Results 1 to 3 of 3
Thread: 2016 Tiguan S - Did I Change ATF Correctly?
    Aug 2019
    I have three questions for the community, highlighted in bold below.
    First, the basics: 2016 Tiguan S with 4-motion, 2.0L 6-speed automatic transmission. I had the Stage I ECU upgrade installed from APR set at 93 Octane. Odometer is currently at 42,000 miles.
    I just followed all the steps to change the ATF:
    - Took out the drain plug and stand pipe and drained the old ATF
    - Removed ATF pan, replaced filter and gasket, reinstalled
    - Put the stand pipe back in
    - Pumped in about 5-6 quarts of ATF
    - Had the wife start the car and start cycling through R, D, S, and manual mode 1 and 2, and back to park
    - As she cycled through I pumped in another quart
    - After she cycled twice she left it in park with engine running and foot on the brake
    - When VCDS displayed 40 degrees Celsius ATF temperature, I removed the pump adapter and let the ATF trickle back out
    - When it stopped trickling and only lightly drizzled I replaced the drain plug with a new crush washer
    - Car in park, I checked for leaks
    - Drove the car around and parked it again, engine running, checked for leaks again
    Question 1: Did I do that all right?
    Question 2: If I screwed it up, how will I know? Will the shifting start to act funny? Will the ATF temperature exceed a certain temperature while driving? Will everything seem fine and then BAM! the tranny explodes while my wife is driving our daughter?
    When I test drove it the shifting seemed totally fine. The ATF temperature never exceeded 60 degrees Celsius during my short test run.
    I ran the auto scan while parked with engine running after the test run.
    Question 3: Why is there a malfunction in Central Electronics (Line 9)? Could it have something to do with APR installing a custom flash for the ECU?
    I would sincerely appreciate any insight into my three questions. I am but a humble DIY guy trying to save money by doing my own maintenance. I was dumbfounded when I found out the procedure for my vehicle.
    Thank you,
    Theo
    Wednesday,07,August,2019,17:46:38:43947
    VIN: WVGBV7AX3GW577137   License Plate:
    Chassis Type: AX-VW36 (7N0)
    Scan: 01 02 03 05 08 09 15 16 17 19 22 25 2B 42 44 46 4C 52 53 5F
              62 72
    VIN: WVGBV7AX3GW577137   Mileage: 68930km-42831miles
       Part No SW: 06J 906 027 JP    HW: 06J 907 309 A
       Component: MED17.5.2 TFSI 2 06 1335
       Revision: P3H08---    Serial number:
       Coding: 0423010A190F0160
       VCID: 025D8A716805ABA7DCD-8056
       Part No SW: 09G 927 750 NK    HW: 09G 927 750 NK
       Component: AQ 250 6F           2627
       Revision: 00H97000    Serial number:
       Coding: 0000840
       VCID: 074B9B6543278E8F8B3-8052
    Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
       Part No SW: 5N0 614 109 BN    HW: 5N0 614 109 BN
       Component: J104   C6 450M VDF7 0021
       Revision: --H07---    Serial number: 00000009076993
       Coding: 0005161
       VCID: 78A9E8993ED9F177F29-802C
       Revision: 00092000    Serial number: 0389948687
       Coding: 030C0C
       VCID: 372B2BA57FC73E0F3B3-8062
       Part No SW: 561 907 426 G    HW: 561 907 426 G
       Component: AC Manuell    H03 0506
       Revision: 00001K02
       Coding: 0010001002
       ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
       ROD: EV_ACManuaElectGen2BHTC_VW36.rod
       VCID: 1F1BE305F737664FD33-804A
       Part No SW: 5K0 937 084 N    HW: 5K0 937 084 N
       Component: BCM PQ35 B    122 0183
       Revision: BG122001
       Coding: EF1A0A1B80232EC4008800C11400044448510086566D8DF064800000A040
       VCID: 3D27398D5D7B145FE1F-8068
       Subsystem 1 - Part No SW: 5N1 955 119 B    HW: 5N1 955 119 B  Labels: 1KX-955-119.CLB
       Component: WWS316 301115  24  0664
       Coding: 009795
       Component: RLS 221215 05  54  0403
       Coding: 02304D
       Part No SW: 5N0 959 655 AB    HW: 5N0 959 655 AB
       Component: J234__005 VW10 HI   5418
       Revision: 36023000    Serial number: 003MAPRJW2R
       Coding: 0012341
       VCID: 7DA7F98D11FBD45FA1F-8028
       Subsystem 1 - Part No: 5N0 959 339 B
       Component: BF-Gewichtsens. 003 0001
