First time user of VCDS here, i've just registered it but not sure how i go about linking it to this account?
I had a reversing camera installed a couple of weeks ago by a professional retrofitting company here in the UK. Despite specifically checking that they will calibrate the camera, my first auto scan shows it as not calibrated
Now I've got my own VCDS and a print off of the calibration board I've decided to give it a go myself.
The coding i've tried to enter for module 6C is 1032006 which gave me an 'error 31 - request out of range'. Is this because the company i used have kindly installed a Q5 camera module into my A5? As the coding 1032010 was accepted. (last 2 digits are 06 for A5 & 10 for Q5)
After the above coding was accepted i changed the various adaptation numbers as required and the calibration was successful.
My question is what difference it makes with the 6C coding being wrong for my car? Do the last 2 digits (which relate to the car model) just affect the adaptation default values?
Scan after calibration below
Matt
Saturday,10,August,2019,15:23:33:33426
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUZZZ8T2FA048289 License Plate:
Chassis Type: 8T-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 47 52 53 56 5F 62 69
6C 72
VIN: WAUZZZ8T2FA048289 Mileage: 68920km-42824miles
Address 01: Engine (J623-CGLC) Labels:. 03L-906-018-CGL.clb
Part No SW: 03L 906 018 KL HW: 03L 906 018 JL
Component: R4 2.0l TDI H25 9978
Revision: 45H25---
Coding: 0A254012243601080000
Shop #: WSC 24483 001 1048576
ASAM Dataset: EV_ECM20TDI01103L906018KL 003009
ROD: EV_ECM20TDI01103L906018KK.rod
VCID: 7EA5FED3D07F5CD7B85-802A
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8K9 927 156 S HW: 0B5 927 156 K
Component: 0B5 20 TDIRdW H03 0005
Revision: --H03---
Coding: 000001
Shop #: WSC 06325 000 00000
ROD: EV_TCMDL501021.rod
VCID: 4DC7691F2D59374F71F-8018
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V2.clb
Part No SW: 8K0 907 379 CP HW: 8K0 907 379 CP
Component: ESP8 quattro H09 0020
Coding: 359DCC01
VCID: 094F9D0F99316B6F9D7-805C
Part No SW: 8K0 907 064 KE HW: 8K0 907 064 KE
Component: BCM2 2.0 H15 0711
Coding: 01B44040000000000000
VCID: 7DA7F9DFDDF947CFA1F-8028
Subsystem 1 - Part No SW: 8K0 959 754 H HW: 8K0 959 754 H
Component: FBSAUDIB8 IDG H71 0083
Serial number: 0515000015944001
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 3215000026633001
Part No SW: 8K2 820 043 BB HW: 8K2 820 043 BB
Revision: D1000000 Serial number: 01160220152780
Coding: 342402E000
VCID: 6A8DC283BC77C07774D-803E
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00001004059602
Coding: 260000108034AFE00781408300001D0D009D634827090201000008004400030100000034000000
Shop #: WSC 01211 210 01254
VCID: 78A9E8CBF2DB62E7F29-802C
Subsystem 1 - Part No SW: 8T2 955 119 D HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 090215 H13 0080
Serial number: SWF15022095188
Coding: 00FD31
Component: G397_RLFS H06 0004
Serial number: 20129513
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000001102150507
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: E4B88397000000000001
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Component: AirbagVW-AU10 H48 0610
Serial number: 003KFDC5WB1Q
Coding: 30533938363030303030554A305238543053
VCID: 48C9580BC23BD267429-801C
Serial number: 6334MSME4E192A63M
Serial number: 6344MSME4E3D7104K
Serial number: 6352QSME764D1B66V
Serial number: 6362QSME2E501264C
Serial number: 63732SME7F4D21468
Serial number: 63832SME7F4D20604
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862OBD0002D
Coding: 000036
VCID: 48C9580BC2BBD267429-801C
Component: E221 - MFL H03 0004
Part No SW: 8T0 920 984 K HW: 8T0 920 984 K
Component: KOMBIINSTR. H35 0567
Revision: 00100000 Serial number: 5L+3APA2G
Coding: 33A7310003012600010400
VCID: 47CB5B37CFA5DD1F4B3-8012
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0060
Revision: 1Y080030 Serial number: 3041Y152100C45
Coding: 80CF07FF00
VCID: 4ACD6203DCB7207754D-801E
Serial number: 5458155803
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H05 0006
Serial number: 15040000605021200410
Part No SW: 8T0 959 793 Q HW: 8T0 959 793 F
Component: TSG FA H10 0305
Coding: 011002624001450005
VCID: 57EB8B771F054D9FDB3-8002
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8K0 909 144 P HW: 8K0 909 144 B
Component: RCEPS H43 0510
Revision: 00001000 Serial number: 0011502315
Coding: 100000010001
Shop #: WSC 06324 000 00000
ASAM Dataset: EV_RCEPSAU48X 008018
ROD: EV_RCEPSAU48X_008.rod
VCID: 3E253ED390FF9CD7F85-806A
Revision: 00002001 Serial number: 0360423804
Coding: 013B0622A0B900008320043680000047
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813040423706
VCID: 2D07099F4D19174F51F-8078
Part No SW: 8T0 959 792 Q HW: 8T0 959 792 H
Component: TSG BF H09 0305
Coding: 011002224001450005
VCID: 56F58673180F7497C05-8002
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 30000000333833
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A2D32C38CD7B0F7C4D-806E
Part No SW: 4G0 035 061 Q HW: 4G0 035 061
Component: Radio U DAB H60 0150
Revision: AB001007 Serial number: 109BK0F8010341
Coding: 010103010000000001
VCID: 2B030787730D197F4FB-807E
Part No SW: 8R2 035 666 H HW: 8R2 035 666 H
Component: H-BN-EU H48 0897
Revision: -------- Serial number: 515BS0F7512306
Coding: 130101040006A1EF0580AB5E00000403E40000020000000000
VCID: 3E253ED3907F9CD7F85-806A
Subsystem 1 - Part No: 8R0 060 884 GA
Component: EUR 2019 2802
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130BT0F3261668
Subsystem 3 - Part No SW: 8T0 919 611 K HW: 8T0 919 611 B
Component: E0380 Bedient H02 0030
Serial number: 00000002127159
Component: CD-Database 5950
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HL H08 0305
Coding: 010002224001450005
VCID: 59EF8D4F69115BEFED7-800C
Address 69: Trailer (J345) Labels:. 8K0-907-383.clb
Part No SW: 8K0 907 383 E HW: 8K0 907 383 E
Component: Anhaenger H12 0100
Revision: 1A001001 Serial number: 00000360403068
Coding: 010D000000000000
Shop #: WSC 25381 000 00000
VCID: 363526F3B84F5497205-8062
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H08--- Serial number: 525PA8-J3940QN
Coding: 1032010
VCID: 34311CFBA23346871E1-8060
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Component: TSG HR H08 0305
End----(Elapsed Time: 01:46, VBatt start/end: 12.1V/12.0V. VIgn 11.9V)-----
Matt
