Results 1 to 10 of 14
Thread: GOLF 7.5 change halogen headlights to Led, Leuchte changed error
    New User
    Jul 2019
    Spain
    Hi, I need urgent help
    I have changed my halogen headlights of golf 7.5 for a full LED with DLA (although I do not have a windshield camera) that I have achieved second hand, and I have coding problems do not go as expected:
    Lighthouse 5G1941081 and 82.
    BCM M + 5q0937084CP
    4B. 3Q090733C
    Existing Gateway High
    The wiring change has been made according to the manufacturer's scheme, and all units have been coded.
    The problem is that the high beam comes on steady without hitting the steering wheel controls, that said I deactivate BCM leuchte 8 and 9 and the low beam lights go out, so I have the high beams on Leuchte 6 and 7, I have a crossing of Leuchte, what may it be due to
    a cable crossed in the wiring, or inside the headlight if it was manipulated, could it be?
    I got a temporary solution that is activating the lichfunktion A8 and A9 by putting Fernlicht Links and Rechts (instead of Abblendlich links and rechts) and now I have no errors in BCM, in the FIS there are no mistakes either and in the 4B the only mistake is that no He lets me make the basic adjustment, although when I flurry, I turn off the lights for 1 second and turn them on again, and I still need the turning lights and coming home, but those must be activated in 4B.
    Someone with experience can guide me please !!!
    thank you.
    Jul 2014
    Tallinn, Estonia
    Also admap of the BCM because that holds the real important info in this case.
  4. Likes Uwe liked this post
    New User
    Jul 2019
    Spain
    Quote Originally Posted by siLc View Post
    This afternoon I realized that one of the cables was changed since the original scheme allows 2 options according to the equalization, of Pin 11 of the right headlight was set at 39 instead of 2 (Socket B), and I removed the existing X-shaped junction, but that has not solved the problem and the lights remain the same. And now they are crossed inside the same headlamp
    Now it's like that.
    Leuchte 6 and 7 activate high beams (backwards)
    Leuchte 8 and 9 activate low beams. (Reversed)
    Say that for the current wiring to Led we take advantage of the existing halogen.
    I can attach the schemes if necessary ..
    Tomorrow I pass you the Admap !!!
    New User
    Jul 2019
    Spain
    Modulo 9
    Fecha: 2019-08-13 17:44
        Numero de bastidor: WVWZZZAUZJP008993
        Coche: Volkswagen Golf
        Año: 2018
        Tipo de carrocería: 5-dr hatchback
        Motor: DADA 110 kW (150 HP) 1.5 l
        Kilometraje: 11157 KM
    Copia de seguridad
        Unidad de Control: 09 Centralita electrónica
        Descripción del sistema: BCM MQBAB M+
        Número de software: 5Q0937084CP
        Versión de software: 0253
        Número de hardware: 5Q0937084CF
        Versión de Hardware: H36
        Número de serie: 01001716100946
        Nombre ODX: EV_BCMMQB
        Versión ODX: 018001
        Nombre de copia de seguridad: modulo09 130819
        Codificación extendida:
            000000000000000000000000000000000000000000000000000000000000
        Sub sistemas:
            Sub sistema: WWS    170508
            Codificación extendida: 0E4DDD
            Sub sistema: RLHS
            Codificación extendida: 00A8DD
        Adaptaciones:
            Leuchte 0 BLK VL B36:
                Lasttyp 0:
                    inactivo
                Lampendefektbit Position 0:
                Fehlerort mittleres Byte DTC-DFCC 0:
                Lichtfunktion A 0:
                    nicht aktiv
                Lichtfunktion B 0:
                    nicht aktiv
                Dimmwert AB 0:
                Lichtansteuerung HD AB 0:
                    always
                Lichtfunktion C 0:
                    nicht aktiv
                Lichtfunktion D 0:
                    nicht aktiv
                Dimmwert CD 0:
                Dimming Direction CD 0:
                    maximize
                Lichtfunktion E 0:
                    nicht aktiv
                Lichtfunktion F 0:
                    nicht aktiv
                Dimmwert EF 0:
                Dimming Direction EF 0:
                    maximize
                Lichtfunktion H 0:
                    nicht aktiv
                Dimmwert GH 0:
                Dimming Direction GH 0:
                    maximize
                Lichtfunktion G 0:
                    nicht aktiv
            Leuchte1BLK VRB20:
                Lasttyp 1:
                    inactivo
                Lampendefektbitposition 1:
                Fehlerort mittleres Byte DTC-DFCC 1:
                Lichtfunktion A 1:
                    nicht aktiv
                Lichtfunktion B 1:
                    nicht aktiv
                Dimmwert AB 1:
                Lichtansteuerung HD AB 1:
                    always
                Lichtfunktion C 1:
                    nicht aktiv
                Lichtfunktion D 1:
                    nicht aktiv
                Dimmwert CD 1:
                Dimming Direction CD 1:
                    maximize
                Lichtfunktion E 1:
                    nicht aktiv
                Lichtfunktion F 1:
                    nicht aktiv
                Dimmwert EF 1:
                Dimming Direction EF 1:
                    maximize
                Lichtfunktion G 1:
                    nicht aktiv
                Lichtfunktion H 1:
                    nicht aktiv
                Dimmwert GH 1:
                Dimming Direction GH 1:
                    maximize
            Leuchte2SL VLB10:
                Lasttyp 2:
                    inactivo
                Lampendefektbitposition 2:
                Fehlerort mittleres Byte DTC-DFCC 2:
                Lichtfunktion A 2:
                    nicht aktiv
                Lichtfunktion B 2:
                    nicht aktiv
                Dimmwert AB 2:
                Lichtansteuerung HD AB 2:
                    always
                Lichtfunktion C 2:
                    nicht aktiv
                Lichtfunktion D 2:
                    nicht aktiv
                Dimmwert CD 2:
                Dimming Direction CD 2:
                    maximize
                Lichtfunktion E 2:
                    nicht aktiv
                Lichtfunktion F 2:
                    nicht aktiv
                Dimmwert EF 2:
                Dimming Direction EF 2:
                    maximize
                Lichtfunktion G 2:
                    nicht aktiv
                Lichtfunktion H 2:
                    nicht aktiv
                Dimmwert GH 2:
                Dimming Direction GH 2:
                    maximize
            Leuchte3SL VRB21:
                Lasttyp 3:
                    inactivo
                Lampendefektbitposition 3:
                Fehlerort mittleres Byte DTC-DFCC 3:
                Lichtfunktion A 3:
                    nicht aktiv
                Lichtfunktion B 3:
                    nicht aktiv
                Dimmwert AB 3:
                Lichtansteuerung HD AB 3:
                    always
                Lichtfunktion C 3:
                    nicht aktiv
                Lichtfunktion D 3:
                    nicht aktiv
                Dimmwert CD 3:
                Dimming Direction CD 3:
                    maximize
                Lichtfunktion E 3:
                    nicht aktiv
                Lichtfunktion F 3:
                    nicht aktiv
                Dimmwert EF 3:
                Dimming Direction EF 3:
                    maximize
                Lichtfunktion G 3:
                    nicht aktiv
                Lichtfunktion H 3:
                    nicht aktiv
                Dimmwert GH 3:
                Dimming Direction GH 3:
                    maximize
            Leuchte4TFL LB4:
                Lasttyp 4:
                    inactivo
                Lampendefektbitposition 4:
                Fehlerort mittleres Byte DTC-DFCC 4:
                Lichtfunktion A 4:
                    nicht aktiv
                Lichtfunktion B 4:
                    nicht aktiv
                Dimmwert AB 4:
                Lichtansteuerung HD AB 4:
                    always
                Lichtfunktion C 4:
                    nicht aktiv
                Lichtfunktion D 4:
                    nicht aktiv
                Dimmwert CD 4:
                Dimming Direction CD 4:
                    maximize
                Lichtfunktion E 4:
                    nicht aktiv
                Lichtfunktion F 4:
                    nicht aktiv
                Dimmwert EF 4:
                Dimming Direction EF 4:
                    maximize
                Lichtfunktion G 4:
                    nicht aktiv
                Lichtfunktion H 4:
                    nicht aktiv
                Dimmwert GH 4:
                Dimming Direction GH 4:
                    maximize
            Leuchte5 TFL RB32:
                Lasttyp 5:
                    inactivo
                Lampendefektbitposition 5:
                Fehlerort mittleres Byte DTC-DFCC 5:
                Lichtfunktion A 5:
                    nicht aktiv
                Lichtfunktion B 5:
                    nicht aktiv
                Dimmwert AB 5:
                Lichtansteuerung HD AB 5:
                    always
                Lichtfunktion C 5:
                    nicht aktiv
                Lichtfunktion D 5:
                    nicht aktiv
                Dimmwert CD 5:
                Dimming Direction CD 5:
                    maximize
                Lichtfunktion E 5:
                    nicht aktiv
                Lichtfunktion F 5:
                    nicht aktiv
                Dimmwert EF 5:
                Dimming Direction EF 5:
                    maximize
                Lichtfunktion G 5:
                    nicht aktiv
                Lichtfunktion H 5:
                    nicht aktiv
                Dimmwert GH 5:
                Dimming Direction GH 5:
                    maximize
            Leuchte6ABL LC5:
                Lasttyp 6:
                    5 - LED Abblendlicht
                Lampendefektbitposition 6:
                    36
                Fehlerort mittleres Byte DTC-DFCC 6:
                    1a
                Lichtfunktion A 6:
                    Fernlicht links
                Lichtfunktion B 6:
                    Lichthupe generell
                Dimmwert AB 6:
                    127
                Lichtansteuerung HD AB 6:
                    always
                Lichtfunktion C 6:
                    Coming Home oder Leaving Home aktiv
                Lichtfunktion D 6:
                    nicht aktiv
                Dimmwert CD 6:
                    127
                Dimming Direction CD 6:
                    maximize
                Lichtfunktion E 6:
                    nicht aktiv
                Lichtfunktion F 6:
                    nicht aktiv
                Dimmwert EF 6:
                Dimming Direction EF 6:
                    maximize
                Lichtfunktion G 6:
                    nicht aktiv
                Lichtfunktion H 6:
                    nicht aktiv
                Dimmwert GH 6:
                Dimming Direction GH 6:
                    maximize
            Leuchte7ABL RB1:
                Lasttyp 7:
                Lampendefektbitposition 7:
                    40
                Fehlerort mittleres Byte DTC-DFCC 7:
                    1b
                Lichtfunktion A 7:
                    Fernlicht rechts
                Lichtfunktion B 7:
                    Lichthupe generell
                Dimmwert AB 7:
                    127
                Lichtansteuerung HD AB 7:
                    always
                Lichtfunktion C 7:
                Lichtfunktion D 7:
                    nicht aktiv
                Dimmwert CD 7:
                    127
                Dimming Direction CD 7:
                    maximize
                Lichtfunktion E 7:
                    nicht aktiv
                Lichtfunktion F 7:
                    nicht aktiv
                Dimmwert EF 7:
                Dimming Direction EF 7:
                    maximize
                Lichtfunktion G 7:
                    nicht aktiv
                Lichtfunktion H 7:
                    nicht aktiv
                Dimmwert GH 7:
                Dimming Direction GH 7:
                    maximize
            Leuchte8FL LB39:
                Lasttyp 8:
                Lampendefektbitposition 8:
                    44
                Fehlerort mittleres Byte DTC-DFCC 8:
                    4b
                Lichtfunktion A 8:
                    Versorgungsbedarf der LCM Module
                Lichtfunktion B 8:
                    nicht aktiv
                Dimmwert AB 8:
                    127
                Lichtansteuerung HD AB 8:
                    always
                Lichtfunktion C 8:
                    nicht aktiv
                Lichtfunktion D 8:
                    Parklicht rechts
                Dimmwert CD 8:
                    127
                Dimming Direction CD 8:
                    maximize
                Lichtfunktion E 8:
                    nicht aktiv
                Lichtfunktion F 8:
                    nicht aktiv
                Dimmwert EF 8:
                Dimming Direction EF 8:
                    maximize
                Lichtfunktion G 8:
                    nicht aktiv
                Lichtfunktion H 8:
                    nicht aktiv
                Dimmwert GH 8:
                Dimming Direction GH 8:
                    maximize
            Leuchte9FL RB2:
                Lasttyp 9:
                Lampendefektbitposition 9:
                    3a
                Fehlerort mittleres Byte DTC-DFCC 9:
                    49
                Lichtfunktion A 9:
                Lichtfunktion B 9:
                    nicht aktiv
                Dimmwert AB 9:
                    127
                Lichtansteuerung HD AB 9:
                    always
                Lichtfunktion C 9:
                    nicht aktiv
                Lichtfunktion D 9:
                    Parklicht rechts
                Dimmwert CD 9:
                    127
                Dimming Direction CD 9:
                    maximize
                Lichtfunktion E 9:
                    nicht aktiv
                Lichtfunktion F 9:
                    nicht aktiv
                Dimmwert EF 9:
                Dimming Direction EF 9:
                    maximize
                Lichtfunktion G 9:
                    nicht aktiv
                Lichtfunktion H 9:
                    nicht aktiv
                Dimmwert GH 9:
                Dimming Direction GH 9:
                    maximize
            Leuchte10SHUTTER LB23:
                Lasttyp 10:
                    inactivo
                Lampendefektbitposition 10:
                Fehlerort mittleres Byte DTC-DFCC 10:
                Lichtfunktion A 10:
                    nicht aktiv
                Lichtfunktion B 10:
                    nicht aktiv
                Dimmwert AB 10:
                Lichtansteuerung HD AB 10:
                    always
                Lichtfunktion C 10:
                    nicht aktiv
                Lichtfunktion D 10:
                    nicht aktiv
                Dimmwert CD 10:
                Dimming Direction CD 10:
                    maximize
                Lichtfunktion E 10:
                    nicht aktiv
                Lichtfunktion F 10:
                    nicht aktiv
                Dimmwert EF 10:
                Dimming Direction EF 10:
                    maximize
                Lichtfunktion G 10:
                    nicht aktiv
                Lichtfunktion H 10:
                    nicht aktiv
                Dimmwert GH 10:
                Dimming Direction GH 10:
                    maximize
            Leuchte11SHUTTER RB22:
                Lasttyp 11:
                    inactivo
                Lampendefektbitposition 11:
                Fehlerort mittleres Byte DTC-DFCC 11:
                Lichtfunktion A 11:
                    nicht aktiv
                Lichtfunktion B 11:
                    nicht aktiv
                Dimmwert AB 11:
                Lichtansteuerung HD AB 11:
                    always
                Lichtfunktion C 11:
                    nicht aktiv
                Lichtfunktion D 11:
                    nicht aktiv
                Dimmwert CD 11:
                Dimming Direction CD 11:
                    maximize
                Lichtfunktion E 11:
                    nicht aktiv
                Lichtfunktion F 11:
                    nicht aktiv
                Dimmwert EF 11:
                Dimming Direction EF 11:
                    maximize
                Lichtfunktion G 11:
                    nicht aktiv
                Lichtfunktion H 11:
                    nicht aktiv
                Dimmwert GH 11:
                Dimming Direction GH 11:
                    maximize
            Leuchte12NL LB45:
                Lasttyp 12:
                    10 - allgemeine Scheinwerfer
                Lampendefektbitposition 12:
                    38
                Fehlerort mittleres Byte DTC-DFCC 12:
                    22
                Lichtfunktion A 12:
                    Nebellicht links
                Lichtfunktion B 12:
                    nicht aktiv
                Dimmwert AB 12:
                    100
                Lichtansteuerung HD AB 12:
                    always
                Lichtfunktion C 12:
                    nicht aktiv
                Lichtfunktion D 12:
                    nicht aktiv
                Dimmwert CD 12:
                Dimming Direction CD 12:
                    maximize
                Lichtfunktion E 12:
                    nicht aktiv
                Lichtfunktion F 12:
                    nicht aktiv
                Dimmwert EF 12:
                Dimming Direction EF 12:
                    maximize
                Lichtfunktion G 12:
                    nicht aktiv
                Lichtfunktion H 12:
                    nicht aktiv
                Dimmwert GH 12:
                Dimming Direction GH 12:
                    maximize
            Leuchte13NL RB5:
                Lasttyp 13:
                Lampendefektbitposition 13:
                    42
                Fehlerort mittleres Byte DTC-DFCC 13:
                    23
                Lichtfunktion A 13:
                    Nebellicht rechts
                Lichtfunktion B 13:
                    nicht aktiv
                Dimmwert AB 13:
                    100
                Lichtansteuerung HD AB 13:
                    always
                Lichtfunktion C 13:
                    nicht aktiv
                Lichtfunktion D 13:
                    nicht aktiv
                Dimmwert CD 13:
                Dimming Direction CD 13:
                    maximize
                Lichtfunktion E 13:
                    nicht aktiv
                Lichtfunktion F 13:
                    nicht aktiv
                Dimmwert EF 13:
                Dimming Direction EF 13:
                    maximize
                Lichtfunktion G 13:
                    nicht aktiv
                Lichtfunktion H 13:
                    nicht aktiv
                Dimmwert GH 13:
                Dimming Direction GH 13:
                    maximize
            Leuchte 35 LED Warnblinktaster C48:
                Lasttyp 15:
                    41 - LED Kleinleistung
                Lampendefektbitposition 15:
                Fehlerort mittleres Byte DTC-DFCC 15:
                    63
                Lichtfunktion A 15:
                    nicht_definiert_4C
                Lichtfunktion B 15:
                    nicht aktiv
                Dimmwert AB 15:
                    100
                Lichtansteuerung HD AB 15:
                    always
                Lichtfunktion C 15:
                    nicht aktiv
                Lichtfunktion D 15:
                    nicht aktiv
                Dimmwert CD 15:
                Dimming Direction CD 15:
                    maximize
                Lichtfunktion E 15:
                    nicht aktiv
                Lichtfunktion F 15:
                    nicht aktiv
                Dimmwert EF 15:
                Dimming Direction EF 15:
                    maximize
                Lichtfunktion G 15:
                    nicht aktiv
                Lichtfunktion H 15:
                    nicht aktiv
                Dimmwert GH 15:
                Dimming Direction GH 15:
                    maximize
            Leuchte16BLK SLB35BLK SL KC9:
                Lasttyp 16:
                    43 - allgemeine LED
                Lampendefektbitposition 16:
                Fehlerort mittleres Byte DTC-DFCC 16:
                    36
                Lichtfunktion A 16:
                    Standlicht allgemein (Schlusslicht, Positionslicht, Begrenzungslicht)
                Lichtfunktion B 16:
                    Parklicht rechts
                Dimmwert AB 16:
                    127
                Lichtansteuerung HD AB 16:
                    only_if_closed
                Lichtfunktion C 16:
                    nicht aktiv
                Lichtfunktion D 16:
                    nicht aktiv
                Dimmwert CD 16:
                Dimming Direction CD 16:
                    maximize
                Lichtfunktion E 16:
                    nicht aktiv
                Lichtfunktion F 16:
                    nicht aktiv
                Dimmwert EF 16:
                Dimming Direction EF 16:
                    maximize
                Lichtfunktion G 16:
                    nicht aktiv
                Lichtfunktion H 16:
                    nicht aktiv
                Dimmwert GH 16:
                Dimming Direction GH 16:
                    maximize
            Leuchte17TFL R BLK SRB3TFL R BLK SR KC3:
                Lasttyp 17:
