Results 1 to 5 of 5
Thread: '10 Golf GTI Will not learn steering angle G85
    Jul 2019
    NC, USA
    I fitted this car with a new brake controller. Some of you may remember the post i created trying to code this module. However it was determined that module was wrong. So we got the CORRECT module from the dealer and coded it. Ive got all the basic settings performed but it will not take G85 Steering Angle sensor. Ive tried this relearn in module 44 and 03 multiple times with no success. As always the auto scan is attached. I did not put a module in this car for this issue.
    Thursday,08,August,2019,17:30:31:46456
    VCDS Version: 19.6.1.0 (x64)
    VIN: WVWHV7AJ7AW079881   License Plate:
    Chassis Type: AJ-VW36 (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 55 56 62 65
              72 77
    VIN: WVWHV7AJ7AW079881   Mileage: 198530km-123360miles
       Part No SW: 1K0 907 115 AM    HW: 1K0 907 115 AA
       Revision: AAH06---    Serial number:
       Coding: 0403010A1C070160
       VCID: 71E929F6681C62C766-8024
    Readiness: 0010 0101
       Part No SW: 02E 300 051 R    HW: 02E 927 770 AJ
       Component: GSG DSG AG6     440 1930
       Revision: 04844002    Serial number: 00000907180071
       VCID: 224B16BAFD7A895FAF-8076
       Part No SW: 1K0 907 379 BA    HW: 1K0 907 379 BA
       Component: ESP MK60EC1   H45 0109
       Revision: 00H45001
       Coding: 114B600CC9290003881306EC931A0041B108
       Shop #: WSC 00001 000 00000
       VCID: 72EB26FAAD1A59DF9F-8026
                        Fault Status: 01100101
                        Reset counter: 60
                        Mileage: 198535 km
                        Date: 2013.12.29
                        Time: 05:42:19
                        Count: 3
                        Count: 12
                        Count: 29184
                        Count: 295
                        Count: 48896
                        Count: 1
       Part No SW: 3C8 907 336 N    HW: 3C8 907 336 N
       Component: Climatic      H13 0203
       Revision: 00006001
       Coding: 0000000000
       ASAM Dataset: EV_Climatic A01001
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 387FD4D283E6F38F61-806C
    Address 09: Cent. Elect.
    Unable to communicate with address 09. Are you sure the doors are unlocked?
       Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
       Component: AirbagVW10G   019 0706
       Serial number: 003C4D073F0E
       Coding: 00003031
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3979D1D6B8ECEA879E-806C
       Subsystem 1 - Part No SW: 5K0 959 339     HW: 5K0 959 339
       Component: BF-Gewichtss.  007 0002
       Serial number: ---0000R--0004LACP00
       Component: S.Sens.Fahr.V  U01 ----
       Serial number: 3572MSME08037249ZZZQ
       Component: S.Sens.Beif.V  U01 ----
       Serial number: 3582MSME0E774149ZZZ/
       Serial number: 3512QSME283B3135ZZZR
       Serial number: 3522QSME14272F78ZZZ
       Serial number: 35527SME04111400ZZZU
       Serial number: 35627SME08211400ZZZ-
    9483008 - Seat Occupied Recognition
              B10B3 00 [008] - Function Restriction due to Implausible Message(s)
                        Fault Frequency: 11
                        Reset counter: 97
                        Mileage: 198526 km
                        Date: 2019.08.07
                        Time: 18:15:02
       Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
       Component: J0527           055 0111
       Coding: 0001632
       VCID: 76E31AEA017245FFB3-8022
       Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS   H05 0010
       Coding: 00000131
       Part No SW: 5K6 920 970 G    HW: 5K6 920 970 G
       Component: KOMBI         H05 0206
       Coding: 270F00
       Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
       Component: J533  Gateway   H07 0081
       Revision:   H07 01    Serial number: 080709F1002115
       Coding: ED817F07001612000002
       VCID: 66C34AAA51D2B57F03-8032
       Revision: 00001000    Serial number: 1225223T5VMZ04
       VCID: 7EF302CA29420DBFEB-802A
    Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
       Component: IMMO          H05 0206
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
       Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
       Revision: A1001003    Serial number: 7667511421
       VCID: 26430AAA5152757FC3-8072
       Component: Tuer-SG         009 2109
       Coding: 0001204
       VCID: 3169E9F6A89C22C726-8064
       Part No: 1K0 909 144 H
       Component: EPS_ZFLS Kl. 74     2901
       Revision: 00H17000
       VCID: 2F6DEF8EBEA8343730-807A
    Address 46: Central Conv.
