Results 1 to 10 of 11
Thread: Rear Traffic Alert with 8Ch PDC Skoda Kodiaq
    Verified VCDS User Norrland's Avatar
    Aug 2019
    Sweden
    Hello Ross-tech forum
    Is it possible to use the Two rear mounted radars as Rear Traffic Alert with the 8Ch PDC?
    Page 226
    https://ws.skoda-auto.com/OwnersManu...nersManual.pdf
    The car is not equipped with Blind Spot monitoring, but it still came with the rear radar from factory Would it be possible to use the Blind spot without LEDs in the mirror? Just sending vibrations through the steering wheel if the cars moves towards the hidden car?
    Friday,09,August,2019,16:05:11:64984
    VIN: TMBLK9NS7H80xxxxx
    Chassis Type: NS-SK37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 22 29 2B 36 39 42
              44 47 52 55 5F 69 6C 6D 75 A5 D6 D7
    VIN: TMBLK9NS7H80xxxxx   Mileage: 25931km-16112miles
    Address 01: Engine (J623-DFHA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 EJ    HW: 04L 907 309 P
       Component: R4 2.0l TDI   H25 3916
       Revision: B4H25---
       Coding: 0125001A04761D083000
       Shop #: WSC 33361 790 00063
       ASAM Dataset: EV_ECM20TDI01104L906026EJ 004004
       ROD: EV_ECM20TDI01104L906026EJ_004.rod
       VCID: 76B5E687E848E037E05-8022
       Part No SW: 0DL 300 011 N    HW: 0GC 927 711 G
       Component: GSG DQ500     H06 2014
       Revision: 00H06V07
       VCID: 33331F93BBBAB51F07B-8066
       Revision: 00000000    Serial number: 60747000000619
       Coding: 60076A9F54210B71477D070962C74906562AD0E2E046927D386150F8E20A4200002F641A1B13111435351919323200
       VCID: 77ABEB83EF42993FFB3-8022
       Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
       Component: VWKESSYMQB    036 0811
       Revision: 00036000    Serial number: 0434760296
       Coding: 032C0C0F03
       VCID: 3C2134AF96E47A67D61-8068
       Part No SW: 565 907 044 S    HW: 565 907 044 S
       Revision: 00001K00
       Coding: 16010104004111011105104C0010100A
       Shop #: WSC 73430 790 00063
       VCID: 2B0307F3638AEDDF4FB-807E
       Air quality sensor:
       Subsystem 3 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
       Component: G238 _AQS  H30 0119
       Serial number: 60358254
       Part No SW: 5Q0 937 086 BH    HW: 5Q0 937 086 BH
       Component: BCM PQ37BOSCH 032 0223
       Revision: --------    Serial number: 865807031701BI
       ROD: EV_BCMBOSCH_017.rod
       VCID: 015F855BB186D78FC57-8054
       Subsystem 1 - Part No SW: 566 955 119     HW: 566 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS326 170126  051 0905
       Serial number: 887353F0401702600908
       Coding: 164DDD
       Component: RLHS  042 0105
       Serial number: S5Y17M03D12H23M55S24
       Coding: 00885D
       Part No SW: 3Q0 919 294 A    HW: 3Q0 919 294
       Component: PDC 8 Kanal   H07 0020
       Serial number: 001102177478010
       Coding: 0071551911
       ASAM Dataset: EV_EPHBO18VW3260000 007015
       ROD: EV_EPHBO18VW3260000_007.rod
       VCID: 372B2B83AFC2593F3B3-8062
       Component: ACCCONTIMQB   H01 0233
       Coding: 320067C950FF8728749C8145304087
       VCID: 3E253EA780F86877F85-806A
       Serial number: 27021741350718
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 382928BFA2DC5647329-806C
       Part No SW: 3Q0 959 655 AP    HW: 3Q0 959 655 AP
       Component: Airbag VW21   004 0306
       Revision: --------    Serial number: 003RAP4X5Z2F
       Coding: 98FCC0C0000000005C5400CF004800000065
       ASAM Dataset: EV_AirbaVW21TS6VW48X 001010
       ROD: EV_AirbaVW21TS6VW48X.rod
       VCID: 0C41A46F86C48AE7A61-8058
       Belt Pretensioner left:
       Serial number: 566857705A0055R00175
       Coding: 80000D
       Belt Pretensioner right:
       Serial number: 566857706A0054R01102
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 454 000 303 17
       Serial number: 35700000000A8499D22T
       Subsystem 4 - Part No SW: -----------    HW: 454 000 303 17
       Serial number: 35800000000F8499D22Z
       Subsystem 5 - Part No SW: -----------    HW: 454 802 402 17