                    43 - allgemeine LED
                Lampendefektbitposition 17:
                Fehlerort mittleres Byte DTC-DFCC 17:
                    35
                Lichtfunktion A 17:
                Lichtfunktion B 17:
                    Parklicht links (beidseitiges Parklicht aktiviert li & re)
                Dimmwert AB 17:
                    127
                Lichtansteuerung HD AB 17:
                    only_if_closed
                Lichtfunktion C 17:
                    nicht aktiv
                Lichtfunktion D 17:
                    nicht aktiv
                Dimmwert CD 17:
                Dimming Direction CD 17:
                    maximize
                Lichtfunktion E 17:
                    nicht aktiv
                Lichtfunktion F 17:
                    nicht aktiv
                Dimmwert EF 17:
                Dimming Direction EF 17:
                    maximize
                Lichtfunktion G 17:
                    nicht aktiv
                Lichtfunktion H 17:
                    nicht aktiv
                Dimmwert GH 17:
                Dimming Direction GH 17:
                    maximize
            Leuchte18BLK HLA60:
                Lasttyp 18:
                    38 - LED Blinkleuchten
                Lampendefektbitposition 18:
                    8
                Fehlerort mittleres Byte DTC-DFCC 18:
                    16
                Lichtfunktion A 18:
                    Blinken links Hellphase
                Lichtfunktion B 18:
                    nicht aktiv
                Dimmwert AB 18:
                    127
                Lichtansteuerung HD AB 18:
                    always
                Lichtfunktion C 18:
                    nicht aktiv
                Lichtfunktion D 18:
                    nicht aktiv
                Dimmwert CD 18:
                Dimming Direction CD 18:
                    maximize
                Lichtfunktion E 18:
                    nicht aktiv
                Lichtfunktion F 18:
                    nicht aktiv
                Dimmwert EF 18:
                Dimming Direction EF 18:
                    maximize
                Lichtfunktion G 18:
                    nicht aktiv
                Lichtfunktion H 18:
                    nicht aktiv
                Dimmwert GH 18:
                Dimming Direction GH 18:
                    maximize
            Leuchte19BLK HRC31:
                Lasttyp 19:
                Lampendefektbitposition 19:
                    18
                Fehlerort mittleres Byte DTC-DFCC 19:
                    18
                Lichtfunktion A 19:
                    Blinken rechts Hellphase
                Lichtfunktion B 19:
                    nicht aktiv
                Dimmwert AB 19:
                    127
                Lichtansteuerung HD AB 19:
                    always
                Lichtfunktion C 19:
                    nicht aktiv
                Lichtfunktion D 19:
                    nicht aktiv
                Dimmwert CD 19:
                Dimming Direction CD 19:
                    maximize
                Lichtfunktion E 19:
                    nicht aktiv
                Lichtfunktion F 19:
                    nicht aktiv
                Dimmwert EF 19:
                Dimming Direction EF 19:
                    maximize
                Lichtfunktion G 19:
                    nicht aktiv
                Lichtfunktion H 19:
                    nicht aktiv
                Dimmwert GH 19:
                Dimming Direction GH 19:
                    maximize
            Leuchte20BR LA71:
                Lasttyp 20:
                    43 - allgemeine LED
                Lampendefektbitposition 20:
                    9
                Fehlerort mittleres Byte DTC-DFCC 20:
                    2b
                Lichtfunktion A 20:
                    Bremslicht
                Lichtfunktion B 20:
                    nicht aktiv
                Dimmwert AB 20:
                    127
                Lichtansteuerung HD AB 20:
                    always
                Lichtfunktion C 20:
                    nicht aktiv
                Lichtfunktion D 20:
                    nicht aktiv
                Dimmwert CD 20:
                Dimming Direction CD 20:
                    maximize
                Lichtfunktion E 20:
                    nicht aktiv
                Lichtfunktion F 20:
                    nicht aktiv
                Dimmwert EF 20:
                Dimming Direction EF 20:
                    maximize
                Lichtfunktion G 20:
                    nicht aktiv
                Lichtfunktion H 20:
                    nicht aktiv
                Dimmwert GH 20:
                Dimming Direction GH 20:
                    maximize
            Leuchte21BR RC8:
                Lasttyp 21:
                    43 - allgemeine LED
                Lampendefektbitposition 21:
                    19
                Fehlerort mittleres Byte DTC-DFCC 21:
                    2d
                Lichtfunktion A 21:
                    Bremslicht
                Lichtfunktion B 21:
                    nicht aktiv
                Dimmwert AB 21:
                    127
                Lichtansteuerung HD AB 21:
                    always
                Lichtfunktion C 21:
                    nicht aktiv
                Lichtfunktion D 21:
                    nicht aktiv
                Dimmwert CD 21:
                Dimming Direction CD 21:
                    maximize
                Lichtfunktion E 21:
                    nicht aktiv
                Lichtfunktion F 21:
                    nicht aktiv
                Dimmwert EF 21:
                Dimming Direction EF 21:
                    maximize
                Lichtfunktion G 21:
                    nicht aktiv
                Lichtfunktion H 21:
                    nicht aktiv
                Dimmwert GH 21:
                Dimming Direction GH 21:
                    maximize
            Leuchte22BR MA57:
                Lasttyp 22:
                    42 - LED dritte Bremsleuchte
                Lampendefektbitposition 22:
                    29
                Fehlerort mittleres Byte DTC-DFCC 22:
                    2c
                Lichtfunktion A 22:
                    Bremslicht
                Lichtfunktion B 22:
                    Quittierungsfunktion 1
                Dimmwert AB 22:
                    127
                Lichtansteuerung HD AB 22:
                    always
                Lichtfunktion C 22:
                    nicht aktiv
                Lichtfunktion D 22:
                    nicht aktiv
                Dimmwert CD 22:
                Dimming Direction CD 22:
                    maximize
                Lichtfunktion E 22:
                    nicht aktiv
                Lichtfunktion F 22:
                    nicht aktiv
                Dimmwert EF 22:
                Dimming Direction EF 22:
                    maximize
                Lichtfunktion G 22:
                    nicht aktiv
                Lichtfunktion H 22:
                    nicht aktiv
                Dimmwert GH 22:
                Dimming Direction GH 22:
                    maximize
            Leuchte23SL HLC10:
                Lasttyp 23:
                    43 - allgemeine LED
                Lampendefektbitposition 23:
                    a
                Fehlerort mittleres Byte DTC-DFCC 23:
                    29
                Lichtfunktion A 23:
                Lichtfunktion B 23:
                Dimmwert AB 23:
                    127
                Lichtansteuerung HD AB 23:
                    always
                Lichtfunktion C 23:
                    nicht aktiv
                Lichtfunktion D 23:
                    nicht aktiv
                Dimmwert CD 23:
                Dimming Direction CD 23:
                    maximize
                Lichtfunktion E 23:
                    nicht aktiv
                Lichtfunktion F 23:
                    nicht aktiv
                Dimmwert EF 23:
                Dimming Direction EF 23:
                    maximize
                Lichtfunktion G 23:
                    nicht aktiv
                Lichtfunktion H 23:
                    nicht aktiv
                Dimmwert GH 23:
                Dimming Direction GH 23:
                    maximize
            Leuchte24SL HRA65:
                Lasttyp 24:
                    43 - allgemeine LED
                Lampendefektbitposition 24:
                    1a
                Fehlerort mittleres Byte DTC-DFCC 24:
                    2a
                Lichtfunktion A 24:
                Lichtfunktion B 24:
                    Parklicht rechts
                Dimmwert AB 24:
                    127
                Lichtansteuerung HD AB 24:
                    always
                Lichtfunktion C 24:
                    nicht aktiv
                Lichtfunktion D 24:
                    nicht aktiv
                Dimmwert CD 24:
                Dimming Direction CD 24:
                    maximize
                Lichtfunktion E 24:
                    nicht aktiv
                Lichtfunktion F 24:
                    nicht aktiv
                Dimmwert EF 24:
                Dimming Direction EF 24:
                    maximize
                Lichtfunktion G 24:
                    nicht aktiv
                Lichtfunktion H 24:
                    nicht aktiv
                Dimmwert GH 24:
                Dimming Direction GH 24:
                    maximize
            Leuchte25KZL HA59:
                Lasttyp 25:
                    25 - allgemeine Glühlampe Innen- oder Außenlicht
                Lampendefektbitposition 25:
                    28
                Fehlerort mittleres Byte DTC-DFCC 25:
                    30
                Lichtfunktion A 25:
                Lichtfunktion B 25:
                    nicht aktiv
                Dimmwert AB 25:
                    127
                Lichtansteuerung HD AB 25:
                    always
                Lichtfunktion C 25:
                    nicht aktiv
                Lichtfunktion D 25:
                    nicht aktiv
                Dimmwert CD 25:
                Dimming Direction CD 25:
                    maximize
                Lichtfunktion E 25:
                    nicht aktiv
                Lichtfunktion F 25:
                    nicht aktiv
                Dimmwert EF 25:
                Dimming Direction EF 25:
                    maximize
                Lichtfunktion G 25:
                    nicht aktiv
                Lichtfunktion H 25:
                    nicht aktiv
                Dimmwert GH 25:
                Dimming Direction GH 25:
                    maximize
            Leuchte26NSL LA72:
                Lasttyp 26:
                    43 - allgemeine LED
                Lampendefektbitposition 26:
                    c
                Fehlerort mittleres Byte DTC-DFCC 26:
                    2e
                Lichtfunktion A 26:
                    Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr
                Lichtfunktion B 26:
                    nicht aktiv
                Dimmwert AB 26:
                    127
                Lichtansteuerung HD AB 26:
                    only_if_closed
                Lichtfunktion C 26:
                    nicht aktiv
                Lichtfunktion D 26:
                    nicht aktiv
                Dimmwert CD 26:
                Dimming Direction CD 26:
                    maximize
                Lichtfunktion E 26:
                    nicht aktiv
                Lichtfunktion F 26:
                    nicht aktiv
                Dimmwert EF 26:
                Dimming Direction EF 26:
                    maximize
                Lichtfunktion G 26:
                    nicht aktiv
                Lichtfunktion H 26:
                    nicht aktiv
                Dimmwert GH 26:
                Dimming Direction GH 26:
                    maximize
            Leuchte27NSL RC6:
                Lasttyp 27:
                    inactivo
                Lampendefektbitposition 27:
                Fehlerort mittleres Byte DTC-DFCC 27:
                Lichtfunktion A 27:
                    nicht aktiv
                Lichtfunktion B 27:
                    nicht aktiv
                Dimmwert AB 27:
                Lichtansteuerung HD AB 27:
                    always
                Lichtfunktion C 27:
                    nicht aktiv
                Lichtfunktion D 27:
                    nicht aktiv
                Dimmwert CD 27:
                Dimming Direction CD 27:
                    maximize
                Lichtfunktion E 27:
                    nicht aktiv
                Lichtfunktion F 27:
                    nicht aktiv
                Dimmwert EF 27:
                Dimming Direction EF 27:
                    maximize
                Lichtfunktion G 27:
                    nicht aktiv
                Lichtfunktion H 27:
                    nicht aktiv
                Dimmwert GH 27:
                Dimming Direction GH 27:
                    maximize
            Leuchte28RFL LC11:
                Lasttyp 28:
                    43 - allgemeine LED
                Lampendefektbitposition 28:
                    b
                Fehlerort mittleres Byte DTC-DFCC 28:
                    31
                Lichtfunktion A 28:
                    Rueckfahrlicht
                Lichtfunktion B 28:
                    nicht aktiv
                Dimmwert AB 28:
                    127
                Lichtansteuerung HD AB 28:
                    only_if_closed
                Lichtfunktion C 28:
                    nicht aktiv
                Lichtfunktion D 28:
                    nicht aktiv
                Dimmwert CD 28:
                Dimming Direction CD 28:
                    maximize
                Lichtfunktion E 28:
                    nicht aktiv
                Lichtfunktion F 28:
                    nicht aktiv
                Dimmwert EF 28:
                Dimming Direction EF 28:
                    maximize
                Lichtfunktion G 28:
                    nicht aktiv
                Lichtfunktion H 28:
                    nicht aktiv
                Dimmwert GH 28:
                Dimming Direction GH 28:
                    maximize
            Leuchte29RFL RA64:
                Lasttyp 29:
                    43 - allgemeine LED
                Lampendefektbitposition 29:
                    1b
                Fehlerort mittleres Byte DTC-DFCC 29:
                    32
                Lichtfunktion A 29:
                    Rueckfahrlicht
                Lichtfunktion B 29:
                    nicht aktiv
                Dimmwert AB 29:
                    127
                Lichtansteuerung HD AB 29:
                    only_if_closed
                Lichtfunktion C 29:
                    nicht aktiv
                Lichtfunktion D 29:
                    nicht aktiv
                Dimmwert CD 29:
                Dimming Direction CD 29:
                    maximize
                Lichtfunktion E 29:
                    nicht aktiv
                Lichtfunktion F 29:
                    nicht aktiv
                Dimmwert EF 29:
                Dimming Direction EF 29:
                    maximize
                Lichtfunktion G 29:
                    nicht aktiv
                Lichtfunktion H 29:
                    nicht aktiv
                Dimmwert GH 29:
                Dimming Direction GH 29:
                    maximize
            Leuchte30FR LC72:
                Lasttyp 30:
                    36 - LED Kleinleistung
                Lampendefektbitposition 30:
                Fehlerort mittleres Byte DTC-DFCC 30:
                Lichtfunktion A 30:
                    Fussraumlicht
                Lichtfunktion B 30:
                    nicht aktiv
                Dimmwert AB 30:
                    89
                Lichtansteuerung HD AB 30:
                    always
                Lichtfunktion C 30:
                    nicht aktiv
                Lichtfunktion D 30:
                    nicht aktiv
                Dimmwert CD 30:
                Dimming Direction CD 30:
                    maximize
                Lichtfunktion E 30:
                    nicht aktiv
                Lichtfunktion F 30:
                    nicht aktiv
                Dimmwert EF 30:
                Dimming Direction EF 30:
                    maximize
                Lichtfunktion G 30:
                    nicht aktiv
                Lichtfunktion H 30:
                    nicht aktiv
                Dimmwert GH 30:
                Dimming Direction GH 30:
                    maximize
            Leuchte31AMBL 1C61:
                Lasttyp 31:
                    inactivo
                Lampendefektbitposition 31:
                Fehlerort mittleres Byte DTC-DFCC 31:
                Lichtfunktion A 31:
                    nicht aktiv
                Lichtfunktion B 31:
                    nicht aktiv
                Dimmwert AB 31:
                Lichtansteuerung HD AB 31:
                    always
                Lichtfunktion C 31:
                    nicht aktiv
                Lichtfunktion D 31:
                    nicht aktiv
                Dimmwert CD 31:
                Dimming Direction CD 31:
                    maximize
                Lichtfunktion E 31:
                    nicht aktiv
                Lichtfunktion F 31:
                    nicht aktiv
                Dimmwert EF 31:
                Dimming Direction EF 31:
                    maximize
                Lichtfunktion G 31:
                    nicht aktiv
                Lichtfunktion H 31:
                    nicht aktiv
                Dimmwert GH 31:
                Dimming Direction GH 31:
                    maximize
            Leuchte32AMBL 2C35:
                Lasttyp 32:
                    inactivo
                Lampendefektbitposition 32:
                Fehlerort mittleres Byte DTC-DFCC 32:
                Lichtfunktion A 32:
                    nicht aktiv
                Lichtfunktion B 32:
                    nicht aktiv
                Dimmwert AB 32:
                Lichtansteuerung HD AB 32:
                    always
                Lichtfunktion C 32:
                    nicht aktiv
                Lichtfunktion D 32:
                    nicht aktiv
                Dimmwert CD 32:
                Dimming Direction CD 32:
                    maximize
                Lichtfunktion E 32:
                    nicht aktiv
                Lichtfunktion F 32:
                    nicht aktiv
                Dimmwert EF 32:
                Dimming Direction EF 32:
                    maximize
                Lichtfunktion G 32:
                    nicht aktiv
                Lichtfunktion H 32:
                    nicht aktiv
                Dimmwert GH 32:
                Dimming Direction GH 32:
                    maximize
            Leuchte33AMBL 3C36:
                Lasttyp 33:
                    inactivo
                Lampendefektbitposition 33:
                Fehlerort mittleres Byte DTC-DFCC 33:
                Lichtfunktion A 33:
                    nicht aktiv
                Lichtfunktion B 33:
                    nicht aktiv
                Dimmwert AB 33:
                Lichtansteuerung HD AB 33:
                    always
                Lichtfunktion C 33:
                    nicht aktiv
                Lichtfunktion D 33:
                    nicht aktiv
                Dimmwert CD 33:
                Dimming Direction CD 33:
                    maximize
                Lichtfunktion E 33:
                    nicht aktiv
                Lichtfunktion F 33:
                    nicht aktiv
                Dimmwert EF 33:
                Dimming Direction EF 33:
                    maximize
                Lichtfunktion G 33:
                    nicht aktiv
                Lichtfunktion H 33:
                    nicht aktiv
                Dimmwert GH 33:
                Dimming Direction GH 33:
                    maximize
            Leuchte34AMBL 4C37:
                Lasttyp 34:
                    inactivo
                Lampendefektbitposition 34:
                Fehlerort mittleres Byte DTC-DFCC 34:
                Lichtfunktion A 34:
                    nicht aktiv
                Lichtfunktion B 34:
                    nicht aktiv
                Dimmwert AB 34:
                Lichtansteuerung HD AB 34:
                    always
                Lichtfunktion C 34:
                    nicht aktiv
                Lichtfunktion D 34:
                    nicht aktiv
                Dimmwert CD 34:
                Dimming Direction CD 34:
                    maximize
                Lichtfunktion E 34:
                    nicht aktiv
                Lichtfunktion F 34:
                    nicht aktiv
                Dimmwert EF 34:
                Dimming Direction EF 34:
                    maximize
                Lichtfunktion G 34:
                    nicht aktiv
                Lichtfunktion H 34:
                    nicht aktiv
                Dimmwert GH 34:
                Dimming Direction GH 34:
                    maximize
            HW_Verbau:
                Aussentemperatursensor:
                    montado
                Desgaste de las guarniciones de freno:
                    montado
                PTC Zuheizer:
                    Sin montar
                Falta líquido de frenos:
                    montado
                Falta líquido refrigerante:
                    montado
                Falta de agua para lavar:
                    Sin montar
                Kontaktschalter_fuer_Motorhaube:
                    montado
                Status_Tankdeckelverriegelung:
                    inactivo
                Druckklappe:
                    Sin montar
                Ladesteckerverriegelung:
                    Sin montar
