Results 1 to 10 of 13
Thread: Arteon Engine Retardation issue
    New User
    Feb 2019
    I have personal problem (hard to live with) concerning the minimal engine braking (speed decrease) when lifting my foot off the accelerator. It's a 2018 Arteon 2.0L 190 Tsi DSG-7.
    Whether in Normal or Sports mode the deceleration is nil on the level ineffective on downwards slopes. Decending a steep hill, the brakes will cause engine braking to cut in, but not consistantly when decending the same hill repeatedly.
    In Tiptronic mode, whether dropping just one, two gears or even three gears has little effect also. At 5000 rpm in 2nd gear there is still no improvement - just engine noise! The dealer says the vehicle is all OK.
    Is there anyway to use VCDS to modify the engine/gearbox/torque retardation effectiveness when taking foot off the gas?
    My first thought is the Tilt sensing feature which does seem to have effect on steep hills. This system recognises me applying the brake pressure on a steep hill somehow. Then when I take foot of brake, I can feel the car is then being held back and assume it is doing so via torque control rather than doing so by applying my brakes automatically.
    Please post an Auto-Scan so people can see exactly how this vehicle is equipped and what we know about the control modules in it.
  3. Likes DrPeter liked this post
    Dec 2016
    Amsterdam
    Are we talking driving modes or transmission modes?
    Current:
    New User
    Feb 2019
    Saturday,10,August,2019,13:50:47:56590
    VCDS Version: 19.6.1.0 (x64)
    Uwe: Here you go, but with some errors relating to the type of interface.
    MasterTommy:
    In all drive modes, the engine braking effect is negligable, except for ECO Mode, when management engages neutral and the car rolls on forever.
    The effect is no different in Auto, TipTronic mode & or paddles, and left stick manual paddles only mode.
    VW Arteon 190 2.0L Tsi DSG7  (United Kingdom EU version)
    VIN: WVWZZZ3HZJE52xxxx
    Mileage: 20811km-12931mi
    Chassis Type  3H-VW48 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 4B 52 5F 6C 75
              A5 BB BC CA
    VIN: WVWZZZ3HZJE520740   Mileage: 20811km-12931miles
    4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
    BC-Door Rear Pass -- Status: Malfunction 0010
    CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
    Address 01: Engine (J623-CZPB)       Labels:. 06L-907-115-V1.clb
       Part No SW: 5NA 907 115 H    HW: 06L 907 309 B
       Component: R4 2.0l TFSI  H31 0002
       Revision: 1DH31000
       Coding: 012500122464050B34000000000000000000000000000000
       Shop #: WSC 05311 115 00304
       ASAM Dataset: EV_ECM20TFS0115NA907115H 001003
       ROD: EV_ECM20TFS0115NA907115H_VW48.rod
       VCID: 43831370CA48D657C4-8016
    14629 - Fuel Pump Control Module
              P025C 00 [032] - Short to Ground
    17156 - Databus
    17158 - Implausible Data Received from ESP Control Module
              U0416 00 [032] - -
    33226 - Please Check Fault Codes in Body Control / Central Electric Module
              U1021 00 [032] - -
       Part No SW: 0GC 300 040 P    HW: 0GC 927 711 G
       Component: GSG DQ381     H06 1401
       Revision: 00H06V07
       ASAM Dataset: EV_TCMDQ381061 001
       ROD: EV_TCMDQ381061_VW37.rod
       VCID: 316F49B860F454C726-8064
    33345 - No Communication With Transmission Fluid Pump
              U0287 00 [047] - -
                        Mileage: 10054 km
                        Date: 2018.12.17
                        Time: 17:26:04
                        Coolant temperature: 71 °C
                        Clutch: primary stat: New
                        selected gear: GANG_R
                        Driving position: P
                        Engine torque: -20 Nm
                        Control Module temperature: 60 °C
                        Accelerator position: 14.5 %
                        DTC memory status: 286
       Part No SW: 5Q0 614 517 CR    HW: 5Q0 614 517 AD
       Component: ESC           H25 0523
       Revision: 00000000    Serial number: 60548000000804
       Coding: 0DEC92943422236C477E060460C349B0492CC4E2600692713842F078C229420B00000012121212B835351919323200
       Shop #: WSC 00015 115 08193
       VCID: 0303D3708AC8165784-8056
