Results 1 to 4 of 4
Thread: SKODA MY16 Autoscan Unsupported Vehicle
    Jul 2018
    Hi
    I have run an autoscan of my new car as below,
    However when went into to individual modules I cannot carry out any adaptions as it shows a popup saying "unsupported Vehicle".
    As the auto scan ran, and read module coding for most of them, I was under the presumption I would be able to communicate with the modules even though I still have Hex-CAN-USB. I am keen to carry out some mods on 09 and
    I presume I do now need to upgrade to HEX-V2?
    Thank you ROSS-Tech Team for supporting my Hex-Can for so long
    Wednesday,31,July,2019,20:44:22:37649
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
    VCDS Version: 19.6.0.2
    VIN: TMBKJ7NE9G0180866   License Plate:
    Chassis Type: NE-SK37 (5Q0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 20 42 44 52 5F 69
    VIN: TMBKJ7NE9G0180866   Mileage: 78598km-48838miles
    Address 01: Engine (J623-CRMB)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 BP    HW: 04L 907 309 R
       Component: R4 2,0L EDC   H22 1198
       Revision: B5H22---
       Coding: 011D0012033501090000
       Shop #: WSC 73430 031 12345
       ASAM Dataset: EV_ECM20TDI01104L906026BP 002002
       ROD: EV_ECM20TDI01104L906026BP_002.rod
       VCID: 79F2792CF84A4387D6-802C
       Part No SW: 0D9 300 041 H    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4902
       Revision: 06253104    Serial number: TFK01512160545
       Shop #: WSC 73430 031 00063
       ROD: EV_TCMDQ250021.rod
       VCID: 1D3A4DBC0C22DFA79A-8048
    10657 - RPM Signal from ECU
              P0726 00 [002] - Implausible Signal
              P1734 00 [002] - -
       Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
       Component: ESC           H32 0393
       Revision: 00000000    Serial number: 60126000000356
       Coding: 1C078A912428096C007F060641C9243851249000608224F210610070C002
       ROD: EV_Brake1UDSContiMK100ESP_034_SK37.rod
       VCID: 4B9EF3E4E256011734-801E
    16401 - Tire Pressure Warning
              C102D 00 [008] - -
                        Reset counter: 162
                        Mileage: 41798 km
                        Date: 2017.12.11
                        Time: 17:11:31
       Part No SW: 5E0 907 044 Q    HW: 5E0 907 044 Q
       Component: Climatronic   H04 1002
       Revision: 00001K07
       Coding: 02110104002100011005000000101000
       Shop #: WSC 73430 031 00000
       VCID: 336E8B049AA679D75C-8066
              P1719 00 [008] - -
                        Reset counter: 166
                        Mileage: 78455 km
                        Date: 2019.05.02
                        Time: 13:50:28
                        Voltage terminal 30: 14.1 V
                        Auxiliary heater: in stages-Act.val.: 1
       Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
       Revision: --------    Serial number: 86580501162422
       Coding: 0F021942424702FB07A04082B10C07280000000000000000000000000000
       Shop #: WSC 73430 790 12345
       ROD: EV_BCMBOSCH_015.rod
       VCID: 030E1BC48A8609578C-8056
       Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS371 151205  041 0570
       Serial number:         151217072526
       Coding: 065DDD
       Component: RLHS  037 0059
       Serial number: S2Y16M01D15H15M53S49
       Coding: 00885D
       Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
       Serial number: 000000000ZY152720D5A
       Serial number: 00000000000064582722
    7 Faults Found:
    550677 - Databus
    787212 - Windshield Washer Pump
              B1261 01 [008] - Electrical Failure
    139528 - Control Relay for Terminal 15 Load
              B12E6 11 [008] - Short to Ground
    204290 - Remote key 1
              B1479 18 [009] - Current Too Low
                        Reset counter: 0
                        Mileage: 76675 km
                        Date: 2019.03.13
                        Time: 09:03:35
    204546 - Remote key 2
              B147A 18 [008] - Current Too Low
    197384 - Lock Module for Central Locking; Rear Right
              B12DC 29 [008] - Signal Implausible
    262664 - Switch for Interior Monitoring / Inclination Sensor
              B131B 29 [008] - Signal Implausible
       Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0048
       Revision: --------    Serial number: 39331528005160
       Coding: 0001050111
       VCID: 3D7AAD3CACE2BFA7BA-8068
    12658704 - Databus
                        Reset counter: 48
                        Mileage: 2651 km
                        Date: 2016.05.06
                        Time: 10:48:10
       Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
       Component: ACC Bosch MQB H05 0400
       Serial number: 15121503212430
       Coding: 00001200FE0339
       ASAM Dataset: EV_ACCMRRBoschVW372 001016
       VCID: 3A70A620BDCC889F9F-806E
       Part No SW: 3Q0 959 655 AS    HW: 3Q0 959 655 AS
       Component: Airbag VW20   013 0200
       Revision: --------    Serial number: 003SQPRXM585
       Coding: 98CCC000000000005C5400CC008800000065
       Shop #: WSC 73430 790 00000
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 0F2627F4D6CE7D3718-805A
       Subsystem 1 - Part No SW: -----------    HW: 454 001 912 15
       Serial number: 3576U000000DE435981M
       Subsystem 2 - Part No SW: -----------    HW: 454 000 801 16
       Serial number: 3586U000000477702812
       Subsystem 3 - Part No SW: -----------    HW: 454 802 212 15
       Serial number: 3516R7F1D7709000000F
       Subsystem 4 - Part No SW: -----------    HW: 454 802 012 15
       Serial number: 3526R1CEE7709000000L
       Subsystem 5 - Part No SW: -----------    HW: 454 801 610 15
       Serial number: 3556V21A6E508000000A
       Part No SW: 5Q0 953 507 GP    HW: 5Q0 953 549 E
       Component: Lenks. Modul  003 0120
       Revision: --------    Serial number: 17011604221223
       Coding: 1410
       ASAM Dataset: EV_SMLSKLOMQB 020001
       VCID: 0A1036E0ADAC581FCF-805E
       Part No SW: 5E0 920 951 B    HW: 5E0 920 951 B
       Component: KOMBI         324 6422
       Coding: 27A40A082180A60001886A011000000000000000
       VCID: 2648625059741C7FCB-8072
       Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1244
       Revision: --------    Serial number: 0004390483
       Coding: 030100045F087300EB0002481C0F00010001050000000000000000000000
       ROD: EV_GatewLear_013.rod
       Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
       Component: E221__MFL-PR6  H02 0150
       Serial number: 000000000C0451080116
       Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
       Component: J367-BDMConti  H02 1011
       Serial number: 74185704001601040686
    Address 20: High Beam Assist. (J844)       Labels:| 8X0-857-511.clb
       Part No SW: 5G0 857 511 D    HW: 5G0 857 511
       Component: FLA           H04 0002
       Revision: AA001001
       Coding: 01028F6B76765D525220343E01
       VCID: 2B5E93644296211714-807E
       Serial number: 0000182344540
       Coding: 00150020D001040000001100
       VCID: 4796CFD4FE3EE57710-8012
       Serial number: 00000000000008486742
       Coding: 1D0200
    589825 - Local Data Bus
              U10BA 00 [008] - No Communication
                        Mileage: 9568 km
                        Date: 2016.07.06
                        Time: 15:16:57
       Component: EPS_MQB_ZFLS  125 1063
       Coding: 8103
       VCID: 448CD8D8CF08CE6FF5-8010
       Serial number: 0000182824883
       VCID: 4688C2D0F934FC7FEB-8012
       Serial number: 00000000000008531217
       Coding: 050200
    Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
       Part No SW: 5Q0 035 874 A    HW: 5Q0 035 874 A
       Component: MU-S-ND-ER    H24 0245
       Serial number: SKZAZ2S8224209
       Coding: 03730201FF00000011111201008800002F0200C601200100C6
       Shop #: WSC 73430 790 00063
       ROD: EV_MUStd4CTSAT_VW41.rod
       VCID: 32608E0065BC70DF57-8066
       Subsystem 1 - Part No SW: 5E0 919 605 J    HW: 5E0 919 605 J
       Component: ABT_Std-2_Nav  H41 1028
       Serial number: SKZ8Z9SBT01JEK
       Subsystem 2 - Part No SW: 5L0 051 236 H    HW: -----------
       Component: ECE 2016  --- 0521
       Part No SW: 5Q0 907 383 J    HW: 5Q0 907 383 B
       Component: Anhaenger     H21 0203
       Revision: 8C001003    Serial number: 0387671170
       Coding: 0100000202000000
       VCID: 3E78AA30A1E4A4BFA3-806A
    136203 - Supply Voltage
              P1757 00 [009] - Open Circuit
                        Reset counter: 133
                        Mileage: 72165 km
                        Date: 2019.01.04
                        Time: 12:39:08
    End-------------------------(Elapsed Time: 05:06)--------------------------
    There's a reason that 19.6.0.2 isn't current anymore.
    Click here.
  3. Likes PetrolDave liked this post
    Jul 2018
    Uwe.
    Thank you, that worked.
    I've never seen this happen before on other cars I've had to see me for a few coding modifications. Is the typical behaviour now for latest versions.
    I really thought it was my modules weren't supported.
  5. Likes Uwe liked this post
  6. #4
    Quote Originally Posted by processpaul View Post
    Uwe.
    No, it was a bug in that particular version.