                Signalhorn ohne KL15:
                    activado
                Elektrische_Laderaumabdeckung:
                    Sin montar
                Elektrische Laderaumabdeckung aktiv:
                    inactivo
            Aussenlicht_Front:
                Abblendlicht_Leuchtentyp:
                    H7
                Zahl der aktiven Scheinwerfer auf 2 limitieren:
                    in Betrieb lassen
                Lichthupe bei Zuendung aus moeglich:
                    activado
                Allwetterlicht Einschaltgrenze:
                    350 km/h
                Allwetterlicht Ausschaltgrenze:
                    350 km/h
                Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht:
                    inactivo
                Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich:
                    inactivo
                Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge:
                    activado
                Standlicht aktiviert zusaetzlich Tagfahrlicht:
                    activado
                Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten:
                    inactivo
                Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht:
                    inactivo
                Tagfahrlichtkontrollleuchte:
                    inactivo
                Fahrlicht bei Tag:
                    Luz de circulación diurna
                Tagfahrlicht nur in Schalterstellung AUTO:
                    inactivo
                Signaturlicht_verbaut:
                    Sin montar
                Signaturlicht HMI-default Anzeige im Kombiinstrument:
                    inactivo
                TFL_Abschaltung_ueber_Geschwindigkeit:
                    inactivo
                Geschwindigkeitsabhaengiges TFL:
                    5 km/h
            Aussenlicht_Heck:
                Bremslicht_ist_auch_Blinklicht:
                    no
                Schlusslicht mit Bremslichtfunktion:
                    inactivo
                Notbremsanzeige NBA:
                    activado
                Umgreifende_Heckklappe:
                    Sin montar
                Nebelschlusslicht Warngeschwindigkeit:
                    0 km/h
            Luz de curva estática:
                bei Rueckwaertsfahrt:
                    ambos lados
                Zeitwert Einschaltzeit Abbiegelicht:
                    15 min
                Vorschrift:
                    ECE R119
                Untere Geschwindigkeitsschwelle:
                    0.0 km/h
                Obere Geschwindigkeitsschwelle:
                    40.0 km/h
                Ángulo del volante, offset:
                    0.3 °
                Unterer Lenkradwinkel:
                    80 °
                Oberer Lenkradwinkel:
                    120 °
                Abdimmgeschwindigkeit:
                    50.0 %/s
                Maximaltemperatur:
                    100.0 °C
                obere Grenztemperatur:
                    95.0 °C
                untere Grenztemperatur:
                    80.0 °C
            Sonderfunktionen:
                Sonderfunktionen 1:
                    Sin montar
                Sonderfunktionen:
                    no desbloqueado
                Signalprioritaet fuer Blinker:
                    SMLS
            Fernlicht_assistent:
                Erweiterte_Fernlichtsteuerung:
                    AFS, BCM-Fernlicht
                Menuesteuerung Fernlichtassistent:
                    Disponible
                Fernlichtassistent Reset:
                    inactivo
                Menuesteuerung Fernlichtassistent Werkseinstellung:
                    Disponible
                Assistenzfahrlicht, Empfindlichkeit per BAP einstellbar:
                    Disponible
            lwr_ofs_RSw_Ah1S:
                x0:
                    -5.00 %
                x1:
                    -5.00 %
                x2:
                    -5.00 %
                x3:
                    -5.00 %
                x4:
                    -5.00 %
                y0:
                    -5.00
                y1:
                    -5.00
                y2:
                    -5.00
                y3:
                    -5.00
                y4:
                    -5.00
            Kennlinie_sLWR_Soll:
                x0:
                    100.00 %
                x1:
                    100.00 %
                x2:
                    100.00 %
                x3:
                    100.00 %
                x4:
                    83.00 %
                x5:
                    67.00 %
                x6:
                    50.00 %
                x7:
                    33.00
                x8:
                    17.00 %
                x9:
                    0.00 %
                y0:
                    58.5 %
                y1:
                    58.5 %
                y2:
                    58.5 %
                y3:
                    58.5 %
                y4:
                    54.5 %
                y5:
                    49.5 %
                y6:
                    46.5 %
                y7:
                    35.5 %
                y8:
                    31.5 %
                y9:
                    20.0 %
            Funciones de luz de asistencia:
                Regen_Lichtsensor:
                    LIN_Regen_Licht_Sensor
                Feuchtesensor:
                    montado
                Assistenzfahrlicht bei Regen:
                    activado
                Sonnensensor:
                    Sin montar
                LS_Error_Ausgabe:
                    activado
                Maskierung_Regenfunktion:
                    inactivo
                Lichtsensorempfindlichkeit:
                    normal
            Sensor de luz:
                Einschaltgrenze_CHO_LHO:
                    600 lx
                Daemmerungsgrenze, Hysterese_obergrenze:
                    1200 lx
                Daemmerungsgrenze_Hysterese_untergrenze:
                    2200 lx
                Helligkeitsgrenze_sehr_hell:
                    2000 lx
                Helligkeitsgrenze_Licht__einschalten:
                    1200 lx
                Helligkeitsgrenze_Licht_ausschalten:
                    2200 lx
                Minimale_Beleuchtungsstaerke:
                    0 lx
                Maximale_Beleuchtungsstaerke:
                    0 lx
                Minimale_Ausgangsspannung:
                    0 mV
                Maximale_Ausgangsspannung:
                    0 mV
                Tunnel_einschalt_verzoegerung:
                ECE_Lichteinschaltschwelle:
                    0 lx
                Helligkeitsgrenze_Licht_ausschalten_red:
                HMI_Wiper_Comfort_Rain_Sensor_OFF:
                    not active
                HMI_Exterior_light_on_highway:
                    inactivo
                HMI_Exterior_light_on_rain:
                    inactivo
                LS_Error_Ausgabe:
                    inactivo
                HMI_exterior_light_sensitivity:
                    frueh
            LuB Lichtrouter Kennlinie 1:
                x0:
                    0.0 %
                x1:
                    5.0 %
                x2:
                    50.0 %
                x3:
                    75.0 %
                x4:
                    110.0
                x5:
                    126.5
                y0:
                    0.0 %
                y1:
                    6.0 %
                y2:
                    16.0 %
                y3:
                    30.0 %
                y4:
                    60.0 %
                y5:
                    100.0 %
            Configuración de luces:
                    0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000536001A0D0F7F1E007F0000000000000540001B0E0F7F1E007F0000000000000544004B46007F000A7F000000000000053A004946007F000A7F00000000000000000000000000000000000000000000000000000000000000000000000000000A3800221200640000000000000000000A420023130064000000000000000000
            Leuchtenkonfiguration_Aussenlich_Heck:
                    2608001602007F0000000000000000002618001804007F0000000000000000002B09002B18007F0000000000000000002B19002D18007F0000000000000000002A29002C18247F0000000000000000002B0A002908097F0000000000000000002B1A002A080A7F0000000000000000001928003008007F0000000000000000002B0C002E1B00FF000000000000000000000000000000000000000000000000002B0B00311900FF0000000000000000002B1B00321900FF000000000000000000
            Leuchtenkonfiguration_Sonstiges:
                    2B000036080AFF0000000000000000002B0000350809FF000000000000000000240000022B005900000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000290000634C0064000000000000000000
            debug_light_function:
                Adresse:
                Bitmask:
                Offset:
                Divisor:
                Polaritaet:
                Aktivierung:
            Iluminación interior, parámetros:
                p_t_verzoegerung_einstieg_innenlicht:
                    0.0 s
                p_t_verzoegerung_ausstieg_innenlicht:
                    0.0 s
                p_t_verzoegerung_oeffnen_innenlicht:
                    0.0 s
                p_t_verzoegerung_entriegelt_innenlicht:
                    0.0 s
                p_t_verzoegerung_schliessen_innenlicht:
                    0.0 s
                p_t_verzoegerung_schluessel_ab_innenlicht:
                    0.0 s
                p_t_verzoegerung_verriegelt_innenlicht:
                    0.0 s
                p_t_verzoegerung_einstieg_tueren:
                    0.5 s
                p_t_verzoegerung_ausstieg_tueren:
                    0.0 s
                p_t_verzoegerung_oeffnen_tueren:
                    0.0 s
                p_t_verzoegerung_entriegelt_tueren:
                    0.0 s
                p_t_verzoegerung_schliessen_tueren:
                    0.0 s
                p_t_verzoegerung_schluessel_ab_tueren:
                    0.0 s
                p_t_verzoegerung_verriegelt_tueren:
                    0.0 s
                p_t_verzoegerung_einstieg_fussraum:
                    2.0 s
                p_t_verzoegerung_ausstieg_fussraum:
                    0.0 s
                p_t_verzoegerung_oeffnen_fussraum:
                    0.0 s
                p_t_verzoegerung_entriegelt_fussraum:
                    0.0 s
                p_t_verzoegerung_schliessen_fussraum:
                    0.0 s
                p_t_verzoegerung_schluessel_ab_fussraum:
                    0.0 s
                p_t_verzoegerung_verriegelt_fussraum:
                    0.0 s
                p_t_verzoegerung_einstieg_cockpit:
                    0.0 s
                p_t_verzoegerung_ausstieg_cockpit:
                    0.0 s
                p_t_verzoegerung_oeffnen_cockpit:
                    0.0 s
                p_t_verzoegerung_entriegelt_cockpit:
                    0.0 s
                p_t_verzoegerung_schliessen_cockpit:
                    0.0 s
                p_t_verzoegerung_schluessel_ab_cockpit:
                    0.0 s
                p_t_verzoegerung_verriegelt_cockpit:
                    0.0 s
                p_t_verzoegerung_einstieg_miko:
                    0.0 s
                p_t_verzoegerung_ausstieg_miko:
                    0.0 s
                p_t_verzoegerung_oeffnen_miko:
                    0.0 s
                p_t_verzoegerung_entriegelt_miko:
                    0.0 s
                p_t_verzoegerung_schliessen_miko:
                    0.0 s
                p_t_verzoegerung_schluessel_ab_miko:
                    0.0 s
                p_t_verzoegerung_verriegelt_miko:
                    0.0 s
                p_t_verzoegerung_einstieg_dach:
                    0.0 s
                p_t_verzoegerung_ausstieg_dach:
                    0.0 s
                p_t_verzoegerung_oeffnen_dach:
                    0.0 s
                p_t_verzoegerung_entriegelt_dach:
                    0.0 s
                p_t_verzoegerung_schliessen_dach:
                    0.0 s
                p_t_verzoegerung_schluessel_ab_dach:
                    0.0 s
                p_t_verzoegerung_verriegelt_dach:
                    0.0 s
                p_helligkeit_entriegelt_innenlicht:
                    100 %
                p_helligkeit_max_innenlicht:
                    100 %
                p_helligkeit_HD_auf_zuendung_ein_innenlicht:
                    100 %
                p_helligkeit_HD_auf_zuendung_aus_innenlicht:
                    100 %
                p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht:
                    100 %
                p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht:
                    100 %
                p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht:
                    0 %
                p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht:
                    100 %
                p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht:
                    100 %
                p_helligkeit_einausstieg_innenlicht:
                    100 %
                p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht:
                    100 %
                p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht:
                    100 %
                p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht:
                    100 %
                p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht:
                    100 %
                p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht:
                    100 %
                p_adaption_kundenwunsch_tuer:
                    0.60
                p_helligkeit_entriegelt_tueren:
                    0 %
                p_helligkeit_max_tueren:
                    96 %
                p_helligkeit_HD_auf_zuendung_ein_tueren:
                    126 %
                p_helligkeit_HD_auf_zuendung_aus_tueren:
                    127 %
                p_helligkeit_dieseTuer_auf_zuendung_ein_tueren:
                    96 %
                p_helligkeit_andereTuer_auf_zuendung_ein_tueren:
                    96 %
                p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren:
                    126 %
                p_helligkeit_dieseTuer_auf_zuendung_aus_tueren:
                    96 %
                p_helligkeit_andereTuer_auf_zuendung_aus_tueren:
                    96 %
                p_helligkeit_einausstieg_tueren:
                    96 %
                p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren:
                    127 %
                p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren:
                    96 %
                p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren:
                    96 %
                p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren:
                    96 %
                p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren:
                    96 %
                p_adaption_kundenwunsch_fussraum:
                    0.20
                p_helligkeit_entriegelt_fussraum:
                    0 %
                p_helligkeit_max_fussraum:
                    70 %
                p_helligkeit_HD_auf_zuendung_ein_fussraum:
                    126 %
                p_helligkeit_HD_auf_zuendung_aus_fussraum:
                    127 %
                p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum:
                    70 %
                p_helligkeit_andereTuer_auf_zuendung_ein_fussraum:
                    70 %
                p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum:
                    126 %
                p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum:
                    70 %
                p_helligkeit_andereTuer_auf_zuendung_aus_fussraum:
                    70 %
                p_helligkeit_einausstieg_fussraum:
                    70 %
                p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum:
                    127 %
                p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum:
                    70 %
                p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum:
                    70 %
                p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum:
                    70 %
                p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum:
                    70 %
                p_adaption_kundenwunsch_lautsprecher:
                    1.00
                p_helligkeit_entriegelt_lautsprecher:
                    100 %
                p_helligkeit_max_lautsprecher:
                    100 %
                p_helligkeit_HD_auf_zuendung_ein_lautsprecher:
                    100 %
                p_helligkeit_HD_auf_zuendung_aus_lautsprecher:
                    100 %
                p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher:
                    100 %
                p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher:
                    100 %
                p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher:
                    126 %
                p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher:
                    100 %
                p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher:
                    100 %
                p_helligkeit_einausstieg_lautsprecher:
                    100 %
                p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher:
                    100 %
                p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher:
                    100 %
                p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher:
                    100 %
                p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher:
                    100 %
                p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher:
                    100 %
                p_adaption_kundenwunsch_itafel:
                    1.00
                p_helligkeit_entriegelt_itafel:
                    100 %
                p_helligkeit_max_itafel:
                    100 %
                p_helligkeit_HD_auf_zuendung_ein_itafel:
                    100 %
                p_helligkeit_HD_auf_zuendung_aus_itafel:
                    100 %
                p_helligkeit_dieseTuer_auf_zuendung_ein_itafel:
                    100 %
                p_helligkeit_andereTuer_auf_zuendung_ein_itafel:
                    100 %
                p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel:
                    126 %
                p_helligkeit_dieseTuer_auf_zuendung_aus_itafel:
                    100 %
                p_helligkeit_andereTuer_auf_zuendung_aus_itafel:
                    100 %
                p_helligkeit_einausstieg_itafel:
                    100 %
                p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel:
                    100 %
                p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel:
                    100 %
                p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel:
                    100 %
                p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel:
                    100 %
                p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel:
                    100 %
                p_adaption_kundenwunsch_cockpit:
                    1.00
                p_helligkeit_entriegelt_cockpit:
                    100 %
                p_helligkeit_max_cockpit:
                    100 %
                p_helligkeit_HD_auf_zuendung_ein_cockpit:
                    100 %
                p_helligkeit_HD_auf_zuendung_aus_cockpit:
                    100 %
                p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit:
                    100 %
                p_helligkeit_andereTuer_auf_zuendung_ein_cockpit:
                    100 %
                p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit:
                    126 %
                p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit:
                    100 %
                p_helligkeit_andereTuer_auf_zuendung_aus_cockpit:
                    100 %
                p_helligkeit_einausstieg_cockpit:
                    100 %
                p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit:
                    100 %
                p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit:
                    100 %
                p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit:
                    100 %
                p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit:
                    100 %
                p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit:
                    100 %
                p_adaption_kundenwunsch_miko:
                    1.00
                p_helligkeit_entriegelt_miko:
                    100 %
                p_helligkeit_max_miko:
                    100 %
                p_helligkeit_HD_auf_zuendung_ein_miko:
                    100 %
                p_helligkeit_HD_auf_zuendung_aus_miko:
                    100 %
                p_helligkeit_dieseTuer_auf_zuendung_ein_miko:
                    100 %
                p_helligkeit_andereTuer_auf_zuendung_ein_miko:
                    100 %
                p_helligkeit_Fzg_geschlossen_zuendung_ein_miko:
                    126 %
                p_helligkeit_dieseTuer_auf_zuendung_aus_miko:
                    100 %
                p_helligkeit_andereTuer_auf_zuendung_aus_miko:
                    100 %
                p_helligkeit_einausstieg_miko:
                    100 %
                p_helligkeit_Fzg_geschlossen_zuendung_aus_miko:
                    100 %
                p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko:
                    100 %
                p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko:
                    100 %
                p_helligkeit_Tueren_geschlossen_schluessel_ab_miko:
