Page 9 of 12 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 116
Thread: Dynamic Chassis Control Retrofit
  1. #81
    May 2017
    Yes I have drive mode select. According to various websites it does not need FeC. Coding part is to be seen. There are few modules where you need to code the DCC but like you wrote there’s no adaptation in 5F for DCC separately.
  2. #82
    Apr 2018
    ITALY
    my question was incorrect because on MQB you can't have DCC without the Drive Mode Selection. I should have said I hope the FeC for Driving Mode only is not different from the FeC for Driving Mode + DCC.
    you need to code DCC by enabling a bit into modules 03, 17 and 19.
    I did, but my Driving Mode display never changed... but my shocks were still
    disconnected when I left home so I hope that's the reason.
    my Golf came out of the factory with 13 ECUs. now she has 20. and counting
  3. #83
    May 2017
    Aalraity then, installation completed. But stupid me, attached the unit to the wrong CAN bus. This was the only thing I did NOT check and double check. I trusted the coloring on the Chinese wiring harness. Should've known better from past experiences with those
    Anyway, everything seems to communicate with the DCC module, only missing messages caused by the incorrect CAN bus connection.
    BUT, and this is the BUT where I cursed a lot. The DCC module seems to have incorrect dataset.... SHITTT!! Not a show stopper, I can get this one fixed but still, causes extra effort.
    When CAN bus connection corrected tomorrow, only errors left in DCC module should be missing basic setting and implausible data set.
    Saturday,25,January,2020,19:25:48:18875
    VCDS Version: 19.6.2.0 (x64)  HEX-V2 CB: 0.4513.4
    VIN: WVGZZZ5NZHW310427   License Plate: -
    Mileage: 85901km-53376mi   Repair Order:
    Chassis Type: 5N-VW37 (5Q0)
    Scan: 01 02 03 08 09 10 13 14 15 16 17 18 19 22 29 39 3C 42 44 47
              52 55 5F 69 6C 6D A5 BB BC CF D6 D7
    VIN: WVGZZZ5NZHW310427   Mileage: 85901km-53376miles
    Address 01: Engine (J623-DFHA)       Labels:. User\04L-907-309-V1.lbl
       Part No SW: 04L 906 026 EJ    HW: 04L 907 309 P
       Component: R4 2.0l TDI   X24 3015
       Revision: B4X24---
       Coding: 0125003A04761D082000
       Shop #: WSC 92521 052 00000
       ASAM Dataset: EV_ECM20TDI01104L906026EJ 004002
       ROD: EV_ECM20TDI01104L906026EJ_004.rod
       VCID: 76B5E6CBA843A607E3B-8022
       Part No SW: 0DL 300 011 A    HW: 0DE 927 711
       Component: GSG DQ500     H12 1449
       Revision: 00H12V32
       VCID: 2615F68B3863968793B-8072
       Part No SW: 5Q0 614 517 BH    HW: 5Q0 614 517 AD
       Component: ESC           H25 0507
       Revision: 00000000    Serial number: 61576000000096
       Coding: 0AEE6B9A54210B6C477B670262CA4950D62AD0E2E646927D386250F8C2AA02
       VCID: 78A9E8F3A257D077F17-802C
    8216 - Databus
              [FCAN: Fahrwerk_01 message is not received]
                        Reset counter: 116
                        Date: 2020.01.24
                        Time: 19:19:36
       Part No SW: 5NA 907 044 L    HW: 5NA 907 044 L
       Component: AC Automat    H35 4301
       Revision: 20K08000    Serial number: 00000B00147934
       Coding: 0002010420411101110510400010102A
       ASAM Dataset: EV_ACClimaPrehVW37X 002023
       ROD: EV_ACClimaPrehVW37X.rod
       VCID: 48C95833923760F7417-801C
       Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
       Component: E265KlimaHeck  H02 0201
       Serial number: 00000000000000000000
       Serial number: 02001616700623
       ROD: EV_BCMBOSCH_017.rod
       VCID: 7EA5FEEB8073EE47BBB-802A
       Subsystem 1 - Part No SW: 5NB 955 119     HW: 5NB 955 119   Labels: 1KX-955-119.CLB
       Component: 326 LL 160523  033 0372
       Serial number: 00000001605180309405
       Component: RLHS  037 0059
       Serial number: S5Y16M06D13H18M41S51
       Coding: 03A8DD
       Part No SW: 3Q0 919 298 B    HW: 3Q0 919 298
       Component: PLA 3.0 12K   H09 0029
       Serial number: 002605167478042
       Coding: 0231567A51
       ASAM Dataset: EV_EPHBO2CVW3260000 010016
       ROD: EV_EPHBO2CVW3260000.rod
       VCID: 3C2134E3D6EF3C57D5F-8068
    Address 13: Auto Dist. Reg (J428)       Labels:| User\2Q0-907-572.lbl
       Part No SW: 2Q0 907 572 H    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H01 0155
       Coding: 320C47DB1CFF8728749C8065304085
       ASAM Dataset: EV_ACCMRRCONTIVW376 001010
       ROD: EV_ACCMRRCONTIVW376_001.rod
       VCID: 392F2DF7D9DD097FCE9-806C
       Serial number: 17011741350132
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 382928F3E2D71077317-806C
