Results 1 to 2 of 2
Thread: Audi A5 8T Reverse Camera Calibration/Coding
    Aug 2019
    First time user of VCDS here, i've just registered it but not sure how i go about linking it to this account?
    I had a reversing camera installed a couple of weeks ago by a professional retrofitting company here in the UK. Despite specifically checking that they will calibrate the camera, my first auto scan shows it as not calibrated
    Now I've got my own VCDS and a print off of the calibration board I've decided to give it a go myself.
    The coding i've tried to enter for module 6C is 1032006 which gave me an 'error 31 - request out of range'. Is this because the company i used have kindly installed a Q5 camera module into my A5? As the coding 1032010 was accepted. (last 2 digits are 06 for A5 & 10 for Q5)
    After the above coding was accepted i changed the various adaptation numbers as required and the calibration was successful.
    My question is what difference it makes with the 6C coding being wrong for my car? Do the last 2 digits (which relate to the car model) just affect the adaptation default values?
    Scan after calibration below
    Saturday,10,August,2019,15:23:33:33426
    VIN: WAUZZZ8T2FA048289   License Plate:
    Chassis Type: 8T-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 47 52 53 56 5F 62 69
              6C 72
    VIN: WAUZZZ8T2FA048289   Mileage: 68920km-42824miles
    Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
       Part No SW: 03L 906 018 KL    HW: 03L 906 018 JL
       Component: R4 2.0l TDI   H25 9978
       Revision: 45H25---
       Coding: 0A254012243601080000
       Shop #: WSC 24483 001 1048576
       ASAM Dataset: EV_ECM20TDI01103L906018KL 003009
       ROD: EV_ECM20TDI01103L906018KK.rod
       VCID: 7EA5FED3D07F5CD7B85-802A
       Part No SW: 8K9 927 156 S    HW: 0B5 927 156 K
       Component: 0B5 20 TDIRdW H03 0005
       Revision: --H03---
       Shop #: WSC 06325 000 00000
       ROD: EV_TCMDL501021.rod
       VCID: 4DC7691F2D59374F71F-8018
       Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
       Coding: 359DCC01
       VCID: 094F9D0F99316B6F9D7-805C
       Part No SW: 8K0 907 064 KE    HW: 8K0 907 064 KE
       Component: BCM2 2.0      H15 0711
       Coding: 01B44040000000000000
       VCID: 7DA7F9DFDDF947CFA1F-8028
       Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
       Serial number: 0515000015944001
       Serial number: 3215000026633001
       Part No SW: 8K2 820 043 BB    HW: 8K2 820 043 BB
       Revision: D1000000    Serial number: 01160220152780
       Coding: 342402E000
       VCID: 6A8DC283BC77C07774D-803E
       Revision: 08016001    Serial number: 00001004059602
       Coding: 260000108034AFE00781408300001D0D009D634827090201000008004400030100000034000000
       Shop #: WSC 01211 210 01254
       VCID: 78A9E8CBF2DB62E7F29-802C
       Subsystem 1 - Part No SW: 8T2 955 119 D    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 090215  H13 0080
       Serial number: SWF15022095188
       Coding: 00FD31
       Serial number: 20129513
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000001102150507
       Serial number: E4B88397000000000001
       Component: AirbagVW-AU10 H48 0610
       Serial number: 003KFDC5WB1Q
       Coding: 30533938363030303030554A305238543053
       VCID: 48C9580BC23BD267429-801C
       Serial number: 6334MSME4E192A63M
       Serial number: 6344MSME4E3D7104K
       Serial number: 6352QSME764D1B66V
       Serial number: 6362QSME2E501264C
       Serial number: 63732SME7F4D21468
       Serial number: 63832SME7F4D20604
       Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
       Component: Lenks.Modul   H03 0003
       Revision: C0062331    Serial number: 90862OBD0002D
       Coding: 000036
       VCID: 48C9580BC2BBD267429-801C
       Part No SW: 8T0 920 984 K    HW: 8T0 920 984 K
       Component: KOMBIINSTR.   H35 0567
       Revision: 00100000    Serial number: 5L+3APA2G
       Coding: 33A7310003012600010400
       VCID: 47CB5B37CFA5DD1F4B3-8012
       Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
       Component: GW-BEM 4CAN-M H11 0060
       Revision: 1Y080030    Serial number: 3041Y152100C45
       Coding: 80CF07FF00
       VCID: 4ACD6203DCB7207754D-801E
       Serial number: 5458155803
       Serial number: 15040000605021200410
       Part No SW: 8T0 959 793 Q    HW: 8T0 959 793 F
       Component: TSG FA        H10 0305
       Coding: 011002624001450005
       VCID: 57EB8B771F054D9FDB3-8002
       Part No SW: 8K0 909 144 P    HW: 8K0 909 144 B
       Component: RCEPS         H43 0510
       Revision: 00001000    Serial number: 0011502315
       Coding: 100000010001
       Shop #: WSC 06324 000 00000
       ASAM Dataset: EV_RCEPSAU48X 008018
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3E253ED390FF9CD7F85-806A
       Revision: 00002001    Serial number: 0360423804
       Coding: 013B0622A0B900008320043680000047
       Revision: 00005001    Serial number: 94813040423706
       VCID: 2D07099F4D19174F51F-8078
       Part No SW: 8T0 959 792 Q    HW: 8T0 959 792 H
       Component: TSG BF        H09 0305
       Coding: 011002224001450005
       VCID: 56F58673180F7497C05-8002
       Component: EPB-4         H02 0005
       Revision: --------    Serial number: 30000000333833
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3A2D32C38CD7B0F7C4D-806E
       Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
       Component: Radio U DAB   H60 0150
       Revision: AB001007    Serial number: 109BK0F8010341
       Coding: 010103010000000001
       VCID: 2B030787730D197F4FB-807E
       Part No SW: 8R2 035 666 H    HW: 8R2 035 666 H
       Component: H-BN-EU       H48 0897
       Revision: --------    Serial number: 515BS0F7512306
       Coding: 130101040006A1EF0580AB5E00000403E40000020000000000
       VCID: 3E253ED3907F9CD7F85-806A
       Subsystem 1 - Part No: 8R0 060 884 GA
       Component: EUR 2019  2802
       Component: DU7 High  H42 0104
       Serial number: A130BT0F3261668
       Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
       Serial number: 00000002127159
       Component: CD-Database  5950
       Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
       Component: TSG HL        H08 0305
       Coding: 010002224001450005
       VCID: 59EF8D4F69115BEFED7-800C
       Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
       Component: Anhaenger     H12 0100
       Revision: 1A001001    Serial number: 00000360403068
       Coding: 010D000000000000
       Shop #: WSC 25381 000 00000
       VCID: 363526F3B84F5497205-8062
       Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
       Revision: --H08---    Serial number: 525PA8-J3940QN
       Coding: 1032010
       VCID: 34311CFBA23346871E1-8060
       Component: TSG HR        H08 0305
    End----(Elapsed Time: 01:46, VBatt start/end: 12.1V/12.0V. VIgn 11.9V)-----
    Thanks
    Matt
    Quote Originally Posted by MAJones89 View Post
    Done, Verified. Moving to Retrofits.
  3. Likes MAJones89 liked this post