                    100 %
                p_helligkeit_Fzg_geschlossen_schluessel_ab_miko:
                    100 %
                p_adaption_kundenwunsch_dach:
                    1.00
                p_helligkeit_entriegelt_dach:
                    100 %
                p_helligkeit_max_dach:
                    100 %
                p_helligkeit_HD_auf_zuendung_ein_dach:
                    100 %
                p_helligkeit_HD_auf_zuendung_aus_dach:
                    100 %
                p_helligkeit_dieseTuer_auf_zuendung_ein_dach:
                    100 %
                p_helligkeit_andereTuer_auf_zuendung_ein_dach:
                    100 %
                p_helligkeit_Fzg_geschlossen_zuendung_ein_dach:
                    126 %
                p_helligkeit_dieseTuer_auf_zuendung_aus_dach:
                    100 %
                p_helligkeit_andereTuer_auf_zuendung_aus_dach:
                    100 %
                p_helligkeit_einausstieg_dach:
                    100 %
                p_helligkeit_Fzg_geschlossen_zuendung_aus_dach:
                    100 %
                p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach:
                    100 %
                p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach:
                    100 %
                p_helligkeit_Tueren_geschlossen_schluessel_ab_dach:
                    100 %
                p_helligkeit_Fzg_geschlossen_schluessel_ab_dach:
                    100 %
                p_adaption_kundenwunsch_psd:
                    1.00
                p_helligkeit_entriegelt_psd:
                    100 %
                p_helligkeit_max_psd:
                    100 %
                p_helligkeit_HD_auf_zuendung_ein_psd:
                    100 %
                p_helligkeit_HD_auf_zuendung_aus_psd:
                    100 %
                p_helligkeit_dieseTuer_auf_zuendung_ein_psd:
                    100 %
                p_helligkeit_andereTuer_auf_zuendung_ein_psd:
                    100 %
                p_helligkeit_Fzg_geschlossen_zuendung_ein_psd:
                    126 %
                p_helligkeit_dieseTuer_auf_zuendung_aus_psd:
                    100 %
                p_helligkeit_andereTuer_auf_zuendung_aus_psd:
                    100 %
                p_helligkeit_einausstieg_psd:
                    100 %
                p_helligkeit_Fzg_geschlossen_zuendung_aus_psd:
                    100 %
                p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd:
                    100 %
                p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd:
                    100 %
                p_helligkeit_Tueren_geschlossen_schluessel_ab_psd:
                    100 %
                p_helligkeit_Fzg_geschlossen_schluessel_ab_psd:
                    100 %
                p_dimmfaktor_farbwechsel_auf:
                p_dimmfaktor_farbwechsel_ab:
                p_farbwechsel_delay:
                p_farbauswahl_HMI:
                p_ambienteumfang_mehrfarbig_HMI:
                p_ambienteumfang_mehrfarbig_HMI_2:
                p_ambienteumfang_mehrfarbig_HMI_3:
                p_ambienteumfang_mehrfarbig_HMI_4:
                p_ambientelicht_verbauinformation_HMI:
                p_ambientelicht_verbauinformation_HMI_2:
                p_ambientelicht_verbauinformation_HMI_3:
                p_ambientelicht_verbauinformation_HMI_4:
                p_verzoegerung_berechnen:
                p_t_HMI_verzoegerung_helligkeitswerte:
                    200 ms
            Ambientelicht Farbliste:
                Rotwert Farbe 1:
                Gruenwert Farbe 1:
                Blauwert Farbe 1:
                Rotwert Farbe 2:
                Gruenwert Farbe 2:
                Blauwert Farbe 2:
                Rotwert Farbe 3:
                Gruenwert Farbe 3:
                Blauwert Farbe 3:
                Rotwert Farbe 4:
                Gruenwert Farbe 4:
                Blauwert Farbe 4:
                Rotwert Farbe 5:
                Gruenwert Farbe 5:
                Blauwert Farbe 5:
                Rotwert Farbe 6:
                Gruenwert Farbe 6:
                Blauwert Farbe 6:
                Rotwert Farbe 7:
                Gruenwert Farbe 7:
                Blauwert Farbe 7:
                Rotwert Farbe 8:
                Gruenwert Farbe 8:
                Blauwert Farbe 8:
                Rotwert Farbe 9:
                Gruenwert Farbe 9:
                Blauwert Farbe 9:
                Rotwert Farbe 10:
                Gruenwert Farbe 10:
                Blauwert Farbe 10:
            ambient_lighting_lin_slaves_modules:
                pa_einzeladresse_slave_1:
                pa_verbauinfo_slave_1:
                    Sin montar
                pa_fehlerort_slave_1:
                pa_einzeladresse_slave_2:
                pa_verbauinfo_slave_2:
                    Sin montar
                pa_fehlerort_slave_2:
                pa_einzeladresse_slave_3:
                pa_verbauinfo_slave_3:
                    Sin montar
                pa_fehlerort_slave_3:
                pa_einzeladresse_slave_4:
                pa_verbauinfo_slave_4:
                    Sin montar
                pa_fehlerort_slave_4:
                pa_einzeladresse_slave_5:
                pa_verbauinfo_slave_5:
                    Sin montar
                pa_fehlerort_slave_5:
                pa_einzeladresse_slave_6:
                pa_verbauinfo_slave_6:
                    Sin montar
                pa_fehlerort_slave_6:
                pa_einzeladresse_slave_7:
                pa_verbauinfo_slave_7:
                    Sin montar
                pa_fehlerort_slave_7:
                pa_einzeladresse_slave_8:
                pa_verbauinfo_slave8:
                    Sin montar
                pa_fehlerort_slave8:
                pa_einzeladresse_slave_9:
                pa_verbauinfo_slave_9:
                    Sin montar
                pa_fehlerort_slave_9:
                pa_einzeladresse_slave_10:
                pa_verbauinfo_slave_10:
                    Sin montar
                pa_fehlerort_slave_10:
                pa_einzeladresse_slave_11:
                pa_verbauinfo_slave_11:
                    Sin montar
                pa_fehlerort_slave_11:
                pa_einzeladresse_slave_:12:
                pa_verbauinfo_slave_12:
                    Sin montar
                pa_fehlerort_slave_12:
                pa_einzeladresse_slave_13:
                pa_verbauinfo_slave_13:
                    Sin montar
                pa_fehlerort_slave_13:
                pa_einzeladresse_slave_14:
                pa_verbauinfo_slave_14:
                    Sin montar
                pa_fehlerort_slave_14:
                pa_einzeladresse_slave_15:
                pa_verbauinfo_slave_15:
                    Sin montar
                pa_fehlerort_slave_15:
                pa_einzeladresse_slave_16:
                pa_verbauinfo_slave_16:
                    Sin montar
                pa_fehlerort_slave_16:
                pa_einzeladresse_slave_17:
                pa_verbauinfo_slave_17:
                    Sin montar
                pa_fehlerort_slave_17:
                pa_einzeladresse_slave_18:
                pa_verbauinfo_slave_18:
                    Sin montar
                pa_fehlerort_slave_18:
                pa_einzeladresse_slave_19:
                pa_verbauinfo_slave_19:
                    Sin montar
                pa_fehlerort_slave_19:
                pa_einzeladresse_slave_20:
                pa_verbauinfo_slave_20:
                    Sin montar
                pa_fehlerort_slave_20:
            ambient_lighting_lin_slaves_groups:
                pa_verbauinfo_gruppe_1:
                    Sin montar
                pa_lichtfunktion_gruppe_1:
                    Puerta
                pa_korrekturfaktor_gruppe_1:
                    1.00
                pa_verbauinfo_gruppe_2:
                    Sin montar
                pa_lichtfunktion_gruppe_2:
                    Puerta
                pa_korrekturfaktor_gruppe_2:
                    1.00
                pa_verbauinfo_gruppe_3:
                    Sin montar
                pa_lichtfunktion_gruppe_3:
                    Puerta
                pa_korrekturfaktor_gruppe_3:
                    1.00
                pa_verbauinfo_gruppe_4:
                    Sin montar
                pa_lichtfunktion_gruppe_4:
                    Puerta
                pa_korrekturfaktor_gruppe_4:
                    1.00
                pa_verbauinfo_gruppe_5:
                    Sin montar
                pa_lichtfunktion_gruppe_5:
                    Puerta
                pa_korrekturfaktor_gruppe_5:
                    1.00
                pa_verbauinfo_gruppe_6:
                    Sin montar
                pa_lichtfunktion_gruppe_6:
                    Puerta
                pa_korrekturfaktor_gruppe_6:
                    1.00
                pa_verbauinfo_gruppe_7:
                    Sin montar
                pa_lichtfunktion_gruppe_7:
                    Puerta
                pa_korrekturfaktor_gruppe_7:
                    1.00
                pa_verbauinfo_gruppe_8:
                    Sin montar
                pa_lichtfunktion_gruppe_8:
                    Puerta
                pa_korrekturfaktor_gruppe_8:
                    1.00
                pa_verbauinfo_gruppe_9:
                    Sin montar
                pa_lichtfunktion_gruppe_9:
                    Puerta
                pa_korrekturfaktor_gruppe_9:
                    1.00
                pa_verbauinfo_gruppe_10:
                    Sin montar
                pa_lichtfunktion_gruppe_10:
                    Puerta
                pa_korrekturfaktor_gruppe_10:
                    1.00
                pa_verbauinfo_gruppe_11:
                    Sin montar
                pa_lichtfunktion_gruppe_11:
                    Puerta
                pa_korrekturfaktor_gruppe_11:
                    1.00
                pa_verbauinfo_gruppe_12:
                    Sin montar
                pa_lichtfunktion_gruppe_12:
                    Puerta
                pa_korrekturfaktor_gruppe_12:
                    1.00
                pa_verbauinfo_gruppe_13:
                    Sin montar
                pa_lichtfunktion_gruppe_13:
                    Puerta
                pa_korrekturfaktor_gruppe_13:
                    1.00
                pa_verbauinfo_gruppe_14:
                    Sin montar
                pa_lichtfunktion_gruppe_14:
                    Puerta
                pa_korrekturfaktor_gruppe_14:
                    1.00
                pa_verbauinfo_gruppe_15:
                    Sin montar
                pa_lichtfunktion_gruppe_15:
                    Puerta
                pa_korrekturfaktor_gruppe_15:
                    1.00
            Suchbeleuchtung_Tasterdimmung:
                tasterdimmung x0:
                    0 ms
                tasterdimmung x1:
                    2000 ms
                tasterdimmung x2:
                    3000 ms
                tasterdimmung x3:
                    4000 ms
                tasterdimmung x4:
                    5100 ms
                tasterdimmung y0:
                    1.0 %
                tasterdimmung y1:
                    5.0
                tasterdimmung y2:
                    15.0
                tasterdimmung y3:
                    40.0
                tasterdimmung y4:
                    100.0
            Suchbeleuchtung_Hochdimmen:
                x0:
                    0 ms
                x1:
                    200 ms
                x2:
                    400 ms
                x3:
                    600 ms
                x4:
                    800 ms
                x5:
                    1000 ms
                x6:
                    1200 ms
                x7:
                    1400 ms
                x8:
                    1600 ms
                x9:
                    1800 ms
                x10:
                    2000 ms
                y0:
                    0.0 %
                y1:
                    1.0 %
                y2:
                    3.0 %
                y3:
                    5.0 %
                y4:
                    11.0 %
                y5:
                    22.0 %
                y6:
                    40.0 %
                y7:
                    80.0 %
                y8:
                    95.0 %
                y9:
                    100.0 %
                y10:
                    100.0 %
            Suchbeleuchtung_Abdimmen:
                x0:
                    0 ms
                x1:
                    200 ms
                x2:
                    400 ms
                x3:
                    600 ms
                x4:
                    800 ms
                x5:
                    1000 ms
                x6:
                    1200 ms
                x7:
                    1400 ms
                x8:
                    1600 ms
                x9:
                    1800 ms
                x10:
                    2000 ms
                y0:
                    100.0 %
                y1:
                    100.0 %
                y2:
                    95.0 %
                y3:
                    80.0 %
                y4:
                    40.0 %
                y5:
                    20.0 %
                y6:
                    10.0 %
                y7:
                    5.0 %
                y8:
                    3.0 %
                y9:
                    1.0 %
                y10:
                    0.0 %
            Suchbeleuchtung_Fotosensor:
                x0:
                x1:
                    50
                x2:
                    100
                x3:
                    200
                x4:
                    253
                x5:
                x6:
                x7:
                x8:
                x9:
                x10:
                y0:
                    0 lx
                y1:
                    50 lx
                y2:
                    100 lx
                y3:
                    200
                y4:
                    500
                y5:
                y6:
                    0 lx
                y7:
                    0 lx
                y8:
                    0 lx
                y9:
                    0 lx
                y10:
                    0 lx
            Suchbeleuchtung_KL 58xs min:
                x0:
                    0 lx
                x1:
                    8 lx
                x2:
                    50 lx
                x3:
                    510 lx
                y0:
                    6.0
                y1:
                    6.0
                y2:
                    100.0
                y3:
                    100.0
            Suchbeleuchtung_KL 58xs max:
                x0:
                    0 lx
                x1:
                    8 lx
                x2:
                    50 lx
                x3:
                    500 lx
                y0:
                    100.0
                y1:
                    100.0
                y2:
                    100.0
                y3:
                    100.0
            Suchbeleuchtung_KL_58xt min:
                x0:
                    0 lx
                x1:
                    8 lx
                x2:
                    50 lx
                x3:
                    500 lx
                y0:
                    6.0
                y1:
                    6.0
                y2:
                    100.0
                y3:
                    100.0
            Suchbeleuchtung_KL_58xt_max:
                x0:
                    0 lx
                x1:
                    8 lx
                x2:
                    50 lx
                x3:
                    500 lx
                y0:
                    100.0
                y1:
                    100.0
                y2:
                    100.0
                y3:
                    100.0
            Suchbeleuchtung_KL_58xd_min:
                x0:
                    0 lx
                x1:
                    50 lx
                x2:
                    220 lx
                x3:
                    300 lx
                x4:
                    500 lx
                y0:
                    6.0
                y1:
                    16.0
                y2:
                    25.0
                y3:
                    30.0
                y4:
                    50.0
            Suchbeleuchtung_KL_58xd_max:
                x0:
                    0 lx
                x1:
                    8 lx
                x2:
                    200 lx
                x3:
                    300 lx
                x4:
                    500 lx
                y0:
                    16.0
                y1:
                    16.0
                y2:
                    100.0
                y3:
                    100.0
                y4:
                    100.0
            Suchbeleuchtung_KL_58xd_log_Bus:
                x0:
                    0.0 %
                x1:
                    6.0 %
                x2:
                    16.0 %
                x3:
                    30.0 %
                x4:
                    60.0 %
                x5:
                    100.0 %
                y0:
                    10
                y1:
                    10
                y2:
                    100
                y3:
                    150
                y4:
                    220
                y5:
                    253
            Dimmunt_KL_58xs_PWM:
                x0:
                    0.0 %
                x1:
                    50.0 %
                x2:
                    100.0 %
                y0:
                    0.0 %
                y1:
                    50.0 %
                y2:
                    100.0 %
            Suchbeleuchtung_KL_58xt_PWM:
                x0:
                    0.0 %
                x1:
                    50.0 %
                x2:
                    100.0 %
                y0:
                    0.0 %
                y1:
                    50.0 %
                y2:
                    100.0 %
            Suchbeleuchtung_KL_58xd_PWM:
                x0:
                x1:
                    10
                x2:
                    50
                x3:
                    100
                x4:
                    220
                x5:
                    253
                y0:
                    2.0 %
                y1:
                    2.0 %
                y2:
                    6.0 %
                y3:
                    10.0 %
                y4:
                    80.0 %
                y5:
                    100.0 %
            Suchbeleuchtung_58_xs_Bus_Kennlinie:
                x0:
                    0.0 lx
                x1:
                    8.0 lx
                x2:
                    50.0 lx
                x3:
                    80.0 lx
                x4:
                    100.0 lx
                y0:
                    6.0
                y1:
                    6.0
                y2:
                    20.0
                y3:
                    50.0
                y4:
                    100.0
            Suchbeleuchtung_58xt_Bus_Kennlinie:
                x0:
                    0.0 lx
                x1:
                    8.0 lx
                x2:
                    50.0 lx
                x3:
                    80.0 lx
                x4:
                    100.0 lx
                y0:
                    6.0
                y1:
                    6.0
                y2:
                    20.0
                y3:
                    50.0
                y4:
                    100.0
            Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie:
                x0:
                    0 lx
                x1:
                    10 lx
                x2:
                    100 lx
                x3:
                    500 lx
                x4:
                    800 lx
                x5:
                    1020 lx
                y0:
                y1:
                    20
                y2:
                    80
                y3:
                    180
                y4:
                    300
                y5:
                    500
            ZV allgemein:
                Notschliessfunktion:
                    activado
                Funkfrequenz:
                    434,42MHz
                Funk bei Klemme 15 ein:
                    inactivo
                ZV_ohne_Safe_Funktion:
                    Sin montar
                Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster:
                    activado
                Entsafen mit autorisierte Klemme 15 Ein:
                    activado
                Bewusstes Safe mit 2. Betaetigung der FFB:
                    inactivo
                Lock_Unlock_Taster_direkt:
                    Sin montar
                Lock_Unlock_Toggle_Taster:
                    Sin montar
                ZV Tuerentriegelung:
                    Globale Entriegelung
                Menuesteuerung Tuerentriegelung:
                    activado
                LS_Taster_Togglefunktion:
                    inactivo
                Deaktivierung_Laderaumschliessung_extern:
                    inactivo
                Nutzfahrzeug_Schliessung:
                    inactivo
                Wiederverriegelung_Laderaum:
                    Freigabe_Softtouch
                Tankschloss:
                    bidirectional
            ZV Türkonfiguration:
                Viertuerer:
                    sí
                Fond_Schloss:
                    2-Motorenschloesser
                Schlosstyp_NAR:
                    no
                Schiebetueren_Crafter:
                    Sin montar
                Schiebetuerschloss_direkt_BCM:
                    lado cond.