       Subsystem 2 - Serial number: 0000000000RLSP
       Subsystem 3 - Serial number: 0026.10.150000300000650008˙†63
       Subsystem 4 - Serial number: 650008˙†6332MTS605663125+˙†63
       Subsystem 5 - Serial number: 63125+˙†6342MTS6074931252˙†63
       Subsystem 6 - Serial number: 931252˙†6351HTS6MPLA4EKJF˙†63
       Subsystem 7 - Serial number: A4EKJF˙†6361HTS69R1P1EKR5˙†63
       Subsystem 8 - Serial number: P1EKR5˙†63727TS6JEIPSDKJT˙†63
       Subsystem 9 - Serial number: PSDKJT˙†63827TS6HH3C3EKJM˙
       Subsystem 10 - Serial number: C3EKJM˙
       Part No SW: 5K0 953 501 DM    HW: 5K0 953 569 AP
       Revision: FF010042    Serial number: 20151211300400
       Coding: 1102140000
       VCID: 78A9E8993259F177F29-802C
       Subsystem 1 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H31 0037
       Serial number: 0933302
       Coding: 820000
       Part No SW: 5N0 920 973 L    HW: 5N0 920 973 L
       Component: KOMBI         H04 1008
       Coding: 211F010000
       VCID: 3D27398D5DFB145FE1F-8068
       Part No SW: 7N0 907 530 AT    HW: 7N0 907 530 AK
       Component: J533  Gateway H57 1663
       Revision:   H57       Serial number: 131215F1001318
       Coding: 356022
       VCID: 025D8A716405ABA7DCD-8056
       Part No SW: 0AY 907 554 J    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7540
       Serial number: HA1-00013.11.15
       Coding: 0001
       VCID: 52FD7A31F465FB272CD-8006
       Component: IMMO          H04 1008
       Coding: 000007
       VCID: 6A8DC2D17CF553E774D-803E
       Revision: 00000000    Serial number: 15000260863003
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 303910B99AA9E9377A9-8064
       Part No SW: 5N0 959 701 H    HW: 3C0 959 793 H
       Component: TUER-SG FT    002 0601
       Revision: 13100010    Serial number: 0010169822
       Coding: 0004B4
       ASAM Dataset: EV_TSGFPQ35BRFVW46X A04004
       VCID: 3A2D32914CD52367C4D-806E
       Slave Driver:
       Subsystem 1 - Part No SW: 5N0 959 703 G    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  010 1505
       Serial number: 00000009635653
       Coding: 000490
       Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
       Component: J500__APA-BS KL.285 1401
       Revision: 1BH04841    Serial number: 00153270164201
       Coding: 0000258
       VCID: 41DF457D2D8370BF857-8014
       Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
       Component: TUER-SG BT    002 0503
       Revision: 15110009    Serial number: 0010266599
       Coding: 0004B4
       VCID: 392F2D9D49D3287FCD7-806C
       Slave Passenger:
       Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  010 1505
       Serial number: 00000009647861
       Coding: 000490
       Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
       Component: J540 EPB4  VW-63206 0012
       Revision:   H19       Serial number: 00000000980834
       Coding: 0026156
       VCID: 382928997E593177329-806C
       Part No SW: 561 035 150     HW: 561 035 150
       Component: MU-E--US      857 6495
       Serial number: 04121500011967
       Coding: 02130600FF00000041220001001000001F0000D40000010000
       ASAM Dataset: EV_MUEnt4CGen2LGE 001025
       VCID: 4ACD62511C35B3E754D-801E
    End----------(Elapsed Time: 01:22, VBatt start/end: 13.5V/13.6V)-----------
    Quote Originally Posted by ttrifko2 View Post
    Your fluid change procedure sounds OK to me, but I can't say I've ever done that myself, so if anyone has another opinion, please chime in here.
    The Gateway sometimes gets out of synch with the actual status of a module.
    Try clearing fault codes directly in 09:
    [Select]
    [09 - Cent. Elect]
    [Fault Codes]
    [Clear Codes]
    If that doesn't resolve it, go to the Auto-Scan screen and:
    [Gateway Installation List]
    [Clear all DTCs] (make sure "Use CAN Command" is checked).
  3. Likes Jetta ,97 liked this post
    Dallas (McKinney) ,TX ,USA
    Yes you did good job on transmisiion.
    Also you need to do Haldex fluid at that miles .
    Immobilizer/ECU
    /Cluster Programing (Used or NEW)
    email: marinmm2001@gmail.com , info@advancedcarelectronics.com
    https://www.advancedcarelectronics.com/
  5. Likes Uwe, PetrolDave liked this post
