Results 1 to 10 of 16
Thread: 2008 Audi TT 3.2 AWD - P1545 and P1558 - Throttle Body
    Oct 2018
    Utah, USA
    We keep throwing these codes! Only happens when driving for a while (on freeway). We have replaced the throttle body THREE TIMES now, argh. We have replaced the connector plug, spliced in new wires, and new pins. All continuity to ECU and resistance values check out fine. Drives just fine for a few weeks then fails while driving. Letting the engine cool down will allow it to start and run again.
    What am I missing? Is the ECU prone to this type of failure (about the only thing I haven't replaced yet).
    Thanks,
    Kelly
    P.S. Log file:
                    Address 01: Engine       Labels: 022-906-032-BDB.lbl
    Control Module Part Number: 022 906 032 HG    HW: 022 906 032 GP
      Component and/or Version: TT-3.2-DQ-LEV2  G   0862
               Software Coding: 0000178
                Work Shop Code: WSC 01236 785 00200
                          VCID: 57FE8EECE6988BF2CC-8002
    005445 - Throttle Valve Controller
                   P1545 - 008 - Malfunction - Intermittent
                        Mileage: 192463 km
                        Date: 2019.04.21
                        Time: 15:53:27
                        RPM: 2513 /min
                        Load: 18.4 %
                        Speed: 101.0 km/h
                        Temperature: 73.0C
                        Temperature: 17.0C
                        Absolute Pres.: 850.0 mbar
                        Voltage: 14.097 V
    005464 - Throttle Actuator (G186)
                   P1558 - 002 - Electrical Malfunction - Intermittent
                        Mileage: 192464 km
                        Load: 100.0 %
                        Temperature: 72.0C
                        Temperature: 21.0C
                        Voltage: 9.652 V
    Readiness: 0010 0100
    Stop running FOD modified code and more DTC's will come up to guide you.
    Oct 2018
    Utah, USA
    What is FOD modified code? I don’t understand. I am using HEX-NET and the latest VCDS from Ross-Tech. Or are you suggesting that the ECU has been modified?!?
    Kelly
    I believe the ECU is modified!
    Oct 2018
    Utah, USA
    Hmmm. I have used modified ECU's before (urS6, RS6, VW GTI, etc.), but not on this car. I have not had good luck in my area with tunes like this because (theory) I live at higher altitude (5000 ft) and high summer time temperatures (100 F). They tend to crash at peak performance on pump gas.
    Unfortunately, this car was purchased for my son's daily driver, not a tuner. So...what was the hint that you think the ECU is modified? Can you tell/guess which one it is (GIAC, Unitronic, ???). I want to UNDO this, but we are not the ones that did it. How would I do this short of finding a new ECU?
    Indeed lets attempt to qualify FOD!
    Please clear all fault codes and post a new complete auto-scan after letting car idle for 30 seconds & with the addition of the OBD2 data Modes 0x33 MODE 01-01, 03, 7 & 9 saved to the scan folder.
  7. #7
    Oct 2018
    Utah, USA
    Here is the complete scan after clearing all codes and running an auto-scan after 30 seconds with the car idling:
    Friday,16,August,2019,13:25:18:38383
    VIN: TRUDD38J481002253   License Plate:
    Chassis Type: 8J (1K0)
    Scan: 01 02 03 08 09 0F 14 15 16 17 19 22 25 42 44 46 47 52 55 56
              65 76
    VIN: TRUDD38J481002253   Mileage: 197160km-122509miles
    0F-Digital Radio -- Status: Cannot be reached 1100
       Part No SW: 022 906 032 HG    HW: 022 906 032 GP
       Component: TT-3.2-DQ-LEV2  G   0862
       Revision: 1QH02---    Serial number: AUX7Z0G2FNG00D
       Coding: 0000178
       Shop #: WSC 01236 785 00200
       VCID: D7FE0EEC66980BF708-8082
       Part No SW: 02E 300 011 BL    HW: 02E 927 770 AD
       Component: GSG DSG         082 1396
       Revision: 05108020    Serial number: 00001005190451
       Shop #: WSC 04940 001 00001
       VCID: DAF817D8158A169F37-808E
    Address 03: ABS Brakes        Labels: 8J0-614-517.clb
       Part No SW: 8J0 614 517     HW: 8J0 614 517
       Component: ESP MK60E1          0130
       Revision: 00H52001
       Coding: 0026177