                Schiebetuer_Kontaktmodul_Fahrerseite:
                    Sin montar
                Schiebetuer_Kontaktmodul_Beifahrerseite:
                    Sin montar
                Schiebetuer_links:
                    no
                Schiebetuer_rechts:
                    no
                Schliessung der Schiebetuer bei geoeffneter Tankklappe:
                    inactivo
                HFT_Invertierung_Drehfallensignal:
                    nicht invertiert
            ZV Heck:
                Tausch_Tank_Hecktreiberausgang:
                    no
                ZV_Heck_Schlosstyp:
                    1- oder 2-Rasten-Hecksteller
                Heckschloss_mit_Vorraste:
                    sí
                Heckschloss_Steuerung:
                    Kontaktsteuerung
                Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang:
                    inactivo
                Heckdeckelentriegelung_HDF_Innentaster:
                    Sin montar
                ZV entriegelt auch Heckdeckel:
                    activado
                Direkter Auswurf des Heckdeckels:
                    activado
                Heckfreigabe_Ohne_Verzoegerung:
                    inactivo
                ZV Heck nur direkt auswerfen:
                    inactivo
                Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster:
                    inactivo
                Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt:
                    inactivo
                Mindestbetaetigung_HDF_Innentaster:
                    0.0 s
                Heckoeffnung_ueber_2_Bedienhandlungen:
                    inactivo
            Señales de respuesta:
                Aviso óptico al bloquear:
                    Decelerar
                Optische Rueckmeldung Komfortschliessen:
                    activado
                Optische Rueckmeldung 3.Bremsleuchte:
                    inactivo
                Akustische Rueckmeldung global:
                    inactivo
                Akustische Rueckmeldung entriegeln:
                    inactivo
                Quittierton bei zweitem ZV-AUF-Befehl:
                    inactivo
                Akustische Rueckmeldung verriegeln:
                    inactivo
                Quittierton bei zweitem ZV-ZU-Befehl:
                    inactivo
                Menuesteuerung akustische Rueckmeldung:
                    inactivo
                Dauer der Akustischen Rueckmeldung vom Einfachhorn:
                    kurz
                Akustische Rueckmeldung Signalhorn:
                    inactivo
                ZV-Blinken_Hellzeit:
                    200 ms
                ZV-Blinken_Dunkelzeit:
                    200 ms
                ZV-Blinken_Abschluss_Dunkelzeit:
                    200 ms
            ZV Komfort:
                Freigabenachlauf FH bei Kl 15 aus:
                    activado
                Freigabenachlauf FH bei Tueroeffnen abbrechen:
                    activado
                Komfortbedienung global:
                    activado
                Apertura confort:
                    inactivo
                Komfortoeffnen nur FH Fahrertuer:
                    inactivo
                Schliesszylinder Komfort oeffnen:
                    inactivo
                Funk Komfort oeffnen:
                    activado
                Fahrertuerbedienung Fensterheber oeffnen:
                    activado
                FH SAD Kl15Aus Freigabezeit:
                    600 s
                Cierre de confort:
                    activado
                Schliesszylinder Komfort schliessen:
                    inactivo
                Funk Komfort schliessen:
                    activado
                Fahrertuerbedienung Fensterheber schliessen:
                    activado
                Menuesteuerung Komfortbedienung einstellbar:
                    adjustable
                Regenschliessen_ein_aus:
                    inactivo
                Regenschliessen_art:
                    once
                Menuesteuerung Regenschliessen:
                    inactivo
                elektrischer_Fensterheber_hinten:
                    sí
            ZV Autolock:
                Automatisches Verriegeln bei Geschwindigkeit:
                    inactivo
                automatisches Entriegeln:
                    activado
                Autounlock NAR:
                    inactivo
                Autolock Autounlock wirkt auf Heck:
                    activado
                Geschwindigkeitsabhaengige Tankdeckelverriegelung:
                    inactivo
                Menuesteuerung ZV Autolock-Unlock:
                    adjustable
            Schiebedach:
                SAD Richtung Komfortoeffnen:
                    tilting
                SAD Komfort schliessen:
                    inactivo
                SAD Komfort oeffnen:
                    inactivo
                Schiebedachmodul_MD_1:
                    Sin montar
                Schiebedachmodul_MD_3:
                    Sin montar
                Schiebedachmodul_MD_Rollo:
                    Sin montar
                Verortung Schiebedachmodule:
                    LIN
            Spiegelverstellung:
                Spiegelabsenkung bei Rueckwaertsfahrt:
                    activado
                Spiegelverstellung Synchron:
                    activado
                Menuesteuerung Spiegelabsenkung:
                    activado
                Funk Spiegelanklappen:
                    activado
                Funk Spiegelanklappung Modus:
                    by look command via remote control key
                Menuesteuerung synchrone Spiegelverstellung:
                    activado
                Menuesteuerung Funk Spiegel anklappen:
                    activado
                Profilfunktion fuer Anklappung der Aussenspiegel:
                    activado
                Signalisierung_Spiegelanklappung:
                    inactivo
                Spiegelanklappen_bei_Wiederverriegelung:
                    activado
            ZV Crash:
                Heckdeckel-Bedienstellen nachCrash temporaer sperren:
                    activado
                ZV-Entriegelung nach Seitencrash:
                    inactivo
                SAD PreCrash Konturschliessen:
                    inactivo
            Postfunc. luz posición:
                Bedingungen zur Beendigung des Standlichtnachlaufs:
                    inactivo
                ZV verriegeln bei Klemme 15 Ein:
                    activado
                Standlicht-Nachlaufzeit:
                    255 min
            Pulsador en consola central:
                Funktion Taster 1:
                    Arranque/parada
                Funktion Taster 2:
                    Sin codificar / sin montar
                Funktion Taster 3:
                    Programa de conducción
                Funktion Taster 4:
                Zusatzcodierung Fahrprofiltaster hat keine LED:
                    LED installed
            Curva característica ventilador asiento:
                Level_1_Sitz:
                    25 %
                Level_1_Lehne:
                    30 %
                Level_2_Sitz:
                    25 %
                Level_2_Lehne:
                    30 %
                Level_3_Sitz:
                    53 %
                Level_3_Lehne:
                    58 %
                Level_4_Sitz:
                    53 %
                Level_4_Lehne:
                    58 %
                Level_5_Sitz:
                    80 %
                Level_5_Lehne:
                    85 %
                Level_6_Sitz:
                    80 %
                Level_6_Lehne:
                    85 %
                Sitzlueftung:
                    Sin montar
                Sitzlueftung_reduzierbar:
                    Sin montar
                Sitzpneumatik:
                    Sin montar
            Función de clim./calef. por control remoto:
                Remotestart:
                    Sin montar
                Rueckmeldung_bei_Aktivierung:
                    activado
                Kombi_Fahrerhinweis_m_Uebernahme_RSt:
                    activado
                Abbruch_Hupen_RSt:
                    inactivo
                Abbruch_d_Warnblinker_moeglich:
                    activado
                Kombi_Fahrerhinweis_m_Akustik:
                    activado
                Aktivierung_Drehzahlanzeige:
                    activado
            Comportamiento en modo de producción:
                Lavafaros:
                    2000 ms
            Modo para banco de pruebas de rodillos, funcional:
                    inactivo
            Modo de transporte:
                    activado
            Desactivar modo de producción:
                    inactivo
            Schlüssellose Zugang- und Startberechtigung:
                Kessy:
                    Sin montar
                Elektische_Lenkradverriegelung:
                    Sin montar
                Kessy Komfort oeffnen:
                    inactivo
                Kessy Komfort schliessen:
                    activado
                Oeffnung Heckdeckel bei Wiederentriegelung:
                    inactivo
                Kessy Komfortbedienung Reichweitenbegrenzung:
                    inactivo
            Leer dirección de parámetros:
                Parámetro dirección:
            Vernetzungs- Diagnosefunktionen:
                can msg 1:
                can msg 2:
                can msg 3:
                can msg 4:
                lin msg 1:
                lin msg 2:
                lin msg 3:
                lin msg 4:
                lin msg 5:
                lin msg 6:
            Activación y desactivación de todos los mensajes de desarrollo:
                    inactivo
            Gestión de energía:
                Hybridfahrzeug:
                    no
                Recuperation:
                    activado
                Energiemanagement Abschaltung:
                    activado
                Zweitbatterie:
                    Sin montar
                Energy_Management_Adaptation:
                    Gestión de energía activada
                Praediktives_Energiemanagement:
                    inactivo
                Hochvoltfahrzeug:
                    Sin montar
            Verdecksteuergeraet:
                Nachsaven_nach_Verdecklauf:
                    inactivo
                Komfortbedienung Verdeck global:
                    activado
                Komfortbedienung Verdeck oeffnen:
                    activado
                Komfortbedienung Verdeck schliessen:
                    activado
                Verdeck oeffnen via Schliesszylinder:
                    activado
                Verdeck schliessen via Schliesszylinder:
                    activado
                Verdeck oeffnen via Funkfernbedienung:
                    activado
                Verdeck schliessen via Funkfernbedienung:
                    activado
                Verdeck oeffnen via Kessy:
                    activado
                Verdeck schliessen via Kessy:
                    activado
                Doppelpuls nur Verdeck:
                    activado
                Verdeck mit Schiebedach:
                    inactivo
                Heckdeckel sperren bei Verdeckbetrieb:
                    inactivo
                Softtouch-Betaetigung senden:
                    immer
                Servoheck Schlossansteuerung:
                    immer
                Reichweitenbegrenzung fuer Servoheck schliessen:
                    inactivo
                Cabrio_Verdeck:
                    not_installed
                trunk_lid_conrol_unit:
                    Sin montar
                Virtuelles_Pedal_Verbau:
                    Sin montar
                Virtuelles_Pedal:
                    inactivo
                Virtuelles_Pedal_HMI_einstellba:
                    inactivo
                easycloselight_aktiv:
                    inactivo
                Kick_and_close:
                    Sin montar
            Allwetterlicht_Spoiler:
                tt_spoiler:
                    Sin montar
                Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT:
                    inactivo
                Spoiler Einfahrunterdrueckung nach manuellem Ausfahren:
                    inactivo
            Slave_systems_identification:
                UC para el motor del limpiacristales:
                    No disponible
                Sensor de lluvia y de luz:
                    No disponible
                Conmutador de las luces:
                    No disponible
                Unidad de control para apertura de la puerta del garaje:
                    No disponible
                Unidad de mandos para apertura de la puerta del garaje:
                    No disponible
                Sensor del sistema de alarma antirrobo:
                    No disponible
                Bocina alarma:
                    No disponible
                Unidad de control del techo corredizo:
                    No disponible
                Unidad de control de la electrónica del techo:
                    No disponible
                Unidad de control de la cortinilla del techo:
                    No disponible
                Sensor de humedad del aire, interior:
                    No disponible
                Calefacción zona cabeza, izq.:
                    No disponible
                Calefacción zona cabeza, der.:
                    No disponible
                Ventilador 1 para el respaldo del asiento del. izq.:
                    No disponible
                Ventilador 1 para el cojín del asiento del. izq.:
                    No disponible
                Ventilador 1 para el respaldo del asiento del. der.:
                    No disponible
                Ventilador 1 para el cojín del asiento del. der.:
                    No disponible
            Vigilancia del habitáculo, alarma antirrobo:
                Sensibilidad:
                    100 %
            Alarma antirrobo: sensor inclinación veh.:
                Sensibilidad:
                    100 %
            Vigil. hab., alarma antirrobo, set parámetros:
                    010A080043530AC801140A0381330C00000001CDD606000F1E00850F39F764234542579B25443F3A6958952D09A3027A0656000F170089102FF7690FE342871B05343F3A6958930809A30344462A000F1C00880E2FE7691E6542771B05243F3A6947930809A304FFF646000F1E00851E32F7440C4220571B05243F3A6958920509A305342619150C12188609263367234542579B25240CFA0A34952D09A3210300020202020202B110232966
            DWA_Interior_Monitoring_Data_Set_Development:
                    FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
            RLS_wiper_position_parking:
                    15 s
            RLS_close_glazing:
                    2.0 s
            RLS_lights_for_autobahn:
                p_v_autobahn_on:
                    140 km/h
                p_v_autobahn_off:
                    65 km/h
                p_t_autobahn_delay_on:
                    10 s
                p_t_autobahn_delay_off:
                    120 s
            RLS_Washer_Front:
                    15 s
            RLS_LIN_Communication:
                    4 s
            RLS_tunel_gateway_recognize:
                    5 s
            RLS_Lights_on_at_Rain:
                p_n_regenlichtschwelle_high:
                    12
                p_n_regenlichtschwelle_low:
                    6
                p_lx_regenlichtschwelle:
                    6000 lx
                p_t_regenlicht:
                    30 s
            RLS_Night_Sensitivity:
                p_lx_rs_day:
                    500 lx
                p_lx_rs_dawn:
                    200 lx
            Pos. de giro superior:
                    170.494335 °
            Pos. de giro inferior:
                    31.494474 °
            Posición en funcionamiento a intervalos:
                    31.494474 °
            Posición de aparcamiento alterna 1:
                    7.494498 °
            Posición de aparcamiento alterna 2:
                    29.494476 °
            Posición de servicio:
                    170.494335 °
            Wischgeschwindigkeiten:
                Dauerwischen Stufe_1 Zyklen pro Minute:
                    40
                Dauerwischen Stufe_2 Zyklen pro Minute:
                    60
                Reduzierte Wischgeschwindigkeit Zyklen pro Minute:
                    30
            Front_wash_function:
                factor_washing_delay:
                    10
            error_mask:
                    0 bit
            erase_error_table:
                    550000
            Kopfraumheizung:
                blower_speed:
                temperature:
                    -2
            Vernetzung:
                Klimaelektronik:
                    montado
                Anhaengeranschlussgeraet:
                    Sin montar
                Bremsen_Steuergeraet:
                    montado
                Getriebesteuergeraet:
                    Sin montar
                Kunden_spezifisches_Funktions_SG:
                    Sin montar
                Kopfraumheizung:
                    Sin montar
                UGDO:
                    Sin montar
            Querschnitts_funktionen:
                Lenkungsanordnung:
                    Izq.
                Verkehrsseite:
                    Der.
                Marca:
                    VW
                Personalisierungsuebernahme:
                    not_installed
                Bedien_und_Anzeigeprotokoll:
                    activado
                Schnittstelle_TrackingSystem:
                    inactivo
                Codierungsabsicherung:
                    inactivo
                CAN Wecken bei Softtouchbetaetigung:
                    inactivo
                Hardware_Eingang_Drucktankklappenstatus:
                    Pin A31
                Klemmenfehler auf CAN ausgeben:
                    activado
                Fahrgeschwindigkeit_aus_ESP_21:
                    activado
                Hupe:
                    Sollspannungsanforderung 13,5V
            Aktivierung_Entwicklungsdiagnose:
                log_dtc_status:
                    inactivo
                Reaktion_LOG-DTC:
                    First_dtc
                log-dtc_DFCC:
            Aussenlicht_uebergreifend:
                Light_Control_Module:
                    montado
                Kontrollleuchte fuer Begrenzungslicht:
                    integriert in Suchbeleuchtung
                Standlicht aus:
                    activado
                Parklicht ueber LSS aktiviert:
                    Un lado
                Standlichtreduzierung mit beidseitigem Parklicht:
                    activado
                Menueeinstellung CHO LHO:
                    Menuesteuerung Zeit aktivieren
                Faktor fuer Verfuegbarkeitstimer:
                    Faktor fuer x5 Minuten
                Umfeldleuchte als Manoevrierleuchte:
                    inactivo
                Fahrlichtwarnung_Hinweis_Konfig:
                    Hinweis_in_LDS-Stellung_Null_und_SL
                Fahrlicht_Hinweis_mehrfach:
                    activado
                Bedingungen zur Standlichtbegrenzung:
                    abschaltbar über Energiemanagement
                Standlicht-Verfügbarkeit:
                    24 s
                bewusstes Standlicht:
                    Aktive Begrenzung
                Bedingungen zur Parklichtbegrenzung:
                Lichtwarnungsverhalten:
                    klemmenabhaengig
                Coming Home Verbaustatus:
                    manual
                Menuesteuerung Coming Home Werkseinstellung:
                    activado
                Coming home Leuchten:
                    luz de cruce
                Menueeinstellung Cominghome:
                    10 segundos
                Coming-home Einschaltereignis:
                    driver door
                Helligkeitsschwelle Infrarot-Messung:
                    12 lx
                Leaving-Home Verbausstatus:
                    desbloqueado
                Menuesteuerung Leaving-home Freischaltung per BAP:
                    activado
                LDS_mit_Nebellicht:
                    sí
                Lichtdrehschalter (LDS):
                    discrete
                Menueeinstellung Leaving-home Zeit per BAP:
                    10 segundos
                Helligkeitsschwelle Forward-Messung:
                    46400 lx
                LDS_mit_Nebel_Schlusslicht:
                    sí
                LDS_mit_AFL:
                    sí
                LDS_mit_Standlichtstellung:
                    sí
                HVLM_Ladezustandsanzeige:
                    no
                LCM_blinker:
                    WAHR
                Allwetterlicht:
                    Sin montar
                Abblendlicht:
                Fernlicht_LH:
                Nebellicht:
                Blinker:
            Aussenlicht_Blinker:
                Warnblinken_durch_Fahrerassistenz:
                    inactivo
                Komfortblinken Blinkzyklen:
                    3
                Abbruch Komfortblinken:
                    activado
                Komfortblinken:
                    activado
                Blinkkontrolleuchte fuer Anhaenger:
                    separte
                Schluessel_Anlern_Blinken:
                    activado
                UGDO_ Anlern_Blinken:
                    activado
                ZV_Blinken_zu:
                    activado
                ZV_Blinken_auf:
                    activado
                Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken:
                    activado
                DWA_Schaerfungsquittung:
                    activado
                DWA_Alarm_Blinken:
                    activado
                Taxialarmblinken:
                    activado
                Panikblinken:
                    activado
                Multi_kollisions_Blinken:
                    inactivo
                Emergency_alert_blinken:
                    inactivo
                Notwarn_blinken_NBA_Phase_2:
                    inactivo
                dynamisch_blinken_10:
                    activado
                Richtungs_blinken_rechts:
                    activado
                Richtungs_blinken_links:
                    activado
                ABBA_Blinken:
                    inactivo
                Crashblinken:
                    inactivo
                Warnblinken_Zuendung_EIN:
                    activado
                Warnblinken_Zuendung_AUS:
                    activado
                Dynamische_Blink_Delay:
                    50 ms
                Fahrerassistenz_Blinkenfunktionen:
                    Warnblinke_zulaessig
                PreCrash_RECAS:
                    PreCrash_passiv
            Leuchtweitenregulierung:
                sensor_headlight_range_control_installed:
                    Sin montar
                sLWR_verbaut:
                    HIM
                1_Sensor_LWR:
                    1-Sensor_LWR
                Fahrwerk_Variante:
                    Variante_1
                sLWR_bei_Abblendlicht:
                    activado
                Quelle_Hoehenwerte:
                    BCM
                Aktivierung_LWR_Fehlerlampe:
                    inactivo
                Logik_PWM_Signal:
                    Negativo
                sLWR_nach_Motorstart:
                    inactivo
                Entprellung_Fehlerlampe:
                    10.0 s
                Fail_Safe_sLWR:
                    0.0 %
                Zyklus_sLWR:
                    1.00 s
                sLWR_Touristenlicht:
                    -100.0 %
                sLWR_SW_Grad:
                    10.0 %/s
                sLWR_Hysterese:
                    1.0 %
                diagnose_soll_toleranz:
                    15 %
                Ansteuerung_untere_grenze:
                    0.0 %
                Ansteuerung_obere_grenze:
                    100.0 %
                Delay_DC_Motor_Versorgung:
                    -101.5 ms
