Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: P0193 fuel pressure sensor Mk6 TDI
    Aug 2019
    Canada
    I bough VCDS to try and solve my issue that even volkswagen cannot figure out. It's been to a vw shop three times without success in finding a fix.
    Issue: code P0193 consistently pops up on my dash with engine light and blinking glow plug light. The car is in limp mode most of the time now. It started off on the hwy about 2 months ago went into limp mode, restarting the car would get rid of the issue, but slowly the issue got worse and worse. I've been through about 10 tanks of diesel since the issue has started. The VW shop replaced a torn seal on the pump and the fuel pressure valve with no improvement. I replaced the fuel pressure sensor with OEM replacement, after doing this the car drove great for one day then the issue came back again in full force.
    All wiring has been checked in the fuel system to the ECU without any cause for concern, no crimped fuel lines either. There is NO metal shavings anywhere in the fuel system and it has a brand new fuel filter, this is first thing I tried.
    Now i'm at the point that the only thing left to change out is the high pressure fuel pump.
    Fuel pressure at idle - 350 bar.
    Here's my log from running vcds.
    If anyone has any insight on this i'd greatly appreciate input. I called IDparts about a new high pressure fuel pump and they said it should be covered under VW warranty, but I called vw and there is no warranty for this that I was told, my car did have extended warranty up to 197,000km but it's over that now, of course.
    Wednesday,07,August,2019,20:35:26:04508
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64(Parallels)
    VCDS Version 19.6.1.0 (x64)  HEX-V2 CB: 0.4508.4
    VIN: 3VWPL8AJ4BM649339   License Plate:
    Mileage: 218090km-135514mi   Repair Order:
    Chassis Type: AJ-VW36 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 56 62 72
              77
    VIN: 3VWPL8AJ4BM649339   Mileage: 218090km-135514miles
    77-Telephone -- Status: Sporadic communication error 1000
    Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 997 030 B    HW: 03L 906 019 DA
       Component: R4 2.0l TDI G000AG  9983
       Revision: 12H13---    Serial number:
       Coding: 0050078
       Shop #: WSC 55306 001 1048576
       VCID: 2D0709F0511027AF51F-8079
    000403 - Fuel Pressure Sensor (G247)
                   P0193 - 000 - Short to Plus - MIL ON
                        Fault Status: 11100000
                        Mileage: 218098 km
                        Date: 2013.12.28
                        Time: 20:28:58
                        RPM: 828 /min
                        Voltage: 13.45 V
                        Inj. Quantity: 8.8 mg/str
                        Temperature: 40.5∞C
                        Temperature: 58.5∞C
                        Temperature: 39.6∞C
    Readiness: 0 0 0 1 1
       Part No SW: 02E 300 052 G    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 9136
       Revision: 05151112    Serial number: 00001009081821
       VCID: 1869C824CE92B207129-804D
       Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
       Component: ESP MK60EC1   H31 0108
       Revision: 00H31001
       Coding: 114B600C49260003880E06E792220042310000
       VCID: 76B5E69CE8C62477E05-8023
       Part No SW: 3C8 907 336 AC    HW: 3C8 907 336 AC
       Component: Climatic      H14 0305
       Revision: 00009001
       Coding: 0000000002
       Shop #: WSC 00066 000 00147
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 6E85CEFC90161CB7285-803B
       Part No SW: 5K0 937 086 H    HW: 5K0 937 086 H
       Component: BCM PQ35 M    011 1035
       Revision: BJ011001
       Coding: 2D380E1F902F3EC4008800816000054401000086535D8560648020000040
       VCID: 392F2DA099588B0FCD7-806D
       Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer 17111  21  0512
       Coding: 009795
       Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
       Component: AirbagVW10G   021 0706
       Serial number: 003C4R01428I
       Coding: 00003047
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 392F2DA099D88B0FCD7-806D
       Subsystem 1 - Part No SW: 1KM 955 557     HW: 1KM 955 557
       Serial number: 3572MSME37504558ZZZU
       Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
       Serial number: 3582MSME32094658ZZZV
       Serial number: 3511HSME05523C24ZZZE
       Serial number: 3521HSME1B1E3C24ZZZU
       Serial number: 35527SME61014B23ZZZ4
       Serial number: 35627SME7A264B23ZZZM
       Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
       Component: Lenks.Modul   007 0080
       Revision: --------    Serial number:  90440JJB00015
       Coding: 188A140000
       Shop #: WSC 00066 000 00158
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 76B5E69CE8462477E05-8023
       Component: E221__MFL-TAS  H07 0013
       Serial number: 0080912
       Coding: 820000
       Part No SW: 5K0 920 871 A    HW: 5K0 920 871 A
       Component: KOMBI         H23 0204
       Revision: X0023007    Serial number:
       Coding: 370F00
