Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Audi A6 C7.5 Facelift Upgrade Full LED (not Matrix) from Xenon with AFS
    Feb 2016
    Czech Republic
    I found small diference in coding each headlight
    The right coding is E01F00 but friend have E01E00. I am not able to change the coding. Any advice ?
    I have:
       Coding: 04DA06102A630200
       VCID: 3430ED87FEB5D8F71DF-8060
       Coding: E01E00
       Coding: E01F00
    Friend in RS6 have:
       Coding: 04FA02102A230200
       VCID: 3424E85E9F0BCFEF4D-8060
       Coding: E01E00
       Coding: E01E00
  2. #12
    Feb 2016
    Czech Republic
    So it works now!
    Helpded - upload ZDC file dataset with VCP cable to 09 - Central elec. I checked there all LED headlights with AFS parameters for my car (without Air suspension). Then i made Basic settings 55 - Headlight range (i made it with VCP also, but with VCDS it can also work :-) )
    Now it is without errors. May be it will help to someone:-)
    Chassis Type: 4G-AU57 (4G8)
    Scan: 01 02 03 05 06 08 09 15 16 17 19 20 28 36 3B 3C 42 44 46 52
              53 55 5F 62 6D 72 88 89 AC
    17-Instruments -- Status: Cannot be reached 0100
    88-Multicont. Seat Driver -- Status: Malfunction 0010
    89-Multicont. Seat Pass. -- Status: Malfunction 0010
    Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 FQ    HW: 04L 907 309
       Component: R4 2,0L EDC   H23 1649
       Revision: 85H23---
       Coding: 12254012232401080000
       ASAM Dataset: EV_ECM20TDI01104L906021FQ 002004
       ROD: EV_ECM20TDI01104L906021FQ_002.rod
       VCID: 79BA196AF8E9F287E0-802C
       Part No SW: 4G1 927 153 G    HW: 0CJ 927 156
       Component: 0CK 20TDI RdW H05 0001
       Revision: --H05---    Serial number: 0000002243
       Coding: 000001
       ASAM Dataset: EV_TCMDL382021 002028
       ROD: EV_TCMDL382021_AU57.rod
       VCID: 2E10FA367127E53F05-807A
       Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
       Component: V553 MTFP  003 0576
       Serial number: 75145041170332003398
       Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
       Component: ESP9 Premium  H01 0420
       Coding: 06A29E41604579829B00
       ASAM Dataset: EV_ESP9BOSCHAU57X 003019
       ROD: EV_ESP9BOSCHAU57X_003.rod
       VCID: 3FCEB772A64D1CB79E-806A
       Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
       Component: BCM2 2.0      H36 0560
       Coding: 0189700E000000000000
       VCID: 7AB80666F5EFF99FE9-802E
       Part No SW: 4G8 959 760 C    HW: 4G8 959 760 C
       Component: MEM-BFS       H04 0157
       Revision: AA000000    Serial number: 00000152599056
       Coding: C018320085006201010001010101112030303333283333
       VCID: 3A38C666B56F399FA9-806E
       Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
       Component: KLIMA 4 ZONEN H14 0112
       Serial number: 19101500040623
       Coding: 3402097E210000
       VCID: 63865B026A651857DA-8036
       Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
       Revision: 15020001    Serial number: 00000956571002
       Coding: 0105001440F49FE00101408480001800CF9CC6082608020100000814E111140200400024030000
       VCID: 71AA214AA899BAC758-8024
       Component: WWS57X 141109  H37 0080
       Serial number:         141114150030
       Coding: 0045F7
       Serial number: 23501075
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
       Component: E1 - LDS  H07 0044
       Serial number: 22 11 2014  00000555
       Serial number: AD188E57000000000001
       Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
       Component: Airbag10.43   H82 0086
       Revision: --------    Serial number: 003P1002E079
       Coding: 30333130313830313833554A304C34473053
       VCID: 3B36C362B2550097B2-806E
       Serial number: 3575HRB40692QMKADH6
       Serial number: 3585HRB40572ORMG1OPI
       Serial number: 3515JRB404T32I4KK8EP
       Serial number: 3525JRB404T32I4KDHCQ
       Serial number: 3554VRB405H32PV6C85W
       Serial number: 3564VRB405732PV6CGJ2
       Revision: C0068538    Serial number: 90862NKP001J4
       Coding: 000035
       VCID: 3B36C362BA550097B2-806E
       Serial number: 04 11 2014  10007750
       Part No SW: 4G8 920 933 Q    HW: 4G8 920 933 Q
       Component: TDieRdw       H07 0043
       Revision: 03001036    Serial number: 658261114592008
       Coding: 03A612000B410008080000
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K_AU57.rod
       VCID: 3E30CA76A14715BF95-806A
       Part No SW: 4G8 907 468     HW: 4G8 907 468
       Component: J533--Gateway H13 0075
       Revision: --------    Serial number: 00000001644078
       Coding: C0CD074418
       ASAM Dataset: EV_GatewPkoUDS 001024
       VCID: 75A2155AD4F196E784-8020
       Serial number: 2715675003
       Voltage stabilizer:
       Serial number: 14091800000000000059
       Revision: AA001002
       VCID: 7CB4007EFFDBC7AFFB-8028
       Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
       Component: KLIMA FOND    H08 0112
       Serial number: 27111400040081
       Coding: 20
       VCID: 3D32CD7AAC410EA78C-8068
       Component: MEM-FS        H04 0157
       Revision: AA000000    Serial number: 00000152598571
       Coding: C018330085016201010001010101112030303333203333
       Component: SARA 3D       H04 0056
       Revision: --------    Serial number: EJ1BPA720DTZMG
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 3326EB429A05C8D76A-8066
       Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
       Component: SWA Master    H08 0070
       Serial number: 0432084805
       Coding: 040311
       Shop #: WSC 22675 401 00000
       VCID: 393AD96AB8693287A0-806C
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
       Component: SWA Slave  H08 0070
       Serial number: 0431896700
       Coding: 040311
       Coding: 011F17015E00620002080012
       VCID: 47DEAF92F69D547726-8012
       Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
       Component: RCEPS         H41 0011
       Revision: 00001000    Serial number: 0013202325
       Coding: 101000010001
       ASAM Dataset: EV_RCEPS 009010
       ROD: EV_RCEPS_009.rod
       Revision: 00002001    Serial number: 0353536751
       Coding: 0100063820B930808320090000010F400000000000000000000000000000
       Coding: 011F17015E00620002080002
       VCID: 46C0A296F1974D7FDD-8012
       Revision: --------    Serial number: 00000001285373
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2D12FD3A7C219E273C-8078
       VCID: 3424E85E9F0BCFEF73-8060
       Coding: E01E00
       Coding: E01E00
       Part No SW: 4G1 035 044 G    HW: 4G1 035 044
       Component: MU-H-LN-EU    040 0910
       Serial number: A589K0E7501633
       Coding: 01750201FF0A000013110001000A00102F0006E5F1700100DF
       VCID: 23061B022AE558579A-8076
       Subsystem 1 - Part No SW: V03 959 802 DF    HW: -----------
       Component: ECE 2019/2020  --- 0177
       Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
       Serial number: AUZ8Z9EY8007PM
       Multimedia Operating Unit:
       Serial number: 90349OJD0000G
       Component: Gracenote2  --- 1012
    1556 - Internal Control Module Memory Check Sum Error
              B2000 87 [009] - Missing message
                        Reset counter: 56
                        Mileage: 230174 km
                        Date: 2019.10.31
                        Time: 21:34:37
                        Voltage terminal 30: 12.0 V
                        Software module: status-SW_Status_Consistency: 00 28 13
                        Software module: status-SW_Status_Device: Mmx2Mmx2Mmx2M
       Coding: 010F15004000620002080002
       VCID: 49DAA9AAE089A20730-801C
       Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
       Component: HDSG-Modul    H05 0150
       Revision: 14005001    Serial number: 325400984
       Coding: 093205C010
       ROD: EV_HDSGAu571.rod
       VCID: 3620D2568977DDFF4D-8062
       Part No SW: 4G8 881 073     HW: 4G8 881 073
       Component: P2G           H02 0032
       Serial number: 0F5R4MU
       Coding: 766FF0
       ASAM Dataset: EV_P2GDriveSideFrnt 001006
       ROD: EV_P2GDriveSideFrnt.rod
       VCID: 6E903A36B1A7A53F45-803A
       Subsystem 1 - Part No SW: 4G8 907 181     HW: 4G8 907 181
       Component: PSLB  H02 0023
       Serial number: 00000000000000F5T5E2
       Valve Block 2 In Driver Side Front Seat:
       Subsystem 2 - Part No SW: 4G8 907 182     HW: 4G8 907 182
       Component: PSML  H02 0023
       Serial number: 00000000000000F5J44C
       Valve Block 3 In Driver Side Front Seat:
       Subsystem 3 - Part No SW: 4G8 907 182     HW: 4G8 907 182
       Component: PSMR  H02 0023
       Serial number: 00000000000000F5J2A9
    0018 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Funktionseinschränkung wegen fehlender CAN-Botschaft]
                        Reset counter: 56
                        Mileage: 230174 km
                        Date: 2019.10.31
                        Time: 21:34:23
       Serial number: 0F5R5QW
       Coding: 366FF0
       ASAM Dataset: EV_P2GPasseSideFrnt 001006
       ROD: EV_P2GPasseSideFrnt.rod
       Serial number: 00000000000000F5V571
       Valve Block 2 In Passenger Side Front Seat:
       Serial number: 00000000000000F5J2C6
       Valve Block 3 In Passenger Side Front Seat:
       Serial number: 00000000000000F5J2BZ
              U1111 00 [009] - -
                        Reset counter: 56
                        Mileage: 230174 km
                        Date: 2019.10.31
                        Time: 21:34:23
       Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0010
       Revision: 00000000    Serial number: 143110282
       ROD: EV_RDCMA00100_008.rod
       VCID: 2B16F3224235901722-807E
  3. Likes Uwe, Bogdan.audi liked this post
  4. #13
    Oct 2016
    Ukraine
    I have 09 only coded
