Page 3 of 12 FirstFirst 12345 ... LastLast
Results 21 to 30 of 116
Thread: Dynamic Chassis Control Retrofit
  1. #21
    Apr 2018
    ITALY
    I am back home so I started the job. I connected the DCC module to the car and verified that they talk to each other. will soon parameterize with remote help, with ODIS.
    this morning I installed the level senders on the front suspensions. very easy with jacking the car and removing the wheel, one at a time.
    I have the wiring loom waiting under the battery tray, will need to extend and reach both suspensions, need to remove the wipers and plenum wiper covers. also wheel arch cover maybe.
    I am looking for a garage that will replace the shocks for me, I never did it so I am not comfy without help.
    my Golf came out of the factory with 13 ECUs. now she has 20. and counting
  2. #22
    Apr 2018
    ITALY
    found the garage willing to replace the shocks, it's scheduled for the 18th. he was surprisingly reasonable with the labor price.
  3. #23
    ^^^^ darkchina: good to read that soon the module count will be 20 (don't forget to change your signature)..........and thanks for venturing all the way to the deep south for the cuppa and the chat.
  4. #24
    Apr 2018
    ITALY
    it was a pleasure to meet you Don.
    today I finished the wiring on the front axle. it's not necessary to remove the wheel arch cover. I pulled the wiring looms following the brake lines. the left one enters the engine bay just behind the battery and the right one close to the ABS module. the right one then makes its way under the battery by running along the plenum chamber.
    I also installed and wired both acceleration sensors, there are threaded holes under the wipers, one per side.
    tomorrow I'll run wiring for the rear axle.
  5. #25
    Apr 2018
    ITALY
    I did pull wires for the two rear shock valves. however it is really uncomfortable (for me) to lie on the ground and the car is really low. I mean, I could not pull the wiring from the left side of the car, to the right shock.
    also I need to buy some heat insulating sleeve because the route I have chosen is a little too close to the exhaust.
    so I'll probably finish while the mechanic is replacing the shocks, it will be much easier with the car raised on the bridge.
  6. #26
    May 2017
    ^ Why not pull the wiring inside? There’s pass through rubber behind battery tray on the firewall and another behind the passenger footwell. ABS wires go through wheel arches from inside and it’s easy to make small punctures to the rubber grommets to pull the wires through.
    And it saves you the hassle of removing rear bumper to pull the cables to the DCC module.
  7. #27
    Apr 2018
    ITALY
    I am talking about rear shock valves. wires go from the DCC module (inside the trunk on the left) to the shocks. I reached the left shock and to reach the right one I will tie the cable (with sleeve of course) UNDER the car, but it's close to the exhaust.
    anyway. we did parameterization for the module tonight, online with ODIS.
    I added module 14 to gateway installation list;
    I recoded 03 ABS module for DCC;
    I recoded 17 cluster for DCC;
    I am now left with these errors in DCC module
    Address 14: Susp. Elect.       Labels: 5Q0-907-376.clb
    Control Module Part Number: 5Q0 907 376 B    HW: 5Q0 907 376 A
      Component and/or Version: DAEMPFUNGS-SG H17 0121
               Software Coding:
                Work Shop Code:
                  ASAM Dataset: EV_DRCONTITEMIC 001019 (VW37)
                           ROD: EV_DRCONTITEMIC_VW37.rod
                          VCID: 3829D4F302D22547317-806C
    9 Faults Found:
    278272 - Basic Setting of Deflected Position not Performed
              C10C5 00 [137] - -
                        Reset counter: 125
                        Mileage: 36630 km
                        Date: 2019.12.15
                        Time: 00:25:05
    835584 - MIL Request Signal Active (Check TCM for errors too!)
              P1624 00 [137] - -
                        Reset counter: 125
                        Mileage: 36630 km
                        Date: 2019.12.15
                        Time: 00:25:26
    835328 - MIL Request Signal Active (Check TCM for errors too!)
