Seat 2019 Alhambra 2.0 TDi 150ps module access denied?
Hi everyone
Recently took delivery of a brand new Alhambra Excellence and very happy with the car, well, I do miss my old A6 C6 3.0 but hey, I might get another one one day as the Alhambra is mainly for the Mrs
Anyways I have just applied the needle sweep mod and it works as intended, so thought that I would add beep on locking and mirror fold on remote locking but when I try to connect to those particular modules it times out and displays an error message about not being able to connect
Other modules connect but not 35 or 46
Is there a reason for this?
I tried the search option on the forum but nothing came to light.
Any pointers to what I might be doing wrong would be most welcome as im hoping to add a few more options, thanks.
Here is my full scan
Hi everyone
Monday,05,August,2019,19:12:46:08403
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: VSSZZZ7NZKV517115 License Plate:
Mileage: 2600km-1615mi Repair Order:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 25 2B 36 42 44 46 4C
4F 52 53 5F 61 62 6C 6D 72 A5 BE BF
VIN: VSSZZZ7NZKV517115 Mileage: 2600km-1615miles
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
Address 01: Engine (J623-DLTA) Labels: None
Part No SW: 04L 906 016 JF HW: 04L 907 309 AB
Component: R4 2.0l TDI H20 6636
Revision: 8EH20---
Coding: 011D001A042511083000
Shop #: WSC 00020 999 00000
ASAM Dataset: EV_ECM20TDI01104L906016JF 004005
ROD: EV_ECM20TDI01104L906016JE_VW36.rod
VCID: 76B5E5B688453087E05-8022
25147 - Control Circuit for Reductant Pump 1
P208B 00 [096] - Implausible Signal
Mileage: 1578 km
Date: 2019.07.17
Time: 09:03:41
Engine speed: 826.00 /min
Normed load value: 44.3 %
Coolant temperature: 16 °C
Intake air temperature: 17 °C
Voltage terminal 30: 13.200 V
Unlearning counter according OBD: 21
Extern.temp.sens.1 bank 1: raw value: 20.5 °C
Reducing agent pump module relative press.: calculated: 0 hPa
Reducing agent fill level sensor: act. value: 150.3 mm
Sensor for reducing agent tank temperature: temperature: 17.5 °C
Reducing agent system pressurization release conditions-Bits 0-7: 0
Reducing agent system pressurization release conditions-Bits 0-7: 205
Reducing agent system: current status: COSCR_NOPRESSURECTL
Reducing agent system: current status-Test_Program_SCR Con State 01 UBYTE: 2
22561 - Control Circuit for Reductant Pump 1
Mileage: 1578 km
Date: 2019.07.17
Time: 09:05:04
Engine speed: 1352.50 /min
Normed load value: 72.5 %
Vehicle speed: 33 km/h
Coolant temperature: 28 °C
Intake air temperature: 45 °C
Voltage terminal 30: 12.880 V
Unlearning counter according OBD: 20
Reducing agent fill level sensor: act. value: 154.0 mm
Sensor for reducing agent tank temperature: temperature: 17.2 °C
Reducing agent system pressurization release conditions-Bits 0-7: 255
Reducing agent system: current status: COSCR_PURGE
Reducing agent system: current status-Test_Program_SCR Con State 01 UBYTE: 8
Part No SW: 02E 300 066 N HW: 02E 927 770 AT
Component: GSG DSG AG6 541 5204
Revision: 06454104 Serial number: 00001903260289
Shop #: WSC 00020 790 00000
VCID: 2411EFFE62D9F2178E1-8070
Part No SW: 5N0 614 109 CR HW: 5N0 614 109 CR
Component: ESC-EBC460iV1 H15 0023
Serial number: A01Z3WC
Coding: 11F0449A8921C2730878880122C89143103917F000014884
ASAM Dataset: EV_Brake1ESCEPBTRW 006353
ROD: EV_Brake1ESCEPBTRW_006.rod
VCID: 7DA7FA9AAD7363DFA1F-8028
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 J HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1403
Revision: 00092000 Serial number: 0514131985
