Results 11 to 20 of 33
Thread: 2019 Audi RS3, 2.5TFSI EA855 EVO (DAZA)
    Aug 2019
    Toronto, Canada
    17 - Instruments
    ADPmap - 17 - Instruments
    ;SW:8V0-920-790-C   HW:8V0-920-790-C ---  Instruments
    ;Component:FBenRDW       H19 0109, Coding:080F18537F8800080284EC001800001000000000
    ;EV_DashBoardFPKAU37X,001032,EV_DashBoardFPKAU37X.rod
    ;Sunday,11,August,2019,16:09:17:40778
    ;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
    ;VCID: 3C34F8E2B7F4EDAF85-8068
    IDE00001-Production mode,not active ,3
    IDE00301-Distance,500 km,3
    IDE00342-ESI: Resetting ESI,no warning ,1
    IDE00343-Language version,US English ,1
    IDE00499-Display correction of consumptions and operating range,100 %,1
    IDE00500-Hour,16 H,1
    IDE00501-Minute,9 min,1
    IDE00502-Year,2019 yr,2
    IDE00503-Month,8 mon,1
    IDE00504-Day,11 d,1
    IDE00510-ESI: distance driven from inspection,400 km,3
    IDE00511-ESI: time from inspection,19 d,2
    IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2
    IDE00513-ESI: maximum value km-driving distance/inspection,15000 km,2
    IDE00514-ESI: maximum value of time between inspections,730 d,2
    IDE00515-ESI: oil quality,poor oil quality ,1
    IDE00517-ESI: soot entry,0 km,2
    IDE00518-ESI: thermal load,900 km,2
    IDE00819-Day counter,54 d,2
    IDE00827-ESI: minimum value of time between inspections,365 d,2
    IDE01153-SIA: maximum value of distance to service,15000 km,2
    IDE01154-SIA: maximum value of time to service,365 d,2
    IDE02489-Display depiction,Version 2 ,1
    IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.80 l,5
    IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.80 l,5
    IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,-12.80 l,5
    IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.70 l,5
    IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.70 l,5
    IDE03329-Driving profiled for range remaining,9.40 l/100km,2
    IDE03346-IDE00301-Units adjusted-Distance,Kilometers ,3
    IDE03346-MAS01230-Units adjusted-Date,yy_mm_dd ,3
    IDE03346-MAS01456-Units adjusted-Speed,Kilometers per hour ,3
    IDE03346-MAS02201-Units adjusted-Temperature,∞C ,3
    IDE03346-MAS02957-Units adjusted-Time,24h ,3
    IDE03346-MAS03032-Units adjusted-Volume,Liter ,3
    IDE03346-MAS03034-Units adjusted-Pressure,psi ,3
    IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,3
    IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,3
    IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km ,3
    IDE03348-MAS01456-Speed warning-Speed,150 ,2
    IDE03348-MAS01561-Speed warning-Unit,Kilometers per hour ,2
    IDE03348-Speed warning-,active ,2
    IDE03349-FIX: Max. distance until next mileage-related inspection,30000 km,3
    IDE03350-FIX: Maximum time until next time-dependent inspection,730 d,2
    IDE03351-FIX: Distance covered since last mileage-dependent inspection,400 km,3
    IDE03352-FIX: Time since last time-dependent inspection,19 d,2
    IDE03372-Source for synchronization of time,GPS ,1
    IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On ,5
    IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s,5
    IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,OFF ,5
    IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On ,5
    IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h,5
    IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s,5
    IDE03568-ENG104099-Service-key settings-p_write_distance,20 km,5
    IDE03867-Deactivate seat belt warning,No ,1
    IDE04169-Display correction of consumption and operating range: gas,100 %,1
    IDE05930-Service notification in days,30 d,1
    IDE05971-Vehicle Positioning System Interface Control Module,not installed ,1
    IDE06588-Ignition active message: actuator,Driver door ,1
    IDE06922-No-voltage display,No display ,1
    IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min,2
    IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2
    IDE07221-Cylinder shut-off,Display ,1
    IDE07579-MAS05872-Driving profile for operating range consump.with electric drive-Operating range average voltage,10.00 A,8
    IDE07579-MAS05875-Driving profile for operating range consump.with electric drive-Average consumption: electric drive,25 ,8
    IDE07579-MAS05876-Driving profile for operating range consump.with electric drive-Average consumption: low voltage auxiliary consumer,0.20 ,8
    IDE07579-MAS05877-Driving profile for operating range consump.with electric drive-Average consumption: high voltage auxiliary consumer,0.50 ,8
    IDE07600-ENG114653-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_0,25.00 ,14
    IDE07600-ENG114654-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_1,25.00 ,14
    IDE07600-ENG114655-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_2,25.00 ,14
    IDE07600-ENG114656-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_3,25.00 ,14
    IDE07600-ENG114657-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_4,25.00 ,14
    IDE07600-ENG114658-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_5,25.00 ,14
    IDE07600-ENG114659-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_6,25.00 ,14
    IDE08140-Driving profiled for range remaining CNG,0.00 kg/100 km,2
    IDE08247-Driving profile for range remaining LPG,0.00 l/100km,2
    IDE10208-Display correct. of consump. and operating range: elec.,100 %,1
    IDE10693-Initialize sensor for fuel level,No ,1
    IDE10694-ENG126302-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_0,10.50 l/100km,14
    IDE10694-ENG126303-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_1,10.00 l/100km,14
    IDE10694-ENG126304-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_2,10.00 l/100km,14
    IDE10694-ENG126305-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_3,10.00 l/100km,14
    IDE10694-ENG126306-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_4,10.00 l/100km,14
    IDE10694-ENG126307-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_5,10.00 l/100km,14
    IDE10694-ENG126308-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_6,10.00 l/100km,14
    IDE11472-IDE03360-Configuration of displayable contents-Upshift display in center panel,Display ,4
    IDE11472-MAS05424-Configuration of displayable contents-Natural gas quality,No display ,4
    IDE11472-MAS12789-Configuration of displayable contents-Display: engine running required,No display ,4
    IDE11472-MAS18773-Configuration of displayable contents-Acceleration measurement,No display ,4
    IDE11472-MAS18774-Configuration of displayable contents-Drag indicator,No display ,4
    IDE11472-MAS19086-Configuration of displayable contents-Charge symbol color,Standard ,4
    IDE12050-Acoustic: drive position R,not active ,1
    IDE13607-MAS16698-Lock display contents-Lock infotainment list,No ,9
    IDE13607-MAS16699-Lock display contents-Lock function lists,No ,9
    IDE13607-MAS16700-Lock display contents-Lock MFA displays,No ,9
    IDE13607-MAS16701-Lock display contents-Dynamic image lock,No ,9
    IDE13607-MAS16702-Lock display contents-Lock functional animation,No ,9
    IDE13607-MAS16703-Lock display contents-lock,No ,9
    IDE13607-MAS16704-Lock display contents-Lock system status animation,No ,9
    IDE13607-MAS16705-Lock display contents-Lock operating support animation,No ,9
    IDE13607-MAS16706-Lock display contents-List time out,0 s,9
    IDE13607-MAS17250-Lock display contents-Map locked,No ,9
    IDE13607-MAS17251-Lock display contents-Piloted driving locked,No ,9
    IDE13607-MAS17283-Lock display contents-Vehicle model locked,No ,9
    IDE13607-MAS17284-Lock display contents-Cover intensity locked,100 %,9
    IDE13607-MAS17285-Lock display contents-Number of list entries blocked,0 ,9
    IDE14123-MAS01129-Design variant activation-Version 1,not active ,2
    IDE14123-MAS01130-Design variant activation-Version 2,not active ,2
    IDE14123-MAS01131-Design variant activation-Version 3,not active ,2
    IDE14123-MAS01339-Design variant activation-Version 9,not active ,2
    IDE14123-MAS03101-Design variant activation-Version 4,not active ,2
    IDE14123-MAS03102-Design variant activation-Version 5,not active ,2
    IDE14123-MAS03103-Design variant activation-Version 6,not active ,2
    IDE14123-MAS03104-Design variant activation-Version 7,not active ,2
    IDE14123-MAS03105-Design variant activation-Version 8,not active ,2
    IDE14123-MAS05866-Design variant activation-lock,No ,2
    IDE14123-MAS06157-Design variant activation-Version 10,not active ,2
    IDE14123-MAS06158-Design variant activation-Version 11,not active ,2
    IDE14123-MAS06159-Design variant activation-Version 12,not active ,2
    IDE14123-MAS06160-Design variant activation-Version 13,not active ,2
    IDE14123-MAS06161-Design variant activation-Version 14,not active ,2
    IDE14123-MAS06162-Design variant activation-Version 15,not active ,2
    IDE14220-Vehicle speed warning for India-,No ,1
    IDE14220-Vehicle speed warning for India-,0 s,1
    MAS03555-Lap counter,No display ,1
    MAS03685-Digital speedometer,Display ,1
    ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,21
    ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,21
    ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,21
    ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,21
    ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,21
    ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,21
    ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,21
    ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,21
    ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,21
    ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,21
    ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,21
    ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,21
    ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,21
    ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,21
    ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,21
    ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,21
    ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,21
    ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,21
    ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,21
    ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,21
    ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,21
    ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,21
    ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,21
    ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,21
    ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,21
    ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,21
    ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,21
    ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,21
    ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,21
    ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,21
    ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,21
    ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,21
    ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,21
    ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,21
    ENG119877-ENG126397-Configuration of Development CAN-Messages-Block 40,OFF ,21
    ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,21
    ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,21
    ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,21
    ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,21
    ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,50ms ,21
    ENG128731-MAS01129-designvariant_activation-Version 1,active ,2
    ENG128731-MAS01130-designvariant_activation-Version 2,active ,2
    ENG128731-MAS01131-designvariant_activation-Version 3,not active ,2
    ENG128731-MAS03101-designvariant_activation-Version 4,not active ,2
    ENG128731-MAS03102-designvariant_activation-Version 5,not active ,2
    ENG128731-MAS03103-designvariant_activation-Version 6,not active ,2
    ENG128731-MAS03104-designvariant_activation-Version 7,not active ,2
    ENG128731-MAS03105-designvariant_activation-Version 8,not active ,2
    ENG99320-Developers_menu,not active ,1
    ENG119879-ENG101574-dimming_characteristic_curve_adjustment_bargraph_main_colour-X1,00 ,12
    ENG119879-ENG99557-dimming_characteristic_curve_adjustment_bargraph_main_colour-X2,0A ,12
    ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,32 ,12
    ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,64 ,12
    ENG119879-ENG103548-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5,DC ,12
    ENG119879-ENG113992-dimming_characteristic_curve_adjustment_bargraph_main_colour-X6,FD ,12
    ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,02 ,12
    ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,02 ,12
    ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,06 ,12
    ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,0A ,12
    ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,50 ,12
    ENG119879-ENG113993-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y6,64 ,12
    ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,0A ,12
    ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,32 ,12
    ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,64 ,12
    ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,96 ,12
    ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,02 ,12
    ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,02 ,12
    ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,0E ,12
    ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,1E ,12
    ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,32 ,12
    ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
    ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
    ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,02 ,12
    ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,02 ,12
    ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,0E ,12
    ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,1E ,12
    ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,32 ,12
    ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,14 ,12
    ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,1E ,12
    ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,32 ,12
    ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,46 ,12
    ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,64 ,12
    ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,00 ,12
    ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,14 ,12
    ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,1E ,12
    ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,32 ,12
    ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,46 ,12
    ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32 ,12
    ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64 ,12
    ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,DC ,12
    ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,02 ,12
    ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,02 ,12
    ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,06 ,12
    ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,0A ,12
    ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,50 ,12
    ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 96 ,20
    ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 32 ,20
    ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 64 ,20
    ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8 ,20
    ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32 ,12
    ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64 ,12
    ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,DC ,12
    ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,02 ,12
    ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,02 ,12
    ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,06 ,12
    ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,0A ,12
    ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,50 ,12
    ENG153811-ENG154946-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X1,0.20 s,24
    ENG153811-ENG154947-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X2,0.40 s,24
    ENG153811-ENG154948-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X3,0.60 s,24
    ENG153811-ENG154949-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X4,0.80 s,24
    ENG153811-ENG154950-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X5,1.00 s,24
    ENG153811-ENG154951-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X6,1.20 s,24
    ENG153811-ENG154952-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y1,80.00 %,24
    ENG153811-ENG154953-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y2,60.00 %,24
    ENG153811-ENG154954-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y3,40.00 %,24
    ENG153811-ENG154955-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y4,25.00 %,24
    ENG153811-ENG154956-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y5,12.00 %,24
    ENG153811-ENG154957-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y6,0.00 %,24
    ENG153811-ENG155080-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X1,0.20 s,24
    ENG153811-ENG155081-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X2,0.40 s,24
    ENG153811-ENG155082-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X3,0.60 s,24
    ENG153811-ENG155083-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X4,0.80 s,24
    ENG153811-ENG155084-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X5,1.00 s,24
    ENG153811-ENG155085-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X6,1.20 s,24
    ENG153811-ENG155086-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y1,40.00 %,24
    ENG153811-ENG155087-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y2,60.00 %,24
    ENG153811-ENG155088-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y3,75.00 %,24
    ENG153811-ENG155089-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y4,85.00 %,24
    ENG153811-ENG155090-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y5,95.00 %,24
    ENG153811-ENG155091-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y6,100.00 %,24
    ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xs_bus ,1
    ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,lds ,1
    ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 ∞C,16
    ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 ∞C,16
    ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 ∞C,16
    ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,5.00 km,16
    ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.00 ∞C,16
    ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.00 ,16
    ENG126283-parameter_hmi,41 43 56 03 05 FF 1E 03 00 01 00 FA 02 00 FF 00 00 FF FF 00 00 F3 00 00 FF 00 24 00 FF 43 14 28 00 00 5A 00 E1 00 19 FF B4 00 1E 8C AA 64 AA 00 BF 4B 68 A2 91 6D 6D 97 A2 73 9B 75 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,100
    ENG135292-phev_stat_intervall-,5.00 ,3
    ENG135292-phev_stat_intervall-,100 m,3
    ENG135292-phev_stat_intervall-,0 min,3
    ENG119876-Service_Key_Clear_All_Counter,No ,1
    ENG126281-ENG126398-SK2_Adjustment-max_number_of_writing_procedures,6 ,3
    ENG126281-ENG126400-SK2_Adjustment-timeout_request_immediate,150 s,3
    ENG126281-ENG126399-SK2_Adjustment-timeout_request_normal,300 s,3
    ENG109442-ENG101663-time_parameter_display-tDD15_off,0.25 ,18
    ENG109442-ENG103975-time_parameter_display-tDD15_on,0.50 ,18
    ENG109442-ENG100026-time_parameter_display-tDDWUP,0.00 ,18
    ENG112418-ENG112412-total_range_gas-consumption_factor,1.40 ,4
    ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation ,4
    ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN ,4
    ENG112418-ENG99298-total_range_gas-State,active ,4
    Elapsed Time: 00:49
    Blockmap - 17 - Instruments
    ;Sunday,11,August,2019,16:08:18:40778
    Group,Description,Actual
    IDE00019,Voltage terminal 30,11.90, V
    IDE00021,Engine speed,0, /min
    IDE00025,Coolant temperature,25.50, ∞C
    IDE00030,Status of actuator test,not active,
    IDE00075,Vehicle speed,0, km/h
    IDE00191,Charge air pressure: actual value,0.00, %
    IDE00196,Engine oil temperature,25, ∞C
    IDE00301,Distance,500, km
    IDE00310,Outside air temperature,25.50, ∞C
    IDE00316-IDE00500,Time-Hour,16, H
    IDE00316-IDE00501,Time-Minute,8, min
    IDE00316-MAS00111,Time-Seconds,18, s
    IDE00317-IDE00502,Date-Year,2019, yr
    IDE00317-IDE00503,Date-Month,8, mon
    IDE00317-IDE00504,Date-Day,11, d
    IDE00322,Status of basic setting,not active,
    IDE00323,Security Access: Number of invalid keys,0,
    IDE00510,ESI: distance driven from inspection,400, km
    IDE00511,ESI: time from inspection,19, d
    IDE00512,ESI: minimum value km-driving distance/inspection,15000, km
    IDE00513,ESI: maximum value km-driving distance/inspection,15000, km
    IDE00514,ESI: maximum value of time between inspections,730, d
    IDE00515,ESI: oil quality,poor oil quality,
    IDE00517,ESI: soot entry,0, km
    IDE00518,ESI: thermal load,900, km
    IDE00520,Phototransistor,249,
    IDE00695,ESI: service exceedance in km,Not available,
    IDE00696,ESI: service exceedance in days,Not available,
    IDE00697,ESI: remaining distance,14530, km
    IDE00698,ESI: remaining running time,346, d
    IDE00787-IDE02689,Cause for cancellation-Complete tank calibration,not performed,
    IDE00787-IDE02690,Cause for cancellation-Wet dry tank calibration,not performed,
    IDE00819,Day counter,54, d
    IDE00827,ESI: minimum value of time between inspections,365, d
    IDE00845-MAS03213,Wheel circ.-Average wheel circumference for trip distance,1950, mm
    IDE00845-MAS03214,Wheel circ.-Maximum wheel circumference for speed,2005, mm
    IDE00935,ESI: Theoretical service interval,15000, km
    IDE01076,Time since ignition off,54863, s
    IDE01153,SIA: maximum value of distance to service,15000, km
    IDE01154,SIA: maximum value of time to service,365, d
    IDE01285,Counter of component protection malfunctions,0,
    IDE01985-ENG101043,FAZIT identification test sum-Checksum,46 A9 8C 8D,
    IDE01985-ENG99027,FAZIT identification test sum-Version,02,
    IDE02642,Outside temp.: displayed value,25.50, ∞C
    IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,FD,
    IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,00,
    IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,64,
    IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,476,
    IDE03349,FIX: Max. distance until next mileage-related inspection,30000, km
    IDE03350,FIX: Maximum time until next time-dependent inspection,730, d
    IDE03351,FIX: Distance covered since last mileage-dependent inspection,400, km
    IDE03352,FIX: Time since last time-dependent inspection,19, d
    IDE03471-IDE02383,Vehicle configuration-Dynamic steering,Correct coding,
    IDE03471-IDE03640,Vehicle configuration-Dynamic AFS light,Correct coding,
    IDE03471-IDE03726,Vehicle configuration-Parallel Parking Assistance,Correct coding,
    IDE03471-IDE04525,Vehicle configuration-Wheel Dampening Electronics,Correct coding,
    IDE03471-IDE04939,Vehicle configuration-Tire pressure monitoring display,Correct coding,
    IDE03471-IDE05830,Vehicle configuration-Rear Spoiler,Correct coding,
    IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring,Correct coding,
    IDE03471-IDE07944,Vehicle configuration-electronic brake booster,Correct coding,
    IDE03471-MAS00809,Vehicle configuration-Electro-Mechanical Parking Brake Control Module,Correct coding,
    IDE03471-MAS00811,Vehicle configuration-Active steering control module,Correct coding,
    IDE03471-MAS00911,Vehicle configuration-All Wheel Drive (AWD),Correct coding,
    IDE03471-MAS01091,Vehicle configuration-Automated manual transmission,Correct coding,
    IDE03471-MAS01374,Vehicle configuration-Trailer,Correct coding,
    IDE03471-MAS01891,Vehicle configuration-Lane assistant,Correct coding,
    IDE03471-MAS01938,Vehicle configuration-Road sign detection,Correct coding,
    IDE03471-MAS02570,Vehicle configuration-Lock Electronics,Correct coding,
    IDE03471-MAS03385,Vehicle configuration-Lane change assistance,Correct coding,
    IDE03471-MAS04384,Vehicle configuration-Electrical steering column lock control module,Correct coding,
    IDE03471-MAS05723,Vehicle configuration-Adaptive cruise control or reducing stopping distance,Correct coding,
    IDE03471-MAS06008,Vehicle configuration-Internal noise sound actuator,Correct coding,
    IDE03471-MAS08201,Vehicle configuration-Trailer positioning assistant,Correct coding,
    IDE03471-MAS08940,Vehicle configuration-Collision warning,Correct coding,
    IDE03471-MAS09196,Vehicle configuration-Rear Axle Steering,Correct coding,
    IDE03471-ENG126401,Vehicle configuration-intelligent_park_assist,Correct coding,
    IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,6.50, l
    IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,55.00, l
    IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,56.90, l
    IDE03472-MAS03809,Volume after refueling-Last reference quantity,7.00, l
    IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,1.00, l
    IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,55.00, l
    IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,56.90, l
    IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,6.40, l
    IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,0.00, l
    IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,0.00, l
    IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,0.00, l
    IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,0.00, l
    IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,0.00, l
    IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,0.00, l
    IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,0.00, l
    IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,0.00, l
    IDE03472-MAS03822,Volume after refueling-Last error status,00,
    IDE03472-MAS03823,Volume after refueling-Penultimate error status,00,
    IDE03472-MAS03824,Volume after refueling-Third-last error status,00,
    IDE03472-MAS03825,Volume after refueling-Fourth-last error status,00,
    IDE03472-MAS06153,Volume after refueling-Last distance,390, km
    IDE03472-MAS06154,Volume after refueling-Penultimate distance,30, km
    IDE03472-MAS06155,Volume after refueling-Third to last distance,0, km
    IDE03472-MAS06156,Volume after refueling-Fourth to last distance,0, km
    IDE03473-IDE00730,Fuel tank sens-Fuel level sensor 1 including soiling resistance,80, Ohm
    IDE03473-IDE00731,Fuel tank sens-Fuel level sensor 2 including soiling resistance,112, Ohm
    IDE03473-IDE00732,Fuel tank sens-Fuel level sensor 1 soiling resistance,0, Ohm
    IDE03473-IDE00733,Fuel tank sens-Fuel level sensor 2 soiling resistance,0, Ohm
    IDE03473-IDE03494,Fuel tank sens-Fuel level sensor 3 including soiling resistance,not_available,
    IDE03473-IDE03495,Fuel tank sens-Fuel level sensor 3 soiling resistance,not_available,
    IDE03473-IDE03496,Fuel tank sens-Fuel level sensor 4 including soiling resistance,not_available,
    IDE03473-IDE03497,Fuel tank sens-Fuel level sensor 4 soiling resistance,not_available,
    IDE03473-MAS03798,Fuel tank sens-Raw value sensor 1 resistor 1,291,
    IDE03473-MAS03799,Fuel tank sens-Raw value sensor 1 resistor 2,619,
    IDE03473-MAS03800,Fuel tank sens-Raw value sensor 2 resistor 1,374,
    IDE03473-MAS03801,Fuel tank sens-Raw value sensor 2 resistor 2,581,
    IDE03473-MAS03802,Fuel tank sens-Raw value sensor 3 resistor 1,not_available,
    IDE03473-MAS03803,Fuel tank sens-Raw value sensor 3 resistor 2,not_available,
    IDE03473-MAS03804,Fuel tank sens-Raw value sensor 4 resistor 1,not_available,
    IDE03473-MAS03805,Fuel tank sens-Raw value sensor 4 resistor 2,not_available,
    IDE03474-IDE00304,Calculated volume-Fuel level,46.20, l
    IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,79, Ohm
    IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,111, Ohm
    IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,not_available,
    IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,not_available,
    IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,21.00, l
    IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,26.30, l
    IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,not_available,
    IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,not_available,
    IDE03474-IDE00802,Calculated volume-Full volume,55.00, l
    IDE03474-MAS03826,Calculated volume-Quality sensor 1,10,
    IDE03474-MAS03827,Calculated volume-Quality sensor 2,10,
    IDE03474-MAS03828,Calculated volume-Quality sensor 3,not installed,
    IDE03474-MAS03829,Calculated volume-Quality sensor 4,not installed,
    IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,21.00, l
    IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,26.30, l
    IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,not_available,
    IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,not_available,
    IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.00,
    IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.00,
    IDE03474-ENG102894,Calculated volume-averaged_volume,47.20, l
    IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,47.20, l
    IDE03474-ENG101619,Calculated volume-calibrated_volume_total,47.30, l
    IDE03474-ENG126318,Calculated volume-gas_based_linking,1.00,
    IDE03474-ENG99553,Calculated volume-linking,0.0000000,
    IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,-0.25, m/s
    IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,-0.66, m/s
    IDE03474-ENG101623,Calculated volume-reference_volume,47.00, l
    IDE03474-ENG102479,Calculated volume-speed_based_linking,0.00,
    IDE03474-ENG99683,Calculated volume-version_of_application,3,
    IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0010309,
    IDE03475-MAS02915,Control button in instrument cluster-Button for auto check system,not active,
    IDE03475-MAS03929,Control button in instrument cluster-Menu button,not active,
    IDE03475-MAS12387,Control button in instrument cluster-Button for daily distance driven,not active,
    IDE03477-IDE00500,GPS time-Hour,16, H
    IDE03477-IDE00500,GPS time-Hour,15, H
    IDE03477-IDE00501,GPS time-Minute,40, min
    IDE03477-IDE00501,GPS time-Minute,8, min
    IDE03477-IDE00502,GPS time-Year,2019, yr
    IDE03477-IDE00503,GPS time-Month,8, mon
    IDE03477-IDE00504,GPS time-Day,11, d
    IDE03477-MAS00111,GPS time-Seconds,40, s
    IDE03477-MAS00111,GPS time-Seconds,10, s
    IDE03477-MAS03493,GPS time-last synchronization year,2019, yr