                Lineare_Abbildung:
                    normal
                fac_Pwm_Zu_Hoehe_V_1:
                    -8.00 mm/%
                fac_Pwm_Zu_Hoehe_H_1:
                    -8.00 mm/%
                fac_Pwm_Zu_Hoehe_V_2:
                    -8.00 mm/%
                fac_Pwm_Zu_Hoehe_H_2:
                    -8.00 mm/%
                fac_Pwm_Zu_Hoehe_V_3:
                    -8.00 mm/%
                fac_Pwm_Zu_Hoehe_H_3:
                    -8.00 mm/%
                Achsabstand_des_Fahrzeuges:
                    0 mm
                lwr_lFzg_Sw_Abstand:
                    0 mm
                lwr_lFzg_Sw_Hoehe:
                    0 mm
                pa_fDynFiltStatLwr:
                    100 Hz
                fFiltEinf:
                    0.00 Hz
                pa_fFiltSwNeigung:
                    0.00 Hz
                lwr_pwm_untere_schwelle:
                    2.5 %
                lwr_pwm_obere_schwelle:
                    95.0 %
                max_v_slwr:
                    255 km/h
                lwr_lEinfOffsHFahrw_1:
                    0 mm
                lwr_lEinfOffsHFahrw_2:
                    0 mm
                lwr_lEinfOffsHFahrw_3:
                    0 mm
                lwr_lEinfOffsHFahrw_4:
                    0 mm
            Activar conmutación conducción por la izquierda/derecha:
                    inactivo
            Luz interior 2.ª generación:
                Aufloesung Dimmzeit:
                    0.10 s
                weicher Farbwechsel:
                    inactivo
                Tuertafelbeleuchtung mehrfarbig:
                    inactivo
                Instrumententafelbeleuchtung mehrfarbig:
                    inactivo
                Cockpitbeleuchtung mehrfarbig:
                    inactivo
                Lautsprecherbeleuchtung mehrfarbig:
                    inactivo
                Mittelkonsolenbeleuchtung mehrfarbig:
                    inactivo
                Dachbeleuchtung mehrfarbig:
                    inactivo
                Panoramaschiebedachbeleuchtung mehrfarbig:
                    inactivo
                Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren:
                    inactivo
                BAP Farbwert Farbe 1:
                BAP Farbwert Farbe 2:
                    3
                BAP Farbwert Farbe 3:
                Defaultwert Ambienteprofil Mittelkonsole:
                    80 %
                Defaultwert Ambienteprofil Dach:
                    80 %
                Defaultwert Ambienteprofil Farbe:
                Defaultwert Ambienteprofil Fussraum:
                    50 %
                Defaultwert Ambienteprofil Tuer:
                    50 %
                Defaultwert Ambienteprofil Vorn:
                    50 %
                Ambiente_Farbliste_HMI_mit_Farbtransformation:
                    inactivo
                Helligkeit_Tuertafelbeleuchtung_nicht_berechnen:
                    inactivo
                Helligkeit Instrumententafelbeleuchtung nicht berechnen:
                    activado
                Helligkeit Cockpitbeleuchtung nicht berechnen:
                    activado
                Helligkeit Lautsprecherbeleuchtung nicht berechnen:
                    activado
                Helligkeit Mittelkonsolenbeleuchtung nicht berechnen:
                    activado
                Helligkeit Dachbeleuchtung nicht berechnen:
                    activado
                Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen:
                    activado
                Farbausgabe Tuertafelbeleuchtung nicht berechnen:
                    activado
                Farbausgabe Instrumententafelbeleuchtung nicht berechnen:
                    activado
                Farbausgabe Cockpitbeleuchtung nicht berechnen:
                    activado
                Farbausgabe Lautsprecherbeleuchtung nicht berechnen:
                    activado
                Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen:
                    activado
                Farbausgabe Dachbeleuchtung nicht berechnen:
                    activado
                Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen:
                    activado
                Innenlicht bei offenem Heckdeckel einschalten:
                    inactivo
                KL30G ohne PWM:
                    inactivo
                Weckfaehigkeit_klemme_30G:
                    montado
                LIN-Dachkonsole mit Flaechenlicht:
                    Sin montar
                Tuerinnengriffbeleuchtung mit I-Tafel:
                    Sin montar
                Tuerinnengriff mit Tuertafel:
                    Sin montar
                Ambiente_Farbwahl_FPA_waehlbare_Kopplung:
                    inactivo
                Ambiente_Fahrprofil_Individual:
                    7
                Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default:
                    activado
                Innenlicht:
                    Keine_Spannungsanforderung
            Luz interior configuración de luces:
                Ambiente_Applikationsleisten_in_Tuertafel:
                    montado
                Ambiente_Lautsprecher:
                    Sin montar
                Ambiente_Applikationsleisten_in_Instrumententafel:
                    Sin montar
                Cockpitbeleuchtung:
                    Sin montar
                Mittelkonsolenbeleuchtung:
                    Sin montar
                Dachbeleuchtung:
                    Sin montar
                Panoramaschiebedachbeleuchtung:
                    Sin montar
                Fussraumbeleuchtung:
                    montado
                Farbwahl ueber HMI:
                    Sin montar
                Farbwahl ueber Fahrprofil:
                    Sin montar
                LIN-Dachkonsole lokal aktivierbar:
                    inactivo
                Ambientemenue mit globalem aus:
                    inactivo
                Ambientemenue mit alle Zonen:
                    inactivo
                Ambient_Farbliste_HMI:
                    inactivo
                Frei_Farbwahl_ueber_HMI:
                    inactivo
                Ambience_light_colorlist_default:
            Ambience_lightning_color_list_2:
                Rotwert Farbe 11:
                Gruenwert Farbe 11:
                Blauwert Farbe 11:
                Rotwert Farbe 12:
                Gruenwert Farbe 12:
                Blauwert Farbe 12:
                Rotwert Farbe 13:
                Gruenwert Farbe 13:
                Blauwert Farbe 13:
                Rotwert Farbe 14:
                Gruenwert Farbe 14:
                Blauwert Farbe 14:
                Rotwert Farbe 15:
                Gruenwert Farbe 15:
                Blauwert Farbe 15:
                Rotwert Farbe 16:
                Gruenwert Farbe 16:
                Blauwert Farbe 16:
                Rotwert Farbe 17:
                Gruenwert Farbe 17:
                Blauwert Farbe 17:
                Rotwert Farbe 18:
                Gruenwert Farbe 18:
                Blauwert Farbe 18:
                Rotwert Farbe 19:
                Gruenwert Farbe 19:
                Blauwert Farbe 19:
                Rotwert Farbe 20:
                Gruenwert Farbe 20:
                Blauwert Farbe 20:
                Rotwert_Farbe_21:
                Gruenwert_Farbe_21:
                Blauwert_Farbe_21:
                Rotwert_Farbe_22:
                Gruenwert_Farbe_22:
                Blauwert_Farbe_22:
                Rotwert_Farbe_23:
                Gruenwert_Farbe_23:
                Blauwert_Farbe_23:
                Rotwert_Farbe_24:
                Gruenwert_Farbe_24:
                Blauwert_Farbe_24:
                Rotwert_Farbe_25:
                Gruenwert_Farbe_25:
                Blauwert_Farbe_25:
                Rotwert_Farbe_26:
                Gruenwert_Farbe_26:
                Blauwert_Farbe_26:
                Rotwert_Farbe_27:
                Gruenwert_Farbe_27:
                Blauwert_Farbe_27:
                Rotwert_Farbe_28:
                Gruenwert_Farbe_28:
                Blauwert_Farbe_28:
                Rotwert_Farbe_29:
                Gruenwert_Farbe_29:
                Blauwert_Farbe_29:
                Rotwert_Farbe_30:
                Gruenwert_Farbe_30:
                Blauwert_Farbe_30:
            Ambience_lightning_color_list_lin:
                Rotwert_Farbe_1_lin:
                Gruenwert_Farbe_1_lin:
                Blauwert_Farbe_1_lin:
                Rotwert_Farbe_2_lin:
                Gruenwert_Farbe_2_lin:
                Blauwert_Farbe_2_lin:
                Rotwert_Farbe_3_lin:
                Gruenwert_Farbe_3_lin:
                Blauwert_Farbe_3_lin:
                Rotwert_Farbe_4_lin:
                Gruenwert_Farbe_4_lin:
                Blauwert_Farbe_4_lin:
                Rotwert_Farbe_5_lin:
                Gruenwert_Farbe_5_lin:
                Blauwert_Farbe_5_lin:
                Rotwert_Farbe_6_lin:
                Gruenwert_Farbe_6_lin:
                Blauwert_Farbe_6_lin:
                Rotwert_Farbe_7_lin:
                Gruenwert_Farbe_7_lin:
                Blauwert_Farbe_7_lin:
                Rotwert_Farbe_8_lin:
                Gruenwert_Farbe_8_lin:
                Blauwert_Farbe_8_lin:
                Rotwert_Farbe_9_lin:
                Gruenwert_Farbe_9_lin:
                Blauwert_Farbe_9_lin:
                Rotwert_Farbe_10_lin:
                Gruenwert_Farbe_10_lin:
                Blauwert_Farbe_10_lin:
            Ambience_lightning_color_list_lin_2:
                Rotwert_Farbe_11_lin:
                Gruenwert_Farbe_11_lin:
                Blauwert_Farbe_11_lin:
                Rotwert_Farbe_12_lin:
                Gruenwert_Farbe_12_lin:
                Blauwert_Farbe_12_lin:
                Rotwert_Farbe_13_lin:
                Gruenwert_Farbe_13_lin:
                Blauwert_Farbe_13_lin:
                Rotwert_Farbe_14_lin:
                Gruenwert_Farbe_14_lin:
                Blauwert_Farbe_14_lin:
                Rotwert_Farbe_15_lin:
                Gruenwert_Farbe_15_lin:
                Blauwert_Farbe_15_lin:
                Rotwert_Farbe_16_lin:
                Gruenwert_Farbe_16_lin:
                Blauwert_Farbe_16_lin:
                Rotwert_Farbe_17_lin:
                Gruenwert_Farbe_17_lin:
                Blauwert_Farbe_17_lin:
                Rotwert_Farbe_18_lin:
                Gruenwert_Farbe_18_lin:
                Blauwert_Farbe_18_lin:
                Rotwert_Farbe_19_lin:
                Gruenwert_Farbe_19_lin:
                Blauwert_Farbe_19_lin:
                Rotwert_Farbe_20_lin:
                Gruenwert_Farbe_20_lin:
                Blauwert_Farbe_20_lin:
                Rotwert_Farbe_21_lin:
                Gruenwert_Farbe_21_lin:
                Blauwert_Farbe_21_lin:
                Rotwert_Farbe_22_lin:
                Gruenwert_Farbe_22_lin:
                Blauwert_Farbe_22_lin:
                Rotwert_Farbe_23_lin:
                Gruenwert_Farbe_23_lin:
                Blauwert_Farbe_23_lin:
                Rotwert_Farbe_24_lin:
                Gruenwert_Farbe_24_lin:
                Blauwert_Farbe_24_lin:
                Rotwert_Farbe_25_lin:
                Gruenwert_Farbe_25_lin:
                Blauwert_Farbe_25_lin:
                Rotwert_Farbe_26_lin:
                Gruenwert_Farbe_26_lin:
                Blauwert_Farbe_26_lin:
                Rotwert_Farbe_27_lin:
                Gruenwert_Farbe_27_lin:
                Blauwert_Farbe_27_lin:
                Rotwert_Farbe_28_lin:
                Gruenwert_Farbe_28_lin:
                Blauwert_Farbe_28_lin:
                Rotwert_Farbe_29_lin:
                Gruenwert_Farbe_29_lin:
                Blauwert_Farbe_29_lin:
                Rotwert_Farbe_30_lin:
                Gruenwert_Farbe_30_lin:
                Blauwert_Farbe_30_lin:
            Ambientelicht Zuordnung der Farbe zum Fahrprofil:
                Fahrprofil_0:
                Fahrprofil_1:
                Fahrprofil_2:
                Fahrprofil_3:
                Fahrprofil_4:
                Fahrprofil_5:
                Fahrprofil_6:
                Fahrprofil_7:
                Fahrprofil_8:
                Fahrprofil_9:
                Fahrprofil_10:
                Fahrprofil_11:
                Fahrprofil_12:
                Fahrprofil_13:
                Fahrprofil_14:
                Fahrprofil_15:
                Ambiente:
            Suchbeleuchtung_allgemein:
                Warnblinktastersuchbeleuchtung Aktivierung:
                    always active
                Eingabemedium_Suchbeleuchtung:
                    HMI
                Umgebungs_helligkeit_auswahl:
                    Fotosensor_Kombi
                Warnblinktastersuchbeleuchtung Grundwert:
                    6.0 %
                Warnblinktastersuchbeleuchtung Faktor:
                    0.100
                KL58 Einschalten mit Rampe:
                    inactivo
                KL58 Verriegelungsausschalten:
                    not_active
                Lichtsensor wirkt auf Suchbeleuchtung:
                    activado
                Suchbeleuchtung Festwert:
                    100 %
                PWM_Daempfung_Aufdimmen_KL58xs_PWM:
                    0.00 s
                Daempfung_Abdimmen_KL_58xs_PWM:
                    0.00 s
                Daempfung_Aufdimmen_KL_58xt_PWM:
                    0.00 s
                Daempfung_Abdimmen_KL_58xt_PWM:
                    0.00 s
                Daempfung_Aufdimmen_KL_58xd_PWM:
                    0.00 s
                Daempfung Abdimmen KL 58xd PWM:
                    0.00 s
                Helligkeit_RLS_Daempfung_Aufdimmen:
                    3.0 s
                Helligkeit_RLS_Daempfung_Abdimmen:
                    20.0 s
                pa_Hysterese_RLS:
            Protección antirrobo:
                Alarmsignal:
                    frequency modulated
                Verzoegerung Panikalarm:
                    2 sekunden verzoegerung
                DWA Alarmverzoegerung:
                    inactivo
                DWA Camper Modus:
                    inactivo
                Ueberwachung Innenentriegelungshebel:
                    inactivo
                Sirenen Alarmzahl:
                    10 Alarme
                Akustischer Alarm Signalhorn:
                    inactivo
                IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet:
                    no
                Diebstahlwarnanlage:
                    activado
                Heckscheibenbruchsensor:
                    Sin montar
                Deaktivierung_DWA_Sensoren_HMI:
                    activ
                DWA_Einfachhorn_oder_Sounder:
                    Sounder_verbaut
                tilt_sensor:
                    sí
                Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv):
                    no
                Sensor_fuer_Innenraumueberwachung:
                    sí
                Calefacción independiente:
                    Sin montar
                OBD Alarm:
                    activ
                Deaktivierung DWA-Sensoren via Doppelklick:
                    not_active
                RHF_Panikalarm:
                    not_active
            Front_wiper:
                Frontwischertyp:
                    LIN
                Frontwischer Referenzlauf:
                    activado
                Variable Regensensoraktivierung:
                    inactivo
                Wischer stop bei KL15 aus:
                    inactivo
                Wischer abparken bei Oeffnen der Motorhaube:
                    inactivo
                Regensensor aktivieren:
                    desactivar
                Menuesteuerung Frontwischer:
                    inactivo
                Frontwischer Notlaufprogramm:
                    activado
                Tippwischen mit erhoehter Wischfrequenz:
                    activado
                Geschwindigkeitsabhaengige Wischstufenrueckschaltung:
                    activado
                Traenenwischen Front Status:
                    inactivo
                Washer_Tipwiping_Variant:
                    inactivo
                Adaptives Nachwischen bei SRA:
                    inactivo
                Wischer Stopp bei Oeffnen der Motorhaube:
                    activado
                Frontwischer_Abtauposition:
                    inactivo
                Anfahrzeit_servicestellung:
                    800 ms
                Mindestwaschzeit_Frontwischer:
                    0 ms
                Timer_DWP_SRA_delay:
                    300 ms
                Frontwischer Spannungsanforderung_konfig:
            Limpialuneta:
                Heckwischer:
                    logikgesteuert
                Komfortwischen Heck:
                    activado
                Menuesteuerung Komfortwischen HW:
                    activado
                Automatisches Heckwischen:
                    inactivo
                Traenenwischen Heck:
                    activado
                Heckwischer Weiterlauf:
                    inactivo
                Komofortwischen Heck Intervallpausenzeit Stufe Intervall:
                    7 s
                Komofortwischen Heck Intervallpausenzeit Stufe Automatik:
                    7 s
                Komofortwischen Heck Intervallpausenzeit Stufe 1:
                    5 s
                Komofortwischen Heck Intervallpausenzeit Stufe 2:
                    3 s
                Einzelansteuerung Heckintervallwischen Zeitintervall 1:
                    8 s
                Einzelansteuerung Heckintervallwischen Zeitintervall 2:
                    16 s
                Einzelansteuerung Heckintervallwischen:
                    inactivo
                Zeit_wasch_min_heck:
                    0 ms
                Spannungsanforderung_konfig_Wischer:
            Scheinwerferreinigung:
                Scheinwerferreinigungsanlage:
                    Sin montar
                SRA bei Waschwassermangel:
                    activado
                Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung:
                    10
                SRA Verzoegerungszeit:
                    0 ms
                SRA Waschzeit:
                    400 ms
                SRA Einweichpausenzeit:
                    2000 ms
                SRA Nachwaschzeit:
                    400 ms
                SRA Pausenzeit:
                    0 ms
                Waschen:
            Asignac. consumo corriente p. niveles calef. asiento:
                Sitzheizung Filterkonstante fuer Waermefluss:
                    0 s
                Sitzheizung Regeltemperaturkorrektur bei Waermefluss:
                    0.00 °C
                Sitzheizung Stufe 1 untere Schaltschwelle:
                    0.00 °C
                Sitzheizung Stufe 1 obere Schaltschwelle:
                    0.00 °C
                Sitzheizung Stufe 2 untere Schaltschwelle:
                    0.00 °C
                Sitzheizung Stufe 2 obere Schaltschwelle:
                    0.00 °C
                Sitzheizung Stufe 3 untere Schaltschwelle:
                    0.00 °C
                Sitzheizung Stufe 3 obere Schaltschwelle:
                    0.00 °C
                Sitzheizung Stufe 4 untere Schaltschwelle:
                    0.00 °C
                Sitzheizung Stufe 4 obere Schaltschwelle:
                    0.00 °C
                Sitzheizung Stufe 5 untere Schaltschwelle:
                    0.00 °C
                Sitzheizung Stufe 5 obere Schaltschwelle:
                    0.00 °C
                Sitzheizung Stufe 6 untere Schaltschwelle:
                    0.00 °C
                Sitzheizung Stufe 6 obere Schaltschwelle:
                    0.00 °C
                Spannungsoffset SIH_75:
                    15.0 V
                Sitzheitzung_CAN:
                    not_installed
                Sitzheizungsfreigabe:
                    Sin montar
                Sitzheizung.Regelbetrieb LO:
                Sitzheizung.Aufheizphase HI:
            Calefacción de los cristales:
                Heizbare_Frontscheibe:
                    Sin montar
                Heizbare Heckscheibe:
                    montado
                Waschduesenheizung:
                    Sin montar
                Frontscheibenheizung_LED_direkt:
                    Sin montar
                Frontscheibenheizungsansteuerung direkt von externem Algorithmus:
                    Sin montar
                Temperaturabhaengige Einschaltzeit HSH:
                    activado
                Temperaturabhaengige Einschaltzeit FSH:
                    activado
                FSH Automatik:
                    activado
                Heckscheibenheizung Zeitwert:
                    320 s
                Parabrisas térmico, tiempo de ejecución:
                    600 s
                Abschalttemperatur fuer Heckscheibenheizung:
                    35.0 °C
                Abschalttemperatur fuer Frontscheibenheizung:
                    35.0 °C
                Frontscheibenheizung _maximale_Dauer:
                    0 s
                window heating front activation time pause:
                    240 s
            Modo de producción:
                    inactivo
                Heckwischer:
                    inactivo
                Innenbeleuchtung:
                    inactivo
                Aussenbeleuchtung:
                    inactivo
                Zugangskontrolle:
                    inactivo
                Virtuel_pedal:
                    inactivo
            LIN-Mirrormode:
                mirror_mode_typ:
                    inactivo
                Bus de datos LIN 1:
                    inactivo
                Bus de datos LIN 2:
                    inactivo
                Bus de datos LIN 3:
                    inactivo
                Bus de datos LIN 4:
                    inactivo
                Bus de datos LIN 5:
                    inactivo
                Bus de datos LIN 6:
                    inactivo
            Personalisierung:
                Personalisierung_Profilfunkion:
                    profiles_active
                Profil_Variante:
                    Konto (v. 1.x)
                Personalisierung_aktiv:
                    activado
                Aktivierungsoption_im_HMI-Menue_sichtbar:
                    activado
                Benutzerkontenverwaltung_in_HMI-Menue_sichtbar:
                    activado
                Personalisierungsfunktionen_in_HMI-Menue_sichtbar:
                    activado
                Anzahl_Benutzerkonten:
                    4
                Automatische_ Schluesselzuordnung:
                    inactivo
                PSO_FSG_Setup2_Bit_1:
                    activado
                PSO_FSG_Setup2_Bit_2:
                    activado
                PSO_FSG_Setup2_Bit_3:
                    inactivo
                PSO_FSG_Setup2_Bit_4:
                    inactivo
            OCU:
                OCU:
                    Sin montar
                DWA_push:
                    inactivo
                Remote_Unlock_Lock:
                    not_active
                Honk DWA_Ausgabe_Fanfare:
                    inactivo
                Remote Lock Unlock Timer s3:
                    2000 ms
                Remote Lock Unlock Timer s1:
                    80 s
                Remote HuF Abbruch:
                    20 km/h
                Remote HuF Hupfrequenz:
                    3 Hz
            Lenkstockschalter:
                Verbauort_Lenkstockschalter:
                    CAN
                Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel:
                    10 km/h
                Zeit_erkennung_fahrt_für_P_plausibel:
                    10.0 min
                Anzahl_fehler_P-verriegelt:
                    250
                Zeit_t_P-verriegelt_entprellen:
                    40 ms
        Kilometraje: 11157 km
        Fecha: 2019-08-13 17:44
    New User
    Jul 2019
    Spain
    Modulo 4B
    Quote Originally Posted by siLc View Post
    Also admap of the BCM because that holds the real important info in this case.
