Hey, All
Dan here, Have a HEX-USB-CAN from Gendan back in 2011! To use with my Audi A3 8p.
Now with new A3 8v 2017 think it's about time lean more!
Friday,09,August,2019,12:55:43:64396
VCDS Version: 19.6.1.0
VIN: WAUZZZ8V7HA0xxxxx License Plate: GJ17xxx
Mileage: 30418km-18900mi Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 47 52 5F BB BC
VIN: WAUZZZ8V7HA0 Mileage: 30418km-18900miles
Address 01: Engine (J623-CRLB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 BP HW: 04L 907 309 R
Component: R4 2,0L EDC H23 1198
Revision: B5H23---
Coding: 021D0012032501082000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM20TDI01104L906026BP 002002
ROD: EV_ECM20TDI01104L906026BP_002.rod
VCID: 79F3FF34F822DE87DE-802C
Part No SW: 0D9 300 041 H HW: 02E 927 770 AQ
Component: DQ250-6F MQB H54 4902
Revision: 06354004 Serial number: TFK01608301205
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 1D3BCBA40C4A42A792-8048
Part No SW: 5Q0 614 517 AR HW: 5Q0 614 517 AG
Component: ESC H62 0642
Revision: 00000000 Serial number: 62766000000630
Coding: 12F18AA224260A718B7E0E0440C42948512450D170029473026100748208420000000012121212B835351919323200
ROD: EV_Brake1UDSContiMK100IPB_036_AU37.rod
VCID: 010397D490F2864796-8054
Part No SW: 8V0 820 043 Q HW: 8V0 820 043 Q
Component: AC Automat H03 0110
Revision: 20001000 Serial number: 00000001043745
Coding: 03100104002000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
VCID: 408552D0DB784F4FD9-8014
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0005
Serial number: 9FF88F4800PAG0MUFU03
Part No SW: 5Q0 937 084 CG HW: 5Q0 937 084 CG
Component: BCM MQBAB H H34 0236
Serial number: 02001627901283
ROD: EV_BCMBOSCH_017.rod
VCID: 7F07112CE606F0B7E0-802A
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 160906 043 0580
Serial number: 160916224159
Coding: 0A47F7
Component: G397_RLFS H06 0004
Serial number: 62323861
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 03 08 2016 00000957
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY162223C3V
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0313
Serial number: 00000000000067223095
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5QA 919 283 HW: 5QA 919 283
Component: PDC 4 KanalH07 0031
Serial number: 000308419616272
Coding: 0700040011
ASAM Dataset: EV_EPHVA14AU3700000 009027
ROD: EV_EPHVA14AU3700000_009.rod
VCID: 071789CCBED6B877D8-8052
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0315
Serial number: 003TDR25MCTD
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 1025A290CB98FFCF09-8044
Subsystem 1 - Part No SW: ----------- HW: 480 000 610 16
Serial number: 357000000007E4CCDE16
Subsystem 2 - Part No SW: ----------- HW: 480 000 610 16
Serial number: 35800000000B277C4E1V
Subsystem 3 - Part No SW: ----------- HW: 480 401 010 16
Serial number: 3510001A5231F2B294A+
Subsystem 4 - Part No SW: ----------- HW: 480 401 010 16
Serial number: 3520001A5231F2B1B5C3
Subsystem 5 - Part No SW: ----------- HW: 480 401 608 16
Serial number: 35500029F218C2A37367
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 401 908 16
Component: PedP_Sensor_D 000 6149
Serial number: 2280001C121DBA03263Y
Subsystem 7 - Part No SW: ----------- HW: 480 401 908 16
Component: PedP_Sensor_P 000 6149
Serial number: 2290001A120F2B2125BX
Subsystem 8 - Part No SW: ----------- HW: 480 001 209 16
Component: PedPSensor_D2 001 0887
Serial number: I0M000000009E2706E17
Subsystem 9 - Part No SW: ----------- HW: 480 001 209 16
Component: PedPSensor_P2 001 0887
Serial number: I0N000000007D0206E1+
Part No SW: 8V0 953 521 HB HW: 5Q0 953 549 E
Revision: -------- Serial number: 07101608490083
Coding: A418
Part No SW: 8V0 920 972 L HW: 8V0 920 972 L
Component: KOMBI H04 8316
Coding: 27A409082B8026000100E8001001000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009054
VCID: 479749CCFE56787718-8012
Part No SW: 5Q0 907 530 AL HW: 5Q0 907 530 E
Component: GW MQB Mid 127 1265
Revision: -------- Serial number: 0005425667
Coding: 030100041F0873005B0002481C0B00000001010000000000000000000000
ROD: EV_GatewLear_013.rod
VCID: 7BFFE53CF21EEC97CC-802E
Subsystem 2 - Part No SW: 81A 951 523 A HW: 81A 951 523 A
Component: J453 MFL H04 0003
Serial number: 20160824213720 21330
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1050
Serial number: 75410803001610015096
Component: TSG FS 020 0041
Serial number: 210916EIK10937
Coding: 00518A205C01040000001002
VCID: 438F5DDCCA6E5457C4-8016
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 128 1072
Coding: 8107
ROD: EV_SteerAssisMQB_013.rod
VCID: 458B43C4C45A6A67EA-8010
Address 47: Sound System (J525) Labels:| 81A-035-466.clb
Part No SW: 81A 035 466 HW: 81A 035 466
Component: MIB2_amp_P_A3 H10 0100
Revision: 00000001 Serial number: AUZ8ZAGHX00CZH0
Coding: 0173030000AAAA2AAA0000010000
ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
ROD: EV_AMPMst16C9Gen2ALPI.rod
VCID: 62C1B85875B43D5FEF-8036
Component: TSG BFS 020 0041
Serial number: 130916EID22802
Coding: 005182205E01040000001002
VCID: 428158D8D5745D5FCF-8016
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 81A 035 192 HW: 81A 035 192
Component: MU-HS-LND-EU 045 0148
Coding: 017303010000000011111102000A00102F002AE601F00100CE
ASAM Dataset: EV_MUHigScl6C3DELP 001011
ROD: EV_MUHigScl6C3DELP.rod
VCID: 5EB98CA841CC19BFCB-800A
Subsystem 1 - Part No SW: 8W0 919 866 C HW: -----------
Component: ECE 2016 --- 0009
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9GY208EA7
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 BE HW: 8V0 919 614 BE
Component: ControlUnit_B H50 0103
Serial number: ALJAL126091600010287
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 260916EIP0952B
Coding: 000082204001040000001002
Component: TSG HBFS 020 0041
Serial number: 260916EIP09527
End-------------------------(Elapsed Time: 04:20)--------------------------