    IDE03506,Distance: high resolution,00 07 A1 4F,
    IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,17,
    IDE03880-MAS03425,MOST address-Physical address,04 01,
    IDE03911-MAS01390,Service -interval- display: history 1-Block 1,4F F0 00 23,
    IDE03911-MAS01391,Service -interval- display: history 1-Block 2,0F F0 00 1A,
    IDE03911-MAS01392,Service -interval- display: history 1-Block 3,8F F0 00 1A,
    IDE03911-MAS01393,Service -interval- display: history 1-Block 4,CF F0 00 23,
    IDE03911-MAS01394,Service -interval- display: history 1-Block 5,FF FF FF FF,
    IDE03911-MAS01395,Service -interval- display: history 1-Block 6,FF FF FF FF,
    IDE03911-MAS01396,Service -interval- display: history 1-Block 7,FF FF FF FF,
    IDE03911-MAS01397,Service -interval- display: history 1-Block 8,FF FF FF FF,
    IDE03911-MAS01398,Service -interval- display: history 1-Block 9,FF FF FF FF,
    IDE03911-MAS01399,Service -interval- display: history 1-Block 10,FF FF FF FF,
    IDE03911-MAS01400,Service -interval- display: history 1-Block 11,FF FF FF FF,
    IDE03911-MAS01401,Service -interval- display: history 1-Block 12,FF FF FF FF,
    IDE03911-MAS01402,Service -interval- display: history 1-Block 13,FF FF FF FF,
    IDE03911-MAS01403,Service -interval- display: history 1-Block 14,FF FF FF FF,
    IDE03911-MAS01404,Service -interval- display: history 1-Block 15,FF FF FF FF,
    IDE03911-MAS01405,Service -interval- display: history 1-Block 16,FF FF FF FF,
    IDE03912-MAS01390,Service -interval- display: history 2-Block 1,FF FF FF FF,
    IDE03912-MAS01391,Service -interval- display: history 2-Block 2,FF FF FF FF,
    IDE03912-MAS01392,Service -interval- display: history 2-Block 3,FF FF FF FF,
    IDE03912-MAS01393,Service -interval- display: history 2-Block 4,FF FF FF FF,
    IDE03912-MAS01394,Service -interval- display: history 2-Block 5,FF FF FF FF,
    IDE03912-MAS01395,Service -interval- display: history 2-Block 6,FF FF FF FF,
    IDE03912-MAS01396,Service -interval- display: history 2-Block 7,FF FF FF FF,
    IDE03912-MAS01397,Service -interval- display: history 2-Block 8,FF FF FF FF,
    IDE03912-MAS01398,Service -interval- display: history 2-Block 9,FF FF FF FF,
    IDE03912-MAS01399,Service -interval- display: history 2-Block 10,FF FF FF FF,
    IDE03912-MAS01400,Service -interval- display: history 2-Block 11,FF FF FF FF,
    IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
    IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
    IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
    IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
    IDE03912-MAS01405,Service -interval- display: history 2-Block 16,FF FF FF FF,
    IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
    IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
    IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
    IDE03913-MAS01393,Service -interval- display: history 3-Block 4,FF FF FF FF,
    IDE03913-MAS01394,Service -interval- display: history 3-Block 5,FF FF FF FF,
    IDE03913-MAS01395,Service -interval- display: history 3-Block 6,FF FF FF FF,
    IDE03913-MAS01396,Service -interval- display: history 3-Block 7,FF FF FF FF,
    IDE03913-MAS01397,Service -interval- display: history 3-Block 8,FF FF FF FF,
    IDE03913-MAS01398,Service -interval- display: history 3-Block 9,FF FF FF FF,
    IDE03913-MAS01399,Service -interval- display: history 3-Block 10,FF FF FF FF,
    IDE03913-MAS01400,Service -interval- display: history 3-Block 11,FF FF FF FF,
    IDE03913-MAS01401,Service -interval- display: history 3-Block 12,FF FF FF FF,
    IDE03913-MAS01402,Service -interval- display: history 3-Block 13,FF FF FF FF,
    IDE03913-MAS01403,Service -interval- display: history 3-Block 14,FF FF FF FF,
    IDE03913-MAS01404,Service -interval- display: history 3-Block 15,FF FF FF FF,
    IDE03913-MAS01405,Service -interval- display: history 3-Block 16,FF FF FF FF,
    IDE03914-MAS01390,Service -interval- display: history 4-Block 1,FF FF FF FF,
    IDE03914-MAS01391,Service -interval- display: history 4-Block 2,FF FF FF FF,
    IDE03914-MAS01392,Service -interval- display: history 4-Block 3,FF FF FF FF,
    IDE03914-MAS01393,Service -interval- display: history 4-Block 4,FF FF FF FF,
    IDE03914-MAS01394,Service -interval- display: history 4-Block 5,FF FF FF FF,
    IDE03914-MAS01395,Service -interval- display: history 4-Block 6,FF FF FF FF,
    IDE03914-MAS01396,Service -interval- display: history 4-Block 7,FF FF FF FF,
    IDE03914-MAS01397,Service -interval- display: history 4-Block 8,FF FF FF FF,
    IDE03914-MAS01398,Service -interval- display: history 4-Block 9,FF FF FF FF,
    IDE03914-MAS01399,Service -interval- display: history 4-Block 10,FF FF FF FF,
    IDE03914-MAS01400,Service -interval- display: history 4-Block 11,FF FF FF FF,
    IDE03914-MAS01401,Service -interval- display: history 4-Block 12,FF FF FF FF,
    IDE03914-MAS01402,Service -interval- display: history 4-Block 13,FF FF FF FF,
    IDE03914-MAS01403,Service -interval- display: history 4-Block 14,FF FF FF FF,
    IDE03914-MAS01404,Service -interval- display: history 4-Block 15,FF FF FF FF,
    IDE03914-MAS01405,Service -interval- display: history 4-Block 16,FF FF FF FF,
    IDE04649-MAS06857,Activation for housing fan-Speed,0, /min
    IDE04649-ENG128738,Activation for housing fan-PWM_FAN,0, %
    IDE04649-ENG128737,Activation for housing fan-source_max_PWM_requested,none,
    IDE04649-ENG98933,Activation for housing fan-Status,OFF,
    IDE04649-ENG128733,Activation for housing fan-temperature_Boost,60, ∞C
    IDE04649-ENG128734,Activation for housing fan-temperature_chipled,92, ∞C
    IDE04649-ENG128736,Activation for housing fan-temperature_GPU,63, ∞C
    IDE04649-ENG128735,Activation for housing fan-temperature_KI,60, ∞C
    IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
    IDE06425-IDE06026,Roller test bench mode: functional-Adaptation of brake pedal path sensor,not activated,
    IDE06592-MAS05002,Status: special functions-Showroom mode,OFF,
    IDE06592-MAS05003,Status: special functions-Debug functions,OFF,
    IDE06924,Performance display,0,
    IDE07145-MAS06772,Component protection properties-Component protection generation,02,
    IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,02,
    IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,00,
    IDE07145-MAS06775,Component protection properties-KS Standard software correct number,01,
    IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
    IDE07145-MAS06781,Component protection properties-Secure Hardware Extension,used,
    IDE07145-MAS06782,Component protection properties-Master ECU Key,administered by component protection,
    IDE07145-MAS06785,Component protection properties-GFA key,used,
    IDE07145-MAS06786,Component protection properties-SSW RND Generation,Not Used,
    IDE07145-MAS06787,Component protection properties-Indiv Key Generation,used,
    IDE07145-MAS06788,Component protection properties-SHE Secure Boot,Not Used,
    IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
    IDE07145-MAS07187,Component protection properties-KS Data version,01,
    IDE07159-MAS01155,Control module switch-off: counter-Control module,0, min
    IDE07159-MAS05583,Control module switch-off: counter-Data bus,0, min
    IDE07578-MAS00138,Operating range consumption with electric drive-1,0.00,
    IDE07578-MAS00139,Operating range consumption with electric drive-2,65534,
    IDE07578-ENG04221,Operating range consumption with electric drive-ERW_Energieinhalt,0.00,
    IDE07578-ENG114651,Operating range consumption with electric drive-s_erw_rw_batterie,65534, km
    IDE07578-ENG114652,Operating range consumption with electric drive-s_erw_rw_batterie_anz,65534, km
    IDE07578-ENG114648,Operating range consumption with electric drive-s_erw_rwds,0.00, A
    IDE07578-ENG114640,Operating range consumption with electric drive-s_erw_rwds_high,10.00, A
    IDE07578-ENG114644,Operating range consumption with electric drive-s_erw_rwds_low,10.00, A
    IDE07578-ENG114637,Operating range consumption with electric drive-s_erw_rwdv_antrieb_high_unclass,2.50, kWh/100 km
    IDE07578-ENG114641,Operating range consumption with electric drive-s_erw_rwdv_antrieb_low_unclass,25.00,
    IDE07578-ENG114645,Operating range consumption with electric drive-s_erw_rwdv_antrieb_unclass,0.00,
    IDE07578-ENG114638,Operating range consumption with electric drive-s_erw_rwdv_dcdc_high_unclass,0.20, kWh/100 km
    IDE07578-ENG114642,Operating range consumption with electric drive-s_erw_rwdv_dcdc_low_unclass,0.20,
    IDE07578-ENG114646,Operating range consumption with electric drive-s_erw_rwdv_dcdc_unclass,0.00,
    IDE07578-ENG114639,Operating range consumption with electric drive-s_erw_rwdv_tme_high_unclass,0.50,
    IDE07578-ENG114643,Operating range consumption with electric drive-s_erw_rwdv_tme_low_unclass,0.50,
    IDE07578-ENG114647,Operating range consumption with electric drive-s_erw_rwdv_tme_unclass,0.00,
    IDE07578-ENG114649,Operating range consumption with electric drive-s_erw_rwdv_unclass,0.00,
    IDE07646-ENG114675,Consumption for road-specif. range with electric drive-s_erw_endsteigung,0.00, %
    IDE07646-ENG114667,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_0,0.00, kWh/100 km
    IDE07646-ENG114668,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_1,0.00, kWh/100 km
    IDE07646-ENG114669,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_2,0.00, kWh/100 km
    IDE07646-ENG114670,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_3,0.00, kWh/100 km
    IDE07646-ENG114671,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_4,0.00, kWh/100 km
    IDE07646-ENG114672,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_5,0.00, kWh/100 km
    IDE07646-ENG114673,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_6,0.00, kWh/100 km
    IDE07646-ENG114653,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_0,25.00, kWh/100 km
    IDE07646-ENG114654,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_1,25.00, kWh/100 km
    IDE07646-ENG114655,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_2,25.00, kWh/100 km
    IDE07646-ENG114656,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_3,25.00, kWh/100 km
    IDE07646-ENG114657,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_4,25.00, kWh/100 km
    IDE07646-ENG114658,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_5,25.00, kWh/100 km
    IDE07646-ENG114659,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_6,25.00, kWh/100 km
    IDE07646-ENG04222,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_low_class,25.00, kWh/100 km
    IDE07646-ENG114674,Consumption for road-specif. range with electric drive-s_erw_str_klasse,0,
    IDE08235-ENG118223,Status of immobilizer participant-ELV_State,F8,
    IDE08235-ENG118222,Status of immobilizer participant-GSG_State,F8,
    IDE08235-ENG118217,Status of immobilizer participant-Immobilizer_State,00,
    IDE08235-ENG118216,Status of immobilizer participant-key_state,1C,
    IDE08235-ENG118218,Status of immobilizer participant-MSG_1_State,F8,
    IDE08235-ENG118219,Status of immobilizer participant-MSG_2_State,00,
    IDE08235-ENG118220,Status of immobilizer participant-MSG_3_State,00,
    IDE08235-ENG118221,Status of immobilizer participant-MSG_4_State,00,
    IDE08236-ENG118224,Status locking periods immobilizer-blocking_time,00 00 00 00 00 00,
    IDE08239,Transponder ID Key 1,0A CD 8C FC,
    IDE08240,Transponder ID Key 2,0A CC A6 4A,
    IDE08252-ENG101043,Test sum of adapted transponder-Checksum,24 C2 68 B4,
    IDE08252-ENG99027,Test sum of adapted transponder-Version,01,
    IDE08343,Immobilizer Challenge,D4 46 E3 BA,
    IDE08701-MAS07266,ESI: Status-Oil change: unit of dist. travelled,Kilometers,
    IDE08701-MAS07267,ESI: Status-Oil change: dist. travelled,14600,
    IDE08701-MAS07268,ESI: Status-Oil change: stat. of dist. travelled,Service in,
    IDE08701-MAS07269,ESI: Status-Oil change: stat. of time,Service in,
    IDE08701-MAS07270,ESI: Status-Inspection: stat. of dist. travelled,Service in,
    IDE08701-MAS07271,ESI: Status-Inspection: unit of dist. travelled,Kilometers,
    IDE08701-MAS07272,ESI: Status-Inspection: dist. travelled,29600,
    IDE08701-MAS07273,ESI: Status-Inspection: time,711,
    IDE08701-MAS07274,ESI: Status-Oil change warning,no warning,
    IDE08701-MAS07277,ESI: Status-Inspections warning,no warning,
    IDE08701-MAS07305,ESI: Status-Oil change: time,346,
    IDE08701-MAS07308,ESI: Status-Inspection: status time,Service in,
    IDE08701-MAS10768,ESI: Status-Daily mileage,100,
    MAS00077-ENG99298,Immobilizer-State,02 01 03 C7 02 00 00 00 01 00,
    MAS03121,Ring break diagnostic line status,Supply voltage,
    ENG126262-ENG114675,Consumption_for_distance_on_map-s_erw_endsteigung,0.00, %
    ENG126262-ENG114674,Consumption_for_distance_on_map-s_erw_str_klasse,0,
    ENG126262-ENG128739,Consumption_for_distance_on_map-s_vkmrw_rwdv_antrieb_low_class,12.60, l/100km
    ENG126262-ENG126309,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_0,10.50, l/100km
    ENG126262-ENG126310,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_1,10.00, l/100km
    ENG126262-ENG126311,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_2,10.00, l/100km
    ENG126262-ENG126312,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_3,10.00, l/100km
    ENG126262-ENG126313,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_4,10.00, l/100km
    ENG126262-ENG126314,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_5,10.00, l/100km
    ENG126262-ENG126315,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_6,10.00, l/100km
    ENG126262-ENG126302,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_0,10.50, l/100km
    ENG126262-ENG126303,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_1,10.00, l/100km
    ENG126262-ENG126304,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_2,10.00, l/100km
    ENG126262-ENG126305,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_3,10.00, l/100km
    ENG126262-ENG126306,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_4,10.00, l/100km
    ENG126262-ENG126307,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_5,10.00, l/100km
    ENG126262-ENG126308,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_6,10.00, l/100km
    ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,203, %
    ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,100, %
    ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,100, %
    ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,100, %
    ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,100, %
    ENG106303-ENG99140,ESI_active_warning-advance_warning_fixed_days,not active,
    ENG106303-ENG100265,ESI_active_warning-advance_warning_fixed_km,not active,
    ENG106303-ENG101600,ESI_active_warning-advance_warning_WIV_days,not active,
    ENG106303-ENG102887,ESI_active_warning-advance_warning_WIV_km,not active,
    ENG106303-ENG99971,ESI_active_warning-in_calculation,not active,
    ENG106303-ENG101015,ESI_active_warning-no_calculation_available,not active,
    ENG106303-ENG101477,ESI_active_warning-service_warning_fixed_days,not active,
    ENG106303-ENG101550,ESI_active_warning-service_warning_fixed_km,not active,
    ENG106303-ENG101709,ESI_active_warning-service_warning_WIV_days,not active,
    ENG106303-ENG102993,ESI_active_warning-service_warning_WIV_km,not active,
    ENG119883,ESI_mileage_per_day,100, km
    ENG107920-ENG98868,onboard_computer-Range,458, km
    ENG107920-ENG119788,onboard_computer-range_average_consumption,9.40, l/100km
    ENG107920-ENG126296,onboard_computer-range_average_consumption_cng,0.00, kg/100 km
    ENG107920-ENG126292,onboard_computer-range_average_consumption_cng_high,0.00, kg/100 km
    ENG107920-ENG126294,onboard_computer-range_average_consumption_cng_low,0.00, kg/100 km
    ENG107920-ENG119789,onboard_computer-range_average_consumption_high,9.40, l/100km
    ENG107920-ENG119790,onboard_computer-range_average_consumption_low,11.40, l/100km
    ENG107920-ENG126297,onboard_computer-range_average_consumption_lpg,0.00, kg/100 km
    ENG107920-ENG126293,onboard_computer-range_average_consumption_lpg_high,0.00, kg/100 km
    ENG107920-ENG126295,onboard_computer-range_average_consumption_lpg_low,0.00, kg/100 km
    ENG107920-ENG126298,onboard_computer-range_cng,65534, km
    ENG107920-ENG126300,onboard_computer-range_cng_display_value,65534, km
    ENG107920-ENG119791,onboard_computer-range_display_value,458, km
    ENG107920-ENG126299,onboard_computer-range_lpg,65534, km
    ENG107920-ENG126301,onboard_computer-range_lpg_display_value,65534, km
    ENG107953-ENG100938,outside_temp_algorithm_group-coolant_temperature_outdated_bit,not active,
    ENG107953-ENG101136,outside_temp_algorithm_group-distance_threshold_not_yet_reached,active,
    ENG107953-ENG99778,outside_temp_algorithm_group-downward_tendency,not active,
    ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,not active,
    ENG107953-ENG102352,outside_temp_algorithm_group-ice_warning_symbol,not active,
    ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,active,
    ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,151,
    ENG107953-ENG99258,outside_temp_algorithm_group-outside_temperature_filtered_error_state_bit,not active,
    ENG107953-ENG102589,outside_temp_algorithm_group-outside_temperature_old,not active,
    ENG107953-ENG102387,outside_temp_algorithm_group-outside_temperature_raw_score_error_state_bit,not active,
    ENG119885-ENG103300,Service_Key_current_data-Service_Data,F7 DB 00 23 C1 C0 13 08 0A 16 13 2E F1 01 00 00 92 10 5B 11 28 11 C8 12 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 54 FF FF 00 00 41 00,
    ENG108927-ENG119819,Service_Key_Master_Counter-Counter_ID_Kessy,69,
    ENG108927-ENG119811,Service_Key_Master_Counter-Counter_Key_ID_1,0,
    ENG108927-ENG119812,Service_Key_Master_Counter-Counter_Key_ID_2,0,
    ENG108927-ENG119813,Service_Key_Master_Counter-Counter_Key_ID_3,0,
    ENG108927-ENG119814,Service_Key_Master_Counter-Counter_Key_ID_4,0,
    ENG108927-ENG119815,Service_Key_Master_Counter-Counter_Key_ID_5,0,
    ENG108927-ENG119816,Service_Key_Master_Counter-Counter_Key_ID_6,0,
    ENG108927-ENG119817,Service_Key_Master_Counter-Counter_Key_ID_7,0,
    ENG108927-ENG119818,Service_Key_Master_Counter-Counter_Key_ID_8,0,
    ENG108927-ENG119821,Service_Key_Master_Counter-Counter_Trigger,0,
    ENG108927-ENG119822,Service_Key_Master_Counter-Error_Counter,0,
    ENG108927-ENG119823,Service_Key_Master_Counter-Immo_Key,2,
    ENG108927-ENG119820,Service_Key_Master_Counter-Last_Key,ID_Kessy,
    ENG108927-ENG99298,Service_Key_Master_Counter-State,Engine_off,
    ENG126266-ENG119811,SK2_counter_per_day-Counter_Key_ID_1,0,
    ENG126266-ENG119812,SK2_counter_per_day-Counter_Key_ID_2,0,
    ENG126266-ENG119813,SK2_counter_per_day-Counter_Key_ID_3,0,
    ENG126266-ENG119814,SK2_counter_per_day-Counter_Key_ID_4,0,
    ENG126266-ENG119815,SK2_counter_per_day-Counter_Key_ID_5,0,
    ENG126266-ENG119816,SK2_counter_per_day-Counter_Key_ID_6,0,
    ENG126266-ENG119817,SK2_counter_per_day-Counter_Key_ID_7,0,
    ENG126266-ENG119818,SK2_counter_per_day-Counter_Key_ID_8,0,
    ENG126267-ENG126385,SK2_pointer_and_label-SK2_label,FF FF FF FF,
    ENG126267-ENG126382,SK2_pointer_and_label-Write_Pointer_Pos_1,65535,
    ENG126267-ENG126383,SK2_pointer_and_label-Write_Pointer_Pos_2,65535,
    ENG126267-ENG126384,SK2_pointer_and_label-Write_Pointer_Pos_3,65535,
    ENG126263-ENG126381,SK2_received_data_from_datalogger-SK2_data,16 6C 9D 00 01 01 FF FF 00 00 00 27 0B FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
    ENG126268-ENG126392,SK2_state-difference_SK2_data_SK-master_key,Yes,
    ENG126268-ENG126394,SK2_state-last_reveived_end_identification,no_end_identification_received,
    ENG126268-ENG126391,SK2_state-limitation_normal_request,not active,
    ENG126268-ENG126386,SK2_state-SK2_function,not active,
    ENG126268-ENG126389,SK2_state-state_immediate_request,not active,
    ENG126268-ENG126388,SK2_state-state_normal_request,not active,
    ENG126268-ENG126390,SK2_state-state_waiting_for_retry,not active,
    ENG126268-ENG126393,SK2_state-transfer_SK2_data_finished_within_timeout,Yes,
    ENG126268-ENG126387,SK2_state-trigger_normal_request,no_trigger,
    ENG109340-ENG104056,tank_validation-s_vali_abs_active,not active,
    ENG109340-ENG102652,tank_validation-s_vali_abs_display_0,not active,
    ENG109340-ENG102994,tank_validation-s_vali_abs_distance/mileage,not active,
    ENG109340-ENG101149,tank_validation-s_vali_abs_rough,not active,
    ENG109340-ENG101740,tank_validation-s_vali_active,not active,
    ENG109340-ENG101355,tank_validation-s_vali_consumption_deq,3276.80, l
    ENG109340-ENG100596,tank_validation-s_vali_consumption_deq_abs,3276.80, l
    ENG109340-ENG102770,tank_validation-s_vali_display_0,not active,
    ENG109340-ENG99133,tank_validation-s_vali_needle_vol_ref,not active,
    ENG109340-ENG99562,tank_validation-s_vali_rough,not active,
    ENG109340-ENG100160,tank_validation-s_vali_status,2, l
    ENG109340-ENG103691,tank_validation-s_vali_vol_delta_gef,3277.50, l
    ENG109340-ENG100615,tank_validation-s_vali_vol_delta_roh,3279.00, l
    ENG109340-ENG99506,tank_validation-s_vali_vol_g1_vg,3297.80, l
    ENG109340-ENG103928,tank_validation-s_vali_vol_g2_vg,3303.00, l
    ENG109340-ENG101476,tank_validation-s_vali_vol_g3_vg,3276.80, l
    ENG109340-ENG101237,tank_validation-s_vali_vol_g4_vg,3276.80, l
    ENG109340-ENG101103,tank_validation-s_vali_vol_ref_gew,3321.80, l
    ENG109340-ENG100543,tank_validation-s_vali_vol_ref_vg,3321.40, l
    ENG109340-ENG100079,tank_validation-s_vali_vol_total_vg,3324.00, l
    Elapsed Time: 00:59
  2. #12
    Aug 2019
    Toronto, Canada
    19 - CAN Gateway
    ADPmap - 19 - CAN Gateway
    ;SW:3Q0-907-530-AA   HW:3Q0-907-530-C ---  CAN Gateway
    ;Component:GW MQB High   442 4368, Coding:0301000434085D005B00801EB80B00000001010000000000000000000000
    ;EV_GatewNF,013025,EV_GatewNF.rod
    ;Sunday,11,August,2019,16:11:24:40778
    ;VCID: 6E9002AAB1084F3F7B-803A
    IDE00001-ENG124491-Production mode-p_mode_deactivate_mfl_keys,Deactivating ,3
    IDE00001-ENG118694-Production mode-p_mode_deactivate_recuperation,Deactivating ,3
    IDE00002-Transport mode,not active ,1
    IDE01211-Static current measuring mode,not activated ,1
    IDE01457-Energy management deactivation stage,Mode not active ,1
    IDE01459-Energy management heat output control status,Mode not active ,1
    IDE01844-Increase idle speed request,Mode not active ,1
    IDE01847-ENG118685-Auxiliary heater activation restriction request-Set_point_target_time,-- ,3
    IDE01847-ENG118684-Auxiliary heater activation restriction request-Switch_on_ban_activation,Mode not active ,3
    IDE01860-Generator specified voltage value variable,10.6 V,1
    IDE01996-SFT00001-Installation list: specified installations-Engine Control Module 1,coded ,32
    IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module,coded ,32
    IDE01996-SFT00003-Installation list: specified installations-Brakes 1,coded ,32
    IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side,Not coded ,32
    IDE01996-SFT00008-Installation list: specified installations-Air Conditioning,coded ,32
    IDE01996-SFT00009-Installation list: specified installations-Central Electrics,coded ,32
    IDE01996-SFT00011-Installation list: specified installations-Auxiliary Air Heater,Not coded ,32
    IDE01996-SFT00014-Installation list: specified installations-Media Player Position 1,Not coded ,32
    IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control,coded ,32
    IDE01996-SFT00020-Installation list: specified installations-Wheel Dampening Electronics,coded ,32
    IDE01996-SFT00021-Installation list: specified installations-Airbag,coded ,32
    IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics,Not coded ,32
    IDE01996-SFT00023-Installation list: specified installations-Dash Board,coded ,32
    IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater,Not coded ,32
    IDE01996-SFT00025-Installation list: specified installations-Gateway,1 ,32
    IDE01996-SFT00028-Installation list: specified installations-Vehicle Position Detection,Not coded ,32
    IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance,Not coded ,32
    IDE01996-SFT00033-Installation list: specified installations-Battery Energy Control Module 2,Not coded ,32
    IDE01996-SFT00034-Installation list: specified installations-All Wheel Control,coded ,32
    IDE01996-SFT00035-Installation list: specified installations-Brake Boost,Not coded ,32
    IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control,Not coded ,32
    IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking,coded ,32
    IDE01996-SFT00048-Installation list: specified installations-Special Function 2,Not coded ,32
    IDE01996-SFT00050-Installation list: specified installations-Lock Electronics,Not coded ,32
    IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side,Not coded ,32
    IDE01996-SFT00060-Installation list: specified installations-Lane Change Assistant,coded ,32
    IDE01996-SFT00061-Installation list: specified installations-Special Function,Not coded ,32
    IDE01996-SFT00064-Installation list: specified installations-Air Conditioning Compressor,Not coded ,32
    IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side,coded ,32
    IDE01996-SFT00068-Installation list: specified installations-Steering Assistance,coded ,32
    IDE01996-SFT00071-Installation list: specified installations-Sound System,Not coded ,32
    IDE01996-SFT00075-Installation list: specified installations-Multifunction module,coded ,32
    IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module,Not coded ,32
    IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side,coded ,32
    IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation,Not coded ,32
    IDE01996-SFT00086-Installation list: specified installations-Radio,Not coded ,32
    IDE01996-SFT00087-Installation list: specified installations-TV Tuner,Not coded ,32
    IDE01996-SFT00095-Installation list: specified installations-Information Control Unit 1,coded ,32
    IDE01996-SFT00096-Installation list: specified installations-Tachograph,Not coded ,32
    IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1,Not coded ,32
    IDE01996-SFT00105-Installation list: specified installations-Trailer Function,Not coded ,32
    IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View,coded ,32
    IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit,Not coded ,32
    IDE01996-SFT00117-Installation list: specified installations-Telematics Communication Unit,Not coded ,32
    IDE01996-SFT00118-Installation list: specified installations-Parking Assistance,coded ,32
    IDE01996-SFT00128-Installation list: specified installations-Battery Regulation Auxiliary Accumulator 1,Not coded ,32
    IDE01996-SFT00130-Installation list: specified installations-Head Up Display,Not coded ,32
    IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module,Not coded ,32
    IDE01996-SFT00165-Installation list: specified installations-Front Sensors Driver Assistance System,coded ,32
    IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit,Not coded ,32
    IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound,Not coded ,32
    IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface,coded ,32
    IDE01996-SFT00187-Installation list: specified installations-Door Electronics Rear Driver Side,Not coded ,32
    IDE01996-SFT00188-Installation list: specified installations-Door Electronics Rear Passenger Side,Not coded ,32
    IDE01996-SFT00189-Installation list: specified installations-High Voltage Battery Charge Management,Not coded ,32
    IDE01996-SFT00190-Installation list: specified installations-Sliding Door Rear Left,Not coded ,32
    IDE01996-SFT00191-Installation list: specified installations-Sliding Door Rear Right,Not coded ,32
    IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise,Not coded ,32
    IDE01996-SFT00197-Installation list: specified installations-Thermal management,Not coded ,32
    IDE01996-SFT00198-Installation list: specified installations-Battery Charger Control Module,Not coded ,32
    IDE01996-SFT00202-Installation list: specified installations-Control module for sunroof,Not coded ,32
    IDE01996-SFT00204-Installation list: specified installations-Starter / Generator Control Module,Not coded ,32
    IDE01996-SFT00207-Installation list: specified installations-Control Unit Lane Change Assistant 2,coded ,32
    IDE01996-ENG118226-Installation list: specified installations-Node_0x01,Not coded ,32
    IDE01996-ENG118227-Installation list: specified installations-Node_0x02,Not coded ,32
    IDE01996-ENG118228-Installation list: specified installations-Node_0x03,Not coded ,32
    IDE01996-ENG118229-Installation list: specified installations-Node_0x04,Not coded ,32
    IDE01996-ENG118230-Installation list: specified installations-Node_0x05,Not coded ,32
    IDE01996-ENG118231-Installation list: specified installations-Node_0x06,Not coded ,32
    IDE01996-ENG118232-Installation list: specified installations-Node_0x07,Not coded ,32
    IDE01996-ENG118233-Installation list: specified installations-Node_0x08,Not coded ,32
    IDE01996-ENG118235-Installation list: specified installations-Node_0x0D,Not coded ,32
    IDE01996-ENG118236-Installation list: specified installations-Node_0x11,Not coded ,32
    IDE01996-ENG118237-Installation list: specified installations-Node_0x16,Not coded ,32
    IDE01996-ENG118238-Installation list: specified installations-Node_0x17,Not coded ,32
    IDE01996-ENG118239-Installation list: specified installations-Node_0x1A,Not coded ,32
    IDE01996-ENG118241-Installation list: specified installations-Node_0x1D,Not coded ,32
    IDE01996-ENG118242-Installation list: specified installations-Node_0x1F,Not coded ,32
    IDE01996-ENG118243-Installation list: specified installations-Node_0x20,Not coded ,32
    IDE01996-ENG118244-Installation list: specified installations-Node_0x21,Not coded ,32
    IDE01996-ENG118245-Installation list: specified installations-Node_0x22,Not coded ,32
    IDE01996-ENG118246-Installation list: specified installations-Node_0x24,Not coded ,32
    IDE01996-ENG118247-Installation list: specified installations-Node_0x25,Not coded ,32
    IDE01996-ENG118248-Installation list: specified installations-Node_0x26,Not coded ,32
    IDE01996-ENG118249-Installation list: specified installations-Node_0x27,Not coded ,32
    IDE01996-ENG118250-Installation list: specified installations-Node_0x28,Not coded ,32
    IDE01996-ENG118251-Installation list: specified installations-Node_0x29,Not coded ,32