       ASAM Dataset: EV_KombiUDSMM9RM10 A04203
       ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
       VCID: 2C0104F4668A2EA7461-8079
    Address 19: CAN Gateway        Labels:. 7N0-907-530-V1.clb
       Part No SW: 7N0 907 530 A    HW: 1K0 907 951
       Component: J533  Gateway   H25 5603
       Revision:   H25       Serial number: 12111001201192
       Coding: ED807F0600161300002002
       VCID: 2E050EFC5C165CB7685-807B
                        Fault Status: 00110100
                        Fault Frequency: 12
                        Reset counter: 57
                        Mileage: 217963 km
                        Date: 2013.12.17
                        Time: 17:13:45
       Part No SW: 5N0 919 879     HW: 5N0 919 879
       Component: Kompass         001 0001
       Revision: 00001000    Serial number: 1225223RAG1W06
       VCID: 7EA5FEBCCCF66C37B85-802B
       Part No SW: 5K0 953 234     HW: 5K0 920 871 A
       Component: IMMO          H23 0204
       ASAM Dataset: EV_ImmoUDSMM9RM10 A01200
       ROD: EV_ImmoUDSMM9RM10_VW12.rod
       VCID: 6A8DC2ECACFEF09774D-803F
    10485760 - Internal Control Module Memory Check Sum Error
              B2000 00 [008] - -
                        Mileage: 146390 km
                        Date: 2017.11.11
                        Time: 18:48:42
       Revision: A1001003    Serial number: 7668338880
       VCID: 270BFBD87FEC0DFFAB3-8073
       Part No SW: 3C0 959 701 B    HW: 3C0 959 793
       Component: TUER-SG FT    002 0307
       Revision: 13101005    Serial number: 0001501406
       Coding: 0004B5
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_DCU42BroseDriveSide A03004
       ROD: EV_DCU42BroseDriveSide_VW36.rod
       VCID: 270BFBD87F6C0DFFAB3-8073
       Slave Driver:
       Subsystem 1 - Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  006 1401
       Serial number: 00000005193646
       Coding: 000490
              B11EC 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 50
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 70     3001
       Revision: 00H17000
       VCID: 313F15804D28434F757-8065
    00750 - Warning Lamp
                        Fault Status: 00101101
                        Reset counter: 40
                        Voltage: 10.50 V
                            DD
                        Temperature: 21.0∞C
                        RPM: 31 /min
       Component: EZE_2         H25 5603
       Coding: 050B0500
       VCID: 6FBBD3F8979C15BF233-803B
    02071 - Local Databus
                        Fault Status: 00101100
                        Fault Frequency: 65
                        Reset counter: 60
                        Mileage: 169204 km
                        Date: 2012.09.22
                        Time: 15:04:17
       Part No SW: 3C0 959 702 B    HW: 3C0 959 792
       Component: TUER-SG BT    002 0307
       Revision: 15101005    Serial number: 0001466878
       Coding: 0004B4
       ASAM Dataset: EV_DCU52BrosePasseSide A03004
       ROD: EV_DCU52BrosePasseSide_VW32.rod
       VCID: 2809F8E472720287A29-807D
       Slave Passenger:
       Subsystem 1 - Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  006 1401
       Serial number: 00000005192433
       Coding: 000490
                        Reset counter: 54
    67589 - Turn Signal in Exterior Mirror
              B11FD 01 [008] - Electrical Failure
                        Fault Frequency: 15
                        Reset counter: 50
                        Mileage: 217826 km
                        Date: 2019.07.01
                        Time: 12:19:11
       Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
       Component: Radio Prem-8  H13 0043
       Revision: -----26S    Serial number: VWZ4Z7K3126846
       Coding: 2100040004
       VCID: 619FA5C05148B3CFA57-8035
                        Reset counter: 18
                        Mileage: 190189 km
                        Date: 2013.04.07
                        Time: 10:31:02
                        Fault Frequency: 12
                        Reset counter: 57
                        Mileage: 217963 km
                        Date: 2013.12.17
                        Time: 17:13:39
       Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
       Component: TELEFON       H05 0440
       Revision: 1B001001    Serial number: 00007668517367
       Coding: 0A00000000010100
       ASAM Dataset: UHVNA A01007
       ROD: UHVNA.rod
       VCID: 323D1A8C44AE78570CD-8067
    End----------(Elapsed Time: 01:24, VBatt start/end: 13.8V/13.7V)-----------
    Well, the ECU thinks this is an electrical problem with the fuel pressure sensor, or the associated wiring, so...
    Do you have wiring diagrams?
    How many pins/wires to that sensor? Where do they go?
  3. Likes NZDubNurd, Jack@European_Parts liked this post
    Nov 2014
    New Zealand
    Quote Originally Posted by dzubot View Post
    It's not unusual for Dealers to be as useful as a chocolate teapot!
    Jack will be along soon, to ask if you have overlayed wires to rule them out as an issue. Static testing doesn't always help, as the engine is usually off and the wires aren't moving.
