Results 1 to 10 of 18
Thread: Golf MK6 R ABS re-coding headache.
    Dec 2018
    Australia
    Hi there, This was supposed to be relatively simple job, or so I thought, stupid me. After deciding to give the job of replacing the ABS module to a local VW Audi repairer (so they and the sign said, and a recommendation) and after nearly a month to do the job, I finally collected my car and was told the ABS lights are still flashing as they have no gear to re-code the new module. Yes they fitted a new module as its coding comes up as (all 0000000000's). I still have the old one. Any way I was happy to have my little beast back and dragged out the trusty VCDS cable and decided to re-code it myself. I did a auto scan before and after the module was fitted and used the original code to update the module, all to no result. Tried the three options WCS etc and get told either, coding rejected error 00 unknown 0x00 or coding rejected error 12 sub function not supported or invalid format.
    below is a cut and paste of the scan when it first came up.
       Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
       Revision: 00H31001
       Coding: 163B800D092500FB680F01EB901C00813D0000
       VCID: 76B51ABE28CDE6C7B41-8022
    01130 - ABS Operation
                008 - Implausible Signal
                        Fault Status: 01101000
                        Reset counter: 180
                        Mileage: 66675 km
                        Date: 2013.12.04
                        Time: 10:20:55
    Below is the current scan,
       Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
       Component: ESP MK60EC1   H45 0107
       Revision: 00H45001
       VCID: 7EA5029E00FDAE87B85-802A
    00003 - Control Module
                        Fault Status: 01100101
                        Reset counter: 188
                        Mileage: 66799 km
                        Date: 2013.12.30
                        Time: 00:23:19
                        Count: 3
                        Count: 12288
                        Count: 143
                        Count: 38144
    Any help resolving this will be most welcome.
    Just one more, why are the dates so wrong in my logs?
    Regards Col.
    What ever you do do it well.
    Col, as ever we'll need a full unedited VCDS Auto-Scan.
    This is especially important for ABS coding which is dependent on other modules in the car as well as the VIN.
    Dec 2018
    Australia
    Hi Dave,
    Thanks for the reply, below is scan from today, I've also the scans when it went bad. Let me know if you need them as well.
    Thanks & regards Col.
    Sunday,14,July,2019,12:16:26:44471
    VCDS Version: 18.9.1.0  HEX-V2 CB: 0.4436.4
    Dealer/Shop Name: D572226355C88800
    VIN: WVWZZZ1KZBW131473   License Plate:
    Chassis Type: 1K-VW36 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 55 56 62 72
    VIN: WVWZZZ1KZBW131473   Mileage: 66690km-41439miles
    Address 01: Engine (CDL)       Labels:. 06F-907-115-CDL.clb
       Part No SW: 1K8 907 115 D    HW: 8P0 907 115 B
       Revision: 5BH19---    Serial number:
       Coding: 0403000C1C0F0160
       Shop #: WSC 66565 257 00032
       VCID: 2F3BEFDA9B17970F377-807A
    Readiness: 0110 0101
       Part No SW: 02E 300 013     HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2249
       Revision: 05151112    Serial number: 00001007280922
       VCID: 4EC5925EFCDDFE075C1-801A
       Revision: 00H31001
                        Reset counter: 181
                        Mileage: 66698 km
                        Count: 2
                        Count: 14
                        Count: 29184
                        Count: 124