    IDE01996-ENG118252-Installation list: specified installations-Node_0x2A,Not coded ,32
    IDE01996-ENG118253-Installation list: specified installations-Node_0x2E,Not coded ,32
    IDE01996-ENG118254-Installation list: specified installations-Node_0x2F,Not coded ,32
    IDE01996-ENG118255-Installation list: specified installations-Node_0x35,Not coded ,32
    IDE01996-ENG118256-Installation list: specified installations-Node_0x36,Not coded ,32
    IDE01996-ENG118257-Installation list: specified installations-Node_0x37,Not coded ,32
    IDE01996-ENG118258-Installation list: specified installations-Node_0x38,Not coded ,32
    IDE01996-ENG118259-Installation list: specified installations-Node_0x39,Not coded ,32
    IDE01996-ENG118260-Installation list: specified installations-Node_0x3A,Not coded ,32
    IDE01996-ENG118261-Installation list: specified installations-Node_0x3C,Not coded ,32
    IDE01996-ENG118262-Installation list: specified installations-Node_0x3D,Not coded ,32
    IDE01996-ENG118263-Installation list: specified installations-Node_0x40,Not coded ,32
    IDE01996-ENG118264-Installation list: specified installations-Node_0x41,Not coded ,32
    IDE01996-ENG118265-Installation list: specified installations-Node_0x43,Not coded ,32
    IDE01996-ENG118266-Installation list: specified installations-Node_0x45,Not coded ,32
    IDE01996-ENG118267-Installation list: specified installations-Node_0x48,Not coded ,32
    IDE01996-ENG118268-Installation list: specified installations-Node_0x49,Not coded ,32
    IDE01996-ENG118269-Installation list: specified installations-Node_0x51,Not coded ,32
    IDE01996-ENG118270-Installation list: specified installations-Node_0x52,Not coded ,32
    IDE01996-ENG118271-Installation list: specified installations-Node_0x53,Not coded ,32
    IDE01996-ENG118272-Installation list: specified installations-Node_0x55,Not coded ,32
    IDE01996-ENG118273-Installation list: specified installations-Node_0x56,Not coded ,32
    IDE01996-ENG118274-Installation list: specified installations-Node_0x58,Not coded ,32
    IDE01996-ENG118275-Installation list: specified installations-Node_0x59,Not coded ,32
    IDE01996-ENG118276-Installation list: specified installations-Node_0x5A,Not coded ,32
    IDE01996-ENG118277-Installation list: specified installations-Node_0x5B,Not coded ,32
    IDE01996-ENG118278-Installation list: specified installations-Node_0x5C,Not coded ,32
    IDE01996-ENG118279-Installation list: specified installations-Node_0x5D,Not coded ,32
    IDE01996-ENG118280-Installation list: specified installations-Node_0x5E,Not coded ,32
    IDE01996-ENG118281-Installation list: specified installations-Node_0x5F,Not coded ,32
    IDE01996-ENG118282-Installation list: specified installations-Node_0x60,Not coded ,32
    IDE01996-ENG118283-Installation list: specified installations-Node_0x61,Not coded ,32
    IDE01996-ENG118284-Installation list: specified installations-Node_0x62,Not coded ,32
    IDE01996-ENG118285-Installation list: specified installations-Node_0x66,Not coded ,32
    IDE01996-ENG118286-Installation list: specified installations-Node_0x68,Not coded ,32
    IDE01996-ENG118287-Installation list: specified installations-Node_0x6B,Not coded ,32
    IDE01996-ENG118288-Installation list: specified installations-Node_0x6C,Not coded ,32
    IDE01996-ENG118289-Installation list: specified installations-Node_0x6E,Not coded ,32
    IDE01996-ENG118290-Installation list: specified installations-Node_0x74,Not coded ,32
    IDE01996-ENG118291-Installation list: specified installations-Node_0x75,Not coded ,32
    IDE01996-ENG118292-Installation list: specified installations-Node_0x78,Not coded ,32
    IDE01996-ENG118293-Installation list: specified installations-Node_0x79,Not coded ,32
    IDE01996-ENG118294-Installation list: specified installations-Node_0x7A,Not coded ,32
    IDE01996-ENG118295-Installation list: specified installations-Node_0x7D,Not coded ,32
    IDE01996-ENG118296-Installation list: specified installations-Node_0x7E,Not coded ,32
    IDE01996-ENG118297-Installation list: specified installations-Node_0x7F,Not coded ,32
    IDE01996-ENG118298-Installation list: specified installations-Node_0x80,Not coded ,32
    IDE01996-ENG118299-Installation list: specified installations-Node_0x81,Not coded ,32
    IDE01996-ENG118300-Installation list: specified installations-Node_0x82,Not coded ,32
    IDE01996-ENG118301-Installation list: specified installations-Node_0x83,Not coded ,32
    IDE01996-ENG118303-Installation list: specified installations-Node_0x86,Not coded ,32
    IDE01996-ENG118304-Installation list: specified installations-Node_0x87,Not coded ,32
    IDE01996-ENG118305-Installation list: specified installations-Node_0x88,Not coded ,32
    IDE01996-ENG118306-Installation list: specified installations-Node_0x89,Not coded ,32
    IDE01996-ENG118307-Installation list: specified installations-Node_0x8B,Not coded ,32
    IDE01996-ENG118308-Installation list: specified installations-Node_0x8C,Not coded ,32
    IDE01996-ENG118309-Installation list: specified installations-Node_0x8D,Not coded ,32
    IDE01996-ENG118310-Installation list: specified installations-Node_0x8E,Not coded ,32
    IDE01996-ENG118311-Installation list: specified installations-Node_0x8F,Not coded ,32
    IDE01996-ENG118312-Installation list: specified installations-Node_0x90,Not coded ,32
    IDE01996-ENG118313-Installation list: specified installations-Node_0x91,Not coded ,32
    IDE01996-ENG118314-Installation list: specified installations-Node_0x92,Not coded ,32
    IDE01996-ENG118315-Installation list: specified installations-Node_0x93,Not coded ,32
    IDE01996-ENG118316-Installation list: specified installations-Node_0x94,Not coded ,32
    IDE01996-ENG118317-Installation list: specified installations-Node_0x95,Not coded ,32
    IDE01996-ENG118318-Installation list: specified installations-Node_0x96,Not coded ,32
    IDE01996-ENG118319-Installation list: specified installations-Node_0x97,Not coded ,32
    IDE01996-ENG118320-Installation list: specified installations-Node_0x98,Not coded ,32
    IDE01996-ENG118321-Installation list: specified installations-Node_0x99,Not coded ,32
    IDE01996-ENG118322-Installation list: specified installations-Node_0x9A,Not coded ,32
    IDE01996-ENG118323-Installation list: specified installations-Node_0x9B,Not coded ,32
    IDE01996-ENG118325-Installation list: specified installations-Node_0x9D,Not coded ,32
    IDE01996-ENG118326-Installation list: specified installations-Node_0x9E,Not coded ,32
    IDE01996-ENG118327-Installation list: specified installations-Node_0x9F,Not coded ,32
    IDE01996-ENG118328-Installation list: specified installations-Node_0xA0,Not coded ,32
    IDE01996-ENG118329-Installation list: specified installations-Node_0xA1,Not coded ,32
    IDE01996-ENG118330-Installation list: specified installations-Node_0xA2,Not coded ,32
    IDE01996-ENG118331-Installation list: specified installations-Node_0xA3,Not coded ,32
    IDE01996-ENG118333-Installation list: specified installations-Node_0xA5,Not coded ,32
    IDE01996-ENG118334-Installation list: specified installations-Node_0xA6,Not coded ,32
    IDE01996-ENG118335-Installation list: specified installations-Node_0xA7,Not coded ,32
    IDE01996-ENG118336-Installation list: specified installations-Node_0xA8,Not coded ,32
    IDE01996-ENG118338-Installation list: specified installations-Node_0xAA,Not coded ,32
    IDE01996-ENG118339-Installation list: specified installations-Node_0xAB,Not coded ,32
    IDE01996-ENG118340-Installation list: specified installations-Node_0xAC,Not coded ,32
    IDE01996-ENG118341-Installation list: specified installations-Node_0xAD,Not coded ,32
    IDE01996-ENG118343-Installation list: specified installations-Node_0xAF,Not coded ,32
    IDE01996-ENG118344-Installation list: specified installations-Node_0xB0,Not coded ,32
    IDE01996-ENG118345-Installation list: specified installations-Node_0xB1,Not coded ,32
    IDE01996-ENG118346-Installation list: specified installations-Node_0xB2,Not coded ,32
    IDE01996-ENG118347-Installation list: specified installations-Node_0xB3,Not coded ,32
    IDE01996-ENG118348-Installation list: specified installations-Node_0xB4,Not coded ,32
    IDE01996-ENG118349-Installation list: specified installations-Node_0xB5,Not coded ,32
    IDE01996-ENG118350-Installation list: specified installations-Node_0xB6,Not coded ,32
    IDE01996-ENG118351-Installation list: specified installations-Node_0xB7,Not coded ,32
    IDE01996-ENG118352-Installation list: specified installations-Node_0xB8,Not coded ,32
    IDE01996-ENG118353-Installation list: specified installations-Node_0xB9,Not coded ,32
    IDE01996-ENG118354-Installation list: specified installations-Node_0xBA,Not coded ,32
    IDE01996-ENG118355-Installation list: specified installations-Node_0xBB,Not coded ,32
    IDE01996-ENG118356-Installation list: specified installations-Node_0xBC,Not coded ,32
    IDE01996-ENG118357-Installation list: specified installations-Node_0xBD,Not coded ,32
    IDE01996-ENG118358-Installation list: specified installations-Node_0xBE,Not coded ,32
    IDE01996-ENG118359-Installation list: specified installations-Node_0xBF,Not coded ,32
    IDE01996-ENG118360-Installation list: specified installations-Node_0xC0,Not coded ,32
    IDE01996-ENG118361-Installation list: specified installations-Node_0xC1,Not coded ,32
    IDE01996-ENG118362-Installation list: specified installations-Node_0xC2,Not coded ,32
    IDE01996-ENG118363-Installation list: specified installations-Node_0xC3,Not coded ,32
    IDE01996-ENG118364-Installation list: specified installations-Node_0xC4,Not coded ,32
    IDE01996-ENG118365-Installation list: specified installations-Node_0xC5,Not coded ,32
    IDE01996-ENG118366-Installation list: specified installations-Node_0xC6,Not coded ,32
    IDE01996-ENG118367-Installation list: specified installations-Node_0xC7,Not coded ,32
    IDE01996-ENG118368-Installation list: specified installations-Node_0xC8,Not coded ,32
    IDE01996-ENG118369-Installation list: specified installations-Node_0xC9,Not coded ,32
    IDE01996-ENG118370-Installation list: specified installations-Node_0xCA,Not coded ,32
    IDE01996-ENG118371-Installation list: specified installations-Node_0xCB,Not coded ,32
    IDE01996-ENG118372-Installation list: specified installations-Node_0xCC,Not coded ,32
    IDE01996-ENG118373-Installation list: specified installations-Node_0xCD,Not coded ,32
    IDE01996-ENG118374-Installation list: specified installations-Node_0xCE,Not coded ,32
    IDE01996-ENG118375-Installation list: specified installations-Node_0xCF,Not coded ,32
    IDE01996-ENG118376-Installation list: specified installations-Node_0xD0,Not coded ,32
    IDE01996-ENG118377-Installation list: specified installations-Node_0xD1,Not coded ,32
    IDE01996-ENG118378-Installation list: specified installations-Node_0xD2,Not coded ,32
    IDE01996-ENG118379-Installation list: specified installations-Node_0xD3,Not coded ,32
    IDE01996-ENG118380-Installation list: specified installations-Node_0xD4,Not coded ,32
    IDE01996-ENG118381-Installation list: specified installations-Node_0xD5,Not coded ,32
    IDE01996-ENG118382-Installation list: specified installations-Node_0xD6,Not coded ,32
    IDE01996-ENG118383-Installation list: specified installations-Node_0xD7,Not coded ,32
    IDE01996-ENG118384-Installation list: specified installations-Node_0xD8,Not coded ,32
    IDE01996-ENG118385-Installation list: specified installations-Node_0xD9,Not coded ,32
    IDE01996-ENG118386-Installation list: specified installations-Node_0xDA,Not coded ,32
    IDE01996-ENG118387-Installation list: specified installations-Node_0xDB,Not coded ,32
    IDE01996-ENG118388-Installation list: specified installations-Node_0xDC,Not coded ,32
    IDE01996-ENG118389-Installation list: specified installations-Node_0xDD,Not coded ,32
    IDE01996-ENG118390-Installation list: specified installations-Node_0xDE,Not coded ,32
    IDE01996-ENG118391-Installation list: specified installations-Node_0xDF,Not coded ,32
    IDE01996-ENG118392-Installation list: specified installations-Node_0xE0,Not coded ,32
    IDE01996-ENG118393-Installation list: specified installations-Node_0xE1,Not coded ,32
    IDE01996-ENG118394-Installation list: specified installations-Node_0xE2,Not coded ,32
    IDE01996-ENG118395-Installation list: specified installations-Node_0xE3,Not coded ,32
    IDE01996-ENG118396-Installation list: specified installations-Node_0xE4,Not coded ,32
    IDE01996-ENG118397-Installation list: specified installations-Node_0xE5,Not coded ,32
    IDE01996-ENG118398-Installation list: specified installations-Node_0xE6,Not coded ,32
    IDE01996-ENG118399-Installation list: specified installations-Node_0xE7,Not coded ,32
    IDE01996-ENG118400-Installation list: specified installations-Node_0xE8,Not coded ,32
    IDE01996-ENG118401-Installation list: specified installations-Node_0xE9,Not coded ,32
    IDE01996-ENG118402-Installation list: specified installations-Node_0xEA,Not coded ,32
    IDE01996-ENG118403-Installation list: specified installations-Node_0xEB,Not coded ,32
    IDE01996-ENG118404-Installation list: specified installations-Node_0xEC,Not coded ,32
    IDE01996-ENG118405-Installation list: specified installations-Node_0xED,Not coded ,32
    IDE01996-ENG118406-Installation list: specified installations-Node_0xEE,Not coded ,32
    IDE01996-ENG118407-Installation list: specified installations-Node_0xEF,Not coded ,32
    IDE01996-ENG118408-Installation list: specified installations-Node_0xF0,Not coded ,32
    IDE01996-ENG118409-Installation list: specified installations-Node_0xF1,Not coded ,32
    IDE01996-ENG118410-Installation list: specified installations-Node_0xF2,Not coded ,32
    IDE01996-ENG118411-Installation list: specified installations-Node_0xF3,Not coded ,32
    IDE01996-ENG118412-Installation list: specified installations-Node_0xF4,Not coded ,32
    IDE01996-ENG118413-Installation list: specified installations-Node_0xF5,Not coded ,32
    IDE01996-ENG118414-Installation list: specified installations-Node_0xF6,Not coded ,32
    IDE01996-ENG118415-Installation list: specified installations-Node_0xF7,Not coded ,32
    IDE01996-ENG118416-Installation list: specified installations-Node_0xF8,Not coded ,32
    IDE01996-ENG118417-Installation list: specified installations-Node_0xF9,Not coded ,32
    IDE01996-ENG118418-Installation list: specified installations-Node_0xFA,Not coded ,32
    IDE01996-ENG118419-Installation list: specified installations-Node_0xFB,Not coded ,32
    IDE01996-ENG118420-Installation list: specified installations-Node_0xFC,Not coded ,32
    IDE01996-ENG118421-Installation list: specified installations-Node_0xFD,Not coded ,32
    IDE01996-ENG118422-Installation list: specified installations-Node_0xFE,Not coded ,32
    IDE01996-ENG118423-Installation list: specified installations-Node_0xFF,Not coded ,32
    IDE03256-MAS06105-Battery adaptation-Rated battery capacity,75 Ah,15
    IDE03256-MAS06106-Battery adaptation-Battery technology,Fleece ,15
    IDE03256-MAS06107-Battery adaptation-Battery manufacturer,JCB ,15
    IDE03256-MAS06108-Battery adaptation-Battery Serial Number,3906055202 ,15
    IDE03903-Production process data 1,0A AA ,2
    IDE04159-Deactivation of start-stop function,Mode not active ,1
    IDE04186-Battery terminal recognition,connected ,1
    IDE04330-Transfer of release code for a SWaP function,00 ,1
    IDE06530-Distance left for deactivation of static current measuring mode,2 ,1
    IDE06541-Distance left for deactivation of transport mode,50 ,1
    IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroof,activated ,4
    IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,activated ,4
    IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start,activated ,4
    IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch),activated ,4
    IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system,activated ,4
    IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system,activated ,4
    IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroof,activated ,4
    IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D,not activated ,4
    IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill,activated ,4
    IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),activated ,4
    IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill,activated ,4
    IDE06753-MAS06289-Efficiency program display-Comfort use A/C,activated ,4
    IDE06753-MAS06290-Efficiency program display-Comfort use parking heater,activated ,4
    IDE06753-MAS06291-Efficiency program display-Comfort use rear window heater,activated ,4
    IDE06753-MAS06292-Efficiency program display-Comfort use front seat heater,activated ,4
    IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilation,activated ,4
    IDE06753-MAS06294-Efficiency program display-Comfort use rear heater,activated ,4
    IDE06753-MAS06295-Efficiency program display-Comfort use fog light,not activated ,4
    IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light,activated ,4
    IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emission,activated ,4
    IDE06753-MAS06298-Efficiency program display-Comfort use windshield heater,activated ,4
    IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,activated ,4
    IDE06753-MAS06300-Efficiency program display-Comfort use mirror heater,activated ,4
    IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater,activated ,4
    IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation,activated ,4
    IDE06753-MAS14430-Efficiency program display-Dependence of ECO tips on driver profile selection,ECO tips only in ECO mode ,4
    IDE06753-MAS19094-Efficiency program display-Rear A/C System blower convenience consumption,activated ,4
    IDE06753-MAS19095-Efficiency program display-Convenience consumption outer mirror heater dependency,Until temperature threshold: with after-run: with switch ,4
    IDE07838-Counter for inconsistent states,0 ,2
    IDE08348-Start/stop start voltage limit,7.6 V,1
    IDE08624-MKE Check box,activated ,1
    IDE10735-Number requests autonomous recharging,3 ,1
    IDE10736-Cyclization limitation request battery service,0 ,1
    IDE10748-MAS11262-Range gain-Range gain AC system,not activated ,3
    IDE10748-MAS11263-Range gain-Range gain auxiliary heater,not activated ,3
    IDE10748-MAS11264-Range gain-Range gain window defogger,not activated ,3
    IDE10748-MAS11265-Range gain-Range gain seat heater front,not activated ,3
    IDE10748-MAS11266-Range gain-Range gain front set ventilation,not activated ,3
    IDE10748-MAS11267-Range gain-Range gain rear heater,not activated ,3
    IDE10748-MAS11268-Range gain-Range gain fog light,not activated ,3
    IDE10748-MAS11269-Range gain-Range gain rear fog light,not activated ,3
    IDE10748-MAS11270-Range gain-Range gain windshield heating,not activated ,3
    IDE10748-MAS11271-Range gain-Range gain steering wheel heater,not activated ,3
    IDE10748-MAS11272-Range gain-Range gain mirror heater,not activated ,3
    IDE10748-MAS11273-Range gain-Range gain rear seat heater,not activated ,3
    IDE10748-MAS11274-Range gain-Range gain rear seat heater,not activated ,3
    IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system,activated ,3
    IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system,not activated ,3
    IDE10748-MAS11277-Range gain-PTC(low voltage) consumption,activated ,3
    IDE10748-MAS11278-Range gain-PTC(low voltage) range gain,activated ,3
    IDE10748-MAS11279-Range gain-List at engine still stand,activated ,3
    IDE10748-MAS12689-Range gain-Catalogue range display,not activated ,3
    IDE10748-MAS12690-Range gain-Loading condition catalogue range display,not activated ,3
    IDE10748-MAS13161-Range gain-List display absolute values ??with weighting,not activated ,3
    IDE10748-MAS19099-Range gain-Convenience consumption socket,activated ,3
    IDE10748-MAS19100-Range gain-A/C System blower manual convenience consumption,not activated ,3
    IDE10748-MAS19132-Range gain-Outer mirror heater consumption in rear window heating,not activated ,3
    IDE11689-48V-System: locking,regular operation ,1
    IDE13756-Diagnosis filter: activation,active ,1
    IDE13757-MAS16868-Diagnosis filter: kilometer thresholds-Kilometer threshold: production,200 km,2
    IDE13757-MAS16869-Diagnosis filter: kilometer thresholds-Kilometer threshold: customer service,20 km,2
    MAS16372-Security version number,2 ,2
    ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,active ,12
    ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,120 ,12
    ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,60000 ms,12
    ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,10000 ms,12
    ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,3000 ms,12
    ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms,12
    ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,180000 ms,12
    ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,500 ms,12
    ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,800 ms,12
    ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,6000 ms,12
    ENG137060-ENG113874-EM_energy_management_warning_displays-Batteriemeldungen,Mode not active ,4
    ENG137060-ENG98711-EM_energy_management_warning_displays-Charge level,Mode not active ,4
    ENG137060-ENG113873-EM_energy_management_warning_displays-Generatormeldungen,Mode not active ,4
    ENG137060-ENG118686-EM_energy_management_warning_displays-MMI Vorwarnungen,Mode not active ,4
    ENG137075-EM_heating_power_quota_adjustment,1000 W,1
    ENG137061-EM_nominal_voltage_limitation_low_beams,12.1 V,1
    ENG137064-EM_requirement_cyclic_time_voltage_measurement,0 s,1
    ENG137063-EM_requirement_reduction_air_blowers,Mode not active ,1
    ENG137058-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Control Module 1,Enabled ,32
    ENG137058-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Control Module,Enabled ,32
    ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brakes 1,not enabled ,32
    ENG137058-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Passenger Side,Enabled ,32
    ENG137058-SFT00008-GW_Enable_CAN_Timeout_DTC-Air Conditioning,Enabled ,32
    ENG137058-SFT00009-GW_Enable_CAN_Timeout_DTC-Central Electrics,Enabled ,32
    ENG137058-SFT00011-GW_Enable_CAN_Timeout_DTC-Auxiliary Air Heater,Enabled ,32
    ENG137058-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player Position 1,Enabled ,32
    ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control,Enabled ,32
    ENG137058-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Dampening Electronics,Enabled ,32
    ENG137058-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag,not enabled ,32
    ENG137058-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering Column Electronics,Enabled ,32
    ENG137058-SFT00023-GW_Enable_CAN_Timeout_DTC-Dash Board,Enabled ,32
    ENG137058-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary Parking Heater,Enabled ,32
    ENG137058-SFT00025-GW_Enable_CAN_Timeout_DTC-Gateway,Enabled ,32
    ENG137058-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,Enabled ,32
    ENG137058-SFT00032-GW_Enable_CAN_Timeout_DTC-High Beam Assistance,Enabled ,32
    ENG137058-SFT00033-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module 2,Enabled ,32
    ENG137058-SFT00034-GW_Enable_CAN_Timeout_DTC-All Wheel Control,Enabled ,32
    ENG137058-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost,Enabled ,32
    ENG137058-SFT00038-GW_Enable_CAN_Timeout_DTC-Electronic Roof Control,Enabled ,32
    ENG137058-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering Column Locking,Enabled ,32
    ENG137058-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2,Enabled ,32
    ENG137058-SFT00050-GW_Enable_CAN_Timeout_DTC-Lock Electronics,Enabled ,32
    ENG137058-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Driver Side,Enabled ,32
    ENG137058-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant,Enabled ,32
    ENG137058-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function,Enabled ,32
    ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-Air Conditioning Compressor,Enabled ,32
    ENG137058-SFT00066-GW_Enable_CAN_Timeout_DTC-Door Electronics Driver Side,Enabled ,32
    ENG137058-SFT00068-GW_Enable_CAN_Timeout_DTC-Steering Assistance,Enabled ,32
    ENG137058-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System,Enabled ,32
    ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multifunction module,Enabled ,32
    ENG137058-SFT00081-GW_Enable_CAN_Timeout_DTC-Drive Motor Control Module,Enabled ,32
    ENG137058-SFT00082-GW_Enable_CAN_Timeout_DTC-Door Electronics Passenger Side,Enabled ,32
    ENG137058-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlight Regulation,Enabled ,32
    ENG137058-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio,Enabled ,32
    ENG137058-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner,Enabled ,32
    ENG137058-SFT00095-GW_Enable_CAN_Timeout_DTC-Information Control Unit 1,Enabled ,32
    ENG137058-SFT00096-GW_Enable_CAN_Timeout_DTC-Tachograph,Enabled ,32
    ENG137058-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring 1,Enabled ,32
    ENG137058-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function,Enabled ,32
    ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Camera System Rear View,Enabled ,32
    ENG137058-SFT00109-GW_Enable_CAN_Timeout_DTC-Deck Lid Control Unit,Enabled ,32
    ENG137058-SFT00117-GW_Enable_CAN_Timeout_DTC-Telematics Communication Unit,Enabled ,32
    ENG137058-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking Assistance,Enabled ,32
    ENG137058-SFT00128-GW_Enable_CAN_Timeout_DTC-Battery Regulation Auxiliary Accumulator 1,Enabled ,32
    ENG137058-SFT00130-GW_Enable_CAN_Timeout_DTC-Head Up Display,Enabled ,32
    ENG137058-SFT00140-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module,Enabled ,32
    ENG137058-SFT00165-GW_Enable_CAN_Timeout_DTC-Front Sensors Driver Assistance System,Enabled ,32
    ENG137058-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone Control Unit,Enabled ,32
    ENG137058-SFT00169-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound,Enabled ,32
    ENG137058-SFT00183-GW_Enable_CAN_Timeout_DTC-Access Startsystem Interface,Enabled ,32
    ENG137058-SFT00187-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Driver Side,Enabled ,32
    ENG137058-SFT00188-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Passenger Side,Enabled ,32
    ENG137058-SFT00189-GW_Enable_CAN_Timeout_DTC-High Voltage Battery Charge Management,Enabled ,32
    ENG137058-SFT00190-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Left,Enabled ,32
    ENG137058-SFT00191-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Right,Enabled ,32
    ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,Enabled ,32
    ENG137058-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management,Enabled ,32
    ENG137058-SFT00198-GW_Enable_CAN_Timeout_DTC-Battery Charger Control Module,Enabled ,32
    ENG137058-SFT00202-GW_Enable_CAN_Timeout_DTC-Control module for sunroof,Enabled ,32
    ENG137058-SFT00204-GW_Enable_CAN_Timeout_DTC-Starter / Generator Control Module,Enabled ,32
    ENG137058-SFT00207-GW_Enable_CAN_Timeout_DTC-Control Unit Lane Change Assistant 2,Enabled ,32
    ENG137058-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,Enabled ,32
    ENG137058-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,Enabled ,32
    ENG137058-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,Enabled ,32
    ENG137058-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,Enabled ,32
    ENG137058-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,Enabled ,32
    ENG137058-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,Enabled ,32
    ENG137058-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,Enabled ,32
    ENG137058-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,Enabled ,32
    ENG137058-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,Enabled ,32
    ENG137058-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,Enabled ,32
    ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,Enabled ,32
    ENG137058-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,Enabled ,32
    ENG137058-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,Enabled ,32
    ENG137058-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,Enabled ,32
    ENG137058-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,Enabled ,32
    ENG137058-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,Enabled ,32
    ENG137058-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,Enabled ,32
    ENG137058-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,Enabled ,32
    ENG137058-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,Enabled ,32
    ENG137058-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,Enabled ,32
    ENG137058-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,Enabled ,32
    ENG137058-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,Enabled ,32
    ENG137058-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,Enabled ,32
    ENG137058-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,Enabled ,32
    ENG137058-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,Enabled ,32
    ENG137058-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,Enabled ,32
    ENG137058-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,Enabled ,32
    ENG137058-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,Enabled ,32
    ENG137058-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,Enabled ,32
    ENG137058-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,Enabled ,32
    ENG137058-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,Enabled ,32
    ENG137058-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,Enabled ,32
    ENG137058-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,Enabled ,32
    ENG137058-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,Enabled ,32
    ENG137058-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,Enabled ,32
    ENG137058-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,Enabled ,32
    ENG137058-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,Enabled ,32
    ENG137058-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,Enabled ,32
    ENG137058-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,Enabled ,32
    ENG137058-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,Enabled ,32
    ENG137058-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,Enabled ,32
