Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: VW 2005 mk4 Jetta - Hood Latch Question
    Dec 2017
    Hello all,
    So on my 2005 VW Jetta wagon 1.8t I do not get a confirmation "beep" when I lock the car. I first thought it was due to faulty door lock modules because I had signal communication error codes to several doors, and intermittent locking issues, I have since replaced them all and all are now in working order. Upon my last replacement, I went to do the celebratory lock anticipating the "beep" and to my disappointment I did not receive it (although all doors lock/unlock now correctly, so that was a plus). I then used my lovely VCDS and measuring block 08 in central convenience and noticed the front hood latch showed "open" even though the hood was shut. Ahhhhaaaa! So while looking at measuring block 08, with hood open, i manually clicked up and down on the hood latch contact switch, and sadly the measuring block value stayed at "open". So I thought to myself, OK, easy fix, i'll just purchase a new hood latch switch + harness.
    Fast forward to today, before tearing apart the front grill + hood latch assembly, I simply unplugged the harness at the easily accessibly harness connector (front of engine bay on passenger side) and plugged in the new OEM one. Started up my VCDS, went to measuring block 08, and clicked the contact switch up/down and the valued stayed at "open". !! I then thought, OK maybe it is a defective part (unlikely) so I tested the new part on my older 2003 VW jetta and sure enough the value in VCDS went from "open" to "close" etc etc. So i know the new OEM switch (and most likely the original is good too). I then grabbed my trusty test light, unplugged the connector and found with the ignition ON (engine off) on my older 2003 VW jetta I get +12V on pin #2 (brown wire with red stripe). I then go repeat this test on my 2005 mk4 jetta and wouldnt you know I do not have power at pin #2 !!
    So I start trying to trace this wire all over the engine bay, tearing things apart and thanks to my lack of electrical wire tracing skills, cannot find where it terminates or really where it even leads too.
    So my question to the VCDS community is this: Can I make a program / coding change to trick the car to think it is a always "closed" signal ? This would avoid tearing apart wiring looms trying to find where the single wire is open? Oh and I should mention before I started tearing thru, I was able to de-pin the #2 to inspect the crimped connector and all was secure with a good connection.
    If I cannot, does anyone have a clue where this wire has a common failure point? FYI, my full auto scan is below:
    Sunday,28,July,2019,20:24:04:53404
    VIN: WVWSE61J25W010683   License Plate: BR76LB
    Mileage: 273120km-169708mi   Repair Order:
    Chassis Type: 1J (9M - VW Jetta IV (1998 > 2014))
              75 76
    VIN: WVWSE61J25W010683   Mileage: 273120km-169708miles
    Address 01: Engine        Labels: 06A-906-032-AWP.lbl
       Part No: 06A 906 032 SK
       Component: 1.8L R4/5VT     G   0030
       Coding: 07500
       Shop #: WSC 01266
       VCID: 79AF10D230C45B0F8D7-5160
       WVWSE61J25W010683     VWZ7Z0D9180863
    16804 - Catalyst System; Bank 1
                P0420 - 35-10 - Efficiency Below Threshold - Intermittent
    16795 - Secondary Air Injection System
                P0411 - 35-10 - Incorrect Flow Detected - Intermittent
    16840 - EVAP System
                P0456 - 35-10 - Very Small Leak Detected - Intermittent
       Part No: 1C0 907 379 M
       Coding: 0019970
       Shop #: WSC 01266 785 00200
       VCID: 3431E1E6522666671E1-5184
       Part No: 1C0 909 605 F
       Component: 17 AIRBAG VW61 0108 0003
       Coding: 12599
       Shop #: WSC 01266
       VCID: 270B06AA96F01DFFAB3-513C
    Address 16: Steering wheel        Labels: 1J0-907-487-A.lbl
       Part No: 1J0 907 487 A
       Component: Lenkradelektronik   0005
       Coding: 00118
       Shop #: WSC 01266
       VCID: 2F3BEE8ABE0045BF633-5184
       Part No: 1J5 920 906 J
       Coding: 05232
       VCID: 3431E1E6572666671E1-513C
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 01266
       VCID: 70B92DF663BE1A473A9-513C
       Part No: 1C0 959 799 C
       Component: 8A Komfortgerát HLO 0004
       Coding: 00259
       Shop #: WSC 01266
       VCID: 372BD6EA46508D7F3B3-4B1E
       Component: 8A Tőrsteuer.FS KLO 0202
       Component: 8A Tőrsteuer.BF KLO 0202
       Component: 8A Tőrsteuer.HL KLO 0202
       Component: 8A Tőrsteuer.HR KLO 0202
    Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
       Part No: 3B7 035 180 G
       Component:    Radio PM6        0016
       Coding: 04031
       Shop #: WSC 01266
       VCID: 241111A6E7C6F6E78E1-513C
    I know this is small potatoes, but i am a mechanical engineer and it bugs me when a system is designed in a certain way and it does not perform as expected! Cheers and thank you for reading!