    6 Faults Found:
    278272 - Basic Setting of Deflected Position not Performed
              C10C5 00 [137] - -
                        Reset counter: 116
                        Mileage: 85901 km
                        Date: 2020.01.24
                        Time: 19:19:35
    199172 - Databus
              [Lenkwinkelsignale - kein Signal/Kommunikation]
                        Reset counter: 116
                        Mileage: 85901 km
                        Date: 2020.01.24
                        Time: 19:19:35
    332548 - Databus
              [Gateway - kein Signal/Kommunikation]
                        Reset counter: 116
                        Mileage: 85901 km
                        Date: 2020.01.24
                        Time: 19:19:35
    336388 - Databus
              [Motor - kein Signal/Kommunikation]
                        Reset counter: 116
                        Mileage: 85901 km
                        Date: 2020.01.24
                        Time: 19:19:35
    336900 - Databus
              [Bremsensignale - kein Signal/Kommunikation]
                        Reset counter: 116
                        Mileage: 85901 km
                        Date: 2020.01.24
                        Time: 19:19:35
    812800 - invalid data record
              B2005 00 [137] - -
              [Steuergeraet (DatensatzDownload) - Datensatz ungueltig]
                        Reset counter: 116
                        Mileage: 85901 km
                        Date: 2020.01.24
                        Time: 19:19:35
       Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
       Component: AirbagVW21    003 0315
       Serial number: 003TDR1V63SC
       Coding: 98CCC0C00C0000005C5400CF000800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 1079B053AAE7E837597-8044
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1032
       Serial number: 5NB857705C0161Q00678
       Coding: 80000D
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1032
       Serial number: 5NB857706C0166Q00679
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 480 001 506 16
       Serial number: 357000000000741C4C1D
       Subsystem 4 - Part No SW: -----------    HW: 480 001 506 16
       Serial number: 358000000006741C4C1K
       Subsystem 5 - Part No SW: -----------    HW: 480 401 106 16
       Serial number: 3510001BD20FC483F79N
       Subsystem 6 - Part No SW: -----------    HW: 480 401 106 16
       Serial number: 3520001BD20FC483D309
       Subsystem 7 - Part No SW: -----------    HW: 480 401 206 16
       Serial number: 3550001BD20FC482B3CL
       Pedestrian Protection Driver:
       Subsystem 8 - Part No SW: -----------    HW: 480 401 306 16
       Component: PedP_Sensor_D  000 6149
       Serial number: 2280001AF20FC483447B
       Subsystem 9 - Part No SW: -----------    HW: 480 401 306 16
       Component: PedP_Sensor_P  000 6149
       Serial number: 2290001AF20FC484462A
       Pedestrian Protection Center:
       Subsystem 10 - Part No SW: -----------    HW: 480 401 306 16
       Component: PedP_Sensor_C  000 6149
       Serial number: 2300001C120FC48557F6
       Subsystem 11 - Part No SW: -----------    HW: 480 000 906 16
       Serial number: I0M00000000F9A6DEB1X
       Subsystem 12 - Part No SW: -----------    HW: 480 000 906 16
       Serial number: I0N00000000689188B17
       Part No SW: 5Q0 953 521 R    HW: 5Q0 953 569 A
       Revision: FF034034    Serial number: 20160617400541
       Coding: 0C10
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 41DF4517B10D51BF869-8014
    Address 17: Instruments (J285)       Labels:| User\5G0-920-XXX-17.lbl-SRI3
       Part No SW: 5NA 920 790 A    HW: 5NA 920 790 A
       Component: KOMBI         405 2153
       Coding: 07A500087F88000801883B0B1401000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009052
       VCID: 40D94013BA0758B7897-8014
    16777020 - Function Restricted due to Interrupted Communications
              U1110 00 [009] - -
              [BAP_TEL_0x28 keine Kommunikation]
                        Reset counter: 116
                        Mileage: 85901 km
                        Date: 2020.01.24
                        Time: 19:20:02
    16776966 - Databus
              [Daempfer_01 keine Kommunikation]
                        Reset counter: 116
                        Mileage: 85901 km
                        Date: 2020.01.24
                        Time: 19:19:35
    Address 18: Aux. Heat (J364)       Labels:| User\5Q0-963-272.lbl
       Part No SW: 5Q0 963 272 G    HW: 5Q0 963 272 G
       Component: STH-MQB       008 0075
       Coding: 9309