Coding: 03300C
Shop #: WSC 00020 999 39850
VCID: 3C21379EF6E9AAD7D61-8068
Part No SW: 7N0 907 044 BE HW: 7N0 907 044 BE
Component: Clima-Sharan H04 0707
Revision: 00001K06
Coding: 021010C549
ASAM Dataset: EV_ClimatronicSharan A01724
VCID: 74B1DFBE9E392297DE1-8020
Slave 1:
Subsystem 1 - Part No SW: 7N0 907 049 C HW: 7N0 907 049 C
Component: KBT-H 004 0103
Serial number: 20190418000000203840
Part No SW: 5K0 937 086 AC HW: 5K0 937 086 AC
Component: BCM PQ35 M 122 0193
Revision: BC122001
Coding: 40590A3F8925E1C0508800C8B400817403D10008676D2DB26480C720A2C1
VCID: 75B7E2BA95C33B9FE9F-8020
Subsystem 1 - Part No SW: 7N2 955 119 C HW: 7N2 955 119 C
Component: WWS428 190123 024 0646
Serial number: 19011703040341
Coding: 004DBD
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 052 0107
Serial number: S4Y19M04D29H08M41S48
Coding: 0228BB
Subsystem 3 - Part No: 7N0 951 172
Component: Sensor, DWA 0 005 0502
Subsystem 4 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0009
Part No SW: 1K8 919 472 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 39331911900392
Coding: 0031151011
ASAM Dataset: EV_EPHVA18VW364GP00 001007
VCID: 372B28B2CFCF898F3B3-8062
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7N0 907 572
Component: ACC Bosch PQx H03 0211
Serial number: 0804190439AFE9
Coding: 00001100FE0739
ASAM Dataset: EV_ACCBEGVW361 001006
ROD: EV_ACCBEGVW361_VW32.rod
VCID: 363525B6C8C57087205-8062
Part No SW: 7N0 959 655 D HW: 7N0 959 655 D
Component: VW10Airbag11B H16 0016
Serial number: 003PWP6VTVPZ
Coding: 003142
ASAM Dataset: EV_AirbaVW10TS6VW428 A01010
ROD: EV_AirbaVW10TS6VW428.rod
VCID: 40D9436E9A01CE378A9-8014
Subsystem 1 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.V --- ---
Serial number: 3493ETS60E468351E9D1
Subsystem 2 - Part No SW: --- HW: ---
Component: S.Sens.Beif.V --- ---
Serial number: 3503ETS60E582351E9DX
Subsystem 3 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.H --- ---
Serial number: 3513ETS6096D9351E9D%
Subsystem 4 - Part No SW: --- HW: ---
Component: S.Sens.Beif.H --- ---
Serial number: 3523ETS609C7B351EDD6
Subsystem 5 - Part No SW: --- HW: ---
Component: F.Sens.Fahr --- ---
Serial number: 35540TS60875E331E9DS
Part No SW: 5K0 953 521 GP HW: 5K0 953 569 BG
Component: LENKS.MODUL 018 0230
Revision: FF010042 Serial number: 20190423300728
Coding: 3012240000
ROD: EV_SMLSNGVOLWSR8C.rod
VCID: 0059836EDA810E37CA9-8054
Subsystem 1 - Part No SW: 7N5 919 719 HW: 7N5 919 719 Labels: 3C8-959-537.CLB
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000G1279180419
Coding: 011000
Part No SW: 7N5 920 980 E HW: 7N5 920 980 E
Component: KOMBI H02 2040
Coding: 410F010800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
VCID: 3B233482F3E7ADEFDFB-806E
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 7N0 963 271 G
Component: Zuheizer 051 3041
Revision: 00051000 Serial number: 09028242000000
Coding: 0000041
VCID: 38292B8ECE5186F7329-806C
02251 - Heater Unit Locked
Reset counter: 2
Mileage: 15 km
Date: 2019.06.04
Time: 08:52:45
Part No SW: 7N0 907 530 BQ HW: 7N0 907 530 AN
Component: J533 Gateway H56 1691
Revision: H56 Serial number: 230419F1000338
Coding: 468233
VCID: 0059836EDA010E37CA9-8054
Component: IMMO H02 2040
Coding: 000007
VCID: 6A8DC1C6CCFDE46774D-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 D HW: 5K0 905 861 D
Component: ELV-PQ35 H22 0240
Revision: 00000000 Serial number: 19000089016006
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 313F16AA21AB57BF757-8064
Address 36: Seat Mem. Drvr (J810) Labels: 3C0-959-760.lbl