    Fecha: 2019-08-13 17:45
        Numero de bastidor: WVWZZZAUZJP008993
        Coche: Volkswagen Golf
        Año: 2018
        Tipo de carrocería: 5-dr hatchback
        Motor: DADA 110 kW (150 HP) 1.5 l
        Kilometraje: 11157 KM
    Copia de seguridad
        Unidad de Control: 4B Módulo multifunción
        Descripción del sistema: FCM MQB Low
        Número de software: 3Q0907338
        Versión de software: 0286
        Número de hardware: 3Q0907338
        Versión de Hardware: 002
        Número de serie: 15101710800434
        Nombre ODX: EV_MultiModulContiVW48X
        Versión ODX: 001010
        Nombre de copia de seguridad: modulo 4b 130819
        Codificación extendida:
            000000050100164A00200300020000000000000000000000000000000000
            Ventil. 1 p. banqueta del asiento tras. der.:
                Sin montar
            lcm_afs_leimo_mounted:
                Control automático de la luz de cruce
            Luz de curva dinámica:
                activado
            Function_activation_AFS:
                Ativado
            Function_activation_seat_backrest_and_cushion_fan_1:
                no activado
            Tipo de vehículo:
                16
            Sensor de lluvia y luz:
                montado
            Conmutación conducción por la izquierda/derecha:
                Circulación por la derecha
            chassis_unit:
                Mehrlenkerhinterachse Frontantrieb
            disable_afs:
                AFS III Abschaltung MFA+
            Arranque/parada:
                auxiliado
            steering_curve:
                normal
            lwr_sensors:
                1_sensor
            Source_height_value:
                BCM
            market:
                ece
            headlamp_coding_word:
            offroad_light:
                no activado
                ECE R119
        Adaptaciones:
                    inactivo
            Modo de presentación:
                    inactivo
                    inactivo
            Ejecución de presentación luz de curva dinámica:
                    activado
            Funciones adaptativas de luces:
                    activado
            Faros Matrix, atenuación total:
                    100 %
            Faros Matrix, función en parada:
                    inactivo
            Muestra de bit excitación individual de segmentos, faro izq.:
                LED 1:
                    off
                LED 2:
                    off
                LED 3:
                    off
                LED 4:
                    off
                LED 5:
                    off
                LED 6:
                    off
                LED 7:
                    off
                LED 8:
                    off
                LED 9:
                    off
                LED 10:
                    off
                LED 11:
                    off
                LED 12:
                    off
                LED 13:
                    off
                LED 14:
                    off
                LED 15:
                    off
                LED 16:
                    off
                LED 17:
                    off
                LED 18:
                    off
                LED 19:
                    off
                LED 20:
                    off
                LED 21:
                    off
                LED 22:
                    off
                LED 23:
                    off
                LED 24:
                    off
                LED 25:
                    off
                LED 26:
                    off
                LED 27:
                    off
                LED 28:
                    off
                LED 29:
                    off
                LED 30:
                    off
                LED 31:
                    off
                LED 32:
                    off
                LED 33:
                    off
                LED 34:
                    off
                LED 35:
                    off
                LED 36:
                    off
                LED 37:
                    off
                LED 38:
                    off
                LED 39:
                    off
                LED 40:
                    off
                LED 41:
                    off
                LED 42:
                    off
                LED 43:
                    off
                LED 44:
                    off
                LED 45:
                    off
            Muestra de bit excitación individual de segmentos, faro der.:
                LED 1:
                    off
                LED 2:
                    off
                LED 3:
                    off
                LED 4:
                    off
                LED 5:
                    off
                LED 6:
                    off
                LED 7:
                    off
                LED 8:
                    off
                LED 9:
                    off
                LED 10:
                    off
                LED 11:
                    off
                LED 12:
                    off
                LED 13:
                    off
                LED 14:
                    off
                LED 15:
                    off
                LED 16:
                    off
                LED 17:
                    off
                LED 18:
                    off
                LED 19:
                    off
                LED 20:
                    off
                LED 21:
                    off
                LED 22:
                    off
                LED 23:
                    off
                LED 24:
                    off
                LED 25:
                    off
                LED 26:
                    off
                LED 27:
                    off
                LED 28:
                    off
                LED 29:
                    off
                LED 30:
                    off
                LED 31:
                    off
                LED 32:
                    off
                LED 33:
                    off
                LED 34:
                    off
                LED 35:
                    off
                LED 36:
                    off
                LED 37:
                    off
                LED 38:
                    off
                LED 39:
                    off
                LED 40:
                    off
                LED 41:
                    off
                LED 42:
                    off
                LED 43:
                    off
                LED 44:
                    off
                LED 45:
                    off
            Modo de producción:
                Desactivar conmutación conducción por la izquierda/derecha:
                    inactivo
                    desactivar
            Reference_Run_Start_Condition:
                    Arranque del motor
            Seat_fan_rear_characteristics:
                Level_1_seat_cushion:
                    0 %
                Level_1_seat_backrest:
                    0 %
                Level_2_seat_cushion:
                    0 %
                Level_2_seat_backrest:
                    0 %
                Level_3_seat_cushion:
                    0 %
                Level_3_seat_backrest:
                    0 %
                Level_4_seat_cushion:
                    0 %
                Level_4_seat_backrest:
                    0 %
                Level_5_seat_cushion:
                    0 %
                Level_5_seat_backrest:
                    0 %
                Level_6_seat_cushion:
                    0 %
                Level_6_seat_backrest:
                    0 %
            Reference_Run_Activation_Effect:
                par_Reference_Run_Activation_Effect:
                    Activation effect disabled
            Order_Reference_Run_Activation_Effect:
                par_Order_Reference_Run_Activation_Effect:
                    No dependency
            Lista de montaje montaje teórico:
                Módulo multifunción:
                    sí
                Multifunction_Module_Secondary:
                    sí
                Mando de la luz izquierda:
                    sí
                Mando de la luz derecha:
                    sí
                Mando de la luz izquierda 2:
                    sí
                Mando de la luz derecha 2:
                    sí
    New User
    Jul 2019
    Spain
    Modulo19
        Año: 2018
    Copia de seguridad
        Versión ODX: 001010
                Sin montar
                activado
                Ativado
                no activado
            Tipo de vehículo:
                16
                montado
            chassis_unit:
            disable_afs:
            Arranque/parada:
                auxiliado
            steering_curve:
                normal
            lwr_sensors:
                1_sensor
                BCM
            market:
                ece
            offroad_light:
                no activado
                ECE R119
        Adaptaciones:
                    inactivo
                    inactivo
                    inactivo
                    activado
                    activado
                    100 %
                    inactivo
                LED 1:
                    off
                LED 2:
                    off
                LED 3:
                    off
                LED 4:
                    off
                LED 5:
                    off
                LED 6:
                    off
                LED 7:
                    off
                LED 8:
                    off
                LED 9:
                    off
                LED 10:
                    off
                LED 11:
                    off
                LED 12:
                    off
                LED 13:
                    off
                LED 14:
                    off
                LED 15:
                    off
                LED 16:
                    off
                LED 17:
                    off
                LED 18:
                    off
                LED 19:
                    off
                LED 20:
                    off
                LED 21:
                    off
                LED 22:
                    off
                LED 23:
                    off
                LED 24:
                    off
                LED 25:
                    off
                LED 26:
                    off
                LED 27:
                    off
                LED 28:
                    off
                LED 29:
                    off
                LED 30:
                    off
                LED 31:
                    off
                LED 32:
                    off
                LED 33:
                    off
                LED 34:
                    off
                LED 35:
                    off
                LED 36:
                    off
                LED 37:
                    off
                LED 38:
                    off
                LED 39:
                    off
                LED 40:
                    off
                LED 41:
                    off
                LED 42:
                    off
                LED 43:
                    off
                LED 44:
                    off
                LED 45:
                    off
                LED 1:
                    off
                LED 2:
                    off
                LED 3:
                    off
                LED 4:
                    off
                LED 5:
                    off
                LED 6:
                    off
                LED 7:
                    off
                LED 8:
                    off
                LED 9:
                    off
                LED 10:
                    off
                LED 11:
                    off
                LED 12:
                    off
                LED 13:
                    off
                LED 14:
                    off
                LED 15:
                    off
                LED 16:
                    off
                LED 17:
                    off
                LED 18:
                    off
                LED 19:
                    off
                LED 20:
                    off
                LED 21:
                    off
                LED 22:
                    off
                LED 23:
                    off
                LED 24:
                    off
                LED 25:
                    off
                LED 26:
                    off
                LED 27:
                    off
                LED 28:
                    off
                LED 29:
                    off
                LED 30:
                    off
                LED 31:
                    off
                LED 32:
                    off
                LED 33:
                    off
                LED 34:
                    off
                LED 35:
                    off
                LED 36:
                    off
                LED 37:
                    off
                LED 38:
                    off
                LED 39:
                    off
                LED 40:
                    off
                LED 41:
                    off
                LED 42:
                    off
                LED 43:
                    off
                LED 44:
                    off
                LED 45:
                    off
            Modo de producción:
                    inactivo
                    desactivar
                    Arranque del motor
                    0 %
                    0 %
                    0 %
                    0 %
                    0 %
                    0 %
                    0 %
                    0 %
                    0 %
                    0 %
                    0 %
                    0 %
                    No dependency
                    sí
                    sí
                    sí
                    sí
                    sí
                    sí
  9. #8
    New User
    Jul 2019
    Spain
    Modulo17
    Fecha: 2019-08-13 18:20
        Año: 2018
    Copia de seguridad
        Unidad de Control: 17 Cuadro de instrumentos
        Descripción del sistema: KOMBI
        Número de software: 5G1920790A
        Versión de software: 3193
        Número de hardware: 5G1920790A
        Versión de Hardware: 407
        Nombre ODX: EV_DashBoardVDDMQBAB
        Versión ODX: 009058
        Nombre de copia de seguridad: modulo17 130819
            07A401002F80000801882B211401000080000000
            Advertencia de velocidad:
                off
            Lado del volante del vehículo:
                Veh. con volante a la izq.
