Page 5 of 5 FirstFirst ... 345
Results 41 to 46 of 46
Thread: Central Electrics Gremlins
  1. #41
    Aug 2019
    Cool Progress!!
    Well Gents, I drove the car around today doing figure-8's and the fault light on the dash went out. I then checked meas blocks for G85 sensor and was able to see the steering angle move in real time. I then went through the calibration procedure and everything came up aces! I drove the car around a bit more just to make sure things stayed error free and then ran another scan. Everything comes up clean except the number plate fault (01504). I've been searching forums for some clue as to what may be causing that but am not finding anything consistent or conclusive. I would greatly appreciate and insight into that fault. Latest Autoscan is below. Thanks!
    Wednesday,21,August,2019,18:45:53:23170
    VIN: WAULC68E05A114733   License Plate: TONY A4
    Mileage: 274950km-170846mi   Repair Order: 8-20-19 Scan 2 after driving and g85 calibration-original BCM
              67 69 75 76 77
    VIN: WAULC68E05A114733   Mileage: 274950km-170846miles
    Address 01: Engine        Labels: 06B-909-518-AMB.lbl
       Part No SW: 8E0 909 518 BC    HW: 8E0 909 018 A
       Component: 1.8L R4/5VT     G   0020
       Revision: 00000000    Serial number: AUZ6Z0D0371349
       Coding: 0016751
       Shop #: WSC 11111 111 45799
       VCID: 72BDDAB038BA89B7CCD-5160
    Readiness: 0110 1101
       Part No: 8E0 927 156 AA
       Component: AG5 01V 1.8l5VT USA 0505
       Coding: 0001002
       Shop #: WSC 06325 000 00000
       VCID: 6D87C9CC2184564F11F-5160
       Part No: 8E0 614 517 A
       Component: ABS/ESP allrad      4529
       Coding: 04277
       Shop #: WSC 12345
       VCID: 2615F6E0C1F2A517905-51A8
       Part No: 8E0 820 043 AD
       Component:   A4 Klimaautomat   1424
       Coding: 00000
       Shop #: WSC 06325
       VCID: 6393AFF4F240103FB7B-513C
       Part No: 8E0 907 279 F
       Component: int. Lastmodul  USA 0517
       Coding: 00003
       Shop #: WSC 11111
       VCID: 353721AC0C54DE8F29F-4B00
                57-00 - Electric Circuit Failure
    Address 15: Airbags        Labels: 8E0-959-655-84.lbl
       Part No: 8E0 959 655 K
       Component: Airbag 8.4EP        1001
       Coding: 0010607
       VCID: 3FDB43843B6814DFF33-5184
       Part No: 8E0 953 549 N
       Component: Lenks·ulenmodul     0611
       Coding: 01041
       Shop #: WSC 11111
       VCID: 3E253E8039621DD7F85-4B00
       Part No: 8E0 920 950 P
       Component: KOMBI+WEGFAHRS. RB4 D42
       Coding: 01231
       Shop #: WSC 03131
       VCID: 363526A01152D597205-5160
       WAULC68E05A114733     AUZ6Z0D0371349
       Part No: 8E0 959 433 BB
       Component: Komfortger·t T7B    1612
       Coding: 11788
       Shop #: WSC 06325
       VCID: 72BDDAB03DBA89B7CCD-4B00
       Subsystem 1 - Part No: 8E1959801
       Component: Tırsteuer.FS BRM 0205
       Subsystem 2 - Part No: 8E1959802E
       Component: Tırsteuer.BF BRM 0205
       Subsystem 3 - Part No: 8E0959801A
       Component: Tırsteuer.HL BRM 0205
       Subsystem 4 - Part No: 8E0959802A
       Component: Tırsteuer.HR BRM 0205
    End----------(Elapsed Time: 05:46, VBatt start/end: 12.8V/12.6V)-----------
  2. Likes Uwe, Jack@European_Parts liked this post
  3. #42
    Quote Originally Posted by Tbez View Post
       Coding: 00003
       Shop #: WSC 11111
    Does the light work? Is the correct type of bulb installed?
  4. Likes Jack@European_Parts liked this post
  5. #43
    Corrosion in bulb socket from water ingress or cracked lens, damaged wire harness at chafe point to deck?
  6. Likes Uwe liked this post
  7. #44
    Aug 2019
    Hi, the light does not work and I did replace bulbs. I'll poke around in there tomorrow and post update.
  8. #45
    HQ
    J519 - T32b/6 (grey connector station) - grey wire 0.35mm² - tail lights - blue wire 0.35mm² - grounded
    Not much there to check.
    Jef
  9. Likes Jack@European_Parts, Uwe liked this post
  10. #46
    Aug 2019
    Phhhht...
    Well the good news is that I've fixed the license plate issue and just about everything else that I'm capable of fixing. The bad news is that the gremlins still live. The G85 fault is back and I've been unable to clear it. I'm going to get the car into a highly qualified mechanic and get a thorough diagnoses so I can decide if the car is worth keeping. Latest scan is below just for grins.
              67 69 75 76 77
    VIN: WAULC68E05A114733   Mileage: 274960km-170852miles
       Coding: 0016751
       Coding: 0001002
       Coding: 04277
       Shop #: WSC 12345
                35-00 - -
       Coding: 00000
       Shop #: WSC 06325
       Coding: 00003
       Shop #: WSC 11111
       Coding: 0010607
       Coding: 01041
       Shop #: WSC 11111
       Coding: 01231
       Shop #: WSC 03131
       Coding: 11788
       Shop #: WSC 06325
    End----------(Elapsed Time: 06:17, VBatt start/end: 12.5V/12.5V)-----------