    ENG137058-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,Enabled ,32
    ENG137058-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,Enabled ,32
    ENG137058-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,Enabled ,32
    ENG137058-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,Enabled ,32
    ENG137058-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,Enabled ,32
    ENG137058-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,Enabled ,32
    ENG137058-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,Enabled ,32
    ENG137058-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,Enabled ,32
    ENG137058-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,Enabled ,32
    ENG137058-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,Enabled ,32
    ENG137058-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,Enabled ,32
    ENG137058-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,Enabled ,32
    ENG137058-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,Enabled ,32
    ENG137058-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,Enabled ,32
    ENG137058-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,Enabled ,32
    ENG137058-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,Enabled ,32
    ENG137058-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,Enabled ,32
    ENG137058-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,Enabled ,32
    ENG137058-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,Enabled ,32
    ENG137058-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,Enabled ,32
    ENG137058-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,Enabled ,32
    ENG137058-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,Enabled ,32
    ENG137058-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,Enabled ,32
    ENG137058-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,Enabled ,32
    ENG137058-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,Enabled ,32
    ENG137058-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,Enabled ,32
    ENG137058-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,Enabled ,32
    ENG137058-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,Enabled ,32
    ENG137058-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,Enabled ,32
    ENG137058-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,Enabled ,32
    ENG137058-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,Enabled ,32
    ENG137058-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,Enabled ,32
    ENG137058-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,Enabled ,32
    ENG137058-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,Enabled ,32
    ENG137058-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,Enabled ,32
    ENG137058-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,Enabled ,32
    ENG137058-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,Enabled ,32
    ENG137058-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,Enabled ,32
    ENG137058-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,Enabled ,32
    ENG137058-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,Enabled ,32
    ENG137058-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,Enabled ,32
    ENG137058-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,Enabled ,32
    ENG137058-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,Enabled ,32
    ENG137058-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,Enabled ,32
    ENG137058-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,Enabled ,32
    ENG137058-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,Enabled ,32
    ENG137058-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,Enabled ,32
    ENG137058-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,Enabled ,32
    ENG137058-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,Enabled ,32
    ENG137058-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,Enabled ,32
    ENG137058-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,Enabled ,32
    ENG137058-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,Enabled ,32
    ENG137058-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,Enabled ,32
    ENG137058-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,Enabled ,32
    ENG137058-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,Enabled ,32
    ENG137058-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,Enabled ,32
    ENG137058-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,Enabled ,32
    ENG137058-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,Enabled ,32
    ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,Enabled ,32
    ENG137058-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,Enabled ,32
    ENG137058-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,Enabled ,32
    ENG137058-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,Enabled ,32
    ENG137058-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,Enabled ,32
    ENG137058-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,Enabled ,32
    ENG137058-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,Enabled ,32
    ENG137058-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,Enabled ,32
    ENG137058-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,Enabled ,32
    ENG137058-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,Enabled ,32
    ENG137058-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,Enabled ,32
    ENG137058-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,Enabled ,32
    ENG137058-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,Enabled ,32
    ENG137058-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,Enabled ,32
    ENG137058-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,Enabled ,32
    ENG137058-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,Enabled ,32
    ENG137058-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,Enabled ,32
    ENG137058-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,Enabled ,32
    ENG137058-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,Enabled ,32
    ENG137058-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,Enabled ,32
    ENG137058-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,Enabled ,32
    ENG137058-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,Enabled ,32
    ENG137058-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,Enabled ,32
    ENG137058-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,Enabled ,32
    ENG137058-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,Enabled ,32
    ENG137058-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,Enabled ,32
    ENG137058-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,Enabled ,32
    ENG137058-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,Enabled ,32
    ENG137058-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,Enabled ,32
    ENG137058-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,Enabled ,32
    ENG137058-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,Enabled ,32
    ENG137058-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,Enabled ,32
    ENG137058-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,Enabled ,32
    ENG137058-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,Enabled ,32
    ENG137058-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,Enabled ,32
    ENG137058-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,Enabled ,32
    ENG137058-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,Enabled ,32
    ENG137058-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,Enabled ,32
    ENG137058-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,Enabled ,32
    ENG137058-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,Enabled ,32
    ENG137058-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,Enabled ,32
    ENG137058-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,Enabled ,32
    ENG137058-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,Enabled ,32
    ENG137058-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,Enabled ,32
    ENG137058-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,Enabled ,32
    ENG137058-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,Enabled ,32
    ENG137058-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,Enabled ,32
    ENG137058-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,Enabled ,32
    ENG137058-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,Enabled ,32
    ENG137058-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,Enabled ,32
    ENG137058-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,Enabled ,32
    ENG137058-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,Enabled ,32
    ENG137058-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,Enabled ,32
    ENG137058-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,Enabled ,32
    ENG137058-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,Enabled ,32
    ENG137058-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,Enabled ,32
    ENG137058-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,Enabled ,32
    ENG137058-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,Enabled ,32
    ENG137058-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,Enabled ,32
    ENG137058-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,Enabled ,32
    ENG137058-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,Enabled ,32
    ENG137058-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,Enabled ,32
    ENG137058-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,Enabled ,32
    ENG137058-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,Enabled ,32
    ENG137058-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,Enabled ,32
    ENG137058-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,Enabled ,32
    ENG137058-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,Enabled ,32
    ENG137058-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,Enabled ,32
    ENG137058-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,Enabled ,32
    ENG137058-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,Enabled ,32
    ENG137058-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,Enabled ,32
    ENG137058-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,Enabled ,32
    ENG137058-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,Enabled ,32
    ENG137058-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,Enabled ,32
    ENG137058-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,Enabled ,32
    ENG137058-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,Enabled ,32
    ENG137058-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,Enabled ,32
    ENG137058-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,Enabled ,32
    ENG137058-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,Enabled ,32
    ENG137058-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,Enabled ,32
    ENG137058-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,Enabled ,32
    ENG137058-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,Enabled ,32
    ENG137058-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,Enabled ,32
    ENG137058-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,Enabled ,32
    ENG137058-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,Enabled ,32
    ENG137058-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,Enabled ,32
    ENG137058-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,Enabled ,32
    ENG137058-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,Enabled ,32
    ENG137058-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,Enabled ,32
    ENG137058-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,Enabled ,32
    ENG137058-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,Enabled ,32
    ENG137058-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,Enabled ,32
    ENG137058-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,Enabled ,32
    ENG137059-ENG118464-GW_mirror_mode-mirror_mode_bus,Databus drivetrain ,2
    ENG137059-ENG118465-GW_mirror_mode-mirror_mode_typ,not active ,2
    ENG152379-MV-EM_adaption_48V_zero_potential,regular operation ,1
    ENG137850-MVK_Warning,regular operation ,1
    ENG118774-ENG98345-WakeUpMonitor_Activation-Activation,activated ,1
    ENG118774-ENG152567-WakeUpMonitor_Activation-Open_Filter_Activate,activated ,1
    ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,8
    ENG118773-ENG103057-WakeUpMonitor_Configuration-Max_Num_Logical_WakeUp_Events,20 ,8
    ENG118773-ENG104006-WakeUpMonitor_Configuration-Max_Num_Physical_WakeUp_Events,20 ,8
    ENG118773-ENG154846-WakeUpMonitor_Configuration-Open_Filter_Time,45 min,8
    ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,8
    ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,8
    Elapsed Time: 00:24
    Blockmap - 19 - CAN Gateway
    ;Sunday,11,August,2019,16:10:10:40778
    ;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
    Group,Description,Actual
    IDE00019,Voltage terminal 30,11.8, V
    IDE00020,Terminal 15 status,Terminal 15 on,
    IDE00030,Status of actuator test,not active,
    IDE00056-ENG20489,History data 1-Life Cycle Data String,2000-01-01-00:00*00.0*00*00000***
    2000-01-01-00:00*00.0*00**
    2000-01-01-00:00*00.0*00**,
    IDE00057-ENG20489,History data 2-Life Cycle Data String,2000-01-01-00:00*000*000*+0.000*0-0-0-0-0-0-0*0*00*00000**
    2000-01-01-00:00*000*000*+0.000*0-0-0-0-0-0-0*0*00**
    2000-01-01-00:00*000*000*+0.000*0-0-0-0-0-0-0*0*00**,
    IDE00058-ENG20489,History data 3-Life Cycle Data String,2019-07-23-13:15*0*1*095*082*0-0-0-0-1-0-0*1*0*00.0*00.0**
    2019-07-23-12:35*T*0*086*074*0-0-0-0-0-0-0*0*0*00.0*00.0**
    2019-07-23-12:14*T*0*086*074*0-0-0-0-0-0-0*0*0*00.0*00.0**
    2019-07-23-08:52*T*0*087*075*0-0-0-0-0-0-0*0*0*00.0*00.0**
    2019-07-23-07:23*T*0*088*077*0-0-0-0-0-0-0*0*0*00.0*00.0**
    2019-07-18-03:36*T*0*088*079*0-0-0-0-0-0-0*0*0*00.0*00.0**
    2019-07-18-02:00*T*0*091*082*0-0-0-0-0-0-0*0*0*00.0*00.0**
    2019-07-16-21:48*T*0*091*082*0-0-0-0-0-0-0*0*0*00.0*00.0**
    2019-07-12-15:22*T*0*090*079*0-0-0-0-0-0-0*0*0*00.0*00.0**,
    IDE00059-ENG20489,History data 4-Life Cycle Data String,2019-06-18-00:44*01*075*JCB*3906055202*09982*00108*000.0*000.0*000.0**
    2000-01-01-00:00*00*---*---*----------*00000*00000*000.0*000.0*000.0**
    2000-01-01-00:00*00*---*---*----------*00000*00000*000.0*000.0*000.0**,
    IDE00060-ENG20489,History data 5-Life Cycle Data String,2000-01-01-00:00*0*+0.000*00.00*000*00*+00.0*00000*00000*000000*0-0-0-0-0-0-0*0*0*0*00.0*00.0*000.0*00*00*00*00*00**
    2000-01-01-00:00*0*+0.000*00.00*000*00*+00.0*00000*00000*000000*0-0-0-0-0-0-0*0*0*0*00.0*00.0*000.0*00*00*00*00*00**,
    IDE00061-ENG20489,History data 6-Life Cycle Data String,2019-08-11-00:52*046*+32*+000.9*00.00*0.00*000**
    2019-08-10-21:49*056*+31*+000.9*00.50*0.00*000**
    2019-08-10-18:33*060*+29*-004.4*00.70*0.00*000**
    2019-08-10-15:27*055*+26*+001.9*00.60*0.00*000**
    2019-08-10-14:34*053*+24*+001.6*00.80*0.00*000**
    2019-08-10-13:08*054*+22*+004.9*00.60*0.00*000**
    2019-08-10-12:17*053*+21*+000.3*00.10*0.00*000**
    2019-08-10-11:14*053*+21*+000.1*00.00*0.00*000**
    2019-08-09-18:32*057*+31*+001.7*00.70*0.00*000**
    2019-08-09-18:07*057*+30*+001.4*00.20*0.00*000**,
    IDE00062-ENG20489,History data 7-Life Cycle Data String,2019-08-11-00:09*046*+000.7*000.4*00.0*00.0**
    2019-08-10-22:23*051*+001.6*001.6*00.0*00.0**
    2019-08-10-19:17*054*+001.1*002.4*00.0*00.0**
    2019-08-10-16:07*067*+000.9*002.0*00.0*00.0**
    2019-08-10-15:24*053*+000.5*000.0*00.0*00.0**
    2019-08-10-13:48*053*+000.5*000.7*00.0*00.0**
    2019-08-10-12:24*050*+000.4*000.6*00.0*00.0**
    2019-08-10-11:15*052*+001.5*000.9*00.0*00.0**
    2019-08-09-19:18*053*+006.7*015.7*00.2*00.2**
    2019-08-09-18:20*056*+000.5*000.1*00.0*00.0**,
    IDE00063-ENG20489,History data 8-Life Cycle Data String,2019-08-10-21:48*4*03*00*00*17*2019-08-10-19:22*01**
    2019-08-09-17:08*4*03*00*00*16*2019-08-09-11:34*01**
    2019-08-08-11:22*4*03*00*00*15*2019-08-07-14:55*01**,
    IDE00064-ENG20489,History data 9-Life Cycle Data String,2019-06-17-15:49*100*100*091*060*00003*12.70*+26*02*01*12.70*00000*00000**
    2019-07-16-22:45*094*099*091*082*00024*12.70*+26*03*01*12.70*00000*00000**
    2000-01-01-00:00*000*000*000*000*00000*00.00*+00*00*00*00.00*00000*00000**
    2000-01-01-00:00*000*000*000*000*00000*00.00*+00*00*00*00.00*00000*00000**,
    IDE00065-ENG20489,History data 10-Life Cycle Data String,2000-01-01-00:00*0*000.0*0000.0*0*000.0*0000.0*00.00*0000000**
    2000-01-01-00:00*00*00.0*00.00*000.0**,
    IDE00066-ENG20489,History data 11-Life Cycle Data String,2019-08-11-00:08*000*000*000*000*0000*000*00.0*00.1*074*049*074*051*01*00009*00011*00020*00045*00038**
    2019-08-10-21:49*000*013*001*015*0392*034*04.7*06.4*079*054*080*056*01**
    2019-08-10-18:33*000*034*002*000*0384*044*09.7*06.3*090*066*085*060*01**
    2019-08-10-15:28*000*000*000*039*0302*039*00.0*02.5*074*053*076*055*01**
    2019-08-10-14:34*000*000*000*049*0283*049*00.0*02.4*073*052*075*053*01**,
    IDE00067-ENG20489,History data 12-Life Cycle Data String,2000-01-01-00:00*0-0-0-0-0-0-0-0**
    00000*00000*00000*00000*00000*00000*00000*00000**
    2000-01-01-00:00*0*000*000*+00*00*000*+00.00*00.0*0**
    00000*00000*00000**,
    IDE00068-ENG20489,History data 13-Life Cycle Data String,2000-01-01-00:00*0-0-0-0-0*000.0*00000**
    2000-01-01-00:00*0-0-0-0-0*000.0**
    2000-01-01-00:00*0-0-0-0-0*000.0**,
    IDE00069-ENG20489,History data 14-Life Cycle Data String,2019-08-11-00:52*3*00007*0000*0003*00.02*02000c*+32*0000.0*0000.0*0000.0**
    2019-08-10-21:51*1*00102*0000*0000*00.57*038008*+31**
    2000-01-01-00:00*0*00000*0000*0000*00.00*000000*+00**
    00001*00034*00000*00000*00000**
    2000-01-01-00:00*000.0*00.0*00.0*0000.0**
    2000-01-01-00:00*000.0*00.0*00.0**
    2000-01-01-00:00*000.0*00.0*00.0**,
    IDE00071-ENG20489,History data 16-Life Cycle Data String,       0000500km**
    00025*00023*00034*00000*00000**
    00046*00008*00016*00000**
    00481*00015*00001*00000**
    00035*00016*00000*00017**
    00050*00007*00011**
    00009*00002*00000**
    00000*00000*00000**
    00003*00001*00000**
    00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000**,
    IDE00322,Status of basic setting,was not yet started,
    IDE00323,Security Access: Number of invalid keys,0,
    IDE00356-IDE00355,Cruise Control System (CCS): switch position-Cruise Control System (CCS): status,No malfunction detected,
    IDE00356,Cruise Control System (CCS): switch position,OFF,
    IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,not activated,
    IDE00356-MAS00320,Cruise Control System (CCS): switch position-Main switch,Engaged ON,
    IDE00356-MAS00323,Cruise Control System (CCS): switch position-Decelerate tap,not activated,
    IDE00356-MAS00324,Cruise Control System (CCS): switch position-Accelerate tap,not activated,
    IDE00356-MAS00325,Cruise Control System (CCS): switch position-Setting,not activated,
    IDE00356-MAS00326,Cruise Control System (CCS): switch position-Activation,not activated,
    IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,not activated,
    IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,0,
    IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not Used,not activated,
    IDE00356-MAS04522,Cruise Control System (CCS): switch position-Delay tip level 2,not activated,
    IDE00356-MAS05138,Cruise Control System (CCS): switch position-Control unit,none,
    IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,not installed,
    IDE00356-MAS06029,Cruise Control System (CCS): switch position-MFL message counter,0,
    IDE00356-MAS06879,Cruise Control System (CCS): switch position-Checksum,0,
    IDE00767-ENG123029,No. of unscheduled ECU resets-Counter_Watchdog_Resets,59392,
    IDE00773,Terminal 15 status via CAN,On,
    IDE01285,Counter of component protection malfunctions,0,
    IDE01459,Energy management heat output control status,not active,
    IDE01805-ENG20489,History data 19-Life Cycle Data String,2000-01-01-00:00*00000*000*000*+00**
    IDE01807-IDE07142,History data 21-Time since terminal 15 off,15.1, H
    IDE01807-MAS00106,History data 21-Year,2019,
    IDE01807-MAS00107,History data 21-Month,7,
    IDE01807-MAS00108,History data 21-Day,12,
    IDE01807-MAS00109,History data 21-Hours,4, H
    IDE01807-MAS00110,History data 21-Minutes,22, min
    IDE01807-MAS14375,History data 21-Cycle counter,12,
    IDE01807-MAS14376,History data 21-ECU 1,Multifunction module on the second bus connection,
    IDE01807-MAS14377,History data 21-Alert maintenance time for ECU 1,0.4, H
    IDE01807-MAS14378,History data 21-Repetition counter for ECU 1,0,
    IDE01807-MAS14379,History data 21-ECU 2,Node_0x-- $-- (empty entry),
    IDE01807-MAS14380,History data 21-Alert maintenance time for ECU 2,0.0, H
    IDE01807-MAS14381,History data 21-Repetition counter for ECU 2,0,
    IDE01807-MAS14382,History data 21-ECU 3,Node_0x-- $-- (empty entry),
    IDE01807-MAS14383,History data 21-Alert maintenance time for ECU 3,0.0, H
    IDE01807-MAS14384,History data 21-Repetition counter for ECU 3,0,
    IDE01807-MAS14385,History data 21-ECU 4,Node_0x-- $-- (empty entry),
    IDE01807-MAS14386,History data 21-Alert maintenance time for ECU 4,0.0, H
    IDE01807-MAS14387,History data 21-Repetition counter for ECU 4,0,
    IDE01807-MAS14388,History data 21-ECU 5,Node_0x-- $-- (empty entry),
    IDE01807-MAS14389,History data 21-Alert maintenance time for ECU 5,0.0, H
    IDE01807-MAS14390,History data 21-Repetition counter for ECU 5,0,
    IDE01808-MAS03173,History data 22-Databus drivetrain,0.0, H
    IDE01808-MAS03174,History data 22-Comfort data bus,0.0, H
    IDE01808-MAS03175,History data 22-Databus extended,0.0, H
    IDE01808-MAS03176,History data 22-Display and control head databus,0.0, H
    IDE01808-MAS03177,History data 22-Databus Infotainment,0.0, H
    IDE01808-MAS03178,History data 22-Suspension data bus,0.0, H
    IDE01808-MAS03179,History data 22-Local data bus 2,0.0, H
    IDE01808-MAS03180,History data 22-Local data bus,0.0, H
    IDE01808-MAS05686,History data 22-Data bus diagnostics,0.0, H
    IDE01808-MAS14373,History data 22-All BUS systems,0.0, H
    IDE01809-IDE07142,History data 23-Time since terminal 15 off,0.0, H
    IDE01809-MAS00106,History data 23-Year,2000,
    IDE01809-MAS00107,History data 23-Month,1,
    IDE01809-MAS00108,History data 23-Day,1,
    IDE01809-MAS00109,History data 23-Hours,0, H
    IDE01809-MAS00110,History data 23-Minutes,0, min
    IDE01809-MAS14375,History data 23-Cycle counter,0,
    IDE01809-MAS14395,History data 23-Bus with maximum number of post alarms,Unknown,
    IDE01809-MAS14396,History data 23-Post alerts in current cycle,0,
    IDE01809-MAS14397,History data 23-Rousing ECU 1,Node_0x-- $-- (empty entry),
    IDE01809-MAS14398,History data 23-Number of post alerts for control module 1,0,
    IDE01809-MAS14399,History data 23-CarWakeUp bit 1,0,
    IDE01809-MAS14400,History data 23-Rousing ECU 2,Node_0x-- $-- (empty entry),
    IDE01809-MAS14401,History data 23-Number of post alerts for control module 2,0,
    IDE01809-MAS14402,History data 23-CarWakeUp bit 2,0,
    IDE01809-MAS14403,History data 23-Rousing ECU 3,Node_0x-- $-- (empty entry),
    IDE01809-MAS14404,History data 23-Number of post alerts for control module 3,0,
    IDE01809-MAS14405,History data 23-CarWakeUp bit 3,0,
    IDE01809-MAS14406,History data 23-Rousing ECU 4,Node_0x-- $-- (empty entry),
    IDE01809-MAS14407,History data 23-Number of post alerts for control module 4,0,
    IDE01809-MAS14408,History data 23-CarWakeUp bit 4,0,
    IDE01809-MAS14409,History data 23-Rousing ECU 5,Node_0x-- $-- (empty entry),
    IDE01809-MAS14410,History data 23-Number of post alerts for control module 5,0,
    IDE01809-MAS14411,History data 23-CarWakeUp bit 5,0,
    IDE01810-IDE07142,History data 24-Time since terminal 15 off,1.8, H
    IDE01810-MAS00106,History data 24-Year,2019,
    IDE01810-MAS00107,History data 24-Month,8,
    IDE01810-MAS00108,History data 24-Day,7,
    IDE01810-MAS00109,History data 24-Hours,10, H
    IDE01810-MAS00110,History data 24-Minutes,57, min
    IDE01810-MAS14375,History data 24-Cycle counter,38,
    IDE01810-MAS14399,History data 24-CarWakeUp bit 1,0,
    IDE01810-MAS14402,History data 24-CarWakeUp bit 2,0,
    IDE01810-MAS14405,History data 24-CarWakeUp bit 3,0,
    IDE01810-MAS14408,History data 24-CarWakeUp bit 4,0,
    IDE01810-MAS14411,History data 24-CarWakeUp bit 5,32,
    IDE01810-MAS14412,History data 24-Bus with maximum number of alerts,Comfort data bus,
    IDE01810-MAS14413,History data 24-Alert events in current cycle,25,
    IDE01810-MAS14414,History data 24-ID of the alerting message 1,00 00 00 00,
    IDE01810-MAS14415,History data 24-Counter of the alerting message 1,0,
    IDE01810-MAS14416,History data 24-Bus of the alerting message 1,Unknown,
    IDE01810-MAS14417,History data 24-ID of the alerting message 2,00 00 00 00,
    IDE01810-MAS14418,History data 24-Counter of the alerting message 2,0,
    IDE01810-MAS14419,History data 24-Bus of the alerting message 2,Unknown,
    IDE01810-MAS14420,History data 24-ID of the alerting message 3,00 00 00 00,
    IDE01810-MAS14421,History data 24-Counter of the alerting message 3,0,
    IDE01810-MAS14422,History data 24-Bus of the alerting message 3,Unknown,
    IDE01810-MAS14423,History data 24-ID of the alerting message 4,00 00 00 00,
    IDE01810-MAS14424,History data 24-Counter of the alerting message 4,0,
    IDE01810-MAS14425,History data 24-Bus of the alerting message 4,Unknown,
    IDE01810-MAS14426,History data 24-ID of the alerting message 5,1B 00 00 4B,
    IDE01810-MAS14427,History data 24-Counter of the alerting message 5,1,
    IDE01810-MAS14428,History data 24-Bus of the alerting message 5,Comfort data bus,
    IDE01812-MAS01468,History data 26-Terminal 15,0,
    IDE01812-MAS03173,History data 26-Databus drivetrain,0,
    IDE01812-MAS03174,History data 26-Comfort data bus,371,
    IDE01812-MAS03175,History data 26-Databus extended,324,
    IDE01812-MAS03177,History data 26-Databus Infotainment,0,
    IDE01812-MAS03178,History data 26-Suspension data bus,3,
    IDE01812-MAS03180,History data 26-Local data bus,45,
    IDE01812-MAS05686,History data 26-Data bus diagnostics,0,
    IDE01812-MAS14374,History data 26-Totals,743,
    IDE01813-MAS03173,History data 27-Databus drivetrain,0,
    IDE01813-MAS03174,History data 27-Comfort data bus,126,
    IDE01813-MAS03175,History data 27-Databus extended,4,
    IDE01813-MAS03177,History data 27-Databus Infotainment,0,
    IDE01813-MAS03178,History data 27-Suspension data bus,1,
    IDE01813-MAS14374,History data 27-Totals,131,
    IDE01814-MAS03173,History data 28-Databus drivetrain,0,
    IDE01814-MAS03174,History data 28-Comfort data bus,879,
    IDE01814-MAS03175,History data 28-Databus extended,0,
    IDE01814-MAS03177,History data 28-Databus Infotainment,0,
    IDE01814-MAS03178,History data 28-Suspension data bus,2,
    IDE01814-MAS14374,History data 28-Totals,881,
    IDE01816-IDE07142,History data 30-Time since terminal 15 off,15.1, H
    IDE01816-MAS00106,History data 30-Year,2019,
    IDE01816-MAS00107,History data 30-Month,7,
    IDE01816-MAS00108,History data 30-Day,12,
    IDE01816-MAS00109,History data 30-Hours,4, H
    IDE01816-MAS00110,History data 30-Minutes,22, min
    IDE01816-MAS14375,History data 30-Cycle counter,12,
    IDE01816-ENG20570,History data 30-Bus_1,Databus extended,
    IDE01816-ENG20572,History data 30-Bus_2,Suspension data bus,
    IDE01816-ENG20574,History data 30-Bus_3,Databus drivetrain,
    IDE01816-ENG20576,History data 30-Bus_4,Unknown (80),
    IDE01816-ENG20578,History data 30-Bus_5,Comfort data bus,
    IDE01816-ENG20571,History data 30-Bus_Active_Time_1,0.5, H
    IDE01816-ENG20573,History data 30-Bus_Active_Time_2,0.0, H
    IDE01816-ENG20575,History data 30-Bus_Active_Time_3,0.0, H
    IDE01816-ENG20577,History data 30-Bus_Active_Time_4,0.0, H
    IDE01816-ENG20579,History data 30-Bus_Active_Time_5,0.0, H
    IDE01817-IDE07142,History data 31-Time since terminal 15 off,14.7, H
    IDE01817-MAS00106,History data 31-Year,2019,
    IDE01817-MAS00107,History data 31-Month,8,
    IDE01817-MAS00108,History data 31-Day,11,
    IDE01817-MAS00109,History data 31-Hours,15, H
    IDE01817-MAS00110,History data 31-Minutes,38, min
    IDE01817-MAS14375,History data 31-Cycle counter,65,
    IDE01817-MAS14376,History data 31-ECU 1,Central Electrics,
    IDE01817-MAS14377,History data 31-Alert maintenance time for ECU 1,0.0, H
    IDE01817-MAS14378,History data 31-Repetition counter for ECU 1,0,
    IDE01817-MAS14379,History data 31-ECU 2,Multifunction module on the second bus connection,
    IDE01817-MAS14380,History data 31-Alert maintenance time for ECU 2,0.0, H
    IDE01817-MAS14381,History data 31-Repetition counter for ECU 2,0,
    IDE01817-MAS14382,History data 31-ECU 3,Door Electronics Driver Side,
    IDE01817-MAS14383,History data 31-Alert maintenance time for ECU 3,0.0, H
    IDE01817-MAS14384,History data 31-Repetition counter for ECU 3,0,
    IDE01817-MAS14385,History data 31-ECU 4,Transmission Control Module,
    IDE01817-MAS14386,History data 31-Alert maintenance time for ECU 4,0.0, H
    IDE01817-MAS14387,History data 31-Repetition counter for ECU 4,0,
    IDE01817-MAS14388,History data 31-ECU 5,Engine Control Module 1,
    IDE01817-MAS14389,History data 31-Alert maintenance time for ECU 5,0.0, H
    IDE01817-MAS14390,History data 31-Repetition counter for ECU 5,0,
    IDE01818-IDE07142,History data 32-Time since terminal 15 off,0.0, H
    IDE01818-MAS00106,History data 32-Year,2019,
    IDE01818-MAS00107,History data 32-Month,8,
    IDE01818-MAS00108,History data 32-Day,11,
    IDE01818-MAS00109,History data 32-Hours,0, H
    IDE01818-MAS00110,History data 32-Minutes,54, min
    IDE01818-MAS14375,History data 32-Cycle counter,65,
    IDE01818-MAS14391,History data 32-Alerting ECU,Door Electronics Driver Side,
    IDE01818-MAS14392,History data 32-CarWakeUp Bit,1,
    IDE01819-IDE07142,History data 33-Time since terminal 15 off,1.8, H
    IDE01819-MAS00106,History data 33-Year,2019,
    IDE01819-MAS00107,History data 33-Month,8,
    IDE01819-MAS00108,History data 33-Day,7,
    IDE01819-MAS00109,History data 33-Hours,10, H
    IDE01819-MAS00110,History data 33-Minutes,57, min
    IDE01819-MAS14375,History data 33-Cycle counter,38,
    IDE01819-MAS14393,History data 33-ID of the alerting message,1B 00 00 4B,
    IDE01819-MAS14394,History data 33-Bus of the alerting message,Comfort data bus,
    IDE01820-IDE07142,History data 34-Time since terminal 15 off,14.7, H