       Part No SW: 3Q0 959 435 F    HW: 3Q0 959 435 F
       Component: VWKESSYMQB    027 0907
       Revision: 00027000    Serial number: 0472444313
       Coding: 102F0F0723
       VCID: 3D776588ACACA0A7B2-8068
       Part No SW: 5G0 907 044 DP    HW: 5G0 907 044 DP
       Component: Climatronic   H04 2001
       Revision: 00001K10
       Coding: 1412001420011001111500000010182A
       ASAM Dataset: EV_ACClimaBHBVW37X 006146
       VCID: 78F9B49CC30E458FA1-802C
       Part No SW: 5Q0 937 086 BM    HW: 5Q0 937 086 BH
       Component: BCM PQ37BOSCH 034 0245
       Revision: --------    Serial number: 865831011801HK
       ROD: EV_BCMBOSCH_018.rod
       VCID: 0605CA64B9FA237FA3-8052
       Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS    180117  043 0607
       Serial number:         180127063925
       Component: RLHS  047 0105
       Serial number: SAY18M02D27H21M36S56
       Coding: 00A8DD
       Light switch:
       Subsystem 3 - Part No SW: 3G8 941 633     HW: 3G8 941 633
       Serial number: 22 08 2017  10001396
       Serial number: 000000000ZY180080HTU
       Subsystem 5 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
       Component: Sirene, DWA  004 0006
       Serial number: 00000000000000055879
       Ceiling Light Module:
       Subsystem 6 - Part No SW: 3G0 947 105 D    HW: 3G0 947 105 D
       Component: J528 Dachelek  H08 0009
       Serial number: 18021900010190D
       Coding: F38380
       Serial number: 000308418018043
       Coding: 0471151811
       Shop #: WSC 05311 115 00068
       VCID: 4B933B50E2181E173C-801E
       Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
       Component: ACC BOSCH MQB H10 0654
       Coding: 32017FC259FFC728949C812481400600000000000000000000
       ASAM Dataset: EV_ACCBOSCHVW416 002006
       ROD: EV_ACCBOSCHVW416_002_VW48.rod
       VCID: 3E756284A1AABBBFAB-806A
       Part No SW: 3Q0 959 655 BK    HW: 3Q0 959 655 BK
       Component: Airbag VW21   006 0703
       Revision: --------    Serial number: 003W6P3QQPV5
       Coding: 98FCC0C00C0000005C5400CF008840000065
       Shop #: WSC 05311 000 08193
       ROD: EV_AirbaVW21TS6VW48X.rod
       VCID: 0819C45CB3EE350FD1-805C
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1032
       Serial number: 3G8857705B0037S01309
       Coding: 80000D
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1032
       Serial number: 3G8857706B0037S01742
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 454 001 402 18
       Serial number: 357000000001678D1C2M
       Subsystem 4 - Part No SW: -----------    HW: 454 001 402 18
       Serial number: 35800000000AC89C6D22
       Subsystem 5 - Part No SW: -----------    HW: 454 801 702 18
       Serial number: 35100A06EB613000000H
       Subsystem 6 - Part No SW: -----------    HW: 454 801 702 18
       Serial number: 3520092E0BC13000000J
       Subsystem 7 - Part No SW: -----------    HW: 454 801 202 18
       Serial number: 3550084D02D13000000E
       Pedestrian Protection Driver:
       Subsystem 8 - Part No SW: -----------    HW: 454 801 902 18
       Component: PedP_Sensor_D  304 0149
       Serial number: 22800E3758313000000D
       Subsystem 9 - Part No SW: -----------    HW: 454 801 702 18
       Component: PedP_Sensor_P  304 0149
       Serial number: 22900B9C98913000000W
       Pedestrian Protection Center:
       Subsystem 10 - Part No SW: -----------    HW: 454 801 702 18
       Component: PedP_Sensor_C  304 0149
       Serial number: 23000B9CD8913000000S
       Subsystem 11 - Part No SW: -----------    HW: 454 001 101 18
       Component: PedP_Sens_D_2  008 0887
       Serial number: I0M0000000027A24D923
       Subsystem 12 - Part No SW: -----------    HW: 454 001 101 18
       Component: PedP_Sens_P_2  008 0887
       Serial number: I0N00000000F8B24D92J
       Part No SW: 5Q0 953 521 AH    HW: 5Q0 953 569 A
       Revision: FF033033    Serial number: 20180227201435
       Coding: 0810
       ASAM Dataset: EV_SMLSVALEOMQB 001016
       ROD: EV_SMLSVALEOMQB.rod
       Part No SW: 3G0 920 791 C    HW: 3G0 920 791 C
       Component: KOMBI         407 3195
       Coding: 27A4111B6F84060001806B031001000800000000
       VCID: 295FA1D848242C07EE-807C
       Component: GW MQB High   518 5323
       Serial number: 15021810800879