       VCID: EA984718C5EA861FA7-80BE
       Part No SW: 8J0 820 043 AA    HW: 8J0 820 043 AA
       Component: J255  Klima 1 Zone  0060
       Revision: 00H07003    Serial number: 00000001024006
       Coding: 1048614
       VCID: E58234242CF4A9678A-80B0
    Address 09: Cent. Elect.        Labels:. 8P0-907-279-23-H.lbl
       Part No SW: 8P0 907 279 H    HW: 8P0 907 279 H
       Component: Bordnetz-SG     H46 1802
       Revision: 00H46000    Serial number: 00000006810467
       Coding: F1041E83C0141C0003180000180000000028EE075A250802
       VCID: C2C8CFB89D1ABE5F4F-8096
       Subsystem 1 - Part No: 8J1 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer AU354   H05 0060
       Coding: 00064784
       Shop #: WSC 01236
       Coding: 00149804
       Shop #: WSC 01236
    Address 0F: Digital Radio
    Address 14: Susp. Elect.        Labels: 8P0-907-376.lbl
       Part No SW: 8J0 910 376     HW: 8J0 907 376 A
       Component: J250 Raddaempfung   0050
       Revision: --H16---    Serial number: 190DPH 7032349
       Coding: 0000012
       VCID: EC944100CF1E982FD5-80B8
    Address 15: Airbags        Labels: 8J0-959-655.lbl
       Part No SW: 8J0 959 655     HW: 8J0 959 655
       Component: -E Airbag 9.43  H02 0020
       Revision: 93H02002    Serial number: 0036K001056+
       Coding: 0011589
       VCID: F9BA6854B04C3D875E-80AC
       Subsystem 1 - Part No: 8J0 910 339 A
       Component: BF-Gewichtsens. H02 0030
       Subsystem 2 - Serial number: 007XR
       Subsystem 3 - Serial number: 0001.01.0000H0200000000000†63
       Subsystem 4 - Serial number: 000000†6332DRB40493049DP†63
       Subsystem 5 - Serial number: 3049DP†6342DRB404DA94A8%†63
       Subsystem 6 - Serial number: A94A8%†63747RB40177B2F0Q†63
       Subsystem 7 - Serial number: 7B2F0Q†63847RB40177B287R
       Subsystem 8 - Serial number: 7B287R
    Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
       Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
       Component: J0527           H36 0070
       Coding: 0014141
       VCID: C1CAC0B4981CA54756-8094
       Component: E0221           H06 0030
    01301 - Control Module for Voice Recognition (J507)
    Address 17: Instruments        Labels: 8J0-920-xxx-17-MY7.lbl
       Part No SW: 8J0 920 990 C    HW: 8J0 920 990 C
       Component: KOMBIINSTR. VDO H21 0070
       Revision: D0H21004    Serial number: 2242G004002861
       Coding: 0113208
       Shop #: WSC 58755 067 57207
       VCID: B2289F782DBA0EDFDF-80E6
       Part No SW: 1K0 907 530 K    HW: 1K0 907 951
       Component: J533__Gateway   H12 0170
       Revision:   H12       Serial number: 33001073070850
       Coding: FF8F076227004100
       VCID: AF2E960C3E882337B0-80FA
    02649 - Digital Radio Tuner
                        Reset counter: 88
                        Mileage: 197163 km
                        Date: 2019.08.16
                        Time: 13:21:56
    Address 22: AWD        Labels: 1K0-907-554.lbl
       Part No: 1K0 907 554 L
       Component: Haldex 4Motion      0116
       VCID: B620A368C1D212FFF3-80E2
       Revision: D0H21004    Serial number: AUX7Z0G2FNG00D
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX1.lbl
       Part No: 8J8 959 801 C
       Component: Tuer-SG         H02 0060
       Coding: 0001077
       VCID: BD32BC44E4E4C1A732-80E8
       Part No: 8J1 909 143 B
       Component: EPS_ZFLS Kl.155 H07 1807
    Address 46: Central Conv.        Labels:. 8J0-959-433.lbl
       Part No: 8J0 959 433 A
       Component:    KSG          H08 0070
       Coding: 9B90328201382D290F0FC88A0477
       VCID: B4249960D7AE00EFCD-80E0
    Address 47: Sound System        Labels: 8J0-035-223.lbl
       Part No SW: 8J0 035 223 C    HW: 8J0 035 223 C
       Component: J525 Amp High   H04 0110
       Revision: PROD_01     Serial number: 00000000008688
       Coding: 0236116
       VCID: A4046920674E906F5D-80F0
                        Reset counter: 88
                        Mileage: 197163 km
                        Date: 2019.08.16
                        Time: 13:21:55
    Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MAX1.lbl
       Part No: 8J8 959 802 C
       Coding: 0001077
       VCID: BE30BB48E9E2DABF2B-80EA
