Results 1 to 10 of 11
Thread: 2010 VW Jertta Sportwagen TDIturn off lamp warning in speedo face.
    Sep 2018
    I replaced tag lamps with LEDs. Is there a workaround to turn off defective lamp signal in VCDS?
    thanks
    Cliff
    Wednesday,22,August,2018,18:06:05:40333
    VCDS Version: 18.2.1.5 (x64)
    VIN: 3VWTL7AJ8AM662893   License Plate:
    Mileage: 178510km-110920mi   Repair Order:
    Chassis Type: AJ-VW36 (1K0)
    Scan: 01 03 08 09 15 16 17 19 1C 25 2E 37 42 44 46 4F 52 56 62 65
              72 77
    VIN: 3VWTL7AJ8AM662893   Mileage: 178510km-110920miles
    2E-Media Player 3 -- Status: Malfunction 1010
    37-Navigation -- Status: Not registered 0011
    Address 01: Engine
    Address 03: ABS Brakes
    Address 08: Auto HVAC
    Address 09: Cent. Elect.
    Unable to communicate with address 09. Are you sure the doors are unlocked?
    Address 15: Airbags
    Address 16: Steering wheel
       Part No SW: 5K0 920 970 Q    HW: 5K0 920 970 Q
       Component: KOMBI         H03 0305
       Coding: 270D00
       Shop #: WSC 00066 000 00147
       VCID: 3C7C2FC3B7F62AA438-8068
       Part No SW: 1K0 907 530 AE    HW: 1K0 907 951
       Component: J533  Gateway   H06 0112
       Revision:   H06 01    Serial number: 161209F2001243
       Coding: E9807F07001613002002
       Shop #: WSC 00066 000 00000
       VCID: 6AD0D99B45E264149A-803E
    01304 - Radio
                        Fault Status: 00110100
                        Reset counter: 134
                        Mileage: 177727 km
                        Date: 2013.01.04
                        Time: 07:27:10
                000 -  -
                        Fault Frequency: 140
                        Mileage: 177979 km
                        Date: 2013.01.07
                        Time: 17:01:09
    03272 - Control Module for Audio Interface
                        Reset counter: 134
                        Mileage: 177756 km
                        Date: 2013.01.04
                        Time: 10:54:57
    Address 1C: Position Sensing
       Component: IMMO          H03 0305
       VCID: 6AD0D99B8DE264149A-803E
    Address 2E: Media Player 3
       Part No SW: 3C0 035 684 C    HW: 3C0 035 684
       Component: RNS-MID       H17 1140
       Revision: AB001001    Serial number: VWZ6Z7H6200096
       Coding: 04000400040000A600
       Shop #: WSC 05311 000 08193
       VCID: 234EF4BF2248755C19-8076
                000 -  -
                        Fault Frequency: 21
                        Reset counter: 103
                        Mileage: 177976 km
                        Fault Status: 00101011
                        Fault Frequency: 8
                        Reset counter: 143
    Address 44: Steering Assist
    Address 46: Central Conv.
       Part No SW: 1K0 907 532     HW: 1K0 907 951
       Component: EZE_2         H06 0112
       Coding: 050B0500
       VCID: 66C8ADAB91FA4074BE-8032
    Address 52: Door Elect, Pass.
                000 -  -
                        Fault Frequency: 21
                        Reset counter: 103
                        Mileage: 177976 km
                        Fault Frequency: 8
                        Reset counter: 143
    Address 62: Door, Rear Left
    Address 65: Tire Pressure
    Address 72: Door, Rear Right
    Address 77: Telephone
    End-------------------------(Elapsed Time: 03:28)--------------------------
    Address 56,3C0 035 684 C,recoded (Long Coding),from,04000400040000A600,to,06000400040000A600,(05311/000/08193),
    Address 56,3C0 035 684 C,recoded (Long Coding),from,06000400040000A600,to,06010400040000A600,(05311/123/08193),
    Address 56,3C0 035 684 C,recoded (Long Coding),from,06010400040000A600,to,06010440040000A600,(05311/123/08193),
    Address 56: DTCs cleared
    Dec 2016
    DE
    Unfortunately no. Not with VCDS.
    In your Auto-Scan many modules aren’t reachable. Did you create it with ignition on and doors unlocked?