       Coding: 030300047F085900FB00025E1C0F00010001070000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 3879749C838E858F61-806C
       Serial number: 29180000390230078081
       Coding: 2DFFFF
       Serial number: 7588600000180212020B
       Analog clock:
       Component: Analoguhr  209 2002
    197169 - Controls in Steering Wheel
              U108E 00 [008] - No Communications
                        Reset counter: 145
                        Mileage: 19746 km
                        Date: 2019.07.14
                        Time: 13:18:27
                        Supply voltage: Terminal 30: 12.2 V
                        Terminal 15: OFF
       Part No SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
       Component: ELV-MQBB      H05 0020
       Serial number: 18000035497009
       Coding: 0800000000000000
       ROD: EV_ELVMarqMQBA0_VW37.rod
       VCID: 336343B09AE866D754-8066
       Serial number: 0000305727016
       Coding: 003F4A02D001028000001000
       VCID: 479B0760FE70FA7718-8012
       Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
       Component: EPS_MQB_ZFLS  507 5081
       Coding: 91170000
       Shop #: WSC 00015 115 00304
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 3B736B90B2B8AE978C-806E
    Address 4B: Multifunc. Module
    Interface not compatible.
       Serial number: 0000304306849
       Coding: 003F4002DE01028000001000
       VCID: 46850A64F97AE37FE3-8012
       Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
       Component: MU-S-ND-ER    851 0867
       Coding: 02840301FF00000051110101008808001F0506E6012000008E
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 326D46B465F26FDF5F-8066
       Component: ABT_Std-2_Nav  H50 8130
       Serial number: VWZ6ZHV0310774
       Subsystem 2 - Part No SW: 5NA 919 866 R    HW: -----------
       Component: ECE AS 19/20  --- 1115
       Coding: 0184030162002017000040
       VCID: 397F7198B8849C879E-806C
       Part No SW: 5NA 035 284 B    HW: 5NA 035 284 B
       Component: OCULowMQBLGE  H17 0718
       Revision: --------
       Coding: 02840301EA42380D3F1CBE000045400382E608
       ASAM Dataset: EV_OCULowMQBLGE 004044
       ROD: EV_OCULowMQBLGE_004_VW25.rod
       VCID: 3C71688CB7B6A9AF85-8068
       Part No SW: 3Q0 980 654 J    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H07 0273
       Serial number: 27011812P10598
       Coding: 0004080400000401000213448150A90094000E300040
    1275 - Unknown Error Code
              B182E F0 [008] - Unknown Error Elaboration
                        Reset counter: 89
                        Mileage: 17532 km
                        Date: 2019.07.01
                        Time: 16:22:51
                        Control Module temperature: 47 °C
                        Outside air temperature: 25.0 °C
                        Vehicle speed: 39.03 km/h
                        System run time: 3920.4 s
                        Voltage terminal 15: 12.5 V
                        mid: 01 63
                        Status of camera: operational
                        Engine_Running_Info: 1
                        Software_Info_4: 3
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
       Part No SW: 5Q4 959 595 E    HW: 5Q4 959 595 B
       Component: TSG HFS       012 0032
       Serial number: 0000305632591
       Coding: 000A40020101028000001000
       ASAM Dataset: EV_DCURearDriveMAXCONT 006001
       VCID: 499F0158E8640C070E-801C
       Component: TSG HBFS      012 0032
       Serial number: 0000305632590
       ASAM Dataset: EV_DCURearPasseMAXCONT 006001
    65605 - Switch for Interior Door Handle
              B132E 29 [008] - Signal Implausible
                        Mileage: 14292 km
                        Date: 2019.05.12
                        Time: 12:45:11
    65637 - Switch for Exterior Door Handle
              B132F 29 [008] - Signal Implausible
                        Mileage: 14292 km
                        Date: 2019.05.12
                        Time: 12:45:11
    Address CA: Sunroof
    End-------------------------(Elapsed Time: 06:01)--------------------------
    2018 Arteon 190 R-Line 2.0 TSi + Discover Media Gen2,
    2011 Passat Mk7 2.0 TDI,
    2009 Golf 1.4 TSI,
    2004 Honda CBR1100XX,
    1949 Austin A16
    I don't see anything in the documented channels or coding bits that would influence "compression braking".