       Coding: 0001204
       VCID: 326BE6FAAD9A19DF5F-8066
       Component: AFS-Steuergeraet    0142
       Coding: 1446940
       VCID: 3467E0E2578E17EF4D-8060
       Coding: 00000022
       Coding: 00000022
       Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
       Component: Radio Prem-8  H10 0034
       Revision: -----19S    Serial number: VWZ4Z7J1107953
       Coding: 0100040004
       VCID: 61C959B678FCD247F6-8034
                        Reset counter: 55
                        Mileage: 198526 km
                        Date: 2013.12.28
                        Time: 18:13:37
       Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
       Coding: 0001168
       Shop #: WSC 01357 011 1012552
    Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
       Part No SW: 1K0 937 087 G    HW: 1K0 937 087 G
       Component: RDK           103 0521
       Coding: 018705
       VCID: 3561DDE69CF40EE77A-8060
       Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
       Coding: 0001168
       VCID: 3561DDE65CF40EE77A-8060
    Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
       Part No SW: 1K8 035 730 C    HW: 1K8 035 730 C
       Component: Telefon       H08 6600
       Revision: 00008000    Serial number: 20389520180607
       Coding: 412100
       VCID: 29590196404C5A07EE-807C
    End-------------------------(Elapsed Time: 02:43)--------------------------
    Did you login the ABS controller with observation of caption code provided and commence the basic settings for G85 & road test?
  3. Likes DrPeter liked this post
    16.4905 S, 151.7375 W
    In addition to what Jack has mentioned, you may want to have a look at the Measuring Value Block group [007] in the [44-Steering Assist] controller.
    The following fields will be useful and should help to determine the "status" of the G85-Steering Angle sensor.
    MVB [007], field (1) = Steering Angle Sensor (G85)
    ---> This is the 'live' value of the G85 sensor in degrees and should reflect the movement of the steering wheel, the Range is: [-720.0...+720.0 ]
    MVB [007], field (2) = Steering Angle Speed
    ---> Speed at which the G85 sensor changes value
    MVB [007], field (3) = Calibration,Status (G85)
    ---> This is the 'status' of the G85 Sensor, Range is: [Yes] or [No]
    MVB [007] (4) = Initialization Status (G85)
    ---> This is the important one!! The G85 Sensor MUST be initialized before it can be calibrated!
    ---> Range is: [SteerAng Init] or [SteerAng n.Init]
    If the G85 sensor has not been initialized, you will need to change this status. You can typically do this by performing a slow (15-20mph) parking lot road test, then come to a complete stop and turn the steering wheel from one 'end-stop' to the other 'end-stop', hold at the stops for about 10-15 seconds. Then check the MVB group [007], field (4) to verify the [SteerAng Init] is displayed.
    Hope this helps,
    drpeter
  5. Likes Uwe, Jack@European_Parts liked this post
    Jul 2019
    NC, USA
    drpeter thank you sorry it had taken so long to get back. this vehicle has went to the back burner.
    Address 44: Steering Assist (1K0 909 144 H)
    11:01:19
    -1.49 Steering Angle Sensor (G85)
    0.0/s Steering Angle Speed
    calibrated Calibration Status (G85)
    SteerAng Init Initialization Status (G85)
    I went right into module 44 and veiwed the data. I did the parking lot test drive and field for changed to steerang init. The light went right off. Wow thank you for your help. i was missing one important step that i didn't know about.
    See this is why I say just go and do 0x44 first than 0x03 adaptions of G85
