updated autoscan after DC/AC power inverter retrofit
Sunday,02,August,2020,21:20:41:06888
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4513.4
Dealer/Shop Name: dB
Workshop Code: 031 33097 006209
VIN: WVWZZZAUZHW0xxxxx   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 14 15 16 17 18 19 3C 42 44 52 55 5F 65 6C A5
VIN: WVWZZZAUZHW0xxxxx   Mileage: 40654km-25261miles
Address 01: Engine (J623-CZCA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HB    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H25 4418
   Revision: R7H25---
   Coding: 0119003A23441D082000
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_ECM14TFS01104E906027HB 001006
   ROD: EV_ECM14TFS01104E906027HB.rod
   VCID: 6B833BBF03045ED3969-803E
   CAN Converter 01:
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels:. User\5Q0-614-517-CC.lbl
   Part No SW: 5Q0 614 517 CC    HW: 5Q0 614 517 AG
   Component: ESC           H62 0637
   Revision: 00000000    Serial number: 91596000011507
   Coding: 01FA6AA1342219704779060841C62980562C98E26082947314205088408903
   Shop #: WSC 33097 031 06209
   VCID: 74B120C35E3A812B473-8020
   Part No SW: 5G0 907 044 BM    HW: 5G0 907 044 BM
   Component: Climatronic   H04 1601
   Revision: 00001K08
   Coding: 00020004104411011105004200101022
   VCID: 73B323DF5B3486135E9-8026
   Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
   Air quality sensor:
   Part No SW: 5Q0 937 084 CL    HW: 5Q0 937 084 AN
   Component: BCM MQBAB H   H24 0175
   Serial number: 01061633700891
   Coding: 00000966C20102F90B244080B11407281400000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 045170030E9AB1AB773-8050
   Component: WWS    160522  043 0551
   Serial number:         160601172917
   Coding: 0E4DFD
   Component: RLFS  024 0042
   Serial number: Y13M05D10H00M20S03S4
   Coding: 06A8DD
   Serial number: 000000000ZY15028208R
   Serial number: 00000000000030139763
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Serial number: 000308417617145
   Coding: 0271565841
   VCID: 50F98C538A629D0B83B-8004
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 G    HW: 5Q0 907 567 G
   Component: ACC3          H08 0390
   Serial number: 19021303030627
   Coding: 00000700FE030B
   ASAM Dataset: EV_ACCBoschMQB 001021
   ROD: EV_ACCBoschMQB_VW37.rod
   VCID: 3FDBBFEF27FC12736A1-806A
   Serial number: 13011641350610
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 3829D4F302D2254BABB-806C
   Component: AirbagVW20    015 0388
   Serial number: 003F6R1V1W4Y
   VCID: 41DFB917510864831C5-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 001 506 16
   Serial number: 35767000000432B44C1Q
   Subsystem 2 - Part No SW: -----------    HW: 480 001 506 16
   Serial number: 358670000008B4C4DB17
   Subsystem 3 - Part No SW: -----------    HW: 480 400 306 16
   Serial number: 3516502BB205729313D3
   Subsystem 4 - Part No SW: -----------    HW: 480 401 105 16
   Serial number: 3526502AF2076340F201
   Subsystem 5 - Part No SW: -----------    HW: 480 401 106 16
   Serial number: 35565029B21160C1025X
   Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
   Revision: --------    Serial number: 13061608490829
   Coding: 0400
   VCID: 0D4755275DD0F0E328D-8058
   Part No SW: 5G1 920 750 B    HW: 5G1 920 750 B
   Component: KOMBI         303 8311
   Coding: 03A501807E8C000D02882B0F1401000000000000
   VCID: 26150A8BD866A3BB097-8072
   Part No SW: 5Q0 963 272 B    HW: 5Q0 963 272 B
   Component: STH-MQB       006 0069
   Coding: 1309
   ASAM Dataset: EV_AuxilParkiHeateWOS 002014
   VCID: 3537DDC715C0D823B0D-8060
   Component: R64 D208L  004 0401
   Serial number: 00000000000000180382
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1265
   Revision: --------    Serial number: 0004271482
   Coding: 0B0100043F085701FB000258880F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 7CA108E3766AC96B0F3-8028
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0038
   Serial number: 29140002632800044485
   Coding: 2C0000
   Serial number: 8442320304
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 5Q0 907 155 F    HW: 5Q0 907 155 F
   Component: U13DCAC  H27 0810
   Serial number: 6072417
   Component: HRE_Master    H11 0071
   Serial number: 0392234969
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3C21C8E336EA096B4F3-8068
   Component: HRE_Slave  H11 0071
   Serial number: 0381249049
   Coding: 020111
   Serial number: 300516EEU02971
   Coding: 003F0220D000040100001001
   VCID: 43D3B31F4B1476930E9-8016
   Coding: 9307
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2DCEFB3CDE375B5DF-806E
   Serial number: 280516EER24731
   Coding: 003F0020DE00040100801001
   VCID: 42DDB61B540E7F9B05F-8016
   Coding: 0292000001000000
   VCID: 75B71DC75540982370D-8020
   Part No SW: 3Q0 035 824 B    HW: 3Q0 035 824 B
   Component: MU-S--ER      710 0757
   Coding: 02730000000000004111000100080A239F0206C40120010003
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2C01F8A3C68A99EBDF3-8078
   Subsystem 1 - Part No SW: 5G6 919 605     HW: 5G6 919 605
   Component: ABT_Std-2  H50 8120
   Serial number: VWZ6ZHT1541317
   Serial number: 40000000018766
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3431E0C31EBAC12B873-8060
   Part No SW: 5Q0 980 568 A    HW: 5Q0 980 568 B
   Component: RVC Compact+  H09 0180
   Coding: 01844201C2002013000040
   ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 006008
   ROD: EV_CamSysRVRVCARPANAMQBAB_006_VW37.rod
   VCID: 3B23CBFF33E40E53469-806E
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0060
   Serial number: 10000049677
   Coding: 0101010001020300010500010100000100
   ROD: EV_MFKBoschAU370.rod
End----------(Elapsed Time: 01:47, VBatt start/end: 12.2V/12.1V)-----------