    Engine has four fault codes, but the ones that might be relevant are all "Intermittent - Not Confirmed" and haven't been reported to the Gateway.
    However, the fault in the Transmission, U0287 is "Confirmed", not flagged Intermittent, and reported to the Gateway. I wonder whether this has any effect on what you're experiencing?
    Have you tried clearing fault codes to see if that changes anything?
    New User
    Feb 2019
    I did not think this was worthy of attention considering the date (2018.12) and location of the vehicle (Parked position, 0 mph, 0 rpm).
    Probably a conflict of shutdown processes at a time when the vehicle is normally in my garage..
    Does this now draw a blank on engine compression braking issues?
    U0287 00 [047] - -
    Mileage: 10054 km
    Date: 2018.12.17
    Time: 17:26:04
    Driving position: P
    2009 Golf 1.4 TSI,
    1949 Austin A16
    Quote Originally Posted by Midori View Post
    What's annoying is that your TCU isn't giving a Fault Frequency with that code, so we don't know how often it has occurred since the freeze frame data was written on the first occurrence. But since it's not flagged "Intermittent", it seems to me that it likely occurs regularly.
    Sometimes the presence of fault codes has strange effects. Like I said, I suggest clearing it to see what happens.
    Other than that, I don't have any ideas, but I don't claim to know everything.
  9. #8
    New User
    Feb 2019
    I cleared the code, toggled the ignition on and off, rescanned a couole of times with engine off and at tickover.
    Here is today's the scan with engine running.
       Revision: 00H06V07
              U0287 00 [047] - -
                        Mileage: 20811 km
                        Date: 2019.08.11
                        Time: 12:14:10
                        Coolant temperature: 19 °C    <<<<---this looks right for cold overnight in garage at tickover. -?
                        Driving position: P
                        Engine torque: -40 Nm
                        Control Module temperature: 21 °C <<<<-------- ?
    For ease of comparison, here is a copy of the originally posted scan. There seems an strange difference on coolant and module temperatures. (but would have to buy new interface to re-confirm.
    U0287 00 [047] - -
    Mileage: 10054 km
    Date: 2018.12.17
    Time: 17:26:04
    Coolant temperature: 71 °C     <<<< --cold overinght engine not running  --?
    Driving position: P
    Control Module temperature: 60 °C  <<<< -------------------?
    Strange that
    2009 Golf 1.4 TSI,
    1949 Austin A16
  10. Likes Uwe liked this post
  11. #9
    Well since it comes right back with the current date, I'd say that's definitely a problem.
    But I do not know whether it's related to your lack of compression braking.
    As for the module and fluid temperatures, I'm not surprised they're close in both sets of data. I believe this is one of those transmissions that uses a "Mechatronic" module that's bolted right to the transmission itself.
  12. #10
    New User
    Feb 2019
    Ok, thanks for helping. I conclude the Arteon is NOT the vehicle to buy !
    2009 Golf 1.4 TSI,
    1949 Austin A16