                        Count: 49152
                        Count: 65280
                        Count: 255
       Part No SW: 5K0 907 044 BS    HW: 5K0 907 044 BS
       Component: Climatronic   H15 0709
       Revision: 00003001
       Coding: 0000001002
       VCID: 7DA705920D7BB59FF5B-8028
       Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
       Component: BCM PQ35  H   103 0615
       Revision: 00103 AD
       Coding: 48180A3A8825F1C040080080340008E441550088736D8960E48000240040
       VCID: 3829D486625950B766D-806C
       Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer 07101  26  0512
       Coding: 009795
       Component: RLS 191010 05  54  0403
       Coding: 0330AD
       Subsystem 4 - Part No: 1K8 951 605 A
       Component: LIN BACKUP HO  H11 9004
    Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
       Part No SW: 5K0 919 475 D    HW: 5K0 919 475
       Component: PARKHILFE 8K  H07 0010
       Revision: --------    Serial number: 48341022200834
       Coding: 100104
       VCID: 372BD7BA6F475FCF6F7-8062
       Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
       Component: AirbagVW10    037 0606
       Serial number: 003FKRAEDDRD
       Coding: 00003131
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01011
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3B23CB8A53EF7BAF8BF-806E
       Serial number: 3572MSME0D253558ZZZY
       Serial number: 3582MSME47763558ZZZ$
       Serial number: 3512QSME282F7049ZZZ
       Serial number: 3522QSME16276B71ZZZX
       Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
       Component: Lenks.Modul   007 0080
       Revision: --------    Serial number:  90422JJF00035
       Coding: 1892140000
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 76B51ABE284DE6C7B41-8022
       Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H06 0010
       Serial number: 0161472
       Coding: 830000
       Part No SW: 5K6 920 871 B    HW: 5K6 920 871 B
       Coding: 170F01
       VCID: 3333E3AA7BBFB3EF53F-8066
    Address 19: CAN Gateway        Labels:. 7N0-907-530-V1.clb
       Part No SW: 7N0 907 530     HW: 1K0 907 951
       Component: J533  Gateway   H27 5603
       Revision:   H27       Serial number: 191010F1000630
       Coding: EDA37F0600020200000003
       VCID: 6D8735D2519B251F45B-8038
       Part No SW: 0BR 907 554 B    HW: 0BR 907 554 B
       Component: Haldex 4Motion      3017
       Coding: 0000005
       VCID: 44D1B07622910457FA5-8010
       VCID: 6A8D3ECE6CF53227209-803E
       Component: Tuer-SG         009 2120
       Coding: 0000692
       VCID: 313FE9A28D2381FF213-8064
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 74     3001
       Revision: 00H17000
       Part No SW: 5K0 959 702 C    HW: 5K0 959 702 C
       Coding: 0000948
       VCID: 3333E3AA773FB3EF53F-8066
       Coding: 1475932
       VCID: 3431E0B67231B4D74A5-8060
       Coding: 00000022
       Coding: 00000022
       Part No SW: 5K0 035 190     HW: 5K0 035 190
       Component: Radio RCD510  041 0167
       Revision: 00000001    Serial number: VWZ1Z3K3563011
       Coding: 0500040004
       VCID: 629D56EE94456A67E89-8036
       Coding: 0000144
       Shop #: WSC 01357 011 1012552
       VCID: 3537DDB2794BADDF7DB-8060
       Coding: 0000144
       VCID: 3635DABE644DA6C7741-8062
    End----------(Elapsed Time: 01:17, VBatt start/end: 13.8V/13.7V)-----------
    Dec 2018
    Australia
    Okay stuff up, thats the scan when it went bad. correct one coming.
    Regards Col.
    Dec 2018
    Australia
    Okay, this is the one from today.
    Sorry I tried putting it in the scrolling box, but I just cant get it to do it.