            Iluminación diurna (escalas):
                sí
            Two_keys:
                no
            SDS_BAP:
                sí
            Derivado de vehículo:
                Variante 0
            Curva característica del depósito:
                Variante 2
            Diám. rueda:
                Variante 1
            Formato hora:
                24h
            Volumen:
                litros
            Presión:
                bares
            Velocidad:
                Kilómetros por hora
            Dist. rec.:
                kilómetros
            Temperatura:
                grados Celsios
            Consumo gasolina / diésel / LPG (autogas/gas líquido):
                Litros a los 100 km
            fecha:
                dd_mm_jj
            Idioma:
                Inglés
            Pantalla inicial:
                Variante 1
            Aviso para el uso del cinturón de seguridad:
                Variante 1
            Indicador desgaste pastillas freno con testigo p. sist. frenos:
                no
            Caja de cambios:
                Cambio manual
            Consumo CNG (gas natural comprimido):
                kg por 100 km
            Indicación brújula:
                Posición inferior
            reg. int. luz:
                Regulación de intensidad de iluminación, borne 58xd
            Consumo medio prop. eléctrica:
                kWh por 100 km
            Lista de radios:
                Nombre de emisora o frecuencia
            Towing_capacity_mass:
                kg
        Adaptaciones:
            Día:
                    13 d
            time_parameter_display:
                tDDWUP:
                    0.00
                tDD15_on:
                    0.00
                tDD15_off:
                    0.15
                hmi_t_Dreiter_ms:
                    2.0 s
                hmi_t_dummyMenuTimeout_ms:
                    5 s
                hmi_t_UhrTimeout_ms:
                    10 s
                hmi_t_MenuTimeout_ms:
                    255 s
                hmi_t_TWSAnz_ms:
                    3 s
                hmi_t_NextWarning_ms:
                    6 s
                hmi_t_NextServiceAnz_ms:
                    5 s
                hmi_t_P2Pause_ms:
                    900 s
                hmi_t_Quit_ms:
                    10 s
                hmi_t_FondGurt:
                    35 s
                hmi_t_USZ:
                    0.20 s
                hmi_t_FTuerAUF:
                    300 ms
                hmi_t_P1Pause_ms:
                    20 s
                rollierblockgroesse:
                    3
            Dist. rec.:
                    11157 km
            Picture_Upload_Download:
                    inactivo
            FIJO: Kilometraje desde última rev. en función del kilometraje:
                    11100 km
            Fijo: Kilometraje máx. hasta siguiente rev. en función de kil.:
                    30000 km
            Offset p. val. de calibr. del depósito:
                Offset transmisor 1:
                    -12.8 l
                Offset transmisor 2:
                    12.7 l
                Offset transmisor 3:
                    12.7 l
                Offset transmisor 4:
                    12.7 l
                Depósito calibr. completo:
                    -12.8 l
            Advertencia previa de servicio en día:
                    30 d
            SIA: valor máx. de tiempo hasta servicio:
                    365 d
            Fuente p. sincronización de la hora:
                    Reloj interno
            Desactivar advertencia cinturón:
                    no
            Hora:
                    18 h
            PIM: reiniciar prolong. interv. mant.:
                    ninguna advertencia
            Indicación de la temperatura del aceite:
                    on
            FIJO: Tiempo máx. hasta siguiente rev. en función del tiempo:
                    730 d
            Contador de días:
                    772 d
            FIJO: valor reposic. próx inspec en función del tiempo:
                    365 d
            Reset MFA3:
                Tecla del indicador multifunción RESET / OK:
                    Reset manual, no posible
                Detección de repostaje post. gasolina / gasóleo:
                    Reset MFA3
                Detección repostaje post. gas:
                    Reset MFA3
                Nachtankerkennung Elektro:
                    Reset MFA3
            SIA: valor máx. de trayecto hasta servicio:
                    15000 km
            Unidades ajustadas:
                Volumen:
                    litros
                Temperatura:
                    grados Celsios
                    Litros a los 100 km
                Presión:
                    bares
                Dist. rec.:
                    kilómetros
                Velocidad:
                    Kilómetros por hora
                fecha:
                    dd_mm_jj
                Hora:
                    24h
                    kg por 100 km
                    kWh por 100 km
                    kg
            PIM: valor mínimo de km-prestación kilométrica/revisión:
                    15000 km
                send_messages:
                    inactivo
            Año:
                    2019 a
            Mes:
                    8 mes
                    inactivo
                Unidad:
                    Kilómetros por hora
                Velocidad:
                    70
            FIJO: valor reposic. próx inspec en función del kilometraje:
                    30000 km
            Imagen en pantalla:
                    Variante 1
            outside_temperature:
                p_time_constant_pt1:
                    40 s
                p_speed_threshold:
                    20 km/h
                p_kmt_at_delta:
                    25 °C
                p_blocking_time_after_v_bigger_0:
                    15 s
                p_storage_time_engine_off:
                    180 min
                p_mileage_after_v_bigger_0:
                    5.0 km
                p_ice_warning_exit_temperature:
                    6 °C
                p_ice_warning_entry_temperature:
                    4 °C
                p_tendency_threshold:
                    1.0 °C
                p_time_constant_slow_damping:
                    2.0
                p_tendency_damping:
                    15 s
            Perfil de marcha para alcance restante:
                    6.8 l/100 km
            PIM: tiempo tras inspección:
                    136 d
            FIJO: Tiempo desde última revisión en función del tiempo:
                    741 d
            PIM: valor máximo de km-prestación kilométrica/revisión:
                    30000 km
            Service_Key_Clear_All_Counter:
                clear_all_counter:
                    sí
            PIM: valor máximo del tiempo transcurrido entre revisiones:
                    730 d
            PIM: carga térmica:
                    2300 km
            PIM: Recorrido tras inspección:
                    1660 km
            Ajustes llave de servicio:
                p_write_delay_time:
                    40 s
                p_write_delay_speed:
                    20 km/h
                p_write_distance:
                    20 km
                p_forcewrite_qual_time:
                    10 s
                p_main_switch_Keyless:
                    on
                p_main_switch_Basic:
                    on
                p_deactivate_SK_Function:
                    on
            PIM: valor mínimo del tiempo transcurrido entre revisiones:
                    365 d
            PIM: entrada de hollín:
                    0 km
            Corrección del indicador de consumos y alcance:
                    100 %
            Configuration of Development CAN-Messages:
                Block 1:
                    off
                Block 12:
                    off
                Block 2:
                    off
                Block 3:
                    off
                Block 4:
                    off
                Block 5:
                    off
                Block 6:
                    off
                Block 7:
                    off
                Block 8:
                    off
                Block 9:
                    off
                Block 10:
                    off
                Block 11:
                    off
                Block 13:
                    off
                Block 14:
                    off
                Block 15:
                    off
                Block 16:
                    off
                Block 17:
                    off
                Block 18:
                    off
                Block 19:
                    off
                Block 20:
                    off
                Block 21:
                    off
                Block 22:
                    off
                Block 23:
                    off
                Block 24:
                    off
                Block 25:
                    off
                Block 26:
                    off
                Block 27:
                    off
                Block 28:
                    off
                Block 29:
                    off
                Block 30:
                    off
                Block 31:
                    off
                Block 32:
                    off
                Block 33:
                    off
                Block 34:
                    off
                Block 35:
                    off
                Block 36:
                    off
                Block 37:
                    off
                Block 38:
                    off
                Block 39:
                    off
            Minuto:
                    19 min
            Idioma:
                    Español
            PIM: calidad del aceite:
                    Buena calidad del aceite
            dimming_characteristic_curve_adjustment_internal_phototransistor:
                X1:
                Y1:
                X2:
                Y2:
                    a
                X3:
                    32
                Y3:
                    32
                X4:
                    12c
                Y4:
                    96
                X5:
                    1f4
                Y5:
                    fd
            BAP_Debug_Mode_Release:
                Release:
                    not_released
            UC de la interfaz del sistema de localización del vehículo:
                    Sin montar
            Encendido activo mensaje, excitador:
                    Puerta del conductor
            defuel_threshold:
                defuel_threshold:
                    9 l
            init_fuel_algorithm:
                initialisation:
                    no
                    no activado
            Gas_functionality:
                Gas_functionality:
                    inactivo
            total_range_gas:
                state:
                    inactivo
                selection_consumption_factor:
                    consumption_factor_CAN
                consumption_profile:
                    consumption_profile_calculation
                consumption_factor:
                    0.000
            Desactivación del cilindro:
                    Indicación
            Illumination_algorithm:
                Pointer_illumination_algorithim:
                    terminal_58xd_log_bus_parkinglight
                Scale_switching_algorithm:
                    parking_light
            dimming_characteristic_curve_adjustment_fpk_middle_display_main_field:
                X1:
                Y1:
                    9
                X2:
                    a
                Y2:
                    9
                X3:
                    64
                Y3:
                    50
                X4:
                    96
                Y4:
                    190
                X5:
                    dc
                Y5:
                    352
                X6:
                    fd
                Y6:
                    3e8
            dimming_characteristic_curve_adjustment_fpk_indicator_lights:
                X1:
                Y1:
                    32
                X2:
                    a
                Y2:
                    32
                X3:
                    32
                Y3:
                    78
                X4:
                    64
                Y4:
                    e6
                X5:
                    96
                Y5:
                    1f4
                X6:
                    fd
                Y6:
                    3e8
            Preaviso del Servicio:
                    30 d
            Statistic_phev_mileage:
                    5 km
            Leaving_warning_delay:
                    1.6 s
            Display Farbabgleich:
                Rojo:
                Verde:
                Azul:
                    lowbeam_foglight
            Tube_version:
                    variant_0
            Display_longitudinal_coordinator:
                Control de crucero adaptativo (ACC):
                    inactivo
                GRA:
                    inactivo
                Limitador de velocidad:
                    inactivo
            Second_digital_speed:
                    Indicación
  10. #9
    New User
    Jul 2019
    Spain
    Modulo 19 Correct
    Now it's correct ..
    Fecha: 2019-08-13 18:21
        Año: 2018
    Copia de seguridad
        Unidad de Control: 19 Interfaz de diagnóstico de datos
        Descripción del sistema: GW MQB High
        Número de software: 3Q0907530G
        Versión de software: 5304
        Número de hardware: 3Q0907530C
        Versión de Hardware: 518
        Número de serie: 01061710802433
        Nombre ODX: EV_GatewNF
        Versión ODX: 013023
        Nombre de copia de seguridad: modulo19 130819
            030100047F085700FB000258080F00010001070000000000000000000000
            Sollverbau_MFL:
                montado
            EHR_EHRPsd15ProviderVerbaut_CO:
                Sin montar
            MV-EM_Stützung:
                inactivo
            EM_Ref_Spannungsmessung_Inaktiv:
                sí
            HV-EM_Klima_Codierung:
            MKE_Funktion:
                activado
            EM_Batterie_Verbauort:
                8
            EM_Generator_Uebersetzung:
                57
            FPA_Taster_Auswertung:
                Flanco ascendente
            MKE_Variante:
                7
        Sub sistemas:
            Sub sistema: E221__MFL-DC1
            Codificación extendida: 2CFFFF
        Adaptaciones:
                Interfaz de diagnóstico para el bus de datos:
                    Codificado
                Node_0x01:
                    Sin codificar
                Node_0x02:
                    Sin codificar
                Node_0x03:
                    Sin codificar
                Node_0x04:
                    Sin codificar
                Node_0x05:
                    Sin codificar
                Node_0x06:
                    Sin codificar
                Node_0x07:
                    Sin codificar
                Node_0x08:
                    Sin codificar
                    Codificado
                aparcamiento asistido:
                    Codificado
                Supervisión presión neum.:
                    Sin codificar
                el sistema electrónico de la columna de dirección:
                    Codificado
                Node_0x0D:
                    Sin codificar
                Centralita eléctrica electrónica:
                    Codificado
                Electrónica de todas las ruedas:
                    Sin codificar
                Node_0x11:
                    Sin codificar
                Dirección asistida:
                    Codificado
                Electrónica de los frenos:
                    Codificado
                Cuadro de instrumentos:
                    Codificado
                Airbag:
                    Codificado
                Node_0x16:
                    Sin codificar
                Node_0x17:
                    Sin codificar
                Radio:
                    Sin codificar
                Compresor climatizador:
                    Sin codificar
                Node_0x1A:
                    Sin codificar
                Pantalla elevada:
                    Sin codificar
                Actuador para la sonoridad del motor:
                    Sin codificar
                Node_0x1D:
                    Sin codificar
                Sistema eléctrico de bloqueo:
                    Sin codificar
                Node_0x1F:
                    Sin codificar
                Node_0x20:
                    Sin codificar
                Node_0x21:
                    Sin codificar
                Node_0x22:
                    Sin codificar
                Sistema electrónico de la puerta del maletero:
                    Sin codificar
                Node_0x24:
                    Sin codificar
                Node_0x25:
                    Sin codificar
                Node_0x26:
                    Sin codificar
                Node_0x27:
                    Sin codificar
                Node_0x28:
                    Sin codificar
                Node_0x29:
                    Sin codificar
                Node_0x2A:
                    Sin codificar
                Función especial 2:
                    Sin codificar
                Función especial:
                    Sin codificar
                Accionamiento eléct. techo:
                    Sin codificar
                Node_0x2E:
                    Sin codificar
                Node_0x2F:
                    Sin codificar
                Asistente de luz de carretera:
                    Sin codificar
                Bloqueo columna direc.:
                    Sin codificar
                Interfaz para sist. acceso y arranque:
                    Sin codificar
                Puerta corrediza tras. izq.:
                    Sin codificar
                Puerta corrediza tras. der.:
                    Sin codificar
                Node_0x35:
                    Sin codificar
                Node_0x36:
                    Sin codificar
                Node_0x37:
                    Sin codificar
                Node_0x38:
                    Sin codificar
                Node_0x39:
                    Sin codificar
                Node_0x3A:
                    Sin codificar
                Servofreno:
                    Sin codificar
                Node_0x3C:
                    Sin codificar
                Node_0x3D:
                    Sin codificar
                Electr. pta. lado conductor detrás:
                    Sin codificar
                Electr. pta. lado acomp. detrás:
                    Sin codificar
                Node_0x40:
                    Sin codificar
                Node_0x41:
                    Sin codificar
                Gestión térmica:
                    Sin codificar
                Node_0x43:
                    Sin codificar
                Cargador de la batería de alto voltaje:
                    Sin codificar
                Node_0x45:
                    Sin codificar
                Electrónica del aire acondicionado/de la calefacción:
                    Codificado
                Función remolque:
                    Sin codificar
                Node_0x48:
                    Sin codificar
                Node_0x49:
                    Sin codificar
                Electrónica pta. conductor:
                    Codificado
                Electrónica pta. acomp.:
                    Codificado
                Regulación del asiento del lado del conductor:
                    Sin codificar
                Regulación del asiento, lado del acompañante:
                    Sin codificar
                Sistema de asistencia para cambio de carril:
                    Sin codificar
                Sensores frontales de sist de asist al conductor:
                    Sin codificar
                Detección de la posición del vehículo:
                    Sin codificar
                Node_0x51:
                    Sin codificar
                Node_0x52:
                    Sin codificar
                Node_0x53:
                    Sin codificar
                del alcance de las luces:
                    Sin codificar
                Node_0x55:
                    Sin codificar
                Node_0x56:
                    Sin codificar
                Regulación de la distancia:
                    Codificado
                Node_0x58:
                    Sin codificar
                Node_0x59:
                    Sin codificar
                Node_0x5A:
                    Sin codificar
                Node_0x5B:
                    Sin codificar
                Node_0x5C:
                    Sin codificar
                Node_0x5D:
                    Sin codificar
                Node_0x5E:
                    Sin codificar
                Node_0x5F:
                    Sin codificar
                Node_0x60:
                    Sin codificar
                Node_0x61:
                    Sin codificar
                Node_0x62:
                    Sin codificar
                UC del micrófono:
                    Sin codificar
                Actuador para sonido ext.:
                    Sin codificar
                Gestión de carga de la batería de alto voltaje:
                    Sin codificar
                Node_0x66:
                    Sin codificar
                Módulo llamada de emergencia y unidad de comunicación:
                    Sin codificar
                Node_0x68:
                    Sin codificar
                Sist. cámara marcha atrás:
                    Sin codificar
                Calefacción adicional/auxiliar:
                    Sin codificar
                Node_0x6B:
                    Sin codificar
                Node_0x6C:
                    Sin codificar
                Receptor de TV:
                    Sin codificar
                Node_0x6E:
                    Sin codificar
                Sistema de sonido:
                    Sin codificar
                Media Player 1:
                    Sin codificar
                Tacógrafo:
                    Sin codificar
                Sistema electrónico de amortiguación de las ruedas:
                    Sin codificar
                Electrónica de información 1:
                    Codificado
                Node_0x74:
                    Sin codificar
                Node_0x75:
                    Sin codificar
                Electrónica del motor:
                    Codificado
                Electrónica del cambio:
                    Sin codificar
                Node_0x78:
                    Sin codificar
                Node_0x79:
                    Sin codificar
                Node_0x7A:
                    Sin codificar
                Gestión de batería híbrida:
                    Sin codificar
                Tracción eléctrica:
                    Sin codificar
                Node_0x7D:
                    Sin codificar
                Node_0x7E:
                    Sin codificar
                Node_0x7F:
                    Sin codificar
                Node_0x80:
                    Sin codificar
                Node_0x81:
                    Sin codificar
                Node_0x82:
                    Sin codificar
                Node_0x83:
                    Sin codificar
                    Sin codificar
                Alternador motor arranque:
                    Sin codificar
                Node_0x86:
                    Sin codificar
                Node_0x87:
                    Sin codificar
                Node_0x88:
                    Sin codificar
                Node_0x89:
                    Sin codificar
                Sistema de asistencia de cambio de carril 2:
                    Sin codificar
                Node_0x8B:
                    Sin codificar
                Node_0x8C:
                    Sin codificar
                Node_0x8D:
                    Sin codificar
                Node_0x8E:
                    Sin codificar
                Node_0x8F:
                    Sin codificar
                Node_0x90:
                    Sin codificar
                Node_0x91:
                    Sin codificar
                Node_0x92:
                    Sin codificar
                Node_0x93:
                    Sin codificar
                Node_0x94:
                    Sin codificar
                Node_0x95:
                    Sin codificar
                Node_0x96:
                    Sin codificar
                Node_0x97:
                    Sin codificar
                Node_0x98:
                    Sin codificar
                Node_0x99:
                    Sin codificar
                Node_0x9A:
                    Sin codificar
                Node_0x9B:
                    Sin codificar
                Gestión de batería 2:
                    Sin codificar
                Node_0x9D:
                    Sin codificar
                Node_0x9E:
                    Sin codificar
                Node_0x9F:
                    Sin codificar
                Node_0xA0:
                    Sin codificar
                Node_0xA1:
                    Sin codificar
                Node_0xA2:
                    Sin codificar
                Node_0xA3:
                    Sin codificar
                Calefacción adicional por aire:
                    Sin codificar
                Node_0xA5:
                    Sin codificar
                Node_0xA6:
                    Sin codificar
                Node_0xA7:
                    Sin codificar
                Node_0xA8:
                    Sin codificar
                    Codificado
                Node_0xAA:
                    Sin codificar
                Node_0xAB:
                    Sin codificar
                Node_0xAC:
                    Sin codificar
                Node_0xAD:
                    Sin codificar
                la regulación de la batería:
                    Sin codificar
                Node_0xAF:
                    Sin codificar
                Node_0xB0:
                    Sin codificar
                Node_0xB1:
                    Sin codificar
                Node_0xB2:
                    Sin codificar
                Node_0xB3:
                    Sin codificar
                Node_0xB4:
                    Sin codificar
                Node_0xB5:
                    Sin codificar
                Node_0xB6:
                    Sin codificar
                Node_0xB7:
                    Sin codificar
                Node_0xB8:
                    Sin codificar
                Node_0xB9:
                    Sin codificar
                Node_0xBA:
                    Sin codificar
                Node_0xBB:
                    Sin codificar
                Node_0xBC:
                    Sin codificar
                Node_0xBD:
                    Sin codificar
                Node_0xBE:
                    Sin codificar
                Node_0xBF:
                    Sin codificar
                Node_0xC0:
                    Sin codificar
                Node_0xC1:
                    Sin codificar
                Node_0xC2:
                    Sin codificar
                Node_0xC3:
                    Sin codificar
                Node_0xC4:
                    Sin codificar
                Node_0xC5:
                    Sin codificar
                Node_0xC6:
                    Sin codificar
                Node_0xC7:
                    Sin codificar
                Node_0xC8:
                    Sin codificar
                Node_0xC9:
                    Sin codificar
                Node_0xCA:
                    Sin codificar
                Node_0xCB:
                    Sin codificar
                Node_0xCC:
                    Sin codificar
                Node_0xCD:
                    Sin codificar
                Node_0xCE:
                    Sin codificar
                Node_0xCF:
                    Sin codificar
                Node_0xD0:
                    Sin codificar
                Node_0xD1:
                    Sin codificar
                Node_0xD2:
                    Sin codificar
                Node_0xD3:
                    Sin codificar
                Node_0xD4:
                    Sin codificar
                Node_0xD5:
                    Sin codificar
                Node_0xD6:
                    Sin codificar
                Node_0xD7:
                    Sin codificar
                Node_0xD8:
                    Sin codificar
                Node_0xD9:
                    Sin codificar
                Node_0xDA:
                    Sin codificar
                Node_0xDB:
                    Sin codificar
                Node_0xDC:
                    Sin codificar
                Node_0xDD:
                    Sin codificar
                Node_0xDE:
                    Sin codificar
                Node_0xDF:
                    Sin codificar
                Node_0xE0:
                    Sin codificar
                Node_0xE1:
                    Sin codificar
                Node_0xE2:
                    Sin codificar
                Node_0xE3:
                    Sin codificar
                Node_0xE4:
                    Sin codificar
                Node_0xE5:
                    Sin codificar
                Node_0xE6:
                    Sin codificar
                Node_0xE7:
                    Sin codificar
                Node_0xE8:
                    Sin codificar
                Node_0xE9:
                    Sin codificar
                Node_0xEA:
                    Sin codificar
                Node_0xEB:
                    Sin codificar
                Node_0xEC:
                    Sin codificar
                Node_0xED:
                    Sin codificar
                Node_0xEE:
                    Sin codificar
                Node_0xEF:
                    Sin codificar
                Node_0xF0:
                    Sin codificar
                Node_0xF1:
                    Sin codificar
                Node_0xF2:
                    Sin codificar
                Node_0xF3:
                    Sin codificar
                Node_0xF4:
                    Sin codificar
                Node_0xF5:
                    Sin codificar
                Node_0xF6:
                    Sin codificar
                Node_0xF7:
                    Sin codificar
                Node_0xF8:
                    Sin codificar
                Node_0xF9:
                    Sin codificar
                Node_0xFA:
                    Sin codificar
                Node_0xFB:
                    Sin codificar
                Node_0xFC:
                    Sin codificar
                Node_0xFD:
                    Sin codificar
                Node_0xFE:
                    Sin codificar
                Node_0xFF:
                    Sin codificar
  11. #10
    I'm not sure what these maps are from. Spanish language ODIS? Doesn't matter.
    This is the Ross-Tech forum. It exists to support Ross-Tech's customers. So please post data from VCDS. If you don't have VCDS, then you are seeking help in the wrong place.