    IDE01820-MAS00106,History data 34-Year,2019,
    IDE01820-MAS00107,History data 34-Month,8,
    IDE01820-MAS00108,History data 34-Day,11,
    IDE01820-MAS00109,History data 34-Hours,15, H
    IDE01820-MAS00110,History data 34-Minutes,38, min
    IDE01820-MAS14375,History data 34-Cycle counter,65,
    IDE01820-MAS14393,History data 34-ID of the alerting message,1B 00 00 32,
    IDE01823-IDE07142,History data 37-Time since terminal 15 off,0.0, H
    IDE01823-MAS00106,History data 37-Year,2019,
    IDE01823-MAS00107,History data 37-Month,6,
    IDE01823-MAS00108,History data 37-Day,17,
    IDE01823-MAS00109,History data 37-Hours,22, H
    IDE01823-MAS00110,History data 37-Minutes,40, min
    IDE01823-MAS01632,History data 37-Status,activated,
    IDE01823-MAS14375,History data 37-Cycle counter,66,
    IDE01823-MAS14429,History data 37-Time in current cycle,0.5, H
    IDE01827,Generator specified voltage value,10.6, V
    IDE01828,Generator DF Signal,0.025, %
    IDE01829,Generator exciter current,0.000, A
    IDE01830-MAS01632,Generator Status-Status,Thermal OK,
    IDE01830-MAS02970,Generator Status-Status 2:,Mechanical OK,
    IDE01830-MAS02971,Generator Status-Status 3:,Electrical OK,
    IDE01831-MAS03159,Generator variant-Manufacturer,Valeo GmbH,
    IDE01831-MAS06310,Generator variant-Generator identifier,Generator recognition 105-180A,
    IDE01832-MAS06311,Generator regulator variant-ASIC manufacturer,1,
    IDE01832-MAS06312,Generator regulator variant-ASIC variant,4,
    IDE01834,Battery voltage,12.070, V
    IDE01836,Battery current,-17.719, A
    IDE01837,Temperature of battery sensor,28, ∞C
    IDE01838,Battery temperature,24, ∞C
    IDE01839,Battery charge condition,68, %
    IDE01841,Battery internal resistance,3.2, mOhm
    IDE01842,Usable battery charge,41, Ah
    IDE01843,Battery voltage at rest,12.4, V
    IDE01844,Increase idle speed request,no request,
    IDE01845,Reduce internal fan request,no request,
    IDE01846,Static current shutdown level,Deactivation stage 0,
    IDE01847,Auxiliary heater activation restriction request,Permitted,
    IDE01847-MAS06319,Auxiliary heater activation restriction request-Allowed parking heater runtime,60, min
    IDE01848,Previous journey energy summary,0.0, Ah
    IDE01849,Previous journey duration,0.0, H
    IDE01852,Static current measurement: result,0, mA
    IDE01853,Static current measurement: status,Initializing,
    IDE01854,Energy reclamation request,not active,
    IDE01855,Generator current,0.0, A
    IDE01948,Battery internal resistance not normed,3.4, mOhm
    IDE01985-ENG101043,FAZIT identification test sum-Checksum,05 F3 61 73,
    IDE01985-ENG99027,FAZIT identification test sum-Version,129,
    IDE02578-ENG06041,Play protection status-fiddle_proofing_1,not active,
    IDE02578-ENG06043,Play protection status-fiddle_proofing_2,not active,
    IDE02578-ENG06044,Play protection status-fiddle_proofing_3,not active,
    IDE02578-ENG06045,Play protection status-fiddle_proofing_4,not active,
    IDE02578-ENG06046,Play protection status-fiddle_proofing_5,not active,
    IDE02578-ENG06047,Play protection status-fiddle_proofing_6,not active,
    IDE02578-ENG06048,Play protection status-fiddle_proofing_7,not active,
    IDE02578-ENG06049,Play protection status-fiddle_proofing_8,not active,
    IDE02578-ENG06042,Play protection status-function_calls_counter_1,0,
    IDE02578-ENG06050,Play protection status-function_calls_counter_2,0,
    IDE02578-ENG06051,Play protection status-function_calls_counter_3,0,
    IDE02578-ENG06052,Play protection status-function_calls_counter_4,0,
    IDE02578-ENG06053,Play protection status-function_calls_counter_5,0,
    IDE02578-ENG06054,Play protection status-function_calls_counter_6,0,
    IDE02578-ENG06055,Play protection status-function_calls_counter_7,0,
    IDE02578-ENG06056,Play protection status-function_calls_counter_8,0,
    IDE03008-IDE01838,Stop process prevented-Battery temperature,not active,
    IDE03008-IDE01844,Stop process prevented-Increase idle speed request,not active,
    IDE03008-MAS02193,Stop process prevented-Outside air temperature,not active,
    IDE03008-MAS04054,Stop process prevented-Consumer current too high,not active,
    IDE03008-MAS04055,Stop process prevented-Usable battery charge too low,not active,
    IDE03008-MAS04056,Stop process prevented-Battery charge condition too low,not active,
    IDE03008-MAS04062,Stop process prevented-Possible service life too short,not active,
    IDE03008-MAS06001,Stop process prevented-Energy management special veto,not active,
    IDE03008-MAS06002,Stop process prevented-DC/DC converter Veto,not active,
    IDE03008-MAS19121,Stop process prevented-Successful restart done through freight quota,not active,
    IDE03009-MAS01478,Start process requested-Insuff. voltage,not active,
    IDE03009-MAS02885,Start process requested-Restart because of outside temperature,not active,
    IDE03009-MAS04054,Start process requested-Consumer current too high,not active,
    IDE03009-MAS04055,Start process requested-Usable battery charge too low,not active,
    IDE03009-MAS04056,Start process requested-Battery charge condition too low,not active,
    IDE03009-MAS04058,Start process requested-Service life expired,not active,
    IDE03009-MAS06003,Start process requested-Charging contingent,not active,
    IDE03009-MAS06004,Start process requested-Special start requirements,not active,
    IDE03010-IDE01838,Number of prevented stop processes-Battery temperature,0,
    IDE03010-IDE01844,Number of prevented stop processes-Increase idle speed request,0,
    IDE03010-MAS02193,Number of prevented stop processes-Outside air temperature,0,
    IDE03010-MAS04054,Number of prevented stop processes-Consumer current too high,0,
    IDE03010-MAS04055,Number of prevented stop processes-Usable battery charge too low,0,
    IDE03010-MAS04056,Number of prevented stop processes-Battery charge condition too low,0,
    IDE03010-MAS04062,Number of prevented stop processes-Possible service life too short,0,
    IDE03010-MAS05998,Number of prevented stop processes-Frequency counter DC/DC converter Veto,0,
    IDE03010-MAS06350,Number of prevented stop processes-Frequency counter: energy management special veto,0,
    IDE03011-MAS01478,Number of requested start processes-Insuff. voltage,0,
    IDE03011-MAS02885,Number of requested start processes-Restart because of outside temperature,0,
    IDE03011-MAS04054,Number of requested start processes-Consumer current too high,0,
    IDE03011-MAS04055,Number of requested start processes-Usable battery charge too low,0,
    IDE03011-MAS04056,Number of requested start processes-Battery charge condition too low,0,
    IDE03011-MAS04058,Number of requested start processes-Service life expired,0,
    IDE03011-MAS05999,Number of requested start processes-Frequency counter charging contingent,0,
    IDE03011-MAS06000,Number of requested start processes-Frequency counter special start requirements,0,
    IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2127,
    IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,15,
    IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,31,
    IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,31,
    IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,63,
    IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,63,
    IDE03127-ENG118156,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n,no measured value present,
    IDE03127-ENG118158,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-1,no measured value present,
    IDE03127-ENG118160,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-2,no measured value present,
    IDE03127-ENG118162,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-3,no measured value present,
    IDE03127-ENG118164,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-4,no measured value present,
    IDE03128-MAS00106,Requested start processes (ring memory)-Year,2127,
    IDE03128-MAS00107,Requested start processes (ring memory)-Month,15,
    IDE03128-MAS00108,Requested start processes (ring memory)-Day,31,
    IDE03128-MAS00109,Requested start processes (ring memory)-Hours,31,
    IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,63,
    IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,63,
    IDE03128-ENG118166,Requested start processes (ring memory)-Restart_n,no measured value present,
    IDE03128-ENG118168,Requested start processes (ring memory)-Restart_n-1,no measured value present,
    IDE03128-ENG118170,Requested start processes (ring memory)-Restart_n-2,no measured value present,
    IDE03128-ENG118172,Requested start processes (ring memory)-Restart_n-3,no measured value present,
    IDE03128-ENG118174,Requested start processes (ring memory)-Restart_n-4,no measured value present,
    IDE03212,Start-stop conditions,Stop release,
    IDE03213,Start-stop enabling,System malfunction,
    IDE03214,Engine stop using start-stop function,not active,
    IDE03215,Engine start using start-stop function,not active,
    IDE03256-MAS06105,Battery adaptation-Rated battery capacity,75, Ah
    IDE03256-MAS06106,Battery adaptation-Battery technology,Fleece,
    IDE03256-MAS06107,Battery adaptation-Battery manufacturer,JCB,
    IDE03256-MAS06108,Battery adaptation-Battery Serial Number,3906055202,
    IDE03588-MAS05683,System malfunctions for active participants start/stop-Battery malfunction,0,
    IDE03588-MAS06321,System malfunctions for active participants start/stop-System malfunction generator,0,
    IDE03588-MAS06322,System malfunctions for active participants start/stop-System malfunction due to battery throughput,0,
    IDE03588-MAS06323,System malfunctions for active participants start/stop-Start/stop coordinator implausible,0,
    IDE03588-MAS06324,System malfunctions for active participants start/stop-DCDC converter system malfunction,0,
    IDE03588-MAS06326,System malfunctions for active participants start/stop-Communication malfunction battery data module,0,
    IDE03588-MAS06327,System malfunctions for active participants start/stop-Battery data module defective,0,
    IDE04186,Battery terminal recognition,connected,
    IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Available,
    IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,valid,
    IDE04329-IDE06260,Status of all SWaP functions-ID number,10 00 01 00,
    IDE04329-MAS01340,Status of all SWaP functions-Functions,present,
    IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
    IDE04329-MAS02934,Status of all SWaP functions-Prerequisites met,Condition met,
    IDE04329-MAS05616,Status of all SWaP functions-Cancellation,No,
    IDE04329-MAS05617,Status of all SWaP functions-Authentication,valid,
    IDE04334,Public key for SWaP function,99 19 70 20 DD A9 1D 14 0A BB A4 90 B5 ED 09 97 32 66 86 77 B6 FC 36 C9 0F 44 99 7F 58 BF 1C 99 82 8C DD 35 B4 F5 BB 76 4F 28 2E 4A 4B AA 98 44 D5 65 19 9D 70 BD 6E 67 C7 B2 D6 C9 37 77 57 DD CE 12 D4 A1 15 32 59 88 5E 5C 05 4B C4 B9 D5 8F 18 83 0E BA 93 C1 43 56 0F A4 B6 B9 3C 79 66 8F D7 5B 33 70 34 84 1E 8E D7 AE CD B8 E6 0E 29 FC D5 60 B3 F6 EC FD E2 D3 2B 1A 7D 78 41 88 78 F9 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
    IDE04806-ENG06028,Driving profile selection button-Driving_Profile_Selection_Button_1,operated,
    IDE04806-ENG06029,Driving profile selection button-Driving_Profile_Selection_Button_2,not activated,
    IDE04806-ENG06030,Driving profile selection button-Driving_Profile_Selection_Button_3,not activated,
    IDE04806-ENG06031,Driving profile selection button-Driving_Profile_Selection_Button_4,operated,
    IDE04806-ENG06032,Driving profile selection button-Driving_Profile_Selection_Button_5,operated,
    IDE04806-ENG06033,Driving profile selection button-Driving_Profile_Selection_Button_6,not activated,
    IDE04806-ENG06034,Driving profile selection button-Driving_Profile_Selection_Button_7,not activated,
    IDE04806-ENG06035,Driving profile selection button-Driving_Profile_Selection_Button_8,operated,
    IDE05583-IDE02766,Pause recommendation-Malfunction status,not installed,
    IDE05583-MAS03095,Pause recommendation-Function status,not installed,
    IDE05583-MAS04622,Pause recommendation-Break recommend. message,No message,
    IDE05583-MAS13162,Pause recommendation-Icon deactivated,No,
    IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,active,
    IDE05740-ENG05007,Driving profile selection: system status-profile_state_1,engaged,
    IDE05740-ENG05008,Driving profile selection: system status-profile_state_2,engaged,
    IDE05740-ENG05009,Driving profile selection: system status-profile_state_3,not engaged,
    IDE05740-ENG05010,Driving profile selection: system status-profile_state_4,not engaged,
    IDE05740-ENG05011,Driving profile selection: system status-profile_state_5,not engaged,
    IDE05740-ENG05012,Driving profile selection: system status-profile_state_6,not engaged,
    IDE05740-ENG05013,Driving profile selection: system status-profile_state_7,not engaged,
    IDE05740-ENG05014,Driving profile selection: system status-profile_state_8,not engaged,
    IDE05814,Individualization characteristic,AF BA C3 58 5B,
    IDE06007-IDE00105,Driving profile history data 1-Malfunction type,no entry,
    IDE06007-IDE04805,Driving profile history data 1-Driving profile selection,0,
    IDE06007-IDE07643,Driving profile history data 1-Faulty function,no entry,
    IDE06007-MAS00106,Driving profile history data 1-Year,2000,
    IDE06007-MAS00107,Driving profile history data 1-Month,0,
    IDE06007-MAS00108,Driving profile history data 1-Day,0,
    IDE06007-MAS00109,Driving profile history data 1-Hours,0,
    IDE06007-MAS00110,Driving profile history data 1-Minutes,0,
    IDE06007-MAS00111,Driving profile history data 1-Seconds,0,
    IDE06007-MAS00711,Driving profile history data 1-Odometer reading,0, km
    IDE06007-MAS03095,Driving profile history data 1-Function status,Initializing,
    IDE06008-IDE00105,Driving profile history data 2-Malfunction type,no entry,
    IDE06008-IDE04805,Driving profile history data 2-Driving profile selection,0,
    IDE06008-IDE07643,Driving profile history data 2-Faulty function,no entry,
    IDE06008-MAS00106,Driving profile history data 2-Year,2000,
    IDE06008-MAS00107,Driving profile history data 2-Month,0,
    IDE06008-MAS00108,Driving profile history data 2-Day,0,
    IDE06008-MAS00109,Driving profile history data 2-Hours,0,
    IDE06008-MAS00110,Driving profile history data 2-Minutes,0,
    IDE06008-MAS00111,Driving profile history data 2-Seconds,0,
    IDE06008-MAS00711,Driving profile history data 2-Odometer reading,0, km
    IDE06008-MAS03095,Driving profile history data 2-Function status,Initializing,
    IDE06009-IDE00105,Driving profile history data 3-Malfunction type,no entry,
    IDE06009-IDE04805,Driving profile history data 3-Driving profile selection,0,
    IDE06009-IDE07643,Driving profile history data 3-Faulty function,Transmission Control Module (TCM),
    IDE06009-MAS00106,Driving profile history data 3-Year,2000,
    IDE06009-MAS00107,Driving profile history data 3-Month,0,
    IDE06009-MAS00108,Driving profile history data 3-Day,0,
    IDE06009-MAS00109,Driving profile history data 3-Hours,0,
    IDE06009-MAS00110,Driving profile history data 3-Minutes,0,
    IDE06009-MAS00111,Driving profile history data 3-Seconds,0,
    IDE06009-MAS00711,Driving profile history data 3-Odometer reading,0, km
    IDE06009-MAS03095,Driving profile history data 3-Function status,Initializing,
    IDE06010-IDE00105,Driving profile history data 4-Malfunction type,no entry,
    IDE06010-IDE04805,Driving profile history data 4-Driving profile selection,0,
    IDE06010-IDE07643,Driving profile history data 4-Faulty function,Engine Control Module (ECM),
    IDE06010-MAS00106,Driving profile history data 4-Year,2000,
    IDE06010-MAS00107,Driving profile history data 4-Month,0,
    IDE06010-MAS00108,Driving profile history data 4-Day,0,
    IDE06010-MAS00109,Driving profile history data 4-Hours,0,
    IDE06010-MAS00110,Driving profile history data 4-Minutes,0,
    IDE06010-MAS00111,Driving profile history data 4-Seconds,0,
    IDE06010-MAS00711,Driving profile history data 4-Odometer reading,0, km
    IDE06010-MAS03095,Driving profile history data 4-Function status,Initializing,
    IDE06011-ENG04999,Selected driving profile-driving_profile_1,Dynamic,
    IDE06011-ENG05000,Selected driving profile-driving_profile_2,no function,
    IDE06011-ENG05001,Selected driving profile-driving_profile_3,Comfort,
    IDE06011-ENG05002,Selected driving profile-driving_profile_4,no function,
    IDE06011-ENG05003,Selected driving profile-driving_profile_5,no function,
    IDE06011-ENG05004,Selected driving profile-driving_profile_6,no function,
    IDE06011-ENG05005,Selected driving profile-driving_profile_7,no function,
    IDE06011-ENG05006,Selected driving profile-driving_profile_8,no function,
    IDE06165-MAS06193,Driving profile selection statistics-Profile 1,282,
    IDE06165-MAS06194,Driving profile selection statistics-Profile 2,215,
    IDE06165-MAS06195,Driving profile selection statistics-Profile 3,231,
    IDE06165-MAS06196,Driving profile selection statistics-Profile 4,0,
    IDE06165-MAS06197,Driving profile selection statistics-Profile 5,49,
    IDE06165-MAS06198,Driving profile selection statistics-Profile 6,0,
    IDE06165-MAS06199,Driving profile selection statistics-Profile 7,0,
    IDE06165-MAS06200,Driving profile selection statistics-Profile 8,0,
    IDE06165-MAS08875,Driving profile selection statistics-Profile 9,0,
    IDE06165-MAS08876,Driving profile selection statistics-Profile 10,0,
    IDE06165-MAS08877,Driving profile selection statistics-Profile 11,0,
    IDE06165-MAS08878,Driving profile selection statistics-Profile 12,0,
    IDE06230-MAS00106,Break recommend.: last message-Year,2000,
    IDE06230-MAS00107,Break recommend.: last message-Month,0,
    IDE06230-MAS00108,Break recommend.: last message-Day,0,
    IDE06230-MAS00109,Break recommend.: last message-Hours,0,
    IDE06230-MAS00110,Break recommend.: last message-Minutes,0,
    IDE06230-MAS00111,Break recommend.: last message-Seconds,0,
    IDE06230-MAS03095,Break recommend.: last message-Function status,Initializing,
    IDE06230-MAS04622,Break recommend.: last message-Break recommend. message,No message,
    IDE06592-MAS05002,Status: special functions-Showroom mode,OFF,
    IDE06592-MAS05003,Status: special functions-Debug functions,OFF,
    IDE07145-MAS06772,Component protection properties-Component protection generation,02,
    IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,02,
    IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
    IDE07145-MAS06775,Component protection properties-KS Standard software correct number,03,
    IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Master,
    IDE07145-MAS06781,Component protection properties-Secure Hardware Extension,used,
    IDE07145-MAS06782,Component protection properties-Master ECU Key,administered by component protection,
    IDE07145-MAS06785,Component protection properties-GFA key,used,
    IDE07145-MAS06786,Component protection properties-SSW RND Generation,Not Used,
    IDE07145-MAS06787,Component protection properties-Indiv Key Generation,used,
    IDE07145-MAS06788,Component protection properties-SHE Secure Boot,Not Used,
    IDE07145-MAS06789,Component protection properties-KSB Config Status 2,80,
    IDE07145-MAS07187,Component protection properties-KS Data version,01,
    IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,not activated,
    IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,active,
    IDE07424-IDE04447,Status: driving profile selection for engine-Function status,not engaged,
    IDE07424-IDE06260,Status: driving profile selection for engine-ID number,18,
    IDE07424-MAS01156,Status: driving profile selection for engine-Communication status,OK,
    IDE07424-MAS01447,Status: driving profile selection for engine-Act.val.,2,
    IDE07425-IDE04447,Status: driving profile selection for start-stop function-Function status,not engaged,
    IDE07425-IDE06260,Status: driving profile selection for start-stop function-ID number,22,
    IDE07425-MAS01156,Status: driving profile selection for start-stop function-Communication status,OK,
    IDE07425-MAS01447,Status: driving profile selection for start-stop function-Act.val.,0,
    IDE07426-IDE04447,Status: driving profile selection for transmission-Function status,not engaged,
    IDE07426-IDE06260,Status: driving profile selection for transmission-ID number,35,
    IDE07426-MAS01156,Status: driving profile selection for transmission-Communication status,OK,
    IDE07426-MAS01447,Status: driving profile selection for transmission-Act.val.,2,
    IDE07473-MAS06303,Generator limitation-Status overvoltage limitation,not active,
    IDE07473-MAS06304,Generator limitation-Status overvoltage diagnosis,not active,
    IDE07473-MAS06305,Generator limitation-Status of diagnosis for energy balance,not active,
    IDE07473-MAS06306,Generator limitation-Status generator release by engine,no request,
    IDE07473-MAS06307,Generator limitation-Status of battery charging function,not active,
    IDE07473-MAS06308,Generator limitation-Power steering support active,not active,
    IDE07473-MAS06309,Generator limitation-Coolant fan activation request by BEM,not active,
    IDE07474-MAS06313,Adapting for energy management-Adaptation static current management,not active,
    IDE07474-MAS06314,Adapting for energy management-Battery coding active,not active,
    IDE07616,Battery degradation for start/stop - operation,ERROR,
    IDE07619-IDE07621,Start/stop starting voltage prediction-Permitted engine stoppage time,ERROR,
    IDE07619-IDE07622,Start/stop starting voltage prediction-Power consumption during idle phase,155, A
    IDE07623-MAS06328,Open-circuit voltage gateway-Battery voltage last wakeup,12.0, V
    IDE07623-MAS06329,Open-circuit voltage gateway-Batter voltage penultimate wakeup,15.0, V
    IDE07623-MAS06330,Open-circuit voltage gateway-Open-circuit voltage valid,invalid,
    IDE07628-IDE07629,Status power receptacle-Function release power receptacle,blocked,
    IDE07628-IDE07630,Status power receptacle-Pre-warning power receptacle,not active,
    IDE07628-MAS01581,Status power receptacle-Power consumption,Initializing,
    IDE07628-MAS06331,Status power receptacle-Enabling self-contained operation,blocked,
    IDE07628-MAS06332,Status power receptacle-Status function readiness,blocked,
    IDE07628-MAS06333,Status power receptacle-Status function,OFF,
    IDE07628-MAS06334,Status power receptacle-Status overtemperature,in permissible range,
    IDE07638-MAS06339,Status condition determin. ready for idle-Sleep readiness BEM,active,
    IDE07638-MAS06340,Status condition determin. ready for idle-Busstat readiness BEM,Run busstat,
    IDE07638-MAS06341,Status condition determin. ready for idle-After-run for power receptacle,not active,
    IDE07640-MAS06344,Analysis of start voltage behavior-Minimum voltage at last engine start,9.95,
    IDE07640-MAS06345,Analysis of start voltage behavior-Minimum voltage at last engine start recognized,not recognized,
    IDE07640-MAS06346,Analysis of start voltage behavior-Voltage drop through engine start recognized,not recognized,
    IDE07640-MAS06347,Analysis of start voltage behavior-Current voltage drop last start,0.00, V
    IDE07640-MAS06348,Analysis of start voltage behavior-Normed voltage drop,0.00, V
    IDE07640-MAS11064,Analysis of start voltage behavior-Current last engine start,728, A
    IDE07640-MAS11065,Analysis of start voltage behavior-Current delta last engine start,712, A
    IDE07681-MAS06086,Battery total charging throughput-Total re-charge,91.8, Ah
    IDE07681-MAS06087,Battery total charging throughput-Total energy throughput,107.2, Ah
    IDE07873-MAS06193,FPA enabled profiles-Profile 1,Comfort,
    IDE07873-MAS06194,FPA enabled profiles-Profile 2,AUTO,
    IDE07873-MAS06195,FPA enabled profiles-Profile 3,Dynamic,
    IDE07873-MAS06196,FPA enabled profiles-Profile 4,Not Used,
    IDE07873-MAS06197,FPA enabled profiles-Profile 5,Not Used,
    IDE07873-MAS06198,FPA enabled profiles-Profile 6,Not Used,
    IDE07873-MAS06199,FPA enabled profiles-Profile 7,Not Used,
    IDE07873-MAS06200,FPA enabled profiles-Profile 8,Not Used,
    IDE07873-MAS08875,FPA enabled profiles-Profile 9,Not Used,
    IDE07873-MAS08876,FPA enabled profiles-Profile 10,Not Used,
    IDE07873-MAS08877,FPA enabled profiles-Profile 11,Not Used,
    IDE07873-MAS08878,FPA enabled profiles-Profile 12,Not Used,
    IDE07907,Bus communication,active,
    IDE08343,Immobilizer Challenge,45 B3 61 D7,
    IDE08346-MAS06117,Generator Analysis-Rated voltage,10.6, V
    IDE08346-MAS06864,Generator Analysis-Generator actual voltage,12.0, V
    IDE08346-MAS06865,Generator Analysis-Voltage difference generator battery,0.0, V
    IDE08346-MAS06866,Generator Analysis-Generator speed,564, /min
    IDE08346-MAS06867,Generator Analysis-Generator chip temperature,28, ∞C
    IDE08347,adapted battery capacity,109, Ah
    IDE08680-MAS03173,Allocation data bus identifier-Databus drivetrain,11,
    IDE08680-MAS03174,Allocation data bus identifier-Comfort data bus,12,
    IDE08680-MAS03175,Allocation data bus identifier-Databus extended,15,
    IDE08680-MAS03177,Allocation data bus identifier-Databus Infotainment,13,
    IDE08680-MAS03178,Allocation data bus identifier-Suspension data bus,14,
    IDE08680-MAS03179,Allocation data bus identifier-Local data bus 2,52,
    IDE08680-MAS03180,Allocation data bus identifier-Local data bus,51,
    IDE08680-MAS05686,Allocation data bus identifier-Data bus diagnostics,10,
    IDE08680-MAS05972,Allocation data bus identifier-Local data bus 3,53,
    IDE08681-MAS03173,Data bus defect error-Databus drivetrain,OK,
    IDE08681-MAS03174,Data bus defect error-Comfort data bus,OK,
    IDE08681-MAS03175,Data bus defect error-Databus extended,OK,
    IDE08681-MAS03177,Data bus defect error-Databus Infotainment,OK,
    IDE08681-MAS03178,Data bus defect error-Suspension data bus,OK,
    IDE08681-MAS03179,Data bus defect error-Local data bus 2,OK,
    IDE08681-MAS03180,Data bus defect error-Local data bus,OK,
    IDE08681-MAS05686,Data bus defect error-Data bus diagnostics,OK,
    IDE08681-MAS05972,Data bus defect error-Local data bus 3,not installed,
    IDE08682-MAS03173,Data bus single wire err.-Databus drivetrain,OK,
    IDE08682-MAS03174,Data bus single wire err.-Comfort data bus,OK,
    IDE08682-MAS03175,Data bus single wire err.-Databus extended,OK,
    IDE08682-MAS03177,Data bus single wire err.-Databus Infotainment,OK,
    IDE08682-MAS03178,Data bus single wire err.-Suspension data bus,OK,
    IDE08682-MAS03179,Data bus single wire err.-Local data bus 2,Not coded,
    IDE08682-MAS03180,Data bus single wire err.-Local data bus,Not coded,
    IDE08682-MAS05686,Data bus single wire err.-Data bus diagnostics,Not coded,
    IDE08682-MAS05972,Data bus single wire err.-Local data bus 3,not installed,
    IDE08683-MAS03173,Data bus TimeOut error-Databus drivetrain,OK,
    IDE08683-MAS03174,Data bus TimeOut error-Comfort data bus,OK,
    IDE08683-MAS03175,Data bus TimeOut error-Databus extended,OK,
    IDE08683-MAS03177,Data bus TimeOut error-Databus Infotainment,OK,
    IDE08683-MAS03178,Data bus TimeOut error-Suspension data bus,OK,
    IDE08683-MAS03179,Data bus TimeOut error-Local data bus 2,Not coded,
    IDE08683-MAS03180,Data bus TimeOut error-Local data bus,Not coded,
    IDE08683-MAS05686,Data bus TimeOut error-Data bus diagnostics,Not coded,
    IDE08683-MAS05972,Data bus TimeOut error-Local data bus 3,not installed,
    IDE08684-SFT09757,Allocation LIN system number-Alternator,00 1D,
    IDE08684-SFT09777,Allocation LIN system number-Multi Function Steering Wheel Control Module,00 31,
    IDE08684-SFT09783,Allocation LIN system number-Battery Monitoring Control Module,00 37,
    IDE08684-SFT09833,Allocation LIN system number-Power Converter DC AC,00 69,
    IDE08684-SFT09842,Allocation LIN system number-Analog clock,00 72,
    IDE08684-SFT10031,Allocation LIN system number-Operating Unit Drive Mode Selection,01 2F,
    IDE08684-SFT10046,Allocation LIN system number-Control module for steering wheel touch recognition,01 3E,
    IDE08685-SFT09757,Status LIN user-Alternator,active,
    IDE08685-SFT09777,Status LIN user-Multi Function Steering Wheel Control Module,active,
    IDE08685-SFT09783,Status LIN user-Battery Monitoring Control Module,active,
    IDE08685-SFT09833,Status LIN user-Power Converter DC AC,not active,
    IDE08685-SFT09842,Status LIN user-Analog clock,not active,
    IDE08685-SFT10031,Status LIN user-Operating Unit Drive Mode Selection,not active,
    IDE08685-SFT10046,Status LIN user-Control module for steering wheel touch recognition,not active,
    IDE08794-MAS06106,Battery cell analysis-Battery technology,Unknown,
    IDE08794-MAS07703,Battery cell analysis-Cell voltage,0.0000, V
    IDE08794-MAS07704,Battery cell analysis-Cell temp.,-40, ∞C
    IDE08794-MAS07705,Battery cell analysis-Cell limit voltage (binary coded),0,
    IDE08794-MAS07706,Battery cell analysis-Can be analyzed,Initializing,
    IDE08794-MAS07707,Battery cell analysis-Health condition acc. to calendar,126, %
    IDE08794-MAS07708,Battery cell analysis-Cut-off element,closed,
    IDE09561,Closed-circuit current of last LIN sleep phase,-2.518, A
    IDE09562,Range extension counter: stage 2,0,
    IDE10674-MAS11055,Extended battery diagnosis-Pulse interior resistance,2.2, mOhm
    IDE10674-MAS11056,Extended battery diagnosis-Counter battery warning,0,
    IDE10674-MAS11059,Extended battery diagnosis-Power state LV battery singular operation,OK,
    IDE10674-MAS11060,Extended battery diagnosis-Status Handshake HVK,OK,
    IDE10739-IDE04447,Status: driving profile selection for oper. mode selection-Function status,not engaged,
    IDE10739-IDE06260,Status: driving profile selection for oper. mode selection-ID number,20,
    IDE10739-MAS01156,Status: driving profile selection for oper. mode selection-Communication status,OK,
    IDE10739-MAS01447,Status: driving profile selection for oper. mode selection-Act.val.,0,
    IDE11573,Energy management in heating power allocation,1000, W
    IDE11673-MAS02246,Battery Management 2: prohibition on turning-on 48V-Timeout,not active,
    IDE11673-MAS03123,Battery Management 2: prohibition on turning-on 48V-Reduced performance,not active,
    IDE11673-MAS09519,Battery Management 2: prohibition on turning-on 48V-Message error,not active,
    IDE11673-MAS09541,Battery Management 2: prohibition on turning-on 48V-Act. mode init. error,not active,
    IDE11673-MAS09542,Battery Management 2: prohibition on turning-on 48V-Error status init. error,not active,