Part No SW: 3C8 959 760 E HW: 3C8 959 760 E
Component: Sitzmemory H06 3101
Revision: 00H06000
Coding: 000018
Shop #: WSC 12336 024 394758
VCID: 372B28B2CF4F898F3B3-8062
Address 42: Door Elect, Driver (J386) Labels:. 7N0-959-793.clb
Part No SW: 7N0 959 793 J HW: 7N0 959 793 G
Component: TSG FA H05 0561
Revision: Serial number: 0000373298977
Coding: 01112E209E01411001
VCID: 49CF5E4AA9BB0F7F5D7-801C
Address 44: Steering Assist Labels: None
Part No: 7N0 909 144 R
Component: EPS_ZFLS Kl. 278 3501
Revision: 00H21000
VCID: 42DD4966988DDC279CD-8016
Address 4C: Tire Pressure II
Part No SW: 7N0 907 532 HW: 7N0 907 530 AN
Component: EZE_2 H56 1691
Coding: 050B0500
VCID: 6FBBD0D2F79F014F233-803A
Subsystem 1 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H04 0090
Subsystem 2 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H04 0090
Address 52: Door Elect, Pass. (J387) Labels:. 7N0-959-792.clb
Part No SW: 7N0 959 792 J HW: 7N0 959 792 G
Component: TSG BF H05 0561
Revision: Serial number: 0000373307070
Coding: 01112C209E01411001
VCID: 48C95B4EB2B1F677429-801C
Address 53: Parking Brake
Address 5F: Information Electr. (J794) Labels:| 5F0-035-MIB-STD2.clb
Part No SW: 7N5 035 680 E HW: 7N5 035 680 E
Component: MU-S-ND-ER H41 0475
Serial number: SEZAZ2W0407630
Coding: 04240801FF0000000111110100880A001F0103C600200100C6
ROD: EV_MUStd4CTSAT_VW36.rod
VCID: 353722BAD5C37B9F29F-8060
Subsystem 1 - Part No SW: 6P0 919 866 AF HW: -----------
Component: ECE1 2018/19 --- 1030
U11B8 00 [009] - No Communications
[USB - communication error]
Reset counter: 38
Mileage: 1077 km
Date: 2019.07.05
Time: 11:57:01
Voltage terminal 30: 14.5 V
Interface for external media: status-Status: Open circuit
Part No SW: 7N0 907 534 HW: 7N0 907 530 AN
Component: Batt.regelung H56 1691
Coding: 030F7873
VCID: 71BFD6AAE1AB17BF357-8024
Subsystem 1 - Part No SW: 1K0 915 181 L HW: 1K0 915 181 L
Component: J367-BDM H07 0270
Serial number: 46120744485831198269
Address 62: Door, Rear Left (J388) Labels:. 7N0-959-794.clb
Part No SW: 7N0 959 794 L HW: 7N0 959 794 H
Component: TSG HL H03 0561
Revision: Serial number: 0000373314225
Coding: 01006C200001411001
VCID: 4CC1675EA6C91A57661-8018
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-907-441.clb
Part No SW: 7N0 907 441 B HW: 7N0 907 441 B
Component: VW428 RVC Mid H04 0040
Coding: 012408012201000700
ASAM Dataset: EV_CamSysRearPANAVW428 002002
ROD: EV_CamSysRearPANAVW428.rod
VCID: 303913AE2AA15EB77A9-8064
Address 6D: Trunk Elect. (J605) Labels:| 7N0-959-107.clb
Part No SW: 7N0 959 107 G HW: 7N0 959 107 A
Component: HDSG-Modul H12 0250
Revision: 41012002 Serial number: 100900714
Coding: 0733334002
ASAM Dataset: EV_HDSGVW428 201138
ROD: EV_HDSGVW428_VW36.rod
Address 72: Door, Rear Right (J389) Labels:. 7N0-959-794.clb
Component: TSG HR H03 0561
Revision: Serial number: 0000373314227
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H12 0610
Serial number: 16041915K14429
Coding: 0304020800000401000613048080400080000E00002000
ASAM Dataset: EV_MFKBoschMQBB 002041
ROD: EV_MFKBoschMQBB_002_VW36.rod
Address BE: Slid. Door Rear Left (J558) Labels: 7N0-959-244.clb
Part No SW: 7N0 959 244 B HW: 7N0 959 244 B
Component: Schiebetuer_l 005 2414
Serial number: 19120062
ASAM Dataset: EV_AST A03704
ROD: EV_AST.rod
VCID: 38292B8EC2D186F7329-806C
Address BF: Slid. Door Rear Right (J731) Labels: 7N0-959-244.clb
Component: Schiebetuer_r 005 2414
Serial number: 19120068
ROD: EV_AST.rod
End----(Elapsed Time: 02:10, VBatt start/end: 11.8V/11.8V. VIgn 11.9V)-----
