News
autocomsoft
Czech Republic
C?ID=56999
8.8.2019
added more than one hundret diagnostic procedures for EDC17 UDS modules for example:
Automatic test procedure
Error message identification AdBlue SCR dashboard
Test - fuel pressure regulation vlave (N276)
Test - Coolant pump for EGR (V178)
Test - Dosing of the reducing agent SCR AdBlue
Test - system indicator light: glowing (K29)
Test - Lambda-sensor downstream of catalyst (G130)
Test - additive tank: SCR heating - AD-Blue (Z102)
Test - Change-over valve for the cooler of the exhaust gas recirculation (N345)
Test - small heat capacity relay (J359)
Test - large heat capacity relay (J360)
Test - Starter control (J906)
Test - Intake air mass sensor - test drive
Test - Level sensor: Reducing agent (G697)
Test - Intake air temperature sensor (G42)
Test - temperature sensor: Reducing agent AD-Blue (G685)
Test - fuel pressure - pressure sensor (G247)
Test - filling pressure control valve (N75)
Test - exhaust gas return valve 1 (GX5)
Test - injector 1-4 (N30;N31;N32;N33)
Test - SCR heating - AD-Blue (J891)
Test - SCR heating: Circuit 2 - AD-Blue (Z103;Z104))
Test - exhaust recirculation - potentiometer (G212)
Test - exhaust recirculation - servo engine (V338)
Test of radiator fan control unit (J293)
Test of heating (glow) unit (J179)
Measurement of compression pressure
Test of filling and atmospheric pressure sensor (G31)
Test of gas pedal position sensor 1;2 (G79); (G185)
Test of engine temperature sensor - outlet from radiator (G83)
Test of engine temperature sensor (G62)
Test of intake air temperature sensor (G42)
Test of fuel temperature sensor (G81)
Test of exhaust gases temperature sensor 1;3;4 (G235; G495;G648)
Test of pedal switches
Check of clogging level of Diesel particulate filter
Test of cruise control
Check the leakproofness of the lines AdBlue - SCR
Zero detection of SRC additive level - AdBlue
bleeding (deaeration) - Engine cooling
Bleeding of fuel system
Adaptation of DPF differential pressure sensor
Adaptation of injection valve after replacement
adaptation: oil presure pro engine run-in
adaptation: soot clogging DPF - If replaced: DPF
Reducing agent AD-Blue - status check
DPF regeneration - when vehicle is parked
reset - Use the SRC system to block the starter - AdBlue
Deletion of an error message SCR - AdBlue - dashboard
Start/stop - activation/deactivation
injector: corrective value - Test
Evacuation of fuel tank
Deletion of statistics memory - Start-stop
zeroing learning values - Adaptation of the mean quantity value
zeroing learning values - Lambda sensor(s)
zeroing learning values - Intake air mass sensor
zeroing learning values - turbo blower
zeroing learning values - cylinders: pressure sensor
zeroing learning values DPF - If replaced: DPF
zeroing learning values DPF - If replaced: engine control unit
zeroing learning values DPF - If replaced: engine control unit/DPF
zeroing learning values DPF - If replaced: pressure difference sensor (G505)
zeroing learning values: additive injection system
Emptying of the system AdBlue SCR
creation of Readiness
customer limitation of maximum speed
basic settings - exhaust gas flap
basic settings - Low-pressure exhaust gas return valve
basic settings - adaptation - Test: throttle valve
basic settings - Neutral gear sensor (G701)
basic settings - turbo blower
basic settings - exhaust gas return valve 1 (GX5)
More at diagnostic procedures for EDC17 UDS modules
Jan