    IDE11673-MAS09543,Battery Management 2: prohibition on turning-on 48V-Operating mode error,not active,
    IDE11673-MAS09544,Battery Management 2: prohibition on turning-on 48V-No component function,not active,
    IDE11673-MAS09545,Battery Management 2: prohibition on turning-on 48V-Sequence error,not active,
    IDE11674-MAS02246,Voltage transformer: prohibition on turning-on 48V-Timeout,not active,
    IDE11674-MAS09519,Voltage transformer: prohibition on turning-on 48V-Message error,not active,
    IDE11674-MAS09541,Voltage transformer: prohibition on turning-on 48V-Act. mode init. error,not active,
    IDE11674-MAS09542,Voltage transformer: prohibition on turning-on 48V-Error status init. error,not active,
    IDE11674-MAS09543,Voltage transformer: prohibition on turning-on 48V-Operating mode error,not active,
    IDE11674-MAS09544,Voltage transformer: prohibition on turning-on 48V-No component function,not active,
    IDE11674-MAS09545,Voltage transformer: prohibition on turning-on 48V-Sequence error,not active,
    IDE11676-MAS00799,Airbag: prohibition on turning-on 48V-Airbag control module,not active,
    IDE11676-MAS02246,Airbag: prohibition on turning-on 48V-Timeout,not active,
    IDE11676-MAS09519,Airbag: prohibition on turning-on 48V-Message error,not active,
    IDE11676-MAS09521,Airbag: prohibition on turning-on 48V-Light accident detected,not active,
    IDE11676-MAS09522,Airbag: prohibition on turning-on 48V-Severe accident detected,not active,
    IDE11678-MAS02246,Engine electronics: prohibition on turning-on 48V-Timeout,not active,
    IDE11678-MAS09519,Engine electronics: prohibition on turning-on 48V-Message error,not active,
    IDE11678-MAS09541,Engine electronics: prohibition on turning-on 48V-Act. mode init. error,not active,
    IDE11678-MAS09545,Engine electronics: prohibition on turning-on 48V-Sequence error,not active,
    IDE11678-MAS09547,Engine electronics: prohibition on turning-on 48V-Error status drive motor: init. error,not active,
    IDE11678-MAS09548,Engine electronics: prohibition on turning-on 48V-Error status drive: init. error,not active,
    IDE11678-MAS09549,Engine electronics: prohibition on turning-on 48V-Drive condition: init. error,not active,
    IDE11678-MAS09554,Engine electronics: prohibition on turning-on 48V-no component function drive,not active,
    IDE11678-MAS13413,Engine electronics: prohibition on turning-on 48V-No component function of starter generator,not active,
    IDE11678-MAS13415,Engine electronics: prohibition on turning-on 48V-48 V shut-down due to operating strategy,not active,
    IDE11679-MAS02246,Electrical compressor: prohibition on turning-on 48V-Timeout,not active,
    IDE11679-MAS09519,Electrical compressor: prohibition on turning-on 48V-Message error,not active,
    IDE11679-MAS09541,Electrical compressor: prohibition on turning-on 48V-Act. mode init. error,not active,
    IDE11679-MAS09542,Electrical compressor: prohibition on turning-on 48V-Error status init. error,not active,
    IDE11679-MAS09544,Electrical compressor: prohibition on turning-on 48V-No component function,not active,
    IDE11679-MAS09545,Electrical compressor: prohibition on turning-on 48V-Sequence error,not active,
    IDE11679-MAS13455,Electrical compressor: prohibition on turning-on 48V-48 V voltage measurement error,not active,
    IDE11681-MAS03182,Monitoring line disconnection: prohibition on turning-on 48V-Branch 1,not active,
    IDE11681-MAS03183,Monitoring line disconnection: prohibition on turning-on 48V-Branch 2,not active,
    IDE11683-MAS13705,Engine electronics: status of 48V network-Error status of starter generator,Initializing,
    IDE11683-MAS13708,Engine electronics: status of 48V network-Error status of electrical compressor,No error recognized,
    IDE11683-MAS13715,Engine electronics: status of 48V network-Electro compressor mode,Standby-mode,
    IDE11683-MAS13716,Engine electronics: status of 48V network-Error status of drive,No error recognized,
    IDE11683-MAS13717,Engine electronics: status of 48V network-State of drive,OFF,
    IDE11683-MAS13718,Engine electronics: status of 48V network-Handshake,255,
    IDE11684-MAS02832,Battery management 2: status for 48V power-Malfunction status,Initializing,
    IDE11684-MAS03001,Battery management 2: status for 48V power-Mode,Initializing,
    IDE11685-MAS02832,Voltage converter: status for 48V power-Malfunction status,Initializing,
    IDE11685-MAS03001,Voltage converter: status for 48V power-Mode,Initializing,
    IDE11911-MAS00799,48V activation restriction-Airbag control module,not active,
    IDE11911-MAS09516,48V activation restriction-Engine Electronics,not active,
    IDE11911-MAS10933,48V activation restriction-Roll stabilization,not active,
    IDE11911-MAS13411,48V activation restriction-48 V activation restriction due to open circuit,not active,
    IDE11911-MAS13412,48V activation restriction-48 V activation restriction due to deactivation,not active,
    IDE11911-SFT00033,48V activation restriction-Battery Energy Control Module 2,not active,
    IDE11911-SFT00196,48V activation restriction-DC/DC Converter Control Module,not active,
    IDE11911-SFT09769,48V activation restriction-Control module for auxiliary air heater,active,
    IDE11911-SFT09997,48V activation restriction-Electrical Charger,not active,
    IDE12084,Status of component protection slaves,00 14 1B 00 00 00 0E 13 00 00 00 57 13 00 00 00 15 11 00 00 00 4E 13 00 00 00 6F 11 00 00 00 6D 20 00 00 00 73 11 00 00 00 8A 13 00 00 00 2C 20 00 00 00 4F 20 00 00,
    IDE12133-MAS01896,Freewheel - energy-Free run,155, A
    IDE12133-MAS14352,Freewheel - energy-Auxiliary store current,0, A
    IDE12133-MAS14353,Freewheel - energy-Loading release for additional memory,No enabling,
    IDE12133-MAS14357,Freewheel - energy-Generator start mode,First start,
    IDE12133-MAS14362,Freewheel - energy-Voltage limit boost mode,6.0, V
    IDE12134-MAS14344,Freewheel - condition-Status of coasting release,Release,
    IDE12134-MAS14348,Freewheel - condition-Status of freewheel engine off release,Release,
    IDE12134-MAS14349,Freewheel - condition-Freewheel engine off block,0,
    IDE12134-MAS14350,Freewheel - condition-Store request,no request,
    IDE12134-MAS14351,Freewheel - condition-Freewheel engine off restart,0,
    IDE12609-MAS02832,Steering wheel touch recognition: status-Malfunction status,No malfunction detected,
    IDE12609-MAS14836,Steering wheel touch recognition: status-Touch intensity sensor 1,254,
    IDE12609-MAS14837,Steering wheel touch recognition: status-Touch intensity sensor 2,254,
    IDE12609-MAS14838,Steering wheel touch recognition: status-Touch intensity sensor 3,254,
    IDE12609-MAS14839,Steering wheel touch recognition: status-Touch status,Initializing,
    IDE13754-IDE04447,Diagnosis filter: status-Function status,Function active,
    IDE13754-MAS16866,Diagnosis filter: status-Odometer,0, km
    IDE13754-MAS16867,Diagnosis filter: status-Reason for deactivation,Not deactivated,
    IDE13754-MAS16875,Diagnosis filter: status-Filter status,Filter active,
    IDE13755-IDE00056,Diagnosis filter: history data-History data 1,0000240*2019-08-09-17:12:12*1*,
    IDE13755-IDE00057,Diagnosis filter: history data-History data 2,0000000*2019-06-17-19:02:28*6*,
    IDE13755-IDE00058,Diagnosis filter: history data-History data 3,0000000*2000-01-01-00:00:00*0*,
    IDE13755-IDE00059,Diagnosis filter: history data-History data 4,0000000*2000-01-01-00:00:00*0*,
    IDE13755-IDE00060,Diagnosis filter: history data-History data 5,0000000*2000-01-01-00:00:00*0*,
    IDE14424,Historical data info status,11101100 ,
    MAS00464-MAS00106,Standard - ambient data 1-Year,2019,
    MAS00464-MAS00107,Standard - ambient data 1-Month,8,
    MAS00464-MAS00108,Standard - ambient data 1-Day,11,
    MAS00464-MAS00109,Standard - ambient data 1-Hours,16,
    MAS00464-MAS00110,Standard - ambient data 1-Minutes,10,
    MAS00464-MAS00111,Standard - ambient data 1-Seconds,47,
    MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,15,
    MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,500, km
    MAS00769-IDE02717,Multifunction steering wheel control module-Tiptronic upshift,not activated,
    MAS00769-IDE02718,Multifunction steering wheel control module-Tiptronic downshift,not activated,
    MAS00769-IDE07668,Multifunction steering wheel control module-MFL Variant code,3,
    MAS00769-MAS01065,Multifunction steering wheel control module-Brand,Audi,
    MAS00769-MAS01288,Multifunction steering wheel control module-Signal horn,not activated,
    MAS00769-MAS02317,Multifunction steering wheel control module-Button code 1,Not operated,
    MAS00769-MAS02318,Multifunction steering wheel control module-Button code 2,Not operated,
    MAS00769-MAS02319,Multifunction steering wheel control module-Event code 1,No result,
    MAS00769-MAS02320,Multifunction steering wheel control module-Event code 2,No result,
    MAS00769-MAS06029,Multifunction steering wheel control module-MFL message counter,10,
    MAS00769-MAS06030,Multifunction steering wheel control module-MFL Toggle Bit,1,
    MAS00769-MAS06034,Multifunction steering wheel control module-MFL Local active,not active,
    MAS00769-MAS06035,Multifunction steering wheel control module-MFL M button,not activated,
    MAS04447-IDE06339,Engine running status-Hybrid readiness: status,not active,
    MAS04447-MAS01493,Engine running status-Engine running,Engine off,
    MAS04447-MAS03023,Engine running status-Driving mode,not active,
    MAS04447-MAS06320,Engine running status-Status rolling mode,not active,
    SFT09757,Alternator,-,
    SFT09757-ENG119789,Alternator-alternator_family,31,
    SFT09757-ENG114913,Alternator-asic_manufacturer,30 31,
    SFT09757-ENG119379,Alternator-asic_variant,30 34,
    SFT09757-ENG40398,Alternator-Manufacturer,30 31,
    SFT09757-ENG99001,Alternator-Variant,30 39,
    ENG118785-ENG118741,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Error_Indication,0,
    ENG118785-ENG118742,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Indication_State,0,
    ENG118785-ENG118743,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Request_State,0,
    ENG118785-ENG118744,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Request_State_Value,0,
    ENG118784-ENG124497,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Actuator_Exterior_Noise,not active,
    ENG118784-ENG118736,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Adaptive_Cruise_Control,not active,
    ENG118784-ENG06039,Driv._Prof._Sel._Coord._Retry_State-Retry_State_AGK,not active,
    ENG118784-ENG124493,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Air_Condition,not active,
    ENG118784-ENG118739,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Ambient_Illumination,not active,
    ENG118784-ENG124501,Driv._Prof._Sel._Coord._Retry_State-Retry_State_area_view,not active,
    ENG118784-ENG124495,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Belt_Pretensioner,not active,
    ENG118784-ENG124499,Driv._Prof._Sel._Coord._Retry_State-Retry_State_brake_control_system,not active,
    ENG118784-ENG124503,Driv._Prof._Sel._Coord._Retry_State-Retry_State_central_differential,not active,
    ENG118784-ENG118734,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Damper_Control,not active,
    ENG118784-ENG06040,Driv._Prof._Sel._Coord._Retry_State-Retry_State_EDS,not active,
    ENG118784-ENG126254,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Electronic_Brake_Booster,not active,
    ENG118784-ENG118730,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Engine_Control,not active,
    ENG118784-ENG20970,Driv._Prof._Sel._Coord._Retry_State-Retry_State_FMA,not active,
    ENG118784-ENG124498,Driv._Prof._Sel._Coord._Retry_State-Retry_State_front_axle_differential_lock,not active,
    ENG118784-ENG124500,Driv._Prof._Sel._Coord._Retry_State-Retry_State_hill_descent_control,not active,
    ENG118784-ENG06038,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Hill_Distence_Control,not active,
    ENG118784-ENG124494,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Lighting_Control,not active,
    ENG118784-ENG126252,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Operation_Mode,not active,
    ENG118784-ENG124496,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Overrunning_Clutch,not active,
    ENG118784-ENG06036,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Park_Distence_Control,not active,
    ENG118784-ENG126251,Driv._Prof._Sel._Coord._Retry_State-Retry_State_range_Calculation,not active,
    ENG118784-ENG124502,Driv._Prof._Sel._Coord._Retry_State-Retry_State_rear_spoiler,not active,
    ENG118784-ENG126253,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Seat_Sidebolster_Adjustment,not active,
    ENG118784-ENG118737,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Sound_Actuator,not active,
    ENG118784-ENG124492,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Start_/_Stop,not active,
    ENG118784-ENG118733,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Steering_Support,not active,
    ENG118784-ENG118732,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Transmission_Control,not active,
    ENG118786-ENG06057,Driv._Prof._Sel._Dr._Op.-Drehsteller_Ist_Modus,0,
    ENG118786-ENG06058,Driv._Prof._Sel._Dr._Op.-Drehsteller_Modus,0,
    ENG118786-ENG06061,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_HVEM,0,
    ENG118786-ENG06063,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Mo_BZS,0,
    ENG118786-ENG06062,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Step_Reduction,0,
    ENG118786-ENG06060,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Trailer,0,
    ENG118786-ENG06059,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Modus,not recognized,
    ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not recognized,
    ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,2,
    ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,not active,
    ENG118766,eASS_operation_status,Emergency running mode,
    ENG06004-ENG118763,EM_battery_analog_monitoring-actual_difference_voltage,0.000, V
    ENG06004-ENG118760,EM_battery_analog_monitoring-battery_analog_voltage,0.0, V
    ENG06004-ENG118765,EM_battery_analog_monitoring-battery_off_counter,0,
    ENG06004-ENG118764,EM_battery_analog_monitoring-battery_off_status_intern,connected,
    ENG06004-ENG118761,EM_battery_analog_monitoring-battery_voltage_filtered,4.0, V
    ENG06004-ENG118762,EM_battery_analog_monitoring-voltage_difference,0.00, V
    ENG106123,EM_blAlternator On,OFF,
    ENG106124,EM_blAlternator Valid,Yes,
    ENG106140,EM_Current_Control_Recu,not active,
    ENG20108,EM_electrical_system_current,17.593, A
    ENG118437,EM_IAlternatorReserve,0.0, A
    ENG118434,EM_LoadResponse Time,6, s
    ENG106154,EM_PAltMechanical,0, W
    ENG106155-ENG118436,EM_prcSoh-SOH_P,95, %
    ENG106155-ENG118435,EM_prcSoh-SOH_Q,76, %
    ENG106157,EM_RecuMode_Engine,Neutral,
    ENG118780-ENG115189,EM_Recuperation_Precondition-48V_emergency_run,0,
    ENG118780-ENG118443,EM_Recuperation_Precondition-acid_lamination,1,
    ENG118780-ENG118438,EM_Recuperation_Precondition-available_charge,1,
    ENG118780-ENG118442,EM_Recuperation_Precondition-battery_aging_charge,1,
    ENG118780-ENG118441,EM_Recuperation_Precondition-battery_aging_power,1,
    ENG118780-ENG118440,EM_Recuperation_Precondition-battery_charging_state,0,
    ENG118780-ENG118447,EM_Recuperation_Precondition-battery_regeneration,1,
    ENG118780-ENG103388,EM_Recuperation_Precondition-battery_temperature,1,
    ENG118780-ENG112320,EM_Recuperation_Precondition-Battery_Voltage,1,
    ENG118780-ENG36229,EM_Recuperation_Precondition-climate_electronics_enable,1,
    ENG118780-ENG118448,EM_Recuperation_Precondition-energy_net,1,
    ENG118780-ENG118445,EM_Recuperation_Precondition-generator_diagnosis,1,
    ENG118780-ENG118449,EM_Recuperation_Precondition-idle_increase,1,
    ENG118780-ENG36251,EM_Recuperation_Precondition-kfg_enable,1,
    ENG118780-ENG118439,EM_Recuperation_Precondition-LIN_communication,1,
    ENG118780-ENG118450,EM_Recuperation_Precondition-special_veto,0,
    ENG118781-ENG118673,EM_Recuperation_Restriction-component_protection_engine,0,
    ENG118781-ENG118675,EM_Recuperation_Restriction-component_protection_EPS,0,
    ENG118781-ENG118674,EM_Recuperation_Restriction-component_protection_ESP,0,
    ENG118781-ENG118672,EM_Recuperation_Restriction-component_protection_high_beam_light,0,
    ENG118781-ENG118668,EM_Recuperation_Restriction-inside_light_active,0,
    ENG118781-ENG118670,EM_Recuperation_Restriction-left_turn_signal_active,0,
    ENG118781-ENG121521,EM_Recuperation_Restriction-limited_by_48V_consumer,0,
    ENG118781-ENG107413,EM_Recuperation_Restriction-low_beam_light_active,0,
    ENG118781-ENG110583,EM_Recuperation_Restriction-PLA,0,
    ENG118781-ENG113826,EM_Recuperation_Restriction-RekuLight,0,
    ENG118781-ENG118669,EM_Recuperation_Restriction-right_turn_signal_active,0,
    ENG118781-ENG36309,EM_Recuperation_Restriction-voltage_requirement_bcm,0,
    ENG118781-ENG36310,EM_Recuperation_Restriction-voltage_Requirement_kfg,0,
    ENG118781-ENG118667,EM_Recuperation_Restriction-workload_inside_blaster,0,
    ENG118782-ENG118462,Gateway app. software identification-software_version_BCmE,1004,
    ENG118782-ENG118457,Gateway app. software identification-software_version_eASS,2030,
    ENG118782-ENG06026,Gateway app. software identification-software_version_ehr,----,
    ENG118782-ENG118454,Gateway app. software identification-software_version_em,2407,
    ENG118782-ENG118453,Gateway app. software identification-software_version_fpa,0970,
    ENG118782-ENG118455,Gateway app. software identification-software_version_history_data,0500,
    ENG118782-ENG125888,Gateway app. software identification-software_version_hv-em,----,
    ENG118782-ENG118456,Gateway app. software identification-software_version_ks,----,
    ENG118782-ENG118458,Gateway app. software identification-software_version_mfl,0200,
    ENG118782-ENG118463,Gateway app. software identification-software_version_mke,3148,
    ENG118782-ENG32644,Gateway app. software identification-software_version_mv-em,0400,
    ENG118782-ENG32645,Gateway app. software identification-software_version_rtm,----,
    ENG118782-ENG122591,Gateway app. software identification-software_version_rwb,----,
    ENG118782-ENG118459,Gateway app. software identification-software_version_service_key_1a,0100,
    ENG118782-ENG118460,Gateway app. software identification-software_version_SWaP,0660,
    ENG118782-ENG118461,Gateway app. software identification-software_version_wakeup_monitor,0400,
    ENG118782-ENG118452,Gateway app. software identification-version_routing_gateway,7200,
    ENG118666,MKE_HFC_filtrated,1.0,
    ENG126247-ENG126257,MKE_TTNR-TTNR_DS,60021,
    ENG126247-ENG126256,MKE_TTNR-TTNR_SW,60040,
    ENG20113-ENG09375,MV-EM_48V_electrical_system_components-48V_Ptc_installed,installed,
    ENG20113-ENG09374,MV-EM_48V_electrical_system_components-48V_Rsg_installed,installed,
    ENG20113-ENG09370,MV-EM_48V_electrical_system_components-DcDc_installed,not installed,
    ENG20113-ENG09372,MV-EM_48V_electrical_system_components-eAbc_installed,not installed,
    ENG20113-ENG09373,MV-EM_48V_electrical_system_components-eAv_installed,installed,
    ENG20113-ENG09371,MV-EM_48V_electrical_system_components-eAws_installed,installed,
    ENG20113-ENG09369,MV-EM_48V_electrical_system_components-LiIon_battery_installed,installed,
    ENG20113-ENG09368,MV-EM_48V_electrical_system_components-sCap_installed,not installed,
    ENG20114-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_1-Measurement,Unknown (234),
    ENG20114-ENG09348,MV-EM_48V_electrical_system_diagnosis_typ_1-48V_electrical_system_diagnosis_request,Unknown (136),
    ENG20114-ENG09349,MV-EM_48V_electrical_system_diagnosis_typ_1-Bms_48V_actual_current,57974, A
    ENG20115-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_2-Measurement,not OK,
    ENG20115-ENG09351,MV-EM_48V_electrical_system_diagnosis_typ_2-48V_electrical_system_active,not active,
    ENG20115-ENG09344,MV-EM_48V_electrical_system_diagnosis_typ_2-Bms_48V_actual_voltage,0.00, V
    ENG20115-ENG09352,MV-EM_48V_electrical_system_diagnosis_typ_2-DcDc_48V_actual_voltage,Initializing,
    ENG20115-ENG09356,MV-EM_48V_electrical_system_diagnosis_typ_2-eAbc_back_48V_actual_voltage,0.00, V
    ENG20115-ENG09355,MV-EM_48V_electrical_system_diagnosis_typ_2-eAbc_front_48V_actual_voltage,0.00, V
    ENG20115-ENG09357,MV-EM_48V_electrical_system_diagnosis_typ_2-eAv_48V_actual_voltage,0.00, V
    ENG20115-ENG09354,MV-EM_48V_electrical_system_diagnosis_typ_2-eAws_back_48V_actual_voltage,0.00, V
    ENG20115-ENG09353,MV-EM_48V_electrical_system_diagnosis_typ_2-eAws_front_48V_actual_voltage,0.00, V
    ENG20115-ENG09358,MV-EM_48V_electrical_system_diagnosis_typ_2-Rsg_48V_actual_voltag,Initializing,
    ENG20116-MAS01867,MV-EM_48V_overvoltage_check-Measurement,not OK,
    ENG20116-ENG09344,MV-EM_48V_overvoltage_check-Bms_48V_actual_voltage,0.00, V
    ENG20116-ENG09345,MV-EM_48V_overvoltage_check-Bms_48V_Soc,12.70, %
    ENG20117-MAS11874,MV-EM_48V_Zero_potential_status-Overall status,Initializing,
    ENG20118-ENG09366,MV-EM_coldstart_requirement_engine-requirement_12V_start,not active,
    ENG20118-ENG09367,MV-EM_coldstart_requirement_engine-requirement_48V_start,not active,
    ENG20119,MV-EM_dc_current_Mv,-204.0, A
    ENG20120,MV-EM_dc_power_desired,-6325, W
    ENG20121,MV-EM_DC_voltage_desired,0.00, V
    ENG20122,MV-EM_dc_voltage_Mv,0.00, V
    ENG20123-ENG09198,MV-EM_Derating_voltage-Derating_group_A,0.00, V
    ENG20123-ENG09199,MV-EM_Derating_voltage-Derating_group_B,0.00, V
    ENG20123-ENG09200,MV-EM_Derating_voltage-Derating_group_C,0.00, V
    ENG20123-ENG09337,MV-EM_Derating_voltage-Derating_Umax_feedback,63.50, V
    ENG20124,MV-EM_EMG_level_of_capacity,0.025, %
    ENG20125,MV-EM_Mv_current,-511, A
    ENG20126-ENG09342,MV-EM_recommendation_Dcdc-Dcdc_boost_mode,not active,
    ENG20126-ENG09343,MV-EM_recommendation_Dcdc-Dcdc_buck_mode,not active,
    ENG20127-ENG09338,MV-EM_release-12V_coldstart_release,No enabling,
    ENG20127-ENG09339,MV-EM_release-12V_warmstart_release,No enabling,
    ENG20127-ENG09340,MV-EM_release-48V_coldstart_release,No enabling,
    ENG20127-ENG09341,MV-EM_release-start_stopp_support_release,No enabling,
    ENG20128,MV-EM_RSG_maximal_current,0, A
    ENG20129,MV-EM_RSG_maximal_voltage,0.00, V
    ENG119298-ENG119462,NVEM_Grund_BEM_falsch_codiert-Grund_BEM_falsch_codiert,0,
    Elapsed Time: 00:48
  3. #13
    Aug 2019
    Toronto, Canada
    22 - AWD
    ADPmap - 22 - AWD
    ;SW:0CQ-907-554-K   HW:0CQ-525-130 ---  AWD
    ;Component:Haldex4Motion H55 7762, Coding:0601
    ;EV_AllWheelContrHA1VW37X,002015,EV_AllWheelContrHA1VW37X.rod
    ;Sunday,11,August,2019,16:19:51:40778
    ;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
    ;VCID: 4DD2A5261C4E542722-8018
    IDE07843-MAS06099-Acoustic measure: gasoline-Acoustic measure: anti droning,Keine Maflnahme ,2
    IDE07843-MAS06100-Acoustic measure: gasoline-Acoustic measure: anti impact wrench,Keine Maflnahme ,2
    IDE07844-MAS06099-Acoustic measure: diesel-Acoustic measure: anti droning,Keine Maflnahme ,2
    IDE07844-MAS06100-Acoustic measure: diesel-Acoustic measure: anti impact wrench,Keine Maflnahme ,2
    MAS06098-Acoustic measure: wiring logic,Standard ,1
    Elapsed Time: 00:01
    Blockmap - 22 - AWD
    ;Sunday,11,August,2019,16:19:48:40778
    Group,Description,Actual
    IDE00019,Voltage terminal 30,11.9, V
    IDE00030,Status of actuator test,not active,
    IDE00102,Control Module temperature,28, ∞C
    IDE00322,Status of basic setting,was not yet started,
    IDE00323,Security Access: Number of invalid keys,0,
    IDE00920,Front left wheel speed,0.0, km/h
    IDE00921,Front right wheel speed,0.0, km/h
    IDE00922,Left rear wheel speed,0.0, km/h
    IDE00923,Right rear wheel speed,0.0, km/h
    IDE01617,Clutch temperature,29.50, ∞C
    IDE02271-IDE02384,CAN output signal(s) status-Status of event memory,not active,
    IDE02271-MAS01464,CAN output signal(s) status-Emergency running mode,active,
    IDE02271-MAS01480,CAN output signal(s) status-Excess temp.,not active,
    IDE02404,Checksum calculation,52 63 B0 3C,
    IDE02486,Data logger triggering,not active,
    IDE04502-MAS04730,Haldex clutch status-Degree of blockage,0.00, %
    IDE05609,Cooling fin temperature,27.90, ∞C
    IDE05610,Duration of overtemperature,0, min
    IDE05707,Haldex clutch pump current,0.005, A
    IDE05708,Haldex clutch pump PWM signal,0, %
    IDE05710,Haldex clutch pump voltage,0.0, V
    IDE06111,Axle speed deltas,0.0, km/h
    IDE06425,Roller test bench mode: functional,not activated,
    IDE80003-ENG119372,Analysis 3-Exeedance_Intergral_1_traction_slip_controller,0,
    IDE80003-ENG119373,Analysis 3-Exeedance_Intergral_2_extreme_slip_event,0,
    IDE80003-ENG119374,Analysis 3-Undercut_Integral_3_differential_lock_too_far_closed,0,
    IDE80004-ENG119372,Analysis 4-Exeedance_Intergral_1_traction_slip_controller,0,
    IDE80004-ENG119373,Analysis 4-Exeedance_Intergral_2_extreme_slip_event,0,
    IDE80004-ENG119374,Analysis 4-Undercut_Integral_3_differential_lock_too_far_closed,0,
    MAS00464-MAS00110,Standard - ambient data 1-Minutes,19,
    MAS00464-MAS00111,Standard - ambient data 1-Seconds,49,
    MAS03129,Reset counter,5,
    ENG119394-ENG119379,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Current_EEPROM,1451,
    ENG119394-ENG119380,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Current_Last_Measurement,0,
    ENG119394-ENG119378,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Pressure_EEPROM,0,
    ENG119394-ENG119381,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Voltage_EEPROM,2201,
    ENG119394-ENG119382,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Voltage_Last_Measurement,0,
    ENG119394-ENG119384,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Current_EEPROM,4941,
    ENG119394-ENG119385,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Current_Interpolation,0,
    ENG119394-ENG119383,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Pressure_EEPROM,15,
    ENG119394-ENG119386,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Voltage_EEPROM,4982,
    ENG119394-ENG119387,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Voltage_Interpolation,0,
    ENG119394-ENG119389,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Current_EEPROM,9537,
    ENG119394-ENG119390,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Current_Last_Measurement,0,
    ENG119394-ENG119388,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Pressure_EEPROM,35,
    ENG119394-ENG119391,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Voltage_EEPROM,7532,
    ENG119394-ENG119392,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Voltage_Last_Measurement,0,
    ENG119394-ENG119377,Pump_Calibration_Values-Series_Number_Pump,12033235,
    ENG119394-ENG119376,Pump_Calibration_Values-Temperature_Value_at_Calibration,33, ∞C
    ENG119375,Upper Limit of Temperature Duration,0, min
    Elapsed Time: 00:03
  4. #14
    Aug 2019
    Toronto, Canada
    29 - Left Light
    ADPmap - 29 - Left Light
    ;SW:8S0-907-397-D   HW:8S0-907-397-D ---  Left Light
    ;Component:LCM_MQB       H07 0022, Coding:
    ;EV_LCMLeftCONTIAU426,001009,EV_LCMLeftCONTIAU426_VW41.rod
    ;Sunday,11,August,2019,16:19:58:40778
    ;VCID: 42C8861AD5109B5FCF-8016
    IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not activated ,1
    IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not activated ,1
    IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not activated ,1
    IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,not activated ,1
    IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,not activated ,1
    IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,not activated ,1
    IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,not activated ,1
    IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,not activated ,1
    IDE01550-Service position,not active ,1
    Elapsed Time: 00:01
    Blockmap - 29 - Left Light
    ;Sunday,11,August,2019,16:19:54:40778
    IDE00767-MAS01478,No. of unscheduled ECU resets-Insuff. voltage,247,
    IDE00767-MAS03945,No. of unscheduled ECU resets-Watchdog Reset,1,
    IDE00773,Terminal 15 status via CAN,On,
    IDE03680-MAS01468,Supply voltages-Terminal 15,Not available,
    IDE03680-MAS09376,Supply voltages-Supply via vehicle elec. sys. ctrl. unit,11.80, V
    IDE06876-MAS01482,Signature light bulb-Hardwareversion,not installed,
    IDE06876-MAS01483,Signature light bulb-Softwareversion,not installed,
    IDE06876-MAS12381,Signature light bulb-Software subversion,0F,
    IDE06876-ENG14244,Signature light bulb-Software_sub_version_Textual,Not available,
    IDE06926-IDE02068,History memory: reset counter-Time stamp,EA F9 16 4E 00,
    IDE06926-MAS09176,History memory: reset counter-Reset reason,Watchdog Reset,
    IDE08742-MAS01155,Operating time-Control module,15.33, H
    IDE08742-MAS03835,Operating time-Parking light,5.71, H
    IDE08742-MAS09325,Operating time-Daytime running lights,6.99, H
    IDE08742-MAS09330,Operating time-Cover for low beam headlight,0.00, H
    IDE08742-MAS09332,Operating time-Turn signal,0.55, H
    IDE08742-MAS09333,Operating time-Side-marker light,5.70, H
    IDE08742-MAS09334,Operating time-Parking light,0.00, H
    IDE09492-MAS01155,Temperatures-Control module,63.00, ∞C
    IDE09492-MAS09339,Temperatures-extern. temperature sensor 1,84.00, ∞C
    IDE09492-MAS09340,Temperatures-extern. temperature sensor 2,74.00, ∞C
    IDE09768-MAS04121,LED channel 1-Voltage,15.82, V
    IDE09768-MAS04136,LED channel 1-Current,896, mA
    IDE09768-MAS09022,LED channel 1-PWM value,89.00, %
    IDE09768-MAS09327,LED channel 1-LED brightness class,2,
    IDE09768-MAS09328,LED channel 1-Primary function,Daytime running lights,
    IDE09768-MAS09329,LED channel 1-Secondary function,Daytime running lights,
    IDE09769-MAS04121,LED channel 2-Voltage,0.00, V
    IDE09769-MAS04136,LED channel 2-Current,0, mA
    IDE09769-MAS09022,LED channel 2-PWM value,0.00, %
    IDE09769-MAS09327,LED channel 2-LED brightness class,3,
    IDE09769-MAS09328,LED channel 2-Primary function,Turn signal,
    IDE09769-MAS09329,LED channel 2-Secondary function,Turn signal,
    IDE09770-MAS04136,High side channel 1-Current,0, mA
    IDE09770-MAS09022,High side channel 1-PWM value,0.00, %
    IDE09770-MAS09326,High side channel 1-Function,no function,
    IDE09771-MAS04136,High side channel 2-Current,0, mA
    IDE09771-MAS09022,High side channel 2-PWM value,0.00, %