    Saturday,10,August,2019,11:35:35:44471
    VCDS Version: 19.6.1.0  HEX-V2 CB: 0.4508.4
    VIN: WVWZZZ1KZBW131473   Mileage: 66810km-41513miles
       VCID: 2F3BEFDA9B17970F633-807A
                        Load: 0.0 %
                        Temperature: -40.0°C
                        Absolute Pres.: 0.0 mbar
                        Voltage: 0.000 V
    Readiness: 0010 0001
       VCID: 4EC5925EFCDDFE07085-801A
       Revision: 00H45001
                        Reset counter: 188
                        Mileage: 66799 km
                        Date: 2013.12.30
                        Time: 00:23:19
                        Count: 3
                        Count: 12288
                        Count: 143
                        Count: 38144
                        Reset counter: 188
                        Mileage: 66799 km
                        Date: 2013.12.30
                        Time: 00:23:19
                        Count: 3
                        Count: 12288
                        Count: 279
                        Count: 38144
                        Reset counter: 188
                        Mileage: 66799 km
                        Date: 2013.12.30
                        Time: 00:23:19
                        Count: 3
                        Count: 12288
                        Count: 295
                        Count: 38144
                        Reset counter: 188
                        Mileage: 66799 km
                        Date: 2013.12.30
                        Time: 00:23:19
                        Count: 3
                        Count: 12288
                        Count: 270
                        Count: 38144
                        Reset counter: 188
                        Mileage: 66799 km
                        Date: 2013.12.30
                        Time: 00:23:19
                        Count: 3
                        Count: 12288
                        Count: 195
                        Count: 38144
       Revision: 00003001
       Coding: 0000001002
       VCID: 7DA705920D7BB59FA1F-8028
       Revision: 00103 AD
       VCID: 3829D486625950B7329-806C
       Coding: 009795
       Coding: 0330AD
       Coding: 100104
       VCID: 372BD7BA6F475FCF3B3-8062
       Coding: 00003131
       VCID: 3B23CB8A53EF7BAFDFB-806E
       Coding: 1892140000
       VCID: 76B51ABE284DE6C7E05-8022
       Coding: 830000
       Coding: 170F01
       VCID: 3333E3AA7BBFB3EF07B-8066
       VCID: 6D8735D2519B251F11F-8038
                        Fault Status: 00101011
                        Reset counter: 229
                        Mileage: 66814 km
                        Date: 2013.12.31
                        Time: 02:03:53
       Coding: 0000005
       VCID: 44D1B07622910457AE1-8010
       VCID: 6A8D3ECE6CF5322774D-803E
       Coding: 0000692
       VCID: 313FE9A28D2381FF757-8064
       Revision: 00H17000
       Coding: 0000948
       VCID: 3333E3AA773FB3EF07B-8066
       Coding: 1475932
       VCID: 3431E0B67231B4D71E1-8060
       Coding: 00000022
       Coding: 00000022
       Coding: 0500040004
       VCID: 629D56EE94456A67BCD-8036
       Coding: 0000144
       VCID: 3537DDB2794BADDF29F-8060
       Coding: 0000144
       VCID: 3635DABE644DA6C7205-8062
    End----------(Elapsed Time: 01:19, VBatt start/end: 12.4V/12.4V)-----------
  6. #6
    Tartu, Estonia
    FOD detected....
    Why was different/incorrect ABS installed?
    The world is my oyster...
  7. Likes Jack@European_Parts, Uwe liked this post
    Original: 1K0-907-379-BE
    Replaced with: 1K0-907-379-AN
  9. Likes Jack@European_Parts liked this post
  10. #8
    Vehicle Identification No. WVWZZZ1KZBW131473
    Model Golf 2,0
    GOLF
    Date of production 29.10.2010
    Model year 2011
    Sales type 5K1RX7
    Engine Code CDLC
    Transmission Code MMF
    Nein FOD!
    I believe the AN is correct!
    PART NUMBER DESCRIPTION REMARK
    1K0 907 375 AN Control unit for ABS 1K0 614 517 BD
    1K0 614 517 BJ
    1K0 907 379 AN
    1K0 907 379 AD
    1K0 907 379 CD
    Part No SW: 1K8 907 115 D HW: 8P0 907 115 B <<<<<<<<<<<<<<<<<<< FOD CHECK PASS!
    Part No SW: 02E 300 013 HW: 02E 927 770 AL <<<<<<<<<<<<<<<<<<<<< FOD CHECK PASS!
    Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN <<<<<<<<<<<<<<<<<<< FOD CHECK PASS!