       Serial number: 35100E86B5B0F000000-
       Subsystem 6 - Part No SW: -----------    HW: 454 802 202 17
       Serial number: 35200DEBC130F000000-
       Subsystem 7 - Part No SW: -----------    HW: 454 800 702 17
       Serial number: 35500950C880E000000Q
       Part No SW: 5Q0 953 521 LA    HW: 5Q0 953 569 B
       Component: Lenks.Modul   100 0245
       Revision: FF036036    Serial number: 20170316500834
       Coding: 6414
       ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
       ROD: EV_SMLSVALEOMQBLRH.rod
       VCID: 7CA1F4AFD664BA67961-8028
       Part No SW: 565 920 751     HW: 565 920 751
       Component: KOMBI         311 8311
       Coding: 07A4081CFF84000801886B031001000800000000
       Shop #: WSC 73430 031 00063
       VCID: 58E9883F029CB647D29-800C
       Part No SW: 5Q0 963 272 G    HW: 5Q0 963 272 G
       Component: STH-MQB       008 0075
       Coding: 9309
       VCID: 3A2D32B79CD04457C4D-806E
       Component: R64 D208L  004 0401
       Serial number: 00000000000000212150
       Part No SW: 3Q0 907 530 C    HW: 3Q0 907 530 C
       Component: GW MQB High   515 5286
       Serial number: 15031710520768
       Coding: 030100344F087300EB03225E9E0F00010001070000000000000000000000
       Shop #: WSC 33361 790 00114
       ROD: EV_GatewNF.rod
       VCID: 2F3B13E3579291FF633-807A
       Subsystem 2 - Part No SW: 3V0 919 719 C    HW: 3V0 919 719 C
       Component: E221__MFL-PR6  H02 0160
       Serial number: 000000000C1881030317
       Subsystem 3 - Part No SW: 5QA 915 181 C    HW: 5QA 915 181 C
       Serial number: 75886100001703030047
       Serial number: HA1-00010.02.17
       Coding: 0101
       VCID: 4ACD6277CC30D4D754D-801E
    Address 29: Left Light (J1018)       Labels: None
       Part No SW: 8V0 907 397 AD    HW: 8V0 907 397 D
       Component: LCM_MLBevoH05 0024
       ROD: EV_LCMLeftHELLAAU736_VW48.rod
       VCID: 0655964798A8F0B7F05-8052
       Serial number: 17000058818006
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71BFD59B8126C70F357-8024
    Address 36: Seat Mem. Drvr (J810)       Labels:* None
       Part No SW: 5Q0 959 760 B    HW: 5Q0 959 760 B
       Component: Sitzmemory    H08 0021
       Serial number: Y0006QBH21072
       Coding: 0010000000000500018281818181000000008181000000D400
       ASAM Dataset: EV_SeatMemorDriveSide 002021
    Address 39: Right Light (J1023)       Labels: None
       Component: TSG FS        010 0032
       Serial number: 0000246907243
       Coding: 00150920DE00048000001100
       VCID: 47CB5B43DF2229BF4B3-8012
       Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000013713471
       Coding: 010200
       Part No SW: 5Q0 909 143 P    HW: 5Q0 909 143 E
       Component: MQB_PP_APA    204 2051
       Revision: 00000000    Serial number: 0001478201
       Coding: 01000011004001
       ROD: EV_SteerAssisVWBSMQBA_009_VW41.rod
       VCID: 40D9405FFA0C1E878A9-8014
    Address 47: Sound System (J525)       Labels:| 81A-035-466.clb
       Part No SW: 81A 035 223     HW: 81A 035 223
       Component: MIB2_amp_P_SK H10 0410
       Revision: 00000001    Serial number: SKZ8Z1GJE01DFWM
       Coding: 0323160000AA002AAA0000000000
       ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001003
       ROD: EV_AMPMst16C4Gen2ALPI.rod
       VCID: 59EF8D3B7996AF4FED7-800C
       Component: TSG BFS       010 0032
       Serial number: 0000246372572
       Coding: 00150120DE00048000001100
       VCID: 46D55647D82830B7B05-8012
       Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000013811264
       Coding: 190200
       Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
       Component: AFS-ECU       H07 0070
       Coding: 03E202003D210901
       ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
       ROD: EV_HeadlRegulAFSMQBMAX_SK37.rod
       VCID: 41DF455BF106178F857-8014
       Part No SW: 5Q0 035 864 B    HW: 5Q0 035 864 B
       Component: MU-S-N-ER     H30 0361
       Serial number: SKZAZ2T5119560
       Coding: 032316010000000051110002000808002F0300E4012081008E