              P1624 00 [008] - -
                        Reset counter: 165
                        Mileage: 36630 km
                        Date: 2019.12.15
                        Time: 00:25:05
    36105 - Chassis Acceleration Sensor; Rear
              C10BA 01 [009] - Electrical Failure
                        Reset counter: 125
                        Mileage: 36630 km
                        Date: 2019.12.15
                        Time: 00:25:05
    198154 - Rear Left Ride-Height Sensor
              C1036 15 [009] - Open or Short to Plus
                        Reset counter: 125
                        Mileage: 36630 km
                        Date: 2019.12.15
                        Time: 00:25:05
    36363 - Valve for Damping Adjustment Front Left
              C1040 13 [137] - Open Circuit
                        Reset counter: 125
                        Mileage: 36630 km
                        Date: 2019.12.15
                        Time: 00:25:23
    36619 - Valve for Damping Adjustment Front Right
              C1041 13 [137] - Open Circuit
                        Reset counter: 125
                        Mileage: 36630 km
                        Date: 2019.12.15
                        Time: 00:25:23
    36875 - Valve for Damping Adjustment Rear Left
              C1042 13 [137] - Open Circuit
                        Reset counter: 125
                        Mileage: 36630 km
                        Date: 2019.12.15
                        Time: 00:25:23
    37131 - Valve for Damping Adjustment Rear Right
              C1043 13 [137] - Open Circuit
                        Reset counter: 125
                        Mileage: 36630 km
                        Date: 2019.12.15
                        Time: 00:25:23
    two sensors and the 4 shocks are still disconnected so that's ok. after I replace the shocks and connect everything I will try basic settings.
    what is weird is that I cannot see DCC settings on any menu. DCC is supposed to appear under Driving MODE menu (which is a FeC, and my car has it from stock).
    I remember, when I did ACC retrofit I enabled one bit in gateway coding, thanks to experimental coding. after that ACC showed into Driving MODE menu.
    so I looked for something similar for DCC and I enabled BYTE 9 BIT 7 in gateway experimental coding.
    still I don't see any DCC into any menu.
    I wonder if there is something else to enable, maybe in 5F?
    there is very little information on DCC retrofit as it's not very popular.
    some Jimmy did it in Singapore, did a few actually, but he does not answers emails or social media.
    somebody on drive2.ru did it on Octavia but I don't know how to get ahold of him.
    maybe it just needs basic settings, we'll see.
    fingers crossed.
  8. #28
    Apr 2018
    ITALY
    today I installed the rear acceleration sensor, it's in the trunk on the left side, behind the carpet, very close to the DCC module. I needed a rivet tool for "nutserts", which I bought and will come handy for other DIY stuff.
    I also moved the rear height sensor from module 55 to the DCC module. module 55 needed to be recoded (sensor is not direct anymore but over CAN, thank you experimental coding). module 55 also asked for basic settings, piece of cake.
    I am now down to 6 errors in the DCC module: the 4 valves, no basic settings, and a MIL request.
    baby steps lol
  9. Likes Uwe, downtime liked this post
  10. #29
    May 2017
    Yes it does. Blind spot monitor retrofit needs this one for the rear radar sensors. One of the connection points needs this tool.
    This DCC retrofit is interesting. It's something that I've been considering along with 360 camera one. Only gripe is that it's not very easy to source parts for Tiguan. DCC module is easy but everything else no
  11. #30
    Apr 2018
    ITALY
    I remember reading something about the fixings, before I did the BSD retrofit. when I actually pulled the bumper to install the radar, everything was there and I ended up not needing the tool. whatever
    I don't know what MY your Tiguan is, I did the research for a 2017 just out of curiosity. front shocks are 3C0 413 031 D and you can find them on VW CC / Eos / Passat / Passat CC / Tiguan / Touran, so there are quite a few on the online market, even used if you trust used shocks. rear shocks are 5N0 513 045/6 A/B and they exist only on Tiguan, these are of course more difficult to find.
    for me the shocks were the most difficult to source, I almost bought Bilstein and then I found the OEMs for a real deal. all the sensors can be easily found, and the wiring can be home made by any hardcore retrofitter.