       ASAM Dataset: EV_AuxilParkiHeateWOS 002018
       VCID: 3A2D32FBDCDB0267C73-806E
       Component: R64 D208L  004 0401
       Serial number: 00000000000000050175
       Revision: --------    Serial number: 0005002497
       Coding: 030500341F087300FB07225E1E0F00010001050000000000000000000000
       ROD: EV_GatewLear_013.rod
       VCID: 7CA1F4E3966FFC5795F-8028
       Serial number: 29160001037370086211
       Coding: 2DFFFF
       Serial number: 8958780404
       Serial number: HA1-00002.04.16
       Coding: 0101
       VCID: 4ACD623B8C3B92E7573-801E
       Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
       Component: LCM_MLBevoH05 0012
       VCID: 45D75107A5257D9FBA1-8010
    Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
       Part No SW: 3Q0 907 566 E    HW: 3Q0 907 566
       Component: MRR1Rear      H21 0510
       Revision: --------
       Coding: 16C002
       Shop #: WSC 00046 000 00000
       Serial number: 300516EEU15285
       Coding: 003F0B20D000048000001000
       VCID: 43D34F1FAB1143AF945-8016
       Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
       Component: MQB_PP_APA    204 2041
       Revision: 00000000    Serial number: 0000860713
       Coding: 01010011004001
       ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
       ROD: EV_SteerAssisVWBSMQBA_008_VW37.rod
       VCID: 3D2739E7CDF5355FE21-8068
    Address 47: Sound System (J525)       Labels:| 3Q0-035-466.clb
       Part No SW: 3Q0 035 466 C    HW: 3Q0 035 466 C
       Component: MIB2_amp_P_VW H45 0210
       Revision: 00000001    Serial number: VWZ8Z1GAT00N6GR
       Coding: 1284010001A00A2AAA0000000000
       ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001016
       ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
       VCID: 2F3B13AF1799D7CF60D-807A
       Serial number: 220516EEL28614
       Coding: 003F0120DE00048000001000
       VCID: 42DD4A1BB40B4AA79F3-8016
    Address 55: Headlight Range (J745)       Labels:| User\7P6-907-357.lbl
       Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
       Component: AFS-ECU       H07 0051
       Coding: 08A200104B200201
       ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
       ROD: EV_HeadlRegulAFSMQBMAX_VW37.rod
    13705473 - Databus
              U1121 00 [137] - Missing Message
              [Fahrwerk_01 Datenbus fehlende Botschaft]
                        Reset counter: 116
                        Mileage: 85901 km
                        Date: 2020.01.24
                        Time: 19:19:35
    5275220 - Headlight
                        Reset counter: 116
                        Mileage: 85901 km
                        Date: 2020.01.24
                        Time: 19:19:35
       Part No SW: 3Q0 035 840 B    HW: 3Q0 035 840 B
       Component: MU-S--ER      710 0757
       Coding: 02730600000000005111000200080A001F0106E40120000003
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 2A0D02BB2C7BB2E7B73-807E
       Subsystem 1 - Part No SW: 7C0 919 606     HW: 7C0 919 606
       Component: ABT_HIGH  H54 1031
       Serial number: VWZ8Z9SGY005RH
       Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
       Component: Anhaenger     H21 0204
       Revision: 8A001003    Serial number: 0407247491
       Coding: 0100000202000000
       VCID: 3B2337FFD3E13B6FDC5-806E
       Part No SW: 5Q0 980 556     HW: 5Q0 980 556
       Component: RVC Compact   H09 0170
       Coding: 01230601A3002017000040
       ROD: EV_CamSysRVRVCPANAMQBAB_005_VW37.rod
       VCID: 77ABEBCFAF49DF0FF8D-8022
       Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0253
       Revision: --------    Serial number: 30718393900000
       Coding: 0A80
       ASAM Dataset: EV_DeckLidCONTIAU736 001012
       VCID: 3FDB43EFC7F9274FF0D-806A
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:| User\3Q0-980-65X-A5.lbl
       Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H06 0272
       Serial number: 07061611K13443
       Coding: 000307060000040101220047C056890088000E200040
       Shop #: WSC 25768 001 104857
       Serial number: 030616EF218555
       Coding: 002E01200101048000001000
       Serial number: 190516EEI19186
    Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
       Part No SW: 3Q0 907 590 E    HW: 3Q0 907 590
       Revision: --------
       Coding: 16C002
       VCID: 372B2BCFEFC91F0F38D-8062
       VCID: 1675C64B8803060703B-8042
       ROD: EV_LEDModLeftMELCOAU736_VW48.rod
    End----------(Elapsed Time: 02:04, VBatt start/end: 14.8V/14.8V)-----------
    It was fun to do the installation, outside was -16 degrees celsius, but luckily the garage was around 0 degrees celsius.