    Revision: 00H45001
    Coding: 134B000C092500FBC80F00EB901C00000000 VIN STRIP RHD
    Coding: 163B800D092500FB680F01EB901C00813D00 TRY THIS PLEASE WITH WHAT YOU HAD MINUS THE LAST BYTE of ZERO ZERO VACATED
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PE Wheel bolts with anti-theft protection (unlockable)
    Vehicle class differentiation units/platform components 0HA Vehicle class differentiation -1K0/5K0-
    tail pipe 0P1 Rear side exhaust tailpipe
    drive-off assistance UG1 Hill hold control
    Emission standard 7MG Emission standard EU5
    Trailer hitch 1D0 without trailer towing
    airbag 4UH Airbag for driver and passenger with knee airbag
    Aktivkohlebehälter / Ottopartikelfilter 1E1 Activated carbon canister
    Aerials 8ZH Antenna for AM/FM reception, "diversity"
    Exterior mirror setting 6XG Exterior mirrors with memory feature, power-adjustable/heated
    Left exterior mirror 5SJ Left exterior mirror, convex
    Right exterior mirror 5RV Right exterior mirror, aspherical
    Drive type 1X1 Four-wheel drive
    "Multimedia"video/DVD/notebook connection 9WL Jack for external audio source
    Equipment levels A9R Top sports
    Brake type in rear 1KW Disc brakes in rear
    batteries J1L Battery 280 A (60 Ah)
    Brake type, front 1ZK Silver caliper
    Components with special surface 6FH Exterior mirror housing painted
    Battery/alternator capacity NY0 Standard battery/alternator capacity
    Component part sets with country-specific design requirements B0R Component parts set, complying with vehicle type for Australia, various parts
    vehicle tools and jack 1S4 vehicle tools with special jack
    Brake systems 1AT Electronic stability control (ESC)
    Owner's manuals 0VF Information kit in English
    Operating voltage 9Z0 Operating voltage 12 V
    brake wear indicator 9U1 brake wear indicator
    Heated washer nozzles 9T0 Without heated washer nozzles
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    CD changer/CD player 7A0 Without CD changer/CD player
    "Charism" 2H0 Without "drive select"
    Chrome package QJ3 Chrome package (version 2)
    General operating permit, alterations C34 Operating permit, alteration
    Roof insert/convertible top 3FA roof without cut out
    Suspension system in rear 1JR Rear shock absorption
    Suspension system in front G09 Shock absorption in front
    Load-through hatch/ski bag 3X0 without load through system
    Insert for the filling up of unleaded fuel/fuel type 2G7 Filler neck module 1 with insert
    Installation differentiation for components 0ES Installation differentiation for transmission DQ250 -- vehicle components --
    Theft protection system 7AL Anti-theft alarm system, interior monitoring, backup horn and towing protection
    Inserts 5TD Decorative aluminum inserts
    Scuff plates 7M7 Scuff plates in door apertures
    Park distance control 7X2 Park distance control in front and rear
    Electric interface for external use UF0 Without electric interface
    Manufacturing sequence differentiation 0FA Standard manufacturing sequence
    window regulator 4R4 Power windows with comfort operation and circuit breaker
    fire extinguisher 6A0 without fire extinguisher
    Pedestrian protection VL1 Extended pedestrian protection measures
    Pedal cluster VF1 pedal cluster
    Headlight activation 8K3 Daytime headlights with automatic headlight control and coming home function
    Alternators 8GU Alternator 140 A
    Weight category rear axle 0YB Weight range 2 installation control only, no requirement forecast
    Weight category front axle L99 Suspension range 99 installation control only, no requirement forecast
    Base engine TA2 4-cyl. petrol engine 2.0 l assembly 06F.D
    Luggage netting/pocket on backrest(s) 4U5 Luggage pockets on backrest
    Luggage compartment cover 3U1 Folding trunk cover
    cruise control system 8T2 Electronic cruise control system (CCS)
    Luggage compartment trim 5A7 Comfort luggage compartment trim with service lid/snap-on cover
    Transmission specifications G0R 6-speed automatic transmission for four-wheel drive