       Coding: 0000025
       VCID: A91A7814006C4D076E-80FC
       Subsystem 1 - Part No: 8E0 941 329 A
       Component: AFS-Modul links H04 0020
       Subsystem 2 - Part No: 8E0 941 329 A
       Component: AFS-Modul rechtsH04 0020
       Part No SW: 8J0 035 195 A    HW: 8J0 035 195 A
       Component: R Symphony2+    H15 0221
       Revision: 00H15000    Serial number: AUZ1Z4G6068130
       Coding: 0670102
       VCID: AA188718056A461F67-80FE
                        Reset counter: 88
                        Mileage: 197163 km
                        Date: 2019.08.16
                        Time: 13:23:14
    02218 - Satellite Radio (R146)
                        Reset counter: 88
                        Mileage: 197163 km
                        Date: 2019.08.16
                        Time: 13:23:14
    Address 65: Tire Pressure        Labels: 8J0-907-273.lbl
       Part No SW: 8J0 907 273 A    HW: 8J0 907 273 A
       Component: J502_RDK        H02 0300
       Revision: --H02-B0    Serial number: 11970770279423
       Coding: 0840019
    Address 76: Park Assist        Labels: 8P0-919-283.lbl
       Part No SW: 8P0 919 283 D    HW: 8P0 919 283 D
       Revision: 00H09000    Serial number: 00067824830707
       Coding: 0001231
       VCID: BC34B140FFFEC8AF05-80E8
    End----------(Elapsed Time: 01:43, VBatt start/end: 13.3V/13.1V)-----------
    In addition, I have included the ODB2 data from Modes 1-01, 3, 7, and 9 as screen shots (couldn't figure out how to capture as log or scan files):
    Mode 1-01:
    https://1drv.ms/u/s!Avrv_NULbNUugZUG...T0YSA?e=NZaxpP
    Mode 3:
    https://1drv.ms/u/s!Avrv_NULbNUugZUH...rkZvQ?e=GcODMz
    Mode 7:
    https://1drv.ms/u/s!Avrv_NULbNUugZUI...ETKoQ?e=VggAxL
    Mode 9:
    https://1drv.ms/u/s!Avrv_NULbNUugZUJ...JiQMQ?e=cbqRYE
    https://1drv.ms/u/s!Avrv_NULbNUugZUK...XXjpg?e=JCmD6o
    Thanks for your help.
    Frankly, I don't see anything unusual with these scans. At this point the car will drive just fine until at random it will throw the two TB codes again and won't start. Usually on the side of the freeway in the middle of nowhere. Argh. Hope you can see something I can't. Thanks again.
    Best,
    Kelly Stevens
    Last edited by Uwe; 08-17-2019 at 08:57 AM. Reason: IMG -> URL since they don't embed.
  8. #8
    Nope it is FOD.......
    CAT CANT BE READY BEFORE BEING TESTED IN OPERATION FOR AMPLITUDE DROP.
    -------------------------------------------------------------------------------Address 01: Engine Labels: 022-906-032-BDB.lbl
    Coding: 0000178
    Kelly,
    No screenshots to observe.
    Confirmed........
    Car must have FOD modified code removed & in order to make use of VCDS, so ECU will report tests being circumvented by nefarious code deleting the AECD's purported by your tuner!
    It's hard to see something that cant report indeed!
  9. Likes PetrolDave liked this post
  10. #9
    So I wonder how your car could of had such a gross inconsistency with the data as certified, do you?
    8VWXV03.2535 PAGE 75 for your pleasure.
    https://iaspub.epa.gov/otaqpub/displ...d=18504&flag=1
    Pictures above taken from links as detailed in quotes below by OP of record.
  11. #10
    This news item may bring you some clarity as to why I am requesting such data?
    https://www.autoblog.com/2018/12/11/...er-than-crush/
    Again........8VWXV03.2535 PAGE 75 for your pleasure.
    Vehicle Identification No. TRUDD38J481002253
    Model audi tt coupe 3.2 qu.
    ATT
    Date of production 28.03.2007
    Model year 2007
    Sales type 8J351L
    Engine Code CBRA
    Transmission Code JPZ
    Emission standard 7GA Emission standard LEV 2
    PART NUMBER VIN NUMBER DESCRIPTION REMARK MODEL
    022 997 034 EX TRUDD38J481002253 Control unit for petrol engine 022 906 032HG
    code letter:
    6-speed
    dual clutch
    gearbox+
    CBRA
    OP let's test this theory of liability a bit further & get to the bottom of the box on this okay?
    Could you post a picture of your ECU outside and inside with clarity please?
    I'd like to see if we see anything that is relevant to your described condition in the ECU or externally.
    Take a fresh step towards extricating the car.......