    Dec 2017
    Oh and FYI, on my correctly operating 2003 jetta, while viewing measuring block 08 with the hood open, the value shows "open". When I unplugg the connector, it switches to "closed". On my 2005, with the connector plugged in or unplugged it always stays at "open". So obviously this +12v wire has a continuity issue somewhere but god only knows where or how I can find it!!
    Dec 2017
    Just to throw up my latest auto scan:
       Coding: 00118
       Shop #: WSC 01266
       Coding: 05232
       VCID: 3431E1E6572666671E1-5160
       Coding: 00006
       Shop #: WSC 01266
       VCID: 70B92DF663BE1A473A9-5160
       Coding: 00259
       Shop #: WSC 01266
       Coding: 04031
       Shop #: WSC 01266
       VCID: 241111A6E7C6F6E78E1-5160
    I've read the CCM can get a "hiccup", and to clear it you can try disconnecting battery + and - leads and briefly touching them together to clear the "hiccup". Not sure if I should try this or not....
    Quote Originally Posted by rbb1485 View Post
    I don't think so. Those early CCMs aren't smart enough to have much in the way of programmable option.
    Proper investigation would involve the use of a wiring diagram. But if you're convinced that the the problem is a missing +12V on the one side of the switch, how about running a new wire there, at least temporarily, for testing purposes)? I'd put a 1 amp in-line fuse in that wire just to be sure you don't fry anything.
    This often helps when those CCMs get into a mode where they don't talk to a scan tool, but I'm skeptical that it will help here. OTOH, it can't hurt much to try it either.
    Dec 2017
    Hello Uwe,
    Thank you for your response, truly appreciated. I have in fact pulled the wiring diagram from my bently manual, I'll post a pic below. The hood latch switch F120 is a simple 2 wire switch....1 wire (brown/red) to the CCM, and 1 (brown) a ground connection in headlight wiring harness.
    I am sure that there is to be a +12V with ignition ON as i checked this on my correctly functioning 03' jetta, and this same test on my 05' wagon results in no +12v. So If i understand your suggested test, are you saying to run a 1 amp fused "test wire" with a +12v directly to the appropriate lead in connector going to the switch? Do I then manually depress the hood latch contact lever up/down and watch the measured value in block 08? Expecting it to change between "open" and "close" ? And if this is successful, that confirms I have a continuity issue in the brown/red wire going to the CCM ?
    I will start tomorrow by simply touching the + and - battery leads, as you confirmed this cant hurt anything.
    Thank you again.
  6. #6
    Yes, that's what I was suggesting.
    BUT! Based on the wiring diagram you posted, it looks to me like the other side of that switch goes to a GROUND connection in the headlight harness, not +12.
  7. #7
    Dec 2017
    Hi Uwe, yes that is how I read it as well. So what test would you suggest now? Thanks
  8. #8
    Dec 2017
    Just to provide an update. On my correctly functioning 03' jetta, when checking voltage with a multi-meter across wires T2a/1 and T2a/2 on the F120 hood latch switch, I get a steady +8V at all times. When I repeat this test on my problem 05' wagon, I do not get any measurable voltage.
  9. #9
    Jun 2014
    Newcastle, England
    T2a/! and T2a/2 aren't on the switch itself. They're a plug-coupler that your WD says is near the right headlight. That's a good place to start and narrow down your testing. Personally, there's possibly a whole load of the green crusties in that coupler that's causing things, but please test properly. At the coupler, separate it and test from T2a/1 to ground with a multimeter on resistance. Also test its current-carrying potential using an incandescent test light with the croc clip on the Bat + and the probe on T2a/1.
    Next, at the same plug-coupler, short T2a/2 to ground whilst watching the Measuring Blocks on VCDS. Report back please.
  10. Likes Uwe liked this post
  11. #10
    Dec 2017
    Thank you Zenerdiode. here are my results:
    Test T2a/1 to ground = I am getting around a 5.5ohm resistance.
    Current carrying potential = Incandescent test light LED shows steady "green"
    Short T2a/2 to ground while watching measuring block on VCDS = the value does not change from "OPEN"