    Sep 2018
    No i did not. Just placed the leds in holders. The doors where un locked...ignition was off
    Quote Originally Posted by clifford.hubbard View Post
    Can we get you to post a current scan, using the interface you registered recently, rather than a scan from nearly a year ago, that was done with a totally different interface?
    Sep 2018
    Yes will do when i get a moment...
  6. #6
    Sep 2018
    2010 Jetta Sportwagen TDI Auto scan
    Wednesday,07,August,2019,22:15:05:61365
    VCDS Version: 19.6.1.0 (x64)
    Mileage: 207920km-129195mi   Repair Order:
              72 77
    VIN: 3VWTL7AJ8AM662893   Mileage: 207920km-129195miles
    Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 906 019 CL    HW: 03L 906 022 TS
       Component: R4 2,0L EDC G000SG  9971
       Revision: 12H03---    Serial number:
       Coding: 0050072
       Shop #: WSC 06103 444 999999
       VCID: 77D3327F0622F1F7A8-8022
       Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
       Revision: 00H30001
       Coding: 114B600C492800FC881306ED921C0042300000
       VCID: 78D13143CB3CFE8FA1-802C
       Part No SW: 5K0 937 085 G    HW: 5K0 937 085 G
       Component: BCM PQ35 B++  111 0128
       Revision: BI111001
       Coding: 29380E3F902F3EC480080081440000C405000086535D8560648020000000
       VCID: 3753F27F86A231F768-8062
       Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer 18021  21  0512
       Coding: 009795
                010 - Open or Short to Plus
    Address 15: Airbags
       Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
       Coding: 0000532
       VCID: 78D131430B3CFE8FA1-802C
       Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS   H05 0010
       Coding: 00000130
       Coding: 270D00
       VCID: 3C59ED53B78412AF85-8068
       VCID: 6AF51B0B45905C1F27-803E
       Revision: 00001000    Serial number: 1225223T7DK404
       VCID: 7EDD275B2918C0BFEB-802A
       VCID: 6AF51B0B8D905C1F27-803E
       Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
       Revision: A1001003    Serial number: 7667729189
       VCID: 266D2F3B5108B87FC3-8072
       Coding: 06010440040000A600
       Shop #: WSC 05311 123 08193
       VCID: 236B362F223A4D57A4-8076
    00857 - CD Changer Unit (R41)
    02633 - Antenna for Satellite Tuner
       Part No SW: 3C0 959 701 B    HW: 3C0 959 793
       Component: TUER-SG FT    002 0307
       Revision: 13101005    Serial number: 0000359790
       Coding: 0004B5
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_DCU42BroseDriveSide A03004
       ROD: EV_DCU42BroseDriveSide_VW36.rod
       VCID: 2773223F5E02A177F8-8072
       Slave Driver:
       Subsystem 1 - Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  006 1401
       Serial number: 00000004587424
       Coding: 000490
    67589 - Turn Signal in Exterior Mirror
              B11FD 01 [009] - Electrical Failure
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 70     3001
       Revision: 00H17000
       Shop #: WSC 02069 000 90108
       VCID: 3147CC67A8C6EFC726-8064
       Coding: 050B0500
       VCID: 66ED6F3B9188787F03-8032
       Subsystem 1 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
       Component: J245EE20SKB13  H01 0220
       Component: J394EE20SKB13  H01 0220
    Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
       Component: RDK           111 0821
       Coding: 018705
    02904 - Hard Warning 3
    02903 - Hard Warning 2
    02801 - Hard Warning
    End-------------------------(Elapsed Time: 02:26)--------------------------
  7. #7
    Dallas (McKinney) ,TX ,USA
    When you buy good quality LED they have simulator and not trigger light bulb warning.
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  8. #8
    Sep 2018
    came from amazon. these are the ones i got...
    LED Monster 4pcs Ice Blue T10 194 168 Wedge 5-5050-SMD LED License Plate Light Lamp Bulb 12V (5 SMD)
  9. #9
    Sep 2018
    Found code”Cold Diagnosis License Plate Light, Active”. Un checked box and saved. Light still on...
  10. #10
    Dec 2016
    DE
    The Software and variant of your BCM do not support this bit it seems.
