
    and here is the 090 BCM
    Scan: 01 03 04 08 09 15 17 19 25 44 56 77 0B
    VIN: WV1ZZZ7HZDH124033   Mileage: 177940km-110566miles
    44-Steering Assist -- Status: Cannot be reached 1100
       Revision: 00H43001
       Revision: 00001010
       Coding: 0000000002
              U1111 00 [009] - -
                        Fault Frequency: 12
                        Reset counter: 2
                        Time: 00:00:00
       Part No SW: 7H0 937 090 D    HW: 7H0 937 090
       Component: BCM PQ25 Max4 H74 0726
       Revision: B9074001    Serial number: 0661 234140059
       Coding: E0A0393A0A212011002808102C2B8C510010430F60060000320000000000
       Shop #: WSC 05205 002 104857
       VCID: 2F3B10D2A71161AF633-807A
    01326 - Control Module for Multi-Function Steering Wheel (J453)
                        Reset counter: 2
    01516 - Terminal 30; Left
                        Reset counter: 2
    00927 - Terminal 30 (Right)
                        Reset counter: 2
                        Time: 00:00:00
       Coding: 460201
              U1111 00 [009] - -
                        Reset counter: 2
                        Time: 00:00:00
    13638912 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Steuergerät für Lenkhilfe: keine Kommunikation]
                        Reset counter: 2
                        Time: 00:00:00
       Part No SW: 6N0 909 901     HW: 7H0 937 090
       Component: GW-K-CAN TP20 H74 0726
       Revision: B9074001
       Coding: 702300
                        Reset counter: 2
                        Reset counter: 2
                        Reset counter: 2
    Address 44: Steering Assist
    Address 56: Radio
    Address 77: Telephone
    Mar 2019
    New Zealand
    I've done this on my van. Fitted a Passat CC mfsw. Details are a little vague but I do remember running a lin bus wire for the steering wheel button illumination and swapping the bcm T5's are Polo 6R based electronics wise but I'm pretty sure I used a highline T5 bcm as I installed cornering lights at the same time.
    Unfortunately I'm not near my van till the weekend so can't confirm till then what part number I used
    Mar 2019
    New Zealand
    Come to think of it an 087 bcm is highline and will support those functions
    Oct 2018
    Thanks racofuy, I've not got to the wiring bit yet but have all the instructions for it, it's the fact that the indicators and windows aren't working after putting the 090 BCM in, I'm doing it in steps so as not to bring too many potential issues in in one go.
    Jan 2019
    If you change the BCM you need to copy old Values in Coding and Installation-List of CAN Gateway (19), too.
    From your scan i see that coding there was not copied from old to new.
    Installation List is not visibly in Autoscan, but from the Erros it looks like it is configured wrong, too.
    Before:
    Revision: BM032001
    Coding: 042300
    Now
    Revision: B9074001
    Coding: 702300
  6. Likes Uwe liked this post
    Oct 2018
    Thank you dnoermann, I'll take a look at this as well, it would also appear that I need to add two wires to the instrument cluster for the canbus and extra power as I have got a 'max' BCM.
    Learnt a hell of a lot over the past few days
  8. Likes Uwe liked this post