       ROD: EV_MUStd4CTSAT_VW41.rod
       VCID: 323D1A9744A0BC170CD-8066
       Subsystem 1 - Part No SW: 565 919 605 B    HW: 565 919 605 B
       Component: ABT_Std-2_Nav  H34 8074
       Serial number: SKZ6ZET0771432
       Subsystem 2 - Part No SW: 5L0 051 236 T    HW: -----------
       Component: ECE1 2017/18  --- 0820
       Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
       Component: Anhaenger     H21 0204
       Revision: 8A001003    Serial number: 0434275012
       Coding: 0100000202000000
       VCID: 3B2337B393EA7D5FDFB-806E
       Coding: 04231601A3002017000040
       VCID: 392F2DBB99D64F4FCD7-806C
       Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0261
       Revision: --------    Serial number: 31247102800000
       Coding: 1B88
       Part No SW: 5NA 035 284 A    HW: 5NA 035 284 A
       Component: OCULowMQBLGE  H13 0614
       Coding: 03231601EA421A0D3B1C9E020045400382E608
       ASAM Dataset: EV_OCULowMQBLGE 003042
       ROD: EV_OCULowMQBLGE_003_VW25.rod
       Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
       Component: MQB_B_MFK     H06 0231
       Serial number: 06031712K21388
       Coding: 0203070600000401002213458050A90090000E200020
       Shop #: WSC 24929 002 104857
       Part No SW: 7PP 941 571 AE    HW: 7PP 941 571 A
       Component: LED1L         H09 0007
       VCID: 1869C83FC21C7647129-804C
       Component: LED1R         H09 0007
       ROD: EV_LEDModLeftMELCOAU736_VW48.rod
    End----------(Elapsed Time: 02:16, VBatt start/end: 13.7V/13.7V)-----------
    Thanks in advance
    Norrland
    May 2017
    No, no and no to your questions.
    First, the detection area of the pdc sensors is too short and narrow for this kind of detection.
    Then installing BSD system without mirror indicators. No as the system makes a check when starting and it will disable the system if not all components are ok. The system does not use PDC sensors, it has own radar units behind the rear bumper. So if you don’t have BSD system from factory, you don’t have the radars in the car.
    And anyway, installing the wiring to the mirrors is probably the easiest part.
    I’ve installed BSD to my wife’s Seat Leon, and a Side assist to my own Tiguan. Takes about two days to install and is really not that bad.
    Aug 2019
    Sweden
    Not talking about the short-range PDC sensors.
    The car has the 8Ch PDC computing-unit and the rear radars for RTA and BSD.
    Br
    Norrland
    May 2017
    Do you have RCTA on? I don’t see 3C in your autoscan so I don’t think those are BSD radars. The BSD radars are mounted behind rear bumper, not inside the car.
    This is BSD and RCTA radar :
    https://images.app.goo.gl/2iSrS3qokJnUcHQo8
    Aug 2019
    Sweden
    No I don't have the RCTA. From what I can see those are mounted directly to the back bumper thru the plastic Tunnel. I can look later today if I can see any part-numbers.
    Br
    Norrland
  6. #6
    May 2017
    Do you have easy open trunk? Maybe those are the sensors for that? Really hard to make out from the picture where it is taken from.
  7. #7
    Aug 2019
    Sweden
    Nope, no easy open.
    They are mounted in the car as described in the manual on page 225
    edit: It looks like they are for the ventilation?
    Br
    Norrland
  8. #8
    May 2017
    Look, I know what they are, what they look like and how they are mounted.
    They’re NOT mounted to the bumper. They’re mounted to car chassis behind the rear bumper.
    If your car has blind spot radars mounted and wired from factory without actually having that functionality, it would be the first.
    Try to get part numbers.
    But again, your autoscan isn’t showing 3C lane assist module, so they’re not wired to the system.
  9. #9
    Aug 2019
    Sweden
    Yes, you are right sir. It looks like they are a part of the ventilation system.
    Br
    Norrland
  10. #10
    May 2017
    I hope it’s not you car diced and sliced on the picture ��. Seriously, nice picture. Shows very well what is hidden behind the bumper.