    Total installation time so far around 25 hours. So this retrofit is definitely not for the faint at heart
    Edit : Small clarification to installation time. I did also quite extensive sound insulation at the same time so that increased the time few hours.
  4. Likes NZDubNurd liked this post
  5. #84
    Apr 2018
    ITALY
    well the chinese harness can lie but I am sure the WDs you have from erwin don't :P DCC goes to the powertrain bus if I am not mistaken.
    so, did the menu just magically appear?
  6. #85
    May 2017
    Yes, Drive CAN is where it’s supposed to go. I knew that but I didn’t double check the wire colors
    And no menu yet, let’s see after the unit is parameterized and calibrated.
  7. Likes darkchina811 liked this post
  8. #86
    May 2017
    Hmm.... Now this is getting interesting. I swapped the CAN wires to DRIVE CAN and I even did it directly to gateway instead of using the A pillar connection point. However, now the suspension control module does not communicate with the gateway?????
    How is this even possible???
    Unit communicated just fine when it was in the wrong CAN but now in right one no? Anyone experienced this?
    I've checked that continuous power from fuse box and ignition from dashboard wiring harness is working fine.
    Is there some sort of CAN addressing memory in the gateway for the modules? So that now when I swapped the CAN it still tries to reach the DCC module through the wrong CAN where it was before?
  9. #87
    Apr 2018
    ITALY
    CAN addressing memory? not that I know of, but maybe try leaving the car battery disconnected for a while...
    sure you didn't swap L to H and viceversa? or that the twisted pair got somehow interrupted somewhere?
  10. #88
    May 2017
    I did not touch the "original" wiring. I first connected the wires to A pillar connection point, I then extended the wiring and went to gateway connection point. In both cases the result was the same, no communication.
    And it should communicate even the HI and LO would get mixed. It would then just revert to single wire mode and there would an error about it.
    I still think it must be some sort of gateway addressing issue. I checked all the power wirings and the unit is getting power. And when the unit was connected to infotainment unit, it communicated fine.
  11. #89
    May 2017
    Yihaa, now it communicates. Hard reset was needed, meaning battery disconnection. So there must be some kind of address register on the gateway and it did not update that when the CAN bus changed from infotainment to running gear CAN.
    Now the autoscan looks much much more nicer, and now I managed to run basic settings for the AFS lights as the rear sensor info is now coming through CAN instead of direct sensor connection. This is what you need to recode as well.
    So what needs recoding :
    03 - ABS, enable byte 27 bit 7, DCC
    17 - Instruments, enable byte 4 bit 4, adaptive chassis control (DCC) installed
    19 - Gateway, add 14 Susp. electronics to installation list
    55 - Headlight range control unit, disable byte 1 bit 3, this makes the leveling sensor info to come through CAN and not via direct sensor connection
    And no DCC in drive mode menu yet. Let's wait until the unit is parameterized and calibrated.
    Overall ride experience with these shocks is much much much improved over the default R-Line shocks, even they are not adjustable now. Maybe for sportier vehicles R-Line shocks are fine but for SUV, too stiff.
    Tuesday,01,January,2019,17:01:19:18875
    VIN: WVGZZZ5NZHW310427   License Plate: ....
    Mileage: 85918km-53386mi   Repair Order:
    VIN: WVGZZZ5NZHW310427   Mileage: 85918km-53386miles
    33-Flux Capacitor -- Status: Malfunction 0010
       Revision: B4X24---
       Revision: 00H12V32
       Coding: 03A8DD
       Coding: 0231567A51
              C10C5 00 [137] - -
                        Reset counter: 117
                        Mileage: 85918 km
                        Date: 2020.01.25
                        Time: 16:58:29
              B2005 00 [137] - -
                        Reset counter: 117
                        Mileage: 85918 km
                        Date: 2020.01.25
                        Time: 16:58:29
       Component: AirbagVW21    003 AirbagVW21    003 03150315
       ROD: N/A
       Coding: 80000D
       Coding: 80000D
       Subsystem 12 - Part No: -----------
       Component: PedPSensor_P2  0887
       Coding: 0C10
       Coding: 9309
       Coding: 2DFFFF
       Coding: 0101
       Revision: --------
       Coding: 16C002
       Coding: 0A80
       Revision: --------
       Coding: 16C002
    End----------(Elapsed Time: 02:14, VBatt start/end: 12.1V/12.1V)-----------
  12. Likes PetrolDave, Uwe, DV52, darkchina811 liked this post
  13. #90
    Apr 2018
    ITALY
    glad you are making progress. if you use experimental coding you will find a bit in the gateway that has DCC in the description, it's in german so no clue on what it does. I enabled it and the gateway did not complain, and we happen to have the very same gateway.
  14. Likes downtime liked this post