    It's obviously somewhat intermittent: On the MK5 Golf TDI's there are a number of wires that break where they come off the chassis rail, across to the engine; front left corner in front of/under the battery. If this has happened, it probably only needs to have a very short period of one wire touching another where they're damaged, and the code would set and stay (along with limp mode) until the next engine start.
    Allan
    The R32ran Thread
    How to post a full Auto-Scan
  6. #4
    Aug 2019
    Canada
    I took the car to a local Volkswagen shop not a dealer. They checked all wiring going to ecu from this sensor and ran engine and shook it all and could not replicate the issue. The car now refuses to start normally, in limp mode even before it starts. Iíve tried clearing the code and disconnecting the battery to reset but it still comes on instantly. This issue progressively got worse and worse. It started off doing it only maybe once a week then got worse and worse now to the point where itís only in limp mode. After I changed the fuel pressure sensor the car ran perfect for one full day then the next day while just cruising on the Hwy it came back on and now is on constantly again. Same p0193 code.
    I donít have any wiring diagrams. Thereís three wires going to the sensor along the rail. The shop I took it to check the entire length of wire going to the ecu but could not find any issues with the wiring Iíve briefly checked the wiring and cannot visually see any issues. Itís possible they missed it. Iíll look at wiring near the battery thanks for suggestion
    Is it possible there is an issue with the hpfp? No metal shavings found anywhere but Iíve read there are cases where it can fail and not shed metal. Iíve ran fuel injector cleaner many times now since the issue started, changed the fuel filter again yesterday with no change.
    Aug 2019
    Canada
    I just tried moving around the two big bundle of wires that are behind the battery going towards the ecu under the plastic panel near the wiper blades and after resetting the engine codes I got it off of limp mode. But itís showing many different codes now. Codes pending are p1007, p1006, p1005, p1004, and permanent code of p0193. It also showed p1091 for brief time under pending but now gone.
    Nov 2014
    New Zealand
    Post the scan with the codes showing.
    If moving wires gives you codes... there's something going on! If the previous workshop tested the wiring, but didn't discover wiggling the wires creates many codes... do you really trust they tested the wiring properly? Is the loom even plugged into the ECU properly?
    The normal break point is nearer to the radiator fans where they cross to the engine - on my cars, it's towards the front of the trans, but up higher - sort of near the starter motor, but I don't know if you car has the same trans/starter layout as mine do.
    It shouldn't be related to the HPFP, because the initial code you posted about is an electrical fault code, not a result of a pressure problem. It appears to be complaining that instead of seeing a signal related to/varied by fuel pressure, it's seeing 12V on that feed (short to plus). My first suspects are a wiring fault (because it's internittant and gotten worse) or an ECU fault. Each possibility needs to be eliminated as the fault source somehow.
    You'll still need a wiring diagram to do it. Either bypass the the existing wiring, or disconnect it entirely at the ECU end, and see if a different code comes up. The components need to be isolated or bypassed methodically to determine which one is the cause. It could be the wiring, ECU or sensor. The ECU might even have water damage.
    Allan
    The R32ran Thread
  9. Likes Uwe, Jack@European_Parts liked this post
  10. #7
    The problem most likely resides on this Good Ship, Lop of Shit, Lollypop & at where the harness gets cut by the edge of the cylinder head by chafe resonance point & literally right next to oil filter top, RIGHT?
  11. Likes NZDubNurd liked this post
  12. #8
    Aug 2019
    Canada
    These new codes only came up in the pending area of my cheap obd reader I had plugged in at the time. I did move the wires around near the sensor, and all along where the fuel pressure sensor wires go, down the engine near the oil filter canister so itís possible it was somewhere else that I moved the wires to cause these other codes to pop up. Iíve tried to replicate this again a few times now but cannot get the car to register different codes or get rid of the p0193. It is the one code that does not go away ever. It shouldnít be the sensor as I replaced it with brand new oem one this week. The car was driving very poorly before I changed the sensor, it would be super jerky and stall randomly. After changing the sensor the car ran perfect for one day, then back into limp mode but itís not driving horrible like it was before I changed the sensor. I was able to get it into normal driving for short period today by clearing the code several times and it drove great for about 30 min. The new sensor definitely improved how the car is running but not the p0193 issue.
    Iíll look into the wiring near the transmission area thanks! Will clean the battery ground cable connections also but they look clean. So if I take multimeter to the fuel pressure sensor plug and see 12v this is not good? What should the voltage be 5v?
  13. #9
    Don't you think you should unwrap engine harness and verify the entire thing to find break, than repair and re-tape and add spiral wrap in areas needed?
    Isn't this repair covered by extended warranty and useful life warranties expressed as imported or already litigated by the US & Canadian Government?
    Did you ask for guidance from Canada EPA on this matter?
    Did you try to prove the problem by vacating the DTC using a decade box with engine harness side unplugged at the ECU directly or changing condition of DTC, using RTFB and WD?
    Stop crying and do some work.....
  14. #10
    Have you attempted to clear codes in OBD2 0x33 Mode 04 versus in VAG mode 0x01-02 ?
