I wonder if anyone knows whether it's possible to enable hill hold full-time on a Passat B6? It has hill hold installed from new, but defaults to off on every start cycle. Scan below.
Thanks,
Adam
Thanks,
Adam
Friday,02,August,2019,18:36:27:31354
VCDS Version: 19.6.1.0 (x64) HEX-NET CB: 0.4508.4
VIN: WVWZZZ3CZ9E021693 License Plate: PASSAT
Mileage: 290640km-180595mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ9E021693 Mileage: 290640km-180595miles
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 BL HW: 03L 907 309
Component: R4 2,0L EDC G000SG 2650
Revision: 13H01--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 84224 152 600198
VCID: 70AC2F6063D969CF69-8024
008213 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 - 000 - Implausible Signal - Intermittent
Fault Frequency: 46
Mileage: 290087 km
Date: 2019.06.19
Time: 18:16:26
Lambda: 11.8 %
Lambda: -2.4 %
Voltage: 0.380 V
Bin. Bits: 00000000
006481 - Radiator Fan 2 (V177)
P1951 - 000 - Movement Restricted / Jammed - Intermittent
Mileage: 290573 km
Date: 2019.07.22
Time: 18:01:23
RPM: 1265 /min
Speed: 11.0 km/h
Temperature: 50.4°C
Temperature: 81.0°C
Temperature: 29.7°C
Lambda: 21.3 %
Lambda: 0.0 %
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 P HW: 3C0 614 109 P
Component: J104 C4 440 V2 0011
Revision: --025--- Serial number: 00000785849746
Coding: 0001298
Shop #: WSC 05311 000 00000
VCID: 2B16F80C8A7F4A171C-807E
Part No SW: 1K0 820 047 HN HW: 1K0 820 047 HN
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
VCID: 77BE147C06B73EF7A8-8022
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
Revision: 00H54000 Serial number: 01000008409879
Coding: 00888F0700041A00470A00000F000000000859435C000100000000000000
Shop #: WSC 05124 000 00000
VCID: 6FAE2C1C7EE7763770-803A
Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 290508 022 0601
Coding: 00046997
Shop #: WSC 05124
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__006 VW10 HI 1815
Revision: 19013000 Serial number: 0039DPC8RWXX
Coding: 0012342
VCID: 3B36C84C7A1FDA978C-806E
Subsystem 1 - Serial number: 6333FTS655021268
Subsystem 2 - Serial number: 6343FTS617121598
Subsystem 3 - Serial number: 6353ETS6EK7VTVNH
Subsystem 4 - Serial number: 6363ETS69L4OTVNP
Part No SW: 3C0 953 549 AE HW: 3C0 953 549 AE
Component: J0527 0020
Revision: 00026000 Serial number: 3C9953507AT
Coding: 0000112
Component: E0221 002 0010
Part No SW: 3C0 920 971 E HW: 3C0 920 971 E
Component: KOMBIINSTRUMENT VD1 2416
Revision: V0002000 Serial number: 00000000000000
Coding: 0007405
Shop #: WSC 00488 210 175951
VCID: 271E043C96976E77F8-8072
Address 19: CAN Gateway Labels:. 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 H HW: 3C0 907 951
Component: J533__Gateway H13 0142
Revision: H13 Serial number: 2600P08616079A
Coding: F9807F060002022003
VCID: 26000938919D777FC3-8072
01304 - Radio
Fault Frequency: 122
Reset counter: 143
Mileage: 289799 km
Date: 2019.06.07
Time: 17:10:59
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
VCID: 393AD2447023E8879E-806C
Component: ELV 027 0380
3C0905861G ELV 027 0380
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1518
Revision: 72009005 Serial number: 00000309288612
Coding: 0000693
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 195 2301
Revision: 00H15000
VCID: 2A18FD088585531FE7-807E
Component: KSG PQ46 ELV 042 0472
Coding: 1891020051030E7630049C1D70085FCE107C01
Shop #: WSC 05311 123 12345
Component: Neigungssensor 004 0611
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1518
Revision: 72009005 Serial number: 00000795888626
Coding: 0000692
Fault Status: 00101100
Reset counter: 139
Mileage: 290182 km
Date: 2019.06.22
Time: 15:51:56
Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
Component: J540 EPB3 VW-10498 0003
Revision: 008 Serial number: 00000000059905
Coding: 0000057
VCID: 281C07009B89610FF1-807C
Address 56: Radio
Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
Component: J388 TUER-SG HL 0307
Revision: 41004101 Serial number: 00000000487216
Coding: 0000144
Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
Component: J389 TUER-SG HR 0307
Revision: 41004101 Serial number: 00000000482879
Coding: 0000144
VCID: 71AA2A6468D360C766-8024
End----------(Elapsed Time: 01:29, VBatt start/end: 12.2V/12.2V)-----------