    handle for hand brake lever 6PC handbrake lever grip (leather)
    Rear spoiler 5J4 Body-colored rear spoiler
    Rear window wiper and washer system 8M1 Rear window wiper washer system with intermittent wipe
    Rear seats 3NU Rear bench seat, not split, split backrest, folding centre armrest
    Heating and air-conditioning system 9AK Climatronic with impact pressure control, CFC-free
    Headlamps 8JX Twin headlamps for driving on the left (gas discharge) w/ integrated high beam
    Customized installation FC1 Customized installation
    Interior light in footwell 6T1 Interior light in footwell
    Instrument clusters U5A Instrument insert, km/h speedometer
    Breakaway interior rearview mirror 4L6 Breakaway interior rearview mirror, auto-dimming
    Sticker (customized or special edition) 0KA Without decals and emblems
    Body style K8G Hatchback
    coolbox 1W2 Glove compartment cooling system
    Climatic zones 0Y2 Tropical zones
    Compass/road sign display QR0 Without compass/road sign display/ dynamic road sign display
    headrest for seat, rear 3T2 Three rear head restraints
    Head restraints 5ZF Front head restraints
    Fuel tank treatment 2LC Fuel tank with special material treatment (coextrusion)
    Fuel quantity for initial filling 1Z2 Increase in initial standard fuel filling
    Fuel systems 1A5 Petrol injector fuel system (FSI)
    Body measures 5C3 Body measures for increased safety requirements
    Radiator grille 6KA Radiator grille
    License plate lighting KL0 Standard license plate lighting
    Rear license plate bracket 6P1 Rear license plate carrier (ECE)
    Front license plate bracket 6W1 Front license plate carrier (large)
    Paint preservative/transit coating 5K7 Transport protection film (minimum protection) with additional transport protection measures
    Paint coating FB0 standard paint coating
    Steering system arrangement L0R Right-hand drive
    Reading lamp 8S4 Two reading lights front, two rear
    steering 1N3 Speed-related variable steering assist (Servotronic)
    Backrest release 3H0 Without backrest release for front seats
    Air duct, front area VK1 Air duct, type 1
    Light control systems 8G0 Without Light Assist
    Lumbar support 7P4 Manually adjustable lumbar support in front seats
    steering wheels 2FU Leather-wrapped multi-function sports steering wheel with tiptronic
    Speaker installation 8RM 8 speakers (passive)
    Headlight range control 8Q5 Dynamic headlight range control, with cornering light (AFS 1)
    Center armrest 6E3 Center armrest in front
    Marten repeller UM0 Without marten repeller
    Multi-function display/trip computer 9Q5 Multi-function display with control
    Engine cooling 8Z6 Hot country
    Engine specifications D81 4-cylinder SI engine 2.0 l/188 kW (16V) turbo FSI, homogeneous base engine is TA2
    Left vanity mirror 4SD Vanity mirror, left, illuminated
    Right vanity mirror 4TD Vanity mirror, right, illuminated
    Navigation device 7Q0 without navigation system
    rear fog lamp 8TD Rear fog light for driving on the left
    Front fog lamp/additional headlamp 8WA Without fog lights
    Upgrading measures GP1 Vehicles with special upgrade measures
    Rear of platform module base 4P0 Rear floor panel module, type 1
    Platform group class 7PA Platform group class 1
    Hubcaps 1NL Trims for alloy wheels
    Wheels C6Z Alloy wheels 7.5 x 18
    Radios 8DD Radio "RCD510 World Variant"
    Smoker's/non-smoker's package 9JA Non smoker version
    Tire pressure monitoring system 7K9 Tire pressure monitoring system
    tire H7D Tires 225/40 R18 92Y xl
    Spare wheel/breakdown kit 1G9 Space-saving spare wheel for temporary use, radial tire (5-hole)
    Restraint systems, front 3QT 3-point seat belts in front, with tensioner and height adjustment
    PH2 Air conditioning Climatronic
    PLA "Lights & Vision" Pack
    RKZ
    W4B Power windows front and rear
    WD5 Anti-theft alarm system including single door opening
    WFT Ride comfort package
    Gearshift knob/handle 6Q6 Gearshift knob/handle in aluminum
    Special labels/plates 0SS Labels in English and French