    IDE09771-MAS09326,High side channel 2-Function,no function,
    IDE09772-MAS04136,High side channel 3-Current,0, mA
    IDE09772-MAS09022,High side channel 3-PWM value,0.00, %
    IDE09772-MAS09326,High side channel 3-Function,Side-marker light,
    IDE09774-MAS03835,Number of activations-Parking light,61,
    IDE09774-MAS09325,Number of activations-Daytime running lights,212,
    IDE09774-MAS09330,Number of activations-Cover for low beam headlight,0,
    IDE09774-MAS09332,Number of activations-Turn signal,5056,
    IDE09774-MAS09333,Number of activations-Side-marker light,60,
    IDE09774-MAS09334,Number of activations-Parking light,0,
    IDE09775-MAS09336,High temperature operating times for control unit-∞C,3.60, H
    IDE09775-MAS09337,High temperature operating times for control unit-between 105∞C and 115∞C,1.84, H
    IDE09775-MAS09338,High temperature operating times for control unit-over 115∞C,1.37, H
    IDE09795-MAS09342,Operating times for motor of headlight range adjustment-between 0% and 30%,82.75, %
    IDE09795-MAS09343,Operating times for motor of headlight range adjustment-between 30% and 60%,0.00, %
    IDE09795-MAS09344,Operating times for motor of headlight range adjustment-over 60%,0.00, %
    IDE09828-MAS00890,Head lamp variant-via CAN,E0 44,
    IDE09828-MAS01155,Head lamp variant-Control module,E0 44,
    IDE09916-MAS09563,Data set names-Number of data set names,01,
    IDE09916-MAS09564,Data set names-Data set ID,28929,
    IDE09916-MAS09565,Data set names-Data set name,A3PALEDSWSAE,
    IDE10175,Capturing statistic data: status,active,
    IDE10301-MAS01155,Number of excess temp. protection activations-Control module,0,
    IDE10301-MAS03835,Number of excess temp. protection activations-Parking light,0,
    IDE10301-MAS09325,Number of excess temp. protection activations-Daytime running lights,11,
    IDE10301-MAS09332,Number of excess temp. protection activations-Turn signal,82,
    IDE11124-MAS12195,Headlight beam adjusting motor-Reference run status,performed,
    IDE11124-MAS12196,Headlight beam adjusting motor-Fault position,not approached,
    IDE11124-MAS12199,Headlight beam adjusting motor-Adjustment speed,normal,
    IDE11124-MAS12206,Headlight beam adjusting motor-Motor position (percent of max. adjustment stroke),46.80, %
    IDE11124-MAS12207,Headlight beam adjusting motor-Low beam inclination,-18.50, mm
    IDE11125-MAS12195,Dynamic cornering light adjusting motor-Reference run status,not performed,
    IDE11125-MAS12196,Dynamic cornering light adjusting motor-Fault position,not approached,
    IDE11125-MAS12199,Dynamic cornering light adjusting motor-Adjustment speed,normal,
    IDE11125-MAS12206,Dynamic cornering light adjusting motor-Motor position (percent of max. adjustment stroke),0.00, %
    IDE11125-MAS12209,Dynamic cornering light adjusting motor-Swivel angle,Unknown,
    IDE11276-MAS01482,Power output stage for headlamp aux. functions-Hardwareversion,not installed,
    IDE11276-MAS01483,Power output stage for headlamp aux. functions-Softwareversion,not installed,
    IDE11276-MAS12381,Power output stage for headlamp aux. functions-Software subversion,0F,
    IDE11276-ENG14244,Power output stage for headlamp aux. functions-Software_sub_version_Textual,Not available,
    IDE11347-MAS12195,Variable headlamp positioning motor-Reference run status,not performed,
    IDE11347-MAS12196,Variable headlamp positioning motor-Fault position,not approached,
    IDE11347-MAS12199,Variable headlamp positioning motor-Adjustment speed,normal,
    IDE11347-MAS12212,Variable headlamp positioning motor-Calibrated light index setting,Unknown,
    Elapsed Time: 00:03
  5. #15
    Aug 2019
    Toronto, Canada
    39 - Right Light
    ADPmap - 39 - Right Light
    ;SW:8S0-907-397-D   HW:8S0-907-397-D ---  Right Light
    ;EV_LCMRightCONTIAU426,001009,EV_LCMLeftCONTIAU426_VW41.rod
    ;Sunday,11,August,2019,16:20:12:40778
    Elapsed Time: 00:01
    Blockmap - 39 - Right Light
    ;Sunday,11,August,2019,16:20:09:40778
    IDE00767-MAS01478,No. of unscheduled ECU resets-Insuff. voltage,Overflow,
    IDE03680-MAS09376,Supply voltages-Supply via vehicle elec. sys. ctrl. unit,11.70, V
    IDE08742-MAS01155,Operating time-Control module,14.99, H
    IDE08742-MAS03835,Operating time-Parking light,5.70, H
    IDE08742-MAS09325,Operating time-Daytime running lights,7.06, H
    IDE08742-MAS09332,Operating time-Turn signal,0.52, H
    IDE09492-MAS01155,Temperatures-Control module,62.00, ∞C
    IDE09492-MAS09340,Temperatures-extern. temperature sensor 2,72.00, ∞C
    IDE09768-MAS04121,LED channel 1-Voltage,16.17, V
    IDE09774-MAS03835,Number of activations-Parking light,60,
    IDE09774-MAS09325,Number of activations-Daytime running lights,202,
    IDE09774-MAS09332,Number of activations-Turn signal,4875,
    IDE09774-MAS09333,Number of activations-Side-marker light,59,
    IDE09775-MAS09336,High temperature operating times for control unit-∞C,4.70, H
    IDE09775-MAS09337,High temperature operating times for control unit-between 105∞C and 115∞C,2.65, H
    IDE09775-MAS09338,High temperature operating times for control unit-over 115∞C,1.93, H
    IDE09795-MAS09342,Operating times for motor of headlight range adjustment-between 0% and 30%,82.79, %
    IDE10301-MAS09325,Number of excess temp. protection activations-Daytime running lights,25,
    IDE10301-MAS09332,Number of excess temp. protection activations-Turn signal,102,
    Elapsed Time: 00:03
  6. #16
    Aug 2019
    Toronto, Canada
    42 - Door Elect, Driver
    ADPmap - 42 - Door Elect, Driver
    ;SW:5Q0-959-593-F   HW:5Q0-959-593-F ---  Door Elect, Driver
    ;Component:TSG FS002 0287, Coding:005E1B205000008000000002
    ;EV_DCU2DriveSideMAXHKLO,001010,EV_DCU2DriveSideMAXHCONT_VW37.rod
    ;Sunday,11,August,2019,16:20:33:40778
    ;VCID: 44C48002CF04956FFD-8010
    IDE00001-MAS10864-Production mode-Reduce reverse threshold,Deactivating ,3
    IDE00001-MAS10865-Production mode-Power windows operable with terminal 15 off,Deactivating ,3
    IDE00001-MAS10866-Production mode-Reduce switch-on time of lighting,Deactivating ,3
    IDE00001-MAS10867-Production mode-Deactivate speed control for power windows,Deactivating ,3
    IDE00001-MAS10868-Production mode-Deactivate closing aid,Deactivating ,3
    IDE00001-MAS10869-Production mode-Activate test mode for the fold-in mirror,Deactivating ,3
    IDE00001-MAS10870-Production mode-Activate test mode for power windows,Deactivating ,3
    IDE00001-MAS17286-Production mode-Deactivation of actuation of opening assistance motor: e-lock,Deactivating ,3
    IDE00001-MAS17291-Production mode-Deactivation of CarWakeUp due to activation of seatbelt feeder,Deactivating ,3
    IDE09067-Side window shade: service mode,Deactivating ,1
    ENG117297-Reversing_Threshold_Driver_Side_Front,90 %,1
    ENG117299-Reversing_Threshold_Driver_Side_Rear,90 %,1
    Elapsed Time: 00:02
    Blockmap - 42 - Door Elect, Driver
    ;Sunday,11,August,2019,16:20:26:40778
    IDE00310,Outside air temperature,26.00, ∞C
    IDE01766-MAS02248,Distance impulses-Signal state,OK,
    IDE01992-MAS12276,Installation list: current installations-Front door control module,can be reached,
    IDE01992-MAS12277,Installation list: current installations-Rear door control module,can be reached,
    IDE01993-MAS12276,Control module reference number-Front door control module,Driver side door control module,
    IDE01993-MAS12277,Control module reference number-Rear door control module,Driver side rear door control module,
    IDE02262,synchronous mirror adjustment,not installed,
    IDE02267-IDE00773,Supply voltage for door control module: front: driver side-Terminal 15 status via CAN,active,
    IDE02267-IDE01715,Supply voltage for door control module: front: driver side-Status terminal S,active,
    IDE02267-IDE05835,Supply voltage for door control module: front: driver side-Supply voltage for central locking,11.60, V
    IDE02384-MAS12276,Status of event memory-Front door control module,No malfunctions in DTC memory,
    IDE02384-MAS12277,Status of event memory-Rear door control module,No malfunctions in DTC memory,
    IDE02668,Central window regulator switch,not installed,
    IDE03150-MAS12276,Readiness for bus sleep mode-Front door control module,active,
    IDE03150-MAS12277,Readiness for bus sleep mode-Rear door control module,Sleep mode,
    IDE04215-MAS02428,Mirror adjustment switch-Switch positions,Neutral,
    IDE04216-MAS01458,Mirror heater-Operating condition,not active,
    IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
    IDE04216-MAS04247,Mirror heater-Button,not activated,
    IDE04217,Fuel filler door release button,not installed,
    IDE04218,Turn signal in exterior rear-view mirror,not active,
    IDE04219-IDE02266,Window regulator control unit: driver side-Passenger side rear power window button,not activated,
    IDE04219-IDE04220,Window regulator control unit: driver side-Driver power window button,not activated,
    IDE04219-IDE06621,Window regulator control unit: driver side-Driver side rear power window button,not activated,
    IDE04219-IDE06872,Window regulator control unit: driver side-Front passenger power window button,not activated,
    IDE04220,Driver power window button,not activated,
    IDE04343-MAS03180,Bus identification-Local data bus,assigned,
    IDE04343-MAS12276,Bus identification-Front door control module,Busmaster,
    IDE04411,Child Safety Lock Switch,not activated,
    IDE04539-MAS01634,Mirror memory-Supply voltage,not active,
    IDE04539-MAS02228,Mirror memory-X coordinate,Not available,
    IDE04539-MAS02229,Mirror memory-Y coordinate,Not available,
    IDE04539-MAS02476,Mirror memory-install,not installed,
    IDE04540,Mirror adjustment (X/Y-direction),Position center,
    IDE04580,Dimming of inside door handle lighting,100, %
    IDE04581,Dimming for interior ambient lighting,Not available,
    IDE04586,Mirror fold-in activation,not active,
    IDE05071-MAS02594,Lane change assistance button-Indicator light in switch,not installed,
    IDE05071-MAS07693,Lane change assistance button-Button Status,Implausible,
    IDE05720-IDE02589,Front driver side door status-Rotary latch status,closed,
    IDE05720-IDE04213,Front driver side door status-Central locking button,not activated,
    IDE05720-IDE04214,Front driver side door status-Key switch in door lock,not activated,
    IDE05720-MAS06256,Front driver side door status-Status door lock,Signal from door lock: released,
    IDE05725,Terminal 58xs dimmer,0, %
    IDE05726,Terminal 58xd dimmer,100, %
    IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,No,
    IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,No,
    IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
    IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Yes,
    IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,OFF,
    IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not activated,
    IDE06206-MAS01453,Front window regulator status: driver side-Blocking detection,not active,
    IDE06206-MAS02039,Front window regulator status: driver side-Force limitation,not active,
    IDE06206-MAS02097,Front window regulator status: driver side-Window position,96.00, %
    IDE06206-MAS02098,Front window regulator status: driver side-Power window control standardized,Yes,
    IDE06206-MAS03548,Front window regulator status: driver side-Motor current,0, A
    IDE06206-MAS04642,Front window regulator status: driver side-Before upper stop,not active,
    IDE06206-MAS05370,Front window regulator status: driver side-Direction of movement,Idle condition,
    IDE06469,Ambient illumination for speaker,0, %
    IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not installed,
    IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not installed,
    IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not installed,
    IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not installed,
    IDE06933,Front window regulator relay: driver side,Open,
    IDE06937-MAS02545,Front window regulator reversing position: driver side-Last,127.50, %
    IDE06937-MAS02546,Front window regulator reversing position: driver side-Second to last,127.50, %
    IDE06937-MAS02547,Front window regulator reversing position: driver side-Third to last,127.50, %
    IDE06937-MAS02548,Front window regulator reversing position: driver side-Fourth to last,127.50, %
    IDE06937-MAS05380,Front window regulator reversing position: driver side-fifth to last,127.50, %
    IDE07222,Window regulator child lock: driver side,Not available,
    IDE07405-IDE03114,Enable driver front window regulator relay-Comfort function,No,
    IDE07405-MAS02447,Enable driver front window regulator relay-Release,Yes,
    IDE07409-MAS01632,Excessive temper. disconnect: front window regulator: driv.side-Status,not active,
    IDE07409-MAS02955,Excessive temper. disconnect: front window regulator: driv.side-Engine temperature,23, ∞C
    IDE07413,Comfort function for front window regulator: driver side,not active,
    IDE07543,Vehicle speed,0.00, km/h
    IDE08061,Child safety lock button 2,not installed,
    IDE08205-MAS01453,Pull-shut asst.-Blocking detection,not active,
    IDE08205-MAS02103,Pull-shut asst.-Signal from door lock: catch,Implausible,
    IDE08205-MAS05370,Pull-shut asst.-Direction of movement,Not available,
    IDE08205-MAS08613,Pull-shut asst.-Return contact,closed,
    IDE08205-MAS08614,Pull-shut asst.-Closing assist motor current,Not available,
    IDE08205-MAS09346,Pull-shut asst.-Door position,closed,
    IDE08205-MAS09347,Pull-shut asst.-Redundant door contact,not installed,
    IDE08697-MAS07302,Number of driving cycles without opening door-Max. number of driving cycles without opening door,0,
    IDE08697-MAS07303,Number of driving cycles without opening door-Actual number of driving cycles without opening door,0,
    IDE08795,Button for rear window shade,not installed,
    IDE09071-MAS00030,Belt feeder-Seat occupied recognition,not active,
    IDE09071-MAS02666,Belt feeder-Seat belt buckle scan,Open,
    IDE09071-MAS05370,Belt feeder-Direction of movement,Not available,
    IDE09071-MAS08502,Belt feeder-Standardized belt feeder,No,
    IDE09071-MAS08503,Belt feeder-End stop of Hall sensor,not recognized,
    IDE09071-MAS08504,Belt feeder-Position of belt feeder,Not available,
    IDE09071-MAS08505,Belt feeder-Motor current of belt feeder,Not available,
    IDE09335,Mirror fold-in: current consumption,0.00, A
    IDE09798,Play protection: mirror fold-in,not active,
    IDE10158,Window lift: switch-over from front to rear,not installed,
    IDE10164-MAS01632,automatic day/night exterior mirror-Status,not installed,
    IDE10164-MAS03691,automatic day/night exterior mirror-Dimming,0, %
    IDE12335-IDE12338,Door heating element 1-Sensor for door heating element 1,not installed,
    IDE12335-MAS03095,Door heating element 1-Function status,not installed,
    IDE12335-MAS04136,Door heating element 1-Current,not installed,
    IDE12335-MAS09022,Door heating element 1-PWM value,not installed,
    IDE12336-IDE12474,Door heating element 2-Sensor for door heating element 2,not installed,
    IDE12336-MAS03095,Door heating element 2-Function status,not installed,
    IDE12336-MAS04136,Door heating element 2-Current,not installed,
    IDE12336-MAS09022,Door heating element 2-PWM value,not installed,
    IDE12422-IDE02266,Driver side front door control head-Passenger side rear power window button,not activated,
    IDE12422-IDE04220,Driver side front door control head-Driver power window button,not activated,
    IDE12422-IDE04411,Driver side front door control head-Child Safety Lock Switch,not activated,
    IDE12422-IDE04540,Driver side front door control head-Mirror adjustment (X/Y-direction),Position bottom,
    IDE12422-IDE06621,Driver side front door control head-Driver side rear power window button,not activated,
    IDE12422-IDE06872,Driver side front door control head-Front passenger power window button,not activated,
    IDE12422-IDE10158,Driver side front door control head-Window lift: switch-over from front to rear,not installed,
    IDE12422-IDE11140,Driver side front door control head-Mirror folding position,Driving setting,
    IDE12422-MAS14179,Driver side front door control head-Child safety lock rear driver side: status,active,
    IDE12422-MAS14180,Driver side front door control head-Child safety lock rear passenger side: status,active,
    IDE12422-MAS15309,Driver side front door control head-Mirror selector switch: left,not activated,
    IDE12422-MAS15310,Driver side front door control head-Mirror selection switch: right,not activated,
    IDE12422-MAS15311,Driver side front door control head-Button: open rear lid,not activated,
    IDE12422-MAS15312,Driver side front door control head-Close rear lid button,not installed,
    IDE12422-MAS15313,Driver side front door control head-Bus signal: open rear lid,not activated,
    IDE12422-MAS15314,Driver side front door control head-Close rear lid bus signal,not activated,
    IDE13421-IDE06842,Memory seat adjustment control panel-Status - Button 1,not installed,
    IDE13421-IDE06843,Memory seat adjustment control panel-Status - Button 2,not installed,
    IDE13421-IDE06844,Memory seat adjustment control panel-Status - Button 3,not installed,
    IDE13421-IDE06845,Memory seat adjustment control panel-Status - Button 4,not installed,
    IDE13421-MAS05766,Memory seat adjustment control panel-Status of button for seat position storing,not installed,
    IDE13865-MAS02099,Exterior door handle actuator-Switch for inside door handle,Implausible,
    IDE13865-MAS02100,Exterior door handle actuator-Switch for outside door handle,Implausible,
    IDE13865-MAS09598,Exterior door handle actuator-Request on CAN,Unknown (6),
    IDE13865-MAS11741,Exterior door handle actuator-CAN Status,Initializing,
    IDE13865-MAS17088,Exterior door handle actuator-Contact: exterior door handle retracted,not installed,
    IDE13865-MAS17089,Exterior door handle actuator-Contact: exterior door handle extended,not installed,
    IDE13865-MAS17090,Exterior door handle actuator-Actuator activation status,not installed,
    IDE14109-MAS14614,Excess temperature shutdown of close assist-Switch-on threshold,Not available,
    IDE14109-MAS15599,Excess temperature shutdown of close assist-Counter reading,Not available,
    IDE14109,Excess temperature shutdown of close assist,not active,
    MAS01872,Rear lid remote release button,not activated,
    MAS02099,Switch for inside door handle,not installed,
    MAS02100,Switch for outside door handle,not installed,
    MAS02101,Child safety,active,
    MAS06010,Ambient light,0, %
    Elapsed Time: 00:07
  7. #17
    Aug 2019
    Toronto, Canada
    44 - Steering Assist
    ADPmap - 44 - Steering Assist
    ;SW:3Q0-909-144-M   HW:3Q0-909-144-L ---  Steering Assist
    ;Component:EPS_MQB_ZFLS  507 5082, Coding:911E0000
    ;EV_SteerAssisMQB,015157,EV_SteerAssisMQB_015.rod
    ;Sunday,11,August,2019,16:20:45:40778
    ;VCID: 3C34F8E2B7F4EDAF85-8068
    IDE03724-Straight line running,active ,1
    IDE03734-Support power,100% ,1
    IDE04130-Characteristic curve of steering assistance,Driving profile selection button ,1
    IDE04555-Activation of pwr steering asst without engine running,not active ,1
    IDE05162-Software end stop,active ,1
    IDE06419-Driving profile switchover,Incremental: controlled over time ,1
    IDE07540-Download without rest bus,not active ,1
    IDE09571-RPM monitoring,active ,1
    MAS02080-XCP calibration protocol,not active ,1
    Elapsed Time: 00:02
    Blockmap - 44 - Steering Assist
    ;Sunday,11,August,2019,16:20:37:40778
    IDE00018,Voltage terminal 15,12.00, V
    IDE00019,Voltage terminal 30,11.84, V
    IDE00020,Terminal 15 status,Terminal 15 on,
    IDE00021,Engine speed,0, /min
    IDE00075,Vehicle speed,0.00, km/h
    IDE00102,Control Module temperature,37.0, ∞C
    IDE00550-IDE03737,Identification of parameterization-Index characteristic curve,JA,
    IDE00550-MAS01078,Identification of parameterization-Vehicle type,G0,
    IDE00550-MAS05566,Identification of parameterization-Version of system parameters,71,
    IDE00550-MAS05567,Identification of parameterization-Version of characteristic curves,15,
    IDE00550-MAS05568,Identification of parameterization-Version of memory map,A1,
    IDE02006-IDE02955,Lane assistant-System status,Marginal conditions have not been met,
    IDE02006-IDE04227,Lane assistant-Directional stab. asst w/ pwr steering asst: steering status,0.000, Nm
    IDE02006-MAS03095,Lane assistant-Function status,activated,
    IDE02006-MAS03368,Lane assistant-Steering wheel vibration,not active,
    IDE02202,End stage temperature,28.0, ∞C
    IDE02216-IDE05795,Steering angle sensor: basic setting-End basic setting,Not permitted,
    IDE02216-IDE06673,Steering angle sensor: basic setting-Initialization status,initialized,
    IDE02216-MAS01632,Steering angle sensor: basic setting-Status,calibrated,
    IDE02216-MAS03161,Steering angle sensor: basic setting-Start,Not permitted,
    IDE02955,System status,Waiting for start request,
    IDE03682-IDE04457,Sensor for motor position-Electric motor speed,0, /min
    IDE03682-MAS02961,Sensor for motor position-Engine angle,13.2, ∞
    IDE03682-MAS03083,Sensor for motor position-Cosine signal,2.753, V
    IDE03682-MAS03211,Sensor for motor position-Sine signal,1.587, V
    IDE03682-MAS05053,Sensor for motor position-Reference value,Condition met,
    IDE03725-IDE03734,Steering Assistance-Support power,0, %
    IDE03725-MAS03001,Steering Assistance-Mode,automatic,
    IDE03725-MAS03095,Steering Assistance-Function status,not activated,
    IDE03726-IDE02955,Parallel Parking Assistance-System status,not active,
    IDE03726-IDE05159,Parallel Parking Assistance-Steering angle: target value,-4.0, ∞
    IDE03726-IDE05160,Parallel Parking Assistance-Steering angle: target-actual deviation,0.0, ∞
    IDE03726-MAS03095,Parallel Parking Assistance-Function status,not activated,
    IDE03735,Steering torque,-0.016, Nm
    IDE03735-MAS01632,Steering torque-Status,OK,
    IDE03736,Steering torque 2,-0.016, Nm
    IDE03736-MAS01632,Steering torque 2-Status,OK,
    IDE04118-IDE05157,Straight line running correction-Long term learning condition,Condition not met,
    IDE04118-IDE05158,Straight line running correction-Short term learning condition,Condition not met,
    IDE04118-MAS02998,Straight line running correction-Angle value offset,1.0, ∞
    IDE04118-MAS03095,Straight line running correction-Function status,activated,
    IDE04118-MAS03528,Straight line running correction-Long term adaptation value,1.0, ∞
    IDE04118-MAS03529,Straight line running correction-Short term adaptation value,0.0, ∞
    IDE04119-MAS03738,Active reset-Restoring force: setpoint,1, N
    IDE04183,Steering assistance: target engine torque,0.000, Nm
    IDE04184,Steering assistance: engine output,0.000, %
    IDE04185,Terminal 30 voltage filtered,11.94, V
    IDE04186,Battery terminal recognition,connected,
    IDE04187,Steering torque: raw value 1,63.477, %
    IDE04187-MAS01632,Steering torque: raw value 1-Status,OK,
    IDE04188,Steering torque: raw value 2,-60.840, %
    IDE04188-MAS01632,Steering torque: raw value 2-Status,OK,
    IDE04189,Steering torque: raw value 3,63.477, %
    IDE04189-MAS01632,Steering torque: raw value 3-Status,OK,
    IDE04190,Steering torque: raw value 4,-60.840, %
    IDE04190-MAS01632,Steering torque: raw value 4-Status,OK,
    IDE04191-MAS03084,Steering assistance: PWM signal for motor-Phase 1,2.39, %
    IDE04191-MAS03085,Steering assistance: PWM signal for motor-Phase 2,2.39, %
    IDE04191-MAS03086,Steering assistance: PWM signal for motor-Phase 3,2.40, %
    IDE04192-MAS03084,Steering assistance: motor current-Phase 1,0.1, A
    IDE04192-MAS03085,Steering assistance: motor current-Phase 2,-0.1, A
    IDE04192-MAS03086,Steering assistance: motor current-Phase 3,0.0, A
    IDE04194,Steering assistance: electromotor power,-0.74, W
    IDE04448-IDE00924,Steering angle sensor: angle-Steering angle,-3.2, ∞
    IDE04448-MAS01632,Steering angle sensor: angle-Status,valid,
    IDE04454-MAS01632,Steering angle sensor: angle speed-Status,valid,
    IDE04454-MAS02984,Steering angle sensor: angle speed-Steering angle speed,0.4, ∞
    IDE04458-MAS02996,Steering angle sensor: mechanical steering stroke-Steering stroke measured,160.91, mm
    IDE04458-MAS03731,Steering angle sensor: mechanical steering stroke-Mechanical center position determined,Yes,
    IDE04459,Steering angle sensor: offset index mark mechanical center,0.18, mm
    IDE04460,Steering angle sensor: offset straight line running,3.2, ∞
    IDE04510-MAS03732,Steering angle sensor: slope detection index-Steering angle speed negative dropping slope on curve,not recognized,
    IDE04510-MAS03733,Steering angle sensor: slope detection index-Steering angle speed negative rising slope on curve,not recognized,
    IDE04510-MAS03734,Steering angle sensor: slope detection index-Steering angle speed positive dropping slope on curve,not recognized,
    IDE04510-MAS03735,Steering angle sensor: slope detection index-Steering angle speed positive rising slope on curve,not recognized,
    IDE04510-MAS03736,Steering angle sensor: slope detection index-Index mark,1,
    IDE04511,Steering angle sensor external via CAN: angle,Measured value not available,
    IDE04512,Steering angle sensor external via CAN: angular velocity,Measured value not available,
    IDE04513,Steering angle sensor external via CAN: status,not active,
    IDE04514,Steering angle sensor external via CAN: basic setting,Calibration not possible,
    IDE04765-IDE02955,Counter steer support-System status,operational,
    IDE04765-MAS03095,Counter steer support-Function status,activated,
    IDE04765-MAS03739,Counter steer support-Steering torque request: brake electronics,0.000, Nm
    IDE04766-IDE04116,Replacement values-Vehicle speed replacement value,No,
    IDE04766-MAS00371,Replacement values-Engine speed,No,
    IDE04787,Hybrid status,not active,
    IDE04805-IDE02955,Driving profile selection-System status,operational,
    IDE04805-IDE06419,Driving profile selection-Driving profile switchover,no request,
    IDE04805-MAS01447,Driving profile selection-Act.val.,3,
    IDE04805-MAS01448,Driving profile selection-Specified value,3,
    IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
    IDE05155,Power steering current consumption,-0.06, A
    IDE05162-IDE03723,Software end stop-End stops for steering,Adapted,
    IDE05162-MAS01849,Software end stop-Left,80.63, mm
    IDE05162-MAS01850,Software end stop-Right,-80.27, mm
    IDE05162-MAS03095,Software end stop-Function status,active,
    IDE05713-IDE01864,Network diagnosis-Status of current bus communication,active,
    IDE05713-MAS00102,Network diagnosis-valid,Yes,
    IDE05713-MAS02447,Network diagnosis-Release,Yes,
    IDE05993-ENG120753,Steering wheel angle load-0_to_50_degrees,4139,
    IDE05993-ENG120755,Steering wheel angle load-100_to_150_degrees,0,
    IDE05993-ENG120751,Steering wheel angle load--100_to_-50_degrees,0,
    IDE05993-ENG120750,Steering wheel angle load--150_to_-100_degrees,0,
    IDE05993-ENG120756,Steering wheel angle load-150_to_200_degrees,0,
    IDE05993-ENG120749,Steering wheel angle load--200_to_-150_degrees,0,
    IDE05993-ENG120757,Steering wheel angle load-200_to_250_degrees,0,
    IDE05993-ENG120748,Steering wheel angle load--250_to_-200_degrees,0,
    IDE05993-ENG120758,Steering wheel angle load-250_to_300_degrees,0,
    IDE05993-ENG120747,Steering wheel angle load--300_to_-250_degrees,0,
    IDE05993-ENG120759,Steering wheel angle load-300_to_350_degrees,0,
    IDE05993-ENG120746,Steering wheel angle load--350_to_-300_degrees,0,
    IDE05993-ENG120760,Steering wheel angle load-350_to_400_degrees,0,
    IDE05993-ENG120745,Steering wheel angle load--400_to_-350_degrees,0,
    IDE05993-ENG120761,Steering wheel angle load-400_to_450_degrees,0,
    IDE05993-ENG120744,Steering wheel angle load--450_to_-400_degrees,0,
    IDE05993-ENG120762,Steering wheel angle load-450_to_500_degrees,0,
    IDE05993-ENG120752,Steering wheel angle load--50_to_0_degrees,4099,
    IDE05993-ENG120754,Steering wheel angle load-50_to_100_degrees,0,
    IDE05993-ENG120743,Steering wheel angle load--500_to_-450_degrees,0,
    IDE05993-ENG120763,Steering wheel angle load-500_to_550_degrees,0,
    IDE05993-ENG120742,Steering wheel angle load--550_to_500_degrees,0,
    IDE05993-ENG120764,Steering wheel angle load-above_550_degrees,0,
    IDE05993-ENG120741,Steering wheel angle load-below_-550_degrees,0,
    IDE05994-ENG120729,Engine specified torque load-0_to_1_kilo_newton,0,
    IDE05994-ENG120728,Engine specified torque load--1_to_0_kilo_newton,0,
    IDE05994-ENG120730,Engine specified torque load-1_to_2_kilo_newton,0,
    IDE05994-ENG08146,Engine specified torque load-10_to_11_kilo_newton,0,
    IDE05994-ENG120719,Engine specified torque load--10_to_-9_kilo_newton,0,
    IDE05994-ENG08147,Engine specified torque load--11_to_-10_kilo_newton,0,
    IDE05994-ENG120727,Engine specified torque load--2_to_-1_kilo_newton,0,
    IDE05994-ENG120731,Engine specified torque load-2_to_3_kilo_newton,0,
    IDE05994-ENG120726,Engine specified torque load--3_to_-2_kilo_newton,0,
    IDE05994-ENG120732,Engine specified torque load-3_to_4_kilo_newton,0,
    IDE05994-ENG120725,Engine specified torque load--4_to_-3_kilo_newton,0,
    IDE05994-ENG120733,Engine specified torque load-4_to_5_kilo_newton,0,
    IDE05994-ENG120724,Engine specified torque load--5_to_-4_kilo_newton,0,
    IDE05994-ENG120734,Engine specified torque load-5_to_6_kilo_newton,0,
    IDE05994-ENG120723,Engine specified torque load--6_to_-5_kilo_newton,0,
    IDE05994-ENG120735,Engine specified torque load-6_to_7_kilo_newton,0,
    IDE05994-ENG120722,Engine specified torque load--7_to_-6_kilo_newton,0,
    IDE05994-ENG120736,Engine specified torque load-7_to_8_kilo_newton,0,
    IDE05994-ENG120721,Engine specified torque load--8_to_-7_kilo_newton,0,
    IDE05994-ENG120737,Engine specified torque load-8_to_9_kilo_newton,0,
    IDE05994-ENG120738,Engine specified torque load-9_to_10_kilo_newton,0,
    IDE05994-ENG120720,Engine specified torque load--9_to_-8_kilo_newton,0,
    IDE05994-ENG30242,Engine specified torque load-above_11_kilo_newton,489,
    IDE05994-ENG30407,Engine specified torque load-below_-11_kilo_newton,489,
    IDE05995-ENG120703,ECU temperature load-0_to_10_degrees_celsius,0,
    IDE05995-ENG120702,ECU temperature load--10_to_0_degrees_celsius,54596,
    IDE05995-ENG120704,ECU temperature load-10_to_20_degrees_celsius,0,
    IDE05995-ENG120713,ECU temperature load-100_to_110_degrees_celsius,0,
    IDE05995-ENG120714,ECU temperature load-110_to_120_degrees_celsius,0,