    Tail lamp assemblies 8SP Taillight assemblies with diodes (LED)
    Locking mechanism for boot lid/cover rear 4E0 Tailgate/trunk lid unlocking from outside
    Front seat, left 3TU Sports seat, front left
    Front seat, right 3SU Sports seat in front, right
    Nameplates for sales name QD0 Without lettering for sales name
    Seat belt check 9P3 Seat belt reminder, electric contact in buckle
    Outer rear seat belts 3ZB 3-point seat belts, outer rear with ECE label
    Center rear seat belts 3C7 3-point seat belt for center rear seat
    seat covers N0L Seat trim covers in fabric
    Seat adjustment 3L3 Manual height adjustment for front seats
    seat heater 4A0 without seat heater
    Safety head restraint system 3K0 w/o safety head restraint system
    Side lights 7R3 Side turn signal lights (white)
    Start-stop system/regenerative braking 7L3 Without start/stop system without regenerative braking
    Horns 8Y1 Two-tone horn
    Side and rear windows 4KF heat protective glass for door, side and rear windows, darkened from b-pillar
    power outlet 7B2 12 volt socket in luggage compartment
    Bumper 2JF Painted bumpers
    Rear stabilizer 0BM Rear stabilizer
    Front stabilizer bar 0AE Front stabilizer bar
    Drawers under front seats QN0 Without drawers under front seats
    Heavy-duty/sports version 2UC Sports version
    Headlamp washer system 8X1 Headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N3 intermittent windscreen wiper with rain sensor
    Special approval measures 3M0 Without special measures
    Nameplate set 0PJ Nameplate set "R20" (without model designation)
    Mass damper for steering wheels 1Q1 Mass damper for steering wheel, 26.5Hz
    Door and lid locking system 4K3 Central locking w/ radio remote control, interior controls and SAFELOCK
    Type approval countries/countries with special requirements B30 Type approval country Australia
    Carrier frequency for remote control 5D1 Carrier frequency 433.92 to 434.42 Mhz
    Partition 3CA without partition
    Door and side trim panels 3LJ Door and side trim panel in foam film, insert in leatherette
    doors 0A2 4 doors
    TV reception/digital radio reception QV0 without TV/digital radio reception
    Front underbody guard 1SA Without additional front underbody guard
    Identification plates 1EJ Special identification plate
    Delivery equipment 2A8 Delivery equipment, water border
    First aid kit / warning triangle 1T0 Without first-aid material, without warning triangle
    Two-way radio installation preparation 9D0 without prepared for two way radio system
    Telephone / telematics 9W0 Without car phone preparation/ installation
    Additional warning lights 9TC Additional retro-reflectors (door area)
    LongLife Service Regime QG1 LongLife Service Regime
    Heat accumulator system/auxiliary heater 7E0 W/o heat accumulator/auxiliary heating
    Windshield Glass 4GF Windshield in heat-insulating glass
    Washer fluid level indicator 8W1 Washer fluid level indicator
    floor mats 0TD Front and rear floor mats
    Additional body panels, side 6EA Without additional side body covers (stone guard)
    Additional child seat anchors 3B8 Child seat anchors as per Australian requirements and child seat system ISOFIX
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
  11. #9
    Dec 2018
    Australia
    Hi Guys,
    I must say thanks for the responses, great to see. The original part 1K0-907-379-BE was replaced with 1K0-907-379-AN by VW Australia to the shop doing the work. I was concerned the parts had different numbers, but I was assured it would be all okay.
    So thinking about it, because they are different numbers, would it be correct to consider it will require a different code? Looking at Jacks post I assume the coding at the end of his post is what I need to use, trust me I'm no rocket scientist, it usually requires a large piece of wood to aggressively applied to my head for information to stick.
    Regards Col.
  12. Likes Jack@European_Parts liked this post
  13. #10
    Hi Guys,
    Regards Col.
    Try in GREEN above..........
    REPORT..........
  14. Likes Uwe liked this post