    IDE05995-ENG120701,ECU temperature load--20_to_-10_degrees_celsius,0,
    IDE05995-ENG120705,ECU temperature load-20_to_30_degrees_celsius,0,
    IDE05995-ENG120700,ECU temperature load--30_to_-20_degrees_celsius,0,
    IDE05995-ENG120706,ECU temperature load-30_to_40_degrees_celsius,0,
    IDE05995-ENG120699,ECU temperature load--40_to_-30_degrees_celsius,0,
    IDE05995-ENG120707,ECU temperature load-40_to_50_degrees_celsius,0,
    IDE05995-ENG120708,ECU temperature load-50_to_60_degrees_celsius,0,
    IDE05995-ENG120709,ECU temperature load-60_to_70_degrees_celsius,0,
    IDE05995-ENG120710,ECU temperature load-70_to_80_degrees_celsius,0,
    IDE05995-ENG120711,ECU temperature load-80_to_90_degrees_celsius,0,
    IDE05995-ENG120712,ECU temperature load-90_to_100_degrees_celsius,0,
    IDE05995-ENG120715,ECU temperature load-above_120_degrees_celsius,0,
    IDE05995-ENG120698,ECU temperature load-below_-40_degrees_celsius,0,
    IDE05996-ENG120766,Steering wheel angle speed load-360_to_600_degrees_per_second,15,
    IDE05996-ENG120765,Steering wheel angle speed load-50_to_360_degrees_per_second,12,
    IDE05996-ENG120767,Steering wheel angle speed load-600_to_800_degrees_per_second,14,
    IDE05996-ENG120768,Steering wheel angle speed load-above_800_degrees_per_second,1832,
    IDE06678-IDE03458,Pull compensation-Steering torque offset,0.000, Nm
    IDE06678-MAS03000,Pull compensation-Adapt. value,0.120, Nm
    IDE06678-MAS03095,Pull compensation-Function status,not activated,
    IDE07399,Engine type,2,
    IDE07400-MAS03084,Phase disconnect: status-Phase 1,closed,
    IDE07400-MAS03085,Phase disconnect: status-Phase 2,closed,
    IDE07400-MAS03086,Phase disconnect: status-Phase 3,closed,
    IDE07542-MAS00370,Prerequisites: basic setting-Vehicle speed,Condition met,
    IDE07542-MAS01468,Prerequisites: basic setting-Terminal 15,Condition met,
    IDE07542-MAS01634,Prerequisites: basic setting-Supply voltage,Condition met,
    IDE07542-MAS01746,Prerequisites: basic setting-Regulation active,Condition not met,
    IDE07542-MAS02980,Prerequisites: basic setting-Manual steering torque,Condition met,
    MAS00464-MAS00110,Standard - ambient data 1-Minutes,20,
    MAS00464-MAS00111,Standard - ambient data 1-Seconds,43,
    MAS00976-IDE80003,Counter-Analysis 3,2153882681,
    MAS00976-IDE80004,Counter-Analysis 4,182585,
    MAS01172-MAS01156,Development messages-Communication status,active,
    MAS01172-MAS03095,Development messages-Function status,not active,
    MAS02126-MAS01632,Steering angle sensor: status-Status,active,
    MAS02126-MAS02247,Steering angle sensor: status-CAN message,valid,
    ENG120769-MAS00973,identification_add-on_parts_steering_assistance-Construction version,Series,
    ENG120769-ENG120622,identification_add-on_parts_steering_assistance-moment_sensor,magnetoresistiv,
    ENG120769-ENG120621,identification_add-on_parts_steering_assistance-system_supplier,ZFO,
    ENG37819-ENG37964,Strain_detection-Calculated_worm_gear_temperature,0.0, ∞C
    ENG37819-ENG38046,Strain_detection-High_count_worm_gear_alt,182585,
    ENG37819-ENG38061,Strain_detection-KlimaSensor02_alt,1,
    ENG37819-ENG38097,Strain_detection-Low_count_worm_gear_alt,2153882681,
    ENG37819-ENG38105,Strain_detection-Mileage_counter,0, km
    ENG37819-ENG38117,Strain_detection-OBD_FStatus_ATemp,kein Fehler/Init/nicht verbaut,
    ENG37819-ENG102605,Strain_detection-outside_temperature,26.0, ∞C
    ENG37819-ENG37918,Strain_detection-revolutions_per_minute_electric_motor,1, /min
    ENG37819-ENG26208,Strain_detection-Steering_angle,-3.2, ∞
    ENG37819-ENG37919,Strain_detection-steering_moment,-0.016, Nm
    ENG37819-ENG37920,Strain_detection-Steering_Support_Engine_Commanded_Torque,0.000, Nm
    ENG37819-ENG38151,Strain_detection-Strain_detection_per_cent,0.0000013713, %
    Elapsed Time: 00:07
  8. #18
    Aug 2019
    Toronto, Canada
    47 - Sound System
    ADPmap - 47 - Sound System
    ;SW:81A-035-466-B   HW:81A-035-466 ---  Sound System
    ;Component:MIB2_amp_P_A3 H10 0440, Coding:0173030000AAAA2AAA0000010000
    ;EV_AMPMst16C9Gen2ALPI,001002,EV_AMPMst16C9Gen2ALPI.rod
    ;Sunday,11,August,2019,16:20:58:40778
    ;VCID: 240420822F44B56FDD-8070
    IDE10493-MAS03001-Electrical test 2 of loudspeakers-Mode,automatic ,73
    IDE10493-ENG117360-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,73
    IDE10493-ENG117361-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,60 ,73
    IDE10493-ENG117378-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,73
    IDE10493-ENG117379-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,60 ,73
    IDE10493-ENG117380-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,73
    IDE10493-ENG117381-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,60 ,73
    IDE10493-ENG117382-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,73
    IDE10493-ENG117383-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,60 ,73
    IDE10493-ENG117384-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,73
    IDE10493-ENG117385-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,60 ,73
    IDE10493-ENG117386-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,73
    IDE10493-ENG117387-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,60 ,73
    IDE10493-ENG117388-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,73
    IDE10493-ENG117389-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,60 ,73
    IDE10493-ENG117390-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,73
    IDE10493-ENG117391-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,60 ,73
    IDE10493-ENG126164-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_17_Test_Frequency,19000 Hz,73
    IDE10493-ENG126165-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_17_Test_Volume,60 ,73
    IDE10493-ENG126166-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_18_Test_Frequency,19000 Hz,73
    IDE10493-ENG126167-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_18_Test_Volume,60 ,73
    IDE10493-ENG126168-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_19_Test_Frequency,19000 Hz,73
    IDE10493-ENG126169-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_19_Test_Volume,60 ,73
    IDE10493-ENG117362-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,73
    IDE10493-ENG117363-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,60 ,73
    IDE10493-ENG126170-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_20_Test_Frequency,19000 Hz,73
    IDE10493-ENG126171-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_20_Test_Volume,60 ,73
    IDE10493-ENG126172-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_21_Test_Frequency,19000 Hz,73
    IDE10493-ENG126173-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_21_Test_Volume,60 ,73
    IDE10493-ENG126174-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_22_Test_Frequency,19000 Hz,73
    IDE10493-ENG126175-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_22_Test_Volume,60 ,73
    IDE10493-ENG126176-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_23_Test_Frequency,19000 Hz,73
    IDE10493-ENG126177-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_23_Test_Volume,60 ,73
    IDE10493-ENG126178-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_24_Test_Frequency,19000 Hz,73
    IDE10493-ENG126179-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_24_Test_Volume,60 ,73
    IDE10493-ENG117364-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,73
    IDE10493-ENG117365-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,60 ,73
    IDE10493-ENG117366-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,73
    IDE10493-ENG117367-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,60 ,73
    IDE10493-ENG117368-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,73
    IDE10493-ENG117369-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,60 ,73
    IDE10493-ENG117370-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,73
    IDE10493-ENG117371-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,60 ,73
    IDE10493-ENG117372-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,73
    IDE10493-ENG117373-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,60 ,73
    IDE10493-ENG117374-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,73
    IDE10493-ENG117375-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,60 ,73
    IDE10493-ENG117376-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,73
    IDE10493-ENG117377-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,60 ,73
    Elapsed Time: 00:02
    Blockmap - 47 - Sound System
    ;Sunday,11,August,2019,16:20:50:40778
    IDE00020,Terminal 15 status,On,
    IDE00021,Engine speed,0.00, /min
    IDE00668-MAS03231,Microphone current consumption-Microphone 1,3.00, mA
    IDE00668-MAS03232,Microphone current consumption-Microphone 2,25.50, mA
    IDE00767,No. of unscheduled ECU resets,1, counts
    IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,00 00,
    IDE01351,Terminal 75 status,On,
    IDE01715,Status terminal S,On,
    IDE01716,Terminal 50 status,OFF,
    IDE02070-IDE02060,Wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
    IDE02070-IDE04544,Wake-up cause-Media type in optical drive,No,
    IDE02070-MAS03177,Wake-up cause-Databus Infotainment,No,
    IDE02070-MAS03180,Wake-up cause-Local data bus,No,
    IDE02070-MAS03690,Wake-up cause-Telephone,No,
    IDE02070-MAS03782,Wake-up cause-WLAN,No,
    IDE02070-MAS03833,Wake-up cause-Optical data bus,Yes,
    IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,47,
    IDE03880-MAS03425,MOST address-Physical address,04 02,
    IDE04312-MAS00109,System run time-Hours,0, H
    IDE04312-MAS00110,System run time-Minutes,41, min
    IDE04317-MAS00108,Total system run time-Day,0, d
    IDE04317-MAS00109,Total system run time-Hours,14, H
    IDE04317-MAS00110,Total system run time-Minutes,52, min
    IDE04639-IDE02060,Last wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
    IDE04639-IDE04544,Last wake-up cause-Media type in optical drive,No,
    IDE04639-MAS03177,Last wake-up cause-Databus Infotainment,No,
    IDE04639-MAS03180,Last wake-up cause-Local data bus,No,
    IDE04639-MAS03690,Last wake-up cause-Telephone,No,
    IDE04639-MAS03782,Last wake-up cause-WLAN,No,
    IDE04639-MAS03833,Last wake-up cause-Optical data bus,Yes,
    IDE04640,Over-temperature protection for amplifier,no restriction,
    IDE04641,Speed-dependent volume adjustment,0.0, dB
    IDE04649-MAS01968,Activation for housing fan-Fan,OFF,
    IDE04649-MAS06857,Activation for housing fan-Speed,0, /min
    IDE04749-ENG117444,Mute-am_fm_tuner,No,
    IDE04749-ENG117443,Mute-audiomanager,No,
    IDE04749-ENG117447,Mute-component_protection,No,
    IDE04749-ENG117445,Mute-dab_sdars_tuner,No,
    IDE04749-ENG117446,Mute-drm_hd_tuner,No,
    IDE04749-ENG113342,Mute-Hardware,No,
    IDE05704-MAS02646,Digital Transmission Content Protection (DTCP) key-Key type,License key (DTLA),
    IDE05705-MAS01159,Digital Transmission Content Protection (DTCP) device cert-Version number,2,
    IDE05705-MAS01779,Digital Transmission Content Protection (DTCP) device cert-Length,60,
    IDE05705-MAS06742,Digital Transmission Content Protection (DTCP) device cert-Certificate type,0,
    IDE05713-MAS01632,Network diagnosis-Status,Enabled,
    IDE06055,Invalid authentication (DTCP),5F,
    IDE06519-MAS01424,Temperature of MOST transceiver-max.value,70, ∞C
    IDE06519-MAS01425,Temperature of MOST transceiver-min.value,13, ∞C
    IDE06519-MAS02238,Temperature of MOST transceiver-Current,56, ∞C
    IDE09935-MAS01424,Temperature of inductor-max.value,79, ∞C
    IDE09935-MAS01425,Temperature of inductor-min.value,12, ∞C
    IDE09935-MAS02238,Temperature of inductor-Current,66, ∞C
    IDE10545-IDE03744,Speaker status-Left effects speaker,OK,
    IDE10545-IDE03745,Speaker status-Right effects speaker,OK,
    IDE10545-IDE03747,Speaker status-Left Front Midrange Speaker,OK,
    IDE10545-IDE03748,Speaker status-Right Front Midrange Speaker,OK,
    IDE10545-MAS01188,Speaker status-Left front bass speaker,OK,
    IDE10545-MAS01190,Speaker status-Left front treble speaker,OK,
    IDE10545-MAS01191,Speaker status-Right front bass speaker,OK,
    IDE10545-MAS01193,Speaker status-Right front treble speaker,OK,
    IDE10545-MAS01194,Speaker status-Left rear bass speaker,OK,
    IDE10545-MAS01195,Speaker status-Left rear treble speaker,OK,
    IDE10545-MAS01196,Speaker status-Right rear bass speaker,OK,
    IDE10545-MAS01197,Speaker status-Right rear treble speaker,OK,
    IDE10545-MAS01198,Speaker status-Center speaker,OK,
    IDE10545-MAS04506,Speaker status-Double subwoofer speaker 1,OK,
    IDE10545-MAS04507,Speaker status-Double subwoofer speaker 2,OK,
    IDE10545-ENG117415,Speaker status-loudspeaker_channel_12,Measured value not available,
    IDE10545-ENG126180,Speaker status-loudspeaker_channel_17,Measured value not available,
    IDE10545-ENG126181,Speaker status-loudspeaker_channel_18,Measured value not available,
    IDE10545-ENG126182,Speaker status-loudspeaker_channel_19,Measured value not available,
    IDE10545-ENG126183,Speaker status-loudspeaker_channel_20,Measured value not available,
    IDE10545-ENG126184,Speaker status-loudspeaker_channel_21,Measured value not available,
    IDE10545-ENG126185,Speaker status-loudspeaker_channel_22,Measured value not available,
    IDE10545-ENG126186,Speaker status-loudspeaker_channel_23,Measured value not available,
    IDE10545-ENG126187,Speaker status-loudspeaker_channel_24,Measured value not available,
    IDE10657-MAS01424,Temperature switching power supply-max.value,80, ∞C
    IDE10657-MAS01425,Temperature switching power supply-min.value,12, ∞C
    IDE10657-MAS02238,Temperature switching power supply-Current,65, ∞C
    IDE10659-MAS01424,Temperature switching power supply 2-max.value,75, ∞C
    IDE10659-MAS01425,Temperature switching power supply 2-min.value,17, ∞C
    IDE10659-MAS02238,Temperature switching power supply 2-Current,62, ∞C
    MAS00464-MAS00106,Standard - ambient data 1-Year,2019,
    MAS00464-MAS00107,Standard - ambient data 1-Month,8,
    MAS00464-MAS00108,Standard - ambient data 1-Day,11,
    MAS00464-MAS00109,Standard - ambient data 1-Hours,16,
    MAS00464-MAS00111,Standard - ambient data 1-Seconds,56,
    MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,15,
    MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,500, km
    MAS03121,Ring break diagnostic line status,Supply voltage,
    ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,dont care,
    ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,dont care,
    ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,OK,
    ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,OK,
    ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,OK,
    ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,dont care,
    ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,dont care,
    ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,dont care,
    ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,dont care,
    ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,dont care,
    ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,dont care,
    ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,dont care,
    ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,dont care,
    ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,dont care,
    ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,dont care,
    ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,dont care,
    ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,dont care,
    ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,dont care,
    ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
    ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
    ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
    ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,dont care,
    ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,dont care,
    ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,dont care,
    ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,dont care,
    ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,dont care,
    ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,dont care,
    ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,OK,
    ENG117857-MAS00109,Last_System_Operating_Time-Hours,0, H
    ENG117857-MAS00110,Last_System_Operating_Time-Minutes,1, min
    ENG117856-MAS00106,Last_System_Operating_Time/Mins.-Year,19, yr
    ENG117856-MAS00107,Last_System_Operating_Time/Mins.-Month,8, mon
    ENG117856-MAS00108,Last_System_Operating_Time/Mins.-Day,11, d
    ENG117856-MAS00109,Last_System_Operating_Time/Mins.-Hours,15, H
    ENG117856-MAS00110,Last_System_Operating_Time/Mins.-Minutes,39, min
    ENG117856-MAS00111,Last_System_Operating_Time/Mins.-Seconds,44, s
    Elapsed Time: 00:07
  9. #19
    Aug 2019
    Toronto, Canada
    52 - Door Elect, Pass.
    ADPmap - 52 - Door Elect, Pass.
    ;SW:5Q0-959-592-F   HW:5Q0-959-592-F ---  Door Elect, Pass.
    ;Component:TSG BFS002 0287, Coding:005E13205C00008000000002
    ;EV_DCU2PasseSideMAXHKLO,001010,EV_DCU2PasseSideMAXHCONT_VW37.rod
    ;Sunday,11,August,2019,16:21:29:40778
    ;VCID: 43C6831ECA0A9257C4-8016
    ENG117298-Reversing_Threshold_Passenger_Side_Front,90 %,1
    ENG117300-Reversing_Threshold_Passenger_Side_Rear,90 %,1
    Elapsed Time: 00:02
    Blockmap - 52 - Door Elect, Pass.
    ;Sunday,11,August,2019,16:21:23:40778
    IDE01993-MAS12276,Control module reference number-Front door control module,Frt.pass. side door control module,
    IDE01993-MAS12277,Control module reference number-Rear door control module,Rear passenger side door control module,
    IDE02268-IDE00773,Supply voltage for door control module: front: frt.pass. side-Terminal 15 status via CAN,active,
    IDE02268-IDE01715,Supply voltage for door control module: front: frt.pass. side-Status terminal S,active,
    IDE02268-IDE05835,Supply voltage for door control module: front: frt.pass. side-Supply voltage for central locking,11.70, V
    IDE04216-MAS04247,Mirror heater-Button,not installed,
    IDE04539-MAS01634,Mirror memory-Supply voltage,active,
    IDE04539-MAS02228,Mirror memory-X coordinate,72, %
    IDE04539-MAS02229,Mirror memory-Y coordinate,53, %
    IDE04540,Mirror adjustment (X/Y-direction),not installed,
    IDE05727-IDE02589,Front passenger side door status-Rotary latch status,closed,
    IDE05727-IDE04213,Front passenger side door status-Central locking button,not activated,
    IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,not installed,
    IDE05727-MAS06256,Front passenger side door status-Status door lock,Signal from door lock: released,
    IDE06207-MAS01453,Front window regulator status: frt.pass. side-Blocking detection,not active,
    IDE06207-MAS02039,Front window regulator status: frt.pass. side-Force limitation,not active,
    IDE06207-MAS02097,Front window regulator status: frt.pass. side-Window position,95.50, %
    IDE06207-MAS02098,Front window regulator status: frt.pass. side-Power window control standardized,Yes,
    IDE06207-MAS03548,Front window regulator status: frt.pass. side-Motor current,0, A
    IDE06207-MAS04642,Front window regulator status: frt.pass. side-Before upper stop,not active,
    IDE06207-MAS05370,Front window regulator status: frt.pass. side-Direction of movement,Idle condition,
    IDE06872,Front passenger power window button,not activated,
    IDE06934,Front window regulator relay: frt.pass. side,Open,
    IDE06938-MAS02545,Front window regulator reversing position: frt. pass. side-Last,127.50, %
    IDE06938-MAS02546,Front window regulator reversing position: frt. pass. side-Second to last,127.50, %
    IDE06938-MAS02547,Front window regulator reversing position: frt. pass. side-Third to last,127.50, %
    IDE06938-MAS02548,Front window regulator reversing position: frt. pass. side-Fourth to last,127.50, %
    IDE06938-MAS05380,Front window regulator reversing position: frt. pass. side-fifth to last,127.50, %
    IDE07223,Window regulator child lock: frt.pass. side,Not available,
    IDE07406-IDE03114,Enable front passenger window regulator relay-Comfort function,No,
    IDE07406-MAS02447,Enable front passenger window regulator relay-Release,Yes,
    IDE07410-MAS01632,Excess.temp. disconnect: front window regulator: frt.pass. side-Status,not active,
    IDE07410-MAS02955,Excess.temp. disconnect: front window regulator: frt.pass. side-Engine temperature,24, ∞C
    IDE07414,Comfort function for front window regulator: frt.pass. side,not active,
    Elapsed Time: 00:06
  10. #20
    Aug 2019
    Toronto, Canada
    2B - Steer. Col. Lock
    ADPmap - 2B - Steer. Col. Lock
    ;SW:2Q0-905-861-A   HW:2Q0-905-861-A ---  Steer. Col. Lock
    ;Component:ELV-MQBB      H08 0021, Coding:0800000000000000
    ;EV_ELVMarqMQBA0,002002,EV_ELVMarqMQBA0_AU37.rod
    ;Sunday,11,August,2019,16:20:05:40778
    ;VCID: 312AD9D660B610C726-8064
    IDE07566-Steering column lock unlocked,unlock ,1
    ENG128823-functional_check_manufacturer,tested ,1
    ENG128824-functional_check_steering_column_supplier,not tested ,1
    Elapsed Time: 00:01
    Blockmap - 2B - Steer. Col. Lock
    ;Sunday,11,August,2019,16:20:01:40778
    IDE00021-MAS00058,Engine speed-Implausible,No,
    IDE00021-MAS00103,Engine speed-invalid,No,
    IDE00021-MAS02239,Engine speed-obsolete,No,
    IDE00021-MAS02246,Engine speed-Timeout,No,
    IDE00075-MAS00058,Vehicle speed-Implausible,No,
    IDE00075-MAS00103,Vehicle speed-invalid,No,
    IDE00075-MAS02246,Vehicle speed-Timeout,No,
    IDE00096-MAS02239,Selector lever position-obsolete,No,
    IDE00096-MAS02246,Selector lever position-Timeout,No,
    IDE00096,Selector lever position,OK,
    IDE00660-MAS02246,Drive readiness-Timeout,No,
    IDE00660,Drive readiness,not active,
    IDE01766-MAS03714,Distance impulses-Left front wheel,1,
    IDE01766-MAS03715,Distance impulses-Right front wheel,0,
    IDE01766-MAS03716,Distance impulses-Left rear wheel,3,
    IDE01766-MAS03717,Distance impulses-Right rear wheel,72,
    IDE01766-MAS11907,Distance impulses-Left front wheel signal state timeout,No,
    IDE01766-MAS11908,Distance impulses-Right front wheel signal state timeout,No,
    IDE01766-MAS11909,Distance impulses-Left rear wheel signal state timeout,No,
    IDE01766-MAS11910,Distance impulses-Right rear wheel signal state timeout,No,
    IDE01766-MAS11911,Distance impulses-Left front wheel invalid signal state,No,
    IDE01766-MAS11912,Distance impulses-Right front wheel invalid signal state,No,
    IDE01766-MAS11913,Distance impulses-Left rear wheel invalid signal state,No,
    IDE01766-MAS11914,Distance impulses-Right rear wheel invalid signal state,No,
    IDE02569-MAS02242,Terminal S: line status-Electronic central electric actual value,On,
    IDE02569-MAS02246,Terminal S: line status-Timeout,No,
    IDE02570-MAS02242,Terminal 15: line status-Electronic central electric actual value,On,
    IDE02570-MAS02246,Terminal 15: line status-Timeout,No,
    IDE02573,End switch for steering column: unlocked: status,operated,
    IDE02574,End switch for steering column: locked: status,not activated,
    IDE02575,Unlocking motor: activation status,not activated,
    IDE02576,Locking motor: activation status,not activated,
    IDE02577,Steering column twisting: status,not twisted,
    IDE02579-MAS02246,Park selector lever position-Timeout,No,
    IDE02579,Park selector lever position,locked,
    IDE02580,Number of unlocks,63,
    IDE02588,Terminal signals and start release,not enabled,
    IDE02589-MAS02246,Rotary latch status-Timeout,No,
    IDE02589,Rotary latch status,closed,
    IDE02590-MAS02246,External vehicle locking: SPECIFIED condition-Timeout,No,
    IDE02590-MAS02257,External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key,Vehicle not secured,
    IDE02590,External vehicle locking: SPECIFIED condition,unlocked,
    IDE02759-MAS02345,Steering column lock current condition/learn mode-Current condition,Immobilizer download obtained,
    IDE02759-MAS02349,Steering column lock current condition/learn mode-Learn mode,Adapted,
    IDE03527-IDE03411,CAN signals-Red warning lamp,not active,
    IDE03527-MAS04444,CAN signals-Wake-up,not active,
    IDE03527-MAS05099,CAN signals-Driver information: steering column lock defective,not active,
    IDE03527-MAS05100,CAN signals-Driver information: steering column lock: workshop,not active,
    IDE03527-MAS05101,CAN signals-Driver information: move steering,not active,
    IDE06746-IDE00020,Locking requirements-Terminal 15 status,Condition not met,
    IDE06746-IDE00021,Locking requirements-Engine speed,Condition met,
    IDE06746-IDE00075,Locking requirements-Vehicle speed,Condition met,
    IDE06746-IDE00660,Locking requirements-Drive readiness,Condition met,
    IDE06746-IDE01715,Locking requirements-Status terminal S,Condition not met,
    IDE06746-IDE01766,Locking requirements-Distance impulses,Condition met,
    IDE06746-IDE02052,Locking requirements-Malfunction message in instrument panel,Condition met,
    IDE06746-IDE02579,Locking requirements-Park selector lever position,Condition met,
    IDE06746-MAS08251,Locking requirements-Communication status signal ESP_21,Condition met,
    IDE06746-MAS08252,Locking requirements-Communication status signal Klemmenstatus_01,Condition not met,
    IDE06746-MAS08441,Locking requirements-Test of locking requirements,not active,
    IDE06746-MAS08791,Locking requirements-Cyclical Reception Signal ESP_21,Condition met,
    IDE06746-MAS08792,Locking requirements-Cyclical Reception Signal ESP_10,Condition met,
    IDE06746-MAS08794,Locking requirements-Cyclical Reception Signal Terminal Status_01,Condition met,
    IDE06746-MAS11697,Locking requirements-Communication status signal ESP_10,Condition met,
    IDE09059-MAS02246,Request terminal release-Timeout,No,
    IDE09059,Request terminal release,No,
    IDE09064,Status: unlock trigger,No,
    IDE09065-MAS02246,Status: remote start-Timeout,No,
    IDE09065,Status: remote start,not active,
    IDE09066-MAS02246,ID sensor exiting vehicle-Timeout,No,
    IDE09066,ID sensor exiting vehicle,No,
    MAS00464-MAS00111,Standard - ambient data 1-Seconds,3,
    ENG111213-ENG128873,Activated_Fault_Reactions-Locking disabled,No,
    ENG128821-ENG111184,Errorcounter lifetime-AD-Converter corrupt,0,
    ENG128821-ENG128856,Errorcounter lifetime-AD-Converter corrupt unlocking cycle,No,
    ENG128821-ENG128851,Errorcounter lifetime-Areacheck highside,0,
    ENG128821-ENG128852,Errorcounter lifetime-Areacheck highside unlocking cycle,No,
    ENG128821-ENG128853,Errorcounter lifetime-Areacheck lowside,0,
    ENG128821-ENG128854,Errorcounter lifetime-Areacheck lowside unlocking cycle,No,
    ENG128821-ENG111176,Errorcounter lifetime-CoCo RAM-Check,0,
    ENG128821-ENG128846,Errorcounter lifetime-CoCo RAM-Check unlocking cycle,No,
    ENG128821-ENG111177,Errorcounter lifetime-CoCo ROM-Check,0,
    ENG128821-ENG128847,Errorcounter lifetime-CoCo ROM-Check unlocking cycle,No,
    ENG128821-ENG111194,Errorcounter lifetime-CPU-Test CoCo,0,
    ENG128821-ENG128848,Errorcounter lifetime-CPU-Test CoCo unlocking cycle,No,
    ENG128821-ENG111192,Errorcounter lifetime-CPU-Test HaCo,0,
    ENG128821-ENG128844,Errorcounter lifetime-CPU-Test HaCo unlocking cycle,No,
    ENG128821-ENG111187,Errorcounter lifetime-Enable CoCo incorrect active locking,0,
    ENG128821-ENG128858,Errorcounter lifetime-Enable CoCo incorrect active locking unlocking cycle,No,
    ENG128821-ENG111181,Errorcounter lifetime-Endposition switches implausible,0,
    ENG128821-ENG128855,Errorcounter lifetime-Endposition switches implausible unlocking cycle,No,
    ENG128821-ENG128872,Errorcounter lifetime-Endposition_Button_Unlocked_Change_To_Not_Activated_While_Driving,0,
    ENG128821-ENG128870,Errorcounter lifetime-Endposition_Locked_Not_Reached,0,
    ENG128821-ENG128871,Errorcounter lifetime-Endposition_Locked_Not_Reached unlocking cycle,No,
    ENG128821-ENG31613,Errorcounter lifetime-HaCo CAN-Cell-Check,0,
    ENG128821-ENG31614,Errorcounter lifetime-HaCo CAN-Cell-Check unlocking cycle,No,
    ENG128821-ENG111185,Errorcounter lifetime-HaCo CoCo communication disturbed,0,
    ENG128821-ENG128857,Errorcounter lifetime-HaCo CoCo communication disturbed unlocking cycle,No,
    ENG128821-ENG111175,Errorcounter lifetime-HaCo EEPROM-Check,0,
    ENG128821-ENG128845,Errorcounter lifetime-HaCo EEPROM-Check unlocking cycle,No,
    ENG128821-ENG111173,Errorcounter lifetime-HaCo RAM-Check,0,
    ENG128821-ENG128842,Errorcounter lifetime-HaCo RAM-Check unlocking cycle,No,
    ENG128821-ENG111174,Errorcounter lifetime-HaCo ROM-Check,0,
    ENG128821-ENG128843,Errorcounter lifetime-HaCo ROM-Check unlocking cycle,No,
    ENG128821-ENG128868,Errorcounter lifetime-Invalid eeprom data immobilizer,0,
    ENG128821-ENG128869,Errorcounter lifetime-Invalid eeprom data immobilizer unlocking cycle,No,
    ENG128821-ENG111189,Errorcounter lifetime-No CoCo enable locking,0,
    ENG128821-ENG128859,Errorcounter lifetime-No CoCo enable locking unlocking cycle,No,
    ENG128821-ENG111195,Errorcounter lifetime-Program sequence CoCo,0,
    ENG128821-ENG128863,Errorcounter lifetime-Program sequence CoCo unlocking cycle,No,
    ENG128821-ENG111193,Errorcounter lifetime-Program sequence HaCo,0,
    ENG128821-ENG128862,Errorcounter lifetime-Program sequence HaCo unlocking cycle,No,
    ENG128821-ENG111190,Errorcounter lifetime-Reset HaCo CoCo failed,0,
    ENG128821-ENG128860,Errorcounter lifetime-Reset HaCo CoCo failed unlocking cycle,No,
    ENG128821-ENG111191,Errorcounter lifetime-Reset SBC HaCo failed,0,
    ENG128821-ENG128861,Errorcounter lifetime-Reset SBC HaCo failed unlocking cycle,No,
    ENG128821-ENG119956,Errorcounter lifetime-Return address,00 00 00 00,
    ENG128821-ENG128866,Errorcounter lifetime-SDA-Error CoCo,0,
    ENG128821-ENG128867,Errorcounter lifetime-SDA-Error CoCo unlocking cycle,No,
    ENG128821-ENG128864,Errorcounter lifetime-SDA-Error HaCo,0,
    ENG128821-ENG128865,Errorcounter lifetime-SDA-Error HaCo unlocking cycle,No,
    ENG128821-ENG111179,Errorcounter lifetime-Shortcut motor driver highside,0,
    ENG128821-ENG128849,Errorcounter lifetime-Shortcut motor driver highside unlocking cycle,No,
    ENG128821-ENG111180,Errorcounter lifetime-Shortcut motor driver lowside,0,
    ENG128821-ENG128850,Errorcounter lifetime-Shortcut motor driver lowside unlocking cycle,No,
    ENG128820,Free_Releases_Numbers,256,
    ENG128822-ENG128823,functional_check-functional_check_manufacturer,Confirmed,
    ENG128822-ENG128824,functional_check-functional_check_steering_column_supplier,Not confirmed,
    Elapsed Time: 00:04
